龙人旗下深圳市龙芯世纪科技有限公司
  • DC-DC电流模式转换器选型指南(含参考价格)
  • 发布时间:   修改时间:2008/10/20 15:21:50 浏览次数:807
  • 首页ON 安森美直流-直流(DC-DC)控制器、转换器和稳压器
    转换器
    安森美半导体为直流-直流转换应用提供创新优化的解决方案,如主板VRM应用、48 V电信设备板载功率传输和新兴42V汽车系统中的多相控制器。
    Microsoft Office Excel 文档格式直流-直流(DC-DC)转换器Excel 文档格式选型指南
    Product 数据手册DataSheet 下载 Pb-free Description Topology Mode VCC Min (V) VCC Max (V) VO Typ (V) IO Typ (A) Efficiency (%) fSW Typ (kHz) Package Price
    NCP5810DMUTXG NCP5810DMUTXG Y AMOLED Power Supply IC Multimode   2.7 4.6 4.6 plus -2.0 to -15.0   83 1700 UDFN12 3x3, 0.5P $1.2
    NCV3163MNR2G NCV3163MNR2G Y 3.4 A, StepUp/Down/Inverting Switching Regulator (50-300 kHz) (ext temp - Auto) Step-Down   2.5 40   3   Up to 300 DFN18 6x5, 0.5p $1.4
    NCP3064BDR2G NCP3064BDR2G Y 1.5A Switching Regulator with Enable Boost   3 40   1.5   150 SOIC-8 Narrow Body
    NCP3064BMNTXG NCP3064BMNTXG Y 1.5A Switching Regulator with Enable Step-Up/Step-Down   3 40   1.5   150 8 PIN DFN, 4x4
    NCP3064BPG NCP3064BPG Y 1.5A Switching Regulator with Enable Non-Inverting Buck/Boost   3 40   1.5   150 8 LEAD PDIP
    NCP3064DR2G NCP3064DR2G Y 1.5A Switching Regulator with Enable Step-Up/Step-Down   3 40   1.5   150 SOIC-8 Narrow Body
    NCP3064MNTXG NCP3064MNTXG Y 1.5A Switching Regulator with Enable Step-Down   3 40   1.5   150 8 PIN DFN, 4x4
    NCP3064PG NCP3064PG Y 1.5A Switching Regulator with Enable PFM Step-up   3 40   1.5   150 8 LEAD PDIP
    NCP3066DR2G NCP3066DR2G Y Constant Current Buck Regulator for HB LEDs w/ ENABLE Step-Down   3 40   1.5   250 SOIC-8 Narrow Body
    NCP3066MNTXG NCP3066MNTXG Y Constant Current Buck Regulator for HB LEDs w/ ENABLE SEPIC   3 40   1.5   250 8 PIN DFN, 4x4
    NCP3066PG NCP3066PG Y Constant Current Buck Regulator for HB LEDs w/ ENABLE Boost   3 40   1.5   250 8 LEAD PDIP
    NCV3064DR2G NCV3064DR2G Y 1.5 A Constant Current Switching Regulator for LEDs with Enable Boost   3 40   1.5   Up to 300 SOIC-8 Narrow Body
    NCV3064MNTXG NCV3064MNTXG Y 1.5 A Constant Current Switching Regulator for LEDs with Enable Step-Up/Step-Down   3 40   1.5   Up to 300 8 PIN DFN, 4x4
    NCV3064PG NCV3064PG Y 1.5 A Constant Current Switching Regulator for LEDs with Enable Buck   3 40   1.5   Up to 300 8 LEAD PDIP
    NCV3066DR2G NCV3066DR2G Y 1.5A Sw Reg with Enable for HB LEDs SEPIC   3 40   1.5   Up to 300 SOIC-8 Narrow Body
    NCV3066MNTXG NCV3066MNTXG Y 1.5A Sw Reg with Enable for HB LEDs Step-Up/Step-Down   3 40   1.5   Up to 300 8 PIN DFN, 4x4
    NCV3066PG NCV3066PG Y 1.5A Sw Reg with Enable for HB LEDs Boost   3 40   1.5   Up to 300 8 LEAD PDIP
    CS5101EDW16G CS5101EDW16G Y 1.5 A PWM Secondary Side Post Regulator     8 45 4.8 to 5.2 1.5     SO-16 WB $2.1866
    CS5101EDWR16G CS5101EDWR16G Y 1.5 A PWM Secondary Side Post Regulator     8 45 4.8 to 5.2 1.5     SO-16 WB $2.1866
    CS5101EN14G CS5101EN14G Y 1.5 A PWM Secondary Side Post Regulator     8 45 4.8 to 5.2 1.5     PDIP-14 $2.1866
    CS51411ED8G CS51411ED8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.94
    CS51411EDR8G CS51411EDR8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.94
    CS51411EMNR2G CS51411EMNR2G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5     DFN18 6x5, 0.5p $1.28
    CS51411GD8G CS51411GD8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.91
    CS51411GDR8G CS51411GDR8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.91
    CS51411GMNR2G CS51411GMNR2G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5     DFN18 6x5, 0.5p $1.24
    CS51412ED8G CS51412ED8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.94
    CS51412EDR8G CS51412EDR8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.94
    CS51412EMNR2G CS51412EMNR2G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   260 DFN18 6x5, 0.5p $0.96
    CS51412GD8G CS51412GD8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.91
    CS51412GDR8G CS51412GDR8G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   260 SOIC-8 Narrow Body $0.91
    CS51412GMNR2G CS51412GMNR2G Y 1.5 A, 260 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   260 DFN18 6x5, 0.5p $0.93
    CS51413ED8G CS51413ED8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.94
    CS51413EDR8G CS51413EDR8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.94
    CS51413EMNR2G CS51413EMNR2G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   520 DFN18 6x5, 0.5p $0.96
    CS51413GD8G CS51413GD8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.91
    CS51413GDR8G CS51413GDR8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.91
    CS51413GMNR2G CS51413GMNR2G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with Synchronization Buck V<sup>2</sup> 4.5 40   1.5   520 DFN18 6x5, 0.5p $0.93
    CS51414ED8G CS51414ED8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.94
    CS51414EDR8G CS51414EDR8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.94
    CS51414GD8G CS51414GD8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.91
    CS51414GDR8 CS51414GDR8 N 1.5 A, 520 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $1.2533
    CS51414GDR8G CS51414GDR8G Y 1.5 A, 520 kHz Low Voltage Buck Regulator with External Bias Buck V<sup>2</sup> 4.5 40   1.5   520 SOIC-8 Narrow Body $0.91
    CS5171ED8G CS5171ED8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.72
    CS5171EDR8G CS5171EDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.72
    CS5171GD8G CS5171GD8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.7
    CS5171GDR8G CS5171GDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.7
    CS5172ED8G CS5172ED8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.72
    CS5172EDR8G CS5172EDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.72
    CS5172GD8G CS5172GD8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.7
    CS5172GDR8G CS5172GDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 500 SOIC-8 Narrow Body $0.7
    CS5173ED8G CS5173ED8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.72
    CS5173EDR8G CS5173EDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.72
    CS5173GD8G CS5173GD8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.7
    CS5173GDR8G CS5173GDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator PWM Step-up Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.7
    CS5174ED8G CS5174ED8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.72
    CS5174EDR8G CS5174EDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.72
    CS5174GD8G CS5174GD8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.7
    CS5174GDR8G CS5174GDR8G Y 1.5 A, 280 / 560 kHz Boost Regulator   Current Mode 2.7 30   1.5   Up to 1000 SOIC-8 Narrow Body $0.7
    LM2574DW-ADJR2G LM2574DW-ADJR2G Y 0.5 A, Adjustable 1.23-37 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 1.23 to 37 0.5     SO-16 WB $1.16
    LM2574N-005G LM2574N-005G Y 0.5 A, 5 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 5 0.5     8 LEAD PDIP $1.16
    LM2574N-015G LM2574N-015G Y 0.5 A, 15 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 15 0.5     8 LEAD PDIP $1.16
    LM2574N-12G LM2574N-12G Y 0.5 A, 12 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 12 0.5     8 LEAD PDIP $1.16
    LM2574N-3.3G LM2574N-3.3G Y 0.5 A, 3.3 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 3.3 0.5     8 LEAD PDIP $1.16
    LM2574N-5G LM2574N-5G Y 0.5 A, 5 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 5 0.5     8 LEAD PDIP $1.16
    LM2574N-ADJG LM2574N-ADJG Y 0.5 A, Adjustable 1.23-37 V, 52 kHz Buck PWM Switiching Regulator Step-Down Voltage Mode 7 40 1.23 to 37 0.5     8 LEAD PDIP $1.16
    LM2575D2T-012G LM2575D2T-012G Y 1 A, 12 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 12 1     5 LEAD D2PAK $1.72
    LM2575D2T-015G LM2575D2T-015G Y 1 A, 15 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 15 1     5 LEAD D2PAK $1.72
    LM2575D2T-12R4G LM2575D2T-12R4G Y 1 A, 12 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 12 1     5 LEAD D2PAK $1.72
    LM2575D2T-15R4G LM2575D2T-15R4G Y 1 A, 15 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 15 1     5 LEAD D2PAK $1.72
    LM2575D2T-3.3G LM2575D2T-3.3G Y 1 A, 3.3 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 3.3 1     5 LEAD D2PAK $1.72
    LM2575D2T-3.3R4G LM2575D2T-3.3R4G Y 1 A, 3.3 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 3.3 1     5 LEAD D2PAK $1.72
    LM2575D2T-5G LM2575D2T-5G Y 1 A, 5 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 5 1     5 LEAD D2PAK $1.72
    LM2575D2T-5R4G LM2575D2T-5R4G Y 1 A, 5 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 5 1     5 LEAD D2PAK $1.72
    LM2575D2T-ADJG LM2575D2T-ADJG Y 1 A, Adjustable 1.23-37 V, 52 kHz Buck PWM Switching Regulator Step-Down Voltage Mode 7 40 1.23 to 37 1     5 LEAD D2PAK $1.72
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
