010-82612039 81677922 13910532255 工控部提供
CPCI系统 2U CPCI机箱
产品简介
Dimension: 2U (H) x 84T (W) x 283mm (D) 4-slot 6U CompactPCI backplaneFront cage: 4-slot, 6U x 160mmRear I/O: 4-slot, 6U x 80mm
产品特点
250 W ATX or 250 W cPCI power supply1 x 3.5”HDD and 1 x slim CD-ROM device holders
详细介绍
P-284283 Dimension: 2U (H) x 84T (W) x 283mm (D) 4-slot 6U CompactPCI backplaneFront cage: 4-slot, 6U x 160mmRear I/O: 4-slot, 6U x 80mm250 W ATX or 250 W cPCI power supply1 x 3.5”HDD and 1 x slim CD-ROM device holders Fan Unit Fan Mode Bearing type Nominal Voltage DC 12 V Dimension 70 x 70 x 15 mm Noise 35 dB Backplane 4-slot 6U CompactPCI backplane Power Supply Output power 250 W -ATX type Output voltage +3.3V/22 A, +5V/30 A, +12V/14 A, -5V/0.5 A, -12V/1.0 A, +5VSB/2.0 A Input voltage 100 - 240 VAC Frequency 47 – 63 Hz Power Supply Output power 250 W (3U 8HP Pluggable) -cPCI type Output voltage +5V/25 A, +3.3V/18 A, +12V/5A, -12V/0.5 A Input voltage 90 - 264 VAC Frequency 47 - 63 Hz
P-284283
Fan Unit
Fan Mode
Bearing type
Nominal Voltage
DC 12 V
Dimension
70 x 70 x 15 mm
Noise
35 dB
Backplane
Power Supply
Output power
250 W
-ATX type
Output voltage
Input voltage
100 - 240 VAC
Frequency
47 – 63 Hz
-cPCI type
90 - 264 VAC
47 - 63 Hz
联系电话:010-82612039 81677922 13910532255 Skype业务咨询:ipc406 . 公司网址:www.gtdtech.com.cn
联系人:张
地址:北京市海淀区海淀路50号
邮编:100080
电话:010-82612039 13910532255
传真:010-81677922
公司网址:http://www.gtdtech.com.cn
