Model Number 769-20 Frequency (Low) in MHz DC Frequency (High) in MHz 6000 Attenuation dB (Nominal) 20 Attenuation dB (Deviation DC-2) +/-0.5 Attenuation dB (Deviation 2-6) +/-1.0 Power Input (Max Avg.) in W 150 Power Input (Max Peak) in kW 3 VSWR (max) DC-6 1.35 Weight (max) in kg 1.5 Weight (max) in lbs 3.3 Special Notes NOTE: Temperature Coefficient: 0.0006 dB/dB/Degrees Celsius; Power Coefficient: 0.0005dB/dB/watt Spec Sheet (download) View PDF
联系人:瞿建
地址:上海市浦东新区康桥路1100号保康大厦1103室
邮编:201315
电话:021-58126804
传真:021-58126844
公司网址:http://www.ouqiao.com/
