上海博谊自控电气设备有限公司
  • MCR-CPS-I-I-44-E菲尼克斯隔离器
  • 发布时间:2011/9/6 9:30:59   修改时间:2011/9/6 9:30:59 浏览次数:1024
  • 2814553 MCR-CPS-I-I-44-E
    2810311 MCR-PT100-U-DC
    2810337 MCR-PT100-I-DC
    2810900 MCR-CPSS-I-I-44-E
    2810913 MCR-C-UI-UI-DCI
    2811103 MCR-VAC
    2811925 MCR-PSP-DC
    2814016 MCR-1CLP-I-I-00
    2814029 MCR-2CLP-I-I-00
    2814045 MCR-4CLP-I-I-00
    2814113 MCR-T-UI-E
    2814469 MCR-C-U-U-00-DC
    2814472 MCR-C-U-I-0-DC
    2814498 MCR-C-I-U-00-DC
    2814508 MCR-C-I-I-00-DC
    2814511 MCR-C-I-U-4-DC
    2814524 MCR-C-I-I-40-DC
    2814537 MCR-C-U-I-4-DC
    2814540 MCR-C-I-I-04-DC
    MINI MCR-SL-PT100-UI
    MCR-C-U-I-O-DC
    PLC-RSC-24DC/21-21
    DEK-REL-G24/21
    QUINT-DIODE/40
    ETR-U-18-230UC/21
    EMR-UAC-1-OY-120V
    MCR-PT100-U
    MCR-SL-PT100-I-DC-24
    FLT-PLUS
    VAL-MS-400
    VAL-MS230IT/3+1
    UM 25-D25SUB/S/FRONT/Q
    UM 25-D15SUB/S/FRONT/Q
    FLK-PVB 2/24
    MINI MCR-SL-I-I
    EMG 90-DIO 17E
    FLK-PVB 2/24
    UM 72-R-230UC/21
    EMG45-RELS/K2,DC24V
    IB IL SSI-IN-PAC
    IL PB BK DP/V1
    FLK-PVB 2/36
    plc-rsc-24dc/21au
    MINI MCR-SL-PT100-UI 4-20MA
    UM72-R-24 DC/21
    ELR W 1/10-24DC
    EMR-IDC/1/UC-1A(已仃产)
    EMD-SL-C-UC-10  替代2764658
    EMR-UAC/1/OV-120V(已仃产)
    EMD-FL-V-300  替代2764690
    MCR-PSP-DC
    MCR-SWG/U
    MCR-TE-JK-U
    MCR-TE-JK-I-E
    PIK 4-PE/L/N
    MCR-TE-JK-I-E
    MCR-T/UI-E
    MCR-C-UI-UI-DCI
    MINI MCR-SL-1CP-I-I
    ST-REL7-HG220/4X21
    UDK-RELG 7
    UDK-RELG 2
    ST-REL2-KG 24/1
    IBS ST 24 BK-T
    IBS PC CB/TDOS486/I-T
    PSM-EG-RS232/RS422-P/4K
    PLC-RSC-24DC/21
    PLC-RSC-230UC/21AU
    PLC-BSC-230UC/21/SO46
    PSR-SCP- 24UC/THC4/2X1/1X2
    MCR-PS-24VDC/10DC
    EMG 10-REL/KSR-230/21-LC AU
    PLC-BSC- 60DC/21
    OPT-60DC/24DC/2
    MCR-PS-24DC/24DC/200
    DEK-OV- 12DC/24DC/3
    PLC-RSC-24DC/1/ACT
    PSI-MOS-RS485W2/FO 850 E
    IB IL MUX-CAB PSI
    PLC-BSC-230UC/21
    PLC-BSC- 48DC/21
    PLC-RSC- 48DC/21
    PLC-BSC-24DC/21
    EMG17-REL/KSR-W230/21-21-LC
    SUBCON 9/M-SH
    REL-KSR-G 24/21
    PLC-OSC-120UC/48DC/100
    CM 90-ELR-W3/5-R
    VAL-MS 500 ST
    PLC-RSP-230UC/21
    UMSTBHK 2,5/10-G
    PLC-RSP-24DC/21
    VAL-MS-320
    PSR-SCP- 24UC/ESAM4/8X1/1X2
    EMG 17-OV- 24DC/ 60DC/3
    ST-REL4-KG230/21-21
    PLC-OSP-24DC/24DC/2
    FBST 500-PLC BU
    FBST 500-PLC RD 500MM
    TRIO-PS/1AC/24DC/10
    MCR-SL-D-U-I
    VAL-MS BE/FM
    MCR-FL-T-LP-I-EX
    EMG 17-REL/KSR- 24/21-21-LC
    EMG 10-REL/KSR-G 24/21-LC
    OPT-24DC/24DC/2
    PLC-OSC-24DC/24DC/2
    MCR-PT100-I
    MCR-SL-S-1-5-I-DCI-230
    EMG 17-OV- 24DC/ 24DC/2
    PSR-SCP-24UC/ESD/4X1/1X2/600
    PSR-SCP-24DC/ESD/5X1/1X2/300
    MCR-I-UI-E
    QUINT-DIODE/40
    EMG 45-DIO14M
    EMD-SL-3V-400-N
    D-UFB-V24/S-DSUB 9/SB-B
    MCR-C-U-U-DC
    PLC-BSC- 24DC/21-21
    PSR-SCP- 24UC/URM/5X1/2X2
    PLC-BSC-120UC/21
    UM-HOZ 462/1-1-1-2/G24
    PLC-RSC-230UC/21
    PSM-ME-RS232/RS485-P
    UMK- F48M-VR/VS
    FLKM 10
    UM72-R-24DC/21
    MCR-F-UI-DC
    PLC-RSC-220UC/21-21-SO46
    MCR-C-I/I-40-DC
    PLC-BSC-220UC/21-21-SO46
    MCR-SLP-1-5-UI-0
    EMD-SL-3V-400-N
    EMD-SL-V-UV-300
    ETR-U-18-230UC/21
    PI-EX-ME-ID-I/I
    PI-EX-ME-RPS-I/I
    FLKMS 64
    REL-MR-24DC/21
    PSR-SCP-24UC/ESA4/3X1/1X2/B
    UMK-16 OM-R/MF/MKDS
    MINI MCR-SL-UI-2I
    DEK-OE- 24DC/24DC/100KHZ
    FLT-CP-2C-350
    EMG 22-DIO 4E-1N5408
    EMG 22-DIO 4E
    EMG 45-DIO14P
    EMG 45-DIO14M
    SAC-3P-M12FR-2L/PUR-20
    VAL MS320-1+1
    VAL-MS 320/3+1
    VAL-MS230IT/3+1
    PT 2-PE/S-230AC-ST
    PT 1X2-24DC-ST
    CT 10-2PE/FS-24
    CT-TERMIBLOCK 10 DA
    EMG17-0V-24VDC/240VAC/3
    MCR-FL-C-UI-2UI-DCI
    REL-MR- 60DC/21AU
    VAL-MS230/3+1
    FLT-CP-3C-350
    PLC-BSC- 24DC/21-21
    FLT-CP-3S-350
    BC/3+1/FM
    VAL-MS 230 ST
    VAL-MS BE
    F-MS 12
    CT 10-18FS+F/PE-24
    CT-TERMIBLOCK 10 DA
    PT-BE/FM
    VAL-MS 230/3+1 FM
    PT 2X2-BE
    PT 2X2-HF- 5 DC-ST
    IL DN BK3-PAC
    PLC-RSC- 24DC/1/SEN
    PLC-RSP- 24DC/1/ACT
    MCR-C-UI-UI-DCI-NC
    PLC-RSP- 24DC/1AU/SEN
    PT 2X2-24AC-ST
    PT2*2-BE
    SUBCON-PLUS-PROFIB/SC2
    MCR-1CLP-I-I-00
    IBS RBC METER-T
    MCR-C-I-I-00-DC
    MCR-S-1-5-UI-DCI-NC
    MCR-S-1-5-UI-DCI
    FBST 500-PLC BU
    FBST 500-PLC RD
    FBST 6-PLC BU
    FBST 6-PLC RD
    PLC-RSC-120UC/21
    PLC-ATP BK
    PSR-SCP- 24UC/ESA4/2X1/1X2
    MCR-R-I-4-V-DC
    DEK-REL- 24/I/1
    EMG 45-SD-D/LA/SI YE
    DEK-OE- 5DC/24DC/100KHZ
    VAL-CP-1S-175
    FL WLAN 24 DAP 802-11
    MINI MCR-SL-2CP-I-I
    MCR-FL-C-UI-UI-DCI-24/230
    REL-KSR-G 24/21-21
    MACX MCR-SL-CAC-5-I-UP
    REL-MR-110DC/21-21
     MCR-S-1-5-UI-DCI
    FLKM 26
    PLC-OSC-230UC/48DC/100
    FLKM 40
    EMG 22-REL/KSR- 24/21
    EMG 10-REL/KSR-G 24/1-LC
    PSR-SPP- 24UC/ESA4/3X1/1X2/B
    UMK- F48M-VR/VS
    MCR-FL-C-UI-2UI-DCI-NC
    PLC-OSC-230UC/48DC/100/SEN
    PLC-OSC- 24DC/230AC/1/ACT
    PSM-CABLE-PROFIB/FC
    SUBCON-PLUS-PROFIB/AX/SC
    PLC-BSC- 24UC/21-21
    REL-MR- 24DC/21-21AU
    MCR-TTL-RS232
    MCR-TTL-RS232-E
    PLC-BSC- 5DC/21
    REL-MR- 4,5DC/21
    mcr-sl-s-1-1/5-i-dci-24
    MCR-4CLP-I-I-00
    EMG17-0V-12VDC/240VAC/3
    MCR-FL-TS-LP-I-EX
    MCR-FL-T-LP-I-EX
    MINI MCR-SL-RPS-I-I
    EMG 17-OE-24DC/24DC/50
    PLC-RSC-24UC/21
    PSM-EG-RS-232/TTY-P/2K
    PSM-SET-FSMA/4-HCS
    PSM-HCS-KONFT00L
    EMG22-REL/KSR-G24/TRN35
    PSM-LWL-HCSO-200/230
    PLC-RSC-24DC/1IC/ACT
    PLC-RSC-24UC/21-21AU
    PLC-RSC-24UC/21AU
    SST-IBS-CLX-RLL
    MCR-R-I-4-V
    UM 72-R-24DC/21
    PR2-RSC3-LDP-24DC/2X21
    SAC-3P-M12MS/0,6-PUR/M12FS
    SAC-3P-M12MS/1,5-PUR/M12FS
    ETR-U-18-230UC/21
    OPT-24DC/48DC/100
    ETD-SL-1T-DTF
    EMG 45-B8
    FLK 26
    MCR-1CLP-I-I-00
    UM 72-R-24 DC/21-21
    PSR-SCP- 24UC/ESM4/3X1/1X2/B
    MCR-SL-PT100-SP
    UM72-R-24DC/21
    MCR-T-UI-NC
    MCR-T-UI-E-NC
    DEK-OE-125DC/48DC/100/T
    PR2-RSP3-LDP-24DC/2*21
    SACC-DSI-MS-4CON-M12/0,5 SCO
    SACC-DSI-MS-4CON-M12-SCO SH
    MCR-PS- 24DC-10DC
    PR3-BSC1/3X21
    REL-OR- 24DC/3X21
    MCR-C-U-I-10B-4-DCI
    MINI MCR-SL-PTB
    PLC-BSP-24DC/21
    PLC-BSC-24DC/1/ACT
    PLC-RSC-230UC/21-21
    EMG 10-OV- 24DC/24DC/1
    EMUG 45- 4REL/KSR-G 24/21
    MCR-C-I-U-4-DC
    IBS IP 400 ME-VFD 1-3A DI4
    PSM-ME-RS232/TTY-P
    PRG CAB MINI DIN
    FBST 500-PLC BU
    PLC-RSC-24DC/1-1/ACT
    DEK-OV- 5DC/24DC/3
    DEK-OV- 24DC/24DC/3
    PSI-MOS-PROFIB/FO 660 E
    EMG 22-REL/KSR- 24/21-21
    PLC-RSC-230UC/21-21/S046
    REL-MR-60DC/21
    PSM-ME-RS485/RS485-P
    DEK-DE-12DC/48DC/100
    EMG 10-REL/KSR-G 24/21-LC AU
    DEK-OE-230AC/48DC/100
    EMG 10-REL/KSR- 24/21-LC
    EMG 45-RELS/IR1-G 24
    PLC-BSC-230UC/21-21
    PLC-BSC- 24DC/21-21
    MINI MCR-SL-RPS-I-I
    MCR-CLP-UI-I-4
    FLK 50/EZ-DR/ 200/KONFEK
    FLKM 50-PA-S300
    PLC-V8/FLK14/IN
    PLC-V8/FLK14/OUT
    PLC-V8/FLK14/OUT/M
    PLC-V8/FLK14/IN/M
    MCR-VDC-UI-B-DC
    FLKM 50/LA/PLC
    UMK-32 RM/MR-G24/1/PLC
    REL-MR- 24DC/21AU
    REL-MR- 12DC/21AU
    MCR-VAC-UI-O-DC
    PLC-BSC-120UC/21-21/SO46
    FLK-D37 SUB/B
    CPC 5015 PM CO
    PSI-MOS-DNET CAN/FO 850/EM
    PSM-ME-RS232/RS232-P
    PLC-RSC-230UC/21/S046
    REL-MR-24DC/21-21
    PSR-SCP- 24DC/RSM4/4X1
    PSR-SPP-24UC/ESA2/4X1/1X2/B
    PSR-SCP-24UC/ESA2/4X1/1X2/B
    ST-REL2-KG 24/1 AU
    ST-REL2-KG 24/2 AU
    ST-REL2-KG 24/2
    EMG 17-REL/KSR-120/21-21-LC AU
    SUBCON-PLUS-PROFIB/PG/SC2
    UM 45-FLK14/LA/PLC
    UM 45- 8RM/MR-G24/1/PLC
    MCR-R-U-V
    UEGM-REL-120/230AC/21 AU SO35
    EMG 22-DIO 7M
    PSM-EG-RS232/RS485-P/2D
    PSR-SPP- 24UC/URM4/5X1/2X2/B
    PI-EX-ME-2NAM/TO
    MACX MCR-EX-SL-RPSSI-I
    MACX MCR-EX-SL-2NAM-RO
    OPT-24DC/230AC/1
    OV-24DC/ 60DC/4
    MCR-PS-230AC/24DC/100
    PR2-RSC3-LV-230AC/4X21AU
    SD-D/SC
    SD-D/SC/LA
    EMG 10-REL/KSR-G 24/ 1-LCU
    UM 45-SEFE
    PT 2X2+F-BE
    MCR-PT100-I-DC
    FLKMS-D50 SUB/S
    FLK-PVB 2/24
    PSR-SCF- 24UC/URM/2X21
    FLKM 50
    DEK-OE- 5DC/ 48DC/100
    SD-D/SC/LA
    PSI-MOS-PROFIB/FO 850 E
    PSI-REP-PROFIBUS/12MB
    REL-MR- 24DC/21HC
    FLS PB M12 D08 M12-2A
    FLS PB M12 DI8 M12
    PROT-M12
    SAC-2P-M12MSB/0,3-910/M12FSB
    SAC-4P-2,0-186/M12FS
    SAC-4P-M12MS/0,3-186/M12FS
    SAC-5P-M12MS PB TR
    SACC-M12FSB-5C0N-PG9 SH AU
    SAC-5P-M12T/2XM12 VP
    MCR-2CLP-I-I-00
    PSM PTK-4
    PLC-RSC-24DC/21HC
    SAC-4P-MR/ 7,5-PUR/FS SCO
    ME 6,2 TBUS-2 1,5/5-ST-3.81 GN
    MINI MCR-SL-UI-2I-NC
    MINI MCR-SL-PT100-UI-NC
    PSM-STRIP-FC/PROFIB
    UM 25-D9 SUB/S/FRONT/Q
    UM 25-D9 SUB/B/FRONT/Q
    FLM DI 8 M12
    FLK 20/2FLK14/EZ-DR/200/KONFEK
    FLKM 20/8AI/PLC/F-SO325
    FLK 20/EZ-DR/ 200KONFEK
    PSM-LWL-HCS-RUGGED-200/230
    PLC-BSP-24DC/21-21
    UMK- PVB 2/24/ZFKDS
    FL COM SERVER RS232
    PLC-RSP- 24DC/21-21
    MACX MCR-SL-CAC-5-I
    PSR-SCP-24UC/URM4/5X1/2X2
    ST-RELT-HG220/4*21
    UDK-RELG7
    PLC-RSC-120UC/21-21
    EMG45-DIO-8E
    ST-OE2-24DC/48DC/100
    ST-REL7-HG24/4*21
    REL-IR/LDPP-24DC/4*21AU
    SACB-8/16-L-CGG
    ST-REL2-KG 24/1
    UDK-RELG 2 底座
    PLC-BSP- 24DC/21
    MINI MCR-SL-UI-UI-NC
    PI-EX-RPSS-I/I
    PI-EX-ME-RPSS-I/I
    PLC-RSC-230UC/21-21AU
    PLC-RSC- 24DC/21-21AU
    PSR-SCP- 24DC/ESD/5X1/1X2/ T30
    UM 45-FLK50/32IM/ZFKDS/PLC
    PSR-SCP-24UC/ESAM4/8X1/1X2
    MCR-S-10-50-UI-DCI
    UMK-16 OM/AMSC/E/PLC
    FLK 50/4X14/EZ-DR/ 300/KONFEK
    FLK 50/4X14/EZ-DR/ 400/KONFEK
    FLK 50/4X14/EZ-DR/ 600/KONFEK
    FLK 50/EZ-DR/ 600/KONFEK
    PSR-SPP- 24DC/ESD/5X1/1X2/ T 5
    UM 72-R-24DC/21-21
    SAC-4P-M 8MS/1,5-PUR 16
    SAC-4P-M 8MS/ 0,3-PUR
    SACC-M8MS-3CON-M
    SACB-8/3-L-5.OPUR-M8
    SACC-M12MS-5SC
    HC-A 16-ESTS
    HC-D 25-TFL-72/O1STM20S
    MCR-SWS-I
    MCR-SL-1CLP-I-I-00-4KV
    MCR-PS- 24DC/2X24DC
    DEK-OE- 24DC/48DC/100
    PSI-MOS-RS422/FO 850 E
    MINI MCR-BL-I-I
    PLC-OSC-24DC/48DC/100
    PSM-LWL-GDO- 50/125
    FL CAT5 FLEX
    UMK- 8 OM-R/MF/MKDS/P
    UMK-16 OM-R/MF/MKDS/P
    PSR-SPP- 24UC/ESAM4/2X1/1X2
    VS-M12MSD-RJ45-931/ 2,0
    FLM AI 4 SF M12
    FLM AO 4 SF M12
    MCR-T-UI
    MINI MCR-SL-TC-UI
    MINI MCR-SL-RPSS-I-I
    PLC-OSP-230UC/ 24DC/ 2
    MCR-C-U-I- 4-DC
    MINI MCR-SL-TC-UI-NC
    EMG 90-2SD-D/LA
    NEF 1-10
    FLKM 50/32M/PLC
    PR2-RSC3-LV-230AC/2X21
    MCR-SL-HT-PT 100-I
    MCR-FL-C-UI-UI-B-DCI-24/230
    MINI MCR-SL-R-UI
    UM- 2 FLK50/4FLK20//LA/SO46
    EMD-FL-3V-400
    EMG 17-OV-TTL/ 24DC/2
    FLKM 14-PA-S300
    PSM-KAD 9 SUB 25/BS
    MINI MCR-SL-UI-UI
    MCR-C-UI-UI-450-DCI
    MCR-S-1-5-UI-SW-DCI
    MCR-SL-CUC-100-I
    MINI MCR-BL-U-I-4
    MINI MCR-BL-RPS-I-I
    PLC-BSP-230UC/21
    UM-32 RM/RT-G24/21/PLC
    PLC-OSC-24DC/300DC/1
    DFLK-D37 SUB/B
    PSR-SCP-24UC/ESL4/3X1/1X2/B
    UMK- 8 RM/MR-G24/ 1/PLC
    UMK- 8 RM/MR-G24/ 1/HF/PLC
    EMD-FL-C-10
    ZFK-RELG 2
    PLC-V8L/FLK14/OUT
    UM 72-SEFE/R
    UM 72-SEFE/L
    MCR馈电隔离器,输入信号: 4...20 mA,输出信号: 4...20 mA
上海博谊自控电气设备有限公司是专门从事工业自动化产品的销售、服务和系统集成的高科技公司。经销全系列罗克韦尔PLC,伺服系统,低压电器,开关,传感器,变频器,电源,气动元件,工业以太网,编码器,仪器仪表,工具,人机界面自动化产品。公…  更多>>
上海博谊自控电气设备有限公司
联系人:陈一非
地址:上海市延长西路25号
邮编:200072
电话:021-66100983
传真:021-66100983
公司网址:http://boyi1010.net114.com/
  • Miros?aw Maciejczak 在2026/3/13 16:33:00留言
  • 详细留言:Software 8100-HSKAR
  • 在2025/9/18 19:50:00留言
  • 详细留言:Allen Bradley 800T-TFXLET6A 急停开关
  • 韩哲荣 在2025/6/18 12:39:00留言
  • 详细留言:罗克韦尔800FM-KM21,这个有吗
  • 林海 在2025/2/24 16:35:00留言
  • 详细留言:你好!我询价洛克韦尔的产品,请帮我联系销售人员或者技术人员
  • 李娜 在2025/2/12 17:33:00留言
