北京市北方思源电子技术中心
  • 特价 二手 标准立体声解码器 MSDC2 STANDARD STERODECODER
  • 发布时间:2007/5/20 17:15:20   修改时间:2008/12/21 10:04:21 浏览次数:965
  • 标准立体声解码器 MSDC2
    STANDARD STERODECODER MSDC2
    厂家:德国罗德与施瓦茨   ROHDE&SCHWARZ
    特性:
    stereo multiplex input(balanced or unbalanced,selected with shorting link)
    Frequency range:30Hz-75KHz
    input impedance(balanced):≥40KΩ
    Common-mode suppression:
    at f<150Hz:≥58dB
       150Hz
       15KHz
    input impedance(unbalanced):≥20KΩ
    nominal input level(settable in 6-dB steps):-12 to +12dBm(0dBm=0.775v into 600Ω)
    continuous input-level adjustment:±3dB
    overdrive limit:≥6.5dB
    AF OUTPUTS
    R,L,M outputs(floating,balanced)
    nominal output level:+6dBm
    output impedance:≤20Ω
    Load impedance:≥200Ω
    Level difference between L and R channels:≤0.1dB
    S output(not floating,unbalanced)
    output impedance:≤500Ω
    Linear distortions
    frequency response variations of L,R,M or S output
    signal over the frequency range 30Hz to 15KHz
    relative to 500Hz:≤±0.15dB
    Switchable deemphasis:50μs±2%
               alternatively(slide switch on printed circuit board):75μs±2%
    Linear crosstalk
    crosstalk between M and S channels:≥46dB(typ.50dB)
    crosstalk between L and R channels:
    at 100Hz to 5KHz:≥60dB(typ.64dB)
       30Hz to 15KHz:≥58dB(typ.60dB)
    Nonlinear distortions(L,R,M and S outputs)
    Harmonic distortion at 6 and 12.5dBm:≤±0.1%
    Difference-frequency intermodulation distortion according to DIN 45 403 at 12.5dBm:d2:≤±0.05%
        d3:≤±0.1%
    weighted and unweighted noise(with 50-μs deemphasis)
    unweighted signal-to-noise ratio relative to +6dBm
    at 1000Hz,frequency range 30Hz to 100KHz,rms measurement:≥80dB
    weighted signal-to-noise ratio relative to +6dBm,
    peak-value measurement according to CCIR Recommendation 468-1:≥78dB
    peak-value measurement according to DIN 45 405:≥80dB
    Pilot-tone suppression relative to +6dBm:≥90dB
    SCA suppression relative to +6dBm in frequency range 56 to 96KHz(SCA level-16dB relative tomultiplex signal):≥76dB
    Indication on front-panel instrument
    indication of L,R,M,S or pilot-tone level via selector switch
    indicating error:≤0.2dB plus 1.5% of full scale value
    pilot-tone indication:-7.5 to -17dB
    AF indication(6 ranges in 10dB steps):+18 to -66dBm
    电话 010-62123258/59 ,网址 www.buy17.com
    地址: 北京海淀区大柳树路富海中心4号楼105
我公司专营全新及二手通用电子仪器仪表设备、测试电缆、测试附件等等。为全国厂商企业、科研单位、各类院校及部队提供质优价廉的仪器仪表。十余年来,以专业细致的技术支持和周到的售后服务,赢得了广大用户的青睐。所售仪器,经专业技术人员逐…  更多>>
北京市北方思源电子技术中心
联系人:小孙
地址:北京海淀区大柳树路富海中心4号楼105室
邮编:100081
电话:010-62123259
传真:-
公司网址:http://www.buy17.com
  • Simon Yeung 在2021/8/11 23:03:00留言
  • 详细留言:小孫,你好,有沒有二手 Tektronix A6302 ? 加我微信回覆我什麼價錢 ?
  • Simon 在2020/10/5 8:41:00留言
  • 详细留言:報價 : 二手功能完全正常 Tektronix A6302 current probe
  • Shaukat 在2018/9/24 23:20:00留言
  • 详细留言:Hi i need r&s URE3 voltmeter.
  • 王力 在2015/3/17 14:02:00留言
  • 赵先生 在2012/2/24 16:59:00留言
  • 详细留言:台湾铨华9032C五合一安规综合测试仪报价和周期
