上海欧桥电子科技有限公司
  • GPS定位及时钟基准系统
  • 发布时间:2008/5/21 11:02:52   修改时间:2008/5/21 9:31:57 浏览次数:2627
  •  GPS定位及时钟基准系统
    RF分路设备
    4092A IRIG-B Autosense Fault Switch
    产 品 说 明
    The 4092A is a 1U rackmount fault sense switch that accepts two IRIG-B signals and produces eight outputs (chosen from the two inputs). The unit comes standard with a single HOT SWAP AC power supply and can be configured with redundant HOT SWAP AC or DC power supplies. It has LED indicators that display the selected input as well as a control switch that is used to manually operate the switch or place the switch in uto?mode. When in uto?mode, the unit automatically switches upon failure of the selected input. In addition to front panel control, the unit can be controlled remotely via the Ethernet port on the rear of the unit.
     避雷器
    DAS-BT-DFDM-01 | 1500-2500MHz 2.1MHz
    产 品 说 明
    TECHNICAL SPECIFICATIONS Customer Print
    Application:  AISG test   Data Connector:  NA
    Freq. (MHz):  800-2700   Protected Side Connector:  7/16" Din Male
    Surge Side Connector:  7/16" Din Female   Telemetry:  2-5 MHZ
    Telemetry Insertion Loss:  1 dB   Insertion Loss (dB):  0.1
    Unit Imp. (Ohms):  50 Ω   Mounting:  Bulkhead
    RF Power (Watts):  750 Watts   Throughput Energy (µJ):  ≤ 25.0000 μJ
    Turn On Voltage (Volts):  33 V   UL Approved and Listed:  No
    VSWR:  1.1:1   Weatherized:  Yes
    RELATED FAMILIES:
    AirSmart
    DAS
    UMTS
    DAS-HY-DFDM-06 800-2500MHz 2.1MHz ANT
    产 品 说 明
    DAS-HY-DFDM-06 | 800-2500MHz 2.1MHz ANT
    Application:  Coax test   Data Connector:  8 Pin Circular Female
    Freq. (MHz):  800 - 2500   Protected Side Connector:  Din Male
    Surge Side Connector:  Din Female
    RELATED FAMILIES:
    AirSmart
    DAS
    DC50LNZ+15 | Pickor Protector
    产 品 说 明
    Freq. (MHz):  400-960   Max Oper. Current (Amps):  2.50 A
    Protected Side Connector:  N Female   Surge Side Connector:  N Female
    Turn On Voltage (Volts):  18 V   Insertion Loss (dB):  0.3
    Oper. Voltage (Volts):  15 V   RF Power (Watts):  Receive Only Watts
    VSWR:  1.2:1   Weatherized:  No
    RELATED FAMILIES:
    LNZ
    Tower Top
    RELATED PRODUCTS:
    DC50LNZ+15-MA DC50LNZ+15-ME
    航天,国防,航空用设备
     4415 Digital Cesium Frequency Standard
    产 品 说 明
    Symmetricom's 4415™ Cesium Frequency Standard is a compact, self-contained module that produces accurate, stable and spectrally pure sinusoidal signals. The 4415 satisfies system applications with stringent requirements for precision time and frequency in ground based satellite communication systems, telecommunications synchronization systems and satellite-based timing systems.
    9250 Low Profile Military OCXO
    产 品 说 明
    The Symmetricom 9250 is a military OCXO designed for ground tactical and airborne applications where superior frequency stability and phase noise are required. Advanced communications, navigation and targeting systems require precision oscillators that can withstand a wide range of operating environments with minimal degradation in frequency accuracy and stability. The 9250 is part of a new family of low g oscillators from Symmetricom that support these applications.
    The 9250 is unique in that it combines excellent frequency stability and low dynamic phase noise in a small, low profile package. The 9250 achieves less than ?00dBc phase noise at 1Hz from the 10MHz carrier.
    The 9250 is based around an ovenized 10 MHz, 3rd-overtone SC-cut crystal resonator
    enclosed in a hermetically sealed 1.50?x 2.76?x 0.9?H package. All inputs and outputs are accessible via feed-through pins on the side of the chassis. The small, low profile package allows for easy integration into complex subsystems where space is at a premium.
    Symmetricom抯 9250 can be made available with other output frequencies with varying levels of stability. Please contact the factory for custom output requirements.
    9210B Military OCXO
    产 品 说 明
    The Symmetricom 9210B is a COTS military OCXO designed for ground tactical and airborne applications where superior frequency stability and phase noise are required. The 9210B is well suited for these applications as it provides superior phase noise performance, which is critical for radar applications and precise frequency accuracy and stability which is critical for secure communication and navigation applications.
    The standard oscillator is available in either 5 or 10MHz output configurations, both of which provide excellent frequency stability and phase noise performance in static or dynamic environments.
    For more challenging dynamic applications where phase noise under vibration is a key specification, a low G sensitivity option is available that improves g sensitivity to
    <2e-10/g.
    The 9210B is based around a double oven SC cut crystal resonator enclosed in an industry standard 2.0” x 2.0” x 1.25” package.
    9500 Satellite Master Oscillator
    产 品 说 明
    Symmetricom's 9500 is a master oscillator that produces a highly stable, low noise reference frequency output. Particularly suited to space applications, it delivers superior stability performance unsurpassed in the commercial community.
     9400 Satellite Master Oscillato
    产 品 说 明
    Symmetricom's 9400 is a master oscillator that produces a highly stable, low noise, reference frequency output.
    Symmetricom’s 9633 Low g Sensitivity Military OCXO is made for next generation m
    产 品 说 明
    Symmetricom’s 9633 Low g Sensitivity Military OCXO is made for next generation military navigation, radar and secure communications. Designed to withstand a wide range of operating environments, the 9633 is ideally suited for ground tactical and airborne applications where superior frequency stability and phase noise are required.
    The 9633 achieves its superior dynamic phase noise performance by utilizing both electronic and mechanical compensation techniques to provide up to 40dB of compensation when operating under vibration. Acceleration sensitivity of <2 E-11 per g (gamma) over wide frequency ranges can be achieved.
     9700 HF Aerospace Oscillator Series
    产 品 说 明
    Symmetricom's 9700 is an ultra-miniature ovenized crystal oscillator designed to provide a high stability RF sine wave output.
     9920 & 9940 Hybrid Space Qualified Crystal Oscillat
    产 品 说 明
    Symmetricom thirty-five years of legacy of high reliability and performance quartz oscillators are now available in hybrid construction for applications that require minimal size, weight and power. The model 9920 and 9940 are crystal oscillators( XO) and voltage controlled crystal oscillators( VCXO) based on hybrid manufacturing technology.
    The 9920 and 9940 series of oscillators utilize 3rd or 5th overtone AT cut crystals in a Colpitts configuration with optional multiplication circuitry and output amplifier or driver stages. The precision crystals are contained within hermetic or vacuum sealed packages housed within the hybrid circuit package resulting in the lowest end of life
    frequency drift possible.
    Output type and package are available in industry standard configurations to meet standard and custom applications.
    These hybrid oscillators are based on heritage designs and manufacturing techniques proven for reliability in numerous space applications. The hybrids are manufactured in a mil-prf-38534 class K facility in a class 100,000 clean room that provides for the maximum reliability.
    The 9920 and 9940 have demonstrated excellent performance after exposure to high levels of shock, vibration and radiation consistent with the rigorous requirements of space applications.
    9960
    产 品 说 明
    Symmetricom抯 thirty-five years of legacy of high reliability and performance quartz oscillators are now available in hybrid construction for applications that require minimal size, weight and power. The model 9960 is a temperature compensated crystal oscillator (TCXO) capable of fixed frequency and voltage controlled operation and is based on hybrid manufacturing technology.
    The 9960 series of oscillators utilize 3rd or 5th overtone AT cut crystals in a Colpitts configuration with optional multiplication circuitry and output amplifier or driver stages. The precision crystals are contained within hermetic or vacuum sealed packages housed within the hybrid circuit package resulting in the lowest end of life frequency drift possible. Compensation is achieved by characterization of the individual crystals over temperature and the incorporation of specific components to offset the effect of changes in the temperature.
    The model 9960 has demonstrated excellent performance after exposure to high levels of shock, vibration and radiation consistent with the rigorous requirements of space applications.
     网络时钟测量
     Network Time Displays
    产 品 说 明
    Symmetricom's Network Time Displays are maintenance free clocks that keep accurate time by synchronizing their time – over the network – to a network time server. The ND-2 and ND-4 use existing Ethernet network infrastructure and the standard network time protocol (NTP) to keep the time correct. Select between several time display formats including 12 or 24 hour format. All international time zones are supported as well as daylight savings time transitions so that the display should never need the time adjusted.
    SyncServer S200
    产 品 说 明
    Easy To Set Up – Easy To Maintain
    The S200 is the easiest to set up and maintain network time server in the world. The front panel is designed to quickly bring the time server online with a few front panel keystrokes or DHCP. To fully configure the unit, use the very intuitive web interface. The S200 is also the first network time server to offer Wizard step-by-step set-ups for the most common time server operations. The state-of-the-art user interface offers the network administrator ease-of-use and remote access, with intuitive web pages and full control of the server via a standard browser interface.
    Highly Robust And Secure
    The S200 provides reliable and secure network synchronization technology by combining multi-port, high-speed/ high-capacity network interfaces and versatile GPS timing receiver technology. It supports a wide range of network protocols including IPv4 and IPv6, for easy management and seamless integration into your existing and future network.
    Unmatched High Performance With Unparalleled Flexibility
    The SyncServer S200 has three dedicated and isolated 10/100Base-T Ethernet ports, each with their own Ethernet processor. These multiple ports provide the flexibility to adapt to different network topologies as networks grow and change. Security sensitive networks have the option of using one port for secure maintenance and control functions and the other two for NTP timing functions. And all of this is connected to a high speed processor and a nanosecond clock to assure high bandwidth NTP performance for hundreds of thousands of network clients.
    Perfect Timing
    The Stratum 1 level SyncServer S200 derives its time directly from the atomic clocks aboard the GPS satellite system. By using the integrated, 12-channel GPS receiver, every visible satellite can be tracked and used to maintain extremely accurate and reliable time. If the GPS reference signal is ever lost, the S200 can automatically revert to a Stratum 2 mode and retrieve time from other user-designated time servers. Another option is that the S200 can be upgraded to an internal Rubidium atomic oscillator that keeps the S200 accurate to 25 microseconds per day.
    Customer Tested Design
    As a 5th generation Symmetricom time server, the S200 has decades of design experience behind it. Customer input is evident in every detail. The front panel is designed for quick setup, informative clear presentation of time and status, and convenient physical access to the console ports. The rear panel is configured with those connections that are changed infrequently, such as power, GPS antenna, and network ports. Keypad operation is quick and easy when using the full numeric keypad and control keys.
    NTS-150 GPS Network Time Server
    产 品 说 明
    Symmetricom's Stratum 1 level NTS-150 derives accurate time directly from the atomic clocks aboard the GPS satellite system. By using an integrated, 12-channel GPS receiver, every visible satellite can be tracked and used to maintain accurate and reliable time. Even in urban canyon environments where satellite visibility can be limited, the automatic, single satellite tracking mode provides accurate time from as few as one intermittent satellite and can also track satellites using a window mounted antenna. A GPS antenna and cable is included.
    4420A GPS Internal Rb Reference
    产 品 说 明
    The TSC 4420A is a time and frequency recovery system that generates precise signals traceable to UTC, including a Stratum 1 NTP server. It utilizes a GPS disciplined rubidium frequency reference to provide timing outputs characterized by the short-term stability of the atomic reference and the long-term stability of GPS. The versatility of the TSC 4420A makes it suitable for a variety of applications. It provides multiple copies of 5 different timing signals on the rear of the 1U-high, 19" rack-mount chassis. Year, day, and time of-day are displayed on the front panel. The standard Ethernet connection simplifies integration with complex systems by allowing health and status information to be monitored remotely.
    4422A IRIG-B Crystal Oscillator Reference
    产 品 说 明
    The TSC 4422A is a system that generates precise time and frequency signals referenced to an IRIB-B input. It utilizes a crystal frequency reference and IRIG-B to provide NTP server capability and multiple timing outputs characterized by the short-term stability of the crystal reference. The versatility of the TSC 4422A makes it suitable for a variety of applications. It provides multiple copies of 5 different timing signals on the rear of the 1U-high, 19" rack-mount chassis. Year, day, and time-of-day are displayed on the front panel. The standard Ethernet connection simplifies integration with complex systems by allowing health and status information to be monitored remotely.
     TSC 4421A GPS Internal Crystal Oscillator Reference
    产 品 说 明
    The TSC 4421A is a time and frequency recovery system that generates precise signals traceable to UTC, including a Stratum 1 NTP server. It utilizes a GPS disciplined crystal frequency reference to provide timing outputs characterized by the short-term stability of the crystal reference and the long-term stability of GPS. The versatility of the TSC 4421A makes it suitable for a variety of applications. It provides multiple copies of 5 different timing signals on the rear of the 1U-high, 19" rack-mount chassis. Year, day, and time-of-day are displayed on the front panel. The standard Ethernet connection simplifies integration with complex systems by allowing health and status information to be monitored remotely.
     精确时钟基准
     5071A
    产 品 说 明
    Symmetricom’s 5071A primary frequency standard delivers unsurpassed accuracy, stability and reliability for the most demanding laboratory and field applications.
    Cs4000
    产 品 说 明
    The Symmetricom Cs4000 is a new cesium frequency standard platform that provides exceptional performance in a configurable 3U rack mount chassis. The Cs4000 is designed for high precision timing and frequency applications requiring high stability, low noise RF and 1PPS reference signals. Symmetricom's advanced Cesium III digital technology is the engine that drives this exceptional performance.
    The Cs4000 includes a new color front panel Graphical User Interface (GUI) that provides easy to use monitoring and control of the instrument. All functional control of the cesium and optional output cards are managed via the front panel GUI. The GUI is a touch panel LCD screen that provides easy at a glance access to cesium health, control and configuration data. Remotely, you now have two methods of interfacing with the Cs4000. A new Ethernet interface provides monitoring capability via an embedded web page server. Both static IP and DHCP are supported. The Cs4000 also provides an RS-232 port that allows the user comprehensive monitor and control access via ASCII commands or via Symmetricom抯 Monitor 3 windows based utility
    program.
    The Cs4000 is designed to provide standard and custom output signal formats. The standard outputs include, 100kHz, 1, 5, 10MHz and 1PPS. Optional outputs include T1 and E1 both of which support multiple signaling and alarming formats. Realizing that custom signaling is part of many system designs, the Cs4000 has a custom output area that can support most signaling requirement. Because of this, the standard output signals are not affected and can be utilized along with whatever custom format is required.
    The Cs4000 meets the challenges of laboratory standards, satcom terminals, mobile communications systems and a wide variety of test and measurement applications.
     CsIII
    产 品 说 明
    Symmetricom's CsIII™ is a lightweight, compact, economical cesium frequency standard. The technology developed for the CsIII is an evolutionary step forward in the quest for higher stability, lower phase noise and longer life. An ever-increasing base of demanding users in communications, timing, synchronization and other applications take advantage of this performance.
    Packaged in a 2U, 19" rack mounted chassis; the CsIII weighs less than 30 lbs. Standard features include 5 and 10Mhz sine wave outputs, a 1 PPS output and an RS-232 interface used to monitor and control the unit. Optional T1/E1 telecom outputs and a portability kit are also available. The portability kit replaces the rack mounting brackets with a movable handle and hard shell carrying case making it ideal as a remote calibration standard.
     DRCBT
    产 品 说 明
    Symmetricom's cesium beam tube replacement services offer you both time and cost savings. Installation of a replacement tube restores your cesium instrument's tube performance and can extend your cesium instrument's life span at a fraction of the cost of a new instrument. The appropriate high or standard performance replacement cesium beam tube meets or exceeds the original performance levels when all other components of the instrument perform to original specifications. We offer cesium beam tube replacement for all Symmetricom cesium instruments and many models of cesium instruments formerly manufactured by Hewlett-Packard? Agilent?and Datum?
     1050A
    产 品 说 明
    Symmetricom's 1050A Quartz Frequency Standard is a multiple output instrument suitable for 19" rack mounting. The instrument features a selected third overtone SC-cut precision quartz crystal with drive levels optimized for very low aging, excellent short and long term frequency stability, and retrace characteristics.
    The quartz crystal oscillator exhibits unusually high spectral purity at frequencies close to the carrier frequency permitting multiplication to millimeter-wave frequencies with excellent signal-to-noise ratio. A single stage, solid-state oven, advanced design and careful component selection techniques ensures the instrument’s highly stable operation and ruggedness, normally operated from a 115 or 230 VAC, 47 to 400 Hz power source, the instrument also offers a built-in standby battery and internal battery charger. Switch over to this internal battery is automatic in the event of external power failure.
    Operating controls and monitors are conveniently located on the front panel. LED status monitors indicate Power On, Power Alarm, Oven Ready (oscillator at operating temperature) Battery On and Battery Charge. A built-in meter and thumb wheel switch permit monitoring of supply voltage, control voltage, oscillator oven and battery voltage and battery charging current. Five digital thumb wheel switches permit offset of the frequency over a range
    of 4.0E 7. Rear panel connections include fused power input connections and 1 MHz, 5 MHz and 10 MHz output BNC connectors. 1 PPS outputs are also available. A frequency-control voltage can be applied through a BNC connector for external tuning of the crystal oscillator.
    The 1050A satisfies a wide variety of applications with stringent requirements for precision time and frequency in radar systems, missile range timing systems, deep space communications, satellite command terminals, GPS monitoring stations, calibration labs and test equipment
    1000B
    产 品 说 明
    Symmetricom's 1000B achieves low aging rates by utilizing high performance SC-cut quartz crystal resonators. The specified aging is reached within 30 days of continuous operation, and typically continues to improve. Several users report observed aging rates as low as 1.0E-12 per day after years of continuous operation.
    A dewar-insulated oven provides superior temperature stability over the full temperature range. The maximum frequency change over the operating temperature range is <5.0e-9. An oven temperature indicator (10mV per degree K) is provided at the power connector.
    The oscillator circuit produces phase noise of -116 dBc at 1 Hz and -160 dBc at 10 kHz. Low noise,
    high isolation buffer amplifiers provide two or four independent outputs. The buffer amplifiers isolate outputs from load variations. An internal voltage regulator minimizes fluctuations due to power supply ripple.
    Linearized electronic frequency control allows the use of servo loop techniques for fine frequency tuning. Linearity is better than 5% over the specified tuning range.
    The 1000B crystal oscillator meets the demands of a wide range of applications for military and industrial environments. The oscillator is found in precision frequency counters and synthesizers, GPS receivers, microwave multiplier chains, phase noise calibration test equipment, Stratum II telecommunications applications, radar and tactical communications systems, secure communications systems, satellite ground terminals and space flight systems.
     8130A
    产 品 说 明
    The Symmetricom 8130A is an enhanced version of our popular M-100 rubidium oscillator. This modern, off-the-shelf militarized rubidium oscillator is ideal for use in tactical applications where shock, vibration, humidity and other environmental factors are a challenge. The circuit boards are conformal-coated for moisture resistance, and special precautions are taken for improved shock and vibration hardening. Use of a filtered power/monitor connector minimizes EMI emissions and susceptibility. Designed for ease of integration into frequency and timing systems, the Symmetricom 8130A offers a smaller size MIL atomic frequency reference with a heritage of over 25 years of proven experience in the design, qualification and production of atomic frequency references.
    The long life rubidium lamp and extended crystal oscillator control range of the Symmetricom 8130A minimizes maintenance requirements. The Plastic Encapsulated Microcircuits (PEM) devices are subjected to a proprietary qualification process for improved reliability.
    The 8130A provides a stable frequency with good short and long-term stability, and excellent overall performance. The unit includes an RS-232 digital interface for monitoring and frequency adjustments. Suitable applications include ground, shipboard and airborne navigation, timing and other tactical applications that need the performance level associated with rubidium technology in a militarized off the- shelf package.
    8100
    产 品 说 明
    The Symmetricom 8100 is an enhanced version of our popular commercial LPRO rubidium oscillator. This ruggedized COTS rubidium oscillator is ideal for use in tactical applications where shock, vibration sensitivity, excess relative humidity and other environmental effects are a challenge. Designed for ease of integration into frequency and timing systems, the Symmetricom 8100 offers a low profile and single circuit board construction that uses surface mount technology. The circuit board is conformal-coated for increased moisture resistance, and special precautions are taken for improved shock and vibration tolerance. The height and footprint easily meet the requirements for 1U VME applications. Use of both a filtered D-Connector for I/O signals and an outer mu-metal cover minimizes EMI emissions and susceptibility. For ease of integration, the Symmetricom 8100 only needs one input supply voltage and will allow direct plug-in into another circuit board.
    The long life rubidium lamp and extended crystal control range of the 8100 helps extend operating periods, minimize maintenance and gives acceptable performance of more than a decade. By design, the Symmetricom 8100 provides a stable frequency with good short and long-term stability, and excellent spur
    performance. A 5V CMOS-compatible alarm signal derived from the basic physics operation indicates when output frequency is outside roughly +5.0E-8 of absolute frequency offset. The low temperature coefficient and excellent frequency stability extend holdover performance.
    Suitable applications include shipboard, airborne, navigation timing, range timing and other tactical applications that need the performance level associated with rubidium technology in a commercial off the shelf (COTS) package.
     8040C
    产 品 说 明
    Today’s precision test equipment requires a stable reference to make accurate frequency measurements. The Symmetricom 8040C solves this problem by providing a stable and accurate frequency reference with multiple output signal formats in an easy to install 1U rack mountable chassis.
    Unlike other units, the 8040C offers configurable RF outputs, GPS disciplining and a RS-232 interface for command and control.
    The 8040C is field configurable, allowing the instrument to support changing functionality in evolving systems.
    The 8040C is designed around Symmetricom’s award winning X72 rubidium oscillator, which is deployed worldwide as the reference oscillator in wireless base stations.
    RubiSource T&M
    产 品 说 明
    The RubiSource T&M is a portable timing reference based on Symmetricom's well known rubidium oscillator technology for universal use in test and measurement applications. A variety of coherent standard frequencies are provided:
    ·  Sine wave 10 MHz, 5 MHz & 1 MHz
    ·  Square wave 10 MHz & 5 Mhz
    The RubiSource T&M's 1 PPS output signal provides exact timing information. This output can be synchronized to an external 1 PPS input signal.
    The reliable output signals are based on the highly accurate and stable rubidium oscillator inside. The rubidium's fast warm-up eliminates the need for bulky backup batteries.
    The RubiSource T&M can be locked to an external primary source such as a GPS receiver or cesium Standard for automatic frequency calibration of the rubidium oscillator and/or enhancing the intrinsic rubidium accuracy to near-cesium quality.
     RF 自感应切换分路器
    6502B RF Distribution Module
    产 品 说 明
    The Symmetricom 6502B Distribution Module is a ten channel, RF distribution amplifier packaged in a 1U rack mount chassis. It is comprised of ten low phase noise RF amplifiers that maintain high channel isolation (>100dB). Up to ten units can be daisy chained together to give up to 100 outputs or each output of one unit can be used as a source for other 6502B units to give almost infinite expansion capability with virtually no signal degradation.
    The 6502B standard configuration accepts input frequencies from 0.1MHz to 10MHZ at 1Vrms amplitude and provides ten buffered outputs of the same frequency. Each output and input has an alarm indicator that warns of either a loss of signal or a signal of insufficient amplitude.
    The 6502B is also available in custom configurations.
    6504B IRIG B Distribution Module
    产 品 说 明
    The Symmetricom 6504B Distribution Module is a ten channel, IRIG B distribution amplifier packaged in a 1U rack mount chassis. It is comprised of ten low phase noise RF amplifiers that maintain high channel isolation (>100dB). Up to ten units can be daisy chained together to give up to 100 outputs or each output of one unit can be used as a source for other 6504B units to give almost infinite expansion capability with virtually no signal degradation.
    The 6504B standard configuration accepts an IRIG B time code signal and provides 10 buffered IRIG B outputs. Each output and input has an alarm indicator that warns of either a loss of time code or a time code of insufficient amplitude.
    The 6504B is also available in custom configurations.
    6520A Telecom Distribution Module
    产 品 说 明
    Symmetricom's 6520A Telecom Distribution Module is a twelve channel distribution amplifier packaged in a 1U rack mount chassis. It is comprised of twelve low phase noise amplifiers that maintain high channel isolation (>60dB). Up to four units can be daisy chained together to give up to 48 outputs with virtually no signal degradation.
    The 6520A standard configuration takes a single telecom clock signal, either T1 or E1, and provides twelve buffered T1 or E1 outputs. Each output and input has an alarm indicator that warns of either a loss of signal or a signal of insufficient amplitude.
    The 6520A is ideal for manufacturers who need to distribute high quality telecom reference signals to multiple locations.
    The 6520A is also available in custom configurations.
     6602B Pulse Distribution Module
    Symmetricom's 6602B Pulse Distribution Module is a ten-channel, pulse distribution amplifier packaged in a 1U rack mount chassis. The 6602B buffers and provides one pulse per second signal distribution to ten separate locations. The module’s summary fault alarm output feature indicates an alarm whenever there is a single output fault condition.
    The 6602B preserves input phase characteristics over a wide range of environmental conditions. A daisy chain of up to ten Symmetricom 6602B modules provides up to 100 output signals or with each output of one module as the input signal for other modules it provides almost infinite expansion capability with minimal signal degradation.
     9611 Switch & Distribution Unit
    产 品 说 明
    Symmetricom’s 9611 Switch & Distribution Unit is an intelligent switching, monitoring and distribution system, packaged in a 1U rack mount chassis. It includes a dual input A-B switch that provides a powerful redundant capability.
    The internal microprocessor can be set up to switch on a number of criteria (i.e., voltage level and period detection). Internally, the unit can be configured to direct selected signals to up to twelve independently buffered outputs. Each output can be set for internal monitoring of the output signals. In addition, each output system can be set up as a signal monitor. Any single-ended type signal can be connected to any output line and that line can be configured to simply monitor the signal. The input signal can be connected to any output buffer for additional distribution of the input signal.
    The internal microprocessor is controlled, configured and monitored by means of an RS-232 input/output port. Switch status as well as output status is reported on the front panel for immediate feedback of information to the operator as well as via the RS-232 port. A second connector on the rear panel allows up to thirty-two units to be daisy-chained and controlled via a single serial port on the computer.
    This universal and highly versatile instrument is unequalled in the industry. No other low cost system offers these capabilities in a single product.
    58502A Broadband Distribution Amplifier
    产 品 说 明
    The Symmetricom 58502A Broadband Distribution Amplifier is the one frequency standard distribution system that provides multiple features to ensure continuous distribution of your critical signals. It is designed to meet today’s demanding requirements for frequency distribution in manufacturing, R&D, and standards lab environments. It also provides economical distribution of precision signals from cesium, rubidium, quartz or GPS frequency standards.
    The 58502A Broadband Distribution Amplifier features low signal distortion and high isolation between output channels. Low output phase noise also helps maintain signal integrity.
     56000 Modular Time & Frequency Distribution System
    产 品 说 明
    Symmetricom's 56000 is a versatile Data Rate Clock (DRC) and Distribution System supporting an extensive variety of input references, oscillators, output frequencies, input/output interface styles, powerful network based management tools, and complete power supply plans. The modular architecture supports various clock rates and frequencies required in today’s sophisticated communications applications.
    The 56000 backplane can accept 1, or 10 MHz; IRIG B time code; and any TTL signal from DC to 10Mbps. Multiple redundant external frequency references can be applied to a hitless switch (passive combiner) located on each frequency synthesizer circuit card. The hitless switch provides a glitch-free transition from one input source to another, ensuring reliable and disturbance-free outputs, even in the event of failure of one of the input sources. The frequency reference inputs can be replaced or enhanced by an on-board oscillator circuit card or an on-board GPS timing receiver. The oscillators are disciplined to either the input frequency or GPS. Using the oscillators in combination with external reference inputs provides various levels of redundancy. The oscillators also add holdover capability so that
    uninterrupted operation is maintained in the event of total failure of the reference input(s).
    Model 56000 outputs can include distributed or generated clock signals, frequencies, Network Time Protocol, and IRIG B time code. N.1 clock rate generation from 1Hz to 25MPPS in 1 PPS steps is available in addition to N.8 clock rate generation from 8 KPPS to 8.192 MPPS in 8KPPS steps. Also available is a Telecommunications Interface that provides a variety of outputs and alarms common in today’s telecommunications applications. The chassis is configured with front and rear plug-in cards. The front panel plug-in circuit cards perform the modular rate generation and distribution functions and are hot swappable. The rear panel interfaces are also implemented using plug-in cards with a wide variety of connector types and styles. Of the 21 card slots available, four are reserved for the power supply(s), and the balance can hold almost any combination of available circuit cards. The basic chassis includes power supply, power input module, fault monitoring CPU and a CPU interface module. There are 16 available card slots for the various synthesizer/distributor cards. Additional 56000 systems can be daisy chained using an optional on-board fiber optics transmitter and receiver pair. Large networks of time-frequency distribution can be constructed using the fiber optics link.
    5087B Wideband Distribution Amplifier
    产 品 说 明
    The 5087B wideband distribution amplifier is an economical solution for distributing signals from various frequency standards such as Cesium, Rubidium, Quartz or GPS receivers.
    The 5087B is a perfect solution for standards laboratories that need simultaneous calibration of multiple test equipment. For manufacturers or R&D labs, the 5087B with its 12 channel wideband sine wave distribution can connect all test equipment in a rack to the same frequency source. And if you need to distribute frequency standards from the calibration lab to the manufacturing or R&D facility, the high output-to-output isolation and output-to-input isolation keeps the effects of “accidents” from propagating to other channels or upstream to the frequency standard.
    Front panel lights allow you to check status of the amplifier at a glance. Indicators are provided for power, alarm, input, and all 12 outputs. An alarm occurs whenever there is loss of input signal, or loss of any of the 12 outputs. Full remote control and monitoring of the amplifier can be done through the Ethernet port, including checking status and alarm conditions.
    4032A 1x15 TTL Pulse Distribution Amplifier
    产 品 说 明
    The 4032A is a one-input, fifteen-output pulse distribution amplifier in a 1U,19-inch rack mount chassis. It provides fifteen isolated outputs from a single input. An Ethernet port on the rear panel provides the capability to remotely monitor the status of the input and all output signals. Any failure in the unit will immediately provide an alarm to the Ethernet port. The front panel provides green LED status for the input and green/red for all output signals, as well as indicating an input of 1 PPS, DC IRIG, or Other. The 4032A can be configured to custom requirements.
     4032A-IO 1x15 Pulse Distribution Amplifier with Isolated Outputs
    产 品 说 明
    The 4032A-IO is a one-input, fifteenoutput pulse distribution amplifier in a 1U, 19-inch rack mount chassis. It provides fifteen isolated outputs from a single input. An Ethernet port on the rear panel provides the capability to remotely monitor the status of the input and all output signals. Any failure in the unit will immediately provide an alarm to the Ethernet port. The front panel provides green LED status for the input and green/red for all output signals.
    The 4032A-IO can be configured to custom requirements.
    4033A 1x15 5 Volt Pulse Distribution Amplifier
    产 品 说 明
    The 4033A is a one-input, fifteen-output pulse distribution amplifier in a 1U,19-inch rack mount chassis. It provides fifteen isolated outputs from a single input. An Ethernet port on the rear panel provides the capability to remotely monitor the status of the input and all output signals. Any failure in the unit will immediately provide an alarm to the Ethernet port. The front panel provides green LED status for the input and green/red for all output signals, as well as indicating an input of 1 PPS, DC IRIG, or Other.
    4036B 1x15 RF Distribution Amplifier
    产 品 说 明
    The 4036B is a 1-input, 15-output RF distribution amplifier in a 1U chassis. It provides fifteen isolated copies of a single input. The unit operates over a frequency range of 1MHz to 20 MHz. Fault sensing of signal level is provided on the input and every output. Faults are indicated on front panel LEDs as well as via an Ethernet interface.
     4037A 1x16 L1/L2 RF Distribution Amplifier
    产 品 说 明
    The 4037A is a one-input, sixteen-output L1/L2-Band amplifier in a 1U, 19 inch rack mount chassis. It provides sixteen isolated (> 15 dB) outputs from a single input. This unit is ideal for distributing GPS antenna signals. The front panel provides green LED status for the power and antenna bias voltage setting.
    4059B 1x15 LF (IRIG) Distribution Amplifier
    产 品 说 明
    The 4059B is a one-input, fifteen-output Low Frequency amplifier in a 1U, 19 inch rack mount chassis. It provides fifteen isolated (> 70 dB) outputs from a single input. This unit is ideal for distributing IRIG A/B or G. An Ethernet port on the rear panel provides the capability to remotely monitor the status of the input and all output signals. Any failure in the unit will immediately provide an alarm to this port. The front panel provides green LED status for the input and green/red for all output signals, as well as indicating an input of 1 kHz, 10 kHz, or other. A green LED on the front panel also provides power status.
     4091A RF Autosense Fault Switch
    产 品 说 明
    The 4091A is a 1U rackmount fault sense switch that accepts two RF inputs and produces eight outputs (chosen from the two inputs). The unit comes standard with a single HOT SWAP AC power supply and can be configured with redundant HOT SWAP AC or DC power supplies. It has LED indicators that display the selected input as well as a control switch that is used to manually operate the switch or place the switch in uto?mode. When in uto?mode, the unit automatically switches upon failure of the selected input. In addition to front panel control, the unit can be controlled remotely via the Ethernet port on the rear of the unit. The TSC 4091A can be configured to custom requirements.
    4093A PPS/DC IRIG-B Autosense Fault Switch
    产 品 说 明
    The 4093A is a 1U rackmount fault sense switch that accepts two Pulse signals or two DC IRIG-B signals and produces eight outputs (chosen from the two inputs). The unit comes standard with a single HOT SWAP AC power supply and can be configured with redundant HOT SWAP AC or DC power supplies. It has LED indicators that display the selected input as well as a control switch that is used to manually operate the switch or place the switch in mode. When in mode, the unit automatically switches upon failure of the selected input. In addition to front panel control, the unit can be controlled remotely via the Ethernet port on the rear of the unit.
    分路放大器
    产 品 说 明
     RF分路设备
    产 品 说 明
    产 品 说 明
    产 品 说 明
    symmetricom 56000 Distribution Unit
    产 品 说 明
    The 56000 backplane can accept 1, or 10 MHz; IRIG B time code; and any TTL signal from DC to 10Mbps. Multiple redundant external frequency references can be applied to a hitless switch (passive combiner) located on each frequency synthesizer circuit card. The hitless switch provides a glitch-free transition from one input source to another, ensuring reliable and disturbance-free outputs, even in the event of failure of one of the input sources. The frequency reference inputs can be replaced or enhanced by an on-board oscillator circuit card or an on-board GPS timing receiver. The oscillators are disciplined to either the input frequency or GPS. Using the oscillators in combination with external reference inputs provides various levels of redundancy. The oscillators also add holdover capability so that uninterrupted operation is maintained in the event of total failure of the reference input(s).
    symmetricom 4032A Distribution Unit
    产 品 说 明
     symmetricom 4033A Distribution Unit
    产 品 说 明
欧桥电子科技发展有限公司是英国Universal Corporate Ltd. (UK)在中国的分公司,旗下包含上海欧桥电子、天津欧桥、杭州欧桥等多个分支机构,从事涵盖电子通信产品、仪器、工业及机电产品等不同领域的业务与技术服务。公司本着良好的信誉和出色的售后服…  更多>>
上海欧桥电子科技有限公司
联系人:瞿建
地址:上海市浦东新区康桥路1100号保康大厦1103室
邮编:201315
电话:021-58126804
传真:021-58126844
公司网址:http://www.ouqiao.com/
  • 张克雄 在2025/6/26 17:30:00留言
  • 详细留言:产品尺寸图
  • 何先生 在2023/10/16 18:46:00留言
  • 详细留言:UCL-HP2000-A(B)
  • 李小姐 在2021/9/22 12:16:00留言
  • 详细留言:UCL-HT80GH-18,5PCS
  • huyiping 在2011/5/17 15:20:00留言
  • 详细留言:4142b+41420A+41420A
  • 李永珍 在2010/9/28 19:41:00留言
  • 详细留言:True Time XL-AK GPS Receiver (600-000-03)
