北京祥顺达恒商贸有限公司
  • A-B PLC8
  • 发布时间:2008/9/4 10:17:55   修改时间:2008/9/4 10:17:55 浏览次数:1072
  •   如需了解相关信息咨询      薛晨:13801020197
    1747-L40E 40 I/O FIXED HARDWARE STYLE (24) DC SINK IN W/HSC & (16) XTER SRC OUT, AC LINE PWR
    1747-L40F 40 I/O FIXED HARDWARE STYLE (24) DC SINK IN W/HSC & (16) RELAY OUT, DC LINE PWR
    1747-L511 SLC 5/01 CONTROLLER, 1K MEMORY - DH 485
    1747-L514 SLC 5/01 CONTROLLER, 4K MEMORY - DH 485
    1747-L524 SLC 5/02 CONTROLLER, 4K MEMORY - DH 485
    1747-L531 SLC 5/03,WITH 8K USER INSTRUCTION CAPACITY
    1747-L532 SLC 5/03 CONTROLLER, 16K MEMORY DH 485 AND (RS 232 OR DH 485)
    1747-L541 SLC 5/04 CONTROLLER, 16K MEMORY DH+ AND (RS 232 OR DH 485)
    1747-L542 SLC 5/04 CONTROLLER, 32K MEMORY DH+ AND (RS 232 OR DH 485)
    1747-L542P PRO-SET 200 - 5/04 - 32K
    1747-L543 SLC 5/04 CONTROLLER, 64K MEMORY DH+ AND (RS 232 OR DH 485)
    1747-L543P PRO-SET 200 - 5/04 - 64K
    1747-L551 SLC 5/05 CONTROLLER, 16K 16K MEMORY, ETHERNET/IP  PROCESSOR
    1747-L552 SLC 5/05 CONTROLLER, 32K 32K MEMORY, ETHERNET/IP  PROCESSOR
    1747-L553 SLC 5/05 CONTROLLER 64K 64K MEMORY, ETHERNET/IP PROCESSOR
    1747-L553P PRO-SET 200 - 5/05 - 64K
    1747-M1 EEPROM MEMORY MODULE, 1K FOR PROGRAMMABLE CTRLR
    1747-M13 EEPROM MEMORY MODULE, 64K FOR PROGRAMMABLE CTRLR USE WITH SER C - OS ONLY
    1747-M15 EEPROM MEMORY MODULE ADAPTER FOR 1747-M11, -M12
    1747-M2 EEPROM MEMORY, 4K FOR PROGRAMMABLE CONTROLLER
    1747-M5 ADAPTER SOCKET - FIVE SOCKETS PER PACKAGE MUST BE ORDERED AS A SINGLE PKG OF (5); LIST PRICE IS PRICE PER SOCKET
    1747-MNET MODULE,INTERFACE         FOR PRGRMMABLE CONTROLLER
    1747-NP1 WALL MOUNTED POWER SUPPLY (120V AC INPUT) 2.5 WATT MAX.
    1747-OS302 SLC 5/03 UPGRADE KIT
    1747-OS401 SLC 5/04 UPGRADE KIT
    1747-PBASE BASIC DEVELOPMENT SOFTWARE SUPPORT 1746-BAS & 1771-DB/B
    1747-PIC CONVERTER RS 232/DH 485
    1747-PSD PROGRAM STORAGE DEVICE-SLC 5/03 THRU 5/05 AND MICROLOGIX 1000,1200 AND 1500
    1747-PTA1E MEMORY PAK - ENGLISH
    1747-RL302 SLC 5/03 UPGRADE KIT LABELS
    1747-RL401 SLC 5/04 UPGRADE KIT LABELS
    1747-RL501 5/05 UPGRADE KIT LABELS
    1747-SCNR CONTROLNET SCANNER FOR SLC PLATFORM
    1747-SDN DEVICENET SCANNER MODULE
    1747-SN REMOTE I/O SCANNER MODULE
    1747-UIC CONVERTER USB/DH-485
    1747-UICC13 1747-UIC USB TO DH-485 CNV. AND 1747-C13 CABLE
    1751-SL4SP SYNCHLINK FIBER 4-PORT SPLITTER BLOCK
    1751-SLBA SYNCHLINK FIBER BASE BLOCK
    1751-SLBP SYNCHLINK FIBER BYPASS SWITCH BLOCK
    1753-CBLDN DEVICENET SAFETY SCANNER CABLE - REPLACEMENT CABLE TO CONNECT GUARDPLC 1600/1800 TO DNET SAFETY SCANNER
    1753-CFBBASIC GUARDPLC CERTIFIED FUNCTION BLOCKS - BASIC SUITE
    1753-DNSI DEVICENET SAFETY SCANNER FOR GUARDPLC GUARDPLC 1600 AND 1800 ONLY
    1753-HHT HAND-HELD TERMINAL FOR GUARDPLC CONTROLLER PROGRAM UPLOAD, DOWNLOAD, AND DIO COMMISSIONING
    1753-IB16 GUARDPLC DISTRIBUTED I/O - 16 IN, GUARDPLC ENET 16 DIGITAL INPUTS, 4 PULSE TEST SOURCES, GUARDPLC ETHERNET
    1753-IB16XOB8 GUARDPLC DISTRIBUTED I/O, 24 I/O, GUARDPLC ENET 16 DIGITAL INPUTS, 8 DIGITAL OUTPUTS, GUARDPLC ETHERNET
    1753-IB20XOB8 GUARDPLC DISTRIBUTED I/O -  28 I/O, GUARDPLC ENET 20 DIGITAL INPUTS, 8 DIGITAL OUPUTS, GUARDPLC ETHERNET
    1753-IB8XOB8 GUARDPLC DISTRIBUTED I/O - 16 I/O, GUARDPLC ENET 8 DIGITAL INPUTS, 8 DIGITAL OUTPUTS, GUARDPLC ETHERNET
    1753-IF8XOF4 GUARDPLC DISTIBUTED I/O, 12 I/O, GUARDPLC ENET 8 SAFE ANALOG INPUTS, 4 STANDARD ANALOG OUTPUTS, GUARDPLC ETHERNET
    1753-L28BBBM GUARDPLC 1600 - SAFETY PLC W/MODBUS, 28 I/O 20 DIGITAL INPUTS, 8 DIGITAL OUTPUTS, MODBUS RTU SLAVE
    1753-L28BBBP GUARDPLC 1600 - SAFETY PLC W/PROFIBUS, 28 I/O 20 DIGITAL INPUTS, 8 DIGITAL OUTPUTS, PROFIBUS DP SLAVE
    1753-L32BBBM8A GUARDPLC 1800 - SAFETY PLC W/ MODBUS, 32 I/O 24 DIGITAL IN, 8 DIGITAL OUT, 8 ANALOG IN, 2 HSC, MODBUS RTU SLAVE
    1753-L32BBBP8A GUARDPLC 1800 - SAFETY PLC W/ PROFIBUS, 32 I/O 24 DIGITAL IN, 8 DIGITAL OUT, 8 ANALOG IN, 2 HSC, PROFIBUS DP SLAVE
    1753-OB16 GUARDPLC DISTRIBUTED I/O - 16 OUT, GUARDPLC ENET 16 DIGITAL OUTPUTS, GUARDPLC ETHERNET
    1753-OPC GUARDPLC OPC SERVER
    1753-OW8 GUARDPLC DISTRIBUTED I/O, 8 OUT, GUARDPLC ENET 8 RELAY OUTPUTS, GUARDPLC ETHERNET
    1753-PCSPAR RSLOGIX GUARD PLUS FOR GUARDPLC -PARALLEL HARDLOCK
    1753-PCSUSB RSLOGIX GUARD PLUS FOR GUARDPLC - USB HARDLOCK
    1753-START1600 STARTER KIT OF GUARDPLC 1600 & RSLOGIX GUARD PLUS
    1754-BAT REPLACEMENT BATTERY FOR GUARDPLC 1200
    1754-L28BBB GUARDPLC 1200 - PACKAGED SAFETY CONTROLLER, 28 I/O 20 DIGITAL INPUTS, 8 DIGITAL OUTPUTS, HIGH SPEED COUNTER
    1755-A6 GUARDPLC 2000 - 6 SLOT CHASSIS GUARDPLC 2000 I/O RACK
    1755-BAT REPLACEMENT BATTERY FOR GUARDPLC 2000 CPU
    1755-HSC GUARDPLC 2000 - HIGH SPEED COUNTER MODULE GUARDPLC 2000 COUNTER MODULE
    1755-IB24XOB16 GUARDPLC 2000 - DIGITAL I/O MODULE 24 DIGITAL INPUTS / 16 DIGITAL OUTPUTS COMBINATION MODULE
    1755-IF8 GUARDPLC 2000 - ANALOG INPUT MODULE 8 ANALOG INPUTS
    1755-L1 GUARDPLC 2000 - MODULAR SAFETY PROCESSOR
    1755-N2 GUARDPLC 2000- CHASSIS SLOT FILLER SLOT FILLER FOR GUARDPLC 2000 SIX SLOT CHASSIS
    1755-OF8 GUARDPLC 2000 - ANALOG OUTPUT MODULE 8 ANALOG OUTPUTS
    1755-PB720 GUARDPLC 2000 - POWER SUPPLY, 20.4-28.8 VDC GUARDPLC 2000 POWER SUPPLY
    1756-A10 10 SLOT CONTROLLOGIX CHASSIS
    1756-A13 13 SLOT CONTROLLOGIX CHASSIS
    1756-A17 17 SLOT CONTROLLOGIX CHASSIS
    1756-A4 4 SLOT CONTROLLOGIX CHASSIS
    1756-A7 7 SLOT CONTROLLOGIX CHASSIS
    1756-BA1 LOGIX5000 BATTERY ASSEMBLY
    1756-BA2 LOGIX5000 BATTERY ASSEMBLY-1756-L6X SERIES B ONLY
    1756-BATA REPLACEMENT BATTERY ASSEMBLY FOR 1756-BATM
    1756-BATM CONTROLLOGIX BATTERY MODULE
    1756-CFM 2 CHANNEL/2 OUT CONFIGURABLE FLOWMETER (20PIN)
    1756-CN2 CONTROLNET 2X CAPACITY BRIDGE MODULE NOTE: NOT COMPATIBLE WITH CONTROLLOGIX REDUNDANCY - USE 1756-CNB/D
    1756-CN2R CONTROLNET 2X CAPACITY BRIDGE MOD REDUNDANT MEDIA NOTE: NOT COMPATIBLE WITH CONTROLLOGIX REDUNDANCY - USE 1756-CNB/D
    1756-CNB CONTROLNET BRIDGE MODULE
    1756-CNBR CONTROLNET BRIDGE MODULE - REDUNDANT MEDIA
    1756-CP3 LOGIX5000 RS232 PROGRAMMER CABLE
    1756-CPR2 REDUNDANT POWER SUPPLY CABLE
    1756-DH485 CONTROLLOGIX DH485 COMMUNICATION MODULE
    1756-DHRIO DH+/RIO BRIDGE/SCANNER MODULE 2 CHANNEL DH+ AND/OR RIO SCANNER
    1756-DMD30 1-AXIS DRV CTRL RE SD30001-AXIS DRV CTRL RE SD3000
    1756-DMF30 1-AXIS DRV CTRL RE SF30001-AXIS DRV CTRL RE SF3000
    1756-DNB DEVICENET BRIDGE/SCANNER MODULE
    1756-DPALEN CONTROLLOGIX SYSTEM DOCUMENTATION SET PRINTED
    1756-ENBT CLX ETHERNET/IP 10/100 BRIDGE MODULE - TWISTED PR
    1756-EWEB CLX ENET/IP ENHANCED WEB SERVER MODULE
    1756-HSC 2 CHANNEL / 4 OUTPUT HIGH SPEED COUNTER (36 PIN)
    1756-HYD02 2 CHANNEL LDT HYDRAULICS MODULE (36 PIN)
    1756-IA16 79-132 VAC INPUT  16 PTS (20 PIN)
    1756-IA16I 79-132 VAC ISOLATED INPUT  16 PTS (36 PIN)
    1756-IA32 74-132 VAC INPUT 32 PTS (36P)
    1756-IA8D 79-132 VAC DIAGNOSTIC INPUT  8 PTS (20 PIN)
    1756-IB16 10-31 VDC INPUT 16 PTS (20 PIN)
    1756-IB16D 10-30 VDC DIAGNOSTIC INPUT  16 PTS (36 PIN)
    1756-IB16I 10-30 VDC ISOLATED INPUT  16 PTS (36 PIN)
    1756-IB16ISOE 24/48VDC ISO SEQUENCE OF EVENT INPUT 16PT (36 PIN)
    1756-IB32 10-31 VDC INPUT 32 PTS (36 PIN)
    1756-IC16 30-60 VDC INPUT  16 PTS (20 PIN)
    1756-IF16 ANALOG INPUT - CURRENT/VOLTAGE  16 PTS (36 PIN)
    1756-IF4FXOF2F FAST ANALOG 4 CUR-VOLT IN/2 CUR-VOLT OUT (36 PIN)
    1756-IF6CIS ISOLATED ANALOG IN-CURRENT SOURCING 6 PTS (20 PIN)
    1756-IF6I ISOLATED ANALOG INPUT-CURRENT/VOLTAGE 6 PTS(20PIN)
    1756-IF8 ANALOG INPUT - CURRENT/VOLTAGE 8 PTS (36 PIN)
    1756-IG16 0-5 VDC TTL INPUT (LOW TRUE) 16 PTS (20 PIN)
    1756-IH16I 90-146 VDC ISOLATED INPUT  16 PTS (36 PIN)
    1756-IH16ISOE 125 VDC ISOL SEQUENCE OF EVENT INPUT 16PT (36 PIN)
    1756-IM16I 159-265 VAC ISOLATED INPUT  16 PTS (36 PIN)
    1756-IN16 10-30 VAC INPUT 16 PTS (20 PIN)
    1756-IR6I ISOLATED RTD INPUT  6 PTS (20 PIN)
    1756-IT6I ISOLATED THERMOCOUPLE/MV INPUT  6 PTS (20 PIN)
    1756-IT6I2 ENHANCED ISOL THERMOCOUPLE/MV INPUT 6PTS (20 PIN)
    1756-IV16 10-30 VDC SOURCING INPUT 16 PTS (20 PIN)
    1756-IV32 10-30 VDC SOURCING INPUT 32 PTS (36 PIN)
    1756-JMPR REPLACEMENT JUMPER BARS FOR 36 PIN RTB (QTY 25)
    1756-L55 LOGIX5555 PROCESSOR WITH NO USER MEMORY
    1756-L55M12 LOGIX5555  PROCESSOR WITH 750KBYTE MEMORY
    1756-L55M13 LOGIX5555 PROCESSOR WITH 1.5MBYTE MEMORY
    1756-L55M14 LOGIX5555 PROCESSOR WITH 3.5MBYTE MEMORY
    1756-L55M16 LOGIX5555 PROCESSOR WITH 7.5MBYTE MEMORY
    1756-L55M22 LOGIX5555 PROCESSOR WITH 750KBYTE NV MEMORY
    1756-L55M23 LOGIX5555 PROCESSOR WITH 1.5MBYTE NV MEMORY
    1756-L55M24 LOGIX5555 PROCESSOR WITH 3.5MBYTE NV MEMORY
    1756-L60M03SE LOGIX5560M03SE WITH SERCOS 3-AXIS 750KBYTES MEMORY
    1756-L61 LOGIX5561 PROCESSOR WITH 2MBYTE MEMORY
    1756-L61S GUARDLOGIX SAFETY PRIMARY, 2M STD/1M SAFETY LOGIC
    1756-L62 LOGIX5562 PROCESSOR WITH 4MBYTE MEMORY
    1756-L62S GUARDLOGIX SAFETY PRIMARY, 4M STD/1M SAFETY LOGIC
    1756-L63 LOGIX5563 PROCESSOR WITH 8MBYTE MEMORY
    1756-LSP GUARDLOGIX SAFETY PARTNER
    1756-M02AE 2-AX SERVO,ANALOG/ENC-ICP
    1756-M02AS 1756 2 AXIS ANALOG/SSI SERVO MODULE
    1756-M03SE 1756 3 AXIS SERCOS INTERFACE SERVO MODULE
    1756-M08SE 1756 8 AXIS SERCOS SERVO MODULE
    1756-M12 LOGIX5555 750K MEMORY MODULE
    1756-M13 LOGIX5555 1.5MBYTE MEMORY MODULE
    1756-M14 LOGIX5555 3.5MBYTE MEMORY MODULE
    1756-M16 LOGIX5555 7.5MBYTE MEMORY MODULE
    1756-M16SE 1756 16 AXIS SERCOS SERVO MODULE
    1756-M22 LOGIX5555 750K NV MEMORY MODULE
    1756-M23 LOGIX5555 1.5MBYTE NONVOLATILE MEMORY
    1756-M24 LOGIX5555 3.5MBYTE NONVOLATILE MEMORY
    1756-N2 EMPTY SLOT FILLER CARD (ONE FILLER PER PACKAGE)
    1756-OA16 74-265 VAC OUTPUT  16 PTS (20 PIN)
    1756-OA16I 74-265 VAC ISOLATED OUTPUT  16 PTS (36 PIN)
    1756-OA8 74-265 VAC 2 AMP OUTPUT 8 PTS (20 PIN)
    1756-OA8D 74-132 VAC DIAGNOSTIC OUTPUT 8 PTS (20 PIN)
    1756-OA8E 74-132 VAC ELEC FUSED 2A OUTPUT 8 PTS (20 PIN)
    1756-OB16D 19-30 VDC DIAGNOSTIC OUTPUT  16 PTS (36 PIN)
    1756-OB16E 10-31 VDC ELEC FUSED OUTPUT  16 PTS (20 PIN)
    1756-OB16I 10-30 VDC ISOLATED OUTPUT  16 PTS (36 PIN)
    1756-OB16IS 10-30VDC ISOLATED OUTPUT CAM 16 PTS (36 PIN)
    1756-OB32 10-31 VDC OUTPUT 32 PTS (36 PIN)
    1756-OB8 10-30 VDC 2 AMP OUTPUT 8 PTS (20 PIN)
    1756-OB8EI 10-30 VDC ISOLATED ELEC FUSED OUTPUT 8PTS (36 PIN)
    1756-OB8I 10-30 VDC 2 AMP ISOLATED OUTPUT 8PTS (36 PIN)
    1756-OC8 30-60 VDC 2 AMP OUTPUT 8 PTS (20 PIN)
    1756-OF4 ANALOG OUTPUT - CURRENT/VOLTAGE 4 PTS (20 PIN)
    1756-OF6CI ISOLATED ANALOG OUTPUT - CURRENT 6 PTS (20 PIN)
    1756-OF6VI ISOLATED ANALOG OUTPUT - VOLTAGE 6 PTS (20 PIN)
    1756-OF8 ANALOG OUTPUT - CURRENT/VOLTAGE 8 PTS (20 PIN)
    1756-OG16 0-5 VDC TTL OUTPUT (LOW TRUE) 16 PTS (20 PIN)
    1756-OH8I 90-146 VDC ISOLATED 2 AMP OUTPUT 8 PTS (36 PIN)
    1756-ON8 10-30 VAC 2 AMP OUTPUT 8 PTS (20 PIN)
    1756-OV16E 10-30 VDC ELEC FUSED SINKING OUTPUT 16 PT (20 PIN)
    1756-OV32E 10-30 VDC ELEC FUSED SINKING OUTPUT 32 PT (36 PIN)
    1756-OW16I N.O. ISOLATED RELAY OUTPUT 16 PTS (36 PIN)
    1756-OX8I N.O./N.C. ISOLATED RELAY OUTPUT 8 PTS (36 PIN)
    1756-PA72 85-265 VAC POWER SUPPLY (5V @ 10 AMP)
    1756-PA75 85-265V AC POWER SUPPLY (5V @ 13 AMP)
    1756-PA75R 85-265VAC REDUNDANT POWER SUPPLY
    1756-PAR2 85-265VAC REDUNDANT POWER SUPPLY ASSEMBLY
    1756-PB72 18 - 32 VDC POWER SUPPLY (5V @ 10 AMP)
    1756-PB75 18 - 32V DC POWER SUPPLY (5V @ 13A)
    1756-PB75R 19-32VDC REDUNDANT POWER SUPPLY
    1756-PBR2 19-32VDC REDUNDANT POWER SUPPLY ASSEMBLY
    1756-PC75 30-60VDC POWER SUPPLY (5V @ 13A)
    1756-PH75 90-143VDC POWER SUPPLY (5V @ 13A)
    1756-PLS PROGRAMMABLE LIMIT SWITCH MODULE (3-20 PIN)
    1756-PSCA2 REDUNDANT POWER SUPPLY CHASSIS ADAPTER MODULE
    1756-STRT4 CONTROLLOGIX STARTER KIT - L61 BASED
    1756-SYNCH CONTROLLOGIX SYNCHLINK MODULE
    1756-TBCH 36 PIN SCREW CLAMP BLOCK WITH STANDARD HOUSING
    1756-TBE EXTENDED DEPTH TERMINAL BLOCK HOUSING
    1756-TBNH 20 POSITION NEMA SCREW CLAMP BLOCK WITH STANDARD HOUSING
    1756-TBS6H 36 PIN SPRING CLAMP BLOCK WITH STANDARD HOUSING
    1756-TBSH 20 PIN SPRING CLAMP BLOCK WITH STANDARD HOUSING
    1756-TC15 1756 ETHERNET INTERFACE TRANSCEIVER CABLE 15 METER (49.2 FT)
    1757-ABRIO PROCESS RIO SCANNER MODULE
    1757-BEM BATTERY EXTENSION MODULE
    1757-DNBEXP02 DEVICENET MODULE EXPANSION, 1-2 MAX
    1757-DNBEXP03 DEVICENET MODULE EXPANSION, 2-3 MAX
    1757-DNBEXP05 DEVICENET MODULE EXPANSION, 3-5 MAX
    1757-DNBEXP10 DEVICENET MODULE EXPANSION, 5-10 MAX
    1757-DNBEXP100 DEVICENET MODULE EXPANSION, 80-100 MAX
    1757-DNBEXP20 DEVICENET MODULE EXPANSION, 10-20 MAX
    1757-DNBEXP35 DEVICENET MODULE EXPANSION, 20-35 MAX
    1757-DNBEXP50 DEVICENET MODULE EXPANSION, 35-50 MAX
    1757-DNBEXP65 DEVICENET MODULE EXPANSION, 50-65 MAX
    1757-DNBEXP80 DEVICENET MODULE EXPANSION, 65-80 MAX
    1757-DNBUL01 DEVICENET USAGE LICENSE, 1 DNB MAX
    1757-DNBUL02 DEVICENET USAGE LICENSE, 2 DNB MAX
    1757-DNBUL03 DEVICENET USAGE LICENSE, 3 DNB MAX
    1757-DNBUL05 DEVICENET USAGE LICENSE, 5 DNB MAX
    1757-DNBUL10 DEVICENET USAGE LICENSE, 10 DNB MAX
    1757-DNBUL100 DEVICENET USAGE LICENSE, 100 DNB MAX
    1757-DNBUL20 DEVICENET USAGE LICENSE, 20 DNB MAX
    1757-DNBUL35 DEVICENET USAGE LICENSE, 35 DNB MAX
    1757-DNBUL50 DEVICENET USAGE LICENSE, 50 DNB MAX
    1757-DNBUL65 DEVICENET USAGE LICENSE, 65 DNB MAX
    1757-DNBUL80 DEVICENET USAGE LICENSE, 80 DNB MAX
    1757-DNBUPG01 DEVICENET LIC UPG 1 DNB ONE RELEASE LEVEL
    1757-DNBUPG02 DEVICENET LIC UPG 2 DNB ONE RELEASE LEVEL
    1757-DNBUPG03 DEVICENET LIC UPG 3 DNB ONE RELEASE LEVEL
    1757-DNBUPG05 DEVICENET LIC UPG 5 DNB ONE RELEASE LEVEL
    1757-DNBUPG10 DEVICENET LIC UPG 10 DNB ONE RELEASE LEVEL
    1757-DNBUPG100 DEVICENET LIC UPG 100 DNB ONE RELEASE LEVEL
    1757-DNBUPG20 DEVICENET LIC UPG 20 DNB ONE RELEASE LEVEL
    1757-DNBUPG35 DEVICENET LIC UPG 35 DNB ONE RELEASE LEVEL
    1757-DNBUPG50 DEVICENET LIC UPG 50 DNBS ONE RELEASE LEVEL
    1757-DNBUPG65 DEVICENET LIC UPG 65 DNBS ONE RELEASE LEVEL
    1757-DNBUPG80 DEVICENET LIC UPG 80 DNBS ONE RELEASE LEVEL
    1757-FFLD2 2 H1 / HSE FOUNDATION FIELDBUS LINKING DEVICE
    1757-FFLD4 4 H1 / HSE FOUNDATION FIELDBUS LINKING DEVICE
    1757-FIM FIELDBUS INTERFACE MODULE
    1757-FIMC5 FIELDBUS INTERFACE CABLE - 5 - METERS
    1757-FIMEXP010 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 5 TO 10 MAX
    1757-FIMEXP020 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 10 TO 20 MAX
    1757-FIMEXP035 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 20 TO 35 MAX
    1757-FIMEXP050 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 35 TO 50 MAX
    1757-FIMEXP065 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 50 TO 65 MAX
    1757-FIMEXP080 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 65 TO 80 MAX
    1757-FIMEXP100 FOUNDATION FIELDBUS FIM MODULE EXPANSION FROM 80 TO 100 MAX
    1757-FIMRTP FIELDBUS INTERFACE MODULE REMOTE TERMINATION PANEL
    1757-FIMRTPBASE FIELDBUS INTERFACE RTP BASE
    1757-FIMUL005 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 5 MAX
    1757-FIMUL010 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 10 MAX
    1757-FIMUL020 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 20 MAX
    1757-FIMUL035 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 35 MAX
    1757-FIMUL050 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 50 MAX
    1757-FIMUL065 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 65 MAX
    1757-FIMUL080 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 80 MAX
    1757-FIMUL100 FOUNDATION FIELDBUS FIM MODULE USAGE LICENSE UP TO 100 MAX
    1757-FIMUPG005 FIELDBUS LICENSE UPGRADE, 5 FIMS ONE RELEASE LEVEL
    1757-FIMUPG010 FIELDBUS LICENSE UPGRADE, 10 FIMS ONE RELEASE LEVEL
    1757-FIMUPG020 FIELDBUS LICENSE UPGRADE, 20 FIMS ONE RELEASE LEVEL
    1757-FIMUPG035 FIELDBUS LICENSE UPGRADE, 35 FIMS ONE RELEASE LEVEL
    1757-FIMUPG050 FIELDBUS LICENSE UPGRADE, 50 FIMS ONE RELEASE LEVEL
    1757-FIMUPG065 FIELDBUS LICENSE UPGRADE, 65 FIMS ONE RELEASE LEVEL
    1757-FIMUPG080 FIELDBUS LICENSE UPGRADE, 80 FIMS ONE RELEASE LEVEL
    1757-FIMUPG100 FIELDBUS LICENSE UPGRADE, 100 FIMS ONE RELEASE LEVEL
    1757-PE1400RED1 PLX PRIMARY SERVER ON DELL PE1400
    1757-PE1400RED2 PLX BACKUP SERVER ON DELL PE1400
    1757-PE1600RED1 PROCESSLOGIX PRIMARY SERVER ON DELL PE1600 (FOR REDUNDANT SERVER CONFIGURATION)
    1757-PE1600RED2 PROCESSLOGIX BACKUP SERVER ON DELL PE1600 (FOR REDUNDANT SERVER CONFIGURATION)
    1757-PE1800RED1 PROCESSLOGIX PRIMARY SERVER ON DELL PE 1800
    1757-PE1800RED2 PROCESSLOGIX BACKUP SERVER ON DELL PE 1800
    1757-PFBEXP002 PROFIBUS INTERFACE MODULE EXPANSION FROM 1 TO 2 MAX
    1757-PFBEXP003 PROFIBUS INTERFACE MODULE EXPANSION FROM 2 TO 3 MAX
    1757-PFBEXP005 PROFIBUS INTERFACE MODULE EXPANSION FROM 3 TO 5 MAX
    1757-PFBEXP010 PROFIBUS INTERFACE MODULE EXPANSION FROM 5 TO 10 MAX
    1757-PFBEXP020 PROFIBUS INTERFACE MODULE EXPANSION FROM 10 TO 20 MAX
    1757-PFBEXP035 PROFIBUS INTERFACE MODULE EXPANSION FROM 20 TO 35 MAX
    1757-PFBEXP050 PROFIBUS INTERFACE MODULE EXPANSION FROM 35 TO 50 MAX
    1757-PFBEXP065 PROFIBUS INTERFACE MODULE EXPANSION FROM 50 TO 65 MAX
    1757-PFBEXP080 PROFIBUS INTERFACE MODULE EXPANSION FROM 65 TO 80 MAX
    1757-PFBEXP100 PROFIBUS INTERFACE MODULE EXPANSION FROM 80 TO 100 MAX
    1757-PFBUL001 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 1 MAX
    1757-PFBUL002 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 2 MAX
    1757-PFBUL003 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 3 MAX
    1757-PFBUL005 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 5 MAX
    1757-PFBUL010 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 10 MAX
    1757-PFBUL020 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 20 MAX
    1757-PFBUL035 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 35 MAX
    1757-PFBUL050 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 50 MAX
    1757-PFBUL065 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 65 MAX
    1757-PFBUL080 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 80 MAX
    1757-PFBUL100 PROFIBUS INTERFACE MODULE USAGE LICENSE UP TO 100 MAX
    1757-PFBUPG001 PROFIBUS LIC UPG 1 IOM ONE RELEASE LEVEL
    1757-PFBUPG002 PROFIBUS LIC UPG 2 IOMS ONE RELEASE LEVEL
    1757-PFBUPG003 PROFIBUS LIC UPG 3 IOMS ONE RELEASE LEVEL
    1757-PFBUPG005 PROFIBUS LIC UPG 5 IOMS ONE RELEASE LEVEL
    1757-PFBUPG010 PROFIBUS LIC UPG 10 IOMS ONE RELEASE LEVEL
    1757-PFBUPG020 PROFIBUS LIC UPG 20 IOMS ONE RELEASE LEVEL
    1757-PFBUPG035 PROFIBUS LIC UPG 35 IOMS ONE RELEASE LEVEL
    1757-PFBUPG050 PROFIBUS LIC UPG 50 IOMS ONE RELEASE LEVEL
    1757-PFBUPG065 PROFIBUS LIC UPG 65 IOMS ONE RELEASE LEVEL
    1757-PFBUPG080 PROFIBUS LIC UPG 80 IOMS ONE RELEASE LEVEL
    1757-PFBUPG100 PROFIBUS LIC UPG 100 IOMS ONE RELEASE LEVEL
    1757-PIM PULSE INPUT MODULE
    1757-PLX52 PROCESSLOGIX CPU
    1757-PLXBAT PLX  CPU REPLACEMENT BATTERY
    1757-PLXCGX200 DELL PROCESSLOGIX SERVER
    1757-PLXCLNTCB CLIENT CONTROLBUILDER
    1757-PLXCPE1400 PROCESSLOGIX SERVER ON DELL PE1400
    1757-PLXCPE1600 PROCESSLOGIX SERVER DELL PE 1600
    1757-PLXCPE1800 PROCESSLOGIX SERVER DELL PE 1800
    1757-PLXMULTISTA PROCESSLOGIX MULTI STATION OPTION
    1757-PLXNA RECIPE MANAGER FOR PROCESSLOGIX
    1757-PLXNB POINT CONTROL SCHEDULER FOR PROCESSLOGIX
    1757-PLXND PLX ODBC DATA EXCHANGE
    1757-PLXNG PLX SERVER BATCH REPORT OPTION
    1757-PLXNS EXTENDED EVENT ARCHIVING FOR PROCESSLOGIX
    1757-PLXNT ALARM PAGER FOR PROCESSLOGIX
    1757-PLXNU OPEN DATA ACCESS - 1 USER FOR PROCESSLOGIX
    1757-PLXNV OPEN DATA ACCESS - 5 USER FOR PROCESSLOGIX
    1757-PLXNW OPEN DATA ACCESS - 10 USER FOR PROCESSLOGIX
    1757-PLXNX APPLICATION TOOLKIT FOR PROCESSLOGIX
    1757-PLXRT01 PROCESSLOGIX 1 USER REMOTE OPERATOR INTERFACE LICENSE EXTENSION
    1757-PLXRT05 PROCESSLOGIX 5 USER REMOTE OPERATOR INTERFACE LICENSE EXTENSION
    1757-PLXRT10 PROCESSLOGIX 10 USER REMOTE OPERATOR INTERFACE LICENSE EXTENSION
    1757-PLXS100 PROCESSLOGIX 100 POINT SERVER LICENSE
    1757-PLXS300 PROCESSLOGIX 300 POINT SERVER LICENSE
    1757-PLXS50 PROCESSLOGIX 50 POINT SERVER LICENSE
    1757-PLXSIFA PLX AB INTEGRATION QUICKBUILDER INTERFACE
    1757-PLXSIFC AB RSLINX QUICKBUILDER INTERFACE
    1757-PLXSIFD PLX HW S9000 ETHERNET QUICKBUILDER INTERFACE
    1757-PLXSIFE PLX HW 620 LCS SERIAL & ETHERNET QUICKBUILDER I/F
    1757-PLXSIFF PLX HW TDC3000 DATA HIWAY QUICKBUILDER INTERFACE
    1757-PLXSIFG PLX HW UDC 3000/5000/6300 QUICKBUILDER INTERFACE
    1757-PLXSIFH PLX HW MICROMAX LPU QUICKBUILDER INTERFACE
    1757-PLXSIFI PLX HW XLNET HVAC CONTROLLER QUICKBUILDER INTERFAC
    1757-PLXSIFJ PLX HW XLNET NETWORK NODE QUICKBUILDER INTERFACE
    1757-PLXSIFK PLX GE FAUNC SERIES 90 VIA ENET QUICKBUILDER I/F
    1757-PLXSIFL PLX GE API LICENSE QUICKBUILDER INTERFACE
    1757-PLXSIFM PLX GEC GEM80 PLC QUICKBUILDER INTERFACE
    1757-PLXSIFN PLX MODICON PLC, MODBUS RTU QUICKBUILDER INTERFACE
    1757-PLXSIFO MOORE APACS QUICKBUILDER INTERFACE
    1757-PLXSIFP PLX MOORE 351,352,353,383 QUICKBUILDER INTERFACE
    1757-PLXSIFQ PLX SIEMENS S5 & TI PLC VIA H1/TF QUICKBUILDER I/F
    1757-PLXSIFR PLX HITACHI QUICKBUILDER INTERFACE
    1757-PLXSIFS PLX BRISTOL BABCOCK RTU QUICKBUILDER INTERFACE
    1757-PLXSIFV ASEA CONTROLLER QUICKBUILDER INTERFACE
    1757-PLXSIFW PLX MA500 QUICKBUILDER INTERFACE
    1757-PLXSIFY PLX DPR RECORDERS QUICKBUILDER INTERFACE
    1757-PLXSIFZ PLX RM7800 FLAME SFEGRD QUICKBUILDER INTERFACE
    1757-PLXSIFZA PLX APPLICON QUICKBUILDER INTERFACE
    1757-PLXSIFZB PLX FSC SERIAL MODBUS QUICKBUILDER INTERFACE
    1757-PLXSIFZD PLX OPC SERVER CLIENT QUICKBUILDER INTERFACE
    1757-PLXSIFZE UNIVERSAL MODBUS QUICKBUILDER INTERFACE
    1757-PLXSIFZF BAILEY INFI90 QUICKBUILDER INTERFACE
    1757-PLXSR100 PLX 100 POINT REDUNDANT SERVER LICENSE
    1757-PLXSR300 PLX 300 POINT REDUNDANT SERVER LICENSE
    1757-PLXSR50 PLX 50 POINT REDUNDANT SERVER LICENSE
    1757-PLXSRU100 PLX REDUNDANT SERVER 50 TO 100 POINT EXPANSION WITHIN THE SAME MAJOR RELEASE LEVEL
    1757-PLXSRU300 PLX REDUNDANT SERVER 100 TO 300 POINT EXPANSION WITHIN THE SAME MAJOR RELEASE LEVEL
    1757-PLXSU100 PLX SERVER 50 TO 100 POINT EXPANSION WITHIN THE SAME MAJOR RELEASE LEVEL
    1757-PLXSU300 PLX SERVER 100 TO 300 POINT EXPANSION WITHIN THE SAME MAJOR RELEASE LEVEL
    1757-PROCESSLINX PROCESSLINX OPC SERVER TO OPC SERVER COMM SOFTWARE
    1757-REDPLXOPC REDUNDANT PROCESSLOGIX OPC SERVER
    1757-SRC1 1757 REDUNDANCY MODULE CABLE - 1 METER,  3.28FT
    1757-SRC10 1757 REDUNDANCY MODULE CABLE - 10 METER, 32.81 FT
    1757-SRC3 1757 REDUNANCY MODULE CABLE - 3 METER, 9.84 FT
    1757-SRM SYSTEM REDUNDANCY MODULE
    1757-SWKIT5000 PROCESSLOGIX SOFTWARE KIT RELEASE 500
    1757-SWKIT5100 PROCESSLOGIX SOFTWARE KIT RELEASE 510
    1757-UPGCLNTCB CLIENT CONTROLBUILDER UPGRADE ONE MAJOR RELEASE
    1757-UPGNA UPGRADE RECIPE MANAGER ONE MAJOR RELEASE LEVEL
    1757-UPGNB UPGRADE POINT CNTRL SCHEDULER ONE MAJOR RELEASE LEVEL
    1757-UPGNG PLX SERVER BATCH REPORT UPGRADE
    1757-UPGNU UPGRADE OPEN DATA ACCESS - 1 ONE MAJOR RELEASE LEVEL
    1757-UPGNV UPGRADE OPEN DATA ACCESS - 5 ONE MAJOR RELEASE LEVEL
    1757-UPGNW UPGRADE OPEN DATA ACCESS - 10 ONE MAJOR RELEASE LEVEL
    1757-UPGNX UPGRADE APPLICATION TOOLKIT ONE MAJOR RELEASE LEVEL
    1757-UPGRT01 UPGRADE 1 USER OI EXTENSION ONE MAJOR RELEASE LEVEL
    1757-UPGRT05 UPGRADE 5 USER OI EXTENSION ONE MAJOR RELEASE LEVEL
    1757-UPGRT10 UPGRADE 10 USER OI EXTENSION ONE MAJOR RELEASE LEVEL
    1757-UPGS100 UPGRADE 100PT SERVER ONE MAJOR RELEASE LEVEL
    1757-UPGS300 UPGRADE 300PT SERVER ONE MAJOR RELEASE LEVEL
    1757-UPGSIFA UPGRADE AB INTEGRATION QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFD UPGRADE HW S9000 ENET INT QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFE UPGRADE HW 620 LCS SER & ENET QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFF UPGRADE HW TDC3000 DATA HIWAY QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFG UPGRADE HW UDC 3000/5000/6300 QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFH UPGRADE HW MICROMAX LPU QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFI UPGRADE HW XLNET HVAC QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFJ UPGRADE HW XLNET NETWORK NODE QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFK UPGRADE GE FAUNC 90 ENET QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFL UPGRADE GE API LICENSE QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFM UPGRADE GEC GEM80 PLC QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFN UPGRADE MODICON PLC MODBUS QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFO UPGRADE MOORE APACS QUICKBUILDER INTERFACE
    1757-UPGSIFP UPGRADE MOORE 351,352,353,383 QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFQ UPGRADE SIEMENS S5&TI QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFR UPGRADE HITACHI QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
    1757-UPGSIFS UPGRADE BRISTOL BABCOCK RTU QUICKBUILDER I/F ONE MAJOR RELEASE LEVEL
北京祥顺达恒有限公司主营产品:美国A-B,罗克韦尔,ALLEN-BRADLEY,ABB,丹佛斯,施耐德,变频器,PLC,压力变送器,温度变送器,SLC500,电磁阀,压力开关,触摸屏,伺服系统,PLC编程软件,组态软件,安全开关,软启动器,松下摄像头. …  更多>>
北京祥顺达恒商贸有限公司
联系人:薛晨
地址:北京市宣武区福长街四条4号213室
邮编:100055
电话:010-63388986
传真:010-51417964
公司网址:http://www.81817979.cn
  • 钟先生 在2015/9/11 11:55:00留言
  • 详细留言:EK2107/70/00/1/10轴位移传感器\EK2107/70/00/1/10\离心压缩机\3BCL459(美国ENTEK)
  • 王力 在2015/3/17 11:01:00留言
  • 邓成阳 在2013/8/21 15:38:00留言
  • 详细留言:您好,我是中科院沈阳计算技术研究所的 想购买AB的PLC CPU SLC500 1747-L543
  • Katrina Koh 在2013/3/12 14:35:00留言
  • 详细留言:Dear Sir/Madam Please quote us your best price for the following item :- (1) Prosoft Modbus Module Unit Model : MVI-94-MCM, REV : B03 Qty : 1 Your earliest reply will be most appreciated. Best Regards Katrina Koh Status Code Sdn Bhd 34A, Jalan Jaya Mas 2 Taman Jaya Mas 81300 Skudai Johor Bahru MALAYSIA Tel : 607-5113800 Fax : 607-5113808
  • clayton 在2012/4/17 18:01:00留言
  • 详细留言:5X 1753-L32BBBM8A 1X 1753-PCSPAR
