龙人旗下深圳市龙芯世纪科技有限公司
  • 模数转换器 ADC Analog to Digital Converters (ADCs)Intersil 英特矽尔
  • 发布时间:2011/9/17 15:00:45   修改时间:2008/9/20 15:09:17 浏览次数:820
    1-Channel (ADCs)
    2-Channel (ADCs)
    Integrating Display Output (A- D) Data Converters
    1-Channel (ADCs) 6-Bit
    型号 数据手册DataSheet下载 Resolution (Bits) Conv. Rate (MSPS) Conv. Type Input BW (MHz) Input VIN (Range) (V) Max Power Supply (VS) INL (max) (±LSB) DNL (max) (±LSB) VREF 温度范围
    HI-5701 HI-5701 6 30 Flash 20 4 5 1.25 0.6 Ext 18 Ld SOIC
    8-Bit
    HI1175 HI1175 8 20 Flash 90 2.8 5 1.3 0.5 Int/Ext 24 Ld SOIC
    HI1179 HI1179 8 35 2-Step 60 2.6 5 +1.3, -1 0.5 Int/Ext 32 Ld MQFP
    HI2302 HI2302 8 50 2-Step 100 2 5VA, +3.3VD 0.5 0.5 Int 32 Ld MQFP
    HI3026 HI3026 8 120 Flash 150 2 +5, ±5 0.5 0.5 Ext 48 Ld MQFP
    HI3276 HI3276 8 160 Flash 250 2 +5, ±5 0.5 0.5 Ext 48 Ld MQFP
    HI5714 HI5714 8 40, 75 2-Step Folding 18 2.7 5 0.75 0.4 Ext 24 Ld SOIC
    10-Bit
    HI5746 HI5746 10 40 Pipeline 250 1 +5VA, +3VD 2 1 Ext 28 Ld SOIC,28 Ld SSOP
    HI5766 HI5766 10 60 Pipeline 250 1 +5VA, +3VD 2 1 Ext 28 Ld SOIC,28 Ld SSOP
    HI5767 HI5767 10 20, 40, 60 Pipeline 250 1 +5VA, +3VD 1.75 1 Int/Ext 28 Ld SOIC,28 Ld SSOP
    12-Bit
    HI-574A HI-574A 12 0.04 SAR   ±10 or 0 to 20 ±12 to ±15 0.5   Int/Ext 28 Ld PDIP,28 Ld SBDIP
    HI-674A HI-674A 12 0.067 SAR   ±10 or 0 to 20 ±12 to ±15 0.5   Int/Ext 28 Ld PDIP,28 Ld SBDIP
    HI5805 HI5805 12 5 Pipeline 100 4 +5VA, +3VD 2 1 Int 28 Ld SOIC
    HI5812 HI5812 12 0.05 SAR 1 0 to 5 +3 to +6 1 2 Ext 24 Ld PDIP,24 Ld SOIC
    16-Bit
    HI7188 HI7188 16 0.002 4th OrderSigma Delta   ±2.5 ±5     Ext 44 Ld MQFP
    24-Bit
    HI7190 HI7190 24 0.002 2nd OrderSigma Delta   ±2.5 ±5     Ext 20 Ld PDIP,20 Ld SOIC
    HI7191 HI7191 24 0.002 2nd OrderSigma Delta   ±2.5 ±5     Ext 20 Ld PDIP,20 Ld SOIC
    2-Channel (ADCs) 2x8-Bit
    HI5662 HI5662 2x8 60 Pipeline 250 1 +5VA, +3VD 1 0.5 Int/Ext 44 Ld MQFP
    2x10-Bit
    HI5762 HI5762 2x10 60 Pipeline 250 1 +5VA, +3VD 2 1 Int/Ext 44 Ld MQFP
    Integrating Display Output (A-D) Data Converters
    型号 数据手册DataSheet下载 Resolution (Bits) Conv. Rate (MSPS) Conv. Type Input BW (MHz) Input VIN (Range) (V) Tech. Max Power Supply (VS) INL (max) (±LSB) DNL (max) (±LSB) VREF 温度范围
    HI-7159A HI-7159A 5.5-Digits 0.2 2-Step 1.5 2.5 to -2.5 CMOS ±5 0.5 0.5 Ext 28 Ld PDIP
    ICL7106 ICL7106 3.5-Digits 3Hz (typ) Integrating   ±0.2 CMOS ±5     Int/Ext 40 Ld PDIP, 44 Ld MQFP
    ICL7107 ICL7107 3.5-Digits 3Hz (typ) Integrating   ±0.2 CMOS ±5     Int/Ext 40 Ld PDIP, 44 Ld MQFP
    ICL7126 ICL7126 3.5-Digits 3Hz (typ) Integrating   ±0.2 CMOS ±5     Int/Ext 40 Ld PDIP
    ICL7135 ICL7135 4.5-Digits 2Hz (typ) Integrating   ±0.2 CMOS 5     Int/Ext 28 Ld PDIP
    ICL7136 ICL7136 3.5-Digits 3Hz (typ) Integrating   ±0.2 CMOS ±5     Int/Ext 40 Ld PDIP, 44 Ld MQFP
    Intersil 英特矽尔应用技术支持与电子电路设计开发资源下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
