龙人旗下深圳市龙芯世纪科技有限公司
  • ATMEL 爱特梅尔保密微处理器
  • 发布时间:2009/2/25 10:42:52   修改时间:2009/2/25 10:42:52 浏览次数:1389
  • 首页ATMEL 爱特梅尔保密微处理器
    ATMEL 爱特梅尔 保密微处理器    当前页面搜索:Ctrl+F
    保密微处理器/基于ARM SecurCore
      保密微处理器/基于ARM SecurCore (Microcontrollers 32-bit RISC CPU)  保密微处理器/基于AVR (Microcontrollers 8-/16-bit RISC CPU)
    USB 控制器产品参数表 产品参数表 保密微处理器/基于AVR (Microcontrollers 8-/16-bit RISC CPU)
    设备 描述
    AT91SC512384RCT Low-power, High performance 32-bit RISC secure crypto-controller with 512 K Byte ROM, 384 K Byte EEPROM.Security Features: MMU, OTP (One Time Programmable) EEPROM area, RNG (random Number Generator), "out of bounds" detectors, side channel attack countermeasures.Hardware DES/TDES, CRC Java?Hardware accelerator. AdvX: New Advanced Crypto Engine.
    设备 描述
    AT90SC12836RCFT Low-power, High-performance, 8-/16-bit secure cryptocontroller with 128 Kbytes ROM and 36 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, ISO/IEC 14443 Type A & B contactless interface and ISO/IEC 7816 contact interface, Common Criteria EAL4+ target.
    AT90SC12836RCT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 128 Kbytes ROM and 36 Kbytes EEPROM. Security Features: OTP (one time programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, Common Criteria EAL4+ target.
    AT90SC12872RCFT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 128 Kbytes ROM and 72 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, ISO/IEC 14443 Type A & B contactless interface and ISO/IEC 7816 contact interface, Common Criteria EAL4+ target.
    AT90SC144144CT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 144 Kbytes Flash and 144 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, SPI interface, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, Common Criteria EAL4+ target.
    AT90SC19236RT Low-power, High performance 8-bit/16-bit secure microcontroller with 192 Kbytes ROM, 36 Kbytes EEPROM. Security Features: OTP (one time programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, CRC.
    AT90SC256144RCFT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 256 Kbytes ROM and 144 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, ISO/IEC 14443 Type A & B contactless interface and ISO/IEC 7816 contact interface, Common Criteria EAL5+ target.
    AT90SC25672RCT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 256 Kbytes ROM and 72 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, Common Criteria EAL4+ target.
    AT90SC25672RCT-USB Low-power, high-performance, 8-/16-bit secure cryptocontroller with 256 Kbytes ROM and 72 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, USB V2.0 Full-Speed interface, Common Criteria EAL4+ target.
    AT90SC25672RT Low-power, high-performance, 8-/16-bit secure microcontroller with 256 Kbytes ROM and 72 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, CRC.
    AT90SC288144RT Low-power, high-performance, 8-/16-bit secure microcontroller with 288 Kbytes ROM and 144 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, CRC, Common Criteria EAL4+ target.
    AT90SC320288RCT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 320 Kbytes ROM and 288 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, SPI Interface, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, Common Criteria EAL4+ target.
    AT90SC4818RT Low-power, high-performance, 8-/16-bit secure microcontroller with 48 Kbytes ROM and 18 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (random Number Generator), "out of bounds" detectors.
    AT90SC6404RFT Contactless low-power, high-performance, 8-/16-bit secure microcontroller with 64 Kbytes ROM and 4 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, CRC, ISO/IEC 14443 Type A & B contactless only interface (no ISO/IEC 7816 contact interface), MasterCard CAST/Visa security target.
    AT90SC6404RT Low-power, high-performance 8-bit/16-bit secure microcontroller with 64 Kbytes ROM, 4 Kbytes EEPROM. Security Features: OTP (one time programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, CRC, Common Criteria EAL4+ certified.
    AT90SC6408RFT Low-power, high-performance, 8-/16-bit secure cryptocontroller with 64 Kbytes ROM and 4 Kbytes EEPROM. Security Features: OTP (One Time Programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, CRC, ISO/IEC 14443 Type A & B contactless interface and ISO/IEC 7816 contact interface, security approvals Common Criteria EAL5+, MasterCard CAST and Visa target.
    AT90SC6436RT Low-power, high-performance, 8-/16-bit secure microcontroller with 64 Kbytes ROM and 36 Kbytes EEPROM. Security Features: MMU, MED, OTP (One Time Programmable) EEPROM area, RNG (random Number Generator), "out of bounds" detectors, side channel attack countermeasures.
    AT90SC9608RC Low-power, high-performance 8-bit/16-bit secure cryptocontroller with 96 Kbytes ROM, 8Kbytes EEPROM. Security Features: OTP (one time programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 16-bit RISC Cryptographic Co-processor, CRC, Common Criteria EAL4+ certified.
    AT90SC9618RCT Low-power, High performance 8-bit/16-bit secure cryptocontroller with 96 Kbytes ROM and 18 Kbytes EEPROM. Security Features: OTP (one time programmable) EEPROM area, RNG (Random Number Generator), "out of bounds" detectors, side channel attack countermeasures. Hardware DES/TDES, 32-bit Cryptographic Accelerator, CRC, Common Criteria EAL4+ target.
    产品参数表 保密微处理器 / 基于AVR (Microcontrollers 8-/16-bit RISC CPU)
    设备 EEPROM (Kbytes) Mask ROM (Kbytes) RAM (Kbytes) Flash (Kbytes) Interface Type Vcc (V) CRYPTO
    AT90SC12836RCFT 36 128 5 - ISO14443 + ISO7816 2.7 - 5.5 Yes
    AT90SC12836RCT 36 128 5 - ISO7816 2.7 - 5.5 Yes
    AT90SC12872RCFT 72 128 5 - ISO14443+ISO7816 1.62 - 5.5 Yes
    AT90SC144144CT 144 - 8 144 ISO7816 1.62 - 5.5 Yes
    AT90SC19236RT 36 192 4 - ISO7816 1.62 - 5.5 No
    AT90SC256144RCFT 144 256 8.2 - ISO 14443 and ISO 7816 2.7-5.5 Yes
    AT90SC25672RCT 72 256 6 - ISO7816 1.62 - 5.5 Yes
    AT90SC25672RCT-USB 72 256 6 - USB+ISO7816 1.62 - 5.5 Yes
    AT90SC25672RT 72 256 6 - ISO7816 1.62 - 5.5 No
    AT90SC288144RT 144 288 6 - ISO7816 1.62 - 5.5 No
    AT90SC320288RCT 288 320 8 - ISO7816 1.62 - 5.5 Yes
    AT90SC4818RT 18 48 2 - ISO7816 2.7 - 5.5 No
    AT90SC6404RFT 4 64 1 - ISO14443 2.7 - 5.5 No
    AT90SC6404RT 4 64 2 - ISO7816 2.7 - 5.5 No
    AT90SC6408RFT 4 64 1 - ISO14443+ISO7816 2.7 - 5.5 No
    AT90SC6436RT 36 64 2 - ISO7816 2.7 - 5.5 No
    AT90SC9608RC 8 96 3 - ISO7816 2.7 - 5.5 Yes
    AT90SC9618RCT 18 96 4 - ISO7816 2.7 - 5.5 Yes
    首页ATMEL 爱特梅尔保密微处理器/基于ARM SecurCore
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
