龙人旗下深圳市龙芯世纪科技有限公司
  • 直流-直流(DC-DC)电流模式控制器选型指南(含参考价格)
  • 发布时间:   修改时间:2008/10/20 15:20:26 浏览次数:684
  • 首页ON 安森美直流-直流(DC-DC)控制器、转换器和稳压器
    控制器
    安森美半导体为直流-直流转换应用提供创新优化的解决方案,如主板VRM应用、48 V电信设备板载功率传输和新兴42V汽车系统中的多相控制器。
    Microsoft Office Excel 文档格式直流-直流(DC-DC)控制器Excel 文档格式选型指南
    Product 数据手册DataSheet 下载 Pb-free Description Phases Mode VCC Min (V) VCC Max (V) fSW Typ (kHz) tres Typ (ns) Package Price
    NCP1034DR2G NCP1034DR2G Y 100V Sync Buck Con 1   8 100 Up to 500   SOIC 16 LEAD $2.0
    NCP1586DR2GH NCP1586DR2GH Y Low Voltage Synchro 1 Current/Voltage Mode 4.5 13.2 275 30 SOIC-8 Narrow Body $0.4533
    NCP1587DR2G NCP1587DR2G Y Buck Controller             SOIC-8 Narrow Body $0.3333
    NCP5386AMNR2G NCP5386AMNR2G Y 1/2 Phase Controller 1/2       100 - 1000   32 QFN, 5 x 5 mm, 0 $0.7066
    NCP5386MNR2G NCP5386MNR2G Y 1/2 Phase Controller 1/2       100 - 1000   32 QFN, 5 x 5 mm, 0 $0.7066
    NCP5392MNR2G NCP5392MNR2G Y VR11.1 4 Phase Con 2/3/4 Current/Voltage Mode 4.75 5.25 100 - 1000 10 QFN40 6x6, 0.5P $0.9333
    NCP5392PMNR2G NCP5392PMNR2G Y VR11.1 4 Phase Con 2/3/4 Current/Voltage Mode 4.75 5.25 100 - 1000 10 QFN40 6x6, 0.5P $0.9333
    NCV8851DBG NCV8851DBG Y Automotive Grade Sy 1     40 Adjustable   TSSOP 20 LEAD $1.6
    NCV8851DBR2G NCV8851DBR2G Y Automotive Grade Sy 1     40 Adjustable   TSSOP 20 LEAD $1.6
    NCP1080DEG NCP1080DEG Y Integrated PoE-PD & 1 Current Mode 0 57 250 37 TSSOP-20 EP, 6.5x4
    NCP1080DER2G NCP1080DER2G Y Integrated PoE-PD & 1 Current Mode 0 57 250 37 TSSOP-20 EP, 6.5x4
    NCP1081DEG NCP1081DEG Y Integrated 40 W High 1     57 250 37 TSSOP-20 EP, 6.5x4
    NCP1081DER2G NCP1081DER2G Y Integrated 40 W High 1     57 250 37 TSSOP-20 EP, 6.5x4
    ADP3190AJRUZ-RL ADP3190AJRUZ-RL Y CMOS version of the             TSSOP-28 9.7x4.4 $1.4133
    ADP3196JCPZ-RL ADP3196JCPZ-RL Y 2- to 4-Phase Synchr 2/3/4 Current/Voltage Mode 6 14.5 100 - 1000     $1.8533
    ADP3198JCPZ-RL ADP3198JCPZ-RL Y Synchronous buck c 2/3/4 Current/Voltage Mode 6 14.5 100 - 1000   LFCSP40, 6x6, 0.5P $1.6133
    ADP3290JCPZ-RL ADP3290JCPZ-RL Y VR11.1 4-Phase solu 2/3/4 Current/Voltage Mode 6 14.5 100 - 1000   LFCSP40, 6x6, 0.5P $5.3065
    ADP3293JCPZ-RL ADP3293JCPZ-RL Y VR11.1 8-Bit, Progra 2/3 Current/Voltage Mode 6 14.5 100 - 1000   LFCSP40, 6x6, 0.5P $4.5986
    CS51021AEDR16G CS51021AEDR16G Y Enhanced Current M 1 Current Mode 8.2 20 Adj.   SOIC 16 LEAD $1.7333
    CS51022ADBG CS51022ADBG Y Enhanced Current M 1 Current Mode 8.2 20 Up to 1000   TSSOP-16 $1.6666
    CS51022ADBR2G CS51022ADBR2G Y Enhanced Current M 1 Current Mode 8.2 20 Adj.   TSSOP-16 $1.6666
    CS51022AEDR16G CS51022AEDR16G Y Enhanced Current M 1 Current Mode 8.2 20 Adj.   SOIC 16 LEAD $1.7333
    CS51031GD8G CS51031GD8G Y Hysteretic PFET Buc 1 Hysteretic 4.5 16 200   SOIC-8 Narrow Body $0.6667
    CS51031GDR8G CS51031GDR8G Y Hysteretic PFET Buc 1 Hysteretic 4.5 16 200   SOIC-8 Narrow Body $0.6667
    CS51031YD8G CS51031YD8G Y Hysteretic PFET Buc 1 Hysteretic 4.5 16 200   SOIC-8 Narrow Body $0.6667
    CS51031YDR8G CS51031YDR8G Y Hysteretic PFET Buc 1 Hysteretic 4.5 16 200   SOIC-8 Narrow Body $0.6667
    CS51033GD8 CS51033GD8 N Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $1.04
    CS51033GD8G CS51033GD8G Y Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $0.6667
    CS51033GDR8G CS51033GDR8G Y Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $0.6667
    CS51033YD8 CS51033YD8 N Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $1.08
    CS51033YD8G CS51033YD8G Y Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $0.6667
    CS51033YDR8 CS51033YDR8 N Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $1.08
    CS51033YDR8G CS51033YDR8G Y Fast PFET Buck Con 1 Hysteretic 3.135 3.465 200   SOIC-8 Narrow Body $0.6667
    CS5124XD8G CS5124XD8G Y Integrated Current Mo 1 Current Mode 7.6 75 400   SOIC-8 Narrow Body $1.17
    CS5124XDR8G CS5124XDR8G Y Integrated Current Mo 1 Current Mode 7.6 75 400   SOIC-8 Narrow Body $1.17
    CS5157HGD16 CS5157HGD16 N CPU 5-Bit Synchrono 1 V<sup>2</sup> 4.25 20 1000 100 SOIC 16 LEAD $2.1866
    CS5157HGD16G CS5157HGD16G Y CPU 5-Bit Synchrono 1 V<sup>2</sup> 4.25 20 1000 100 SOIC 16 LEAD $2.0
    CS5157HGDR16 CS5157HGDR16 N CPU 5-Bit Synchrono 1 V<sup>2</sup> 4.25 20 1000 100 SOIC 16 LEAD $2.1866
    CS5157HGDR16G CS5157HGDR16G Y CPU 5-Bit Synchrono 1 V<sup>2</sup> 4.25 20 1000 100 SOIC 16 LEAD $2.0
    CS5165AGDW16 CS5165AGDW16 N 5-Bit Synchronous C 1 V<sup>2</sup> 8 14 1000 130 SO-16 WB $2.2133
    CS5165AGDW16G CS5165AGDW16G Y 5-Bit Synchronous C 1 V<sup>2</sup> 8 14 1000 130 SO-16 WB $1.6666
    CS5165AGDWR16G CS5165AGDWR16G Y 5-Bit Synchronous C 1 V<sup>2</sup> 8 14 1000 130 SO-16 WB $1.6666
    CS5301GDW32G CS5301GDW32G Y 3 Phase Buck Contro 3 V<sup>2</sup> 4.7 14 800   SOIC-32, WB $2.9999
    CS5301GDWR32 CS5301GDWR32 N 3 Phase Buck Contro 3 V<sup>2</sup> 4.7 14 800   SOIC-32, WB $4.0799
    CS5301GDWR32G CS5301GDWR32G Y 3 Phase Buck Contro 3 V<sup>2</sup> 4.7 14 800   SOIC-32, WB $2.9999
    MC33470DW MC33470DW N 1 Phase 5-Bit Synchr 1   4.5 5.5 300   SOIC-20 WB $2.0
    MC33470DWG MC33470DWG Y 1 Phase 5-Bit Synchr 1   4.5 5.5 300   SOIC-20 WB $2.0
    MC33470DWR2 MC33470DWR2 N 1 Phase 5-Bit Synchr 1   4.5 5.5 300   SOIC-20 WB $2.0
    MC33470DWR2G MC33470DWR2G Y 1 Phase 5-Bit Synchr 1   4.5 5.5 300   SOIC-20 WB $2.0
    NCP1282BDR2G NCP1282BDR2G Y Active Clamp / Reset 1 Voltage Mode 8 20 Adj.   SOIC 16 LEAD $1.6
    NCP1571D NCP1571D N Low Voltage Synchro 1 V<sup>2</sup> 11.4 12.6 200 200 SOIC-8 Narrow Body $0.6933
    NCP1571DG NCP1571DG Y Low Voltage Synchro 1 V<sup>2</sup> 11.4 12.6 200 200 SOIC-8 Narrow Body $0.6933
    NCP1571DR2G NCP1571DR2G Y Low Voltage Synchro 1 V<sup>2</sup> 11.4 12.6 200 200 SOIC-8 Narrow Body $0.6933
    NCP1575D NCP1575D N Low Voltage Synchro 1 V<sup>2</sup> 9 20 200 - 400 200 SOIC-8 Narrow Body $0.6933
    NCP1575DG NCP1575DG Y Low Voltage Synchro 1 V<sup>2</sup> 9 20 200 - 400 200 SOIC-8 Narrow Body $0.6933
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
