昆山德旭鼎进出口贸易有限公司
  • MATRIX电磁阀/分气阀-佳美国际发展有限公司
  • 发布时间:2008/12/31 18:49:12   修改时间:2008/12/31 18:49:10 浏览次数:965
  • MATRIX电磁阀/分气阀/佳美国际发展有限公司
    型号︰ 750
    品牌︰ MATRIX
    原产地︰ 意大利
    单价︰ CNY ¥ 3500 / 件
    最少订量︰ 1 件
     共有 28 相关信息
    上一个 7 8 9 10 11 下一个
    自动翻页︰   秒播放
    产品描述
    Description 750 Multi-Function Series 2/2 - 3/2
    750 multi-function Series encloses 8 separately controlled shutters in a single body. Its base version has 8 outputs with the following configurations:
    - four 3/2 NC outlets four 3/2 NC outlets.
    - two 2/2 NC outlets.
    - two 2/2 NO inverted flow outlets.
    The extreme modularity of 750 Series allows the arrangement of an almost unlimited number of customized configurations. For this aim, contact your local dealer or MATRIX technical staff.
    750 multi-function Series is particularly fit for the control of intricate pneumatic system, where different functions are integrated.
    In the present model, all the innovations offered by Matrix technology (this combines special dynamic performance to the simplicity and reliability of manufacture) are present. Response times are of millisecond range, while operation life is over 500 million cycles.
    With a speed-up kind control, dynamic characteristics are even more improved. Standard 12 / 24 VDC control solenoid valves have a response time lower than 5 ms in opening and than 2 ms in closing, with a maximum operation frequency 200 Hz. Speed-up control solenoid valves have a response time lower than 2 ms both in opening and in closing, with a maximum operation frequency of 300 Hz.
    Besides high-speed characteristics, 750 Series solenoid valves offer flow rate values up to 100 l/minute (ANR) for every single outlet, with feeding (supply) pressure from 0 to 8 bar.
    For 750 multi-function series, a lot of accessories is available, such as IP 52 or IP 65 connectors, manifolds with different positions and speed-up driver boards.
    Advantages
    - Compact dimension.
    - Short response times.
    - Insensitivity to frequency work and to vibrations.
    - Low absorbed power.
    - Precision, repetitiveness and flexibility.
    - Long operating life.
    Applications
    - Process and precision instrumentation.
    - Pressure and flow rate control devices.
    - Positioning systems.
    - Biomedical and measure sector.
    - Robotics and industrial automation.
    Materials
    - Body in PPS.
    - Flanges in Al.
    - Seals in NBR (shutters in HNBR if required).
    • 758 2/2 - 3/2 NC - NO
    General Characteristics
     Control  Direct - PFM - PWM
     Type and function  n.4 3/2 - n.2 2/2 n.6 NC
     n.2 2/2 Inverted flow n.2 NO
     Fluid  Non-lubricated dry air, neutral gases
    (-10 +50 °C)
     Filtration rating  40 µ
     Temperature  -10 +50 °C (standard version)
     Response time in
     opening
     12 / JJ< 5 ms    KK < 2 ms
     Response time in closing  12 / JJ< 5    ms KK < 2 ms
     Maximum frequency  200 Hz    300 Hz
     Weight  350 g
     Product life expectancy  ≥ 500 M/s cycles
     IP rating  IP 52 - IP 62 - IP 65
     Flow rate (at 6 bar)  50 Nl/min
     80 Nl/min
     100 Nl/min (Control tension JJ / XX / KK)
     Version  Standard
     HNBR Shutters
     N. Outlets  8 Outlets
     N. Electrical controls  8 Controls
     Port Connection  Integrated cables IP 62 L="500" mm
     Presetting for Easy connecction
     IP 52 - IP 65
     Special Protections  Only with EASY IP 65 port connection
     Stainless Steel (Inox) flanges
     Epox Black varnished flanges
     Control tension  12 VDC ± 10% - ED 100% - 1.4 W
     24 VDC ± 10% - ED 100% (1) - 1.9 W
     Speed-up in tension - ED 100% (1)
     Operating pressure  0 - 4 bar (All models)
     4 - 8 bar (All models)
     0 - 8 bar (... KK)
     2 - 6 bar (All models)
    (1) Only with Electronic Driver Boards PRB or UDB
    产品图片
    选择图片
    相关产品
    MEAD手动阀/佳美国际发展有限公司
    MEAD手动阀/佳美国际发展有限公司
    CNY ¥ 1000
    F
    F.TEC电磁阀
    CNY ¥ 200
    NIHON SEIKI/NISCON冷空气发生器
    AIR WORK电磁阀
    AIR WORK电磁阀
    CNY ¥ 1500
    网站首页   |   产品目录   |   公司新闻   |   UNIVER电磁阀   |   FAIRCHILD电气转换器   |   TOYOOKI   |   TAIYO/TAIYO油缸   |   NEW-ERA电磁阀/气缸   |   自动消泡机/自动消泡设备   |   文件下载   |   供求信息   |   联系我们   |   网站地图
    简体中文     繁體中文     English
昆山德旭鼎进出口贸易有限公司是集贸易.技术.服务于一体的工业器材专业代理、销售的明星企业。 公司成立于2005年,是一支年轻而富有朝气的团队。我们秉承:用户至上,信誉第一的宗旨为广大客户提供一流的产品、一流的服务。 由于全球一体化,在工业发…  更多>>
昆山德旭鼎进出口贸易有限公司
联系人:DANY
地址:昆山市高新区宝益路89号3楼
邮编:215300
电话:0512-86171188 57382299
传真:0512-50128868
公司网址:http://www.57382299.com
  • 尹风育 在2013/4/22 14:05:00留言
  • 详细留言:请你帮我查一下FAIRCHILD阀 EHS629-4KW 4026AE价格及货期,数量3个
  • abilify 在2010/7/16 18:53:00留言
  • 留言类型:
  • 详细留言:Aloha! abilify, )) - 5198
