龙人旗下深圳市龙芯世纪科技有限公司
  • Intersil数字电位器
  • 发布时间:2011/9/17 14:57:48   修改时间:2008/9/21 21:57:42 浏览次数:631
  • Digital Potentiometers (DCPs)数字电位器
    Digitally Controlled Potentiometers (数字电位器DCPs)
    Digitally Controlled Capacitors (数控电容 DCCs)
    Digitally Controlled Potentiometers (DCPs) Non-Volatile Single - 16 Tap
    型号 数据手册DataSheet下载 Bus Interface Type Resistance Options (kù) VCC Range (V) V+, V- Supply Range (V) Terminal Voltage Range VL to VH (V) Resistance Taper Wiper Current (mA) Wiper Resistance (ù) Standby Current ISB (μA) 温度范围
    X9116 X9116 3-Wire (Up/Down) 10 2.7 to 5.5   0 to VCC Linear ±1 200 1 8 Ld MSOP,8 Ld SOIC
    Single - 32 Tap
    X9313 X9313 3-Wire (Up/Down) 1, 10, 50 3.0 to 5.5   -VCC to +VCC Linear ±1 40 500 8 Ld MSOP,8 Ld PDIP, 8 Ld SOIC
    X9314 X9314 3-Wire (Up/Down) 10 3.0 to 5.5   -VCC to +VCC Logarithmic ±1 40 500 8 Ld MSOP,8 Ld PDIP, 8 Ld SOIC
    X9315 X9315 3-Wire (Up/Down) 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±1 200 1 8 Ld MSOP,8 Ld PDIP, 8 Ld SOIC
    X93154 X93154 3-Wire (Up/Down) 50 2.7 to 3.3   0 to VCC Linear ±0.6 1k 1 8 Ld DFN,8 Ld MSOP
    X93155 X93155 3-Wire (Up/Down) 50 4.5 to 5.5   0 to VCC Linear 0.6 1k 2 8 Ld MSOP
    X93156 X93156 3-Wire (Up/Down) 12.5, 50 2.7 to 5.5   0 to VCC Linear 0.6 1k 1 8 Ld MSOP
    X9511 X9511 Push Button 10 4.5 to 5.5   -VCC to +VCC Linear ±1 40 200 8 Ld PDIP,8 Ld SOIC
    Single - 64 Tap
    X9428 X9428 2-Wire 2.5, 10 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear ±6 150 1 14 Ld TSSOP,16 Ld PDIP,16 Ld SOIC
    X9429 X9429 2-Wire 2.5, 10 2.7 to 5.5   0 to VCC Linear ±3 250 5 14 Ld TSSOP,16 Ld SOIC,18 Ld PDIP
    Single - 100 Tap
    X9317 X9317 3-Wire (Up/Down) 1, 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±1 200 1 8 Ld MSOP,8 Ld PDIP, 8 Ld SOIC, 8 Ld TSSOP
    X9318 X9318 3-Wire (Up/Down) 10 4.5 to 5.5   0 to +5 Linear ±1 200 300 8 Ld PDIP,8 Ld SOIC
    X9319 X9319 3-Wire (Up/Down) 10, 50 4.5 to 5.5   0 to +10 Linear ±1 40 300 8 Ld PDIP,8 Ld SOIC
    X9C102 X9C102 3-Wire (Up/Down) 1 4.5 to 5.5   -VCC to +VCC Linear ±1 40 750 8 Ld PDIP,8 Ld SOIC
    X9C103 X9C103 3-Wire (Up/Down) 10 4.5 to 5.5   -VCC to +VCC Linear ±1 40 750 8 Ld PDIP,8 Ld SOIC
    X9C104 X9C104 3-Wire (Up/Down) 100 4.5 to 5.5   -VCC to +VCC Linear ±1 40 750 8 Ld PDIP,8 Ld SOIC
    X9C303 X9C303 3-Wire (Up/Down) 32 4.5 to 5.5   -VCC to +VCC Logarithmic ±1 40 750 8 Ld PDIP,8 Ld SOIC, 8 Ld TSSOP
    X9C503 X9C503 3-Wire (Up/Down) 50 4.5 to 5.5   -VCC to +VCC Linear ±1 40 750 8 Ld PDIP,8 Ld SOIC
    Single - 128 Tap
    ISL22316 ISL22316 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 5 10 Ld MSOP
    ISL22416 ISL22416 SPI 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 5 10 Ld MSOP
    ISL95310 ISL95310 3-Wire (Up/Down) 10, 50 2.7 to 5.5 8 to 13.2 0 to V+ Linear ±3 70 2 10 Ld MSOP
    ISL95311 ISL95311 I2C 10, 50 2.7 to 5.5 8 to 13.2 0 to V+ Linear ±3 70 2 10 Ld MSOP
    ISL95710 ISL95710 3-Wire (Up/Down) 10, 50 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear ±1 200 0.5 (typ) 10 Ld MSOP
    ISL95711 ISL95711 I2C 10, 50 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear ±1 200 0.5 (typ) 10 Ld MSOP
    ISL96017 ISL96017 I2C 10, 50 3.0 to 3.6   0 to VCC Linear ±3 300 10 8 Ld DFN
    ISL22319 ISL22319 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 850 8 Ld MSOP
    ISL22419 ISL22419 SPI 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 850 8 Ld MSOP
    Single - 256 Tap
    X9279 X9279 2-Wire 50, 100 2.7 to 5.5   0 to VCC Linear ±3 150 5 14 Ld TSSOP,18 Ld PDIP
    ISL95810 ISL95810 I2C 10, 50 2.7 to 5.5   0 to VCC Linear 1 200 5 8 Ld DFN,8 Ld MSOP
    X9271 X9271 SPI 50, 100 2.7 to 5.5   0 to +5.0 Linear ±3 150 5 14 Ld TSSOP
    Single - 1024 Tap
    X9118 X9118 2-Wire 100 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±3 100 3 14 Ld TSSOP
    X9119 X9119 2-Wire 100 2.7 to 5.5   V- to V+ Linear ±3 100 3 14 Ld TSSOP
    X9110 X9110 SPI 100 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 0 to VCC Linear ±3 150 3 14 Ld TSSOP
    X9111 X9111 SPI 100 2.7 to 5.5   0 to VCC Linear ±3 150 3 14 Ld TSSOP
    Dual - 32 Tap
    X93254 X93254 3-Wire (Up/Down) 50 2.7 to 3.3   0 to VCC Linear 0.6 1k 1 14 Ld TSSOP
    X93255 X93255 3-Wire (Up/Down) 50 4.5 to 5.5   0 to VCC Linear 0.6 1k 4 14 Ld TSSOP
    X93256 X93256 3-Wire (Up/Down) 12.5, 50 2.7 to 5.5   0 to VCC Linear 0.6 1k 1 14 Ld TSSOP
    Dual - 64 Tap
    X9221A X9221A 2-Wire 2, 10, 50 4.5 to 5.5   -3.0 to VCC Linear ±1 130 500 20 Ld PDIP,20 Ld SOIC
    X9418 X9418 2-Wire 2.5, 10 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear ±3 150 1 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    X9410 X9410 SPI 10 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear ±3 150 1 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    Dual - 128 Tap
    ISL22326 ISL22326 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 5 14 Ld TSSOP
    ISL22329 ISL22329 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 850 10 Ld MSOP
    ISL22426 ISL22426 SPI 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 5 14 Ld TSSOP
    ISL22429 ISL22429 SPI 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 850 10 Ld MSOP
    Dual - 256 Tap
    X9268 X9268 2-Wire 50, 100 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±3 150k 5 24 Ld SOIC,24 Ld TSSOP
    X95820 X95820 I2C 10, 50 2.7 to 5.5   0 to VCC Linear 1 200 5 14 Ld TSSOP
    X9455 X9455 2-Wire, 3-Wire(Up-Down) 2, 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±3 150 20 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    X9260 X9260 SPI 50, 100 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±3 150k 5 24 Ld SOIC,24 Ld TSSOP
    X9261 X9261 SPI 50, 100 2.7 to 5.5   0 to VCC Linear ±3 150k 5 24 Ld SOIC,24 Ld TSSOP
    Quad - 64 Tap
    X9241A X9241A 2-Wire 2, 10, 50 4.5 to 5.5   -3.0 to VCC Linear ±1 130 500 20 Ld PDIP,20 Ld SOIC,20 Ld TSSOP
    X9408 X9408 2-Wire 2.5, 10 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±3 150 1 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    X9409 X9409 2-Wire 2.5, 10 2.7 to 5.5   0 to VCC Linear ±3 150 1 24 Ld SOIC,24 Ld TSSOP
    X9400 X9400 SPI 2.5, 10 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±3 150 1 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    X9401 X9401 SPI 2.5, 10 2.7 to 5.5   0 to VCC Linear ±3 150 1 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    Quad - 128 Tap
    型号 数据手册DataSheet下载 Bus Interface Type Resistance Options (kù) VCC Range (V) V+, V- Supply Range (V) Terminal Voltage Range VL to VH (V) Resistance Taper Wiper Current (mA) Wiper Resistance (ù) Standby Current ISB (μA) 封装尺寸图
    ISL22346 ISL22346 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 5 20 Ld TSSOP
    ISL22349 ISL22349 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 2400 14 Ld TSSOP
    ISL22446 ISL22446 SPI 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 5 20 Ld TSSOP
    ISL22449 ISL22449 SPI 10, 50 2.7 to 5.5   0 to VCC Linear ±3 70 2400 14 Ld TSSOP
    Quad - 256 Tap
    X9252 X9252 2-Wire, 3-Wire (Up/Down) 2, 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±3 150 100 24 Ld TSSOP
    X9258 X9258 2-Wire 50, 100 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±1 100 5 24 Ld SOIC,24 Ld TSSOP
    X9259 X9259 2-Wire 50, 100 2.7 to 5.5   0 to VCC Linear ±1 100 5 24 Ld SOIC,24 Ld TSSOP
    X95840 X95840 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±1 200 5 20 Ld TSSOP
    X9250 X9250 SPI 50, 100 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Linear ±3 150 5 24 Ld SOIC,24 Ld TSSOP
    X9251 X9251 SPI 50, 100 2.7 to 5.5   0 to VCC Linear ±3 150 3 24 Ld PDIP,24 Ld SOIC,24 Ld TSSOP
    Volatile Single - 32 Tap
    ISL90460 ISL90460 2-Pin (Up/Down) 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±0.6 600 1 5 Ld SC-70,5 Ld SOT-23
    ISL90461 ISL90461 2-Pin (Up/Down) 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±0.6 600 1 6 Ld SC-70,6 Ld SOT-23
    ISL90462 ISL90462 2-Pin (Up/Down) 10, 50, 100 2.7 to 5.5   0 to VCC Linear ±0.6 600 1 6 Ld SC-70,6 Ld SOT-23
    X9015 X9015 3-Wire (Up/Down) 10, 50 2.7 to 5.5   0 to VCC Linear ±1 200 1 8 Ld MSOP,8 Ld PDIP, 8 Ld SOIC
    Single - 128 Tap
    ISL23710 ISL23710 3-Wire (Up/Down) 10, 50 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear 1 70 0.5 10 Ld MSOP
    ISL23711 ISL23711 I2C 10, 50 2.7 to 5.5 -5.5 to -2.7 V- to VCC Linear 1 70 0.5 10 Ld MSOP
    ISL90726 ISL90726 I2C 10, 50 2.7 to 5.5   0 to VCC Linear 1 85 0.5 6 Ld SC-70
    ISL90727 ISL90727 I2C 10, 50 2.7 to 5.5   0 to VCC Linear 1 85 0.5 6 Ld SC-70
    Single - 256 Tap
    ISL90810 ISL90810 I2C 10, 50 2.7 to 5.5   0V to VCC Linear 1 200 5 8 Ld MSOP
    Dual - 32 Tap
    X9460 X9460 2-Wire 32 2.7 to 5.5 2.7 to 5.5 and -5.5 to -2.7 V- to V+ Logarithmic ±3 200 3 14 Ld TSSOP
    Quad - 256 Tap
    ISL90840 ISL90840 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 200 5 20 Ld TSSOP
    ISL90841 ISL90841 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 200 5 14 Ld TSSOP
    ISL90842 ISL90842 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 200 5 14 Ld TSSOP
    ISL90843 ISL90843 I2C 10, 50 2.7 to 5.5   0 to VCC Linear ±3 200 2800 10 Ld DFN,10 Ld MSOP
    Digitally Controlled Capacitors (DCCs)
    型号 数据手册DataSheet下载 Number of Taps Capacitance Range (pF) Step Size (pF) Bus Interface Type 温度范围
    X90100 X90100 32 7.5 to 14.5 0.22 3-Wire (Up-Down) 8 Ld MSOP
    Digitally Controlled Potentiometers – Also known as: DCP, RDAC, Variable Resistor, Voltage Divider, Digital Pot, Digital Potentiometer Intersil offers the widest selection of low-to-high resolution digitally controlled potentiometers in single dual and quad configurations. Available in both linear and non-linear tapers, these digital potentiometers replace mechanical potentiometers and trim resistors in applications where digital control allows microprocessor interfacing and extended functionality.
    Intersil 英特矽尔应用技术支持与电子电路设计开发资源下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
