龙人旗下深圳市龙芯世纪科技有限公司
  • 功率因数控制器选型指南(含参考价格)
  • 发布时间:   修改时间:2008/10/20 15:12:29 浏览次数:415
  • 首页ON 安森美交流-直流(AC-DC)控制器和稳压器
    功率因数控制器
    电流模式和电压模式控制器
    安森美半导体提供的控制器和稳压器涵盖多种先进拓扑结构,帮助客户开发高能效电源。
    Microsoft Office Excel 文档格式 功率因数控制器Excel 文档格式选型指南
    Product 数据手册DataSheet 下载 Pb-free Description PFC Mode Frequency Operation Mode Topology Current Limit fSW Typ (kHz) VCC Max (V) Drive Source/Sink Ty UVLO (V) Latch UVP Inhibition Package Price
    NCP1652DR2G NCP1652DR2G Y High Efficiency Singl CCM or DCM Fixed Continuous/Discontin Active Clamp Yes 100000 20 1 9.3V to 11.3V Yes Yes   SOIC 16 LEAD $1.96
    NCP1652DWR2G NCP1652DWR2G Y High Efficiency Singl CCM or DCM Fixed Continuous/Discontin Active Clamp Yes 100000 20 1 9.3V to 11.3V Yes Yes   SOIC-20 WB $1.96
    NCP1654BD65R2G NCP1654BD65R2G Y Power Factor Controll CCM Fixed Current Mode PWM Step-up Programmable Negati 65 20 1500 / 1500 10.5 - 13.75 No Yes Yes SOIC-8 Narrow Body $0.66
    MC33232D MC33232D N Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 16 300 / 300 10 - 16 No Fixed No SOIC-8 Narrow Body $1.04
    MC33232DG MC33232DG Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 16 300 / 300 10 - 16 No Fixed No SOIC-8 Narrow Body $1.04
    MC33232DR2 MC33232DR2 N Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 16 300 / 300 10 - 16 No Fixed No SOIC-8 Narrow Body $1.04
    MC33232DR2G MC33232DR2G Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 16 300 / 300 10 - 16 No Fixed No SOIC-8 Narrow Body $1.04
    MC33232PG MC33232PG Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 16 300 / 300 10 - 16 No Fixed No 8 LEAD PDIP $1.04
    MC33260DG MC33260DG Y Power Factor Controll CRM Variable Voltage Mode Boost and Follower B Current Sensing Variable 16 500 / 500 8.5 - 11 Fixed Fixed Yes SOIC-8 Narrow Body $0.64
    MC33260DR2G MC33260DR2G Y Power Factor Controll CRM Variable Voltage Mode Boost and Follower B Current Sensing Variable 16 500 / 500 8.5 - 11 Fixed Fixed Yes SOIC-8 Narrow Body $0.64
    MC33260PG MC33260PG Y Power Factor Controll CRM Variable Voltage Mode Boost and Follower B Current Sensing Variable 16 500 / 500 8.5 - 11 Fixed Fixed Yes 8 LEAD PDIP $0.78
    MC33262DG MC33262DG Y Power Factor Controll CRM Variable Current Mode Boost Current Sensing Variable 30 500 / 500 8 - 13 Fixed No Yes SOIC-8 Narrow Body $0.4267
    MC33262DR2G MC33262DR2G Y Power Factor Controll CRM Variable Current Mode Boost Current Sensing Variable 30 500 / 500 8 - 13 Fixed No Yes SOIC-8 Narrow Body $0.4267
    MC33262PG MC33262PG Y Power Factor Controll CRM Variable Current Mode Boost Current Sensing Variable 30 500 / 500 8 - 13 Fixed No Yes 8 LEAD PDIP $0.4267
    MC33368DG MC33368DG Y Power Factor Controll CRM Variable Current Mode Boost Current Sensing Variable 16 1000 / 1000 8.5 - 13 Fixed No Yes SOIC 16 Minus Pins $1.0933
    MC33368DR2G MC33368DR2G Y Power Factor Controll CRM Variable Current Mode Boost Current Sensing Variable 16 1000 / 1000 8.5 - 13 Fixed No Yes SOIC 16 Minus Pins $1.0933
    MC33368PG MC33368PG Y Power Factor Controll CRM Variable Current Mode Boost Current Sensing Variable 16 1000 / 1000 8.5 - 13 Fixed No Yes PDIP-16 $1.0933
    NCP1601ADR2G NCP1601ADR2G Y Fixed Frequency Dis CRM or DCM Fixed or Variable Voltage Mode Boost Negative Current Sen Adj. 18 500 / 800 9 - 13.75 Fixed Fixed Yes SOIC-8 Narrow Body $0.52
    NCP1601APG NCP1601APG Y Fixed Frequency Dis CRM or DCM Fixed or Variable Voltage Mode Boost Negative Current Sen Adj. 18 500 / 800 9 - 13.75 Fixed Fixed Yes 8 LEAD PDIP $0.63
    NCP1601BDR2G NCP1601BDR2G Y Fixed Frequency Dis CRM or DCM Fixed or Variable Voltage Mode Boost Negative Current Sen Adj. 18 500 / 800 9 - 10.5 Fixed Fixed Yes SOIC-8 Narrow Body $0.52
    NCP1601BPG NCP1601BPG Y Fixed Frequency Dis CRM or DCM Fixed or Variable Voltage Mode Boost Negative Current Sen Adj. 18 500 / 800 9 - 10.5 Fixed Fixed Yes 8 LEAD PDIP $0.63
    NCP1605DR2G NCP1605DR2G Y Power Factor Controll DCM Fixed Voltage Mode Boost Negative Current Sen Adj. 20 500 / 800 9 - 15 Programmable Fixed Yes SOIC 16 LEAD $0.89
    NCP1606ADR2G NCP1606ADR2G Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 20 500 / 800 9.5 - 12 Programmable Fixed Yes SOIC-8 Narrow Body $0.3
    NCP1606APG NCP1606APG Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 20 500 / 800 9.5 - 12 Programmable Fixed Yes 8 LEAD PDIP $0.36
    NCP1606BDR2G NCP1606BDR2G Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 20 500 / 800 9.5 - 12 Programmable Fixed Yes SOIC-8 Narrow Body $0.3
    NCP1606BPG NCP1606BPG Y Power Factor Controll CRM Variable Voltage Mode Boost Current Sensing Variable 20 500 / 800 9.5 - 12 Programmable Fixed Yes 8 LEAD PDIP $0.36
    NCP1650DR2G NCP1650DR2G Y Power Factor Controll CCM Fixed Average Current-Mod Boost Negative Current Sen Adj. 20 1500 / 1500 10 - 10.5 Fixed No Yes SOIC 16 LEAD $1.6
    NCP1651DR2G NCP1651DR2G Y Single-Stage, Fixed CCM or DCM Fixed Average Current-Mod Boost Current Sensing Adj. 18 1500 / 1500 9.8 - 10.8 No Yes Yes SOIC 16 LEAD $1.82
    NCP1653ADR2G NCP1653ADR2G Y Fixed-Frequency, Co CCM Fixed Average Current-Mod Boost and Follower B Programmable Negati 67 18 1000 / 1000 8.7 - 13.25 Fixed Fixed Yes SOIC-8 Narrow Body $0.62
    NCP1653APG NCP1653APG Y Fixed-Frequency, Co CCM Fixed Average Current-Mod Boost and Follower B Programmable Negati 67 18 1000 / 1000 8.7 - 13.25 Fixed Fixed Yes 8 LEAD PDIP $0.66
    NCP1653DR2G NCP1653DR2G Y Fixed-Frequency, Co CCM Fixed Average Current-Mod Boost and Follower B Programmable Negati 100 18 1000 / 1000 8.7 - 13.25 Fixed Fixed Yes SOIC-8 Narrow Body $0.62
    NCP1653PG NCP1653PG Y Fixed-Frequency, Co CCM Fixed Average Current-Mod Boost and Follower B Programmable Negati 100 18 1000 / 1000 8.7 - 13.25 Fixed Fixed Yes 8 LEAD PDIP $0.66
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
