| 型号︰ |
P3 |
| 品牌︰ |
macnaught |
| 原产地︰ |
澳大利亚 |
| 单价︰ |
CNY ¥ 9800 / 件 |
| 最少订量︰ |
1 件 |
macnaught *玛乐*成立于1948年,是澳洲全资公司。*玛乐*专注于打油器材的发展。他们针对农业,工业及汽车市场的需要发展该行业特有''设计" ."生产"及''市场推广"以提供所需之专用器材。
澳洲*玛乐*提供高品质的产品及服务作为未来成功的指标,更无时无刻地注意市场的变化而更改其产品系列及设计。现时*玛乐*已成为澳洲市场上提供有关产品的领导者,同时*玛乐*已发展了横跨60个国家的完整分销网络。
澳洲*玛乐*在产品设计上亦已荣获三项国家出口奖及两项澳洲设计奖,足以证明*玛乐*在打油器材方面的认许成就。
佳美国际发展有限公司为澳洲macnaught *玛乐*加油系统中国代理
Macnaught Pty Ltd - Macnaught's range of hand operated greasing equipment is highly portable, easy to maintain, and can be used in a wide range of applications.
All of Macnaught's hand operated greasing equipment models follow the same principles as the original designs made over 50 years ago, and vary from the easy to use handgun, to grease pumps suitable for 2.5kg (5lb) - 22kg (48lb) containers:
K3 Super- Lube
Designed to fit pails from 12.5kg (28lb) up to 22kg (48lb), or with depths of 310mm to 430mm
Supplied with the pump unit, lid, rubber edged follower, 3m (10 ft) x 1/2" ID delivery hose, and the high pressure, high volume KR grease gun (all components also available separately)
Spring loaded pump system provides 60 shots of grease
Suitable for greases up to and including NLGI No.2
360 degree swivel to prevent hose kinking
Fully sealed to prevent contamination
Optional TR5 drum trolley to provide portability
5 year warranty (conditions apply)
10 year parts availability
K6 Mini-Lube®
Designed to fit pails from 2.5kg (5lb) to 5kg (11lb), or with depths of 146mm to 225mm
Includes pump unit, lid, rubber edged follower, 1.5m (5 ft) x 1/2" ID delivery hose, and the high pressure, high volume KR grease gun (all components also available separately)
K6-24 contains the above items plus a 2.5kg (5lb) refillable container (KT5), while the K6-67 contains the above items plus a 5kg (11lb) refillable container (KT6)
Spring loaded pump system provides 30 shots of grease
Suitable for greases up to and including NLGI no.2
KR Pressurite Gun
Supplied with the K3 Super-lube and K6 Mini-lube®
Can deliver grease at either high volume or high pressure
K29/K32 Flexigun
K29 • 450gms/15.9oz
K32 • 400gms/14.5oz
Easy one hand operation
Handles up to and including NLGI no.2 greases
Supplied complete with 230mm (9") flexible extension (KF9) and KY coupler
Can be filled by bulk, cartridge or the J2 grease pump
Optional range of couplers and extensions available
Zinc version (K29-Z) available for use in underground mines (450gms)
Fully repairable
K45/K40 Levergun
K45 • 450gms/15.9oz
K40 • 400gms/14.5oz
Two hand operation
Supplied complete with 170mm (6¾") rigid extension and KY coupler
Fully repairable
Five year warranty (conditions apply)
J2/J2B Grease Pump
Designed to fit pails from 12.5kg (28lb) up to 22kg (48lb), or with depths of 315mm to 390mm
Suitable for hand operated grease guns ( K29, K32, K45, K40), air operated grease guns ( K53, K54) and the 2.5kg/5kg containers ( KT5, KT6)
Includes pump unit, lid and rubber edged follower, the J2B bucket pump has these items plus a 1.5m (5ft) x ½" ID delivery hose (all components also available separately)
| 包装︰ |
进口原装 |
| 交货期︰ |
6-8周 |
| 库存单位(SKU)︰ |
PCS | |
