| Product |
数据手册DataSheet 下载 |
Pb-free |
Description |
Output Type |
Polarity |
VO Typ (V) |
IO Typ (A) |
VI Max (V) |
VDO Typ (V) |
Iq Typ (mA) |
PSRR (dB) |
Noise (µVrms) |
Package |
Price(美元) |
| CS8126-1YDPS7G |
CS8126-1YDPS7G |
Y |
5 V, 750 mA Low Dropout Linear Regulator |
Single |
Positive |
5 |
0.75 |
60 |
0.35 |
2 |
75 |
D2PAK-7 (Short Lead) |
1.626 |
| CS8363YDPS7G |
CS8363YDPS7G |
Y |
3.3V/100mA & Tracker/250mA Dual LDO w/ Enable and Reset |
Multiple |
Positive |
3.3 |
0.1 |
12.5 |
0.4 |
0.145 |
70 |
1.8 |
| CS8363YDPSR7G |
CS8363YDPSR7G |
Y |
Multiple |
Positive |
3.3 |
0.1 |
12.5 |
0.4 |
0.145 |
70 |
1.8 |
| MC7808AEBTG |
MC7808AEBTG |
Y |
1 A, 8 V,±1.5% Tolerance, Voltage Regulator |
Single |
Positive |
8 |
1 |
35 |
2 |
TO-220, SINGLE GAUGE |
0.36 |
| NCP3985SN25T1G |
NCP3985SN25T1G |
Y |
Micropower, 150 mA Low-Noise, High PSRR, Ultra-Low Dropout BiCMOS Voltage Regulator |
Single |
Positive |
2.5 |
0.15 |
5.5 |
0.105 |
0.07 |
70 |
20 |
TSOP-5 / SOT23-5 |
0.23 |
| NCP3985SN275T1G |
NCP3985SN275T1G |
Y |
Single |
Positive |
2.75 |
0.15 |
5.5 |
0.105 |
0.07 |
70 |
20 |
TSOP-5 / SOT23-5 |
0.23 |
| NCP3985SN33T1G |
NCP3985SN33T1G |
Y |
Single |
Positive |
3.3 |
0.15 |
5.5 |
0.1 |
0.07 |
70 |
20 |
TSOP-5 / SOT23-5 |
0.23 |
| NCP590MNVVTAG |
NCP590MNVVTAG |
Y |
Dual Output, High Accuracy, Low Dropout Regulator |
Dual |
Positive |
3.3,3.3 |
0.3 |
6 |
0.165 |
DFN8 2.0x2.0x0.9mm, 0.5p |
0.59 |
| NCP699SN34T1G |
NCP699SN34T1G |
Y |
150 mA CMOS Low Iq LDO with Enable |
Single |
Positive |
3.4 |
0.15 |
6 |
0.3 |
TSOP-5 / SOT23-5 |
0.2 |
| NCV2931ADT-5.0RK |
NCV2931ADT-5.0RK |
N |
100mA, 5V, Low Dropout Voltage Regulator with 60V Load Dump Protection |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
90 |
DPAK 4 LEAD Single Gauge Surface Mount |
| NCV2931ADT5.0RKG |
NCV2931ADT5.0RKG |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
90 |
0.68 |
| NCV33269DT-5.0G |
NCV33269DT-5.0G |
Y |
800mA, Low Dropout Voltage Regulator |
Single |
Positive |
5 |
0.8 |
20 |
1.1 |
0.36 |
| NCV33269DTRK-5.0 |
NCV33269DTRK-5.0 |
N |
Single |
Positive |
5 |
0.8 |
20 |
1.1 |
0.52 |
| NCV33269DTRK5.0G |
NCV33269DTRK5.0G |
Y |
Single |
Positive |
5 |
0.8 |
20 |
1.1 |
0.52 |
| NCV33275ST3.3T3G |
NCV33275ST3.3T3G |
Y |
300mA, Low Dropout Voltage Regulator |
Single |
Positive |
3.3 |
0.3 |
13 |
0.26 |
SOT-223 (TO-261) 4 LEAD |
0.6267 |
| NCV4275ADS50G |
NCV4275ADS50G |
Y |
450 mA, 5.0V, LDO w/Reset and Delay |
Single |
Positive |
5 |
0.45 |
45 |
0.25 |
0.15 |
60 |
5 LEAD D2PAK |
0.965 |
| NCV4275ADS50R4G |
NCV4275ADS50R4G |
Y |
Single |
Positive |
5 |
0.45 |
45 |
0.25 |
0.15 |
60 |
5 LEAD D2PAK |
0.965 |
| NCV4275ADT33RKG |
NCV4275ADT33RKG |
Y |
450 mA, 3.3 V, LDO w/Reset and Delay |
Single |
Positive |
3.3 |
0.45 |
45 |
0.25 |
0.15 |
60 |
DPAK 5 Center Lead Crop |
0.9 |
| NCV5500DADJR2G |
NCV5500DADJR2G |
Y |
500 mA Low Dropout Linear Regulator |
SOIC-8 Narrow Body |
| NCV5661MN12T2G |
NCV5661MN12T2G |
Y |
Fast response 1 Amp LDO with enable |
Single |
Positive |
1.2 |
1 |
9 |
1 |
DFN6, 3x3.3x0.9mm, 0.95mm Pitch |
0.451 |
| NCV5661MN15T2G |
NCV5661MN15T2G |
Y |
Single |
Positive |
1.5 |
1 |
9 |
1 |
0.451 |
| NCV5661MN18T2G |
NCV5661MN18T2G |
Y |
Single |
Positive |
1.8 |
1 |
9 |
1 |
0.451 |
| NCV5661MN25T2G |
NCV5661MN25T2G |
Y |
Single |
Positive |
2.5 |
1 |
9 |
1 |
0.451 |
| NCV5661MN28T2G |
NCV5661MN28T2G |
Y |
Single |
Positive |
2.8 |
1 |
9 |
1 |
0.451 |
| NCV5661MN30T2G |
NCV5661MN30T2G |
Y |
Single |
Positive |
3 |
1 |
9 |
1 |
0.451 |
| NCV5661MN33T2G |
NCV5661MN33T2G |
Y |
Single |
Positive |
3.3 |
1 |
9 |
1 |
0.451 |
| NCV5661MNADJT2G |
NCV5661MNADJT2G |
Y |
Single |
Positive |
Adjustable |
1 |
9 |
1 |
0.451 |
| NCV5663DS15R4G |
NCV5663DS15R4G |
Y |
Fast Response 1.5V 3A LDO Regulator with Enable, Qualified for Automotive use |
Single |
Positive |
1.5 |
3 |
9 |
1 |
5 LEAD D2PAK |
0.67 |
| NCV5663DSADJR4G |
NCV5663DSADJR4G |
Y |
Fast Response Adj 3A LDO Regulator with Enable, Qualified for Automotive use |
Single |
Positive |
Adjustable |
3 |
9 |
1 |
5 LEAD D2PAK |
0.67 |
| NCV8184PDG |
NCV8184PDG |
Y |
Micropower 70 mA Low Dropout Tracking Regulator/Line Driver |
Single |
Positive |
Tracking |
0.07 |
26 |
0.35 |
0.05 |
60 |
SOIC8 EP |
0.835 |
| NCV8184PDR2G |
NCV8184PDR2G |
Y |
Single |
Positive |
Tracking |
0.07 |
26 |
0.35 |
0.05 |
60 |
SOIC8 EP |
0.835 |
| NCV8570MN180R2G |
NCV8570MN180R2G |
Y |
200 mA, Ultra-Low Noise, High PSSR, BiCMOS RF LDO Regulator |
Single |
Positive |
1.8 |
0.2 |
5.5 |
0.7 |
0.07 |
80 |
15 |
6 Pin DFN, 2 x 2.2, 0.65 Pitch |
0.335 |
| NCV8570MN250R2G |
NCV8570MN250R2G |
Y |
Single |
Positive |
2.5 |
0.2 |
5.5 |
0.17 |
0.07 |
80 |
15 |
0.335 |
| NCV8570MN275R2G |
NCV8570MN275R2G |
Y |
Single |
Positive |
2.75 |
0.2 |
5.5 |
0.15 |
0.07 |
80 |
15 |
0.335 |
| NCV8570MN280R2G |
NCV8570MN280R2G |
Y |
Single |
Positive |
2.8 |
0.2 |
5.5 |
0.15 |
0.07 |
80 |
15 |
0.335 |
| NCV8570MN300R2G |
NCV8570MN300R2G |
Y |
Single |
Positive |
3 |
0.2 |
5.5 |
0.14 |
0.07 |
80 |
15 |
0.335 |
| NCV8570MN330R2G |
NCV8570MN330R2G |
Y |
Single |
Positive |
3.3 |
0.2 |
5.5 |
0.13 |
0.07 |
80 |
15 |
0.335 |
| NCV86601D50G |
NCV86601D50G |
Y |
5.0 V / 150 mA Very Low Quiescent Current LDO w/ Reset, Delay Reset (8 ms / 128 ms) |
Single |
Positive |
5 |
0.15 |
40 |
0.3 |
0.025 |
60 |
1.238 |
| NCV86601D50R2G |
NCV86601D50R2G |
Y |
Single |
Positive |
5 |
0.15 |
40 |
0.3 |
0.025 |
60 |
1.238 |
| NCV86603DT33RKG |
NCV86603DT33RKG |
Y |
3.3 V / 150 mA Very Low Quiescent Current LDO w/ Reset, Delay Reset Select (16 ms / 64 ms) |
Single |
Positive |
3.3 |
0.15 |
40 |
0.3 |
0.025 |
60 |
1.375 |
| NCV8664D50G |
NCV8664D50G |
Y |
5.0 V / 150 mA Very Low Quiescent Current LDO |
Single |
Positive |
5 |
0.15 |
45 |
0.315 |
0.021 |
67 |
1.125 |
| NCV8664D50R2G |
NCV8664D50R2G |
Y |
Single |
Positive |
5 |
0.15 |
45 |
0.315 |
0.021 |
67 |
1.125 |
| NCV8665DS50G |
NCV8665DS50G |
Y |
5.0 V / 150 mA Very Low Quiescent Current LDO with Reset and Delay Reset |
Single |
Positive |
5 |
0.15 |
45 |
0.25 |
0.03 |
5 LEAD D2PAK |
1.475 |
| NCV8665DS50R4G |
NCV8665DS50R4G |
Y |
Single |
Positive |
5 |
0.15 |
45 |
0.25 |
0.03 |
5 LEAD D2PAK |
1.475 |
| NCV8665D50G |
NCV8665D50G |
Y |
Single |
Positive |
5 |
0.15 |
45 |
0.25 |
0.03 |
| NCV8665D50R2G |
NCV8665D50R2G |
Y |
Single |
Positive |
5 |
0.15 |
45 |
0.25 |
0.03 |
| CS8151D2G |
CS8151D2G |
Y |
5V, 100mA Low Dropout Linear Regulator with WATCHDOG, RESETbar, & WAKE UP |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
SOIC 14 LEAD |
| CS8151D2R2G |
CS8151D2R2G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
SOIC 14 LEAD |
| CS5253B-1GDPR5G |
CS5253B-1GDPR5G |
Y |
3 A, Adjustable, ±1.5% Tolerance Low Dropout Voltage Regulator |
Single |
Positive |
Adjustable |
3 |
6 |
0.4 |
5 LEAD D2PAK |
1.6 |
| CS5253B-8GDP5G |
CS5253B-8GDP5G |
Y |
3 A, 2.5 V, Linear Regulator |
Single |
Positive |
2.5 |
3 |
6 |
0.4 |
5 LEAD D2PAK |
1.88 |
| CS5253B-8GDPR5G |
CS5253B-8GDPR5G |
Y |
Single |
Positive |
2.5 |
3 |
6 |
0.4 |
5 LEAD D2PAK |
1.88 |
| CS8101YD8G |
CS8101YD8G |
Y |
Micropower 5 V, 100 mA Low Dropout Linear Regulator |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.07 |
75 |
0.6425 |
| CS8101YDR8G |
CS8101YDR8G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.07 |
75 |
0.6425 |
| CS8101YDWF20G |
CS8101YDWF20G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.07 |
75 |
SOIC-20 WB |
0.72 |
| CS8101YDWFR20G |
CS8101YDWFR20G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.07 |
75 |
SOIC-20 WB |
0.72 |
| CS8126-1YDPSR7G |
CS8126-1YDPSR7G |
Y |
Single |
Positive |
5 |
0.75 |
60 |
0.35 |
2 |
75 |
2.0325 |
| CS8129YDW16G |
CS8129YDW16G |
Y |
Single |
Positive |
5 |
0.75 |
60 |
0.35 |
2 |
75 |
SO-16 WB |
1.6675 |
| CS8129YDWR16G |
CS8129YDWR16G |
Y |
Single |
Positive |
5 |
0.75 |
60 |
0.35 |
2 |
75 |
SO-16 WB |
1.6675 |
| CS8151CGN8G |
CS8151CGN8G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
8 LEAD PDIP |
1.2 |
| CS8151YDPS7G |
CS8151YDPS7G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
1.36 |
| CS8151YDPSR7G |
CS8151YDPSR7G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
1.36 |
| CS8151YDWF16G |
CS8151YDWF16G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
SO-16 WB |
1.2 |
| CS8151YDWFR16G |
CS8151YDWFR16G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
SO-16 WB |
1.2 |
| CS8151YNF16G |
CS8151YNF16G |
Y |
Single |
Positive |
5 |
0.1 |
60 |
0.4 |
0.4 |
75 |
PDIP-16 |
1.3375 |
| CS8182DTG |
CS8182DTG |
Y |
Micropower 200 mA Low Dropout Tracking Regulator/Line Driver |
Single |
Positive |
Tracking |
0.2 |
26 |
0.35 |
0.075 |
60 |
0.835 |
| CS8182DTRKG |
CS8182DTRKG |
Y |
Single |
Positive |
Tracking |
0.2 |
26 |
0.35 |
0.075 |
60 |
0.835 |
| CS8182YDF8G |
CS8182YDF8G |
Y |
Single |
Positive |
Tracking |
0.2 |
26 |
0.35 |
0.075 |
60 |
0.6275 |
| CS8182YDFR8G |
CS8182YDFR8G |
Y |
Single |
Positive |
Tracking |
0.2 |
26 |
0.35 |
0.075 |
60 |
0.6275 |
| CS8182YDPS5G |
CS8182YDPS5G |
Y |
Single |
Positive |
Tracking |
0.2 |
26 |
0.35 |
0.075 |
60 |
D2PAK |
1.435 |
| CS8182YDPSR5G |
CS8182YDPSR5G |
Y |
Single |
Positive |
Tracking |
0.2 |
26 |
0.35 |
0.075 |
60 |
D2PAK |
1.435 |
| CS8183YDWF20G |
CS8183YDWF20G |
Y |
Dual Micropower 200 mA Low Dropout Tracking Regulator/Line Driver |
Dual |
Positive |
Tracking |
0.2 |
45 |
0.4 |
0.075 |
60 |
SOIC-20 WB |
1.5 |
| CS8183YDWFR20G |
CS8183YDWFR20G |
Y |
Dual |
Positive |
Tracking |
0.2 |
45 |
1.2 |
0.075 |
60 |
SOIC-20 WB |
1.5 |
| CS8221YDFR8G |
CS8221YDFR8G |
Y |
Single |
Positive |
5 |
0.1 |
26 |
0.4 |
0.562 |
| CS8221YDP3G |
CS8221YDP3G |
Y |
Single |
Positive |
5 |
0.1 |
26 |
0.4 |
D2PAK-3 |
1.1 |
| CS8221YDPR3G |
CS8221YDPR3G |
Y |
Single |
Positive |
5 |
0.1 |
26 |
0.4 |
D2PAK-3 |
1.1 |
| CS8361YDPS7G |
CS8361YDPS7G |
Y |
5 V Dual Micropower Low Dropout Regulator |
Dual |
Positive |
5 |
0.25 |
60 |
0.4 |
0.14 |
70 |
1.2533 |
| CS8361YDPSR7G |
CS8361YDPSR7G |
Y |
Dual |
Positive |
5 |
0.25 |
60 |
0.4 |
0.14 |
70 |
1.2533 |
| CS8361YDWF16G |
CS8361YDWF16G |
Y |
Dual |
Positive |
5 |
0.25 |
60 |
0.4 |
0.14 |
70 |
SO-16 WB |
1.12 |
| CS8361YDWFR16G |
CS8361YDWFR16G |
Y |
Dual |
Positive |
5 |
0.25 |
60 |
0.4 |
0.14 |
70 |
SO-16 WB |
1.12 |
| L4949DG |
L4949DG |
Y |
5V, 100 mA, Low Dropout Voltage Regulator with Power-On Reset |
Single |
Positive |
5 |
0.1 |
28 |
0.3 |
0.8133 |
| L4949DR2G |
L4949DR2G |
Y |
Single |
Positive |
5 |
0.1 |
28 |
0.4 |
0.8133 |
| L4949NG |
L4949NG |
Y |
Single |
Positive |
5 |
0.1 |
28 |
0.3 |
8 LEAD PDIP |
0.8266 |
| LM2931ACD2TR4 |
LM2931ACD2TR4 |
N |
100 mA, Adjustable Output 3-24 V, LDO Voltage Regulator with 60 V Load Dump Protection |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
5 LEAD D2PAK |
0.8266 |
| LM2931ACD2TR4G |
LM2931ACD2TR4G |
Y |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
5 LEAD D2PAK |
0.48 |
| LM2931ACDG |
LM2931ACDG |
Y |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
0.2667 |
| LM2931ACDR2 |
LM2931ACDR2 |
N |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
0.5733 |
| LM2931ACDR2G |
LM2931ACDR2G |
Y |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
0.2667 |
| LM2931ACTV |
LM2931ACTV |
N |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
TO-220 5 LEAD OFFSET |
0.5867 |
| LM2931ACTVG |
LM2931ACTVG |
Y |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
0.52 |
| LM2931AD-5.0G |
LM2931AD-5.0G |
Y |
100 mA, 5 V, Low Dropout Voltage Regulator with 60 V Load Dump Protection |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.52 |
| LM2931AD-5.0R2 |
LM2931AD-5.0R2 |
N |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.52 |
| LM2931AD-5.0R2G |
LM2931AD-5.0R2G |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.52 |
| LM2931AD2T-5.0G |
LM2931AD2T-5.0G |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
3 LEAD D2PAK |
0.4667 |
| LM2931AD2T-5R4G |
LM2931AD2T-5R4G |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
3 LEAD D2PAK |
0.4667 |
| LM2931ADT-5.0G |
LM2931ADT-5.0G |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.36 |
| LM2931ADT-5.0RKG |
LM2931ADT-5.0RKG |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.36 |
| LM2931AT-5.0G |
LM2931AT-5.0G |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.56 |
| LM2931AZ-5.0G |
LM2931AZ-5.0G |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
TO-92 (TO-226) 5.33mm Body Height |
0.2533 |
| LM2931AZ-5.0RAG |
LM2931AZ-5.0RAG |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.2533 |
| LM2931AZ-5.0RPG |
LM2931AZ-5.0RPG |
Y |
Single |
Positive |
5 |
0.1 |
40 |
0.16 |
0.2533 |
| LM2931CD2TG |
LM2931CD2TG |
Y |
100 mA, Adjustable Output 3-24 V, Low Dropout Voltage Regulator with 60 V Load Dump Protection |
Single |
Positive |
Adjustable |
0.1 |
40 |
0.16 |
5 LEAD D2PAK |
0.52 |
