北京市北方思源电子技术中心
  • 二手低频频谱分析仪 HP 3585B
  • 发布时间:2008/10/2 13:58:39   修改时间:2008/12/28 14:56:16 浏览次数:866
  • 低频频谱分析仪 HP 3585B
    厂家:美国惠普(HP/AGILENT) (23x43x63cm,36.7kg)
    • 频率范围:20Hz - 40MHz
    • 分 辩 率:0.1 Hz
    • 带宽解析度:3 Hz
    • 电平测量范围:-137 dBm to +30 dBm
    • 80 dB动态范围
    • 幅度精确度:± 0.4 dB
    • 可选择的输入阻抗:50 Ohm, 75 Ohm, and 1 Mohm
    • HP-IB接口
    • 内置跟踪信号发生器
    • 自动输入衰减器
    • 面板设置或标识于CRT读出
    • 1001 X 1024数字存储显示
    Uncompromising Baseband Signal Analysis
    The HP 3585A Spectrum Analyzer delivers high performance where it counts - at baseband frequencies. With unmatched accuracy, resolution, and dynamic range, the 3585A is HP's best solution for signal analysis at the critical frequencies comprising voice, picture, or digital information.
    In today's high speed, high density information processing systems, maintaining the integrity of data signals requires more measurement performance than ever before. The 3585A provides 80 dB of spurious-free dynamic range, a sharp 3 Hz resolution bandwidth, and fully synthesized tuning. Its 20 Hz - 40.1 MHz frequency range is more than adequate to cover most information bandwidths.
    Measurement performance is critically important at baseband frequencies, because signal degradation occurring here is typically not recoverable elsewhere in the system. As a result, test requirements for baseband signals and circuits often demand a level of performance that only a high-performance, low-frequency signal analyzer such as the HP 3585A can provide.
    Inside the HP 3585A
    The HP 3585A is a swept hetrodyne, triple conversion circuit with several major improvements. Frequency tuning is accomplished by a fully synthesized, phase continuous local oscillator, assuring excellent frequency stability for narrowband analysis across the entire frequency range. Internal microprocessors manage several functions including front panel operation, 1001-point digital vector storage display, and periodic calibration of amplitude and frequency offsets. An accurate internal narrowband frequency counter can discriminate between the frequencies of closely spaced sinusoids with 0.1 Hz resolution. Finally, the HP 3585A contains fast-settling narrow resolution bandwidth filters that are among the best in the industry.
    Fast, Flexible Frequency Sweeps
    Well-designed filters and the phase-continuous, synthesized local oscillator team up to give the HP 3585A very fast sweep speeds. A 40-MHz sweep using the 30-kHz resolution bandwidth takes only 200 milliseconds, fast enough for high-resolution spectrum surveillance. A 1-MHz sweep using a 1-kHz bandwidth takes only 2 seconds.
    Sweep width can be set to any arbitrary span between 0 and 40.1 MHz, or adjusted from 100 Hz to 40 MHz in a 1,2,5 step format. Resolution bandwidth and sweep time automatically track the selected frequency span to ensure optimum performance, or can be manually controlled.
    Front Panel Convenience
    The HP 3585A's microprocessor-controlled front panel and CRT readout simplify complicated measurements. Frequency and amplitude settings may be entered directly using the keypad, incrementally stepped, or varied continuously using the rotary pulse generator.
    An autoranging input attenuator eliminates the task of manually adjusting attenuation to achieve the correct mixer level. The input Range can also be manually adjusted from -25 dBm to +30 dBm in 5-dB steps.
    With its primary marker set to a signal peak or other point of interest, the HP 3585A displays amplitude and frequency numerically on the CRT. A second marker numerically displays amplitude and frequency offsets between two markers. Programmable Offset Step allows an operator to move easily between harmonically-related signals or evenly-spaced communication channels.
    Versatile Noise and Distortion Analysis
    Quiet and rock-stable, the HP 3585A excels as a noise and distortion analyzer. Its own uncompromising sensitivity and spectral purity are assured by its advanced front end design, synthesized local oscillator and built-in, oven-stabilized reference.
    The HP 3585A can measure spurious, harmonic, and intermodulation products at levels typically 100 dB or more below the fundamental. Using its 3 Hz resolution bandwidth, power line sidebands below -95 dBc can typically be measured at frequency offsets of only 50 or 60 Hz. Total harmonic distortion and intermodulation distortion measurements can be automated using HPIB programming.
    A built-in noise level key displays RMS noise density normalized to a 1 Hz bandwidth at the marker position, allowing easy comparison of measurements made with different resolution bandwidths.
    Frequency Response Measurements
    With its built-in tracking generator, digital trace storage, and narrowband frequency counter, the HP 3585A Spectrum Analyzer can accurately measure the frequency response of crystals, filters, and amplifiers. Small amplitude variations are resolved to 0.01 dB using the marker readout and the 1 dB/division expanded amplitude scale. Unwanted effects of test fixtures and cables are removed simply by storing the frequency response of the test setup in Trace B and subtracting it from measured data in Trace A.
    With its wide dynamic range capability and high-resolution display, the HP 3585A is ideal for measuring and viewing the analog portions of 14 or 16-bit digital audio systems. It can also measure the frequency response of digital modem filters with better than ± 0.4 dB accuracy.
    HF Radio Applications
    In addition to its many uses as a baseband signal analyzer, the HP 3585A finds a home in HF radio applications as well. Synthesized tuning and high-resolution display make wideband surveillance of the entire 30-MHz radio spectrum easy. Fast-settling resolution bandwidth filters speed the analysis of modulated HF carriers.
    1001 X 1024 Digital Storage Display
    The high performance of the HP 3585A is further complimented by a built-in 1001 X 1024-point display. Measured analog signals are converted to 1001 digital data points prior to storage and display, allowing each point to be accessed individually using the display marker.
    电话 010 - 62123259   52634729@qq.com
我公司专营全新及二手通用电子仪器仪表设备、测试电缆、测试附件等等。为全国厂商企业、科研单位、各类院校及部队提供质优价廉的仪器仪表。十余年来,以专业细致的技术支持和周到的售后服务,赢得了广大用户的青睐。所售仪器,经专业技术人员逐…  更多>>
北京市北方思源电子技术中心
联系人:小孙
地址:北京海淀区大柳树路富海中心4号楼105室
邮编:100081
电话:010-62123259
传真:-
公司网址:http://www.buy17.com
  • Simon Yeung 在2021/8/11 23:03:00留言
  • 详细留言:小孫,你好,有沒有二手 Tektronix A6302 ? 加我微信回覆我什麼價錢 ?
  • Simon 在2020/10/5 8:41:00留言
  • 详细留言:報價 : 二手功能完全正常 Tektronix A6302 current probe
  • Shaukat 在2018/9/24 23:20:00留言
  • 详细留言:Hi i need r&s URE3 voltmeter.
  • 王力 在2015/3/17 14:02:00留言
  • 赵先生 在2012/2/24 16:59:00留言
  • 详细留言:台湾铨华9032C五合一安规综合测试仪报价和周期
