名称:光电转换器 / 光功率计
OPTICAL ELECTRICAL CONVERTER / POWER METER
型号:OCP 5502/5002
厂家:美国泰克
尺寸:255 x 140 x 430mm
重量:6.6 kg
DC to 2 GHz, extremely low drift/low equivalent input noise/high optical return loss. The OCP 5502 Optical Power Meter / 2 GHz Electrooptical Converter incorporates the OCP 5002 and a stand-alone power supply with an additional slot for adding other test equipment (TM 5000 system)
- Measurement of average optical power from +7 dBm to -80 dBm (resolution 0,01 dBm)
- Wavelength range: 1100 to 1650 nm
- Input: accepts fiber up to 62,5 µm core diameter
- Measurements up to 2 GHz bandwidth using the O/E converter output
- Nullify drift with DC Stable Feature
- Full remote control via GBIB interface (IEEE 488.2 standard)
