取样示波器 Tektronix 11801B/SD-22
厂家: 美国惠普
尺寸: 45x24x60cm
重量: 22.3 kg
- 主机带宽 DC to 50 GHz
- 7 ps Rise Time
- 8 Channels, Expandable to 136 (with SM-11)
- 10 fs Sampling Interval (0.01 ps)
- 200 kS/s Sample Rate
- 双时基 Dual Time Base
- Non-volatile Waveform and Setting Storage
- FFT
- Predefined Telecom Masks (Opt. 1T)
- TDR
- Automatic Measurements:
- Jitter/Noise, Statistical
- Histograms, Mask Testing
- Pulse with Statistics
- Programmable for ATE Applications
- 彩色触摸屏
Sampling Heads
SD-22: 12.5 GHz dual-channel low noise head 双通道 低噪声
The SD22 is a dual-channel, 12.5 GHz sampling head specifically designed for low-noise measurement in digital communications and device characterization applications. It provides an acquisition rise time of 28 ps, and typically 450 µVRMS of displayed noise. With smoothing, noise levels are 180 µVRMS.
In order to precisely capture and display the switching characteristics of high-speed communications circuits, to make accurate statistical measurements of signal noise and signal timing jitter, or to obtain stable timing measurements of fast digital ICs, the noise floor of the test equipment must be kept to a minimum. The SD22 is the ideal instrument for these low-noise applications.
Selection Guide
Channels |
Bandwidth |
Rise Time |
Impedance |
Noise |
Applications (Typical) |
| SD14 |
2 |
3 GHz (typical) |
140 ps |
100 kilohm/0.5 pF 0.55 pF Opt. 01 |
2 mV |
ECL, CMOS, ACL GaAs Dev. Characterization |
| SD20 |
1 |
20 GHz |
17.5 ps |
50 Ohm unterm. |
750 µV |
Special TDR, Communications |
| SD22 |
2 |
12.5 GHz |
28 ps |
50 Ohm |
450 µV |
Communications |
| SD24 |
2 |
20 GHz |
17.5 ps |
50 Ohm |
750 µV |
TDR/TDT Crosstalk |
| SD26 |
2 |
20 GHz |
17.5 ps |
50 Ohm |
750 µV |
Device Characterization |
| SD32 |
1 |
50 GHz |
7.0 ps |
50 Ohm |
1.8 mV |
High Bandwidth Communications & Microwave |
| SD42 |
1 |
6.4 GHz |
Optical-to-electrical |
| SD44 |
1 |
15 GHz |
| ORR24 |
1 |
2.0 GHz |
205 ps |
50 Ohm |
Optical Reference Receivers (SONET/SDH) |
