北京祥顺达恒商贸有限公司
  • A-B PLC9
  • 发布时间:2008/9/4 10:19:52   修改时间:2008/9/4 10:19:52 浏览次数:962
  •   如需了解相关信息咨询      薛晨:13801020197
    1757-UPGSIFV UPGRADE ASEA CONTROLLER QUICKBUILDER INTERFACE
    1757-UPGSIFW UPGRADE MA500 QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFY UPGRADE DPR RECORDERS QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFZ UPGRADE FLAME SFGRD QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFZA UPGRADE APPLICON QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFZB UPGRADE FSC SER MODBUS QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFZD UPGRADE OPC SERV CLIENT QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFZE UPGRADE UNIVERSAL MODBUS QUICKBUILDER INTERFACE
    1757-UPGSIFZF UPGRADE BAILEY INFI90 QUICKBUILDER INTERFACE
    1757-UPGSR100 UPGRADE 100 PT RED SERVER ONE MAJOR RELEASE LEVEL
    1757-UPGSR300 UPGRADE 300PT RED SERVER LIC ONE MAJOR RELEASE LEVEL
    1757-UPGSR50 UPGRADE 50PT RED SERVER ONE MAJOR RELEASE LEVEL
    1760-CBL-2M GFX 2 M CPU TO CPU CABLE
    1760-CBL-5M GFX 5 M CPU TO CPU CABLE
    1760-CBL-INT01 PICO-LINK CONNECTIVITY CABLE .3M 1 PCS/PACK
    1760-CBL-INT03 PICO-LINK CONNECTIVITY CBL .8M  1 PCS/PACK
    1760-CBL-INT05 PICO-LINK CONNECTIVITY CBL 1.5M  1 PCS/PACK
    1760-CBL-INT300 INTRA-CBL 100M NONTERM
    1760-CBLPC02 GFX PROGRAMMING CABLE
    1760-CBL-PM02 PROGRAMMMING CABLE FOR PICO CONTROLLER TO BE USED WITH 1760-PICOSOFT CONFIGURATION SOFTWARE
    1760-CONN-RJ45 INTRA-CBL CONNECT 10/PACK
    1760-DNET PICO DEVICENET MODULE
    1760-DU GFX DISPLAY WITH OUT BUTTONS
    1760-DUB GFX DISPLAY WITH BUTTONS
    1760-IA12XOW4I PICO GFX AC I/O, RELAY OUTPUT
    1760-IA12XOW4IF PICO GFX AC I/O, RELAY OUTPUT
    1760-IA12XOW6I 18 I/O EXPANSION MODULE, AC
    1760-IB12XOB4IF 12 DC IN 4 TRANS OUT AI
    1760-IB12XOB4IOF 12 DC IN 4 TRANS OUT AIAO
    1760-IB12XOB8 18 I/O EXPANSION MODULE, DC
    1760-IB12XOW4IF 12 DC IN 4 RELAY OUT AI
    1760-IB12XOW4IOF 12 DC IN 4 RELAY OUT AIAO
    1760-L12AWA 12 I/O PICO CONTROLLER W/ RTC, AC (8) 120/240V AC INPUT, (4) RELAY OUTPUT, AC LINE, RTC & DISPLAY
    1760-L12AWA-NC 12 I/O PICO CONTROLLER, AC (8) 120/240V AC INPUT, (4) RELAY OUTPUT, AC LINE, DISPLAY
    1760-L12AWA-ND 12 I/O PICO CONTROLLER W/OUT DISPLAY, AC (8) 120/240V AC INPUT, (4) RELAY OUTPUT, AC LINE, RTC, NO DISPLAY
    1760-L12BBB 12 I/O PICO CONTROLLER 24V IN 24VDC OUT
    1760-L12BBBND 12 I/O PICO CNTROLLER 24V IN 24VDC OUT W/O DISPLAY
    1760-L12BWB 12 I/O PICO CONTROLLER W/ RTC, DC (8) 24V DC INPUT, (4) RELAY OUTPUT, DC LINE, RTC & DISPLAY
    1760-L12BWB-NC 12 I/O PICO CONTROLLER, DC (8) 24V DC INPUT, (4) RELAY OUTPUT, DC LINE, DISPLAY
    1760-L12BWB-ND 12 I/O PICO CONTROLLER W/OUT DISPLAY, 24V DC
    1760-L12DWD 12 I/O PICO CONTROLLER W/RTC, 12V DC
    1760-L12NWN 12 I/O PICO CONTROLLER, 24VAC
    1760-L12NWNND 12 I/O PICO CONTROLLER W/OUT DISPLAY, 24VAC
    1760-L18AWA-EX 18 I/O PICO CONTROLLER W/RTC, AC, EXPANDABLE
    1760-L18AWAEXND 18 I/O PICO CONTROLLER W/O DISPLAY AC, EXPANDABLE
    1760-L18BWB-EX 18 I/O PICO CONTROLLER W/RTC, 24V DC, EXPANDABLE
    1760-L18BWBEXND 18 I/O PICO 24VDC CNTL W/O DISPLAY, EXPANDABLE
    1760-L18DWDEX 12 I/O PICO CONTROLLER W/RTC, 12V DC EXPANDABLE
    1760-L18DWDEXND 12 I/O PICO CONTROLLER W/O DISPLAY, 12VDC EXPNDBLE
    1760-L18NWNEX 18 I/O PICO 24VAC CONTROLLER, EXPANDABLE
    1760-L18NWNEXND 18 I/O PICO 24VAC CONTROLLER W/O DISP, EXPANDABLE
    1760-L20BBBEX 20 I/O PICO 24VDC CONTROLLER, EXPANDABLE
    1760-L20BBBEXND 20 I/O PICO 24VDC CNTL W/O DISPLAY, EXPANDABLE
    1760-LDF GFX CPU STANDARD
    1760-LDFA PICO GFX AC CPU WITHOUT PICOLINK
    1760-LDFC GFX CPU WITH INTRACONNECT
    1760-LDFCA PICO GFX AC CPU W/PICOLINK
    1760-MM1 MEMORY MODULE FOR 12 I/O PICO CONTROLLER
    1760-MM2 MEMORY MODULE FOR 18 I/O PICO CONTROLLER
    1760-MM2B PICO 32K MEMORY MODULE
    1760-MM3 GFX 256K MEMORY MODULE
    1760-NDC COVER PROTECT DISPLAY
    1760-NDM MEMBRANE PROTECT DISPLAY
    1760-NMF GFX MOUNTING FT; 8 PER PK
    1760-OW2 PICO 2 PT RELAY MODULE FOR PICO & PICO GFX
    1760-PICOPROPC02 PICOSOFTPRO W/PROG CABLE
    1760-PICOSOFT CONFIGURATION SOFTWARE FOR PICO CONTROLLERS INCLUDES CD & 3 MONTHS OF TECH SUPPORT.  USE WITH 1760-CBL-PM02 CABLE.
    1760-PICOSOFTPRO PICOSOFTPRO SOFTWARE
    1760-RMGFX PICO GFX REMOTE MOUNT
    1760-RMPICO PICO STANDARD REMOTE MOUNT
    1760-RPLCONN REPLACEMENT CONNECTOR FOR EXPANSION I/O MODULE
    1760-SIM INPUT SIMULATOR FOR 12 I/O DC PICO CONTROLLER CONTAINS INPUT BOARD, OUTPUT BOARD, 24V DC POWER SUPPLY
    1760-TERM1 TERMINATION RESIST 2/PACK
    1761-CBL-AC00 CABLE: 9-PIN PORT OF 1761-NET-AIC TO 9-PIN PORT OF PERSONAL COMPUTER, 45 CM (17.7 IN.)
    1761-CBL-AM00 CABLE: MICROLOGIX 1000 CONTROLLER TO PORT 2 (8-PIN DIN) OF 1761-NET-AIC, 45 CM (17.7 IN.)
    1761-CBL-AP00 CABLE: MICROLOGIX 1000 CONTROLLER TO PORT 1 (9-PIN PORT) OF 1761-NET-AIC, 45 CM (17.7 IN.)
    1761-CBL-AS03 CABLE: SLC FIXED, 5/01, 5/02 & 5/03 RJ45 TO PORT 3 (6-PIN PHOENIX CONNECTOR) OF 1761-NET-AIC, 3 M (9.8 FT.)
    1761-CBL-AS09 CABLE: SLC FIXED, 5/01, 5/02 & 5/03 RJ45 TO PORT 3 (6-PIN PHOENIX CONNECTOR) OF 1761-NET-AIC, 9.5 M (31 FT.)
    1761-CBL-HM02 CABLE: MICROLOGIX 1000 TO HAND HELD PROGRAMMER 2.0 METER (6.5 FT), 8-PIN MINI DIN TO 8-PIN MINI DIN
    1761-CBL-PM02 CABLE: MICROLOGIX 1000 TO PERSONAL COMPUTER 2.0 METER (6.5 FT), 8-PIN MINI DIN TO 9-PIN D-SHELL
    1761-HHM-K08 8K MEMORY MODULE FOR HHP (STORES AT LEAST 1 PROGRAM)
    1761-HHM-K64 64K MEMORY MODULE FOR HHP (STORES AT LEAST 8 PROGRAMS)
    1761-HHP-B30 HAND HELD PROGRAMMER FOR MICROLOGIX 1000 (INCLUDES 1761-CBL-HM02 CABLE)
    1761-L10BWA 10 I/O MICROLOGIX 1000 (6) 24V DC INPUT, (4) RELAY OUTPUT, AC LINE
    1761-L10BWB 10 I/O MICROLOGIX 1000 (6) 24V DC INPUT, (4) RELAY OUTPUT, DC LINE
    1761-L10BXB ML1000 6-24VDC IN, 2-DC FET & 2-RELAY OUT, DC PWR
    1761-L16AWA 16 I/O MICROLOGIX 1000 (10) 120V AC INPUT, (6) RELAY OUTPUT, AC LINE
    1761-L16BBB 16 I/O MICROLOGIX 1000 (10) 24V DC INPUT, (4) DC MOSFET & (2) RELAY OUTPUTS, DC LINE
    1761-L16BWA 16 I/O MICROLOGIX 1000 (10) 24V DC INPUT, (6) RELAY OUTPUT, AC LINE
    1761-L16BWB 16 I/O MICROLOGIX 1000 (10) 24V DC INPUT, (6) RELAY OUTPUT, DC LINE
    1761-L16NWA MICROLOGIX 1000 16PT. WITH 24V AC INPUTS AC POWER
    1761-L16NWB MICROLOGIX 1000 16PT. WITH 24V AC INPUTS DC POWER
    1761-L20AWA-5A 25 I/O MICROLOGIX 1000 WITH ANALOG (12) 120V AC IN, (4) ANALOG IN, (8) RELAY OUT, (1) ANALOG OUT, AC LINE
    1761-L20BWA-5A 25 I/O MICROLOGIX 1000 WITH ANALOG (12) 24V DC IN, (4) ANALOG IN, (8) RELAY OUT, (1) ANALOG OUT, AC LINE
    1761-L20BWB-5A 25 I/O MICROLOGIX 1000 WITH ANALOG (12) 24V DC IN, (4) ANALOG IN, (8) RELAY OUT, (1) ANALOG OUT, DC LINE
    1761-L32AAA 32 I/O MICROLOGIX 1000 (20) 120V AC IN, (10) AC TRIAC, (2) RELAY OUTPUT, AC LINE
    1761-L32AWA 32 I/O MICROLOGIX 1000 (20) 120V AC INPUT, (12) RELAY OUTPUT, AC LINE
    1761-L32BBB 32 I/O MICROLOGIX 1000 (20) 24V DC INPUT, (10) DC MOSFET & (2) RELAY OUTPUTS, DC LINE
    1761-L32BWA 32 I/O MICROLOGIX 1000 (20) 24V DC INPUT, (12) RELAY OUTPUT, AC LINE
    1761-L32BWB 32 I/O MICROLOGIX 1000 (20) 24V DC INPUT, (12) RELAY OUTPUT, DC LINE
    1761-MMB MICROMENTOR BASICS BOOK FOR PROGRAMMABLE CTRLRS
    1761-NET-AIC AIC+ ADVANCED INTERFACE CONVERTER RS-232 TO RS-485 CNVTR, 2 RS-232 PORTS: 8-PIN MINI DIN & 9-PIN D-SHELL
    1761-NET-DNI DEVICENET INTERFACE (DNI) DEVICENET TO DF1  FULL DUPLEX CONVERTER
    1761-NET-ENI ETHERNET INTERFACE FOR MICROLOGIX AND COMPACTLOGIX
    1761-NETENIW ETHERNET INTERFACE W/WEB FOR MICROCONTROLLER
    1761-RPL-DIN REPLACEMENT DIN LATCHES (SET OF 2) FOR ALL MICROLOGIX 1000 CONTROLLERS
    1761-RPL-RT00 REPLACEMENT DNET TERM BLK FOR 1761-NET-DNI
    1761-RPL-T32X REPLACEMENT TERMINAL COVERS (SET OF 2) FOR CTLG #'S 1761-L32AWA, L32BWA, L32AAA, L32BWB, OR L32BBB
    1761-SIM-B16 MICROLOGIX 1000 INPUT SIMULATOR FOR USE WITH CTLG # 1761-L16BWA
    1762-IA8 8 POINT 120 VAC INPUT MODULE
    1762-IF2OF2 4 CHANNEL ANALOG COMBO MODULE 2 CH CURRENT/VOLTAGE INPUT, 2 CH CURRENT/VOLTAGE OUTPUT
    1762-IF4 4 CHANNEL CURRENT/VOLTAGE ANALOG INPUT MODULE
    1762-IQ16 16 POINT 24 VDC SINK/SOURCE INPUT MODULE
    1762-IQ8 8 POINT 24 VDC SINK/SOURCE INPUT MODULE
    1762-IQ8OW6 8-CH SINK/SOURCE DC IN/6CH RELAY OUT COMBO MODULE
    1762-IR4 4 CHANNEL, RTD/RESISTANCE MODULE
    1762-IT4 4 CHANNEL, THERMOCOUPLE/MILLIVOLT MODULE
    1762-L24AWA MICROLOGIX 1200, 24 PT. (14) 120V AC IN, (10) RELAY OUT, AC POWER
    1762-L24AWAR ML1200 24AC/RLY/AC 2 PORT
    1762-L24BWA MICROLOGIX 1200, 24 PT. (14) 24V DC IN, (10) RELAY OUT, AC POWER
    1762-L24BWAR ML1200 24DC/RLY/AC 2 PORT
    1762-L24BXB MICROLOGIX 1200, 24 PT. (14) 24V DC IN, (5) RELAY AND (5) FET OUT, DC POWER
    1762-L24BXBR ML1200 24DC/DC&RLY/DC 2PT
    1762-L40AWA MICROLOGIX 1200, 40 PT. (24) 120V AC IN, (16) RELAY OUT, AC POWER
    1762-L40AWAR ML1200 40AC/RLY/AC 2 PORT
    1762-L40BWA MICROLOGIX 1200, 40 PT. (24) 24V DC IN, (16) RELAY OUT, AC POWER
    1762-L40BWAR ML1200 40DC/RLY/AC 2 PORT
    1762-L40BXB MICROLOGIX 1200, 40 PT. (24) 24V DC IN, (8) RELAY AND (8) FET OUT, DC POWER
    1762-L40BXBR ML1200 40DC/DC&RLY/DC 2PT
    1762-MM1 MEMORY MODULE
    1762-MM1RTC MEMORY MODULE WITH RTC
    1762-OA8 8 POINT 120/240 VAC OUTPUT MODULE
    1762-OB16 16 POINT 24 VDC SOURCE OUTPUT MODULE
    1762-OB8 8 POINT 24 VDC SOURCE OUTPUT
    1762-OF4 4 CH ANALOG OUTPUT MODULE
    1762-OW16 16 POINT VAC/VDC RELAY OUTPUT MODULE
    1762-OW8 8 POINT VAC/VDC RELAY OUTPUT MODULE
    1762-OX6I 6CH ISOLATED HIGH CURRENT
    1762-RPLDIN2 REPLACEMENT DIN LATCHES FOR 1762 I/O
    1762-RPLDR2 REPLACEMENT DOOR KIT FOR 1762 I/O
    1762-RPLRTB40 REPLACEMENT,40 PT TERM BLOCK FOR MICROCONTROLLER MICROLOGIX 1200
    1762-RPLTLBL2 REPLACEMENT LABELS FOR 1762 I/O MODULES
    1762-RTC REAL TIME CLOCK
    1763-BA ML1100 REPLACE BATTERY ML1100 REPLACEMENT BATTERY
    1763-L16AWA 16 PT ML1100 AC IN/RELAY 16 PT ML1100 CONTROL W/10 110V AC IN /6 RELAY OUT
    1763-L16BBB 16 PT ML1100 DC /DC&RELAY 16 PT ML1100 CONTROL W/10 24V DC IN /2 RELAY 4 FET
    1763-L16BWA 16 PT ML1100 DC IN/RELAY 16 PT ML1100 CONTROL W/10 24V DC IN /6 RELAY OUT
    1763-MM1 ML1100 MEMORY MODULE ML1100 MEMORY MODULE
    1763-NC01 ML1100 RS485 COMM CABLE ML1100 TO RS485 COMMUNICATION CABLE
    1764-24AWA ML 1500 BASE 120V AC IN / RELAY OUT / AC POWER
    1764-24BWA ML 1500 BASE 24V DC IN / RELAY OUT / AC POWER
    1764-28BXB ML 1500 BASE DC IN / DC FET & RELAY OUT / DC POWER
    1764-DAT DATA ACCESS TOOL
    1764-LRP ML 1500 RS-232 PROCESSOR
    1764-LSP MICROLOGIX 1500 STANDARD PROCESSOR UNIT
    1764-MM1 MICROLOGIX 1500 MEMORY MODULE
    1764-MM1RTC MICROLOGIX 1500 MEMORY MODULE WITH REAL TIME CLOCK
    1764-MM2 MICROLOGIX 1500 16K MEMORY MODULE
    1764-MM2RTC MICROLOGIX 1500 16K MEM MOD W/RTC
    1764-MM3 MEMORY MODULE (64K) FOR MICROLOGIX 1500LRP
    1764-MM3RTC MEMORY MODULE (64K)  W/REAL TIME CLOCK FOR 1500LRP
    1764-RPLCDR1 PROCESSOR DOOR REPLACEMENT KIT
    1764-RPLTB1 REMOVABLE TERMINAL BLOCK KIT (17 PT)
    1764-RPLTB2 REMOVABLE TERMINAL BLOCK KIT (21 PT)
    1764-RTC MICROLOGIX 1500 REAL TIME CLOCK
    1768-ENBT COMPACTLOGIX ENET/IP BRIDGE MODULE
    1768-L43 COMPACTLOGIX L43 PROCESSOR WITH 2MB MEMORY
    1768-M04SE COMPACTLOGIX L4X SERCOS INTERFACE MODULE
    1768-PA3 POWER SUPPLY, 120/240 VAC INPUT, 3.5A @ 24VDC
    1769-ADN 1769 COMPACT I/O DEVICENET ADAPTER
    1769-ARM ADDRESS RESERVE MODULE
    1769-ASCII 2 CHANNEL RS232/RS485/RS422 ASCII INTERFACE MODULE
    1769-BOOLEAN 24V INPUT/OUTPUT BOOLEAN CONTROL MODULE
    1769-CLL1 1 FT (305 MM) LEFT-TO-LEFT BUS EXPANSION CABLE
    1769-CLL3 3.28 FT (1 M) LEFT-TO-LEFT BUS EXPANSION CABLE
    1769-CRL1 1 FT (305 MM) RIGHT-TO-LEFT BUS EXPANSION CABLE
    1769-CRL3 3.28 FT (1M) RIGHT-TO-LEFT BUS EXPANSION CABLE
    1769-CRR1 1FT (305 MM) RIGHT-TO-RIGHT BUS EXPANSION CABLE
    1769-CRR3 3.28 FT (1 M) RIGHT-TO-RIGHT BUS EXPANSION CABLE
    1769-DPALEN COMPACTLOGIX SYSTEM DOCUMENTATION SET PRINTED
    1769-ECL LEFT END CAP/TERMINATOR
    1769-ECR RIGHT END CAP/TERMINATOR
    1769-HSC 2/4 CHANNEL HIGH SPEED COUNTER/ENCODER MODULE
    1769-IA16 16 POINT 120 VAC INPUT MODULE
    1769-IA8I 8 POINT 120 VAC INDIVIDUALLY ISOLATED INPUT MODULE
    1769-IF4 4 CHANNNEL ANALOG CURRENT/VOLTAGE INPUT MODULE
    1769-IF4I 4 CHANNEL CURRENT/VOLTAGE ISOLATED ANALOG INPUT
    1769-IF4XOF2 8 BIT RESOLUTION, HIGH SPEED 4 IN/2 OUT ANLG. COMB
    1769-IF8 8 CHANNEL ANALOG VOLTAGE/CURRENT INPUT MODULE
    1769-IG16 5 VDC TTL INPUT MODULE
    1769-IM12 12 POINT 240 VAC INPUT MODULE
    1769-IQ16 16 POINT 24 VDC SINKING/SOURCING INPUT MODULE
    1769-IQ16F 1769 16 POINT HIGH SPEED 24VDC INPUT MODULE
    1769-IQ32 1769 32 POINT 24VDC INPUT MODULE
    1769-IQ32T 32 POINT HIGH DENSITY, 24V DC INPUT - SINGLE WIDE
    1769-IQ6XOW4 COMBO 6PT 24 VDC SNK/SRC IN, 4PT VAC/VDC RELAY OUT
    1769-IR6 6 CHANNEL RTD/RESISTANCE INPUT MODULE
    1769-IT6 6 CHANNEL THERMOCOUPLE/MILLIVOLT INPUT MODULE
    1769-L31 COMPACTLOGIX DUAL SERIAL PROCESSOR, 512K
    1769-L32C COMPACTLOGIX CONTROLNET PROCESSOR, 750K
    1769-L32E COMPACTLOGIX ETHERNET PROCESSOR, 750 KBYTE MEMORY
    1769-L35CR COMPACTLOGIX CONTROLNET REDUNDANT PROCESSOR, 1.5MB
    1769-L35E COMPACTLOGIX ETHERNET PROCESSOR, 1.5MBYTE MEMORY
    1769-OA16 16PT.120/240 VAC OUTPUT
    1769-OA8 8 POINT 120/240 VAC OUTPUT MODULE
    1769-OB16 16 POINT 24 VDC SOURCING OUTPUT MODULE
    1769-OB16P 16 PT. 24 VDC ELECTRONICALLY FUSED SOURCING OUTPUT
    1769-OB32 1769 32 POINT 24VDC OUTPUT MODULE
    1769-OB8 1769 8 POINT HIGH POWER 24VDC OUTPUT MODULE
    1769-OF2 2 CHANNEL ANALOG CURRENT/VOLTAGE OUTPUT MODULE
    1769-OF4CI 4 CHANNEL CURRENT ISOLATED ANALOG OUTPUT
    1769-OF4VI 4 CHANNEL VOLTAGE ISOLATED ANALOG OUTPUT
    1769-OF8C 8 CHANNEL ANALOG CURRENT OUTPUT MODULE
    1769-OF8V 8 CHANNEL ANALOG VOLTAGE OUTPUT MODULE
    1769-OG16 5 VDC TTL OUTPUT MODULE
    1769-OV16 16 POINT 24 VDC SINKING OUTPUT MODULE
    1769-OV32T 32 POINT HIGH DENSITY, 24V DC OUT SINK-SINGLE WIDE
    1769-OW16 16 PT.AC/DC RELAY OUTPUT
    1769-OW8 8 POINT VAC/VDC RELAY OUTPUT MODULE
    1769-OW8I 8 PT. VAC/VDC INDIV. ISOLATED RELAY OUTPUT MODULE
    1769-PA2 PWR SUPPLY 120/240 VAC INPUT 2 AMP @ 5 VDC OUTPUT
    1769-PA4 120/240 VAC INPT. PWR SUPPLY 4A @ 5VDC, 2A @ 24VDC
    1769-PB2 PWR SUPPLY 24 VDC INPUT 2 AMP @ 5 VDC OUTPUT
    1769-PB4 24VDC INPUT P0WER SUPPLY: 4A @ 5VDC 2A @ 24VDC
    1769-RD REPLACEMENT 1769 I/O TERMINAL DOORS
    1769-RL1 REPLACEMENT DOOR LABELS FOR DISC. I/O (2 PER KIT)
    1769-RL2 REPLACEMENT DOOR LABELS FOR SPEC.  I/O (2 PER KIT)
    1769-RTBN10 REPLACEMENT 10 PIN NEMA TERMINAL BLOCK (1 PER KIT)
    1769-RTBN18 REPLACEMENT 18 PIN NEMA TERMINAL BLOCK (1 PER KIT)
    1769-SDN DEVICENET SCANNER FOR 1764 AND 1769 CONTROLLERS
    1769-STRT3 COMPACTLOGIX L31 STARTER KIT
    1769-STRT4 COMPACTLOGIX L32E STARTER KIT
    1770-CD1 DATA HWY TWINAXIAL CABLE, 100 FT/30 M
    1770-CD10 DATA HWY TWINAXIAL CABLE, 1000 FT/305 M
    1770-CD2 DATA HWY TWINAXIAL CABLE, 200 FT/61 M
    1770-CD3 DATA HWY TWINAXIAL CABLE, 300 FT/91 M
    1770-CD4 DATA HWY TWINAXIAL CABLE, 400 FT/122 M
    1770-CD5 DATA HWY TWINAXIAL CABLE, 500 FT/152 M
    1770-CD6 DATA HWY TWINAXIAL CABLE, 600 FT/183 M
    1770-CD7 DATA HWY TWINAXIAL CABLE, 700 FT/213 M
    1770-CD8 DATA HWY TWINAXIAL CABLE, 800 FT/244 M
    1770-CD9 DATA HWY TWINAXIAL CABLE, 900 FT/274 M
    1770-CG RS-232C INTERFACE CABLE 16.5 FT/5.03 M, FOR 1771-KE, -KF, -KG OR 1785-KE
    1770-CP RS-232C MODEM ADAPTER CABLE, 16.5FT/5.03M 1-KE, -KF, -KG OR 1785-KE
    1770-KF2 DATA HWY/DATA HWY+ ASYNCHRONOUS INTERFACE MODULE RS-232C OR RS-422A
    1770-KFC15 SERIAL/PARALLEL INTERFACE CARD
    1770-KFCD15 24 VDC SERIAL/PARALLEL INTERFACE CARD
    1770-KFD DEVICENET RS232 ADAPTER
    1770-KFDG DEVICENET RS-232 ADAPTER W/GLOBAL 9V POWER SUPPLY
    1770-SC DATA HWY STATION CONNECTOR
    1770-XE DATA HWY 15 PIN CONNECTOR KIT, (FEMALE)
    1770-XF DATA HIGHWAY TERMINATOR SET
    1770-XG DATA HWY DROPLINE (1770-CD) CONNECTOR KIT
    1770-XY AA LITHIUM BATTERY FOR ORIGINAL PLC-5 & PLC-2/05  ALL 1785LT AND 1772LS PROCESSORS
    1770-XYB LITHIUM BATTERY FOR PLC-5 ENHANCED PROCESSORS (SERIES A AND B)
    1770-XYC LITHIUM BATTERY FOR PLC-5 PROCESSORS SERIES B & LATER
    1770-XYV PLC-5 VME PROCESSOR BATTERY  (1785VXXX)
    1771-A1B I/O CHASSIS ASSEMBLY, 4 SLOT
    1771-A1BK CONFORMALLY COATED,I/O CHASSIS ASSEMBLY 4 SLOT
    1771-A2B I/O CHASSIS ASSEMBLY, 8 SLOT
    1771-A2BK CONFORMALLY COATED I/O CHASSIS ASSEMBLY 8 SLOT
    1771-A3B I/O CHASSIS ASSEMBLY,12 SLOT,19 RACK MOUNTABLE
    1771-A3B1 I/O CHASSIS ASSEMBLY, 12 SLOT, 19
    1771-A3B1K CONFORMALLY COATED, I/O CHASSIS ASSEMBLY, 12 SLOT
    1771-A3BK CONFORMALLY COATED,I/O CHASSIS ASSEMBLY 12 SLOT,19
    1771-A4B I/O CHASSIS ASSEMBLY, 16 SLOT
    1771-A4BK CONFORMALLY COATED, I/O CHASSIS ASSEMBLY 16 SLOT
    1771-ACN15 CONTROLNET 1.5 AND BEYOND, 1771 I/O ADAPTER (DOES NOT SUPPORT PLC5 CONTROLNET HOT BACKUP)
    1771-ACNR15 CONTROLNET 1.5 AND BEYOND, 1771 I/O ADAPTER (REDUNDANT PORTS AND SUPPORT FOR PLC5 CONTROLNET HOT BACKUP)
    1771-AF FIBER OPTIC CONVERTER MODULE
    1771-AF1 FIBER OPTIC CONVERTER MODULE, STAND-ALONE
    1771-ALX PLC-5 LOCAL I/O ADAPTER MODULE
    1771-ALXK CONFORMALLY COATED, PLC-5 LOCAL I/O ADAPT. MODULE
    1771-AM1 1 SLOT I/O CHASSIS ASSEMBLY WITH INTEGRAL POWER SUPPLY AND I/O ADAPTER
    1771-AM2 2 SLOT I/O CHASSIS ASSEMBLY WITH INTEGRAL POWER SUPPLY AND I/O ADAPTER
    1771-AR REMOTE I/O ADAPTER MODULE FOR 1774PLC
    1771-ASB PLC-2,-3,-5, REMOTE I/O ADAPTER MODULE
    1771-ASBK CONFORMALLY COATED, PLC2, 3, 5 REMOTE I/O ADAPTER
    1771-CCS4 CONTROL COPROCESSOR, SPARE MOUNTING KIT (INCLUDES CHANNEL 3 CONNECTOR)
    1771-CD 1771I/O CHASSIS CABLE FOR 177-P2 POWER SUPPLY 5 FT/1.52 M
    1771-CE 1771 I/O CHASSIS CABLE FOR 1771-P2 POWER SUPPLY 1 FT/0.30 M
    1771-CFM CONFIGURABLE FLOW METER
    1771-CFMK CONFORMALLY COATED, CONFIGURABLE FLOW METER
    1771-CG 1771 I/O CHASSIS CABLE FOR 1774-P1, 1778-P2 POWER SUPPLY, 3 FT/0.91 M
    1771-CL2 1771 I/O CHASSIS CABLE FOR 1771-P1 POWER SUPPLY 2.08 FT/0.64 M
    1771-CP1 1771 I/O CHASSIS CABLE FOR 1771-P7 POWER SUPPLY 1.04 FT/0.32 M
    1771-CP2 1771 I/O CHASSIS CABLE FOR 1771-P7 POWER SUPPLY 5 FT/1.52 M
    1771-CP3 1771 I/O CHASSIS CABLE FOR 1771-P7 POWER SUPPLY 5.5 FT/1.68 M
    1771-CPR FIBER OPTIC CABLE COUPLER USE WITH 1771-PT1, -PT2, -PT3, -PT4
    1771-CT 1771 I/O CHASSIS CABLE FOR 1771-P4S, 6S POWER SPLY 3.58 FT/1.09 M
    1771-CX1 PLC-5 FAMILY LOCAL I/O BUS TERMINATOR CABLE 3 FT/0.91 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX10 PLC-5 LOCAL CABLE 33 FT/10 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX15 PLC-5 LOCAL CABLE 49 FT/15 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX2 PLC-5 LOCAL I/O BUS TERMINATOR CABLE 6.5 FT/1.98 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX20 PLC-5 LOCAL CABLE 65 FT/20 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX25 PLC-5 LOCAL CABLE 82 FT/25 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX30 PLC-5 LOCAL CABLE 98 FT/30 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX5 PLC-5 LOCAL I/O BUS TERMINATOR CABLE 16 FT/4.88 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CX7 PLC-5 LOCAL CABLE 23 FT/7 M, 1785-L40L, -L60L, TO 1771-ALX
    1771-CXT PLC-5 FAMILY LOCAL I/O BUS TERMINATOR
    1771-DA ASCII I/O MODULE
    1771-DB BASIC MODULE
    1771-DBMEM1 1771-DB/B EEPROM MEMORY MODULE - 8 K BYTES
    1771-DBMEM2 1771-DB/B EEPROM MEMORY MODULE - 32 K BYTES
    1771-DCM DIRECT COMMUNICATION MODULE
    1771-DE ABSOLUTE ENCODER MODULE
    1771-DL GRAY ENCODER 12-24V INPUT MODULE ASSEMBLY
    1771-DMC CONTROL COPROCESSOR-MAIN MODULE,256KBYTE
    1771-DMC1 CONTROL COPROCESSOR - MAIN MODULE 1MBYTE W/ETHERNET
    1771-DMC4 CONTROL COPROCESSOR - MAIN MODULE 4MBYTE W/ETHERNET
    1771-DR I/O LOGIC CONTROLLER MODULE
    1771-DRS CONTROL COPROCESSOR, STATIC RAM MEMORY EXPANSION 256KBYTE
    1771-DRS1 CONTROL COPROCESSOR, STATIC RAM MEMORY EXPANSION 1MBYTE
    1771-DRS4 CONTROL COPROCESSOR, STATIC RAM MENORY EXPANSION 4MBYTE
    1771-DS LATCHING INPUT MODULE, 10-27V DC, 8 INPUTS
    1771-DW WIRE FAULT MODULE, 12-24V DC, 7 INPUTS
    1771-DXPS CONTROL COPROCESSOR - SERIAL EXPANDER MODULE
    1771-ES SERVO ENCODER FEEDBACK EXPANDER
    1771-EX EXTENDER, PROCESSOR/ADAPTER, STANDARD DENSITY
    1771-EZ EXTENDER, HIGH DENSITY
    1771-FC 1771 OUTPUT MODULE FUSE PACKAGE W/(5)2A,120V FUSES
    1771-FD FUSE KIT FOR 1771-WHF, QTY. 8 FUSES (3A)
    1771-FD2 FUSE KIT FOR 1771-WHFB, QTY. 8 FUSES (1.5A)
    1771-FE FUSE KIT FOR 1771-OD16
    1771-FF FUSE KIT FOR 1771-OQ16
    1771-IA INPUT MODULE, 120V AC/DC,8 INPUT
    1771-IAD INPUT MODULE, 120V AC, 16 INPUT
    1771-IADK CONFORMALLY COATED, INPUT 120V AC 16 SLOT
    1771-IAN INPUT MODULE, 120V AC, 32 INPUT
    1771-IB INPUT MODULE, 12-24V DC, 8 INPUT
    1771-IBD INPUT MODULE, 10-30V DC, 16 INPUT
    1771-IBDK CONFORMALLY COATED, INPUT 10-30V DC 16 SLOT
    1771-IBN HIGH-TRUE INPUT MODULE, 10-30V DC, 32 INPUT
    1771-IBNK CONFORMALLY COATED, HIGH-TRUE INPUT MODULE 10-30V DC, 32 INPUT
    1771-IC INPUT MODULE, 48V DC, 8 INPUT
    1771-ICD INPUT MODULE, 20-60V DC, 16 INPUT
    1771-ID ISOLATED INPUT MODULE, 120V AC/DC, 6 INPUT
    1771-ID01 ISOLATED INPUT, 220V AC, 6 INPUT
    1771-ID16 ISOLATED INPUT MODULE, 120V AC
    1771-ID16K CONFORMALLY COATED, ISOLATED INPUT 120 V AC
    1771-IDK CONFORMALLY COATED, ISOLATED INPUT MODULE 120V AC/DC, 6 INPUT
    1771-IFE ANALOG INPUT MODULE 12 BIT, 16 SINGLE-ENDED OR 8 DIFFERENTIAL, 8 DIFFERENTIAL
    1771-IFEK CONFORMALLY COATED, ANALOG INPUT MODULE, 12 BIT
    1771-IFF FAST ANALOG INPUT MODULE 12 BIT, 16 SINGLE-ENDED OR 8 DIFFERENTIAL, 8 DIFFERENTIAL
    1771-IFMS INTRINSICALLY SAFE FAST MILIVOLT INPUT MODULE
    1771-IG TTL INPUT MODULE 8 INPUT, USER SELECTABLE HIGH TRUE/LOW TRUE LOGIC LEVELS
    1771-IGD TTL INPUT MODULE 16 INPUT, USER SELECTABLE HIGH TRUE/LOW TRUE LOGIC LEVELS
    1771-IH INPUT MODULE, 24-48V DC, 8 INPUT
    1771-IJ ENCODER/COUNTER MODULE ASSEMBLY TTL, 5V DC
    1771-IK ENCODER/COUNTER MODULE ASSEMBLY, 12-24V DC
    1771-IL ANALOG INPUT MODULE 12 BIT, 8 DIFFERENTIAL, 1000V ISOLATION
    1771-ILK CONFORMALLY COATED, ANALOG INPUT MODULE 1000V, 12 BIT
    1771-IM INPUT MODULE, 220V/240V AC/DC, 8 INPUT
    1771-IMD INPUT MODULE, 220V AC, 16 INPUT
    1771-IN INPUT MODULE, 24V AC, 8 INPUT
    1771-IND INPUT MODULE, 24V AC, 16 INPUT
    1771-IQ SELECTABLE INPUT MODULE, 5-30V DC, 8 INPUT
    1771-IQ16 ISOLATED INPUT MODULE, 24V DC
    1771-IQ16K CONFORMALLY COATED,ISOLATED INPUT MODULE,24V DC
    1771-IR RTD INPUT MODULE, 3-WIRE RTD'S
    1771-IRK CONFORMALLY COATED,RTD INPUT MODULE,3-WIRE RTD'S
    1771-IS MULTIPLEXER INPUT MODULE, 5V DC, 72 INPUT
    1771-IT FAST RESPONSE INPUT MODULE, 12-24V DC, 8 INPUT
    1771-IV DRIVER LOGIC INPUT MODULE, 12-24V DC, 8 INPUT
    1771-IVN LOW-TRUE INPUT MODULE, 10-30V DC, 32 INPUT
    1771-IXE THERMOCOUPLE/MILLIVOLT INPUT MODULE 8 T/C'S, TYPE E, J, K, R, S, T
    1771-IXEK CONFORMALLY COATED, THERMOCOUPLE/MILLIVOLT INPUT MODULE, 8 T/C'S
    1771-IXHR HIGH RESOLUTION THERMOCOUPLE/MILLIVOLT INPUT MDUL. 8 T/C'S, TYPE B, E, J, K, R, S, T
    1771-KE DATA HWY RS-232C INTERFACE MODULE
    1771-KF DATA HWY RS-232C INTERFACE MODULE (STAND ALONE)
    1771-LC3B LOOP CONTROLLER W/RTD OPTION, 120V AC SUPPLY
    1771-LC4B LOOP CONTROLLER W/RTD OPTION,240V AC SUPPLY
    1771-LC5B LOOP CONTORLLER, 24V DC SUPPLY
    1771-LI LOOP CONTROLLER INTERFACE MODULE USE W/1771-LC
    1771-LIA LOOP CONTROLLER INTERFACE MODULE
    1771-LIA2 ADVANCED LOOP CONTROLLER INTERFACE
    1771-M1 STEPPER MOTOR CONTROLLER MODULE (1) INCLUDED WITH 1771-QA
    1771-M3 SERVO CONTROLLER MODULE,(1) INCLUDED W/ 1771-QC
    1771-NB4S HIGH RESOLUTION ISOLATED ANALOG MODULE (2) SRCG 4-20MA IN, (2) 4-20MA OUT, RCMND 1771-RT44 & 1771-NC6 OR NC15
    1771-NB4T HIGH RESOLUTION ISOLATED ANALOG MODULE (2) TC/MV IN, (2) 4-20MA OUT, RCMND 1771-RT41 & (1) 1771-NCG OR NC15
    1771-NBRC HIGH RESOLUTION ISOLATED ANALOG MODULE (6) RTD IN, (2) 4-20MA OUT, RCMND 1771-RTP4 & (2) 1771-NC6 OR NC15
    1771-NBSC HIGH RESOLUTION ISOLATED ANALOG MODULE (6) SRCNG 4-20MA IN, (2) 4-20MA OUT, RCMND 1771RTP4 & 2- 1771NC6, NC15
    1771-NBTC HIGH RESOLUTION ISOLATED ANALOG MODULE (6) TC/MV IN, (2) 4-20MA OUT, RCMND 1771-RTP1 & (2) 1771-NC6 OR NC15
    1771-NBV1 HIGH RESOLUTION ISOLATED ANALOG MODULE (6) +/- 10V IN, (2) +/- 10V OUT, RCMND 1771-RTP4 & 2- 1771-NC6 OR NC15
    1771-NBVC HIGH RESOLUTION ISOLATED ANALOG MODULE (6) +/-5V (4-20MA) IN, (2) 4-20MA OUT, RCMD 1771RTP3 & 2-1771NC6, NC15
    1771-NC15 HIGH RESOLUTION ISOLATED ANALOG SERIES CABLE 15FT/4.56M, CONNECTS N-SERIES ANALOG MDL. TO REMOTE TERMINATION PANEL
    1771-NC6 HIGH RESOLUTION ISOLATED ANALOG SERIES CABLE 6FT/1.82M, CONNECTS N-SERIES ANALOG MDL. TO REMOTE TERMINATION PANEL
    1771-NIS HIGH RESOLUTION ISOLATED ANALOG MODULE (8) SOURCING 4-20MA IN, RECOMMEND 1771-RTP4 & (2) 1771-NC65 OR NC15
    1771-NIV HIGH RESOLUTION ISOLATED ANALOG MODULE (8) +/- 5V (4-20MA) IN, RCMND 1771-RTP3 OR RTP4 & (2) 1771-NC6 OR NC15
    1771-NIV1 HIGH RESOLUTION ISOLATED ANALOG MODULE (8) +/- 10V IN, RECOMMEND 1771-RTP4 & (2) 1771-NC6 OR NC15
    1771-NIVR HIGH RESOLUTION ISOLATED ANALOG MODULE (4) +/-5V(4-20MA) IN, (4) RTD IN, RCMND 1771-RTP4 & (2) 1771-NC6, NC15
    1771-NIVT HIGH RESOLUTION ISOLATED ANALOG MODULE (4) +/-5V(4-20MA) IN, (4) TC/MV IN, RCMND 1771RTP1 & (2) 1771NC6, NC15
    1771-NOC HIGH RESOLUTION ISOLATED ANALOG MODULE (8) 4-20MA OUT, RECOMMEND 1771-RTP3 OR RTP4 & (2) 1771-NC6 OR NC15
    1771-NOV HIGH RESOLUTION ISOLATED ANALOG MODULE (8) +/- 10V OUT, RECOMMEND 1771-RTP3 OR RTP4 & (2) 1771-NC6 OR NC15
    1771-NR HIGH RESOLUTION ISOLATED ANALOG MODULE (8) RTD IN, RECOMMEND 1771-RTP4 & (2) 1771-NC6 OR NC15
    1771-NT1 HIGH RESOLUTION ISOLATED ANALOG MODULE (8) TC/MV IN, RECOMMEND 1771-RTP1 & (2) 1771-NC6 OR NC15
    1771-NT2 HIGH RESOLUTION ISOLATED ANALOG MODULE (8) TC/-5 TO +55 MV IN, RECOMMEND 1771-RTP1 & (2) 1771-NC6 OR NC15
    1771-OA 120V AC OUTPUT MODULE, 8 OUTPUTS
    1771-OAD 120V AC OUTPUT MODULE, 16 OUTPUTS
    1771-OADK CONFORMALLY COATED, 120V AC OUTPUT MODULE 16 OUTPUTS
    1771-OAN OUTPUT MODULE, 120V AC, 32 OUTPUTS
    1771-OB 12-24V DC OUTPUT MODULE, 8 OUTPUTS
    1771-OBD 10/60V DC OUTPUT MODULE, 16 OUTPUTS
    1771-OBDK CONFORMALLY COATED, 10-60V DC OUTPUT MODULE 16 OUTPUTS
    1771-OBDS CURRENT LIMITING OUTPUT MODULE, 10-20V DC
    1771-OBDSK CONFORMALLY COATED, CURRENT LIMITING OUTPUT MODULE 10-20V DC
    1771-OBN 10-30V DC HIGH-TRUE OUTPUT MODULE,32 OUTPUTS
    1771-OBNK CONFORMALLY COATED, HIGH-TRU OUTPUT MODULE 32 OUTPUTS, 10-30V DC
    1771-OC 48V DC OUTPUT MODULE, 8 OUTPUTS
    1771-OD 120V AC ISOLATED OUTPUT MODULE, 6 OUTPUTS
    1771-OD16 ISOLATED OUTPUT MODULE, 120V AC
    1771-OD16K CONFORMALLY COATED, 120V AC ISOLATED OUTPUT MODULE
    1771-ODD 120VAC ISOLATED OUTPUT MODULE, 16 OUTPUTS
    1771-ODDK CONFORMALLY COATED, 120V AC ISOLATED OUTPUT MODULE 16 OUTPUTS
    1771-ODK CONFORMALLY COATED, 120V AC ISOLATED OUTPUT MODULE 6 OUTPUTS
    1771-ODZ 120V AC OUTPUT MODULE (4 COMMONS)
    1771-OFE1 ANALOG OUTPUT MODULE 12 BIT, 4 DIFFERENTIAL, VOLTAGE OUTPUTS 1000V ISOLATION
    1771-OFE1K CONFORMALLY COATED, ANALOG OUTPUT MODULE 12 BIT, 4 DIFFERENTIAL, VOLTAGE OUTPUTS 1000V ISOLATION
    1771-OFE2 ANALOG OUTPUT MODULE 12 BIT, 4 DIFFERENTIAL, 1000V ISOLATION, 4 TO 20MA
    1771-OFE2K CONFORMALLY COATED, ANALOG OUPUT MODULE 12 BIT, 4 DIFFERENTIAL, 1000V ISOLATION, 4 TO 20MA
北京祥顺达恒有限公司主营产品:美国A-B,罗克韦尔,ALLEN-BRADLEY,ABB,丹佛斯,施耐德,变频器,PLC,压力变送器,温度变送器,SLC500,电磁阀,压力开关,触摸屏,伺服系统,PLC编程软件,组态软件,安全开关,软启动器,松下摄像头. …  更多>>
北京祥顺达恒商贸有限公司
联系人:薛晨
地址:北京市宣武区福长街四条4号213室
邮编:100055
电话:010-63388986
传真:010-51417964
公司网址:http://www.81817979.cn
  • 钟先生 在2015/9/11 11:55:00留言
  • 详细留言:EK2107/70/00/1/10轴位移传感器\EK2107/70/00/1/10\离心压缩机\3BCL459(美国ENTEK)
  • 王力 在2015/3/17 11:01:00留言
  • 邓成阳 在2013/8/21 15:38:00留言
  • 详细留言:您好,我是中科院沈阳计算技术研究所的 想购买AB的PLC CPU SLC500 1747-L543
  • Katrina Koh 在2013/3/12 14:35:00留言
  • 详细留言:Dear Sir/Madam Please quote us your best price for the following item :- (1) Prosoft Modbus Module Unit Model : MVI-94-MCM, REV : B03 Qty : 1 Your earliest reply will be most appreciated. Best Regards Katrina Koh Status Code Sdn Bhd 34A, Jalan Jaya Mas 2 Taman Jaya Mas 81300 Skudai Johor Bahru MALAYSIA Tel : 607-5113800 Fax : 607-5113808
  • clayton 在2012/4/17 18:01:00留言
  • 详细留言:5X 1753-L32BBBM8A 1X 1753-PCSPAR
