代理美国SPM公司产品,指定销售地区为中国及中亚地区。主要稍售SPM压裂泵、柱塞、凡尔体、凡尔座、凡尔胶皮。
SPM 旋塞阀、蝶阀、高压活动弯头、油壬、管接.。
哈里伯顿(HALLIBURTON)压裂车上的主泵HT-400包含以下三种规格:
1、Plunger Size 3.38” - 4.00” Valve Part No. P107185 Seat Part No. P107802
Insert Part No. P107186 Spring
2、Plunger Size 4.50” Valve Part No. P107181 Seat Part No. P107180
Insert Part No. P107182 Spring
3、Plunger Size 5.00” - 6.00” Valve Part No. P107188 Seat Part No. P107187
Insert Part No. P107189 Spring4P102382
SPM2000压裂泵的型号及规格
1、Plunger Size 3.75" Plunge Part No 3P103887
2、Plunger Size 4.00" Plunge Part No 3P100339
3、Plunger Size 4.50" Plunge Part No 3P100654
4、Plunger Size" 5.00" Plunge Part No 3P100233
5、Plunger Size" 5.50 Plunge Part No 3P107060
6、Plunger Size" 5.75" Plunge Part No 3P107061
7、Plunger Size 6.00 Plunge Part No 3P107062
SPM压裂泵的型号
TWS 250 Plunger Size 1.75"-3" 3.25"-4"
TWS 400 Plunger Size 2 .50"-3" 3 .50"-4 .50”
TWS 500LW-600 Plunger Size 2 .75" 3"-4 .75"
TWS 600S Plunger Size 2 .50"-3" 3.50"-4 .50"
TWS 900 Plunger Size 3.50"-4"
TWS 1250LW Plunger Size 4"
OPI880 Plunger Size 3.75" 4.00” 4.5” 5.0:” 5.50” 5.75” 6.0”
TWS1000LW、TWS1300
Plunger Size 3.75" 4.00” 4.5” 5.0:” 5.50” 5.75” 6.0” 6.5 “ 6.75”
TWS1600 Plunger Size 3.5” 3.75” 4.0” 4.50” 5.0” 5.5” 5.75 “6.0”
TWS1800 Plunger Size 3.5” 3.75” 4.0” 4.5” 5.0” 5.50” 5.75” 6.0”
TWS2250 Plunger Size 3.75” 4.0” 4.5” 5.0” 5.50” 5.75” 6.0” 6.5”
QWS 2000 Plunger Size 3.75” 4.0” 4.5” 5.0” 5.50” 5.75” 6.0” 6.5”
QWS 2500 Plunger Size 3.75” 4.0” 4.5” 5.0” 5.50” 5.75” 6.0” 6.5”
P10453 1/4" PIPE PL
3P10149 2" 1502 BULL PLUG
3P10226 2" 1502 MALE SUB
3L13139 2" 1502 TRUE WYE
4L11982 2" PLUG VALVE REPAIR KIT
4L13694 2" PLUG VALVE SEAL KIT
2A17205 2" STYLE 10 SWIVEL MXM STYLE 1502
1A11742 2X2 FIG 1502 F X 2" FIG 1502 MALE PLUG VALVE
2A12568 3" 1502 NPS X 10 FT LONG STRAIGHT JOINT
2A12559 3" 1502 NPS X 4 FT LONG STRAIGHT JOINT
2A17658 3" 1502 STYLE 50 SWIVEL JOINT FXM
2A12037 3" 207 BLANKING UNION
3A21280 3" 602 BULL PLUG
3A23277 3" 602 FXM X 2" 1502 M TEE
2A12070 3" 602 HAMMER UNION COMPLETE
2A13765 3" 602 NPS X 10 FT LONG STRAIGHT JOINT
2A13760 3" 602 NPS X 2 FT LONG STRAIGHT JOINT
2A13761 3" 602 NPS X 4 FT LONG STRAIGHT JOINT
2A13764 3" 602 NPS X 8 FT LONG STRAIGHT JOINT
2A17291 3" STYLE 80 SWIVEL JOINT 6,000 FXM
4P100819 ADPTR/PKG/FMLE4.00 TWS600
1A13653-B BALL INJ ASSY/3-1502/MANUAL/.88DIABALL
1A24334 BALL INJ/RMTE CNTRL ASSY/POWER TORK
2A24244 BALL INJ/SCRW ASSY/1.25 BALL
2A25203 BF VA ASSY/3 IN/NITR SEAT/DI DISC/DI BDY
2A25208 BF VA ASSY/6 IN/NITR SEAT/DI DISC/DI BDY
2A25209 BF VA ASSY/8 IN/NITR SEAT/DI DISC/DI BDY
3P105099 BKUP/SEAL/SUC CVR/2.50 TWS600S
P100166 BRG CONE/PINION/TWS400
P100167 BRG CUP/4.6:1 RED/TWS600
P100165 BRG CUP/PINION/TWS400&600
P100108 BRG/CONN ROD//TWS400 & 600
P100111 BRG/MAIN/INNER/FLTNG/TWS400&6
P100110 BRG/MAIN/INNER/FXD/TWS600
P100109 BRG/MAIN/OUTER/FLTNG/TWS600
3P100089 BRG/PIN/WRIST/TWS400/600
P22691 CABLE LOOP 5/8 X 6 LOOP X LOOP W/NAMEPLATE
2P11684 CAP/BLNKNG/4-207
2A26950 CHK VA/CL/4-1002MXF/TP LOAD
1A23463 CHK VA/POPPET/2-1502MXF/CO2
3P100148 CLMP/PLNGR/5.0-6.75 TWS1300-QWS
P100066 CRANKCASE BREATHER CAP
3A23479 CROSS ASSY/4-602FX3-602FX4-602MX3-602F/4
2P106380 CRSSHD/TWS600/SHORT PIN
2P105139 CVR/DIS/3.00-4.50 TWS600/2 PC
2P109834 CVR/SUC/6.00 QWS/GL
2P100257 CVR/SUC/6.50&6.75 T18/6.50 QWS
3P101941 DIAPHRAM/3.50-4.50 RR500 HV
1P17651 ELLS/SWL/MXF BR/3 LR 15 HD
P019509 FLANGE SEAL D RING
3P100182 FLG/DIS/2-1502/2.75 BOSS/T600
3P102045 FLG/DIS/4-602 F TWS1800/2250
P22688 FSC/CABLE LOOP/5/8 X 3 FT LG
2A21200 FSC/QR/ASSY/2 PIPE/2.38 OD/STL
4P100087 GSKT/CVR/REAR/PWR END/TWS600
4P100091 GSKT/CVR/SIDE/TWS600
3P103019 GSKT/DIAPHRAM/TWS600S
4P100092 GSKT/HSG/BRG/MAIN OUTSIDE/TWS600
4P100104 GSKT/RET/PNY RD SEAL/TWS600
4P100122 GSKT/SPRAY BR FLG/RED/TWS600
2P102975 GUIDE/CRSSHD/TWS600S
4A12977 KIT/2-1502 DET NUT/SEGM
4L18114 KIT/PARTS/BALL INJ/3
P14897 NUT/HEX/1.00-8UNC/HVY
3P100812G NUT/PK/4.00 TWS 600
3P105134 NUT/RET/SUC&DISC.304.50 T600
4P100271 NUT/RET/SUC&DISC/6.5 QWS/6.75
1P105797 PLNGR/4.00 TWS 600FE TO RR500PE
2P103312 PLNGR/4.50 TWS600S
3P100233 PLNGR/5 TWS1300-QWS
3P107060 PLNGR/5.50 TWS 1300-QWS/REAR WELD
3P107062 PLNGR/6.00 TWS 1300-QWS/REAR
3P101407 PLNGR/6.75 TWS1800-QWS
1A14492 PLUG VA/2 SP 150 WU/LT/H2S
1A14483 PLUG VAL/1x2 SP 150 WU/LT
P10232 RET RNG/2-1502
3P10231 RET SEG/2-1502
4P10027 RET/SEAL/PNY ROD/TWS 1300-1800
P100342 RNG/HEADER/4X5
4P101409 RNG/LANTERN/6.5 TWS900-QWS
P100343 RNG/PKG/4.00 X 5.00/DBL/ACID
P102128 RNG/PKG/4.00 X 5.00/DBL/CMNT
P102044 RNG/PKG/6.75 x 7.75/DBL/CMNT (GRAY)
P105906 RNG/RET/WRIST PIN/TWS600S
3P103522 RNG/SEAL/PKG/2.50/TWS250
P20518 SCRW/FHCS/.38-16UNC X .63
4P22391 SEAL RNG/UNION/3-1502/2002.. (ANTI-EXCRUSION)
4P22394 SEAL RNG/UNION/3-1502/2002/2202.. (ANTI-EXCRUSION)
P108291 SEAL/D-RING/CVR/S&D/3.50-4.00 T900-QWS
P109129 SEAL/D-RING/CVR/S&D/5.50-6.00/T900-QWS
P105155 SEAL/OIL/DIAPHRAM/4.00 TWS600S
P105307 SEAL/OIL/DIAPHRAM/4.50 TWS600S
P101942 SEAL/OIL/RR500/WESTERN 138630
P100203 SEAL/OR42545013
P100156 SEAL/OR60065025
P109789 SEAL/PNY ROD/TWS13-QWS MODEL 26
P100106 SEAL/PNY ROD/TWS400-900
P16636 SEAL/PPK 050075125-250-B
P100204 SEAL/PPK 238275187 MOLY
P105095 SEAL/PPK 288350312
P101414 SEAL/PPK 400438187
P105029 SEAL/PPKP 288325187
2A109621 SEAT/ASSY/VA/SP/7
P105752 SEAT/VA/N/SEE DWG/4A105916
3P101930 SHIM SET/12/RED/TWS400/600
3P101929 SHIM SET/8/RED/TWS400/600
4P100084 SHIM SET/BRG/MAIN/TWS600
4P101245 SPCR/PKG/6.75 TWS900-QWS
4P100198 SPRNG/VA/4.50 TWS400/77 LB/IN
4P100281 SPRNG/VA/6.50-6.75 TWS900-QWS
4P104474 SPRNG/VA/TWS400/600/36 LB/IN
2P105375 STOP/SUC VA/6.75 T 1800 LG BLK
P14896 STUD/1.00-8UNC X 3.5LG/GRD B7
4P101714 STUD/PNY ROD/TWS400/600
2P12010 SUB/FEMALE/3-200/206/207 PS
P100197 SUCT/DISCHARGE. COVER
3P12309 SWG/INT FM/4-602 X 4.50-8SCT
2A17666 SWVL ASSY/STL 10 MXM/INT/3 LR1
2A17139 SWVL ASSY/STL 50 MXF/INT/2 LR
2A17757 SWVL ASSY/STL 50 MXF/INT/3 LR6 HD
3L11592 TEE ASSY/2-1502 FXMXF
3A14047 UNION/1 1/2 - 200 PS
3A12159 UNION/2-100
2A10223 UNION/2-1502 PS/BUNA
3A12006 UNION/2-200 PS
3A12054 UNION/2-602 PS
2A12167 UNION/3-100 PS
2A10252 UNION/3-1502 PS
2A12041 UNION/3-207 BLANKING
2A11831 UNION/4-200 PA
2A11637 UNION/4-206 PS
2A12038 UNION/4-207 PS/BLNKNG
2A24676 UNION/4-602 NPS/DET/PLAIN
2A14241 UNION/6-100 PS
2A109537PP VA/INSERT/ASSY/SP4-1/POLYMER PROD
2A109627PP VA/INSERT/ASSY/SP7/V1/POLYMER PRO
P100281 VALVE SPRING HEAVY DISCHARGE
3P10228 WING NUT/2-1502
2P10257 WING NUT/3-1502
2P11765 WING NUT/4-200/206
P101883 WIPER/ROD/4 FE/OPI AWS/BWS/CWS
2P20318 WYE/INT/2-1502 FXFXM
2P10318 WYE/INT/2-1502 FXFXM
