龙人旗下深圳市龙芯世纪科技有限公司
  • Intersil 通信电路
  • 发布时间:2011/9/17 15:02:24   修改时间:2008/9/20 15:06:39 浏览次数:845
  • 通信电路
    Intersil is an industry leader in the technologies necessary to meet the growing demands of the video, data, and voice communications markets. In addition to Intersil's DSL line drivers and receivers, the recent acquisition of BitBlitz has brought world-class high speed communications capabilities that complement our 20 years' experience in telephony and Voice Over IP.
    DSL Line Drivers and Receivers 调制解调器线路收发器
    10G Ethernet 万兆以太网技术
    Voice Over IP(VoIP)
    Power Line Communications (电力线通信 PLC)
    Laser Diode Control 激光二极管控制
    SerDes 串行器/解串器
    DSL Line Drivers
    型号 数据手册DataSheet下载 BW @ -3dB (MHz) VS (min) (V) VS (max) (V) IS (mA) Slew Rate (V/μs) IOUT (mA) VOUT @100ù (V) Power Consumption (mW) Harmonic Distortion @ 200kHz (dBc) Function 温度范围
    EL1503A EL1503A 80 ±4.5 ±13.2 12.5 1200 450 ±10.6 900 -70 CO Driver 20 Ld SOIC, 24 Ld QFN
    EL1506 EL1506 70 ±4.5 ±13.2 4 500 360 ±10.9 750 -75 ADSL Driver 24 Ld SOIC, 28 Ld HTSSOP
    EL1507 EL1507 70 ±4.5 ±13.2 3.5 500 360 ±10.9 750 -80 DSL CO Driver 16 Ld QFN, 16 Ld SOIC
    EL1508 EL1508 50 ±4.5 ±13.2 3.5 800 450 ±10.9 700 -80 DSL CO Driver 16 Ld SOIC, 20 Ld SOIC, 24 Ld QFN
    EL1509 EL1509 70 4.5 13.2 7 500 250 10 400 -80 DSL CPE Driver 8 Ld DFN, 8 Ld SOIC
    EL1510 EL1510 70 ±4.5 ±13.2 7.5 500 250 ±10.9 400 -82 DSL CPE Driver 8 Ld DFN, 8 Ld SOIC
    EL1511 EL1511 70 4.5 16.5 3.5 500 360 13 750 -82 G.HDSL, VDSL Driver 16 Ld QFN, 16 Ld SOIC
    EL1517 EL1517 200 4.5 13.2 7 2000 250 10 400 -85 VDSL Line Driver 16 Ld QFN, 8 Ld SOIC
    EL1517A EL1517A 200 4.5 13.2 7 2000 250 10 400 -85 VDSL Line Driver 10 Ld MSOP
    EL1519 EL1519 70 4.5 13.2 7.5 500 250 10 400 -82 DSL CPE Driver 8 Ld SOIC
    EL1526 EL1526 50 ±4.5 ±13.2 2.5 600 400 ±11.0 680/Port -75 Dual Port CO 20 Ld HTSSOP, 24 Ld QFN
    EL1527 EL1527 70 ±4.5 ±13.2 3.5 500 360 ±10.9 750/Port -80 Dual Port CO 28 Ld HTSSOP
    EL1528 EL1528 40 ±4.5 ±13.2 2.7 500 400 ±11.1 680/Port -75 Dual Port CO 20 Ld HTSSOP, 24 Ld QFN
    EL1529 EL1529 50 ±4.5 ±13.2 2.5 600 400 ±11.0 680/Port -75 Dual Port CO 24 Ld QFN
    EL1537 EL1537 50 5 24 3.9 300 500 ±11.0 750/Port -75 Dual Port CO 28 Ld HTSSOP
    EL1537A EL1537A 50 5 24 3.9 300 500 ±11.0 750/Port -75 Dual Port CO 28 Ld HTSSOP
    DSL Line Receivers
    型号 数据手册DataSheet下载 iSim # of Amps BW @ -3dB (MHz) Slew Rate (Vμs) VS (min) (V) VS (max) (V) VN (nV/ √Hz) Rail- to- Rail Gain AV (min) (V) IS (per amp) (mA) IBIAS (μA) IOUT (mA) Vout (v) VOS (max) (mV) AVOL or AZOL (dB or V/mV) Enable CMRR (dB) PSRR (dB) 温度范围
    EL2227 EL2227 Y 2 115 45 2.5 13.2 1.9 N 2 4.5 3.4 100 10 3 87 N 94 95 8 Ld MSOP, 8 Ld SOIC
    EL1516 EL1516   2 220 120 4.5 12 1.3 N 2 4.5   100   3 75 N 105 80 8 Ld MSOP, 8 Ld SOIC
    EL1516A EL1516A   2 220 120 4.5 12 1.3 N 2 4.5   100   3 75 Y 105 80 10 Ld MSOP
    10G Ethernet
    型号 数据手册DataSheet下载 Data Rate (G) RMS Jitter (ps) Half Rate Supply Voltage (V) Power (W) 10 GigE Compliant JTAG BIST 温度范围
    BBT3420 BBT3420 2.5 to 3.125 <6 X 1.5/3.3 1.4 X X X 289 Ld EBGA
    BBT3821 BBT3821 2.5 to 3.2 <6 X 1.5/2.5 1.6 X X X 192 Ld BGA
    ISL35822 ISL35822 2.5 to 3.2 <6 X 1.5/2.5 1.5 X X X 192 Ld BGA
    Voice Over IP
    Subscriber Line Interface Circuits (SLICs)
    Long Loop
    型号 数据手册DataSheet下载 Longitudinal Balance (dB) Polarity Reversal Integrated Battery Switch 温度范围
    HC5503PRC HC5503PRC 58     24 Ld SOIC, 32 Ld QFN
    HC55120 HC55120 53   X 28 Ld PLCC, 28 Ld SOIC
    HC55121 HC55121 53 X X 28 Ld PLCC, 28 Ld SOIC
    HC55130 HC55130 63   X 28 Ld PLCC, 28 Ld SOIC
    HC55130B HC55130B 53     28 Ld PLCC
    HC55140 HC55140 63 X X 28 Ld PLCC, 28 Ld SOIC
    HC55142 HC55142 63 X X 28 Ld PLCC, 28 Ld SOIC
    HC55143 HC55143 63 X X 32 Ld PLCC
    HC55150 HC55150 55 X X 28 Ld PLCC, 28 Ld SOIC
    HC5515 HC5515 53     28 Ld PLCC
    HC5523 HC5523 58     28 Ld PLCC
    HC5526 HC5526 53     22 Ld PDIP, 28 Ld PLCC
    HC5549 HC5549 53 X X 28 Ld PLCC
    Short Loop PBX
    型号 数据手册DataSheet下载 Longitudinal Balance (dB) Supply Voltages Loop Current Limit (mA) Ring Relay Drivers 温度范围
    HC5503 HC5503 53 -24, +5 25 1 24 Ld SOIC
    HC5503T HC5503T 53 -24, +5 30   24 Ld SOIC
    HC5504B HC5504B 58 -48, +5 40 1 24 Ld SOIC
    Ringing SLICs
    型号 数据手册DataSheet下载 Longitudinal Balance (dB) High Battery VBH Loop Current (mA) Integrated Battery Switch Polarity Reversal 温度范围 数据手册DataSheet下载
    HC55183 HC55183 45 75 15 to 45 X   28 Ld PLCC HC55183
    HC55184 HC55184 45 75 15 to 45 X X 28 Ld PLCC HC55184
    HC55185 HC55185 58/53 100/85/75 15 to 45 X X 28 Ld PLCC, 32 Ld QFN HC55185
    ISL5585 ISL5585 58/53 100/85/75 15 to 45 X X 28 Ld PLCC, 32 Ld QFN ISL5585
    ISL5586 ISL5586 58/53 100/85/75 15 to 45 X X 28 Ld PLCC ISL5586
    Line Card Access Switches
    型号 数据手册DataSheet下载 Prot SCR 温度范围 数据手册DataSheet下载
    ISL5571A ISL5571A Yes 16 Ld SOIC ISL5571A
    Analog Crosspoint Switches
    型号 数据手册DataSheet下载 Configuration rDS(ON) (ù) Freq. Response Typ. -3dB 14V (MHz) Crosstalk Typ. -40dB 14V (MHz) VCC Range (±V) 温度范围
    CD22M3494 CD22M3494 16x8x1 36 50 10 4 to 15 40 Ld PDIP, 44 Ld PLCC
    Power Line Communications (PLC)
    型号 数据手册DataSheet下载 产品概述 BW (MHz) VS (min) (V) VS (max) (V) IS (per amp) (mA) SR (V/祍) IOUT (mA) Vout (v) Harmonic Distortion (dBc) Function 温度范围
    ISL1571 ISL1571 Power Line Communication (PLC) 250 4.5 13.2 11 1200 750 10 @ 50Ω -75 @ 17MHz PLC Line Driver 10 Ld HMSOP 10 Ld HMSOP T+R 16 Ld QFN 16 Ld QFN T+R
    ISL1572 ISL1572 Power Line Communication (PLC) 250 4.5 13.2 11 1200 750 10 @ 50Ω -75 @ 17MHz PLC Line Driver
    Laser Diode Control
    型号 数据手册DataSheet下载 # of DCPs # of Taps Interface Type Resistance Options (kù) Single Supply Dual Supply (V+, V-) VS Range 2.7V to 3.3V VS Range 2.7V to 5.5V VS Range 3.0V to 5.5V VS Range 4.5V to 5.5V Resistance Taper VL - VH (V) Wiper Current (IW) Wiper Resistance (RW @ IW) Standby Current Isb (μA) 温度范围
    X9520 X9520 Triple 64, 100, 256 2-Wire 10, 10, 100 Y   Y Y Y Y Linear 0V to VCC 4mA 400 @ 1mA 50 Eval Board, 20 Ld CSP, 20 Ld TSSOP
    X9521 X9521 Dual 100, 256 2-Wire 10, 100 Y   Y Y Y Y Linear 0V to VCC 4mA 400 @ 1mA 50 Eval Board, 20 Ld TSSOP
    X9522 X9522 Triple 64, 100, 256 2-Wire 10, 10, 100 Y   Y Y Y Y Linear 0V to VCC 4mA 400 @ 1mA 50 Eval Board, 20 Ld TSSOP
    X9523 X9523 Dual 100, 256 2-Wire 10, 100 Y   Y Y Y Y Linear 0V to VCC 4mA 400 @ 1mA 50 Eval Board, 20 Ld TSSOP
    X9525 X9525 Dual 100, 256 2-Wire 10, 50 Y   Y Y Y Y Linear 0V to VCC 4mA 400 @ 1mA 50 Eval Board, 20 Ld TSSOP
    型号 数据手册DataSheet下载 Interface Type Internal Temperature Sensor ADC with Anti-Dither Filter Option External Sensor Input Internal Voltage Reference VREF Input/ Output General Purpose EEPROM Look Up Table Organization Number of DACs FSO Current DAC Setting Resistors Current Drive Outputs 温度范围
    X9530 X9530 2-Wire Y Y Y Y Y Y Dual Bank Dual Ext/Int Sink/Source 14 Ld TSSOP
    Communications ICs - SERDES
    型号 数据手册DataSheet下载 产品概述 Function VS (V) IS (mA) Clock Rate (MHz) Format Pre-emphasis Equalization Diff Input Impedance (Ω) Interface 温度范围
    ISL34340 ISL34340 WSVGA 24-Bit Long-Reach Video Serdes with Bidirectional Side-Channel Transceiver 3.3 117 40 24-Bit Data + 3-Bit Control Y Y 100 I2C 64 Ld EPTQFP 64 Ld EPTQFP T+REval Board
    Intersil 英特矽尔应用技术支持与电子电路设计开发资源下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
