1单元二极管
产品型号 参数说明 封装形式 下载
ND89N 89A,1200V,1400V,1600V,1800V PowerBlock 20mm
ND104N 104A,1200V,1400V,1600V,1800V PowerBlock 20mm
ND171N 170A,1200V,1400V,1600V,1800V PowerBlock 34mm
ND260N 260A,2000V,2200V,2400V,2600V PowerBlock 50mm
ND261N 260A,2000V,2200V,2400V,2600V PowerBlock 50mm
DZ540N 540A,2000V,2200V,2400V,2600V PowerBlock 50mm
DZ600N 600A,1200V,1400V,1600V,1800V PowerBlock 50mm
DZ950N 950A,3600V,4000V,4400V PowerBlock 70mm
DZ1070N 1070A,1800V,2000V,2200V,2400V,2600V,2800V PowerBlock 70mm
◆1单元晶闸管
产品型号 参数说明 封装形式 下载
TZ150N 150A,2000V,2200V,2400V,2600V PowerBlock 50mm
TZ240N 240A,2800V,3000V,3200V,3400V,3600V,3800V PowerBlock 50mm
TZ310N 310A,2000V,2200V,2400V,2600V PowerBlock 50mm
TZ375N 375A,1800V,2000V,2200V PowerBlock 50mm
TZ400N 400A,2000V,2200V,2400V,2600V PowerBlock 50mm
TZ425N 425A,1000V,1200V,1400V,1600V,1800V PowerBlock 50mm
TZ430N 430A,1800V,2000V,2200V,2400V PowerBlock 50mm
TZ500N 500A,1200V,1400V,1600V,1800V PowerBlock 50mm
TZ600N 600A,1200V,1400V,1600V PowerBlock 50mm
TZ530N 530A,3000V,3200V,3400V,3600V PowerBlock 70mm
TZ630N 630A,2200V,2400V,2600V,2800V PowerBlock 70mm
TZ740N 740A,1800V,2000V,2200V PowerBlock 70mm
TZ800N 800A,1200V,1400V,1600V,1800 PowerBlock 70mm
◆2单元二极管(半桥)
产品型号 参数说明 封装形式 下载
DD89N 89A,1200V,1400V,1600V,1800V PowerBlock 20mm
DD98N 98A,2000V,2200V,2500V PowerBlock 20mm
DD104N 104A,1200V,1400V,1600V,1800V PowerBlock 20mm
DD106N 106A,1200V,1400V,1600V,1800V,2000V,2200V PowerBlock 25mm
DD151N 150A,1200V,1400V,1600V,1800V,2000V,2200V PowerBlock 30mm
DD171N 170A,1200V,1400V,1600V,1800V PowerBlock 34mm
DD175N 175A,2800V,3000V,3200V,3400V PowerBlock 50mm
DD231N 230A,2000V,2200V,2400V,2600V PowerBlock 50mm
DD260N 260A,1200V,1400V,1600V,1800V PowerBlock 50mm
DD261N 260A,2000V,2200V,2400V,2600V PowerBlock 50mm
DD285N 285A,400V,600V,800V PowerBlock 50mm
DD350N 350A,1200V,1400V,1600V,1800V PowerBlock 50mm
DD435N 435A,2800V,3200V,3600V,4000V PowerBlock 60mm
DD600N 600A,1200V,1400V,1600V,1800V PowerBlock 60mm
◆2单元晶闸管(半桥)
产品型号 参数说明 封装形式 下载
TT61N12-16KOF 60A,1200V,1400V,1600V PowerBlock 20mm
TT92N12-16KOF 92A,1200V,1400V,1600V PowerBlock 20mm
TT104N12-14KOF 104A,1200V,1400V PowerBlock 20mm
TT70N16-24KOF 70A,1600V,1800V,2000V,2200V,2400V PowerBlock 25mm
TT85N18-20KOF 85A,1800V,2000V,2200V PowerBlock 25mm
TT106N12-18KOF 106A,1200V,1400V,1600V,1800V PowerBlock 25mm
TT121N12-20KOF 121A,1200V,1400V,1600V,1800V,2000V PowerBlock 30mm
TT131N12-16KOF 131A,1200V,1400V,1600V PowerBlock 30mm
TT122N18-24KOF 122A,1800V,2000V,2200V,2400V PowerBlock 34mm
TT140N18-22KOF 140A,1800V,2000V,2200V PowerBlock 34mm
TT142N12-16KOF 142A,1200V,1400V,1600V PowerBlock 34mm
TT162N12-16KOF 162A,1200V,1400V,1600V PowerBlock 34mm
TT180N12-16KOF 180A,1200V,1400V,1600V PowerBlock 34mm
TT150N20-26KOF 150A,2000V,2200V,2400V,2600V PowerBlock 50mm
TT170N 170A,1200V,1400V,1600V,1800V PowerBlock 50mm
TT210N 210A,1200V,1400V,1600V,1800V PowerBlock 50mm
TT215N18-24KOF 215A,1800V,2000V,2200V,2400V PowerBlock 50mm
TT250N 250A,1200V,1400V,1600V,1800V PowerBlock 50mm
TT251N 250A,1200V,1400V,1600V,1800V PowerBlock 50mm
TT285N 285A,1200V,1400V,1600V PowerBlock 50mm
TT330N 330A,1200V,1400V,1600V PowerBlock 50mm
TT240N 240A,2800V,3000V,3200V,3400V,3600V,3800V PowerBlock 60mm
TT310N 310A,2000V,2200V,2400V,2600V PowerBlock 60mm
TT375N 375A,1800V,2000V,2200V PowerBlock 60mm
TT380N 380A,1000V,1200V,1400V,1600V,1800V PowerBlock 60mm
TT400N 400A,2000V,2200V,2400V,2600V PowerBlock 60mm
TT425N 425A,1000V,1200V,1400V,1600V,1800V PowerBlock 60mm
TT430N 430A,1800V,2000V,2200V,2400V PowerBlock 60mm
TT500N 500A,1200V,1400V,1600V,1800V PowerBlock 60mm
TT570N 570A,1000V,1200V,1400V,1600V PowerBlock 60mm
◆2单元混合半桥上SCR下D
产品型号 参数说明 封装形式 下载
TD61N12-16KOF 60A,1200V,1400V,1600V PowerBlock 20mm
TD92N12-16KOF 92A,1200V,1400V,1600V PowerBlock 20mm
TD104N12-14KOF 104A,1200V,1400V PowerBlock 20mm
TD70N16-24KOF 70A,1600V,1800V,2000V,2200V,2400V PowerBlock 25mm
TD85N18-20KOF 85A,1800V,2000V,2200V PowerBlock 25mm
TD106N12-18KOF 106A,1200V,1400V,1600V,1800V PowerBlock 25mm
TD121N12-20KOF 121A,1200V,1400V,1600V,1800V,2000V PowerBlock 30mm
TD131N12-16KOF 131A,1200V,1400V,1600V PowerBlock 30mm
TD122N18-24KOF 122A,1800V,2000V,2200V,2400V PowerBlock 34mm
TD140N18-22KOF 140A,1800V,2000V,2200V PowerBlock 34mm
TD142N12-16KOF 142A,1200V,1400V,1600V PowerBlock 34mm
TD162N12-16KOF 162A,1200V,1400V,1600V PowerBlock 34mm
TD180N12-16KOF 180A,1200V,1400V,1600V PowerBlock 34mm
TD150N 150A,2000V,2200V,2400V,2600V PowerBlock 50mm
TD170N 170A,1200V,1400V,1600V,1800V PowerBlock 50mm
TD210N12-18KOF 210A,1200V,1400V,1600V,1800V PowerBlock 50mm
TD215N 215A,1800V,2000V,2200V,2400V PowerBlock 50mm
TD250N 250A,1200V,1400V,1600V,1800V PowerBlock 50mm
TD251N 250A,1200V,1400V,1600V,1800V PowerBlock 50mm
TD285N 285A,1200V,1400V,1600V PowerBlock 50mm
TD330N 330A,1200V,1400V,1600V PowerBlock 50mm
TD240N 240A,2800V,3000V,3200V,3400V,3600V,3800V PowerBlock 60mm
TD310N 310A,2000V,2200V,2400V,2600V PowerBlock 60mm
TD375N 375A,1800V,2000V,2200V PowerBlock 60mm
TD400N 400A,2000V,2200V,2400V,2600V PowerBlock 60mm
TD425N 425A,1000V,1200V,1400V,1600V,1800V PowerBlock 60mm
TD430N 430A,1800V,2000V,2200V,2400V PowerBlock 60mm
TD500N 500A,1200V,1400V,1600V,1800V PowerBlock 60mm
TD570N 570A,1000V,1200V,1400V,1600V PowerBlock 60mm
◆2单元混合半桥上D下SCR
产品型号 参数说明 封装形式 下载
DT61N 600A,1200V,1400V,1600V PowerBlock 20mm
DT92N12-16KOF 92A,1200V,1400V,1600V PowerBlock 20mm
DT104N12-14KOF 104A,1200V,1400V PowerBlock 20mm
DT85N18-20KOF 85A,1800V,2000V,2200V PowerBlock 25mm
DT106N 106A,1200V,1400V,1600V,1800V PowerBlock 25mm
DT121N 121A,1200V,1400V,1600V,1800V,2000V PowerBlock 30mm
DT131N 131A,1200V,1400V,1600V PowerBlock 30mm
DT122N 122A,1800V,2000V,2200V,2400V PowerBlock 34mm
DT142N 142A,1200V,1400V,1600V PowerBlock 34mm
DT162N 162A,1200V,1400V,1600V PowerBlock 34mm
DT150N20-26KOF 150A,2000V,2200V,2400V,2600V PowerBlock 50mm
DT170N 170A,1200V,1400V,1600V,1800V PowerBlock 50mm
DT210N 210A,1200V,1400V,1600V,1800V PowerBlock 50mm
DT250N 250A,1200V,1400V,1600V,1800V PowerBlock 50mm
DT285N 285A,1200V,1400V,1600V PowerBlock 50mm
DT310N 310A,2000V,2200V,2400V,2600V PowerBlock 60mm
DT425N 425A,1000V,1200V,1400V,1600V,1800V PowerBlock 60mm
DT430N 430A,1800V,2000V,2200V,2400V PowerBlock 60mm
DT500N 500A,1200V,1400V,1600V,1800V PowerBlock 60mm
上海汇勤电子科技有限公司
销售部:习小姐
13501613843
021-64128995
www.hqelec.com
