龙人旗下深圳市龙芯世纪科技有限公司
  • 时钟合成器选型指南(含参考价格)
  • 发布时间:2008/10/20 18:30:15   修改时间:2008/10/20 17:01:52 浏览次数:513
  • 首页ON 安森美时钟管理
    时钟合成器
    时钟产生和分配
    安森美半导体提供时钟分配器件、时钟产生器件、时钟合成器件、EMI抑制时钟、歪曲率管理器件和零延迟缓冲器。
    时钟合成器 (55)
    PLL时钟合成器 – PLL时钟产生器
    Microsoft Office Excel 文档格式时钟合成器Excel 文档格式选型指南
    Product 数据手册DataSheet 下载 Pb-free Description VCC Typ (V) fMax Min (MHz) fMax Max (MHz) tLOCK Max (ms) tJitter Typ (ps) tsu Min (ns) th Min (ns) tR & tF Min (ps) tR & tF Max (ps) Package Price
    NB3N3001DTG NB3N3001DTG Y 106.25 MHz/ 212.5 MHz PureEdge" Clock Generator 3.3 not used 106.25 or 212.5 Typ 1 0.3 not used not used 275 600 TSSOP 8 LEAD 3.0x4.4x1.1 mm $3.2399
    NB3N3001DTR2G NB3N3001DTR2G Y 106.25 MHz/ 212.5 MHz PureEdge" Clock Generator 3.3 not used 106.25 or 212.5 Typ 1 0.3 not used not used 275 600 TSSOP 8 LEAD 3.0x4.4x1.1 mm $3.2399
    NB3N3002DTG NB3N3002DTG Y 3.3 V PureEdge" Crystal (25MHz) to HCSL Clock Generator 3.3 25 200 1 2 - - 175 700 TSSOP-16 $1.8
    NB3N3002DTR2G NB3N3002DTR2G Y 3.3 V PureEdge" Crystal (25MHz) to HCSL Clock Generator 3.3 25 200 1 2 - - 175 700 TSSOP-16 $1.8
    NB3N3011DTG NB3N3011DTG Y 100 MHz / 106.25 MHz PureEdge" Clock Generator 3.3 96 120 1 0.29 not speced not speced 275 600 TSSOP 8 LEAD 3.0x4.4x1.1 mm $3.2399
    NB3N3011DTR2G NB3N3011DTR2G Y 100 MHz / 106.25 MHz PureEdge" Clock Generator 3.3 96 120 1 0.29 not speced not speced 275 600 TSSOP 8 LEAD 3.0x4.4x1.1 mm $3.2399
    NB3N502DG NB3N502DG Y PLL Clock Multiplier 3 10 190 1 15 not used not used 1000 1000 SOIC-8 Narrow Body $1.6666
    NB3N502DR2G NB3N502DR2G Y PLL Clock Multiplier 3 10 190 1 15 not used not used 1000 1000 SOIC-8 Narrow Body $1.6666
    NB3N508SDTG NB3N508SDTG Y 3.3V, 216 MHz PureEdge¿ VCXO Clock Generator with MLVDS Output 3.3 not used 216 2 88dBc/Hz @1KHZ  not used not used 380 500 TSSOP-16 $1.0666
    NB3N508SDTR2G NB3N508SDTR2G Y 3.3V, 216 MHz PureEdge¿ VCXO Clock Generator with MLVDS Output 3.3 not used 216 2 88dBc/Hz @1KHZ  not used not used 380 500 TSSOP-16 $1.0666
    NB4N441MNG NB4N441MNG Y Multiprotocol PLL Clock Synthesizer 3.3 12.5 425 5 3.5 20   175 425 QFN 4x4 mm, 24 PIN $5.0
    NB4N441MNR2G NB4N441MNR2G Y Multiprotocol PLL Clock Synthesizer 3.3 12.5 425 5 3.5 20   175 425 QFN 4x4 mm, 24 PIN $5.0
    NB4N507ADG NB4N507ADG Y 50-200 MHz PECL Clock Synthesizer 3.3 50 200 1 10     50 70 SOIC 16 LEAD $1.5
    NB4N507ADR2G NB4N507ADR2G Y 50-200 MHz PECL Clock Synthesizer 3.3 50 200 1 10     50 70 SOIC 16 LEAD $1.5
    NBC12429AFAG NBC12429AFAG Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $8.2665
    NBC12429AFAR2G NBC12429AFAR2G Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $8.2665
    NBC12429AFNG NBC12429AFNG Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 28 LEAD PLCC $6.84
    NBC12429AFNR2G NBC12429AFNR2G Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 28 LEAD PLCC $6.84
    NBC12429AMNG NBC12429AMNG Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $6.84
    NBC12429AMNR4G NBC12429AMNR4G Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $6.84
    NBC12429FAG NBC12429FAG Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12429FAR2 NBC12429FAR2 N Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12429FAR2G NBC12429FAR2G Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12429FN NBC12429FN N Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12429FNG NBC12429FNG Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12429FNR2 NBC12429FNR2 N Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12429FNR2G NBC12429FNR2G Y Programmable PLL Synthesized Clock Generator (25-400 MHz) 3.3 25 400 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12430AFAG NBC12430AFAG Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $8.2665
    NBC12430AFAR2G NBC12430AFAR2G Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $8.2665
    NBC12430AFNG NBC12430AFNG Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $8.2665
    NBC12430AFNR2G NBC12430AFNR2G Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $8.2665
    NBC12430AMNG NBC12430AMNG Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $6.84
    NBC12430AMNR4G NBC12430AMNR4G Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $6.84
    NBC12430FAG NBC12430FAG Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12430FAR2 NBC12430FAR2 N Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12430FAR2G NBC12430FAR2G Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12430FN NBC12430FN N Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12430FNG NBC12430FNG Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12430FNR2 NBC12430FNR2 N Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12430FNR2G NBC12430FNR2G Y Programmable PLL Synthesized Clock Generator (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12439AFAG NBC12439AFAG Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $8.2665
    NBC12439AFAR2G NBC12439AFAR2G Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $8.2665
    NBC12439AFN NBC12439AFN N Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $9.1198
    NBC12439AFNG NBC12439AFNG Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.84
    NBC12439AFNR2 NBC12439AFNR2 N Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $9.1198
    NBC12439AFNR2G NBC12439AFNR2G Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.84
    NBC12439AMNG NBC12439AMNG Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $6.84
    NBC12439AMNR4G NBC12439AMNR4G Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $6.84
    NBC12439FAG NBC12439FAG Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12439FAR2 NBC12439FAR2 N Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12439FAR2G NBC12439FAR2G Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 QFP / 32 LEAD LQFP 7x7x1.4mm $6.8665
    NBC12439FN NBC12439FN N Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12439FNG NBC12439FNG Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12439FNR2 NBC12439FNR2 N Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
    NBC12439FNR2G NBC12439FNR2G Y Programmable PLL Synthesized Clock Generator with Power Down (50-800 MHz) 3.3 50 800 10 20 20 20 175 425 28 LEAD PLCC $6.8665
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
