PLC-BSC-24DC/21
PLC-RSC-24DC/21
PLC-RSC-24DC/21-21
PLC-RSC-24DC/1/ACT
PLC-RSC-24DC/1-1/ACT
PLC-RSC-24DC/21HC
PLC-RSC-230UC/21
PLC-RSC-230UC/21-21
PLC-BSC-230UC/21HC
PLC-BSC-230UC/21/SO46
我司常规Phoenix继电器备件特价产品有:
DEK-OE-24DC/48DC/100CH02
DEK-OE-110DC/48DC/100CH02
DEK-OE-220DC/48DC/100CH02
DEK-OE-24DC/48DC/100CH01
DEK-OE-110DC/48DC/100CH01
DEK-OE-220DC/48DC/100CH01
PSR-SCP-24UC/URM4/5X1/2X2
PSR-SCP-24UC/ESA M4/8*1/1*2
ST-REL3-KG230/21
ST-REL-4-KG24/21-21
ST-REL2-KG 24/1
UDK-RELG 4
ST-OV2-220DC/60DC/1
ST-REL-4-KG230/21-21
ST-OV2-220DC/ 60DC/1
ST-REL2-KG 24/1
EMG 10-REL/KSR- 24/21-LC
Phoenix继电器PLC-RSC-24DC/21
Phoenix继电器PLC-RSC-24DC/21-21
Phoenix继电器PLC-RSC-24DC/1/ACT
Phoenix继电器PLC-RSC-24DC/21HC
PLC-RSC-230UC/21
PLC-BSC-230UC/21HC
REL-MR-60DC/21
PLC-BSC-230UC/21-21/SO46
REL-MR-110DC/21-21
PLC-ESK GY
UM 72-R-24UC/21-21
PLC-RSC-120UC/21
PLC-BSC-24DC/21
PLC-BSC-230UC/21-21
PLC-BSC-24DC/21-21
PLC-RSC-230UC/21AU
PLC-RSC-24DC/21AU
PLC-RSC-24DC/21-21AU
PLC-RSC-230UC/21-21AU
REL-MR-24DC/21-21
PLC-RSC-24UC/21-21
PLC-RSC-230UC/21-21
PLC-RSC-230UC/21/SO46
PLC-V8/FLK14/OUT
PLC-RSC-230UC/21-21/SO46
PSR-SCP-24UC/ESA4/2X1/1X2
PLC-BSC-60DC/21
OPT-60DC/24DC/2
EMG 10-OV-24DC/24DC/1
PSR-SCP-24UC/ESA2/4X1/1X2/B
PSM-EG-RS232/TTY-P/2K
EMG 22-REL/KSR-G24/TRN 5
EMG 17-REL/KSR-24/21-21-LC AU
PSR-SCP-24UC/ESM4/2X1/1X2
PLC-OSC-24DC/48DC/100/SEN
OPT-24DC/24DC/2
PLC-BSP-24DC/21
PSI-MOS-PROFIB/FO 850 E
PSI-MOS-PROFIB/FO 850 T
PLC-RSC-24DC/1/SEN
PLC-RSC-24DC/1AU/SEN
PR2-RSP3-LDP-24DC/4X21AU
PSR-SCP-24DC/ESP4/2X1/1X2
UMK- 8 RELS/KSR-G24/1/NPE/PLC
ST-REL-4-KG24/21-21
PLC-BSC-24DC/1IC/ACT
REL-MR-24DC/1IC
PLC-BSC-24DC/1/SEN
PR2-RSC3-LDP-24DC/2X21
UM 72-R-230UC/4X21/SO46
PLC-OSC-24DC/230AC/1/ACT
PLC-OSC-230UC/48DC/100/SEN
EMG 12-REL/KSR- 24/1
Phoenix安全继电器
PSR-SCP-24DC/ESD/5X1/1X2/300
PLC-BSC-24DC/1/ACT,61.5
REL-MR-12DC/21HC
REL-MR-12DC/21
ST-REL3-KG230/21
ST-REL2-KG 24/1
FBST 500-PLC BU
FBST 500-PLC GY
FBST 500-PLC RD
EMD-FL-3V-400
EMD-FL-C-10
ETD-SL-1T-DTF
ETD-SL-2T-I
ETD-FL-2T-DTI
UM-HOZ462/1-1-1-2/G 24
UM 72-PROFIL 100CM
EMG 10-REL/KSR-G 24/21-LC
UM 72-SEFE/L
UM 72-SEFE/R
UM 72-R-24DC/21
UK 10-DREHSILED 60 (5X20)
带光电耦合器的通用型PLC标准接口
PLC-OSC-24DC/24DC/2
PLC-OSC-48DC/24DC/2
PLC-OSC-60DC/24DC/2
PLC-OSC-120UC/24DC/2
PLC-OSC-125DC/ 24DC/2
PLC-OSC-230UC/24DC/2
PLC-OSC-48DC/48DC/100
PLC-OSC-60DC/48DC/100
PLC-OSC-120UC/48DC/100
PLC-OSC-125DC/ 48DC/100
PLC-OSC-48DC/230AC/1
PLC-OSC-60DC/230AC/1
PLC-OSC-120UC/230AC/1
PLC-OSC-125DC/230AC/1
PLC-OSC-230UC/230AC/1
PLC-OSC-5DC/300DC/1
PLC-OSC-12DC/300DC/1
PLC-OSC-24DC/300DC/1
PLC-OSC-60DC/300DC/1
PLC-OSC-110DC/300DC/1
PLC-OSC-220DC/300DC/1
PLC-OSC-120AC/300DC/1
PLC-OSC-230AC/300DC/1
PLC-OSC- 24DC/24DC/3RW
PLC-OSC-110DC/24DC/3RW
PLC-SC-ELR W1/2-24DC
PLC-OSC-24DC/24DC/10
PLC-OSC-24DC/48DC/500/W
PLC-OSP-24DC/24DC/2
PLC-OSP-48DC/24DC/2
PLC-OSP-60DC/24DC/2
PLC-OSP-120UC/24DC/2
PLC-OSP-230UC/24DC/2
PLC-OSP-24DC/48DC/100
PLC-OSP-48DC/48DC/100
PLC-OSP-60DC/48DC/100
PLC-OSP-120UC/48DC/100
PLC-OSP-230UC/48DC/100
PLC-OSP-24DC/230AC/1
PLC-OSP-48DC/230AC/1
PLC-OSP-60DC/230AC/1
PLC-OSP-120UC/230AC/1
PLC-OSP-230UC/230AC/1
PLC-OSP-5DC/300DC/1
PLC-OSP-12DC/300DC/1
PLC-OSP-24DC/300DC/1
PLC-OSP-60DC/300DC/1
PLC-OSP-110DC/300DC/1
PLC-OSP-220DC/300DC/1
PLC-OSP-120AC/300DC/1
PLC-OSP-230AC/300DC/1
PLC-OSP-24DC/24DC/3RW
PLC-OSP-110DC/24DC/3RW
PLC-SP-ELRW1/2-24DC
PLC-OSP-24DC/48DC/500/W
可插拔的微型光电耦合器
OPT-5DC/48DC/100
OPT-5DC/230AC/2
OPT-24DC/24DC/2
OPT-24DC/24DC/5
OPT-24DC/48DC/100
OPT-24DC/230AC/2
OPT-24DC/230AC/1
OPT-60DC/24DC/2
OPT-60DC/24DC/5
OPT-60DC/48DC/100
OPT-60DC/230AC/1
OPT-60DC/230AC/2
PLC配件
PLC-BP(A1-14)
FBST6-PLCBU
FBST6-PLCGY
FBST6-PLCRD
FBST8-PLCGY
FBST14-PLC BK
FBST500-PLC BN
FBST500-PLC BU
FBST500-PLC GY
FBST500-PLC RD
PLC-SC-EIK1-SVN24P
PLC-SC-EIK1-SVN24M
PLC-SP-EIK1-SVN24P
EMG45-SD-D/LA/SI
EMG45-SD-D/LA/SI YE
EMG90-2SD-D/LA
EMG 17-REL/KSR- 24/21-21-LC
EMG 90-DIO 32M/LP
EMG 45-DIO 14M/LP
PLC-RSC-12DC/21
PLC-RSC-12DC/21AU
PLC-RSC-24DC/21
PLC-RSC-24DC/21AU
PLC-RSC-24UC/21
PLC-RSC-24UC/21AU
PLC-RSC-48DC/21
PLC-RSC-48DC/21AU
PLC-RSC-60DC/21
PLC-RSC-60DC/21AU
PLC-RSC-120UC/21
PLC-RSC-120UC/21AU
PLC-RSC-230UC/21
PLC-RSC-230UC/21AU
PLC-RSC-12DC/21-21
PLC-RSC-12DC/21-21AU
PLC-RSC-24DC/21-21
PLC-RSC-24UC/21-21
PLC-RSC-24UC/21-21AU
PLC-RSC-48DC/21-21
PLC-RSC-48DC/21-21AU
PLC-RSC-60DC/21-21
PLC-RSC-60DC/21-21AU
PLC-RSC-120UC/21-21
PLC-RSC-120UC/21-21AU
PLC-RSC-230UC/21-21
PLC-RSC-24UC/1/S/H
通用型PLC接口,带回拉式弹簧连接
PLC-RSP-24UC/1/S/H
PLC-RSP-12DC/21
PLC-RSP-12DC/21AU
PLC-RSP-12DC/21-21
PLC-RSP-12DC/21-21AU
PLC-RSP-24DC/21
PLC-RSP-24DC/21AU
PLC-RSP-24UC/21
PLC-RSP-24UC/21AU
PLC-RSP-24DC/21-21
PLC-RSP-24DC/21-21AU
PLC-RSP-24UC/21-21
PLC-RSP-24UC/21-21AU
PLC-RSP-48DC/21
PLC-RSP-48DC/21AU
PLC-RSP-48DC/21-21
PLC-RSP-48DC/21-21AU
PLC-RSP-60DC/21
PLC-RSP-60DC/21AU
PLC-RSP-60DC/21-21
PLC-RSP-60DC/21-21AU
PLC-RSP-120UC/21
PLC-RSP-120UC/21AU
PLC-RSP-120UC/21-21
PLC-RSP-120UC/21-21AU
PLC-RSP-230UC/21
PLC-RSP-230UC/21AU
PLC-RSP-230UC/21-21
PLC-RSP-230UC/21-21AU
PLC-RSC-24DC/1IC/ACT
PLC-RSP-24DC/1IC/ACT
可插拔的微型继电器
REL-MR-45DC/21
REL-MR-45DC/21AU
REL-MR-12DC/21
REL-MR-12DC/21AU
REL-MR-12DC/21HC
REL-MR-12DC/21-21
REL-MR-12DC/21-21AU
REL-MR-24DC/ 1IC
REL-MR-24DC/21
REL-MR-24DC/21AU
REL-MR-24DC/21HC
REL-MR-24DC/21-21
REL-MR-24DC/21-21AU
REL-MR-60DC/21
REL-MR-60DC/21AU
REL-MR-60DC/21HC
REL-MR-60DC/21-21
REL-MR-60DC/21-21AU
REL-MR-110DC/21HC
REL-MR-110DC/21-21
REL-MR-110DC/21-21AU
菲尼克斯 PHOENIX继电器 PLC-RSC-24DC/21
Phoenix继电器适用于交流50Hz,主电路额定电压至660V,电流至630A的电力系统中作为三相交流电动机的过载和断相保护,具有断相保护,温度补偿,脱扣指示功能,能自动与手动复位,并与CJ20系列交流接触器配合使用,组成电磁起动器。
