| Ruggedness Fully Rugged |
MIL-STD 810F and IP54 compliance |
Full magnesium alloy case |
Sealed ports and connectors |
Shock-mounted removable HDD |
Vibration & drop-shock resistant |
Others MIL-STD-461E (option) |
| CPU |
Intel U2500 Core Duo ULV 1.2GHz 533 MHz FSB 2MB L2 cache |
| Memory |
512MB DDR2 max 2GB |
| VGA Controller |
Intel 945GMS, 128MB shared memory |
| Storage |
SATA 120GB expandable to 160GB |
| Display |
10.4 XGA(Optional 12.1WXGA) TFT LCD |
Touch screen or optional digitizer |
Optional sunlight readable display |
| Communication Interface |
10/100/1000 base-T Ethernet |
56K ITU V.92 modem |
Intel? PRO/Wireless 3945 a/b/g |
Bluetooth(V2.0+EDR class 2) |
Optional EV-DO/GSM/GPRS/EDGE/UMTS/WCDMA/HSDPA |
| I/O Port DC in x 1 |
USB 2.0 x 2 |
Serial port x 1 |
Docking port x 1 |
RJ-45 x 1 |
RJ-11 x 1 |
External VGA x 1(optional replaced by Serial Port RS232 or RS422 ) |
Microphone x 1 |
Line out x 1 |
Optional docking RF connector |
| Expansion Slots |
PCMCIA Type II x 2 or Type III x 1 |
Webcam Integrated 225 degree reversible 1.3M pixels camera |
Smart Card reader Optional smart card reader(occupies one PCMCIA type-II slot ) |
Memory Card Reader SD card reader |
Security TPM 1.2 |
Kensington lock |
| Power AC |
adapter (90W, 100-240V, 50/60Hz) |
| Battery |
Li-Ion smart battery ( 5200mAh) |
Optional Li-Ion smart battery ( 7800mAh) |
| Dimensions & Weight |
10.4" : 285 x 222 x 49 mm (11.2 x 8.7 x 1.9) , 2.2kg (4.9lbs) |
12.1"W: 311 x 222 x 49 mm (13 x 8.7 x 1.9) , 2.45kg (5.4lbs) |
| Test Specifications |
| Item Test Criteria |
| Temperature According |
to IEC 68-2-1,2,14 / MIL-STD-810F, Method 501.4, 502.4 |
Operating: 0°C (32°F) to 55°C (131°F) |
-20°C (4°F) to 55°C (low temperature option) |
Non-operating: -40°C (-40°F) to 70°C (158°F) |
| Humidity According |
to IEC 68-2-30 / MIL-STD-810F, Method 507.4 |
5% to 95% RH, non-condensing |
| Altitude According |
to IEC 68-2-13/ MIL-STD-810F, Method 500.4 |
Operating: 15,000ft |
Non-operating: 40,000ft |
Altitude change rate: 2,000ft/min |
| Shock According to |
IEC 68-2-27/ MIL-STD-810F, Method 516.5 |
| Drop According to |
IEC 68-2-32 / MIL-STD-810F, Method 516.5 |
| Vibration According to |
IEC 68-2-6 / MIL-STD-810F, Method 514.5 |
| ESD According to |
IEC1000-4-2 |
| Enclosure According to |
IEC 529, NEMA, MIL-STD-810F, Method 506.4, 510.4 |
| IP 54 compliance |
| Regulation |
FCC, UL, CUL, TUV, CE, CB, CCC, PSE, WHQL, BSMI, e-Mark |
| Accessories |
Vehicle docking |
Battery charger |
Vehicle adapter (90Watts, 12-32V) |
Carrying bag |
Shoulder strap |
External USB DVD Combo |
External USB DVD-DUAL |
Digitizer stylus |
Touch screen stylus |
