龙人旗下深圳市龙芯世纪科技有限公司
  • 时钟产生和分配选型指南(含参考价格)
  • 发布时间:2008/10/20 18:43:32   修改时间:2008/10/20 16:59:17 浏览次数:816
  • 首页ON 安森美时钟管理
    时钟产生和分配
    时钟产生和分配
    安森美半导体提供时钟分配器件、时钟产生器件、时钟合成器件、EMI抑制时钟、歪曲率管理器件和零延迟缓冲器。
    Microsoft Office Excel 文档格式时钟产生和分配Excel 文档格式选型指南
    Product 数据手册DataSheet 下载 Pb-free Description Input Level Output Level VCC Typ (V) Channels Outputs per fMax Typ (MHz) tskew(OO) Max (ps) tJitter Typ (ps) tR & tF Max (ps) Package Price
    M100LVEP111FATW MC100LVEP111FATW N 2.5 V / 3.3 V 1:10 Differential ECL/PECL/HSTL Clock Driver ECL/HSTL ECL 3.3 1 10 3000 25 0.2 200 32 LEAD LQFP 7x7, 0.8P $7.9998
    M100LVEP111FATWG MC100LVEP111FATWG Y 2.5 V / 3.3 V 1:10 Differential ECL/PECL/HSTL Clock Driver ECL/HSTL ECL 3.3 1 10 3000 25 0.2 200 32 LEAD LQFP 7x7, 0.8P $7.9998
    MC100LVEP210MNG MC100LVEP210MNG Y 2.5 V / 3.3 V 1:5 Dual Differential ECL/PECL/HSTL Clock Driver ECL/HSTL ECL 3.3 2 5 3000 20 0.2 270 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad
    MC100LVEP210MNRG MC100LVEP210MNRG Y 2.5 V / 3.3 V 1:5 Dual Differential ECL/PECL/HSTL Clock Driver ECL/HSTL ECL 3.3 2 5 3000 20 0.2 270 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad
    NB100LVEP224FARG NB100LVEP224FARG Y 2.5 V / 3.3 V 1:24 Differential ECL/PECL Clock Driver with Clock Select and Output Enable ECL ECL 2.5 1 24 1000 40 5 300 QFP / LQFP 64 LEAD EXPOSED PAD $16.0
    NB7L572MNG NB7L572MNG Y 2.5V/3.3V Differential 4:1 Mux Input to 1:2 LVPECL Clock/Data Fanout/Translator CML/ECL/LVDS CML/ECL/LVDS 2.5 1 2 7000 15 0.5 110 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $9.3331
    NB7L572MNR4G NB7L572MNR4G Y 2.5V/3.3V Differential 4:1 Mux Input to 1:2 LVPECL Clock/Data Fanout/Translator CML/ECL/LVDS CML/ECL/LVDS 2.5 1 2 7000 15 0.5 110 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $9.3331
    NB7L72MMNG NB7L72MMNG Y 2.5V/3.3V Differential 2 x 2 Crosspoint Switch with CML Outputs Clock/Data Buffer/Translator CML/CMOS/ECL/LVDS/TTL CML 2.5 2 2 8500 10 0.2 50 16 PIN QFN, 3x3, 0.5P $9.3331
    NB7L72MMNTXG NB7L72MMNTXG Y 2.5V/3.3V Differential 2 x 2 Crosspoint Switch with CML Outputs Clock/Data Buffer/Translator CML/CMOS/ECL/LVDS/TTL CML 2.5 2 2 8500 10 0.2 50 16 PIN QFN, 3x3, 0.5P $9.3331
    NBSG111BAHTBG NBSG111BAHTBG Y 2.5 V/3.3 V SiGe 1:10 Differential Clock Driver with RSECL Outputs CML/CMOS/ECL/LVDS/TTL ECL 2.5 1 10 6000 15 2 60 FCBGA-49 $39.999
    NBSG11MNHTBG NBSG11MNHTBG Y 2.5 V/3.3 V SiGe 1:2 Differential Clock Driver with RSECL Outputs CML/CMOS/ECL/LVDS/TTL ECL 2.5 1 2 12000 15 0.5 30 16 PIN QFN, 3x3, 0.5P $28.0
    NBSG14MNHTBG NBSG14MNHTBG Y 2.5V/3.3V SiGe 1:4 Differential Clock Driver with RSECL Outputs CML/CMOS/ECL/LVDS/TTL ECL 2.5 1 5 12000 15 0.5 55 16 PIN QFN, 3x3, 0.5P $33.6
    NBSG11BAHTBG NBSG11BAHTBG Y 2.5 V/3.3 V SiGe 1:2 Differential Clock Driver with RSECL Outputs CML/CMOS/ECL/LVDS/TTL ECL 2.5 1 2 12000 15 0.5 30 16 PIN FLIP CHIP BGA
    NBSG14BAHTBG NBSG14BAHTBG Y 2.5V/3.3V SiGe 1:4 Differential Clock Driver with RSECL Outputs CML/CMOS/ECL/LVDS/TTL ECL 2.5 1 5 12000 15 0.5 55 16 PIN FLIP CHIP BGA
    MC100E111FN MC100E111FN N 5 V ECL 1:9 Differential Clock Driver ECL ECL 5 1 9 800 50 0.2 600 28 LEAD PLCC $6.6665
    MC100E111FNG MC100E111FNG Y 5 V ECL 1:9 Differential Clock Driver ECL ECL 5 1 9 800 50 0.2 600 28 LEAD PLCC $6.6665
    MC100E111FNR2 MC100E111FNR2 N 5 V ECL 1:9 Differential Clock Driver ECL ECL 5 1 9 800 50 0.2 600 28 LEAD PLCC $6.6665
    MC100E111FNR2G MC100E111FNR2G Y 5 V ECL 1:9 Differential Clock Driver ECL ECL 5 1 9 800 50 0.2 600 28 LEAD PLCC $6.6665
    MC100E210FNG MC100E210FNG Y 5 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 5 2 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100E210FNR2 MC100E210FNR2 N 5 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 5 2 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100E210FNR2G MC100E210FNR2G Y 5 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 5 2 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100E211FN MC100E211FN N 5 V ECL 1:6 Differential Clock Distribution Chip ECL ECL 5 1 6 700 75 0.2 400 28 LEAD PLCC $9.3598
    MC100E211FNG MC100E211FNG Y 5 V ECL 1:6 Differential Clock Distribution Chip ECL ECL 5 1 6 700 75 0.2 400 28 LEAD PLCC $9.3598
    MC100E211FNR2G MC100E211FNR2G Y 5 V ECL 1:6 Differential Clock Distribution Chip ECL ECL 5 1 6 700 75 0.2 400 28 LEAD PLCC $9.3598
    MC100E310FNG MC100E310FNG Y 2:8 Differential Fanout Buffer ECL ECL 5 1 8 900 50 0.2 600 28 LEAD PLCC $9.3598
    MC100E310FNR2G MC100E310FNR2G Y 2:8 Differential Fanout Buffer ECL ECL 5 1 8 900 50 0.2 600 28 LEAD PLCC $9.3598
    MC100EL11D MC100EL11D N 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 SOIC-8 Narrow Body $2.7999
    MC100EL11DG MC100EL11DG Y 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 SOIC-8 Narrow Body $2.7999
    MC100EL11DR2 MC100EL11DR2 N 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 SOIC-8 Narrow Body $2.7999
    MC100EL11DR2G MC100EL11DR2G Y 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 SOIC-8 Narrow Body $2.7999
    MC100EL11DT MC100EL11DT N 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100EL11DTG MC100EL11DTG Y 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100EL11DTR2G MC100EL11DTR2G Y 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 5 1 2 2000 5 0.2 350 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100EL13DW MC100EL13DW N 5 V ECL Dual 1:3 Fanout Buffer ECL ECL 5 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100EL13DWG MC100EL13DWG Y 5 V ECL Dual 1:3 Fanout Buffer ECL ECL 5 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100EL13DWR2 MC100EL13DWR2 N 5 V ECL Dual 1:3 Fanout Buffer ECL ECL 5 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100EL13DWR2G MC100EL13DWR2G Y 5 V ECL Dual 1:3 Fanout Buffer ECL ECL 5 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100EL14DWG MC100EL14DWG Y 5 V ECL 1:5 Clock Distribution Chip ECL ECL 5 1 5 1000 50 0.2 500 SOIC-20 WB $5.9999
    MC100EL14DWR2 MC100EL14DWR2 N 5 V ECL 1:5 Clock Distribution Chip ECL ECL 5 1 5 1000 50 0.2 500 SOIC-20 WB $5.9999
    MC100EL14DWR2G MC100EL14DWR2G Y 5 V ECL 1:5 Clock Distribution Chip ECL ECL 5 1 5 1000 50 0.2 500 SOIC-20 WB $5.9999
    MC100EL15D MC100EL15D N 5 V ECL 1:4 Clock Distribution Chip ECL ECL 5 1 4 1000 50 0.2 575 SOIC 16 LEAD $3.1999
    MC100EL15DG MC100EL15DG Y 5 V ECL 1:4 Clock Distribution Chip ECL ECL 5 1 4 1000 50 0.2 575 SOIC 16 LEAD $3.1999
    MC100EL15DR2 MC100EL15DR2 N 5 V ECL 1:4 Clock Distribution Chip ECL ECL 5 1 4 1000 50 0.2 575 SOIC 16 LEAD $3.1999
    MC100EL15DR2G MC100EL15DR2G Y 5 V ECL 1:4 Clock Distribution Chip ECL ECL 5 1 4 1000 50 0.2 575 SOIC 16 LEAD $3.1999
    MC100EP11D MC100EP11D N 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 SOIC-8 Narrow Body $6.6665
    MC100EP11DG MC100EP11DG Y 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 SOIC-8 Narrow Body $6.6665
    MC100EP11DR2 MC100EP11DR2 N 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 SOIC-8 Narrow Body $6.6665
    MC100EP11DR2G MC100EP11DR2G Y 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 SOIC-8 Narrow Body $6.6665
    MC100EP11DT MC100EP11DT N 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $6.6665
    MC100EP11DTG MC100EP11DTG Y 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $6.6665
    MC100EP11DTR2 MC100EP11DTR2 N 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $6.6665
    MC100EP11DTR2G MC100EP11DTR2G Y 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $6.6665
    MC100EP11MNR4G MC100EP11MNR4G Y 3.3 V / 5 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 3000 20 0.2 180 DFN8 2.0x2.0x0.9mm, 0.5p $6.6665
    MC100EP14DTG MC100EP14DTG Y 5 V 1:5 Differential Clock Driver ECL/HSTL ECL 3.3 1 5 2000 45 0.2 270 TSSOP 20 LEAD $6.5998
    MC100EP14DTR2G MC100EP14DTR2G Y 5 V 1:5 Differential Clock Driver ECL/HSTL ECL 3.3 1 5 2000 45 0.2 270 TSSOP 20 LEAD $6.5998
    MC100EP210SFA MC100EP210SFA N 2.5 V 1:5 Dual Differential LVDS Clock Driver ECL/LVDS LVDS 3.3 2 5 1000 20 0.2 225 QFP / 32 LEAD LQFP 7x7x1.4mm $15.0263
    MC100EP210SFAG MC100EP210SFAG Y 2.5 V 1:5 Dual Differential LVDS Clock Driver ECL/LVDS LVDS 3.3 2 5 1000 20 0.2 225 QFP / 32 LEAD LQFP 7x7x1.4mm $11.27
    MC100EP210SFAR2 MC100EP210SFAR2 N 2.5 V 1:5 Dual Differential LVDS Clock Driver ECL/LVDS LVDS 3.3 2 5 1000 20 0.2 225 QFP / 32 LEAD LQFP 7x7x1.4mm $15.0263
    MC100EP210SFAR2G MC100EP210SFAR2G Y 2.5 V 1:5 Dual Differential LVDS Clock Driver ECL/LVDS LVDS 3.3 2 5 1000 20 0.2 225 QFP / 32 LEAD LQFP 7x7x1.4mm $11.27
    MC100EP210SMNG MC100EP210SMNG Y 2.5 V 1:5 Dual Differential LVDS Clock Driver ECL/LVDS LVDS 3.3 2 5 1000 20 0.2 225 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $11.27
    MC100EP210SMNR4G MC100EP210SMNR4G Y 2.5 V 1:5 Dual Differential LVDS Clock Driver ECL/LVDS LVDS 3.3 2 5 1000 20 0.2 225 32 QFN, 5 x 5 mm, 0.5 mm pitch, exposed pad $11.27
    MC100EP809FAG MC100EP809FAG Y 3.3 V 1:9 Differential HSTL/PECL to HSTL Clock Driver CML/ECL/HSTL/LVDS HSTL 3.3 1 9 750 15 1.4 600 QFP / 32 LEAD LQFP 7x7x1.4mm $7.9998
    MC100EP809FAR2 MC100EP809FAR2 N 3.3 V 1:9 Differential HSTL/PECL to HSTL Clock Driver CML/ECL/HSTL/LVDS HSTL 3.3 1 9 750 15 1.4 600 QFP / 32 LEAD LQFP 7x7x1.4mm $7.9998
    MC100EP809FAR2G MC100EP809FAR2G Y 3.3 V 1:9 Differential HSTL/PECL to HSTL Clock Driver CML/ECL/HSTL/LVDS HSTL 3.3 1 9 750 15 1.4 600 QFP / 32 LEAD LQFP 7x7x1.4mm $7.9998
    MC100H640FNG MC100H640FNG Y 68030/040 PECL to TTL Clock Driver ECL TTL 5 1 8 135 500   2500 28 LEAD PLCC $19.9995
    MC100H640FNR2 MC100H640FNR2 N 68030/040 PECL to TTL Clock Driver ECL TTL 5 1 8 135 500   2500 28 LEAD PLCC $19.9995
    MC100H640FNR2G MC100H640FNR2G Y 68030/040 PECL to TTL Clock Driver ECL TTL 5 1 8 135 500   2500 28 LEAD PLCC $19.9995
    MC100H641FN MC100H641FN N 1:9 Clock Driver ECL TTL 5 1 9 65 350   1700 28 LEAD PLCC $7.4665
    MC100H641FNG MC100H641FNG Y 1:9 Clock Driver ECL TTL 5 1 8 80 350   1700 28 LEAD PLCC $7.4665
    MC100H641FNR2 MC100H641FNR2 N 1:9 Clock Driver ECL TTL 5 1 9 65 350   1700 28 LEAD PLCC $7.4665
    MC100H641FNR2G MC100H641FNR2G Y 1:9 Clock Driver ECL TTL 5 1 8 80 350   1700 28 LEAD PLCC $7.4665
    MC100H642FNG MC100H642FNG Y 68030/040 PECL to TTL Clock Driver ECL TTL 5 1 8 100 500   2500 28 LEAD PLCC $11.8397
    MC100H642FNR2 MC100H642FNR2 N 68030/040 PECL to TTL Clock Driver ECL TTL 5 1 8 100 500   2500 28 LEAD PLCC $11.8397
    MC100H642FNR2G MC100H642FNR2G Y 68030/040 PECL to TTL Clock Driver ECL TTL 5 1 8 100 500   2500 28 LEAD PLCC $11.8397
    MC100H643FNG MC100H643FNG Y 1:8 Clock Driver ECL TTL 5 1 8 80 500   1200 28 LEAD PLCC $10.2797
    MC100H643FNR2 MC100H643FNR2 N 1:8 Clock Driver ECL TTL 5 1 8 80 500   1200 28 LEAD PLCC $10.2797
    MC100H643FNR2G MC100H643FNR2G Y 1:8 Clock Driver ECL TTL 5 1 8 80 500   1200 28 LEAD PLCC $10.2797
    MC100H646FNG MC100H646FNG Y PECL/TTL-TTL 1:8 Distribution Chip ECL TTL 5 1 8 80 350   1500 28 LEAD PLCC $7.4665
    MC100H646FNR2G MC100H646FNR2G Y PECL/TTL-TTL 1:8 Distribution Chip ECL TTL 5 1 8 80 350   1500 28 LEAD PLCC $7.4665
    MC100LVE111FN MC100LVE111FN N 3.3 V ECL 1:9 Differential Clock Driver ECL ECL 3.3 1 9 1500 20 0.2 600 28 LEAD PLCC $6.6665
    MC100LVE111FNG MC100LVE111FNG Y 3.3 V ECL 1:9 Differential Clock Driver ECL ECL 3.3 1 9 1500 20 0.2 600 28 LEAD PLCC $6.6665
    MC100LVE111FNR2 MC100LVE111FNR2 N 3.3 V ECL 1:9 Differential Clock Driver ECL ECL 3.3 1 9 1500 20 0.2 600 28 LEAD PLCC $6.6665
    MC100LVE111FNR2G MC100LVE111FNR2G Y 3.3 V ECL 1:9 Differential Clock Driver ECL ECL 3.3 1 9 1500 20 0.2 600 28 LEAD PLCC $6.6665
    MC100LVE210FN MC100LVE210FN N 3.3 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 3.3 2 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100LVE210FNG MC100LVE210FNG Y 3.3 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 3.3 1 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100LVE210FNR2 MC100LVE210FNR2 N 3.3 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 3.3 2 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100LVE210FNR2G MC100LVE210FNR2G Y 3.3 V ECL Dual 1:4, 1:5 Differential Fanout Buffer ECL ECL 3.3 1 4+5 700 75 0.2 600 28 LEAD PLCC $9.3598
    MC100LVE222FA MC100LVE222FA N 1:15 Differential ÷1/2 ECL/PECL Clock Driver ECL ECL 3.3 2 15 1500 50 0.2 600 QFP / LQFP 10x10x1.4 52 LEAD $10.6664
    MC100LVE222FAG MC100LVE222FAG Y 1:15 Differential ÷1/2 ECL/PECL Clock Driver ECL ECL 3.3 2 15 1500 50 0.2 600 QFP / LQFP 10x10x1.4 52 LEAD $10.6664
    MC100LVE222FAR2 MC100LVE222FAR2 N 1:15 Differential ÷1/2 ECL/PECL Clock Driver ECL ECL 3.3 2 15 1500 50 0.2 600 QFP / LQFP 10x10x1.4 52 LEAD $10.6664
    MC100LVE222FAR2G MC100LVE222FAR2G Y 1:15 Differential ÷1/2 ECL/PECL Clock Driver ECL ECL 3.3 2 15 1500 50 0.2 600 QFP / LQFP 10x10x1.4 52 LEAD $10.6664
    MC100LVE310FN MC100LVE310FN N 3.3 V ECL 2:8 Differential Fanout Buffer ECL ECL 3.3 1 8 1000 50 1.5 600 28 LEAD PLCC $5.4665
    MC100LVE310FNG MC100LVE310FNG Y 3.3 V ECL 2:8 Differential Fanout Buffer ECL ECL 3.3 1 8 1000 50 1.5 600 28 LEAD PLCC $5.4665
    MC100LVE310FNR2 MC100LVE310FNR2 N 3.3 V ECL 2:8 Differential Fanout Buffer ECL ECL 3.3 1 8 1000 50 1.5 600 28 LEAD PLCC $5.4665
    MC100LVE310FNR2G MC100LVE310FNR2G Y 3.3 V ECL 2:8 Differential Fanout Buffer ECL ECL 3.3 1 8 1000 50 1.5 600 28 LEAD PLCC $5.4665
    MC100LVEL11D MC100LVEL11D N 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 SOIC-8 Narrow Body $2.7999
    MC100LVEL11DG MC100LVEL11DG Y 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 SOIC-8 Narrow Body $2.7999
    MC100LVEL11DR2 MC100LVEL11DR2 N 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 SOIC-8 Narrow Body $2.7999
    MC100LVEL11DR2G MC100LVEL11DR2G Y 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 SOIC-8 Narrow Body $2.7999
    MC100LVEL11DT MC100LVEL11DT N 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100LVEL11DTG MC100LVEL11DTG Y 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100LVEL11DTR2 MC100LVEL11DTR2 N 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100LVEL11DTR2G MC100LVEL11DTR2G Y 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 TSSOP 8 3.0x3.0x0.95 mm $2.7999
    MC100LVEL11MNR4G MC100LVEL11MNR4G Y 3.3 V ECL 1:2 Differential Fanout Buffer ECL ECL 3.3 1 2 1000 20 0.2 180 DFN8 2.0x2.0x0.9mm, 0.5p $2.7999
    MC100LVEL13DW MC100LVEL13DW N 3.3 V ECL Dual 1:3 Fanout Buffer ECL ECL 3.3 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100LVEL13DWG MC100LVEL13DWG Y 3.3 V ECL Dual 1:3 Fanout Buffer ECL ECL 3.3 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100LVEL13DWR2 MC100LVEL13DWR2 N 3.3 V ECL Dual 1:3 Fanout Buffer ECL ECL 3.3 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100LVEL13DWR2G MC100LVEL13DWR2G Y 3.3 V ECL Dual 1:3 Fanout Buffer ECL ECL 3.3 2 3 1000 50 0.2 500 SOIC-20 WB $8.5731
    MC100LVEL14DW MC100LVEL14DW N 3.3 V ECL 1:5 Clock Distribution Chip ECL ECL 3.3 1 5 1000 50 0.2 500 SOIC-20 WB $5.9999
    MC100LVEL14DWG MC100LVEL14DWG Y 3.3 V ECL 1:5 Clock Distribution Chip ECL ECL 3.3 1 5 1000 50 0.2 500 SOIC-20 WB $5.9999
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
