北方思源电子技术中心
  • 高速采样示波器 Agilent/HP 54750A
  • 发布时间:2008/4/16 17:40:33   修改时间:2008/4/16 17:40:29 浏览次数:613
    厂家: 美国安捷伦/惠普 ( cm,24.5kg)
    The Agilent 54750A is a modular system. Up to four high-bandwidth channels and TDR are supported by the mainframe. The modular design allows for expansion to meet changing needs.
    The 20-GHz or 50-GHz bandwidth and the low-noise specifications allow very precise measurements on low-level, high-speed signals. Timebase stability, accuracy, and resolution allow characterization of jitter in the most demanding applications.
    • 62.5-fs Resolution
    • 10-ps Accuracy
    • TDR/TDT测量
    • 存储深度:4k/CH
    • 数据传输率:550Kbytes/s typical
    配:Agilent 54753A Single Ended TDR/TDT Plug-In Module
    The Agilent 54753A TDR/TDT plug-in modules provide you with TDR and TDT measurement features. In addition to the TDR and TDT measurement features, the TDR plug-ins provide two accurate oscilloscope measurement channels with user selectable bandwidths of 12.4 or 18 GHz. The lower bandwidth mode provides excellent oscilloscope noise performance for accurate measurement of small signals. The high bandwidth mode provides high-fidelity display and measurement of very high-speed waveforms.
    • 通道数:2 CH
    • 用户可选择带宽:12.4 or 18 GHz (Channel 1)
    • 用户可选择带宽:12.4 or 20 GHz (Channel 2)
    • 2.5 GHz 触发通道
    • 带宽:TDR/垂直通道上为20-GHz、18-GHz
    • 垂直精度:0.4%
    • 垂直分辨率:12位(平均值为15)
    • 最大噪声:< 1 mVrms
    • Automatic and manual single-ended TDR and TDT measurement capability
    • Automatic and manual waveform, histogram, FFT, waveform math, eye pattern measurements, statistical measurements, and limit testing capabilities
北京市北方思源电子技术中心  我公司专营全新及二手通用电子仪器仪表设备、测试电缆、测试附件等。为全国厂商企业、科研单位、各类院校提供质优价廉的仪器仪表。十余年来,以专业细致的技术支持和周到的售后服务,赢得了广大用户的青睐。所售…  更多>>
北方思源电子技术中心
联系人:刘凌
地址:北京市海淀区大柳树路富海中心
邮编:100081
电话:010-62123258
传真:010-62123259
公司网址:http://www.buy17.com
  • 王志勇 在2022/7/3 7:19:00留言
  • 详细留言:我有一台LITE3000,由于自己能力所限,实在搞不明白,特请专家指导,如需要资金请说明,谢谢!
  • 陈春生 在2012/7/9 15:53:00留言
  • 详细留言:使用说明书(中文)
