北京祥顺达恒商贸有限公司
  • A-B PLC 2
  • 发布时间:2008/9/4 10:10:05   修改时间:2008/9/4 10:10:05 浏览次数:636
  •   如需了解相关信息咨询      薛晨:13801020197
    1326-CCU-D-045 CABLE,RESOLVER FDBK,DOUBLE-ENDED-45M
    1326-CCU-D-053 CABLE,RESOLVER FDBK,DOUBLE-ENDED-53M
    1326-CCU-D-060 CABLE,RESOLVER FDBK,DOUBLE-ENDED,60M
    1326-CCU-D-070 CABLE,RESOLVER FDBK,DOUBLE-ENDED-70M
    1326-CCU-D-075 CABLE,RESOLVER FDBK,DOUBLE-ENDED-75M
    1326-CCU-D-084 CABLE,RESOLVER FDBK,DOUBLE-ENDED,84M
    1326-CCU-DE-003 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 3M
    1326-CCU-DE-005 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 5M
    1326-CCU-DE-006 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 6M
    1326-CCU-DE-009 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 9M
    1326-CCU-DE-012 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 12M
    1326-CCU-DE-024 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 24M
    1326-CCU-DE-035 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 35M
    1326-CCU-DE-040 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 40M
    1326-CCU-DE-045 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 45M
    1326-CCU-DE-053 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 53M
    1326-CCU-DE-070 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 70M
    1326-CCU-DE-075 CABLE,RESOLVER FDBK,MALE TO FEMALE CONNECT, 75M
    1326-CCU-DL-003 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,3M
    1326-CCU-DL-005 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,5M
    1326-CCU-DL-006 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,6M
    1326-CCU-DL-009 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,9M
    1326-CCU-DL-012 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,12M
    1326-CCU-DL-015 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,15M
    1326-CCU-DL-024 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,24M
    1326-CCU-DL-030 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,30M
    1326-CCU-DL-035 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,35M
    1326-CCU-DL-040 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,40M
    1326-CCU-DL-045 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,45M
    1326-CCU-DL-053 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,53M
    1326-CCU-DL-060 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,60M
    1326-CCU-DL-070 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,70M
    1326-CCU-DL-075 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,75M
    1326-CCU-DL-084 CABLE,RESOLVER FDBK,DOUBLE-ENDED IP67,84M
    1326-CCU-E-001 CABLE,RESOLVER FDBK,W/BULKHEAD,1M
    1326-CCU-E-002 CABLE,RESOLVER FDBK,W/BULKHEAD,2M
    1326-CCU-E-003 CABLE,RESOLVER FDBK,W/BULKHEAD,3M
    1326-CCU-E-004 CABLE,RESOLVER FDBK,W/BULKHEAD,4M
    1326-CCU-E-005 CABLE,RESOLVER FDBK,W/BULKHEAD,5M
    1326-CCU-E-006 CABLE,RESOLVER FDBK,W/BULKHEAD,6M
    1326-CCU-E-007 CABLE,RESOLVER FDBK,W/BULKHEAD,7M
    1326-CCU-E-008 CABLE,RESOLVER FDBK,W/BULKHEAD,8M
    1326-CCU-E-009 CABLE,RESOLVER FDBK,W/BULKHEAD,9M
    1326-CCU-E-010 CABLE,RESOLVER FDBK,W/BULKHEAD,10M
    1326-CCU-E-011 CABLE,RESOLVER FDBK,W/BULKHEAD,11M
    1326-CCU-E-012 CABLE,RESOLVER FDBK,W/BULKHEAD,12M
    1326-CCU-E-015 CABLE,RESOLVER FDBK,W/BULKHEAD,15M
    1326-CCU-E-024 CABLE,RESOLVER FDBK,W/BULKHEAD,24M
    1326-CCU-E-030 CABLE,RESOLVER FDBK,W/BULKHEAD,30M
    1326-CCU-E-035 CABLE,RESOLVER FDBK,W/BULKHEAD,35M
    1326-CCU-E-040 CABLE,RESOLVER FDBK,W/BULKHEAD,40M
    1326-CCU-E-045 CABLE,RESOLVER FDBK,W/BULKHEAD,45M
    1326-CCU-E-053 CABLE,RESOLVER FDBK,W/BULKHEAD,53M
    1326-CCU-E-060 CABLE,RESOLVER FDBK,W/BULKHEAD,60M
    1326-CCU-E-070 CABLE,RESOLVER FDBK,W/BULKHEAD,70M
    1326-CCU-E-075 CABLE,RESOLVER FDBK,W/BULKHEAD,75M
    1326-CCU-E-084 CABLE,RESOLVER FDBK,W/BULKHEAD,84M
    1326-CCU-EL-001 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,1M
    1326-CCU-EL-002 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,2M
    1326-CCU-EL-003 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,3M
    1326-CCU-EL-004 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,4M
    1326-CCU-EL-006 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,6M
    1326-CCU-EL-007 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,7M
    1326-CCU-EL-008 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,8M
    1326-CCU-EL-009 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,9M
    1326-CCU-EL-010 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,10M
    1326-CCU-EL-011 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,11M
    1326-CCU-EL-012 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,12M
    1326-CCU-EL-024 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,24M
    1326-CCU-EL-030 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,30M
    1326-CCU-EL-035 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,35M
    1326-CCU-EL-040 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,40M
    1326-CCU-EL-045 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,45M
    1326-CCU-EL-053 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,53M
    1326-CCU-EL-070 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,70M
    1326-CCU-EL-075 CABLE,RESOLVER FDBK,W/BULKHEAD IP67,75M
    1326-CCU-L-005 CABLE,RESOLVER FDBK,IP67 FOR 1326AX-BXX,5M
    1326-CCU-L-015 CABLE, RESOLVER FDBK,IP67 FOR 1326AX-BXX,15M
    1326-CCU-L-030 CABLE,RESOLVER FDBK,IP67 FOR 1326AX-BXX,30M
    1326-CCU-L-060 CABLE,RESOLVER FDBK,IP67 FOR 1326AX-BXX,60M
    1326-CCU-L-090 CABLE,RESOLVER FDBK,IP67 FOR 1326AX-BXX,90M
    1326-CCU-RA-005 CABLE,RESOLVER FDBK,RIGHT ANGLE,SHAFT EXIT,5M
    1326-CCU-RA-015 CABLE,RESOLVER FDBK,RIGHT ANGLE,SHAFT EXIT,15M
    1326-CCU-RA-030 CABLE,RESOLVER FDBK,RTG ANGLE,SHAFT EXIT,30M
    1326-CCU-RA-060 CABLE,RESOLVER FDBK,RTG ANGLE,SHAFT EXIT,60M
    1326-CCU-RA-090 CABLE,RESOLVER FDBK,RTG ANGLE,SHAFT EXIT,90M
    1326-CCU-RAL-005 CABLE,RESOLVER FDBK,RTG ANGLE,SHAFT EXIT,IP67,5M
    1326-CCU-RAL-015 CABLE,RESOLVER FDBK,RIGHT ANGLE,SHAFT EXIT,IP67,15
    1326-CCU-RAL-030 CABLE,RESOLVER FDBK,RIGHT ANGLE,SHAFT EXIT,IP67,30
    1326-CCU-RAL-060 CABLE,RESOLVER FDBK,RTG ANGLE,SHAFT EXIT,IP67,60M
    1326-CCU-RAL-090 CABLE,RESOLVER FDBK,RTG ANGLE,SHAFT EXIT,IP67,90M
    1326-CCU-RB-005 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,5M
    1326-CCU-RB-015 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,15M
    1326-CCU-RB-030 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,30M
    1326-CCU-RB-060 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,60M
    1326-CCU-RB-090 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,90M
    1326-CCU-RBL-005 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,IP67,5M
    1326-CCU-RBL-015 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,IP67,15M
    1326-CCU-RBL-030 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,IP67,30M
    1326-CCU-RBL-060 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,IP67,60M
    1326-CCU-RBL-090 CABLE,RESOLVER FDBK,RTG ANGLE,BACK EXIT,IP67,90M
    1326-CCUT-003 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,3M
    1326-CCUT-005 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,5M
    1326-CCUT-006 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,6M
    1326-CCUT-009 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,9M
    1326-CCUT-012 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,12M
    1326-CCUT-015 CABLE,HI-FLEX,MOTOR FDBK,15M,FOR 1326AX-BX
    1326-CCUT-024 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,24M
    1326-CCUT-030 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,30M
    1326-CCUT-035 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,35M
    1326-CCUT-040 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,40M
    1326-CCUT-045 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,45M
    1326-CCUT-053 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,53M
    1326-CCUT-060 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,60M
    1326-CCUT-070 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,70M
    1326-CCUT-075 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,75M
    1326-CCUT-084 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,84M
    1326-CCUT-090 CABLE,RESOLVER FDBK,FLEX,FOR 1326AX-BXX,90M
    1326-CCUT-D-003 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 3M
    1326-CCUT-D-005 CABLE,RESOLVER FDBK,FLEX,DOUBLE-ENDED 5M
    1326-CCUT-D-006 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 6M
    1326-CCUT-D-009 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 9M
    1326-CCUT-D-012 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 12M
    1326-CCUT-D-015 CABLE,RESOLVER FDBK,FLEX,DOUBLE-ENDED,15M
    1326-CCUT-D-024 CABLE,RESOLVER FDBK,FLEX,DOUBLE-ENDED,24M
    1326-CCUT-D-030 CABLE,RESOLVER FDBK,FLEX,DOUBLE-ENDED,30M
    1326-CCUT-D-035 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 35M
    1326-CCUT-D-040 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 40M
    1326-CCUT-D-045 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 45M
    1326-CCUT-D-053 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 53M
    1326-CCUT-D-060 CABLE,RESOLVER FDBK,FLEX,DOUBLE-ENDED,60M
    1326-CCUT-D-070 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 70M
    1326-CCUT-D-075 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 75M
    1326-CCUT-D-084 CABLE,RESOLVER FDBK,FLEX DOUBLE-ENDED 84M
    1326-CCUT-DL-003 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,3M
    1326-CCUT-DL-005 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,5M
    1326-CCUT-DL-006 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,6M
    1326-CCUT-DL-009 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,9M
    1326-CCUT-DL-012 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,12M
    1326-CCUT-DL-015 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,15M
    1326-CCUT-DL-024 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,24M
    1326-CCUT-DL-035 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,35M
    1326-CCUT-DL-040 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,40M
    1326-CCUT-DL-045 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,45M
    1326-CCUT-DL-053 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,53M
    1326-CCUT-DL-070 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,70M
    1326-CCUT-DL-075 CABLE,RESOLVER FDBK,FLEX,DBL-ENDED,IP67,75M
    1326-CCUT-EE-003 CABLE,RESOLVER FDBK,FLEX,W/2 BLKHD CONN
    1326-CCUT-EE-005 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-006 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-009 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-012 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-024 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-030 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-035 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-040 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-045 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-053 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-EE-070 CABLE,RESOLVER FDBK,FLEX,W/2 BULKHEAD CONN
    1326-CCUT-L-005 CABLE,RESOLVER FDBK,FLEX,IP67,5M
    1326-CCUT-L-015 CABLE,RESOLVER FDBK,FLEX,IP67,15M
    1326-CCUT-L-030 CABLE,RESOLVER FDBK,FLEX,IP67,30M
    1326-CCUT-RA-005 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,SHAFT EXIT,5M
    1326-CCUT-RA-015 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,SHAFT EXIT,15M
    1326-CCUT-RA-030 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,SHAFT EXIT,30M
    1326-CCUT-RA-060 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,SHAFT EXIT,60M
    1326-CCUT-RA-090 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,SHAFT EXIT,90M
    1326-CCUT-RAL-015 CABLE,RESOLVER FDBK,FLEX,RGT ANG,SFT EXIT,IP67
    1326-CCUT-RAL-030 CABLE,RESOLVER FDBK,FLEX,RGT ANG,SFT EXIT IP67
    1326-CCUT-RB-005 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,BACK EXIT,5M
    1326-CCUT-RB-015 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,BACK EXIT,15M
    1326-CCUT-RB-030 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,BACK EXIT,30M
    1326-CCUT-RB-060 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,BACK EXIT,60M
    1326-CCUT-RB-090 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,BACK EXIT,90M
    1326-CCUT-RBL-030 CABLE,RESOLVER FDBK,FLEX,RT ANGLE,BACK EXIT,IP67
    1326-CECU-L-005 CABLE,HI RES,IP67
    1326-CECU-L-015 CABLE,HI RES,IP67
    1326-CECU-L-030 CABLE,HI RES,IP67
    1326-CECU-L-060 CABLE,HI RES,IP67
    1326-CECU-L-090 CABLE,HI RES,IP67
    1326-CECU-RAL-005 CABLE,HI RES,IP67,RIGHT ANGLE,SHAFT EXIT
    1326-CECU-RAL-015 CABLE,HI RES,IP67,RIGHT ANGLE,SHAFT EXIT
    1326-CECU-RAL-030 CABLE,HI RES,IP67,RIGHT ANGLE,SHAFT EXIT
    1326-CECU-RAL-060 CABLE,HI RES,IP67,RIGHT ANGLE,SHAFT EXIT
    1326-CECU-RAL-090 CABLE,HI RES,IP67,RIGHT ANGLE,SHAFT EXIT
    1326-CECU-RBL-005 CABLE,HI RES,IP67,RIGHT ANGLE,REAR EXIT
    1326-CECU-RBL-015 CABLE,HI RES,IP67,RIGHT ANGLE,REAR EXIT
    1326-CECU-RBL-030 CABLE,HI RES,IP67,RIGHT ANGLE,REAR EXIT
    1326-CECU-RBL-060 CABLE,HI RES,IP67,RIGHT ANGLE,REAR EXIT
    1326-CECU-RBL-090 CABLE,HI RES,IP67,RIGHT ANGLE,REAR EXIT
    1326-CECUT-L-005 CABLE,HI RES,FLEX,IP67
    1326-CECUT-L-015 CABLE,HI RES,FLEX,IP67
    1326-CECUT-L-030 CABLE,HI RES,FLEX,IP67
    1326-CECUT-L-090 CABLE,HI RES,FLEX,IP67
    1326-CECUT-RAL-005 CABLE,HI RES,IP67,RT ANGEL,SHAFT EXIT,FLEX
    1326-CECUT-RAL-015 CABLE,HI RES,IP67,RT ANGEL,SHAFT EXIT,FLEX
    1326-CECUT-RAL-030 CABLE,HI RES,IP67,RT ANGEL,SHAFT EXIT,FLEX
    1326-CECUT-RBL-005 CABLE,HI RES,IP67,RT ANGEL,SHAFT EXIT,FLEX
    1326-CECUT-RBL-030 CABLE,HI RES,IP67,RT ANGEL,SHAFT EXIT,FLEX
    1326-CPB1-003 CABLE,MTR PWR,3M,FOR 4/48 FRAME
    1326-CPB1-005 CABLE,MTR PWR,5M,FOR 4/48 FRAME
    1326-CPB1-006 CABLE,MTR PWR, 6M,FOR 4/48 FRAME
    1326-CPB1-009 CABLE,MTR,PWR,9M,FOR 4/48 FRAME
    1326-CPB1-012 CABLE,MTR PWR,12M,FRO 4/48 FRAME
    1326-CPB1-015 CABLE,MTR PWR,15M,FOR 4/48 FRAME
    1326-CPB1-024 CABLE,MTR PWR,24M,FOR 4/48 FRAME
    1326-CPB1-030 CABLE,MTR PWR,30M,FOR 4/48 FRAME
    1326-CPB1-040 CABLE,MTR PWR,40M,FOR 4/48 FRAME
    1326-CPB1-045 CABLE,MTR PWR,45M,FOR 4/48 FRAME
    1326-CPB1-053 CABLE,MTR PWR,53M,FOR 4/48 FRAME
    1326-CPB1-060 CABLE,MTR PWR,60M,FOR 4/48 FRAME
    1326-CPB1-070 CABLE,MTR PWR,70M,FOR 4/48 FRAME
    1326-CPB1-075 CABLE,MTR PWR,75M,FOR 4/48 FRAME
    1326-CPB1-084 CABLE,MTR PWR,84M,FOR 4/48 FRAME
    1326-CPB1-090 CABLE,MTR PWR,90M,FOR 4/48 FRAME
    1326-CPB1-D-003 CABLE,MTR PWR, 3M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-005 CABLE,MTR PWR,5M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-006 CABLE,MTR PWR, 6M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-009 CABLE,MTR PWR,9M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-012 CABLE,MTR PWR,12M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-015 CABLE,MTR PWR,15M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-024 CABLE,MTR PWR,24M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-030 CABLE,MTR PWR,30M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-035 CABLE,MTR PWR,35M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-040 CABLE,MTR PWR,40M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-045 CABLE,MTR PWR,45M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-053 CABLE,MTR PWR,53M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-060 CABLE,MTR PWR,60M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-070 CABLE,MTR PWR,70M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-075 CABLE,MTR PWR,75M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-D-084 CABLE,MTR,PWR,84M,DOUBLE-ENDED,FOR 4/48 FRAME
    1326-CPB1-DE-003 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 3M
    1326-CPB1-DE-005 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 5M
    1326-CPB1-DE-006 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 6M
    1326-CPB1-DE-009 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 9M
    1326-CPB1-DE-012 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 12M
    1326-CPB1-DE-024 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 24M
    1326-CPB1-DE-035 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 35M
    1326-CPB1-DE-040 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 40M
    1326-CPB1-DE-045 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 45M
    1326-CPB1-DE-053 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 53M
    1326-CPB1-DE-070 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 70M
    1326-CPB1-DE-075 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 75M
    1326-CPB1-DE-084 CABLE,MTR PWR, MALE TO FEMALE, FOR 4/48 FRM, 84M
    1326-CPB1-DL-003 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,3M
    1326-CPB1-DL-005 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,5M
    1326-CPB1-DL-006 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,6M
    1326-CPB1-DL-009 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,9M
    1326-CPB1-DL-012 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,12M
    1326-CPB1-DL-015 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,15M
    1326-CPB1-DL-024 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,24M
    1326-CPB1-DL-030 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,30M
    1326-CPB1-DL-035 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,35M
    1326-CPB1-DL-040 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,40M
    1326-CPB1-DL-045 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,45M
    1326-CPB1-DL-053 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,53M
    1326-CPB1-DL-060 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,60M
    1326-CPB1-DL-070 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,70M
    1326-CPB1-DL-075 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,75M
    1326-CPB1-DL-084 CABLE,MTR PWR,75M,DOUBLE-ENDED,IP67,84M
    1326-CPB1-E-001 CABLE,MTR PWR,1M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-002 CABLE,MTR PWR,2M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-003 CABLE,MTR PWR,3M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-004 CABLE,MTR PWR,4M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-005 CABLE,MTR PWR,5M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-006 CABLE,MTR PWR,6M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-007 CABLE,MTR PWR,7M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-008 CABLE,MTR PWR,8M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-009 CABLE,MTR PWR,9M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-010 CABLE,MTR PWR,10M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-011 CABLE,MTR PWR,11M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-012 CABLE,MTR PWR,12M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-015 CABLE,MTR PWR,15M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-024 CABLE,MTR PWR,24M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-030 CABLE,MTR PWR,30M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-035 CABLE,MTR PWR,35M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-040 CABLE,MTR PWR,40M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-045 CABLE,MTR PWR,45M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-053 CABLE,MTR PWR,53M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-060 CABLE,MTR PWR,60M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-070 CABLE,MTR PWR,70M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-075 CABLE,MTR PWR,75M,BULKHEAD,4/48 FRAME
    1326-CPB1-E-084 CABLE,MTR PWR,84M,BULKHEAD,4/48 FRAME
    1326-CPB1-EL-001 CABLE,MTR PWR,BULKHEAD,IP67,1M
    1326-CPB1-EL-002 CABLE,MTR PWR,BULKHEAD,IP67,2M
    1326-CPB1-EL-003 CABLE,MTR PWR,BULKHEAD,IP67,3M
    1326-CPB1-EL-004 CABLE,MTR PWR,BULKHEAD,IP67,4M
    1326-CPB1-EL-006 CABLE,MTR PWR,BULKHEAD,IP67,6M
    1326-CPB1-EL-007 CABLE,MTR PWR,BULKHEAD,IP67,7M
    1326-CPB1-EL-008 CABLE,MTR PWR,BULKHEAD,IP67,8M
    1326-CPB1-EL-009 CABLE,MTR PWR,BULKHEAD,IP67,9M
    1326-CPB1-EL-010 CABLE,MTR PWR,BULKHEAD,IP67,10M
    1326-CPB1-EL-011 CABLE,MTR PWR,BULKHEAD,IP67,11M
    1326-CPB1-EL-012 CABLE,MTR PWR,BULKHEAD,IP67,12M
    1326-CPB1-EL-024 CABLE,MTR PWR,BULKHEAD,IP67,24M
    1326-CPB1-EL-030 CABLE,MTR PWR,BULKHEAD,IP67,30M
    1326-CPB1-EL-035 CABLE,MTR PWR,BULKHEAD,IP67,35M
    1326-CPB1-EL-040 CABLE,MTR PWR,BULKHEAD,IP67,40M
    1326-CPB1-EL-045 CABLE,MTR PWR,BULKHEAD,IP67,45M
    1326-CPB1-EL-053 CABLE,MTR PWR,BULKHEAD,IP67,53M
北京祥顺达恒有限公司主营产品:美国A-B,罗克韦尔,ALLEN-BRADLEY,ABB,丹佛斯,施耐德,变频器,PLC,压力变送器,温度变送器,SLC500,电磁阀,压力开关,触摸屏,伺服系统,PLC编程软件,组态软件,安全开关,软启动器,松下摄像头. …  更多>>
北京祥顺达恒商贸有限公司
联系人:薛晨
地址:北京市宣武区福长街四条4号213室
邮编:100055
电话:010-63388986
传真:010-51417964
公司网址:http://www.81817979.cn
  • 钟先生 在2015/9/11 11:55:00留言
  • 详细留言:EK2107/70/00/1/10轴位移传感器\EK2107/70/00/1/10\离心压缩机\3BCL459(美国ENTEK)
  • 王力 在2015/3/17 11:01:00留言
  • 邓成阳 在2013/8/21 15:38:00留言
  • 详细留言:您好,我是中科院沈阳计算技术研究所的 想购买AB的PLC CPU SLC500 1747-L543
  • Katrina Koh 在2013/3/12 14:35:00留言
  • 详细留言:Dear Sir/Madam Please quote us your best price for the following item :- (1) Prosoft Modbus Module Unit Model : MVI-94-MCM, REV : B03 Qty : 1 Your earliest reply will be most appreciated. Best Regards Katrina Koh Status Code Sdn Bhd 34A, Jalan Jaya Mas 2 Taman Jaya Mas 81300 Skudai Johor Bahru MALAYSIA Tel : 607-5113800 Fax : 607-5113808
  • clayton 在2012/4/17 18:01:00留言
  • 详细留言:5X 1753-L32BBBM8A 1X 1753-PCSPAR
