2938604 QUINT-PS-100-240AC/24DC/10
2938620 QUINT-PS-100-240AC/24DC/20
2866750 QUINT-PS/ 1AC/24DC/ 5
2938578 QUINT-PS-100-240AC/24DC/2.5
2938581 QUINT-PS-100-240AC/24DC/5
2866255 QUINT-PS-100-240AC/48DC/5
2938594 QUINT-PS-3X400-500AC/24DC/5
2938811 QUINT-PS-100-240AC/12DC/10
2938248 QUINT-PS-100-240AC/48DC/10
2938617 QUINT-PS-3X400-500AC/24DC/10
2938219 QUINT-PS-3X400-500AC/48DC/10
2938976 QUINT-PS-100-240AC/48DC/20
2938727 QUINT-PS-3X400-500AC/24DC/20
2938222 QUINT-PS-3X400-500AC/48DC/20
2938633 QUINT-PS-3X400-500AC/24DC/30
2938879 QUINT-PS-100-240AC/24DC/40
2938646 QUINT-PS-3X400-500AC/24DC/40
2866378 QUINT-PS-24DC/24DC/10
2938196 QUINT-PS-ADAPTERS7/1
2938206 QUINT-PS-ADAPTERS7/2
2866857 QUINT-ADAPTER/4
2938235 UWA 182/52
防爆型初级开关电源和冗余模块
2938853 QUINT-PS-100-240AC/24DC/5/EX
2938866 QUINT-PS-100-240AC/24DC/10/EX
2938963 QUINT-DIODE/40
不间断初级开关电源
2866213 QUINT-BUFFER/24DC/20
2866226 QUINT-DC-UPS/24DC/10
2866239 QUINT-DC-UPS/24DC/20
2866242 QUINT-DC-UPS/24DC/40
2866349 QUINT-BAT/24DC/3.4AH
2866352 QUINT-BAT/24DC/7.2AH
2866365 QUINT-BAT/24DC/12AH
初级开关电源单元
通用型初级开关电源 a
2938714 MINI-PS-100-240AC/5DC/3
2938743 MINI-PS-100-240AC/2X15DC/1
2938756 MINI-PS-100-240AC/10-15DC/2
2866297 MINI-PS-100-240AC/10-15DC/8
2938840 MINI-PS-100-240AC/24DC/1
2866446 MINI-PS-100-240AC/24DC/1.3
2938730 MINI-PS-100-240AC/24DC/2
2938837 MINI-PS-100-240AC/24DC/4
2866336 MINI-PS-100-240AC/24DC/C2LPS
2866271 MINI-PS-48-60DC/24DC/1
2866284 MINI-PS-12-24DC/24DC/1
2866983 MINI-SYS-PS-100-240AC/24DC/1.5
阶梯设计的初级开关电源
2938918 STEP-PS-100-240AC/ 5DC/4
2938921 STEP-PS-100-240AC/12DC/3
2938934 STEP-PS-100-240AC/15DC/2.4
2938947 STEP-PS-100-240AC/24DC/1.5
2938950 STEP-PS-100-240AC/48DC/0.75
QUINT-PS-100-240AC/24DC/5A
QUINT-PS-3X400-500AC/24DC/10A
QUINI-PS-100-240AC/24DC/20A
QUINT-PS-3*400-500AC/24DC/10A
QUINT-PS-100-240AC/24DC/2.5A
QUINT-PS-100-240AC/12DC/10A
QUINT-PS-3*400-500AC/24DC/30A
QUINT-PS-3*400-500AC/24DC/5A
QUINT-PS-3*400-500AC/24DC/40A
QUINT-PS-3*400-500AC/24DC/20A
QUINT-DUINE/40
MINI-PS-100-240AC/2*15DC/1
QUINT-PS-100-240AC/24DC/40A
MINI-MCR-SL-I-I
QUINT-DIODE/40
QUINT-PS-3*400-240AC/24DC/20
QUINT-DC-UPS/24DC/40?
MINI MCR-SL-RPS-I-I
TRIO-PS/1AC/24DC/5
QUINT-PS-100-240AC/12DC/40A
TRIO-PS/1AC/24DC/10
STEP-PS-100-240AC/24DC/1,5停产
QUINT-PS-1AC/24DC/10
MINI-PS-100-240AC/ 5DC/3
ASI QUINT 100-240/2.4 EFD
PSM-LWL-HCSO-200/230
STEP-PS-100-240AC/5DC/4
QUINT-BAT/24DC/12AH
QUINT-PS/1AC/24DC/5
QUINT-PS-3*400-500AC/48DC/10
MCR-PS-24DC/24DC/200
QUINT-PS/ 3AC/24DC/20
QUINT-PS/ 1AC/24DC/20
TRIO-PS/1AC/24DC/20
TRIO-PS/3AC/24DC/40
TRIO-PS/1AC/24DC/2,5
STEP-PS/1AC/24DC/2.5
QUINT-PS/3AC/24DC/10
MCR-PS- 24DC/2X24DC
TRIO-PS/3AC/24DC/10
QUINT-PS/ 1AC/24DC/40
QUINT-PS-1AC/24DC/20
QUINT-PS/ 3AC/24DC/ 5
TRIO-PS/3AC/24DC/20
PSR-SPP-24DC/ESD/4X1/30
STEP-PS/ 1AC/24DC/1.75
QUINT-DC-UPS/24DC/10 技术参数: 24V DC/10A不间断电源,集成1.3Ah电池模块。 下载区域有清晰的选型表,提供负载电流和缓冲时间,以及缓冲模式的充电时间。信号类型 LED,继电器触点 ,环境温度(运行) 0 °C ... 50 °C .
特价销售
QUINT-PS-3*400-500AC/24DC/10 三相电源 订货号:2938594 技术资料:输入电压范围3*320-575VAC 输出电压范围:22.5-28.5VDC 额定输出电流10A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-3*400-500AC/24DC/20 三相电源 订货号:2938727 技术资料:输入电压范围3*320-575VAC 输出电压范围:22.5-28.5VDC 额定输出电流20A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-3*400-500AC/24DC/30 三相电源 订货号:2938633 技术资料:输入电压范围3*320-575VAC 输出电压范围:22.5-28.5VDC 额定输出电流30A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-3*400-500AC/24DC/40 三相电源 订货号:2938633 技术资料:输入电压范围3*320-575VAC 输出电压范围:22.5-28.5VDC 额定输出电流40A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-3*400-500AC/24DC/5 三相电源 订货号:2938633 技术资料:输入电压范围3*320-575VAC 输出电压范围:22.5-28.5VDC 额定输出电流5A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-100-240AC/24DC/2.5 单相电源 订货号:2938578 技术资料:输入电压范围100-240VAC 输出电压范围:24VDC 额定输出电流2.5A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-100-240AC/24DC/5 单相电源 订货号:2938581 技术资料:输入电压范围100-240VAC 输出电压范围:24VDC 额定输出电流5A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-100-240AC/24DC/10 单相电源 订货号:2938604 技术资料:输入电压范围100-240VAC 输出电压范围:24VDC 额定输出电流10A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-100-240AC/24DC/20 单相电源 订货号:2938620 技术资料:输入电压范围100-240VAC 输出电压范围:24VDC 额定输出电流20A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
QUINT-PS-100-240AC/24DC/40 单相电源 订货号:2938879 技术资料:输入电压范围100-240VAC 输出电压范围:24VDC 额定输出电流40A 电源启运时间<1S 带LED状态显示灯(绿) 导轨安装.
STEP-PS-100-240AC/5DC/4 电源 订货号:2938918 技术资料:输入电压范围100-240VAC 输出电压范围:5VDC 额定输出电流4A 电源启运时间<1S 带LED状态显示灯 导轨安装.
STEP-PS-100-240AC/12DC/3 电源 订货号:2938921 技术资料:输入电压范围100-240VAC 输出电压范围:12VDC 额定输出电流3A 电源启运时间<1S 带LED状态显示灯 导轨安装.
STEP-PS-100-240AC/15DC/2.4 电源 订货号:2938934 技术资料:输入电压范围100-240VAC 输出电压范围:15VDC 额定输出电流2.4A 电源启运时间<1S 带LED状态显示灯 导轨安装.
STEP-PS-100-240AC/24DC/1.5 电源 订货号:2938947 技术资料:输入电压范围100-240VAC 输出电压范围:24VDC 额定输出电流1.5A 电源启运时间<1S 带LED状态显示灯 导轨安装.
STEP-PS-100-240AC/4.8DC/0.75 电源 订货号:2938950 技术资料:输入电压范围100-240VAC 输出电压范围:4.8VDC 额定输出电流0.75A 电源启运时间<1S 带LED状态显示灯 导轨安装.
TRIO-PS/1AC/24DC/10 电源
产品详情
输入额定电压100-240AC 输入电压范围 85-264AC
额定输出电压24DC 输出电压可调范围 22.5-29.5DC 额定输出电流10A
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
尺寸60*130*115MM 重1.1KG
TRIO-PS/1AC/24DC/10 电源 特点:体积小,结 构紧凑,价格比QUINT系列便宜。主要性能与QUINT 电源一致 。性价比高
TRIO-PS/1AC/24DC/20 电源
产品详情
额定输出电压24DC 输出电压可调范围 22.5-29.5DC 额定输出电流20A
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
尺寸115*130*115MM 重2KG
TRIO-PS/1AC/24DC/20 电源 特点:体积小,结 构紧凑,价格比QUINT系列便宜。主要性能与QUINT 电源一致 。性价比高
TRIO-PS/1AC/24DC/2.5 电源
产品详情
额定输出电压24DC 输出电压可调范围 22.5-29.5DC 额定输出电流2.5A
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
TRIO-PS/1AC/24DC/2.5 电源 特点:体积小,结 构紧凑,价格比QUINT系列便宜。主要性能与QUINT 电源一致 。性价比高
TRIO-PS/1AC/24DC/5 电源
产品详情
额定输出电压24DC 输出电压可调范围 22.5-29.5DC 额定输出电流5A
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
TRIO-PS/1AC/24DC/5 电源特点:体积小,结 构紧凑,价格比QUINT系列便宜。主要性能与QUINT 电源一致 。性价比高
TRIO-PS/3AC/24DC/40 电源
输入额定电压3*400-500AC 输入电压范围 320-575AC
额定输出电压24DC 输出电压可调范围 22.5-29.5DC 额定输出电流40A
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
尺寸115*130*152.5MM 重2KG
TRIO-PS/3AC/24DC/40 电源 特点:体积小,结 构紧凑,价格比QUINT系列电源便宜。主要性能与QUINT 电源一致 。性价比高 三相缺一项也能长期正常使用
TRIO-PS/3AC/24DC/20 电源
产品详情
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
TRIO-PS/3AC/24DC/20 电源 特点:体积小,结 构紧凑,价格比QUINT系列电源便宜。主要性能与QUINT 电源一致 。性价比高 三相缺一项也能长期正常使用
TRIO-PS/3AC/24DC/10 电源
产品详情
可并联连接 用于冗余和增加功率
输出纹波<=100mvpp
DC OK LED灯显示
TRIO-PS/3AC/24DC/20 电源特点:体积小,结 构紧凑,价格比QUINT系列电源便宜。主要性能与QUINT 电源一致 。性价比高 三相缺一项也能长期正常使用
