PR2-RSC3-LDP-24DC/2X21预制继电器模块
- 发布时间:2014/4/8 13:52:44
修改时间:2014/4/8 13:52:44 浏览次数:1510
螺钉接线的预制继电器模块,包括: 继电器底座、内置LED的工业继电器、续流二极管、手动操作杆和固定夹 输入电压: 24V AC,2PDT,10A ,菲尼克斯全部产品全场特价,国外工厂直销,环节减少,货期缩短,成本降低,实惠增加,
PR2-RSP3-LDP-24DC/2*21
PR3-BSC1/3X21
PR2-RSC3-LV-230AC/4X21AU
PR2-RSC3-LV-230AC/2X21
PR1-RSC3-LDP-24DC/2X21
PR2-BSC2/4X21
TCP 5/DC32V
TCP 7,5/DC32V
TCP 10/DC32V
TCP 20/DC32V
REL-IR/L-230AC/2X21
UMK-4 OM-R/MF/P
MACX MCR-SL-RPSSI-2I
PSR-SCP-230UC/ESAM4/3X1/1X2/B
PSI-MOS-PROFIB/FO1300 T
PLC-OSP-24DC/24DC/2/ACT
ST-REL3-HG220/21
ST-REL7-HG220/4X21
ST-REL7-HG24/4X21
PSR-SPP-24DC/ESP4/2X1/1X2
EEM-MA600
PLC-RSC-230UC/21HC
REL-MR-24DC/1IC
EEM-MA400
EEM-RS485-MA400
PLC-BSC-230UC/1/SEN
CM-KBL-RS232/USB
UM72-R-230UC/4*21/SO46
PSM-EG-RS232/LWL-K
UEGM 22,5
UM 45-FLK14
PSI-MOS-RS232/FO 660 E
UM72-R-24DC/4*21
EMG 17-REL/KSR-24/21-21-LC AU
OPT-24DC/24DC/5
PSR-SPP-24UC/ESA4/2X1/1X2
PSR-SPP- 24DC/URD3/4X1/2X2
UM 25-D15SUB/B/FRONT/Q
UM 25-D 9SUB/B/FRONT/Q
VIP-3/SC/D25SUB/M
VIP-3/SC/D50SUB/M
EB 80- DIK BU
EB 80- DIK RD
SKBI 64/C64
SKBI 128-C64/C64
UK 5-TWIN
PSI-MOS-DNET/FO 850 E
EMG 10-REL/KSR-G 24/21-LCU
PSI-REP-DNET CAN
REL-IR/L- 24AC/4X21 AU
REL-IR/LDP-24DC/4X21AU
PR2-BSC2/4X21
REL-IR/L-230AC/4X21 AU
PLC-RSC-24DC/1AU/SEN
ST-OV2- 24DC/ 24DC/5
PLC-OSC-24DC/24DC/2ACT
PLC-RSC-120UC/21-21
ST-REL7-HG 24/4X21
OPT-5DC/24DC/2
PSM-SET-B-FOC/4-HCS
PSR-SCP-24-230UC/ESAM4/3X1/1X2
PSR-SPP- 24-230UC/ESAM4/3X1/1X2
PSR-SCP-24DC/ESD/5X1/1X2/T1
PLC-OSC-230UC/ 24DC/ 2
EMG17-REL/KSR-W230/21-21-LC
EMG 22-REL/KSR- 24/21-21AU
PSI-MOS-PROFIB/FO 850 E-SO
PSI-MOS-PROFIB/FO 850 T-SO
SD-D/SP/LA
EMG 90-DIO 32P
EMG 90-DIO 32M/LP
EMG 90-DIO 32M
REL-MR-230AC/21-21
PSM-V24/TTY-P/AK/BB
RAD-IN-4A-I
RAD-OUT-4A-I
RAD-IN-8D
RAD-OUT-8D-REL
RAD-ISM-2400-SET-UD-ANT
EMG 45-ELR3/1,5
PLC-V8L/FLK14/OUT
UM 72-SEFE/R
UM 72-SEFE/L
UM 72-PROFIL 200CM
PSR-SCP-24UC/ESL4/3X1/1X2/B
UMK- 8 RM/MR-G24/ 1/PLC
UMK- 8 RM/MR-G24/ 1/HF/PLC
EMD-FL-C-10
PLC-BSP-230UC/21
UM-32 RM/RT-G24/21/PLC
PLC-OSC-24DC/300DC/1
DFLK-D37 SUB/B
UM- 2 FLK50/4FLK20//LA/SO46
EMD-FL-3V-400
EMG 17-OV-TTL/ 24DC/2
FLKM 14-PA-S300
PSM-KAD 9 SUB 25/BS
EMG 90-2SD-D/LA
NEF 1-10
FLKM 50/32M/PLC
FLM AI 4 SF M12
FLM AO 4 SF M12
UMK- 8 OM-R/MF/MKDS/P
UMK-16 OM-R/MF/MKDS/P
PSR-SPP- 24UC/ESAM4/2X1/1X2
PLC-OSC-24DC/48DC/100
PSM-LWL-GDO- 50/125
FL CAT5 FLEX
DEK-OE-24DC/48DC/100
PSI-MOS-RS422/FO 850 E
UMK-16 OM/AMSC/E/PLC
FLK 50/4X14/EZ-DR/ 300/KONFEK
FLK 50/4X14/EZ-DR/ 400/KONFEK
FLK 50/4X14/EZ-DR/ 600/KONFEK
FLK 50/EZ-DR/ 600/KONFEK
PSR-SPP- 24DC/ESD/5X1/1X2/ T 5
UM 72-R-24DC/21-21
PSR-SCP-24UC/ESAM4/8X1/1X2
PI-EX-RPSS-I/I
PI-EX-ME-RPSS-I/I
PLC-RSC-230UC/21-21AU
PLC-RSC-24DC/21-21AU
PSR-SCP- 24DC/ESD/5X1/1X2/ T30
UM 45-FLK50/32IM/ZFKDS/PLC
ST-REL2-KG 24/1
UDK-RELG 2 底座
PLC-BSP-24DC/21
PSR-SCP-24UC/URM4/5X1/2X2
ST-RELT-HG220/4*21
UDK-RELG7
PLC-RSC-120UC/21-21
EMG45-DIO-8E
ST-OE2-24DC/48DC/100
ST-REL7-HG24/4*21
REL-IR/LDPP-24DC/4*21AU
SACB-8/16-L-CGG
PSM-STRIP-FC/PROFIB
UM 25-D9 SUB/S/FRONT/Q
UM 25-D9 SUB/B/FRONT/Q
FLM DI 8 M12
FLK 20/2FLK14/EZ-DR/200/KONFEK
FLKM 20/8AI/PLC/F-SO325
FLK 20/EZ-DR/ 200KONFEK
PSM-LWL-HCS-RUGGED-200/230
PLC-BSP-24DC/21-21
UMK- PVB 2/24/ZFKDS
FL COM SERVER RS232
PLC-RSP- 24DC/21-21
PSM PTK-4
FLKMS-D50 SUB/S
FLK-PVB 2/24
PSR-SCF- 24UC/URM/2X21
FLKM 50
DEK-OE- 5DC/ 48DC/100
SD-D/SC/LA
PSI-REP-PROFIBUS/12MB
REL-MR- 24DC/21HC
FLS PB M12 D08 M12-2A
FLS PB M12 DI8 M12
EMG 10-REL/KSR-G24/1-LCU
UM 45-SEFE
PT 2X2+F-BE
OPT-24DC/230AC/1
OV-24DC/ 60DC/4
PSI-MOS-DNET CAN/FO 850/EM
PSM-ME-RS232/RS232-P
PLC-RSC-230UC/21/S046
REL-MR-24DC/21-21
PSR-SCP- 24DC/RSM4/4X1
PSR-SPP-24UC/ESA2/4X1/1X2/B
PSR-SCP-24UC/ESA2/4X1/1X2/B
ST-REL2-KG 24/1 AU
ST-REL2-KG 24/2 AU
ST-REL2-KG 24/2
EMG 17-REL/KSR-120/21-21-LC AU
SUBCON-PLUS-PROFIB/PG/SC2
UM 45-FLK14/LA/PLC
UM 45- 8RM/MR-G24/1/PLC
UEGM-REL-120/230AC/21 AU SO35
EMG 22-DIO 7M
PSM-EG-RS232/RS485-P/2D
PSR-SPP- 24UC/URM4/5X1/2X2/B
PI-EX-ME-2NAM/TO
PLC-BSC-120UC/21-21/SO46
FLK-D37 SUB/B
FLK 50/EZ-DR/200/KONFEK
FLKM 50-PA-S300
FLK 50/EZ-DR/100/KONFEK/S
PLC-V8/FLK14/IN
PLC-V8/FLK14/OUT
PLC-V8/FLK14/OUT/M
PLC-V8/FLK14/IN/M
MCR-VDC-UI-B-DC
FLKM 50/LA/PLC
UMK-32 RM/MR-G24/1/PLC
REL-MR- 24DC/21AU
REL-MR- 12DC/21AU
IBS IP 400 ME-VFD 1-3A DI4
PSM-ME-RS232/TTY-P
PRG CAB MINI DIN
FBST 500-PLC BU
PLC-RSC-24DC/1-1/ACT
DEK-OV-5DC/24DC/3
DEK-OV- 24DC/24DC/3
PSI-MOS-PROFIB/FO 660 E
PLC-RSC-230UC/21-21/S046
REL-MR-60DC/21
PSM-ME-RS485/RS485-P
DEK-DE-12DC/48DC/100
EMG 10-REL/KSR-G 24/21-LC AU
DEK-OE-230AC/48DC/100
EMG 10-REL/KSR- 24/21-LC
EMG 45-RELS/IR1-G 24
PLC-BSC-230UC/21-21
PLC-BSC- 24DC/21-21
PLC-BSP-24DC/21
PLC-BSC-24DC/1/ACT
PLC-RSC-230UC/21-21
EMG 10-OV- 24DC/24DC/1
EMUG 45- 4REL/KSR-G 24/21
REL-OR- 24DC/3X21
DEK-OE-125DC/48DC/100/T
UM72-R-24DC/21
ETR-U-18-230UC/21
OPT-24DC/48DC/100
ETD-SL-1T-DTF
EMG 45-B8
FLK 26
UM 72-R-24 DC/21-21
PSR-SCP- 24UC/ESM4/3X1/1X2/B
EMG 17-OE-24DC/24DC/50
PLC-RSC-24UC/21
PSM-EG-RS-232/TTY-P/2K
PSM-SET-FSMA/4-HCS
PSM-HCS-KONFT00L
EMG22-REL/KSR-G24/TRN35
D-UFB-V24/S-DSUB 9/SB-B
PSM-LWL-HCSO-200/230
PLC-RSC-24DC/1IC/ACT
PLC-RSC-24UC/21-21AU
PLC-RSC-24UC/21AU
SST-IBS-CLX-RLL
MCR-R-I-4-V
UM 72-R-24DC/21
EMG17-0V-12VDC/240VAC/3
PLC-BSC- 5DC/21
REL-MR- 4,5DC/21
PLC-OSC-230UC/48DC/100/SEN
PLC-OSC- 24DC/230AC/1/ACT
PSM-CABLE-PROFIB/FC
SUBCON-PLUS-PROFIB/AX/SC
PLC-BSC-24UC/21-21
REL-MR- 24DC/21-21AU
EMG 10-REL/KSR-G 24/1-LC
FLKM 26
FLKM 40
PSR-SPP- 24UC/ESA4/3X1/1X2/B
UMK- F48M-VR/VS
REL-MR-110DC/21-21
REL-KSR-G 24/21-21
DEK-REL-24/I/1
DEK-REL-24/O/1
EMG 45-SD-D/LA/SI YE
DEK-OE- 5DC/24DC/100KHZ
VAL-CP-1S-175
FL WLAN 24 DAP 802-11
FBST 500-PLC BU
FBST 500-PLC RD
FBST 6-PLC BU
FBST 6-PLC RD
PLC-RSC-120UC/21
PLC-ATP BK
PSR-SCP-24UC/ESA4/2X1/1X2
PLC-RSP- 24DC/1AU/SEN
PT 2X2-24AC-ST
PT2*2-BE
SUBCON-PLUS-PROFIB/SC2
IL DN BK3-PAC
PLC-RSC- 24DC/1/SEN
PLC-RSP- 24DC/1/ACT
CT 10-18FS+F/PE-24
CT-TERMIBLOCK 10 DA
EMG 22-DIO 4E-1N5408
EMG 22-DIO 4E
EMG 45-DIO14P
EMG 45-DIO14M
EMG 45-DIO 8E-1N5408
EMG 45-DIO14M/LP
