北京市北方思源电子技术中心
  • 特价 PCM信道分析仪 PCM-4 PCM Analyser 二手仪器
  • 发布时间:2007/5/21 5:41:45   修改时间:2008/9/15 15:29:08 浏览次数:2391
  • PCM-4 PCM Analyser
    厂 家:Wandel&Goltermann
    形成自动测试序列的设置链接
    A-A,A-D,D-A,D-D测量(半信道和全信道测量)
    进行数字信号处理,以提高速度和精度
    针对特定应用的容差摸板的图形显示
    可达128kHz的带外测量
    The PCM-4 PCM Channel Measuring Set can handle practically all PCM multiplexer measurements, and also measurements on the constituent subassemblies of digital exchanges. Transmultiplexer measurements are also possible because investigations between digital
    ·形成自动测试序列的设置链接
    ·A-A,A-D,D-A,D-D测量(“半信道”和“全信道”测量)
    ·进行数字信号处理,以提高速度和精度
    ·针对特定应用的容差模板的图形显示
    ·可达128kHz的带外测量
    Ifonthing to hte contrary is stated,the values given below are vaiid for all operatingconditions and device settings within the rated rated ranges of use for a.c.livevoltage,a.c.line frequency and ambient temperature
    Analoggenerator
    Generator output
    BN984/01;984/51 balanced,floating,3-pin CF connector
    BN984/02;984/52 balanced,fem.connector compatible with WECO310
    BN 984/05;984/55 balanced,fem.connectorcompatible with 1212 APS
    Outputimpedance,switch-selectalbe 600,850,900Ω and complex
    Permissibled.c.voltage to earth ≤60V
    Sendsignals
    Sinusoidal signals
    Frequencyrange 20Hz to 72kHz
    Group-delaymeasuring signal(PCM-4 only)
    Similar to the measuring signal described in ITU-URec.O.81 and IEEE Standards
    Measuringfrequencies 292,500,604,1000,1792,2604,2792 and
    3396Hz
    Modulationfrequency selectable 41.66 or 83.33Hz
    4-tonesignal Four equal level tones at 857,862,1373 and 1388Hz
    Sendlevels
    Display of power levels(dBm0),can be switched over to voltage levels(dB0)
    Relativelevel
    Level entry in steps of0.001dB from -19.9 to +9.9dBr
    Displayedon screen in steps of 0.1dB
    Levels relative to 1mW at a point of 0 rel.level
    Levelentry in steps of 0.01dB
    Level range in the preferred range
    for relative level -17 to +3dBr,at 600Ω
    fornose(.50 to 550Hz),at least -60.0 to +2.0dBm0
    forsine signals(f≧200Hz),at least -60.0 to +10.0dBm0
    forall other signals,at least -30.0 to +2.0dBm0
    Analogreceiver
    Receiver input see"analoggenerator output"
    Additionalinput impedance ≧30kΩ
    Two-wireinput and output
    The tow-wire connector can be terminated with a complex impedancefor transhybrid loss measurements
    Receivelevels
    Calibratin.see "analog generato"
    Relative levels,see"analoggenerator"
    Levels relative to 1mW at a pontof 0 rel.level
    Level range in the preferred range of the relative level-9.9to +9.9dBr and at 600Ω
    signal levelmeasurements,at least -60.0 to +10.0dBm0
    noiseand crosstalk measurements,at lease -80.0 to 0 dBm0
    Receivefilters
    Wideband filters passband range Narrow-bandfilters passband at :
    200Hz to4kHz
    20Hz to 4kHz
    330Hz to 3100Hz
    20Hz to 72kHz
    4.6kHz to 128kHz(PCM-4only)
    301Hz
    813Hz
    1014Hz
    3343Hz
    350bis 550Hz
    Filters for weighted nose measurements
    Psophometerfilter(ITU-T Rec.P.53/O.41)
    C-message weighting filter to North American standsrds3kHz flat filter to North Amarican standards
    Psophometer filter with 2kHz notch-filter
    C-messageweighting filter with 2kHz notch-filtr
    Bandpass 300 to 3350Hz,with 2 kHz notch-filter
    Digitalsignal generator
    PCM frame structure
    BN 984/01 and BN 984/51
    32 channelPCM frames containing:
    30 telephone channels toITU-T Rec.G.704 Para.3.3
    or 31telephone channels time slots 1 to 31
    or32 telephone channels all time slots
    BN984/02,BN 984/52,BN 984/05 and BN 984/55
    Selectablebetween T1"norm"12FRM/MFRM to ITU-T G.704
    Para.3.1and T1"extd."24 FRM/MFRM to ITU-T G.704 Para.3.1
    Telephonechannels per frame 24
    Channelsequences D3/D4,D2 or D1D
    Signalling
    μ-law CCIS or CAS(75/6)
    A-law CCIS
    Generatoroutputs
    Interface characteristics comply with ITU-TRec.G703
    Line codes NRZ,AMIand HDB3
    Coaxial output Versacon9 Universal Connector
    System,adaptable to all common connectors
    Outputimpedance 75Ω
    Balanced output 3ploe,CF connector
    Output impedance 120Ω
    Interface characteristics comply withITU-T Rec.G703 and North American standards
    Linecodes AMI and B8ZS
    Output pulsecharacteristic to AT&T
    Technical Advisory No.34
    W-bitinsertion ON or OFF
    Balancedoutput fem.connectro compatible with WECO310(BN 984/02 and984/52)1214APS(BN 984/05and 984/555)
    Outputimpedance 100Ω
    Operation andclock supply
    Loop-through operation
    A test pattern is injected into onetime slot of a PCM frame which has been looped through the PCM-4
    BN984/01 and BN 984/51
    Generator operation
    frominternal clock 2048kHz±25*10-6
    orexternal clock 2048kHz ±100*10-6
    orexternal 8 kHz sync-signal 8kHz ±100*10-6 or clockderived from receiver signal
    Digitalloops
    2Mbit/s loop: all timeslots are switched through
    2Mbit/sloop: selected time slots can be switched through (independentselection of the receive and send channel is possible)
    64 kbit/sloop: at relevant interfaces(Option)
    Generator operation
    frominternal operation 1544±25*10-6
    orexternal clock 1544 ±100*10-6
    orexternal 8kHz sync.signal 8kHz ±100*10-6 or clock derivedfrom receiver signal
    Digitalloops
    1.5Mbit/s loop: all timeslots are switched through
    1.5Mbit/sloop: selected time slots can be swithced through (inedependentselection of the receive and send channel is possible)
    64kbit/sloop: at relevant interfaces(Option)
    Digitalwords for telephone channels
    Injectionof a digital signal in one of the telphone channels 1 to 30(or 31,32)or in alltelephone channels,or in all telphone channels except the selected channel.
    Encodinglaw,selectable A-law ro μ-law
    Injectionof a digital signal in one of the telephone channels 1 to 24,or in all telephonechannels,or in all telepohe channels except the selected channel.
    Encodinglaw,selectable A-law or μ-law
    Sendsignals
    Sine signals
    Frequency range 20Hzto 3.99kHz
    Send level rage(in stepsof 0.1dB) -60.0 to +7.5dBm0
    Noisesignals
    Pseudorandom noise signal
    350Hzto 550Hz complies with 300 to 3400Hz
    Sendlevel range(0.1dB steps) -65.0 to 0.0dBm0
    Widebandnose sihnal for telpbhone channels
    Noise band 300to 3400Hz
    Send level range -65.0to 0.0dBm0
    Conventional telephone signal complieswith ITU-T Rec.G.227
    Send levelrange -30.0 to 0.0dBm0
    Echo returnloss and singing return loss signals to North American standards
    Noiseband of ERL-signal 560 to 1965Hz
    Noiseband of SRL-signal 260 to 500Hz
    Noiseband of SRLH-signal 2200 to 3400Hz
    Sendlevel range -30.0 to 0.0dBm0
    Groupdelay measuring signal
    See: "Analoggenerator signals"
    4-tonesignal
    See: Analoggenerator signals"
    Send level range -30.0to 0.0dBm0
    Idle channel signals
    Anyfixed word can be silected.It is also possible to select words which vary randomlyor periodically between two neighbouing values
    Bitpatterns
    The following are available for bit error measurements:
    Pseudorandomsequence complying
    with ITU-TRec.V.52 29-1 bits long
    Pseurdorandomsequence complying
    withITU-T Rec.0.152 211-1 bits long
    User-programmable8 bit word
    External analog signal(via VAR.MODE)
    An external analog signalcan be input via an internal PCM coder and injicted in one telephone channel oroutput via 64kbit/s interface
    Testfacilities and error insertion
    BN 984/01 and BN 984/81
    AIS transmission(continuous sequence of "1"s)
    Frame alignmentbit error ratio 10-3 or 10-4
    Framealignment word errors 2 or 3 in 4
    Multiframealignment errors of 1 or 2 in 2
    CRC-4error ate settable in steps of 0.1%
    inthe range 0.1 to 99.9% based on 1s(1000CRC-4 words)
    BN984/02,984/52,984/005 and BN 984/55
    ALL ONES transmission
    Bit 2 alarm transmission
    Bit2 is set to "0" in each channel
    Sbit alarm(T1"norm")transmission
    S-bitin frame 12 is set to "1" m bit alarm(T1"extd")transmission
    Eight"0"-bitsalternating with eight"1"-bits
    FAS errors 1in 6 bits or 2 in 4 bits
    S-bit/MFASerrors 1 or 2 in 6bits
    CRC-6error rate settalbe in steps of 0.3%
    inthe range 0.3 to 99.7% based on 999 ms(333 multiframes)
    Signallingfacilities
    Static signalling bits
    Transmissionof signalling bits a b c d in time slot 16 for selected and unoccupied telphonechannels
    Signalling byt value settable via menu
    Dynamic signalling bits
    Signallingbit value for selected telephone channel set externally via aus.parallel input
    BN984/02,BN 9848/52,BN 984/05 and BN 984/55
    Transmissionof signalling bits A, B/A,B,D,D for selected and unoccupied telephone channels
    Singanllingbit value settable via menu
    Signaling bit valuefor selected telephon channel set exgernally via aux.parallel input for CAS(75/6)only,orS/m bit value set externally via contradirectional 4 kbit/s input
    Digitalsignal receiver
    PCM frame struture see "digital signal generator"
    Receiverinputs
    Interface characteristis comply with ITU-TRec.G.703
    Line code NRZ,AMIand HDB3
    Coaxial input 75Ω or>3kΩ
    Balanced input 12Ωor >3kΩ
    Input signal monitoring via LEDs: NOSIGNAL,AIS ,NO FRAME,NO MULTIRRAME
    Interface characteristics comply withITU-T Rec.G.703 and North American standards.
    Balancedinput fem.connector compatible with WECO 310(BN 984/02,984/52);1214APS(BN684/05,984/55)
    Input impedance 100Ωor >3kΩ
    Input signal monitoringvia LEDs: NO SIGNAL,ALL ONES,NO SYNC,REMOTE ALARM
    Evalutionof digital word in telephone channels
    Selectinga telphone channel
    A code word from one telephone channel 1 to 30(or 31,32)canbe evaluated.
    Code word measurements
    Receivelevel range,at least -80 to +6dBm0
    BN984/02,BN 84/52,BN 984/05 and BN 984/55
    Selecting a telephone channel
    Acode word from one telephone channel 1 to 24 can be evaluated
    Receivelevel range ,at least -80 to +6 dBm0
    Receivefilters see"Analog receive "
    Bit error measurements
    on telep[honechannels(64 kbit/s).Shown as a histogram with the X axis representing measuringperides or channels.
    Bit pattern: see"digitalsignal generagor send signals"
    Error conutson FAS/MFAS and CRC-signals
    Signalling distortion measurements(option;PCM-4only)
    Method:
    Measure the duty cycle deviation of a rectangular signal
    Generator
    Frequencysetting 10Hz or 20Hz
    Duty cyclesettable in step
    Analog output(back panel)
    Outputimpedance,mark <30Ω
    space >20kΩ
    Max.switchingvoltage 200mA
    Max.switchingvoltage 70V
    Signallingreceiver Measuring range ±10ms
    Resolution 0.1ms
    Analoginput(back panel)Input impedance (connected internally to -15V) 750Ω
    Shor-circuitcurrent 10mA
    Evaluationand monitoring of words and bits
    Monitor ing via8 LEDs(bits 1 to 8)
    Codewords of selected channel,FAS,NOT RAS ,MFAS NOT MFASSignalling bits a b c d (TX and RX)
    Evalution on screen (MODEB91)
    Codewordsof selected channel,FAS,NOT FAS,MFAS,NOT MEFASM\,Signalling bits a b c d(RX)
    Monitoring via 8 LEDs(bits 1 to 8)
    Codewordsof selected channel,FAS or MFAS,S bits,
    Signalling bits ,B/A,B,C,D
    Auxiliaryoutputs(back panel)
    Activation signal for crosstalk measurements
    Analogdecoder output for decoded signal of selected telephone channel
    Signallingoutput
    Error and alarm outputs
    Video signal output
    GeneralSpecifications
    Power supply
    Rated ranges of use for a.c. line voltage,12%to +10%
    swithch-selectable 110/117/127/220/227/237V
    BN984/05 and BN 984/55 only 100/110/117/200/210/217v
    Ratedrange of use of a.c.line frequency 47.5 to 63Hz
    Powerconsumption approx.150VA
    Safetyclass to IEC 348 and VDE 0411 Class 1
    Ambienttemperatur
    Ratedrange of use +5 to +0℃
    Storageand transportation -40 to +70℃
    Dimensions
    Bench-topinstrument(w*h*d in mm) 477*244*425
    Weight approx.25kg
    订货信息
    PCMChannel Measuring Set PCM-4
    2048 kbit/s version,menuin English BN 984/01
    1544kbit/s version,menu in English,WECO connectors BN 984/02
    2048 kbit/s version,menu in German
    BN 984/03
    1544kbit/s version,menu in English,1214 APS connectors BN 984/05
    2048kbit/s version,menu in Spanish BN 984/06
    PCMChannel Measuring Set PCM-5
    2048 kbit/s version,menuin English BN 984/51
    1544kbit/s version,menu in English,WECO connectors BN 984/52
    2048kbit/s version,men in German BN 984/53
    1544kbit/s version,meanu in English,1214 APS connectors BN 984/55
    Options
    Interfaces:
    Codirectional64 kbit/s input BN 984/00.01
    Codirectional64 kbit/s output
    Electrical characteristics to ITU-T G.703
    BN984/00.02
    Contradirectional 64kbit/s input BN 984/00.03
    Contradirektionaler64 kbit/s output
    BN984/00.04
    Serial 64 kbit/s TTLinput BN 984/00.05
    Serial 64 kbit/sTTL output
    Co-or contradirectional,depending on mode
    BN984/00.06
    Parallel 64 kbit/s TTLinput BN 984/00.07
    Parallel 64kbit/s TTL output
    Parallel 8 bit input/output with 8kHz clock signal
    BN984/00.08
    64 kbit/s V.11 interface
    formeasurement of signalling distortion and interference fromsignalling
    BN984/00.09
    IEEE 488/IEC 625 Interface
    with IEEE488 connector and K 420 connecting calbe
    BN 984/00.09
    Analogsignalling interface for measurement of signalling distortion and interferencefrom signlling BN 984/00.19
    IEEE488/IEC 625 Interface with IEEE 488 connector and K 420 connecting calbe BN958/24
    Bridges:
    Reurn Lossand Longitudinal Conversion
    Transfer Loss Bridge
    600Ω/900Ω/CPLX(PCM-4only) BN984/00.0
    600Ω/900Ω9CPLX(PCM-4only) BN984/00.11
    Impedance modification(replaces 850Ω or900Ω and CPLX) BN 984/00.32
    Bridgeimpedance addition
    Up to 4 additional customer specific CPLX impedances canbe added to the bridge;selection lnly via IEC/IEEE interface
    BN984/00.16
    12 kHz low pass filter
    for out-of-bandnoise suppressin
    BN 984/00.14
    Softwareretrofitted to the latest status for
    PCM-4BN 984/01 BN 984/00.41
    PCM-4BN 984/02 and BN 984/05 BN 984/00.42
    PCM-4BN 984/03 BN 984/00.43
    Specifyactual software version and serial no.when ordering
    Userspecified modifications
    A detailed specification sheet is available for enteringthe values required
    Analog generator/receiverimpedance modifications(replacces 850Ω/900Ω and CPLX) BN 984/00.31
    Analonggenerator output impedance modified to Zou≈0Ω in place of complex impedance BN984/00.34
    Impedance modification(replaces850Ω or 900Ω and CPLX) BN 984/00.32
    1wire terminaltion modification(replaces 910Ω||39nF)(selected with PARAM 914,D-Dmode) BN 984/00.33
    Tolerancemasks programmed to user specifications BN 984/00.35
    Instrumentsare equipped with ITU-T tolerance masks as standard
    Forms for entering toperancemask changes are included in Appendix D of the operating manual
    Accessories
    LabWindow®Driver(forPCM-4/5 and MU-30)
    for integrationin automatic test systems for development,productionand service/calibration
    BN 984/95.99
    TestPoint Scanner MU-30
    with Interface Card
    Balanced through0switchingof 10,24 or 30 VF channel in TX and RX directions
    BN 823/11
    WGPenBERT mini PCM monitor(E1)(see WG PenBERT data sheet for details) BN4555/11
    D.C.Loop Holding CircuitGH-1
    with capacitor-coupled output
    BN 984/00.12
    1.5mconnecting calbe
    CF (male )to 1214 APS(male)
    K 348
    1.0mconnecting cable CF(male)to 1214 APS (male) K 438
    D.C.Decouplingfor analog inputs and outputs,PCMZ-4 for use with BN 984/01,BN 984/51,BN 984/03and BN 984/53 only.(Not required if (GH-1 is used) BN 984/00.13
    IEEE488/ Adapter(m-m)
    for Interface card
    S832
    Front and Back Panel Covers SD-5(1 set) BN700/00.25
    19" conversion kty BN700/00.05
     电话 010-62123258/59 ,网址 www.buy17.com
    地址: 北京海淀区大柳树路富海中心4号楼105
我公司专营全新及二手通用电子仪器仪表设备、测试电缆、测试附件等等。为全国厂商企业、科研单位、各类院校及部队提供质优价廉的仪器仪表。十余年来,以专业细致的技术支持和周到的售后服务,赢得了广大用户的青睐。所售仪器,经专业技术人员逐…  更多>>
北京市北方思源电子技术中心
联系人:小孙
地址:北京海淀区大柳树路富海中心4号楼105室
邮编:100081
电话:010-62123259
传真:-
公司网址:http://www.buy17.com
  • Simon Yeung 在2021/8/11 23:03:00留言
  • 详细留言:小孫,你好,有沒有二手 Tektronix A6302 ? 加我微信回覆我什麼價錢 ?
  • Simon 在2020/10/5 8:41:00留言
  • 详细留言:報價 : 二手功能完全正常 Tektronix A6302 current probe
  • Shaukat 在2018/9/24 23:20:00留言
  • 详细留言:Hi i need r&s URE3 voltmeter.
  • 王力 在2015/3/17 14:02:00留言
  • 赵先生 在2012/2/24 16:59:00留言
  • 详细留言:台湾铨华9032C五合一安规综合测试仪报价和周期
