  • ARIS蝶阀ARIS执行机构
  • 发布时间:2021/7/20 7:52:04   修改时间:2021/7/20 7:52:04 浏览次数:906
  • 上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机
    ARIS    PD35
    ARIS    PE55-06
    ARIS    BE41-21003
    ARIS    ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
    ARIS    EF06-1
    ARIS    K3006/1242-84873-01001
    ARIS    FNr.1420-6259-01010;Typ:EF 1 MA333312
    ARIS    PE40-08
    ARIS Antriebe und Steuerungen GmbH    PE30-08
    aris    FNr: 0736-67622-01002
    aris    6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
    ARIS    N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
    Aris    PMR2 0700002 NR:0216-52001-001
    ARIS     0542-61428-02010 N-B1-E
    Aris    K3006 FNR.1137-5461-01059
    ARIS    FNr:1142-5481-02040
    ARIS    FNr:1219-83411-01003
    Aris    K3012,Stroke -- 300mm;actuating force --- 1200N;voltage --- 230V/50Hz;actuating speed --- 1.7(2) sec;
    ARIS    PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise 81020/06
    ARIS    PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27, counterclockwise 81928/03
    ARIS    N 5 1209-82710-01003 30 s / 90??+ PMR 3
    ARIS    Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
    ARIS    FNr:0908-4966-01008 Typ:EF1
    ARIS    NL-90/120
    Aris    Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage: 220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
    ARIS    TYP.N5 FNr.1117-79726-01002
    Aris    1206-S2453-02002 N5L SNR107504
    ARIS    0906-71866-01002??N6S DN1120d
    aris    PE60-08 0087.00033
    aris    0301-54088-01006
    ARIS     TYPE:N5 230V 50HZ 18VA 110Nm 90' 50S IP54
    Aris    Nr.1012-5165-02067
    ARIS    WRK 3012 Nr.9425-16842-01011 220V 50HZ 17VA 1200N 200S/300MM
    ARIS    NL-90/120
    ARIS    EV61-521MJ1
    ARIS    K 3012 1126-79613-01002
    ARIS    K 3012 1126-79612-01002
    ARIS    N5 RD-S/DN250d /0620-62724-01001/:230v 50(60)HZ
    ARIS    N1-RD-S/DN125d/1108-78827-02036
    ARIS    N4 230v 50HZ 30Nm 35VA 6U 4??2(3??5)S/90??FNr??0816-69661-01002
    ARIS    type K3012 1,7/1200 2ZW; regulating distance: 300 mm;actuating force: 1200 N; actuating time: 176 s; nominal ,voltage: 230 V AC, 50Hz; nominal power: 31 W; protection ,class: IP 54; limit switches: 2 (standard), 2 (additio
    ARIS    BE41-210003
    ARIS     N5 1209-82710-0100330 S/90+PMR3
    Aris    FNr:1136-5463-01001 TYP:K1512
    Aris    FNr.1112-5375-04014 TPY:K3012
    Aris    FNr.1026-5230-01040 TPY:K3006
    ARIS    1217-83288-01001
    ARIS    1217-83288-01002
    ARIS    FNr.0906-71866-01003 TYP.N68 DN1120d
    ARIS    FNr.0751-4710-02034 Typ.K 3006
    Aris    K-A 3025
    ARIS Antriebe und Steuerungen GmbH    PE 30-08
    aris    typ nk3015 dn150d,FNr:1118-79608-02001
    Aris    PE20-08
    ARIS    0338-55766-01005 TYP:N3
    ARIS    RD-S DN125+N1 JN0 O-BDNR 2139147;TLNR 148048 257270/#16
    Aris    EV61-521MJ1
    Aris    K3012 1012-5165-02062
    Aris    see picture
    Aris    K3012, 1029-5247-02029
    Aris    K3006, 1013-75710-02003
    Aris    FNr: 1235-84300-02061 TYP: NK3015 230V 50(60)Hz 7VA 15Nm
    Aris    Nr.1442-90991-01001
    Aris    PMR3(FNR:1219-83411-0100)
    Aris    6444LI 230V 375/450rpm
    ARIS    FNr:0633-64053-01001 Typ:N3 230V 50(60)Hz 18VA 30Nm 90?? 30(25)s IP65 A.121.879.6234
    ARIS Antriebe und Steuerungen GmbH    0633-S4053-01001
    ArIS    NL3040 (including limit switches, PMR2-LC, electric heating)
    ARIS Antriebe und Steuerungen GmbH    FNr:1012-5165-02067;Typ:K 3012
    ARIS    0203-51259-01003 K3012
    ARIS    NL-90/100
    ARIS    KA3050
    ARIS    K3012
    ARIS Antriebe und Steuerungen GmbH     0850-71942-01001;6443LI 230V 50 (60)HZ 18VA
    ARIS    K1506 40NM 23OV 50(60HZ)
    ARIS    HK40.1 ?A:20mm--?B:20mm
    ARIS    HK60.5 ?A:12mm--?B:12mm
    Aris    K3012 1,7/1200 2ZW ARIS art.-no. 0100.03217
    ARIS Antriebe und Steuerungen GmbH    /motor 6443LI/230V/50(60)Hz/18VA/375rpm/78MA/0.56uF
    Aris    WAN 3 Nr.9914-43637-01002
    Aris    CL-L 140-70
    Aris    WAK 3012 N; Nr.2473672
    Aris    WAK 3012N NR:2473672
    Aris    FNr: 0836-71033-01002 230V 50 (60) Hz, 30Nm 35VA 6U 4,2 (3,50 s/90??, Ip65 UTO/+60 ??C PMR3
    Aris    PD25HT MAX10BAR 8BAR 90NM
    ARIS    0523-4198-02046 K3012
    ARIS    0615-4394-01008
    ARIS    SM6585-4 1-2UF
    ARIS    KA3050
    ARIS    K3012??
    ARIS    NL-90/100
    Aris    0080.10013 6444LI 230V 375/450RPM
    Aris    Nano M 40-60 Nr.VA03.00002
    Aris    VA02.L0001
    Aris    117.00501
    Aris    CL 12-17 300(replace K3012)+0117.00501
    Aris    VA02.L0005
    VARISCO    117.00588
    VARISCO    JE1-110 G10 ET20
    Aris    117.00501
    Aris    117.00652
    VARISCO    VA02.L0001
    Aris    CL12-17 300 NrVA02.L1001Replace K3012
    Aris    06-17 3000429-4002-01003
    Aris    VA02.L0001
    Aris    117.00501
    Aris    VA02.L0005
    VARISCO   117.00652
    Aris    117.00588
    Aris    Artikel-Nr.0045.00011
    Aris    Artikel-Nr.0016.X9014
    Aris    Artikel-Nr.1110.00115
    VARISCO    14440012
    Aris    10014358
    Aris    10008895
    Aris    10009010
    Aris    999990.999.000001:1 ersetzt K 3012 1305-5758-01018
    Aris    06-17-300 230V 50Hz
    Aris    10007593
    Aris    10005371
    Aris    10016934
    Aris    10014358
    Aris    10009010
    Aris    10008895
    Aris    14440012
    Aris    117.00652
    Aris    VA02.L0005
    Aris    117.00501
    Aris    Linearis TE 12-17 300 ARIS Klappenversteller
    Aris    I-ACT-Regler, eingebaut
    Aris    Linearis N+ 12-17 300 (replacement K3012 1012-5165-02062)
    Aris    1672.82004
    Aris    1672.82003
    Aris    VA07.L0001
    Aris    117.00501
    Aris    117.00652
    Aris    VA02.L0005
    Aris    1110.00200 Endschaltersatz BE41
    Aris    EV61-521MJ1
    Aris    000988.024.60153; Stellantrieb Typ EF 1
    Aris   8047GG+GG514+TYP.1A
    Aris    Typ:WAN V71-R1;FNr:0115-49153-04001
    Aris    Typ:WAN V71-R1;FNr:0115-49153-03003
    Aris    K 3012 Nr.0243-03671-01016
    Aris    N6S DN1120d 0906-71866-01002
    Aris    Nr 9843-42249-01006 typ WAK 3012
    Aris    |ADJUSTING DRIVE|TYPE WAK 3012; VOLTAGE: 220V; 09346.401.011006.000
    Aris    K3012 H300,Nr.1505-91626-04001
    Aris    CL-M60-25
    Aris    FNr??1302-5756-01023
    Aris    K3006
    Aris    ype: CL-S 30-30 30Nm 30s/90?230V 50(60)Hz 11VA 48mA UT-15/+60?? ED-S1-100%Pa?f. MP21 FNr:1538-93225-01001
    Aris    Type:N3230V 50(60)Hz18VA 30Nm90?30(25)SIP54 UT-15/+60?? FNr:1342-88096-01001
    Aris    Typ:K 1512,FNr:0936-73991-01001,pls see the pic
    Aris    CL-S?40-120 FNr:1136-81073-01001??Typ:N3??230V 50(60)Hz 7VA 40Nm 90?? 120(100)s IP65 UT-15/+60??
    Aris    CL-M60-25
    Aris    SN:038895 SW-REV PMR3_06
    Aris    CL-M 100-25
    Aris    117.00501
    Aris    CL-L160-17
    Aris    1110.00003
    Aris    1110.00309
    Aris    1110.0031
    Aris    40.02291
    Aris    1110.00309
    Aris    1110.00003
    Aris    1110.0031
    Aris    1145-78525-01001 NL-3040
    Aris    FNr??0851-4915-01003 typ??K 3006
    Aris    PE30-08
    Aris    0016.02076+1110.00107+0045.00011
    Aris    FNr:1445-91087-01016 Typ??LINEARIS 06-17 300 23V 50(60) HZ 18VA 1.7(2) mm 600N H300 IP65 UT-15/+60?? 2ZW, PMR-CL
    Aris    Typ??K 3012 1142-5481-02045
    Aris    Typ??K 3006
    Aris    PE60-08
    Aris    FNr:0827-70285-01004 Typ:N1 230V 50(60)Hz 7VA 30Nm 90?? 120??100??s IP54 UT-15/+60??
    Aris    1209-82710-01003 TYP??N5
    Aris    K 3012 1305-5758-01018
    Aris    CL-L 140-70 140Nm 220v/50HZ,4-20mA
    Aris    CL12-17 300??Nr??VA02.L1001??Replace K3012??
    Aris    NL-3040
    Aris    NL-3040
    Aris    FNr:1219-83411-01009TYP: K 3012
    Aris    PMR3 (FNR:1219-83411-0100)
    Aris    K3006 4-20MA 600N FNr??1307-85809-01039
    Aris    EV61-521MB1
    Aris    K3006??Nr0914-72779-01009
    ARIS    Nr.1442-90991-01001 Typ??LINEARIS12-17 300
    aris    1102-78517-03002
    ARIS Antriebe und Steuerungen GmbH    TYP:WAK 3012 N ,Nr:9310-12551-01004
    ARIS    EF06
    ARIS    K3012
    ARIS    K3006
    ARIS    K1512
    ARIS     K3006 NR.1145-81511-01006
    ARIS    PMR3(FNR:1219-83411-01008)
    ARIS Antriebe und Steuerungen GmbH     FNr:1219-83411-01009 TYP: K 3012
    ARIS     K3012 Nr??1107-78855-01001 IP54 50/60HZ
    ARIS    1010-75416-01002
    ARIS    K3012.ED-S3-50%,~230V.50HZ.31VA.1200N.H300.1.7(2)mm/S
    ARIS    WAN 1 Nr??2214859
    ARIS    1141-81317-01003
    ARIS     Type:K3012 1,7/1200 2ZW RP19 1029-5247-02016
    ARIS    K3006 1316-5830-01002
    ARIS Antriebe und Steuerungen     0016x9014+1110.0 0107+0045.0011
    ARIS    FNr:1219-83411-01008 TYP:K3012
    ARIS    K3006??Nr.0914-72779-01009 230v 50??60??HZ 180VA 600N
    Aris    K3006 FNR:1048-5310-01033
    ARIS    "type WAK 3012; stroke: 300 mm; actuating force: 11200 N上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
    产品型号         TL-5920                      TADIRAN
    产品型号         95.110.045.3.0                           OTT
    产品型号         95.110.058.3.0                           OTT
    产品型号         4PSO10                       CLIPSAL
    产品型号         KM330                        COMARK
    产品型号         RD8X2-TR                            COMPACT
    产品型号         7000-12221-6140500                         MURR
    产品型号         7000-13101-3480500                         MURR
    产品型号         7000-12041-6150500                         MURR
    产品型号         UTS-1180C-303                           CONTRINEX
    产品型号         130B1235                            DANFOSS
    产品型号         315-4NE12                 315-4NE23       Vipa
    产品型号         ERF3L       6151652860              Desoutter
    产品型号         1019472                     CROSBY
    产品型号         AT 101      TAT1013K0X05                   FRER
    产品型号         TAC040250X05                            FRER
    产品型号         T37168-03-0                       CURTIS
    产品型号         266-3                           Carbide Probes
    产品型号         CHME-50 U I=7.5  PAM80                        Chiaravalli
    产品型号         YA80/N/RF/WR 230VAC 45mA                            Clifford&Snell
    产品型号         KUS-16-60-SD                     MONTECH
    产品型号         MD-21DC         Art No:3151-2001             WESTERMO
    产品型号         K16                     ELCA
    产品型号         KGR for Darwin 2000D A005.156.01#22                   LOSMA
    产品型号         RSB-13                        DAIICHI
    产品型号         OMS315 151F0548                             DANFOSS
    产品型号         MBC5000-1011-1CB04                      DANFOSS
    产品型号         R8           95A151370                DATALOGIC
    产品型号         HLD-P080                            DATASENSOR
    产品型号         TH-TH-03                   DATASENSOR
    产品型号         S18-5-B-82  SV2063                 S5-5-B3-32        DATASENSOR
    产品型号         LD2 LED DRIVER 24VDC 2*350mA                         DATASENSOR
    产品型号         3TP95                          DAYTON
    产品型号         MCOMV, Input:0~220V(DC)(50% overload) Output:0~20mA(50% overload),Aux.Supply:220V DC,0~220V DC                       FRER
    产品型号         MCOMV, Input:0~48V(DC)(50% overload)  Output:0~20mA(50% overload),Aux.Supply:220V DC, 0~48V DC                      FRER
    产品型号         F1238E 12B                       MECHATRONICS
    产品型号         ACCON-EasyLog Basic Win      130001WUX              DELTALOGIC
    产品型号         918820-W32-U                  918820-W-U    DELTALOGIC
    产品型号         ACCON-AGLink S7-TCP/IP Entwicklerlizenz Windows      918814-W                  DELTALOGIC
    产品型号         375TM 3PDT    21011-84          DELTROL
    产品型号         550-0400 Green                       DELTRON
    产品型号         DTS37PYC/2M63UN                           DELTRON
    产品型号         DE006603                          DELTRON
    产品型号         332-0000                    DELTRON
    产品型号         DTS15SYC/2     DE002140                  DELTRON
    产品型号         WUE20DD-B14.1-35-3-13.7    50211266                   DEMAG
    产品型号         0160900304 RC 3/4KW-STF 575V Antidisturb o                         DETAS
    产品型号         CKR-200-BKT                      DI-SORIC
    产品型号         C4G7-24G-E00                            DI-SORIC
    产品型号         HS-GH-3-12-A                     DI-SORIC
    产品型号         HS-K-14-12-A                      DI-SORIC
    产品型号         SH-BEK                        DI-SORIC
    产品型号         HS-S-12-100-V                    DI-SORIC
    产品型号         D303                           DIAMOND
    产品型号         647-3                        DWYER
    产品型号         D98MVXXXXG10               D98MS5PROG0DS   FRER
    产品型号         61803800                            MAEDLER
    产品型号         9IDGG-90FW                      DKM
    产品型号         9WD36BL                            DKM
    产品型号         AT065                          FELLER
    产品型号         114030K12M010                        WOODHEAD
    产品型号         114030K12M020                        WOODHEAD
    产品型号         100.0057.39.00                          DOGA
    产品型号         37.17.007                            Dopag
    产品型号         40.01.001                            Dopag
    产品型号         40.01.013                            Dopag
    产品型号         C.2844.03                           ESD
    产品型号         DTV02/S                     DPC
    产品型号         3546-021N000, 28VDC, 15A                      APEM
    产品型号         0970 PSL 111                      LUMBERG
    产品型号         0970 PSL 109                      LUMBERG
    产品型号         JG 61211                    W&T
    产品型号         JK42SC                       ZERO-MAX
    产品型号         JK2SC 25CW                       ZERO-MAX
    产品型号         817SR5GD                           DUFF-NORTON
    产品型号         3S2086K                     DUFF-NORTON
    产品型号         FA140B-2                            FUMEX
    产品型号         MS-121                       DWYER
    产品型号         LKP-30 OEM                        DYNAMP
    产品型号         RI41-0/1000AR.11RB-0.35-G-S09-HD                        DYNAPAR
    产品型号         X252048034 Class I ,Division 1 Group D                       DYNAPAR
    产品型号         DN3020                      WOODHEAD
    产品型号         470.00.00                            Dopag
    产品型号         HM28D3F10000                         DWYER
    产品型号         MN57A4AD02M040                           AMPHENOL
    产品型号         FTL206-1020             FTL31-AA4U3BAWDJ        E+H
    产品型号         FTL31-14J1/0FTL31-AA4M3BAWDJ                            E+H
    产品型号         90-0004-01                         E+H
    产品型号         XPD0011-A2                       E+H
    产品型号         FX 5260           363592             E+L
    产品型号         CA-FC10-SH-NC-10                     US DIGITAL
    产品型号         HP50-133                            EAGLE SIGNAL
    产品型号         101-1037-009                     EATON
    产品型号         101-1701-009                     EATON
    产品型号         密封套装                           EATON
    产品型号         OL920103000000              OL92010300000A    EDI
    产品型号         EE-kit for PKL 740                       NETTER
    产品型号         EGT 183                      TUNKERS
    产品型号         ES0350H1A04A27KO        4220042007049       FS0350-NM40CWALTN-L27SKA-00XX       EL-O-Matic
    产品型号         RUOTAMRAG200/10                          ELAP
    产品型号         SIS212 24VDC                           ELESTA RELAYS
    产品型号         050PVDE                    Elfin
    产品型号         016P3P22                            Elfin
    产品型号         050F02                        Elfin
    产品型号         050PEL3C                            Elfin
    产品型号         050PEL3C-24                      Elfin
    产品型号         171271A10                         ELOBAU
    产品型号         MR 25F5 SM    35585583         MR25SF6 ELSTER
    产品型号         EL38F100Z5/28P6X3PR2                    ELTRA
    产品型号         09-26.28.33.41-243 12/08  639946                26-1. 28.33.41.-0243      EMB
    产品型号         CDX48-018 54CEBSAANNNPAN-U                    CDX48-018 55DEBSAAGNNNPAN-UL       EMOTRON
    产品型号         WA532007                          END-ARMATUREN
    产品型号         CLS-1004           HCG1004 ENERPAC
    产品型号         VTA05SC-24                        ETA
    产品型号         VTE24SC48                         ETA
    产品型号         SVB24SC48                         ETA
    产品型号         07.06.815                            ETTINGER
    产品型号         5.14.069                     ETTINGER
    产品型号         5.43.110                     ETTINGER
    产品型号         05.44.412                            ETTINGER
    产品型号         05.49.430                            ETTINGER
    产品型号         5.15.209                     ETTINGER
    产品型号         05.82.050                            ETTINGER
    产品型号         ZSM2300 111871              EUCHNER
    产品型号         HBA-124286                       EUCHNER
    产品型号         1.4404 SMS 0.8145 一套                           EUROBINOX
    产品型号         61E026413                          EUROGI
    产品型号         21E014005                          EUROGI
    产品型号         11E016505                          EUROGI
    产品型号         204.085.15GO.2.S1                   EUROSWITCH
    产品型号         204.085.15GO.2.S1                   国产代替eueuroswitch
    产品型号         ET/DC-DC/18-36/10/0.3A/GB ET4310                      EUROTEK
    产品型号         2500T/D08                          EUROTHERM
    产品型号         2500T/DI8                           EUROTHERM
    产品型号         NANODAC/VH/X/X/LRR/XX/TS/WD                           EUROTHERM
    产品型号         21321/AL/VH/ENG///AC/FH/Z/O/400/C/XX/XX                         EUROTHERM
    产品型号         GKV2000211-R                            EVG
    产品型号         GFK20                         EVG
    产品型号         GKV1500211                      EVG
    产品型号         440E-A17003                      GUARDMASTER
    产品型号         43-0647                      ELECTROCRAFT
    产品型号         EZ30-P/A/D-40000-3,5-750-1-1-1-1-0-0-0        8-0000002202          GROB
    产品型号         020SM                        Elfin
    产品型号         060PMG                     Elfin
    产品型号         050KFM                      Elfin
    产品型号         LUMISTAR 125                           F.H.Papenmeier
    产品型号         12F5C1B-350A                           KEB
    产品型号         HP6X4FF-DR                       FABCO-AIR
    产品型号         89TXA                         FACOM
    产品型号         84TZSA                       FACOM
    产品型号         CLS-K-63 4000HZ     10040035                   ELTROTEC
    产品型号         CLS-K-63  100HZ    10040045                   ELTROTEC
    产品型号         ER-25-01-M                    (002) NJ LCR300LS115AC         FC Performance
    产品型号         MEH-5/3E-5,0-B       173146             FESTO
    产品型号         556839                       FESTO
    产品型号         556838                       FESTO
    产品型号         DFM-25-40-P-A-GF                     FESTO
    产品型号         DFM-16-20-P-A-GF                     FESTO
    产品型号         MS6-DL-1/2-AD7                        FESTO
    产品型号         DS21010A20BK0W00U0006                      FISCHER
    产品型号         FLEXCON 18/1 26186                FLAMCO
    产品型号         1050WA   0711197            FALK
    产品型号         LU28-11                    FLOWLINE
    产品型号         DERV2-38                            FLUID-TEAM
    产品型号         F 57           K57  FOX
    产品型号         1F72-EV-600 EQ72            F72EVX600XSD         FRER
    产品型号         F48EAX001XSD                            FRER
  • 朱磊 在2026/3/18 8:59:00留言
  • 详细留言:1906R-035单向阀
  • 在2025/12/25 9:25:00留言
  • 详细留言:6A37-SS
  • 胡光旭 在2025/12/10 16:20:00留言
  • 林小姐 在2025/11/27 16:54:00留言
  • 详细留言:采购MTE电容器MTECAP-283
  • 刘言 在2025/11/24 15:20:00留言
  • 详细留言:PBL6/VMP 38/5.TS.S
