代理NuFlo仪表
美国NuFlo计量系统公司是一家从事油气和工业过程控制仪表的制造商。公司主要产品包括:管线在线自动取样系统;全系列涡轮流量计;流量累计指示仪;全系列带RTU功能的流量计算机;极高精度的超声波流量计;一体化孔板流量计;可在线更换孔板的高级阀式孔板流量计;小型刮板流量计;锥形管流量计;双波纹管差压传感器、差压指示表、差压开关;圆盘有纸记录仪;高精度压力、温度变送器;多参数变送器;先导式安全阀。
Barton Model 7101 Turbine Flow MeterBarton Model BA202D-44L Flow Totalizer
P/N: 1000012090 RES NO:6565453 MAX PSI:800W.P.:5. 50MPa CL 1 6P A.B.C.C LR21617
MC-II Plus EXP流量分析S/N: 10100104430VDC, MAX, 4-20mA,输出电流 2Inch ANSI Class 150#RF
Manual: 101001394, S/N:MC2EXP 014303流量显示器MC-II Plus EXP
MC Totalizers Flow Computers MC-II Scanner 2000 MC-II Plus EXP Scanner 1150
MC-II Plus WP Scanner 1140 MC-III WP Scanner 1141 MC-II Portable Rate Meter Scanner 1131
MC-III EXP ScanWin Software MC-RTU ScanPLC Software HFC-RTU NuFlo Monitor Software
FLO-III Pre-Amplifiers TMP-100
DP Cone Meters Transmitters DP Cone Meter MVX-II Multi-Variable FCX AII (Temp/Gauge/DP) Series 3920 Series 3940 Series 20 RTD
Barton 7400系列高精度液体涡轮流量计
Barton 7000 Series -- 7102 Barton 7000 Series -- 7103 Barton 7000 Series -- 7104
Barton 7000 Series -- 7106 Barton 7000 Series -- 7108 Barton 7000 Series -- 7110
Barton 7000 Series -- 7112 Barton 7000 Series -- 7146 Barton 7000 Series -- 7182
Barton 7000 Series -- 7183 NuFlo Scanner 1131流量计算机, 具有RTU功能
Scanner 1141单路或双路流量计算机, 具有RTU功能 Clif Mock Caldon LEFM 280C 超声波流量计
Enhanced Scanner 1150 Flow Computer, Pilot-Operated Safety Relief Valves, NuFlo Liquid Turbine Meters, C-Series Isokinetic Inline Sampling Probe, Flow Computer - Scanner 1141, Differential Pressure Units, NuFlo Cone Meter, MVX-II Multi-Variable Transmitter, Scanner 2000 microEFM, CaldonHydro, Pressure & Level Measurement RTU, FCX Series Electronic Transmitters, Flow Analyzer - MC-III EXP
MC-III WP Flow Analyzer, MC-III EXP Flow Analyzer
MC-II Flow Analyzer, MC-II Plus EXP Flow Analyzer
MC-II Plus WP Flow Analyzer, MC-II Plus Panel Mount
MC-II Plus Portable Rate Meter, MC-RTU, HFC-RTU, FLO-III, Pre-Amplifiers, TMP-100
Other pBarton 7000 系列液体涡轮流量计
Barton 7400系列气体涡轮流量计Barton 8000 系列液体涡轮流量计Barton TIM7 – 顶部插入式涡轮流量计
roducts from Cameron’s Measurement Systems Division in Flow Meters Barton 7000 Series -- 7101, Barton 7000 Series -- 7102, Barton 7000 Series -- 7103, Barton 7000 Series -- 7104, Barton 7000 Series -- 7106, Barton 7000 Series -- 7108, Barton 7000 Series -- 7110, Barton 7000 Series -- 7112, Barton 7000 Series -- 7146, Barton 7000 Series -- 7182
