如需了解相关信息咨询 薛晨:13801020197 |
| 1771-OFE3 |
ANALOG OUTPUT MODULE |
12 BIT, 4 DIFFERENTIAL, 1000V ISOLATION, 0 TO 50MA |
| 1771-OG |
TTL OUTPUT MODULE |
8 OUTPUTS, USER SELECTABLE HIGH/LOW TRUE LOGIC LEVELS |
| 1771-OGD |
TTL OUTPUT MODULE |
16 OUTPUTS, USER SELECTABLE HIGH/LOW TRUE LOGIC LEVELS |
| 1771-OJ |
PULSE OUTPUT EXPANDER ASSEMBLY |
(1) INCLUDED WITH 1771-QA |
| 1771-OM |
220/240V AC OUTPUT MODULE, 8 DRIVER, SOURCE OUTPUT |
| 1771-OMD |
220V AC OUTPUT MODULE, 16 OUTPUTS |
| 1771-ON |
24V AC OUTPUT MODULE, 8 OUTPUTS |
| 1771-OND |
24VAC OUTPUT MODULE, 16 OUTPUTS |
| 1771-OP |
120V AC PROTECTED OUTPUT MODULE, 4 OUTPUTS |
| 1771-OQ |
24V DC ISOLATED OUTPUT MODULE |
8 OUTPUTS, ISOLATED IN GROUPS OF 2 |
| 1771-OQ16 |
ISOLATED OUTPUT MODULE, 24V DC |
| 1771-OQ16K |
CONFORMALLY COATED,ISOLATED OUTPUT MODULE,24V DC |
| 1771-OR |
ISOLATED OUTPUT MODULE, 6 OUTPUTS, 220V AC |
| 1771-OVN |
LOW-TRUE OUTPUT MODULE, 32 OUTPUTS, 10-30V DC |
| 1771-OW |
CONTACT OUTPUT MODULE |
8 SELECTABLE CONTACTS, 8 NO OR NC SELECTABLE CONTACTS |
| 1771-OW16 |
CHANNEL-ISOLATED CONTACT OUTPUT MODULE |
16 POINT (8 NO, 8 SELECTABLE) |
| 1771-OW16K |
CONFORMALLY COATED, CHNL-ISOL. CONTACT OUTPUT MDL. |
| 1771-OWK |
CONFORMALLY COATED, CONTACT OUTPUT MODULE |
8 SELECTABLE CONTACTS, NO OR NC |
| 1771-OWN |
SELECTABLE CONTACT OUTPUT MODULE 32 POINT |
| 1771-OWNA |
CONTACT OUTPUT MODULE 32 POINT (NORMALLY OPEN) |
| 1771-OX |
POWER CONTACT OUTPUT MODULE, 4 SELECTABLE CONTACTS |
| 1771-OXK |
CONFORMALLY COATED, POWER CONTACT OUTPUT MODULE |
| 1771-OYL |
REED RELAY CONTACT OUTPUT MODULE, 0 TO 24V |
| 1771-OZL |
| 1771-OZLK |
CONFORMALLY COATED, REED RELAY CONTACT OUTPUT MDL. |
0 TO 24V |
| 1771-P10 |
POWER SUPPLY,2-SLOT (125V DC, 8 AMPS) |
| 1771-P2 |
POWER SUPPLY, 6.5A, 120/220V AC |
| 1771-P4R |
POWER SUPPLY,REDUNDANT,SLOT,8A,120V AC |
| 1771-P4RK |
CONFORMALLY COATED, POWER SUPPLY, REDUNDANT, SLOT |
8A, 120V AC |
| 1771-P4S |
POWER SUPPLY, SLOT, 8A, 120V AC |
| 1771-P4S1 |
POWER SUPPLY, SLOT (ONE SLOT), 8A, 100V AC |
| 1771-P4SK |
CONFORMALLY COATED,POWER SUPPLY,SLOT,8A,120V AC |
| 1771-P5 |
POWER SUPPLY,SLOT,8A,24V DC |
| 1771-P5E |
POWER SUPPLY, SLOT,8A,24V DC (EMI ENHANCED) |
| 1771-P5EK |
CONFORMALLY COATED,POWER SUPPLY,SLOT,8A,24V DC |
(EMI ENHANCED) |
| 1771-P5K |
| 1771-P6R |
POWER SUPPLY,REDUNDANT,SLOT,8A,220V AC |
| 1771-P6S |
POWER SUPPLY,SLOT (ONE SLOT), 8A, 220V AC |
| 1771-P6S1 |
POWER SUPPLY,SLOT(ONE SLOT), 8A,220V AC |
| 1771-P7 |
POWER SUPPLY, 16A, 120/220V AC |
| 1771-P7K |
CONFORMALLY COATED, POWER SUPPLY, 16A, 120/220V AC |
| 1771-PCB |
CONTROL COPROCESSOR PRGM DEVELOPMENT & CROSS CMPLR |
SOFTWARE, ON-LINE/OFF-LINE, 3.5 DISKS |
| 1771-PM |
CLUTCK/BRAKE MODULE, (USED IN PAIRS) |
| 1771-PS7 |
MULTIVOLTAGE 1771 RACK POWER SUPPLY |
+5V DC BACKPLANE, +-15V DC, +5V DC, +24V DC ISOLATED |
| 1771-PS7K |
CONFORMALLY COATED, MULTIVOLTAGE 1771 RACK PWR SPL |
| 1771-PSC |
POWER SUPPLY CHASSIS, 4 SLOTS |
| 1771-PSCC |
POWER CABLE, 1771 I/O RACK TO 1771-PS7, 1771-PSC |
5.5 FT/1.68 M |
| 1771-PT1 |
FIBER OPTIC CABLE |
98.4 FT/30 M, PRETERMINATED USE WITH 1771-AF, 1771-AF1 |
| 1771-PT2 |
FIBER OPTIC CABLE |
246 FT/75 M, PRETERMINATED USE WITH 1771-AF, 1771-AF1 |
| 1771-PT3 |
FIBER OPTIC CABLE |
492 FT/150 M, PRETERMINATED USE WITH 1771-AF, 1771-AF1 |
| 1771-PT4 |
FIBER OPTIC CABLE |
984 FT/300 M, PRETERMINATED USE WITH 1771-AF, 1771-AF1 |
| 1771-QA |
STEPPER MOTOR POSITIONING ASSEMBLY W/ 1771OJ,-M1 |
| 1771-QB |
LINEAR HYDRAULIC POSITIONING MODULE |
| 1771-QD |
PLASTIC INJECTION CONTROL MODULE |
| 1771-QDC |
PLASTIC MOLDING MODULE |
| 1771-QI |
PLASTIC MOLDING MODULE FOR COINJECTION |
WITH PROCESS TRACE |
| 1771-RK |
I/O RACK KEYING BANDS, 36 PER PACKAGE |
| 1771-RT41 |
4 CHANNEL REMOTE TERM. PNL W/ COLD JUNCTION SENSOR |
FOR HIGH RESOLUTION ISOLATED ANALOG MODULE |
| 1771-RT44 |
REMOTE TERMINATION PANEL, BASE VERSION, 4 CHANNEL |
| 1771-RTP1 |
HIGH RESOLUTION ISOLATED ANALOG SERIES |
REMOTE TERMINATION PANEL W/COLD JUNCTION SENSOR |
| 1771-RTP3 |
REMOTE TERMINATION PANEL W/FUSES AND RESISTORS |
| 1771-RTP4 |
REMOTE TERMINATION PANEL |
| 1771-SDN |
2-CHANNEL DEVICENET SCANNER MODULE |
| 1771-SIM |
8 POINT DISCRETE INPUT/OUTPUT SIMULATOR MODULE |
| 1771-SN |
SUB I/O SCANNER MODULE |
| 1771-SPI |
SPI PROTOCOL INTERFACE MODULE |
| 1771-TCM |
TEMPERATURE CONTROL MODULE |
| 1771-TCMR |
RTD TEMP CONTROL MODULE |
| 1771-VHSC |
VERY HIGH SPEED COUNTER MODULE |
| 1771-VHSCK |
CONFORMALLY COATED, VERY HIGH SPEED COUNTER MODULE |
| 1771-WA |
FIELD WIRING ARM, 10 TERMINALS, TIN PLATED |
| 1771-WB |
FIELD WIRING ARM, 12 TERMINALS, GOLD PLATED |
| 1771-WC |
FIELD WIRING ARM, 10 TERMINALS, GOLD PLATED |
| 1771-WD |
FIELD WIRING ARM, 12 TERMINALS, TIN PLATED |
| 1771-WE |
THERMOCOUPLE WIRING ARM FOR IX/IY |
| 1771-WF |
FIELD WIRING ARM, 18 TERMINALS |
| 1771-WG |
FIELD WIRING ARM, 21 TERMINALS, GOLD PLATED |
| 1771-WH |
FIELD WIRING ARM, 21 TERMINALS, TIN PLATED |
| 1771-WHF |
FUSED WIRING ARM |
| 1771-WHFB |
FUSED WIRING ARM (1.5A FUSE) |
| 1771-WI |
THERMOCOUPLE WIRING ARM FOR IXE, 18 TERMINALS |
| 1771-WN |
FIELD WIRING ARM, 32 TERMINALS |
| 1771-XB |
MODULE GROUP 1 SET OF 8 LABELS, FOR 8,16,32,PT I/O |
| 1771-XL |
MODULE GROUP, SET OF 1 LABEL FOR 8 PT. I/O |
| 1784-CF64 |
INDUSTRIAL COMPACTFLASH CARD 64MB |
| 1784-CP |
CABLE ASSY, 10.5 FT/3.2 M, 1784-KTP, KT, KT2, KL |
(62-PIN D-SHELL) PLC-5/10, 12, 15, 25 & PLC-3 W/DH+ (9-PIN D-SHELL) |
| 1784-CP10 |
PC SERIAL PORT (9 PIN) TO PLC-5 SERIAL (25 PIN) |
CABLE ASSY, 10FT/3.20M |
| 1784-CP11 |
PC SERIAL PORT (25 PIN) TO PLC-5 SERIAL (25 PIN) |
| 1784-CP14 |
1784-PKTX/PKTXD TO SLC 500 RJ-45 CONNECTOR |
CABLE ASSY, 10 FT/3.2 M |
| 1784-CP15 |
1784-KTX/KTXD TO PLC-2 15-PIN CONNECTOR |
| 1784-CP16 |
1784-KTX/KTXDTO PLC-3 25-PIN CONNECTOR |
| 1784-CP2 |
CABLE ASSY, 10 FT/3.20 M, 1784-KTP, -KT, -KT2, -KL |
(62-PIN D-SHELL) TO PLC-2 PROCESSORS (FRONT PORT 15-PIN D-SHELL) |
| 1784-CP3 |
(62-PIN D-SHELL) TO PLC-3 PROCESSORS (FRONT PORT 25-PIN D-SHELL) |
| 1784-CP5 |
CABLE ASSY, 10FT/3.20M, 1784-KTK1 (15-PIN D-SHELL) |
TO 5/10, 5/15, 5/25 & PLC-3 WITH DH+ (9-PIN D-SHELL) |
| 1784-CP6 |
CABLE ASSY, 10FT/3.05M,KT/KT2/KL TO PLC-5 (DIN) |
| 1784-CP7 |
ADAPTER, CP/CP5 TO PLC-5 (DIN) |
| 1784-CP8 |
ADAPTER 62-PIN D-SHELL TO 3-PIN PHOENIX |
FOR 1784-KT, -KT2, -KL |
| 1784-DPC1 |
1784-KTCX KT EMULATION DUALPORT TOOLKIT |
| 1784-KTCX15 |
CONTROLNET(1.5 ONLY)ISA/EISA BUS |
INTERFACE CARD W/BNC CONNECTORS AND NETWORK ACCESS PORT |
| 1784-KTS |
ISA BUS PC CARD WITH RIO SCANNER |
CONNECTIVITY ONE CHANNEL |
| 1784-KTX |
ISA BUS PC CARD W/DH+, DH485 & RIO |
SCANNER CONNECT ONE CHANNEL |
| 1784-KTXD |
SCANNER CONNECT TWO CHANNEL |
| 1784-PCC |
CONTROLNET PCMCIA COMMUNICATION CARD |
| 1784-PCC1 |
PCMCIA CARD INTERFACE CABLE TO CNET |
10 FT/3.2 M |
| 1784-PCD |
DEVICENET PCMCIA COMM CARD |
| 1784-PCD1 |
DEVICENET PCMCIA CABLE (PC CARD CONNECTOR TO |
5-POSITION OPEN-STYLE HEADER), 1 FT/0.3 M |
| 1784-PCIC |
CONTROLNET PCI BUS MESSAGING CARD WITH |
| 1784-PCICS |
CONTROLNET PCI BUS SCANNER & MESSAGING CARD WITH |
| 1784-PCID |
DEVICENET PCI BUS EXPLICIT MESSAGING CARD |
| 1784-PCIDS |
DNET UNIV PCI BUS SCANNER CARD |
W/SCANNER FUNCTION |
| 1784-PCM2 |
DIRECT CONNECT CABLE (15 PIN D SHELL) FOR PLC-2 |
10 FT/ 3.2 M |
| 1784-PCM4 |
1784-PCMK DH485 COMMUNICATION CABLE (RJ45) |
10 FT/ 3.2 M |
| 1784-PCM5 |
PLC-5/PCMCIA COMMUNICATION CABLE |
10 FT/3.16 M (9-PIN D-SHELL) WITH 1784-CP7 ADAPTER |
| 1784-PCM6 |
1784-PCMK DH+COMMUNICATION CABLE(8 PIN DIN) |
10 FT/ 3.2 M |
| 1784-PCMC |
PCMCIA 1784PCMK COMMUNICATION CARD |
+ PCM5 CABLE (9-PIN D-SHELL) |
| 1784-PCMC1 |
PCMCIA 1784-PCMK CARD W/1784-PCM6 |
CABLE (8PIN DIN) |
| 1784-PCMK |
PCMCIA COMMUNICATIONS CARD |
FOR PLC-5,-5/250,-3,-2 |
| 1784-PCMKS |
PRMCIA 1784PCMKS/A CARD FOR RIO SCANNER |
| 1784-PKTCS |
CNET UNIV PCI BUS IOLINX SCANNER CARD (BNC, NAP) |
| 1784-PKTS |
PCI BUS CARD WITH RIO SCANNER- 1 CHANNEL |
| 1784-PKTX |
PCI BUS CARD W/ DH+,DH485,RIO SCANNER |
ONE CHANNEL |
| 1784-PKTXD |
PCI BUS CARD W/DH+,DH485,RIO SCANNER |
TWO CHANNEL |
| 1784-PM02AE |
2 AXIS ANALOG/ENCODER PCI MOTION CARD |
| 1784-PM16SE |
16 AXIS PCI SERCOS MOTION MODULE |
| 1784-PMCSY4 |
1784PCI MOTION MODULE SYNCHRONIZATION CABLE |
| 1785-ACC5LA |
ACCESSORY KIT FOR PLC-5/11,5/20 |
| 1785-ACC5LB |
ACCESSORY KIT FOR PLC-5/30 OR HIGHER |
| 1785-BCM |
PLC-5 BACK-UP COMMUNICATIONS MODULE |
| 1785-BEM |
PLC-5 BACKUP COMMUNICATIONS EXPANSION MODULE |
| 1785-CHBM |
CONTROLNET 1.5 HOT BACKUP MEMORY CARTRIDGE |
| 1785-ENET |
PLC-5 ETHERNET/IP EXPANSION MODULE FOR PLC-5 |
| 1785-KA |
DATA HWY/DATA HWY PLUS INTERFACE MODULE |
| 1785-KA3 |
PLC-2 DATA HWY PLUS COMMUNICATION ADAPTER MODULE |
| 1785-KA5 |
COMMUNICATION MODULE DATA HWY PLUS TO DATA HWY 485 |
| 1785-KA5P |
COMMUNICATION MODULE, PANEL MOUNT DH+ TO DH-405 |
| 1785-KE |
DATA HWY PLUS RS-232C INTERFACE MODULE |
| 1785-L11B |
PLC-5/11 CONTROLLER, 8K WORK SRAM |
| 1785-L20B |
PLC-5/20 CONTROLLER, 16K WORD SRAM |
| 1785-L20C15 |
PLC-5/20C FOR CONTROLNET PHASE 1.5 |
| 1785-L20E |
ETHERNET/IP PLC-5/20 CONTROLLER, 16K WORD SRAM |
| 1785-L26B |
PROTECTED PLC-5/20 CONTROLLER, 16K WORD SRAM |
| 1785-L30B |
PLC-5/30 CONTROLLER, 32K WORD SRAM |
| 1785-L40B |
PLC-5/40 CONTROLLER, 48K WORD SRAM |
| 1785-L40C15 |
PLC-5/40C FOR CONTROLNET PHASE 1.5 |
| 1785-L40E |
ETHERNET/IP PLC-5/40 CONTROLLER, 48K WORD SRAM |
| 1785-L40L |
EXTENDED LOCAL PLC5/40, 48K WORD SRAM |
| 1785-L46B |
PROTECTED PLC-5/40 CONTROLLER, 48K WORD SRAM |
| 1785-L46C15 |
PROTECTED CONTROLNET PLC-5/40 CONTROLLER, 48K WORD |
| 1785-L60B |
PLC-5/60 CONTROLLER, 64K WORD SRAM |
| 1785-L60L |
EXTENDED LOCAL PLC-5/60 CONTROLLER, 64K WORD SRAM |
| 1785-L80B |
PLC-5/80 CONTROLLER, 100K WORD SRAM |
| 1785-L80C15 |
PLC-5/80C FOR CONTROLNET PHASE 1.5 |
| 1785-L80E |
ETHERNET/IP PLC-5/80 CONTROLLER, 100K WORD SRAM |
| 1785-L86B |
PROTECTED PLC-5/80 CONTROLLER, 100K WORD SRAM |
| 1785-M100 |
PLC-5/80 EEPROM MEMORY CARTRIDGE, 100K |
| 1785-ME16 |
PLC-5/11, 5/20 EEPROM MEMORY CARTRIDGE |
PROCESSOR SERIES REV A/J, B/F, C/C OR LATER |
| 1785-ME32 |
PLC-5/30 EEPROM MEMORY CARTRIDGE |
PROCESSOR SERIES/REV A/J, B/F, C/C OR LATER |
| 1785-ME64 |
PLC-5/40, 5/60 EEPROM MEMORY CARTRIDGE |
| 1785-TAM |
THIN-WIRE TRANSCEIVER CABLE KIT, 49.2FT/15M, STD |
| 1785-TAS |
| 1785-TBM |
THICK-WIRE TRANSCEIVER CABLE KIT, 49.2FT/15M, STD |
| 1785-TBS |
THICK-WIRE TRANSCEIVER CABLE KIT, 6.56FT/2M, STD |
| 1785-TR10B2 |
AUI TO THIN WIRE ENET TRA |
| 1785-TR10B5 |
AUI TO THICK WIRE ENET TR |
| 1785-TR10BF |
AUI TO F.OPTIC ENET TRANS |
| 1785-TR10BT |
AUI TO TW PAIR ENET TRANS |
| 1786-BNC |
IMPROVED CONTROLNET RG6 COAXIAL CONNECTOR |
75 OHM CRIMP TYPE (PRICED PER PIECE, SOLD IN LOTS OF 50) |
| 1786-BNC2TNC |
CONTROLNET BNC-TNC COAXIAL CONN - ISOL BULKHEAD |
(PRICED PER PIECE, SOLD IN LOTS OF 2) |
| 1786-BNCJ |
CONTROLNET BNC COAXIAL CONNECTOR |
JACK TO JACK ADAPTER (PRICED PER PIECE, SOLD IN LOTS OF 50) |
| 1786-BNCJI |
ISOLATED BULKHEAD (PRICED PER PIECE; SOLD IN LOTS OF 5 PIECES) |
| 1786-BNCP |
MALE TO MALE PLUG CONNECTOR (PRICED PER PIECE, SOLD IN LOTS OF 50) |
| 1786-CP |
CONTROLNET PROGRAMMING CABLE |
10 FT, NETWORK ACCESS PORT |
| 1786-CTK |
CNET RG6 TOOLKIT |
| 1786-FS10 |
200 MICRON CABLE ASSEMBLY 10 METERS (32.8 FT) |
| 1786-FS100 |
200 MICRON CABLE ASSEMBLY 100 METERS (328 .1 FT) |
| 1786-FS20 |
200 MICRON CABLE ASSEMBLY 20 METERS (65.6 FT) |
| 1786-FS200 |
200 MICRON CABLE ASSEMBLY 200 METERS (656.2 FT) |
| 1786-FS300 |
200 MICRON CABLE ASSEMBLY 300 METERS (984.2 FT) |
| 1786-FS60 |
200 MICRON CABLE ASSEMBLY 60 METERS (196.8 FT) |
| 1786-FSB500 |
200 MICRON BULK CABLE 500 METERS (1640 FT) |
| 1786-FSKIT |
V-PIN CONNECTOR KIT |
| 1786-RG6 |
CONTROLNET RG6 QUAD SHIELD COAX CABLE |
1000 FT ROLL (304.8 METERS) |
| 1786-RG6F |
CONTROLNET RG6 QUAD SHIELD HIGH FLEX COAX CABLE |
| 1786-RPA |
CONTROLNET MODULAR REPEATER ADAPTER |
| 1786-RPCD |
CNET COAXIAL HUB REPEATER |
| 1786-RPFM |
CONTROLNET FIBER REPEATER - MEDIUM |
| 1786-RPFRL |
CONTROLNET FIBER RING REPEATER - LONG |
| 1786-RPFRXL |
CONTROLNET FIBER RING REPEATER - EXTRA LONG |
| 1786-RPFS |
CONTROLNET FIBER REPEATER - SHORT |
| 1786-TCAP |
CONTROLNET DUMMY LOAD FOR UNUSED COAX TAPS - BNC |
| 1786-TCT2BD1 |
CONTROLNET TNC IP67 T-TAP/BNC STRAIGHT |
| 1786-TJPR |
CONTROLNET 5" FLEXIBLE COAX JUMPER |
(PRICED PER PIECE, SOLD IN LOTS OF 4) |
| 1786-TNCJ4 |
CONTROLNET TNC COAXIAL CONN - JACK TO JACK |
| 1786-TNCJI4 |
CONTROLNET TNC COAXIAL CONN - ISOL JACK TO JACK |
| 1786-TNCL10 |
CONTROLNET TNC COAXIAL CONNECTOR - PLUG |
(PRICED PER PIECE; SOLD IN LOTS OF 10) |
| 1786-TNCLP4 |
CONTROLNET TNC COAXIAL CONN - PLUG TO PLUG |
| 1786-TNCLXT4 |
CONTROLNET TNC 75 OHM TERMINATOR PLUG |
| 1786-TPR |
CONTROLNET T-TAP/RIGHT ANGLE |
| 1786-TPRT2T |
CONTROLNET TNC IP67 T-TAP/TNC-TNC RIGHT THICK |
| 1786-TPS |
CONTROLNET T-TAP/STRAIGHT |
| 1786-TPST2T |
CONTROLNET TNC IP67 T-TAP/TNC-TNC STRAIGHT |
| 1786-TPYR |
CONTROLNET Y-TAP/RIGHT ANGLE |
| 1786-TPYS |
CONTROLNET Y-TAP/STRAIGHT |
| 1786-XT |
CONTROLNET 75 OHM TERMINATOR PLUG |
(PRICED PER PIECE; SOLD IN LOTS OF 50) |
| 1787-DNPS |
DEVICENET CLASS II 24VDC POWER SUPPLY |
| 1787-GEN2KIT1 |
DEVICENET STARTER KIT: 1747SDN SCANNER + 1770KFD |
PLUS OTHER DEVICENET COMPONENTS |
| 1787-GEN2KIT2 |
DEVICENET STARTER KIT: 1747SDN SCANNER + 1784PCD |
| 1787-GEN2KIT3 |
DEVICENET STARTER KIT: 1771SDN SCANNER+ 1770KFD |
| 1787-GEN2KIT4 |
DEVICENET STARTER KIT: 1771SDN SCANNER+ 1784PCD |
| 1787-GEN2KIT5 |
DEVICENET STARTER KIT: 1756DNB SCANNER+ 1770KFD |
| 1787-GEN2KIT6 |
DEVICENET STARTER KIT: 1756DNB + 1784PCD |
| 1787-GEN2KIT7 |
DEVICENET STARTER KIT: 1784PCIDS SCANNER + |
CONTROLPAK + OTHER DEVICENET COMPONENTS |
| 1787-MCABL |
MINI-CONNECTOR CABLE FOR 1770-KFD |
6 FT (1.82 METERS) |
| 1787-PCABL |
PROBE CABLE FOR 1770KFD |
| 1787-PLUG10R |
DEVICENET 10 POSITION CONNECTOR WITH JACK SCREWS |
(BAG OF 10) |
| 1787-RSCABL |
6FT (1.82 METERS) 9-9 PIN NULL MODEM RS-232 CABLE |
| 1787-TCABL |
T-STYLE CABLE FOR 1770-KFD 6 FT (1.82 METERS) |
| 1787-USADPTR |
U.S. P/S ADAPTER FOR 1770-KFD |
| 1788-CN2DN |
CONTROLNET TO DEVICENET LINKING DEVICE |
| 1788-CN2FF |
CONTROLNET TO FIELDBUS LINKING DEVICE |
| 1788-CNC |
CNET LOGIX DAUGHTERCARD - COAX MEDIA |
CONTROLNET COAX DAUGHTERCARD |
| 1788-CNCHKR |
CONTROLNET NETCHECKER DIAGNOSTIC TOOL |
| 1788-CNCR |
CNET LOGIX DAUGHTERCARD - REDUNDANT COAX MEDIA |
CONTROLNET REDUNDANT COAX DAUGHTERCARD |
| 1788-CNF |
CONTROLNET LOGIX DAUGHTER CARD |
SINGLE FIBER MEDIA |
| 1788-CNFR |
REDUNDANT FIBER MEDIA |
| 1788-DNBO |
DEVICENET LOGIX DAUGHTERCARD - OPEN CONNECTOR |
| 1788-EN2DN |
ETHERNET/IP TO DEVICENET LINKING DEVICE |
| 1788-ENBT |
ETHERNET/IP LOGIX DAUGHTERCARD |
UNSHIELDED TWISTED PAIR RJ45 |
| 1788-FFCT |
CONTROLNET-FIELDBUS CONFIGURATION TOOL |
| 1788-MCHKR |
NETWORK MEDIACHECKER (ENET, CNET, DNET, DH+/RIO) |
| 1789-L10 |
SOFTLOGIX5810 CONTROLLER W/2 USABLE CHASSIS SLOTS |
| 1789-L10UL30 |
SOFTLOGIX 5800 1789L10 TO 1789L30 UPGRADE |
| 1789-L30 |
SOFTLOGIX5830 CONTROLLER W/5 USABLE CHASSIS SLOTS |
| 1789-L60 |
SOFTLOGIX5860 CONTROLLER W/16 SLOT VIRTUAL CHASSIS |
| 1789-SLOTL |
SOFTLOGIX STARTER KIT DOCUMENTATION SET |
| 1789-SLX |
RSSIDEWINDERX |
| 1789-STRT1 |
SOFTLOGIX 5800 STARTER KIT ENGLISH |
| 1789-STRT1DE |
SOFTLOGIX 5800 STARTER KIT GERMAN |
| 1789-STRT1ES |
SOFTLOGIX 5800 STARTER KIT SPANISH |
| 1789-STRT1FR |
SOFTLOGIX 5800 STARTER KIT FRENCH |
| 1789-STRT1IT |
SOFTLOGIX 5800 STARTER KIT ITALIAN |
| 1789-STRT1PT |
SOFTLOGIX 5800 STARTER KIT PORTUGUESE |
| 1790-0B16X |
LDX I/O, 24VDC, 16 SOURCE OUT EXPANSION, D-SHELL |
| 1790-0V16X |
LDX I/O, 24 VDC, 16 SINK OUT EXPANSION, D-SHELL |
| 1790-0W8X |
LDX I/O, 24VDC, 8 RELAY OUT EXPANSION , D-SHELL |
| 1790-15CMCBL |
LDX I/O LONGER RIBBON CABLE, 15CM (LOTS OF 5) |
| 1790-16BV0X |
LDX I/O, 24VDC, 16 UNIVERSAL IN EXPANSION, D-SHELL |
| 1790-7CMCBL |
LDX I/O REPLACEMENT RIBBON CABLE, 7CM (LOTS OF 5) |
| 1790-8BV8BX |
LDX I/O, 24VDC, 8 UNIV IN/8 SRCE OUT EXPAN D-SHELL |
| 1790-8BV8VX |
LDX I/O,24VDC,8 UNIV IN/8 SINK OUT EXPN D-SHELL |
| 1790D-0B16 |
DNET LDX I/O, 24VDC, 16 SOURCE OUT BASE, D-SHELL |
| 1790D-0V16 |
DNET LDX I/O, 24VDC, 16 SINK OUT BASE, D-SHELL |
| 1790D-0W6 |
DNET LDX I/O. 6 RELAY OUT BASE, D-SHELL |
| 1790D-16BV0 |
DNET LDX I/O,24VDC,16 UNIVERSAL IN BASE, D-SHELL |
| 1790D-4R0 |
DNET LDX, 4 INPUT RTD BSE,D-SHELL CONN |
| 1790D-4T0 |
DNET LDX, 4 INPUT THERMOCOUPLE BSE,D-SHELL CONN |
| 1790D-8BV8B |
DNET LDX ,24VDC,8 UNIV IN/8 SRCE OUT BASE, D-SHELL |
| 1790D-8BV8V |
DNET LDX, 24VDC,8 UNIV IN/8 SINK OUT BASE, D-SHELL |
| 1790D-N0C2 |
DNET LDX, 2 OUTPUT ANALOG CURRENT BSE,D-SHELL CONN |
| 1790D-N0V2 |
DNET LDX, 2 OUTPUT VOLTAGE ANALOG BSE,D-SHELL CONN |
| 1790D-N4C0 |
DNET LDX, 4 INPUT ANALOG CURRENT BSE,D-SHELL CONN |
| 1790D-N4V0 |
DNET LDX, 4 INPUT VOLTAGE ANALOG BSE,D-SHELL CONN |
| 1790D-T0A6 |
DNET LDX , 120V AC, 6 OUTPUT BASE, TERMINAL BLOCK |
| 1790D-T0B16 |
DNET LDX, 24VDC, 16 SOURCE OUT BASE, TERMINAL BLK |
| 1790D-T0V16 |
DNET LDX I/O,24VDC,16 SINK OUT BASE, TERMINAL BLK |
| 1790D-T0W6 |
DNET LDX I/O, 6 RELAY OUT BASE, TERMINAL BLOCK |
| 1790D-T16BV0 |
DNET LDX, 24VDC, 16 UNIV. IN BASE, TERMINAL BLK |
| 1790D-T4R0 |
DNET LDX, 4 INPUT RTD BSE, TERM BLOCK |
| 1790D-T4T0 |
DNET LDX, 4 INPUT THERMOCOUPLE BSE, TERM BLOCK |
| 1790D-T8A0 |
DNET LDX , 120V AC, 8 INPUT BASE, TERMINAL BLOCK |
| 1790D-T8BV8B |
DNET LDX 24VDC, 8 UNIV IN/8 SRCE OUT BASE TERM BLK |
| 1790D-T8BV8V |
DNET LDX 24VDC,8 UNIV IN/8 SINK OUT BASE, TERM BLK |
| 1790D-TN0C2 |
DNET LDX, 2 OUTPUT ANALOG CURRENT BSE, TERM BLOCK |
| 1790D-TN0V2 |
DNET LDX, 2 OUTPUT VOLTAGE ANALOG BSE, TERM BLOCK |
| 1790D-TN4C0 |
DNET LDX, 4 INPUT ANALOG CURRENT BSE, TERM BLOCK |
| 1790D-TN4V0 |
DNET LDX, 4 INPUT VOLTAGE ANALOG BSE, TERM BLOCK |
| 1790P-T0W6 |
PROFIBUS, 6 RELAY OUT BASE, TERMINAL BLOCK |
| 1790P-T4R0 |
PROFIBUS, 4 INPUT RTD BASE, TERMINAL BLOCK |
| 1790P-T4T0 |
PROFIBUS,4 INPUT THERMOCOUPLE BASE, TERMINAL BLOCK |
| 1790P-T8BV8B |
PROFIBUS, 24VDC,8 UNIV IN/8 SRCEOUT BASE,TERM BLK |
| 1790P-T8BV8V |
PROFIBUS, 24VDC,8 IN/8 SINK OUT BASE,TERMINL BLOCK |
| 1790P-TN0C2 |
PROFIBUS,2 OUTPT ANALG CURRENT BASE,TERMINAL BLOCK |
| 1790P-TN4C0 |
PROFIBUS,4 INPUT ANALG CURRENT BASE,TERMINAL BLOCK |
| 1790-T0A8X |
LDX I/O, 120V AC, 8 OUTPUT EXPANSION, TERM BLK |
| 1790-T0B16X |
LDX I/O, 24VDC, 16 SOURCE OUT EXPANSION, TERM BLK |
| 1790-T0V16X |
LDX I/O, 24VDC, 16 SINK OUT EXPANSION, TERM BLK |
| 1790-T0W8X |
LDX I/O, 24VDC, 8 RELAY OUT EXPANSION, TERM BLK |
| 1790-T16BV0X |
LDX I/O, 24VDC,16 UNIVERSAL IN EXPANSION, TERM BLK |
| 1790-T8A0X |
LDX I/O, 110V AC, 8 INPUT EXPANSION, TERMINAL BLK |
| 1790-T8BV8BX |
LDX I/O,24VDC, 8 UNIV IN/8 SRCE OUT EXPN, TERM BLK |
| 1790-T8BV8VX |
LDX I/O, 24VDC, 8 UNIV IN/8 SINK OUT EXPN TERM BLK |
| 1791D-0B16P |
DNET 24 VDC COMPACTBLACK I/O, 16 OUT SOURCE, BASE |
| 1791D-0B16PX |
24 VDC BLOCK I/O EXPANSION, 16 OUT SOURCE, RTB |
| 1791D-0B8P |
DNET 24 VDC COMPACTBLOCK I/O, 8 OUT SOURCE, BASE |
| 1791D-0V16P |
DNET 24 VDC COMPACTBLOCK I/O, 16 OUT SINK, BASE |
| 1791D-0V16PX |
24 VDC COMPACTBLOCK I/O EXPANSION, 16 OUT SINK |
| 1791D-15CMCBL |
24 VDC BLOCK I/O RIBBON CABLE, 15 CM |
PRICED PER EACH, ORDER IN LOTS OF 5 |
| 1791D-16B0 |
DNET 24 VDC COMPACTBLOCK I/O, 16 IN SINK, BASE |
| 1791D-16B0X |
24VDC COMPACTBLOCK I/O EXPANSION, 16 IN SINK |
| 1791D-16V0 |
DNET 24 VDC COMPACTBLOCK I/O, 16 IN SOURCE, BASE |
| 1791D-16V0X |
24VDC COMPACTBLOCK I/O EXPANSION, 16 IN SOURCE |
| 1791D-4B0 |
DNET 24VDC CBLOCK I/O, 4 IN SINK (NOT EXPANDABLE) |
| 1791D-4B4P |
DNET 24VDC CBLOCK I/O, 4 IN SINK 4 OUT SOURCE,BASE |
| 1791D-4CMCBL |
24 VDC BLOCK I/O RIBBON CABLE, 4CM |
| 1791D-8B8P |
DNET 24VDC CBLOCK I/O,8 IN SINK 8 OUT SOURCE, BASE |
| 1791D-8V8P |
DNET 24VDC CBLOCK I/O, 8 IN SOURCE 8 OUT SINK,BASE |
| 1791D-N4CV2X |
24 VDC CB I/O EXPANSION, ANALOG COMBO, 4 IN/2 OUT |
| 1791D-RTBN21 |
BLOCK I/O REPLACEMENT TERMINAL BLOCK, 21 PIN NEMA |
| 1791DS-IB12 |
DEVICENET SAFETY 24VDC 12 INPUT MODULE |
| 1791DS-IB4XOW4 |
DEVICENET SAFETY 24VDC 4 INPUT/4 RELAY OUTPUT |
| 1791DS-IB8XOB8 |
DEVICENET SAFETY 24VDC 8 INPUT/8 SEMICON OUTPUT |
| 1791-IOBW |
BLOCK I/O, 24V DC, 64 PT MODULE |
| 1791-IOBX |
BLOCK I/O, 24V DC, 128 PT MODULE |
| 1791-IOVW |
(32 SOURCE IN, 32 SOURCE OUT) |
| 1791-IOVX |
(64 SOURCE IN, 64 SOURCE OUT) |
| 1791P-0B16P |
PROFIBUS 24VDC BLOCK I/O, 16 OUT, SOURCING |
| 1791P-16B0 |
PROFIBUS 24VDC CBLOCK I/O, 16 IN SINKING, BASE |
| 1791P-4B4P |
PROFIBUS 24 VDC CBLOCK I/O, 4 IN SINK 4 OUT SOURCE |
| 1791P-8B8P |
PROFIBUS 24VDC CBLK I/O,8 IN SINK 8 SRCE OUT,BASE |
| 1791P-8V8P |
PROFIBUS 24VDC CBLK I/O,8 IN SRCE 8 OUT SINK,BASE |
| 1791R-0B16P |
RIO 24VDC COMPACTBLOCK, 16 OUT SOURCE, BASE |
| 1791R-16B0 |
RIO 24VDC COMPACTBLOCK, 16 IN SINKING, BASE |
| 1791R-4B4P |
RIO 24VDC COMPACTBLK, 4 IN SINK 4 OUT SOURCE, BASE |
| 1791R-8B8P |
RIO 24VDC COMPACTBLK, 8 IN SINK 8 OUT SOURCE, BASE |
| 1791R-8V8P |
RIO 24VDC COMPACTBLK, 8 IN SOURCE 8 OUT SINK, BASE |
| 1791R-RIOSCON |
RIO 6 PSITION CONNECTOR, LOCK SCREWS (LOT OF 5) |
| 1792D-0B4D |
4 SOURCING OUTPUTS UP TO 2 AMPS, 4 CONNECTORS |
| 1792D-0B8D |
8 SOURCING 0.5 AMP OUTPUTS, 8 CONNECTORS |
| 1792D-0VT16E |
16 SINKING 0.5 AMP OUTPUTS, 8 CONNECTORS |
| 1792D-12BT4PE |
12 IN/4 OUT MAXUM WITH PIN 5 GROUND |
| 1792D-12BVT4D |
12 SINK/SOURCE INPUTS, 4 SOURCING 0.5 AMP OUTPUTS |
8 CONNECTORS |
| 1792D-16BVT0CD |
MAXUM 16 IN WITH POINT LEVEL DIAGNOSTICS |
| 1792D-16BVT0D |
16 SINK/SOURCE INPUTS, 8 CONNECTORS |
| 1792D-2BV0D |
2 SINK/SOURCE INPUTS, 2 CONNECTORS |
| 1792D-2BVA2D |
2 SINK/SOURCE INPUTS W/ALARM, 2 SOURCING 1AMP OUT |
4 CONNECTORS |
| 1792D-4BV0D |
4 SINK/SOURCE INPUTS, 4 CONNECTORS |
| 1792D-4BV4D |
4 SINK/SOURCE INPUTS, 4 SOURCING 0.5 AMP OUTPUTS |
8 CONNECTORS, POINT LEVEL DIAGNOSTICS |
| 1792D-4BVT4D |
4 CONNECTORS, CONNECTOR LEVEL DIAGNOSTICS |
| 1792D-88HC |
8 SINK/SOURCE INPUTS, 8 SOURCING 5-10 AMP OUTPUTS |
HIGH CURRENT BLOCK |
| 1792D-88HCCBL |
HIGH CURRENT BLOCK CABLE |
| 1792D-88HCCON |
HIGH CURRENT BLOCK CONNECTOR AND PINS |
| 1792D-8BIO8E |
8 SINKING INPUTS, 8 SOURCING 0.5 AMP OUTPUTS |
W/ 1 INPUT AND 1 OUTPUT ON EACH CONNECTOR |
| 1792D-8BT8PE |
8 IN/8 OUT MAXUM WITH PIN 5 GROUND |
| 1792D-8BV0D |
8 SINK/SOURCE INPUTS, 8 CONNECTORS |
COMPLETE POINT DIAGNOSTICS |
| 1792D-8BVT0D |
8 SINK/SOURCE INPUTS, 4 CONNECTORS |
| 1792D-8BVT8CD |
MAXUM 8IN/8OUT WITH POINT LEVEL DIAGNOSTICS |
| 1792D-8BVT8D |
8 SINK/SOURCE INPUTS, 8 SOURCING 0.5AMP OUTS |
8 CONNECTORS |
| 1792D-CB12 |
MAXUM MEDIA BASE W/12MM CONNECTORS |
| 1792D-CB12JP |
MAXUM MEIDA BASE W/12MM CONNECTORS |
JUMPERED DEVICENET POWER |
| 1792D-CB18 |
MAXUM ROUND MEDIA 18MM BASE, PASSTHRU FOR DNET |
| 1792D-CB18JP |
| 1792D-CB18P |
SINGLE 18MM AUX POWER CONNECTOR |
| 1792D-CB18PT |
MAXUM ROUND MEDIA 18MM BASE, |
PASSTHRU FOR DNET AND AUX POWER |
| 1792D-CB23 |
MAXUM CABLE BASE WITH 17 PIN M23 CONNECTORS |
| 1792D-CBFM |
MAXUM MEDIA BASE FOR KWIKLINK FLAT MEDIA |
| 1792D-KPLT |
KEMPF INTERFACE PLATE |
| 1794-ACN15 |
SINGLE MEDIA ADAPTER FOR CONTROLNET |
PHASE 1.5 AND BEYOND |
| 1794-ACN15K |
CONFORMAL COATED, SINGLE MEDIA ADAPTER, CONTROLNET |
| 1794-ACNR15 |
REDUNDANT MEDIA ADAPTER FOR CONTROLNET |
| 1794-ACNR15K |
CONFORMAL COATED, REDUNDANT MEDIA ADAPTER, CNET |
| 1794-ADN |
DEVICENET ADAPTER WITH 24V DC POWER SUPPLY |
| 1794-ADNK |
CONFORMALLY COATED, DEVICENET ADAPTER |
| 1794-AENT |
ETHERNET ADAPTER W/24V DC POWEL SUPPLY, TWIST PR |
| 1794-APB |
1794-APB 12 MBPS PROFIBUS DP ADAPTER FOR FLEX I/O |
| 1794-ASB |
REMOTE I/O ADAPTER W/24V DC POWER SUPPLY |
| 1794-ASB2 |
FLEX I/O 2 MODULE 24V DC RIO ADAPTER |
| 1794-ASBK |
CONFORMALLY COATED, REMOTE I/O ADAPTER |
| 1794-CE1 |
EXTENDER CABLE FOR TERMINAL BASES, 1FT/.3M |
| 1794-CE3 |
EXTENDER CABLE FOR TERMINAL BASES, 3 FT/.9M |
| 1794-CJC2 |
COLD JUNCTION COMPENSATION KIT (2 PIECES) |
| 1794D-PALEN |
FLEXLOGIX DOCUMENTATION SET |
| 1794-FLA |
FLEX LOGIX FLEXBUS2 LOCAL I/0 ADAPTER |
| 1794-IA16 |
85-132V AC INPUT MODULE, 16 POINT |
| 1794-IA8 |
85-132 VAC INPUT MODULE, 8 POINT |
| 1794-IA8K |
CONFORMAL COATED, 85-125V AC INPUT MODULE, 16 PT |
| 1794-IB10XOB6 |
10 INPUT/6 OUTPUT 24VDC COMBO |
| 1794-IB16 |
24V DC SINK INPUT MODULE, 16 POINT |
| 1794-IB16D |
24V DC SINK DIAGNOSTIC INPUT MODULE, 16PT |
| 1794-IB16K |
CONFORMAL COATED, 24V DC SINK INPUT MODULE, 16 PT |
| 1794-IB16XOB16P |
24 VDC COMBO MODULE, 32 POINTS |
16 SINK INPUTS, 16 SOURCE OUTPUTS, PROTECTED |
| 1794-IB32 |
24 VDC INPUT MODULE, 32 POINTS |
| 1794-IB8 |
24 VDC INPUT 8 POINTS |
| 1794-IC16 |
FLEX 48 VDC INPUT MDL |
| 1794-ID2 |
2-CHANNEL INCREMENTAL ENCODER INPUT MODULE |
| 1794-IE12 |
ANALOG INPUT MODULE, 16 BIT, 12 POINT, S.E. |
| 1794-IE4XOE2 |
ANALOG COMBO MODULE, 12 BIT, 4 INPUT/2 OUTPUT |
| 1794-IE8 |
ANALOG INPUT MODULE, 12 BIT, 8 POINT |
| 1794-IE8H |
ANALOG INPUT MODULE, HART, 8 POINT, 16 BIT, S.E. |
| 1794-IE8K |
CONFORMAL COATED, ANALOG INPUT MODULE, 8 POINT |
| 1794-IE8XOE4 |
ANALOG COMBO MODULE, 16 BIT, 8 INPUT/4 OUTPUT,S.E. |
| 1794-IF2XOF2I |
ISOLATED ANALOG COMBO MODULE |
16 BIT, 2 INPUT, 2 OUTPUT |
| 1794-IF4I |
ISOLATED ANALOG INPUT MODULE, 16 BIT, 4 POINT |
| 1794-IJ2 |
2-CHANNEL HIGH RESOLUTION FREQUENCY MODULE |
| 1794-IJ2K |
CONFORMAL COAT, 2-CHANNEL HI RES FREQUENCY MODULE |
| 1794-IM8 |
220V AC INPUT MOD, 8 PT. |
| 1794-IP4 |
4-CHANNEL 12/24V PULSE COUNTER INPUT MODULE |
| 1794-IR8 |
RTD INPUT MODULE, 8 POINT |
| 1794-IRT8 |
NON-ISOLATED, THERMOCOUPLE/RTD/MV INPUT MODULE |
8 POINT, 14 BIT |
| 1794-IRT8K |
CONFORMAL COAT, NON-ISOLATED TC/RTD/MV INPUT, 8PT |
| 1794-IT8 |
THERMOCOUPLE INPUT MODULE, 8 POINT |
| 1794-IV16 |
FLEX I/O 24V DC 16 CHANNEL SOURCING INPUT MODULE |
| 1794-L34 |
FLEX LOGIX PROCESSOR, 512KBYTES USER MEMORY |
| 1794-N2 |
FLEX DUMMY FILLER MODULE |
| 1794-NM1 |
PANEL MOUNTING KIT FOR FLEX I/O |
| 1794-OA16 |
85-132V AC OUTPUT MODULE, 16 POINT |
| 1794-OA8 |
85-132 VAC OUTPUT MODULE, 8 POINT |
| 1794-OA8I |
85-132V AC OUTPUT MODULE (ISOLATED), 8 POINT |
| 1794-OA8K |
CONFORMAL COATED, 85-132V AC OUTPUT MODULE, 16 PT |
| 1794-OB16 |
24V DC SOURCE OUTPUT MODULE, 16 POINT |
| 1794-OB16D |
24V DC SOURCE DIAGNOSTIC OUTPUT MODULE, 16PT |
| 1794-OB16P |
24V DC SOURCE OUTPUT MODULE (PROTECTED), 16 POINT |
| 1794-OB16PK |
CONFORMAL COAT, 24VDC SOURCE OUT PROTECTED,16 PT |
| 1794-OB32P |
24 VDC OUTPUT MODULE, 32 POINTS |
| 1794-OB8 |
24 VDC OUTPUT 8 POINTS |
| 1794-OB8EP |
FLEX I/O 24VDC 8 CHANNEL ELECT. FUSED 2AMP OUT MOD |
MP OUTPUT MODULE |
| 1794-OB8EPK |
CONFORMAL COAT, 24VDC SOURCE OUT ELECT FUSED, 8 PT |
| 1794-OC16 |
FLEX 48 VDC OUTPUT MDL |
| 1794-OE12 |
ANALOG OUTPUT MODULE, 16 BIT, 12 POINT, S.E. |
| 1794-OE4 |
ANALOG OUTPUT MODULE, 12 BIT, 4 POINT |
| 1794-OE4K |
CONFORMAL COATED, ANALOG OUPUT MODULE, 4 POINT |
| 1794-OE8H |
ANALOG OUTPUT MODULE, HART, 8 POINT, 13 BIT, S.E. |
| 1794-OF4I |
ISOLATED ANALOG OUTPUT MODULE, 16 BIT, 4 POINT |
| 1794-OM8 |
220V AC OUTPUT MOD, 8 PT. |
| 1794-OV16 |
FLEX I/O 24V DC 16 POINT SINK OUTPUT MODULE |
| 1794-OV16P |
FLEX I/O 24VDC SINK OUTPUT MODULE, PROTECTED, 16PT |
| 1794-OW8 |
RELAY CONTACT OUTPUT, 8 PT, ISOLATED |
| 1794-OW8K |
CONFORMAL COATED, RELAY CONTACT OUT, 8 PT ISOLATED |
| 1794-PS13 |
85-264 VAC TO 24 VDC 1.3A POWER SUPPLY |
| 1794-PS3 |
120/230VAC TO 24VDC @3A |
FLEX I/O POWER SUPPLY |
| 1794-TB2 |
TERMINAL BASE, 2-WIRE |
| 1794-TB3 |
TERMINAL BASE, 3-WIRE |
| 1794-TB32 |
TERMINAL BASE FOR 32 POINT MODULES - SCREW |
| 1794-TB32S |
TERMINAL BASE FOR 32 POINT MODULES - SPRING CLAMP |
| 1794-TB37DS |
TERMINAL BASE WITH 37-PIN D-SHELL |
| 1794-TB37EXD4CM8 |
37PIN DSHELL EXPANSION MOD W/4CM8 |
| 1794-TB37EXD4VM8 |
37PIN DSHELL EXPANSION MOD W/4VM8 |
| 1794-TB3G |
3-WIRE GROUNDED TERMINAL BASE - SCREW CLAMP |
| 1794-TB3GK |
CONFORMALLY COATED, GROUNDED TERMINAL BASE 3-WIRE |
| 1794-TB3GS |
3-WIRE GROUNDED TERMINAL BASE - SPRING CLAMP |
| 1794-TB3K |
CONFORMALLY COATED, TERMINAL BASE 3-WIRE |
| 1794-TB3S |
FLEX I/O TERMINAL BASE WITH SPRING CLAMPS |
| 1794-TB3T |
3-WIRE TEMPERATURE TERMINAL BASE |
| 1794-TB3TS |
3-WIRE TEMPERATURE TERMINAL BASE - SPRING CLAMP |
| 1794-TB62DS |
TERMINAL BASE WITH 62-PIN D-SHELL |
| 1794-TB62EXD4X15 |
62PIN DSHELL EXPANSION MOD W/4X15 PIN DSHELL |
| 1794-TBKD |
KNIFE DISCONNECT TERMINAL BASE, 16 SPST SWITCHES |
| 1794-TBN |
NEMA TERMINAL BASE |
| 1794-TBNF |
FUSED NEMA TERMINAL BASE |
| 1794-TBNK |
CONFORMALLY COATED, NEMA TERMINAL BASE |
| 1794-VHSC |
2-CHANNEL 1 MHZ VERY HIGH SPEED COUNTER |
CONTROLNET SERIES B OR LATER ONLY |
| 1797-ACNR15 |
REDUNDANT MEDIA CONTROLNET EX ADAPTER |
| 1797-BCNR |
CONTROLNET COAX BARRIER, REDUNDANT |
| 1797-BIC |
IS BUS ISOLATOR - CABLE |
| 1797-BOOT |
CONTROLNET EX BOOT INSULATOR KIT (50 PIECES) |
| 1797-CE1S |
BUS EXTENDER CABLE FOR BUS ISOLATOR - 1 FOOT |
| 1797-CE3S |
BUS EXTENDER CABLE FOR BUS ISOLATOR - 3 FOOT |
| 1797-CEC |
FLEX BUS CONNECTOR |
| 1797-EXMK |
CONTROLNET EX CABLE MARKING KIT (100 PIECES) |
| 1797-IBN16 |
EX NAMUR DIGITAL INPUT MODULE, 16 PT. |
| 1797-IE8 |
EX ANALOG INPUT MODULE, 16 BIT, 8 PT., S.E. |
| 1797-IE8H |
EX HART ANALOG INPUT MODULE, 16 BIT, 8PT., S.E. |
| 1797-IE8NF |
EX ANALOG INPUT MODULE, 16 BIT, 8 PT. NOISE FILTER |
| 1797-IJ2 |
2-CHANNEL EX HIGH RESOLUTION FREQUENCY MODULE |
| 1797-INS |
CONTROLNET EX INSULATOR KIT (50 MIXED PIECES) |
| 1797-IRT8 |
EX RTD/THERMOCOUPLE/MV INPUT MODULE, 16 BIT, 8 PT. |
| 1797-OB4D |
EX SOURCE DIGITAL OUTPUT MODULE, 4 PT. |
| 1797-OE8 |
EX ANALOG/UNIVERSAL OUT MODULE, 13 BIT, 8 PT, S.E. |
| 1797-OE8H |
EX HART ANALOG OUTPUT MODULE, 13 BIT, 8PT., S.E. |
| 1797-PS1E |
85-250 VAC IN QUAD-EX IS OUT POWER SUPPLY-IS TERM. |
| 1797-PS1N |
AC IN QUAD-EX DC OUT POWER SUPPLY- NPT CONDUIT |
| 1797-PS2E2 |
24 VDC IN QUAD-EX OUT POWER SUPPLY, IS CONN, ATEX |
| 1797-PS2N2 |
24 VDC IN QUAD-EX OUT POWER SUPPLY, NPT CONDUIT |
| 1797-RPA |
CONTROLNET EX MODULAR REPEATER ADAPTER |
| 1797-RPFM |
CONTROLNET EX FIBER REPEATER - MEDIUM |
| 1797-TB3 |
3-WIRE EX TERMINAL BASE - SCREW CLAMP |
| 1797-TB3S |
3-WIRE EX TERMINAL BASE - SPRING CLAMP |
| 1797-TCAP |
CONTROLNET EX TAP (DUMMY) TERMINATOR (5 PIECES) |
| 1797-TPR |
CONTROLNET EX T-TAP RIGHT ANGLE |
| 1797-TPS |
CONTROLNET EX T-TAP STRAIGHT |
| 1797-TPYR |
CONTROLNET EX Y-TAP RIGHT ANGLE |
| 1797-TPYS |
CONTROLNET EX Y-TAP STRAIGHT |
| 1797-XT |
CONTROLNET EX TRUNK TERMINATOR (LOT 50, PER EACH) |
| 1799-12SPCON |
12-POSITION GOLD-PLATED I/O MATING CONNECTOR (2) |
| 1799-AUXCON |
2-POSITION PLUG FOR AUXILIARY POWER |
| 1799-BRKD |
DIN RAIL BRACKETS WITH SCREWS(2 BRKTS/ 4 SCREWS) |
| 1799-COV20 |
CLEAR PLASTIC COVER, 4 STAND-OFFS/SCREWS (20 PT) |
| 1799-COV32 |
CLEAR PLASTIC COVER; 4 STAND-OFFS/SCREWS (32PT) |
| 1799-D10U10B |
24 VDC 20 POINT SRC OUT I/O BOARD |
| 1799-D10U10BL |
24 VDC 20 POINT SRC OUT I/O BOARD WITH LOGIC |
| 1799-D10U10V |
24 VDC 20 POINT SINK OUT I/O BOARD |
| 1799-D10U10VL |
24 VDC 20 POINT SINK OUT I/O BOARD WITH LOGIC |
| 1799-D16U16B |
24VDC 32 POINT SOURCE OUT I/O BOARD |
| 1799-D16U16BL |
24VDC 32 POINT SRC OUT I/O BOARD WITH LOGIC |
| 1799-D16U16V |
24VDC 32 POINT SINKING OUT I/O BOARD |
| 1799-D16U16VL |
24VDC 32 POINT SINKING OUT I/O BOARD WITH LOGIC |
| 1799-DNC5MMS |
DNET 5-POS. TO MICRO MALE CONNECTOR (LOTS OF 5) |
| 1799-DNETCON |
5-POSITION OPEN STYLE PLUG FOR DN |
| 1799-DNETSCON |
5-POSITION OPEN STYLE PLUG/LOCKING SCREWS FOR DN |
| 1799-DSCCON |
D-SUB(50) I/O MATING CONNECTOR (CRIMP) |
| 1799-DSSCON |
D-SUB(50) I/O MATING CONNECTOR (SOLDER) |
| 1799-MP20 |
PLASTIC MOUNTING PLATE/4 SCREWS-20 PT BOARD |
| 1799-MP32 |
PLASTIC MOUNTING PLATE/4 SCREWS-32 PT BOARD |
| 1799-ZCIOB |
ZONE CONTROL I/O CARD W/SOURCING OUTPUTS AND ZIP |
| 1799-ZCIOV |
ZONE CONTROL I/O CARD W/SINKING OUTPUTS AND ZIP |
| 193B-PM4 |
ADAPTER,DIN RAIL PANEL FOR CONTACTOR OR STARTER |
| 193B-PM5 |
ADAPTER,DIN RAIL PANEL FOR OVERLOAD RELAY |
| 193C-1D1 |
SOLID STATE OVERLOAD RELAY |
| 193C-1F1 |
| 193C-1H1 |
| 193C-1H2 |
| 193C-1K2 |
| 193C-1K3 |
| 193C-1L4 |
| 193C-1L7 |
| 193C-1M4 |
| 193C-1M5 |
| 193C-1M7 |
| 193C-1N6A |
| 193C-1N6D |
| 193C-1N6L |
RELAY,OVERLOAD 600V AC MAX |
| 193C-1N6T |
| 193C-1P6D |
| 193C-1P6L |
| 193C-1P6T |
| 193C-1R6A |
| 193C-1R6L |
| 193C-1R6T |
| 193N-X15 |
BUL 193 F/CT MOUNT |
| 193N-X16 |
B193 F/CT MOUNT |
| 193N-X17 |
B193 F/CT MOUNT |
| 193N-X18 |
SMP3FF5 CT |
| 2030-EUCF |
ELECTROGUARD ACCESSORY, EXPANSION MODULE |
| 2030-EUNF |
| 2030-PA1201 |
2030 ELECTROGUARD ACCESSO |
| 2030-PC1203 |
ELECTROGUARD ACCESSORY, PNEUMATIC ISOLATION MODULE |
| 2030-PF1201 |
| 2030-PJ1201 |
| 2030-PJ1203 |
| 2030-RLSAW |
ELECTROGUARD ACCESSORY, REMOTE LOCKOUT STATION |
| 2030-RLSCW |
| 2030-RLSFW |
| 2030-RLSJW |
| 2031B-A0630AA |
2031 ELECTROGUARD, NON-COMBINATION |
| 2031B-A0860AB |
| 2031T-A0630AA |
| 2032-A0300JB-28J |
2032 ELECTROGUARD, FUSIBLE DISCONNECT |
| 2090-CDNFDMP-S05 |
CABLE, FEEDBACK, MP STYLE, TO 1394, 05 METER |
| 2090-CDNFDMP-S15 |
CABLE, FEEDBACK, MP STYLE, TO 1394, 15 METER |
| 2090-CDNFDMP-S30 |
CABLE, FEEDBACK, MP STYLE, TO 1394, 30 METER |
| 2090-CDNFDMP-S60 |
CABLE, FEEDBACK, MP STYLE, TO 1394, 60 METER |
| 2090-CDNFDMP-S90 |
CABLE, FEEDBACK, MP STYLE, TO 1394, 90 METER METER |
| 2090-CDNPBMP-10S05 |
CABLE, POWER, MP STYLE - TO 1394, 10 AWG, 05 METER |
| 2090-CDNPBMP-10S15 |
CABLE, POWER, MP STYLE - TO 1394, 10 AWG, 15 METER |
| 2090-CDNPBMP-10S30 |
CABLE, POWER, MP STYLE - TO 1394, 10 AWG, 30 METER |
| 2090-CDNPBMP-10S60 |
CABLE, POWER, MP STYLE - TO 1394, 10 AWG, 60 METER |
| 2090-CDNPBMP-10S90 |
CABLE, POWER, MP STYLE - TO 1394, 10 AWG, 90 METER |
| 2090-CDNPBMP-8S05 |
CABLE,460V,NON-FLEX,MOTOR POWER,MP,8 GAUGE,5M |
| 2090-CDNPBMP-8S15 |
CABLE,460V,NON-FLEX,MOTOR POWER,MP,8 GAUGE,15M |
| 2090-CDNPBMP-8S30 |
CABLE, 460V,NON-FLEX,MOTOR POWER,MP,8 GAUGE,30M |
| 2090-CDNPBMP-8S60 |
CABLE,460V,NON-FLEX,MOTOR POWER,MP,8 GAUGE,60M |
| 2090-CDNPBMP-8S90 |
CABLE,460V,NON-FLEX,MOTOR POWER,MP,8 GAUGE,90M |
| 2090-DA-BAT |
BATTERY, 3.6V, DRIVE TO TL MOTOR |
| 2090-DAIO-D5001 |
CABLE, NON-FLEX, CN1 CONTROL, 01M |
| 2090-DAIO-D5003 |
CABLE, NON-FLEX, CN1 CONTROL, 03M |
| 2090-DANBT-18S01 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 01M |
| 2090-DANBT-18S02 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 02M |
| 2090-DANBT-18S03 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 03M |
| 2090-DANBT-18S04 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 04M |
| 2090-DANBT-18S05 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 05M |
| 2090-DANBT-18S07 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 07M |
| 2090-DANBT-18S09 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 09M |
| 2090-DANBT-18S12 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 12M |
| 2090-DANBT-18S15 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 15M |
| 2090-DANBT-18S20 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 20M |
| 2090-DANBT-18S25 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 25M |
| 2090-DANBT-18S30 |
CABLE, NON-FLEX, MTR BRK FOR CABLE-MTD CONNS, 30M |
| 2090-DANFCT-S01 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 01M |
| 2090-DANFCT-S02 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 02M |
| 2090-DANFCT-S03 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 03M |
| 2090-DANFCT-S04 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 04M |
| 2090-DANFCT-S05 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 05M |
| 2090-DANFCT-S07 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 07M |
| 2090-DANFCT-S09 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 09M |
| 2090-DANFCT-S12 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 12M |
| 2090-DANFCT-S15 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 15M |
| 2090-DANFCT-S20 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 20M |
| 2090-DANFCT-S25 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 25M |
| 2090-DANFCT-S30 |
CABLE, NF, MTR FBACK FOR CABLE-MTD CONN, T, 30M |
| 2090-DANPT-16S01 |
CABLE, NON-FLEX, MTR PWR, CABLE-MTD CONN, 16AWG, 0 |
| 2090-DANPT-16S02 |
| 2090-DANPT-16S03 |
| 2090-DANPT-16S04 |
| 2090-DANPT-16S05 |
| 2090-DANPT-16S07 |
| 2090-DANPT-16S09 |
| 2090-DANPT-16S12 |
CABLE, NON-FLEX, MTR PWR, CABLE-MTD CONN, 16AWG, 1 |
| 2090-DANPT-16S15 |
| 2090-DANPT-16S25 |
CABLE, NON-FLEX, MTR PWR, CABLE-MTD CONN, 16AWG, 2 |
| 2090-DANPT-16S30 |
CABLE, NON-FLEX, MTR PWR, CABLE-MTD CONN, 16AWG, 3 |
| 2090-DAPC-D0901 |
CABLE, NON-FLEX, CN3 SERIAL COMMUNICATIONS, 01M |
| 2090-DAPC-D0903 |
CABLE, NON-FLEX, CN3 SERIAL COMMUNICATIONS, 03M |
| 2090-DAPC-D0909 |
CABLE, NON-FLEX, CN3 SERIAL COMMUNICATIONS, 09M |
| 2090-K6CK-D15F |
CONNECTOR, AUX FDBK, D-SHELL/TERM BLOCK, 15 PIN F |
| 2090-K6CK-D15M |
CONNECTOR, MOTOR FDBK, D-SHELL/TERM BLOCK, 15 PIN |
| 2090-K6CK-D15MF |
CONNECTOR, MOTOR FDBK DSHELL/TERMBLOCK, 15M FILTER |
| 2090-K6CK-D26M |
CONNECTOR, I/O, D-SHELL/TERM BLOCK, 26 PIN |
| 2090-MCNPMP-6S01 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,1METER |
| 2090-MCNPMP-6S02 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,2METER |
| 2090-MCNPMP-6S03 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,3METER |
| 2090-MCNPMP-6S04 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,4METER |
| 2090-MCNPMP-6S05 |
CABLE,NON-FLEX,MOTOR POWER,MP,5 GAUGE,4METER |
| 2090-MCNPMP-6S07 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,7METER |
| 2090-MCNPMP-6S09 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,9METER |
| 2090-MCNPMP-6S12 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,12 METER |
| 2090-MCNPMP-6S15 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,15 METER |
| 2090-MCNPMP-6S20 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,20 METER |
| 2090-MCNPMP-6S25 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,25 METER |
| 2090-MCNPMP-6S30 |
CABLE,NON-FLEX,MOTOR POWER,MP,6 GAUGE,30 METER |
| 2090-MPBC-S |
KIT,CONNECTOR,BRAKE,STRAIGHT,MF |
| 2090-MPFC-S |
KIT,CONNECTOR,FEEDBACK,STRAIGHT,MF |
| 2090-MPPC-08S |
KIT,CONNECTOR,POWER,STRAIGHT,8AWG,FOR MPL-A6,B6 |
| 2090-MPPC-S |
KIT CONNECTOR,POWER STRAIGHT MF |
| 2090-S-BLHD |
SERCOS FIBER CABLE BULKHEAD ADAPTOR 2 PER |
| 2090-SCEP0-1 |
SERCOS FBR CABL,CONN,ENCLOSUR ONLY,PLASTIC,0.1M |
| 2090-SCEP0-2 |
SERCOS CABLE,PLASTIC,POLYETHYL JACKET,0.18 METER |
| 2090-SCEP0-3 |
SERCOS FBR CABL,CONN,ENCLOSUR ONLY,PLASTIC,0.3M |
| 2090-SCEP1-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,1.0M |
| 2090-SCEP10-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,10.0M |
| 2090-SCEP15-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,15.0M |
| 2090-SCEP20-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,20.0M |
| 2090-SCEP25-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,25.0M |
| 2090-SCEP3-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,3.0M |
| 2090-SCEP32-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,32.0M |
| 2090-SCEP5-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,5.0M |
| 2090-SCEP8-0 |
SERCOS FBR CABL,CONN,ENCLOSURE ONLY PLASTIC,8.0M |
| 2090-SCNP1-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,1.0M |
| 2090-SCNP10-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,10.0M |
| 2090-SCNP15-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,15.0M |
| 2090-SCNP20-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,20.0M |
| 2090-SCNP25-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,25.0M |
| 2090-SCNP3-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,3.0M |
| 2090-SCNP32-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,32.0M |
| 2090-SCNP5-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,5.0M |
| 2090-SCNP8-0 |
SERCOS FBR CABL,CONN,HARSH DUTY,JKT,PLASTIC,8.0M |
| 2090-SCVG100-0 |
SERCOS FBR CABL,CONN,STNDRD PVC JKT,GLASS,100.0M |
| 2090-SCVG150-0 |
SERCOS FBR CABL,CONN,STNDRD PVC JKT,GLASS,150.0M |
| 2090-SCVG200-0 |
SERCOS FBR CABL,CONN,STNDRD PVC JKT,GLASS,200.0M |
| 2090-SCVG50-0 |
SERCOS FBR CABL,CONN,STNDRD PVC JKT,GLASS,50.0M |
| 2090-SCVP0-3 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 0.3M |
| 2090-SCVP1-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 1.0M |
| 2090-SCVP10-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 10.0 |
| 2090-SCVP15-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 15.0 |
| 2090-SCVP20-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 20.0 |
| 2090-SCVP25-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 25.0 |
| 2090-SCVP3-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 3.0M |
| 2090-SCVP32-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 32.0 |
| 2090-SCVP5-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 5.0M |
| 2090-SCVP8-0 |
SERCOS FBR CABL,CONN,STANDARD PVC JKT,PLASTIC 8.0M |
| 2090-SR040-09 |
40 OHM, 900W |
| 2090-SR040-18 |
40 OHM, 1800W |
| 2090-SR120-09 |
120 OHM, 900W |
| 2090-U3AE-D4401 |
CABLE,TWO AXISTO LOGIX 1756MOAE2 CARD,1M |
| 2090-U3AE-D4403 |
CABLE,TWO AXISTO LOGIX 1756MOAE2 CARD,3M |
| 2090-U3AE-D4409 |
CABLE,TWO AXISTO LOGIX 1756MOAE2 CARD,9M |
| 2090-U3AE-D4415 |
CABLE,TWO AXISTO LOGIX 1756MOAE2 CARD,15M |
| 2090-U3AE-D4430 |
CABLE,TWO AXISTO LOGIX 1756MOAE2 CARD,30M |
| 2090-U3BB-D44 |
BREAKOUT BOARD CN1, ULTRA 3000 |
| 2090-U3BB-DM12 |
BREAKOUT BOARD, CN1, ULTRA3000 DRIVE MOUNTED |
| 2090-U3BB-DM44 |
| 2090-U3BB2-DM44 |
| 2090-U3BC-D4401 |
BREAKOUT BOARD CABLE,CN1,ULTRA 3000,1M |
| 2090-U3BC-D4403 |
BREAKOUT BOARD CABLE,CN1,ULTRA 3000,3M |
| 2090-U3BC-D4409 |
BREAKOUT BOARD CABLE,CN1,ULTRA 3000,9M |
| 2090-U3BK-D4401 |
BREAKOUT BOARD KIT,CONTROL,CN1,ULTRA 3000,1M |
| 2090-U3BK-D4403 |
BREAKOUT BOARD KIT,CONTROL,CN1,ULTRA 3000,3M |
| 2090-U3BK-D4409 |
BREAKOUT BOARD KIT,CONTROL,CN1,ULTRA 3000,9M |
| 2090-U3CBB-DM12 |
BREAKOUT BOARD,CN1,ULTRA3000 DRIVE MOUNTED,24-5V C |
| 2090-U3CBB-DM44 |
| 2090-U3CC-D4401 |
CABLE,CONTROLLER INTERFACE,ULTRA 3000,CN1,1M |
| 2090-U3CC-D4403 |
CABLE,CONTROLLER INTERFACE,ULTRA 3000,CN1,3M |
| 2090-U3CC-D4409 |
CABLE,CONTROLLER INTERFACE,ULTRA 3000,CN1,9M |
| 2090-U3CC-D4415 |
CABLE,CONTROLLER INTERFACE,ULTRA 3000,CN1,15M |
| 2090-U3CC-D4430 |
CABLE,CONTROLLER INTERFACE,ULTRA 3000,CN1,30M |
| 2090-U3CK-D44 |
CONNECTOR KIT 44 PIN D SUB, CNTRL I/O INTERFACE CN |
| 2090-U5CK-TB |
CONNECTOR KIT,ULTRA5000,28 PIN AND 15 PIN PLUGABLE |
| 2090-U5EK-DN |
KIT,EXPANSION,ULTRA5000 DEVICE NET |
| 2090-U5PM-D0901 |
CABLE, ULTRA5000 TO PANELVIEW 300 MICRO, 1M |
| 2090-U5PM-D0903 |
CABLE, ULTRA5000 TO PANELVIEW 300 MICRO, 3M |
| 2090-U5PM-D0909 |
CABLE, ULTRA5000 TO PANELVIEW 300 MICRO, 9M |
| 2090-U5PV-D0901 |
CABLE, ULTRA5000 TO PANELVIEW STANDARD, 1M |
| 2090-U5PV-D0903 |
CABLE, ULTRA5000 TO PANELVIEW STANDARD, 3M |
| 2090-U5PV-D0909 |
CABLE, ULTRA5000 TO PANELVIEW STANDARD, 9M |
| 2090-UCSR-P900 |
PASSIVE SHUNT REGULATOR, ULTRA, 900 W |
| 2090-UXBB-D15 |
BREAKOUT BOARD CN2,ULTRAX000 |
| 2090-UXBB-DM09 |
BREAKOUT BOARD, CN3, ULTRAX000 DRIVE MOUNTED |
| 2090-UXBB-DM15 |
BREAKOUT BOARD, CN2, ULTRAX000 DRIVE MOUNTED |
| 2090-UXBC-D1501 |
BREAKOUT BOARD CABLE,CN2,ULTRAX000,1M |
| 2090-UXBC-D1503 |
BREAKOUT BOARD CABLE,CN2,ULTRAX000,3M |
| 2090-UXBC-D1509 |
BREAKOUT BOARD CABLE,CN2,ULTRAX000,9M |
| 2090-UXBC-D1515 |
BREAKOUT BOARD CABLE,CN2,ULTRAX000,15M |
| 2090-UXBK-D1501 |
BREAKOUT BOARD KIT,MTR FDBK,CN2,ULTRA X000,1M |
| 2090-UXBK-D1503 |
BREAKOUT BOARD KIT,MTR FDBK,CN2,ULTRA X000,3M |
| 2090-UXBK-D1509 |
BREAKOUT BOARD KIT,MTR FDBK,CN2,ULTRA X000,9M |
| 2090-UXBK-D1515 |
BREAKOUT BOARD KIT,MTR FDBK,CN2,ULTRA X000,15M |
| 2090-UXCK-D09 |
CONNECTOR KIT 9PIN D SUB SERIAL CN3 |
| 2090-UXCK-D15 |
CONNECTOR KIT 15 PIN D SUB, FEEDBACK CN2 |
| 2090-UXLF-106 |
AC LINE FILTER,ULTRA,6 AMPS,1 PHASE |
| 2090-UXLF-110 |
AC LINE FILTER,ULTRA,10 AMPS,1 PHASE |
| 2090-UXLF-123 |
AC LINE FILTER,ULTRA,23 AMPS,1 PHASE |
| 2090-UXLF-132 |
AC LINE FILTER, ULTRA, 32 AMPS, 1 PHASE |
| 2090-UXLF-136 |
AC LINE FILTER,ULTRA,36 AMPS,1 PHASE |
| 2090-UXLF-150 |
AC LINE FILTER,ULTRA,50 AMPS,1 PHASE |
| 2090-UXLF-336 |
AC LINE FILTER,ULTRA,36 AMPS,3 PHASE |
| 2090-UXLF-350 |
AC LINE FILTER,ULTRA,50 AMPS,3 PHASE |
| 2090-UXLF-370 |
AC LINE FILTER,ULTRA,70 AMPS,3 PHASE |
| 2090-UXLF-HV323 |
AC LINE FILTER,ULTRA,23 AMPS, 460V, 3 PHASE |
| 2090-UXLF-HV330 |
AC LINE FILTER,ULTRA,30 AMPS, 460V, 3 PHASE |
| 2090-UXLF-HV350 |
AC LINE FILTER,ULTRA,50 AMPS, 460V, 3 PHASE |
| 2090-UXNBMP-18S01 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 1 MTR. |
| 2090-UXNBMP-18S03 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 3 MTR. |
| 2090-UXNBMP-18S09 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 9 MTR. |
| 2090-UXNBMP-18S15 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 15 MTR. |
| 2090-UXNBMP-18S30 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 30 MTR. |
| 2090-UXNBMP-18S60 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 60 MTR. |
| 2090-UXNBMP-18S90 |
CABLE,ULTRA,NON-FLEX,MOTOR BRAKE,MP 90 MTR. |
| 2090-UXNFBHF-K01 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,R/A,SKWD,1M |
| 2090-UXNFBHF-K03 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,R/A,SKWD,3M |
| 2090-UXNFBHF-K09 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,R/A,SKWD,9M |
| 2090-UXNFBHF-K15 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,R/A,SKWD,15M |
| 2090-UXNFBHF-K30 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,R/A,SKWD,30M |
| 2090-UXNFBHF-R01 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,RT ANGLE,1M |
| 2090-UXNFBHF-R03 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,RT ANGLE,3M |
| 2090-UXNFBHF-R09 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,RT ANGLE,9M |
| 2090-UXNFBHF-R15 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,RT ANGLE,15M |
| 2090-UXNFBHF-R30 |
CABLE,ULTRA, NON-FLEX, MOTOR FEEDBACK,RT ANGLE,30M |
| 2090-UXNFBHF-S01 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,H&F,1M |
| 2090-UXNFBHF-S02 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,2M |
| 2090-UXNFBHF-S03 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,H&F,3M |
| 2090-UXNFBHF-S04 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,4M |
| 2090-UXNFBHF-S05 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,5M |
| 2090-UXNFBHF-S07 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,7M |
| 2090-UXNFBHF-S09 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,H&F,9M |
| 2090-UXNFBHF-S12 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,12M |
| 2090-UXNFBHF-S15 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,H&F,15M |
| 2090-UXNFBHF-S20 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,20M |
| 2090-UXNFBHF-S25 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,H&F,25M |
| 2090-UXNFBHF-S30 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,H&F,30M |
| 2090-UXNFBMP-S01 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,MP,1M |
| 2090-UXNFBMP-S02 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,2M |
| 2090-UXNFBMP-S03 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,MP,3M |
| 2090-UXNFBMP-S04 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,4M |
| 2090-UXNFBMP-S05 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,5M |
| 2090-UXNFBMP-S07 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,7M |
| 2090-UXNFBMP-S09 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,MP,9M |
| 2090-UXNFBMP-S12 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,12M |
| 2090-UXNFBMP-S15 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,MP,15M |
| 2090-UXNFBMP-S20 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,20M |
| 2090-UXNFBMP-S25 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,25M |
| 2090-UXNFBMP-S30 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,MP,30M |
| 2090-UXNFBMP-S40 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,40M |
| 2090-UXNFBMP-S60 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,60M |
| 2090-UXNFBMP-S90 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,MP,90M |
| 2090-UXNFBN-K01 |
CABLE,ULTRA, NON-FLEX,SKWD,R/A,1M |
| 2090-UXNFBN-K03 |
CABLE,ULTRA, NON-FLEX,SKWD,R/A,3M |
| 2090-UXNFBN-K09 |
CABLE,ULTRA, NON-FLEX,SKWD,R/A,9M |
| 2090-UXNFBN-K15 |
CABLE,ULTRA, NON-FLEX,SKWD,R/A,15M |
| 2090-UXNFBN-K30 |
CABLE,ULTRA, NON-FLEX,SKWD,R/A,30M |
| 2090-UXNFBN-R01 |
CABLE,ULTRA, NON-FLEX,RT ANGLE,1M |
| 2090-UXNFBN-R03 |
CABLE,ULTRA, NON-FLEX,RT ANGLE,3M |
| 2090-UXNFBN-R09 |
CABLE,ULTRA, NON-FLEX,RT ANGLE,9M |
| 2090-UXNFBN-R15 |
CABLE,ULTRA, NON-FLEX,RT ANGLE,15M |
| 2090-UXNFBN-R30 |
CABLE,ULTRA, NON-FLEX,RT ANGLE,30M |
| 2090-UXNFBN-S01 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,N,1M |
| 2090-UXNFBN-S02 |
CABLE,ULTRA,NON-FLEX,MOTOR FEEDBACK,N,2M |
| 2090-UXNFBN-S03 |
CABLE,ULGRF50ON-FLEX,MOTOR FEEDBACK,N,3M |
