英国Farnell公司中国代理
  • 3M公司-产品
  • 发布时间:2006/11/24 19:16:43   修改时间:2006/11/24 19:16:43 浏览次数:5791
  • 3M公司-产品
  • Product Brand Mftrs No Description
    101606 3M 500/12X66 TAPE, PACKING 12MMX66M
    101608 3M 500/19X66 TAPE, PACKING 19MMX66M
    101609 3M 500/25X66 TAPE, PACKING 25MMX66M
    103907 3M 216-3340. IC SOCKET, ZIF 16 WAY
    103908 3M 224-1275. IC SOCKET, ZIF 24 WAY
    103909 3M 228-3345. IC SOCKET, ZIF 28 WAY
    103910 3M 240-3346. IC SOCKET, ZIF 40 WAY
    1112296 3M 6900 CRIMPLOK CONNECTOR, SC CONNECTOR, HIGH R
    1112302 3M 6901 CRIMPLOK CONNECTOR, ST CONNECTOR, ZIRCON
    1112314 3M 6955 Termination Kit, Crimplok™
    1247578 3M 88 SUPER (3/4"X66') Scotch Super 88 Vinyl Plastic Electrica
    1247610 3M 33+Super-3/4x66FT Scotch Super 33+ Vinyl Plastic Electric
    1247621 3M 33+ SUPER (3/4"X20') Scotch Super 33+ Vinyl Plastic Electric
    1247633 3M 35 RED (1/2"X20') Electrical Tape for Color Coding, Type 3
    1247645 3M 35 WHITE (1/2"X20') Electrical Tape for Color Coding, Type 3
    1247657 3M 35 YELLOW (1/2"X20') Electrical Tape for Color Coding, Type 3
    1247669 3M 35 GRAY (1/2"X20') Electrical Tape for Color Coding, Type 3
    1247670 3M 27 TAPE (1/2") Scotch 27 Glass Cloth Electrical Tape,
    1247682 3M "70 (1""X30')" Self-fusing silicone rubber electrical t
    1247694 3M 35 GRAY (3/4"X66') Electrical Tape for Color Coding, Type 3
    1324457 3M Y (BULK) Insulated electrical spring connector, 2
    1324482 3M 951X Self stripping T-tap female disconnect,
    1324494 3M 952X Self stripping T-tap female disconnect,
    1324500 3M 953X Self stripping T-tap female disconnect,
    1324524 3M STD-0-9 Tape Dispenser, Wire Marker, SCOTCHCODE&
    1324536 3M STD-C TAPE DISPENSER, WIRE MARKER, SCOTCHCODE&
    1324548 3M SDR-0 LABELS, CABLE MARKERS
    1324550 3M SDR-1 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324561 3M SDR-2 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324573 3M SDR-3 LABELS, CABLE MARKERS
    1324585 3M SDR-4 LABELS, CABLE MARKERS
    1324597 3M SDR-5 LABELS, CABLE MARKERS
    1324603 3M SDR-6 LABELS, CABLE MARKERS
    1324615 3M SDR-7 LABELS, CABLE MARKERS
    1324627 3M SDR-8 LABELS, CABLE MARKERS
    1324639 3M SDR-9 LABELS, CABLE MARKERS
    1324640 3M SDR-BK 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324652 3M SDR-BL 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324664 3M SDR-BN 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324676 3M SDR-GN 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324688 3M SDR-GY 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324690 3M SDR-OR 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324706 3M SDR-RD 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324718 3M SDR-VL 5.5-MIL HIGH TACK ADHESIVE EPOXY FILM MA
    1324720 3M 1245 TAPE (1) Scotch 1245 EMI/RFI Foil Shielding Tape
    1324731 3M 557 (BOXED) Self stripping connector, 22-16 AWG, red
    1324743 3M 558 (BOXED) Self stripping connector, 22-16 AWG, red
    1324755 3M 1181 TAPE (1) Scotch 1181 EMI/RFI Foil Shielding Tape
    1341510 3M 929647-01-36-I Connectors, Headers & Receptacles, Pin H
    1341522 3M 929647-03-36-I Connectors, Headers & Receptacles, Pin H
    1341546 3M 929834-01-36 Connectors, Headers & Receptacles, Pin H
    1341558 3M 929834-03-36 Connectors, Headers & Receptacles, Pin H
    1341560 3M 929836-01-36 Connectors, Headers & Receptacles, Pin H
    1341571 3M 929836-03-36 Connectors, Headers & Receptacles, Pin H
    1341583 3M 929835-01-36 Connectors, Headers & Receptacles, Pin H
    1341595 3M 929838-01-36 Connectors, Headers & Receptacles, Pin H
    1341601 3M 929400-01-36 Connectors, Headers & Receptacles, Pin H
    1341613 3M 929500-01-36 Connectors, Headers & Receptacles, Pin H
    1342095 3M 929700-01-36 Connectors, Headers & Receptacles, Pin H
    1342101 3M 929700-06-36 Connectors, Headers & Receptacles, Pin H
    1342113 3M 929700-11-36 Connectors, Headers & Receptacles, Pin H
    1342149 3M 929710-01-36 Connectors, Headers & Receptacles, Pin H
    1342150 3M 929710-11-36 Connectors, Headers & Receptacles, Pin H
    1342162 3M 929710-03-36 Connectors, Headers & Receptacles, Pin H
    1358224 3M 923670-20 Test clip, 20 contact, PLCC
    1358248 3M 923670-68. Test clip, 68 contact, PLCC
    1358261 3M 923650-08. Narrow test clip, 8 contact, SOIC
    1358285 3M 923660-16 Connectors; Connector Type: SOIC IC Test
    1358339 3M 923660-20. Wide test clip, 20 contact, SOIC
    1358340 3M 923660-24. Wide test clip, 24 contact, SOIC
    1358364 3M 923665-16 Wide test clip, 16 contact, SOIC
    1358376 3M 923665-18 Wide test clip, 18 contact, SOIC
    1358406 3M 923665-28 IC Socket Test Clip Connector Type:SOIC
    1358418 3M 923743-14 Standard nail-head test clip, 14 contact
    1358420 3M 923743-16 Standard nail-head test clip, 16 contact
    1358443 3M 923739-14 Long wire test clip, 24 contact
    1358455 3M 923739-16 Long wire test clip, 16 contact
    1367730 3M 35 RED (3/4"X66') Electrical Tape for Color Coding, Type 3
    1367742 3M 35-WHITE-3/4 Electrical Tape for Color Coding, Type 3
    1367754 3M 35 YELLOW (3/4"X66') Electrical Tape for Color Coding, Type 3
    1367766 3M 560B (BOXED) Self stripping connector, 18-14 AWG, dar
    1367778 3M 905-BOX Self stripping connector, 22-18 AWG, red
    1367791 3M 1345 TAPE (1) EMI/RFI copper foil shielding electrical
    1368230 3M 929836-05-36 Connectors, Headers & Receptacles, Pin H
    1368266 3M 929850-01-36-10 Connectors, PCB, Wire to Board, Female G
    1368278 3M 929852-01-36-10 Connector Number of Contacts:36; Pitch S
    1368280 3M 929950-00 Midgie, .1 in. pitch, copper alloy conta
    1368291 3M 929955-06 Midgie, .1 in. pitch, copper alloy conta
    1368308 3M 929800-01-36 Connectors, Headers & Receptacles, Pin H
    1368497 3M 3473-6600. Wiremount socket, 26 and 28 American wir
    1368503 3M 3385-6600. Wiremount socket, 26 and 28 American wir
    1368515 3M 3452-6600. Wiremount socket, 26 and 28 American wir
    1368527 3M 3421-6600. Wiremount socket, 26 and 28 American wir
    1368539 3M 3399-6600. Wiremount socket, 26 and 28 American wir
    1368540 3M 3419-6600. Wire mount socket, 26 and 28 American wi
    1368552 3M 3414-6600. Wiremount socket, 26 and 28 American wir
    1368564 3M 3417-6600. Wiremount socket, 26 and 28 American wir
    1368576 3M 3425-6600. Wiremount socket, 26 and 28 American wir
    1368588 3M 3334-6600. Wiremount socket, 26 and 28 American wir
    1368590 3M 3448-3010 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368606 3M 3448-3014 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368618 3M 3448-3016 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368620 3M 3448-3020 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368631 3M 3448-3026 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368643 3M 3448-3030 Strain Relief
    1368655 3M 3448-3034 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368667 3M 3448-3040 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368679 3M 3448-3050 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368680 3M 3448-3060 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1368692 3M 3314-5002 Connectors, Headers & Receptacles, Four
    1368709 3M 3408-5002 Connectors, Headers & Receptacles, Four
    1368710 3M 3428-5002 Connectors, Headers & Receptacles, Four
    1368722 3M 3429-5002 Connectors, Headers & Receptacles, Four
    1368734 3M 3440-5002 Latch/ejector header, header, 30 circuit
    1368746 3M 3431-5002 Connectors, Headers & Receptacles, Four
    1368758 3M 3432-5002 Connectors, Headers & Receptacles, Four
    1368760 3M 3433-5002 Connectors, Headers & Receptacles, Four
    1368771 3M 3372-5002. Latch/ejector header, 60 contact, .1 in.
    1368783 3M 3314-6002 Connectors, Headers & Receptacles, Four
    1368795 3M 3408-6002 Connectors, Headers & Receptacles, Four
    1368801 3M 3428-6002 Connectors, Headers & Receptacles, Four
    1368813 3M 3429-6002 Connectors, Headers & Receptacles, Four
    1368825 3M 3440-6002 Connectors, Headers & Receptacles, Four
    1368837 3M 3431-6002 Connectors, Headers & Receptacles, Four
    1368849 3M 3432-6002 Connectors, Headers & Receptacles, Four
    1368850 3M 3433-6002 CONNECTORS, PCB HEADER AND JUMPERS MULTI
    1368862 3M 3372-6002 Connectors, Headers & Receptacles, Four
    1368874 3M 2510-5002UB CONNECTORS, PCB HEADER AND JUMPERS MULTI
    1368886 3M 2540-5002UB Connectors, Headers & Receptacles, Four
    1368898 3M 2550-5002UB Connectors, Headers & Receptacles, Four
    1368904 3M 2560-5002UB CONNECTORS, PCB HEADER AND JUMPERS MULTI
    1368916 3M 2510-6002UB Connectors, Headers & Receptacles, Four
    1368928 3M 2514-6002UB CONNECTORS, PCB HEADER AND JUMPERS MULTI
    1368930 3M 2526-6002UB Connectors; Connector Type: Four Wall Lo
    1368941 3M 2530-6002UB Low profile header
    1368953 3M 2534-6002UB Connectors, PCB header and Jumpers; Conn
    1368965 3M 2540-6002UB Connectors, Headers & Receptacles, Four
    1368977 3M 2550-6002UB Connectors, Headers & Receptacles, Four
    1368989 3M 2560-6002UB Connectors, Headers & Receptacles, Four
    1368990 3M 3358-0000 Connectors, Card Edge, 10 Contacts, Wir
    1369015 3M 3461-0000 Connectors, Card Edge, 20 Contacts, PCB
    1369027 3M 3462-0000 Connectors, Card Edge, 26 Contacts, Wir
    1369039 3M 3463-0000 Connectors, Card Edge, 34 Contacts, Wir
    1369040 3M 3464-0000 Connectors, Card Edge, 40 Contacts, PCB
    1369052 3M 3415-0000 Connectors, Card Edge, 50 Contacts, PCB
    1369064 3M 3666-0000 Connectors, Card Edge, 60 Contacts, Wir
    1369076 3M 3403-0000 Connectors, Card Edge, 64 Contacts, PCB
    1369088 3M 3358-0001 Connectors; Connector Type: Card Edge Co
    1369090 3M 3368-0001 Connectors, Card Edge, 16 Contacts, Wir
    1369106 3M 3461-0001 Connectors, Card Edge, 20 Contacts, PCB
    1369118 3M 3462-0001 Connectors, Card Edge, 26 Contacts, PCB
    1369120 3M 3463-0001 CONNECTORS, CARD EDGE CONNECTOR TYPE:CAR
    1369131 3M 3464-0001 Connectors, Card Edge, 40 Contacts, PCB
    1369143 3M 3415-0001 Connectors, Card Edge, 50 Contacts, PCB
    1369167 3M 3403-0001 Connectors, Card Edge, 64 Contacts, PCB
    1369192 3M 3461-0002 Connectors, Card Edge, 20 Contacts, Wir
    1369209 3M 3462-0002 Connectors, Card Edge, 26 Contacts, Wir
    1369222 3M 3464-0002 Connectors, Card Edge, 40 Contacts, Wir
    1369234 3M 3415-0002 Connectors, Card Edge, 50 Contacts, Wir
    1369246 3M 3666-0002 Connectors, Card Edge, 60 Contacts, Wir
    1369295 3M 3548-1000. D ribbon connector, plug, 24 position, g
    1369350 3M 3564-1000. D ribbon connector, plug, 50 position, g
    1369362 3M 3564-1001. D ribbon connector, plug, 50 position, p
    1369374 3M 3564-1002 Connectors, D-Subminiature, Plug, 50 Pos
    1369416 3M 3549-1000. D ribbon connector, socket, 24 position,
    1369477 3M 3565-1000. D ribbon connector, socket, 50 position,
    1369489 3M 3565-1001 Connectors, D-Subminiature, Socket, 50 P
    1369490 3M 3565-1002 Connectors, D-Subminiature, Socket, 50 P
    1369519 3M 8209-6000 Connectors, D-Subminiature, Plug, 9 Posi
    1369520 3M 8215-6000 Connectors, D-Subminiature, Plug, 15 Pos
    1369532 3M 8225-6000 Connectors, D-Subminiature, Plug, 25 Pos
    1369544 3M 8237-6000 Connectors, D-Subminiature, Plug, 37 Pos
    1369556 3M 8250-6005. Connectors, D-Subminiature, Plug, 50 Pos
    1369568 3M 8309-6000 Connectors, D-Subminiature, Socket, 9 Po
    1369570 3M 8315-6000 Connectors, D-Subminiature, Socket, 15 P
    1369581 3M 8325-6000 Connectors, D-Subminiature, Socket, 25 P
    1369593 3M 8337-6000 Connectors, D-Subminiature, Socket, 37 P
    1369600 3M 8350-6005. Connectors, D-Subminiature, Socket, 50 P
    1369611 3M 3365/9 Cable; Cable/Wire Type: Ribbon Cable; To
    1369623 3M 3365/10 Cable; Cable/Wire Type: Ribbon Cable; To
    1369635 3M 3365/14 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369647 3M 3365/16 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369659 3M 3365/20 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369660 3M 3365/26 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369672 3M 3365/34 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369684 3M 3365/37 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369696 3M 3365/40 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369702 3M 3365/50 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369714 3M 3365/60 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369726 3M 3302/9 Cable; Cable/Wire Type: Ribbon Cable; To
    1369738 3M 3302/10 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369740 3M 3302/14 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369751 3M 3302/16 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369763 3M 3302/20 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369775 3M 3302/26 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369787 3M 3302/34 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369805 3M 3302/40 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369817 3M 3302/50 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369829 3M 3302/60 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369842 3M 3659/09 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369854 3M 3659/10 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369866 3M 3659/15 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369878 3M 3659/20 (100') CABLE, ROUND, TWISTED AND FLAT RIBBON (F
    1369891 3M 3659/25 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369908 3M 3659/26 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369910 3M 3659/34 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369933 3M 3659/37 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369945 3M 3659/40 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369957 3M 3659/50 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1369969 3M 3659/60 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1374370 3M 3505-2 Connector Accessories, Short Latch, For
    1374382 3M 3505-3 Optional Ejector Latch for Click Headers
    1379124 3M 2210 Replacement Cord, Coiled, 5 foot Extende
    1379173 3M 2220 Replacement Cord, Coiled, 10 foot Extend
    1379185 3M 3040 15-foot grounding cord for static contro
    1379197 3M 7101 STATIC-SENSITIVE AWARENESS LABELS, LABEL
    1379203 3M 7102 STATIC-SENSITIVE AWARENESS LABELS, LABEL
    1379215 3M 7201 AWARENESS LABEL, INCHATTENTION: ELECTROS
    1379227 3M 7202 STATIC-SENSITIVE AWARENESS LABELS, LABEL
    1379239 3M 8501 Grounding Kit, Portable, for Field Servi
    1379276 3M 8023 Workstation Static Control Grounding Kit
    1379288 3M 8024 Workstation Static Control Grounding Kit
    1379320 3M 8033 Workstation Static Control Grounding Kit
    1379331 3M 8034 Workstation Static Control Grounding Kit
    1379355 3M 8201 Static-control floor mat, vinyl material
    1379379 3M 8211 TABLE MAT Static-control floor mat, vinyl material
    1383619 3M 3473-6010 Wiremount socket, 10 contact, .05 in. pi
    1383620 3M 3452-6016 Wiremount socket, 16 contact, .05 in. pi
    1383632 3M 3399-7026 Wiremount socket, 26 contact, .05 in. pi
    1383644 3M 3342-1. DSUB JACK SCREW KIT- SHORT- SINGLE KIT P
    1383656 3M 3425-7050 Wiremount socket, 50 contact, .05 in. pi
    1383668 3M 3421-6020 Wiremount socket, 20 contact, .05 in. pi
    1383670 3M 3448-4610. Plug, 10 contact, .1 in. pitch, 26 & 28
    1383693 3M 3429-1302 Latch/ejector header, header, 26 circuit
    1383700 3M 3341-1L. D/R JACK SKT KIT- LONG SINGLE KIT PKG
    1383711 3M 3399-6026 Wiremount socket, 26 contact, .05 in. pi
    1383735 3M 3473-7000 Connectors, IDC, Closed End, Receptacle,
    1383747 3M 3811/50 (100') 3811 Series Flat Cable, .050 in. Pitch,
    1383759 3M 3485-2500F. D-SUB CONNECTOR, BACKSHELL, 50 CONTACTS
    1383784 3M 3443-94. Locator Plate, For Socket Connectors
    1383796 3M 3399-6000 Connectors, IDC, Open End, Receptacle, 2
    1383802 3M 3385-6014 14/SKT/OP/SRC/30AVG
    1383826 3M 3397-0240 Breadboard solder strip, 24 circuit, 24
    1383838 3M 3425-6050 Wiremount socket, 50 contact, .05 in. pi
    1383863 3M 3357-6525. Metalized plastic EMI junction shell D-s
    1383905 3M 3422-0000T PCB, 26 and 28 American wire gauge, 20 c
    1383917 3M 3402-0000T PCB, 26 and 28 AWG, 34 circuit, 34 conta
    1383929 3M 3452-6000 Connectors, IDC, Open End, Receptacle, 1
    1383966 3M 3399-7000 Connectors, IDC, Closed End, Receptacle,
    1383978 3M 3432-6302 Latch/ejector header, header, 40 circuit
    1383980 3M 3428-6302 CONNECTORS, PCB
    1383991 3M 3334-7060 60/SKT/CL/SRC/30AVG
    1384004 3M 3417-7040 Wiremount socket, 40 contact, .05 in. pi
    1384065 3M 3372-6302 Latch/ejector header, 60 position, pcb c
    1384077 3M 3434-0000T PCB, 26 and 28 American wire gauge, 26 c
    1384090 3M 3518 Connector Accessories, Polarization Key,
    1384107 3M 3473-6000 Connectors, IDC, Open End, Receptacle, 1
    1384120 3M 3425-7000 CONNECTORS, PCB CONNECTOR TYPE:IDC; NUMB
    1384132 3M 3365/25 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1384156 3M 3428-6202 Latch/ejector header, header, 20 circuit
    1384181 3M 3950-0000T Connectors, PCB, Wire to Board, Male Gen
    1384211 3M 3414-6034 Wiremount socket, 34 contact, .05 in. pi
    1384235 3M 3429-6303 Latch/ejector header, header, 26 circuit
    1384247 3M 3417-6040 Wiremount socket, 40 contact, .05 in. pi
    1384259 3M 3432-6303 Latch/ejector header, header, 40 circuit
    1384260 3M 3341-4. D/DR JACK SKT KIT- SINGLE KIT PKG
    1384272 3M 3421-6000 Connectors, IDC, Open End, Receptacle, 2
    1384284 3M 3414-6000 Connectors, IDC, Open End, Receptacle, 3
    1384296 3M 3417-6000 Connectors, IDC, Open End, Receptacle, 4
    1384302 3M 3431-6303 Latch/ejector header, header, 34 circuit
    1384314 3M 3433-6303 Latch/ejector header, header, 50 circuit
    1393479 3M 8106 CONNECTOR, ST CONNECTOR, ZIRCONIA CERAMI
    1393510 3M 6105-B CONNECTOR, ST CONNECTOR, ZIRCONIA CERAMI
    1400150 3M 3549-2002 24/DR/SKT/METAL/THRD MT/30AVG/100PK
    1400228 3M 3565-3002 50/DRIB/F/MET FACE/DED BAIL/4-40 THD INS
    1408653 3M 3484-1 (BULK1000) Fasteners
    1408690 3M 3365/15 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1408707 3M 3365/24 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1408744 3M 3302/64 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1408768 3M 2010/10 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1418038 3M 4008 1" ACRYLIC ADHESIVE FOAM TAPE, URETHANE, 0.
    1418040 3M 4416 1" BLACK Acrylic Adhesive Foam Tape, Vinyl, 0.062
    1418051 3M 4408 1" Acrylic Adhesive Foam Tape, Vinyl, 0.125
    1418063 3M SJ-5009 (BLACK) BLACK, .40 x .88" DIAMETER DEP
    1430294 3M 2051 Heel Grounding Assembly, Comfortable Ela
    143075 3M UY BUTT CONNECTOR SCOTCHLOK, BUTT PK100
    143077 3M 560B BRIDGE CONNECTOR SCOTCHLOK, TAP PK10
    143078 3M 33+ 19MM X 20M VINYL TAPE TAPE, VINYL 33+ 19MM X 20M
    143079 3M 23 19MMX9M SELF FUSING TP TAPE, SELF AMALG. 19MM
    148290 3M 191-2801-115 RIBBON CABLE, 15 WAY PER M
    148291 3M 191-2801-116 RIBBON CABLE, 16 WAY PER M
    148292 3M 191-2801-120 RIBBON CABLE, 20 WAY PER M
    148294 3M 191-2801-125 RIBBON CABLE, 25 WAY PER M
    148296 3M 191-2801-134 RIBBON CABLE, 34 WAY PER M
    148301 3M 191-2801-164 RIBBON CABLE, 64 WAY PER M
    148922 3M SJ5076BLACK FEET, STICK ON PK56
    148923 3M SJ5312TRANS FEET, STICK ON PK56
    148924 3M SJ5018GREY FEET, STICK ON PK40
    148926 3M SJ5009GREY FEET, STICK ON PK48
    152309 3M SJ5018BLACK FEET STICK ON PK40
    1536280 3M 10226-6212VC Connectors, D-Subminiature, Socket, 26 P
    1536291 3M 10236-6212VC Connectors, D-Subminiature, Socket, 36 P
    1536308 3M 10250-6212VC Connectors, PCB, Mini D Ribbon, Female G
    1536310 3M 10268-6212VC Connectors, PCB, Mini D Ribbon, Female G
    1536321 3M 10226-55G3VC Connectors, PCB, Mini D Ribbon, Female G
    1536333 3M 10236-55G3VC Connectors, PCB, Mini D Ribbon, Female G
    1536345 3M 10250-55H3VC Connectors, PCB, Mini D Ribbon, Female G
    1536357 3M 10268-55H3VC Connectors, PCB, Mini D Ribbon, Female G
    1536369 3M 10126-6000EC PC Board Connector Number of Contacts:26
    1536370 3M 10150-6000EC Connectors, D-Subminiature, Plug, 50 Pos
    1536382 3M 10136-6000EC Connectors, D-Subminiature, Plug, 36 Pos
    1536394 3M 10168-6000EC Connectors, D-Subminiature, Plug, 68 Pos
    1536400 3M 10326-3210-000 Enclosures; Body Material: Plastic; Colo
    1536412 3M 10336-3210-000 JUNCTION SHELL ((NW))
    1536424 3M 10350-3210-000 Enclosures; Body Material: Plastic; Colo
    1536436 3M 10368-3210-000 Enclosures; Body Material: Plastic; Colo
    1536448 3M 3600B/26 (300') Cable; Number of Conductors: 26; Jacket
    1536473 3M 3600B/68 (300') 3600X Series Round Jacket Discrete Wire,
    1603590 3M 923252 MINI-BREADBOARD, 6.5 INCH LENGTH X 2.25
    1603607 3M 923695 Standard nail-head test clip, 8 contact,
    1603619 3M 923698 Standard nail-head test clip, 14 contact
    1603620 3M 923700 Standard nail-head test clip, 16 contact
    1603644 3M 923703 Test clip, alloy 770 contact, DIP
    1603656 3M 923704 Standard nail-head test clip, 20 contact
    1603670 3M 923714 Standard nail-head test clip, 24 contact
    1603681 3M 923718 Standard nail head test clip, 28 contact
    1603700 3M 923722 Standard nail-head test clip, 40 contact
    1603711 3M 922576-20-I CONNECTORS, PINS/RECEPTACLES PCB CONNECT
    1603723 3M 922576-26-I INTRA-CONNECTOR, NON-CORROSION ALLOY 770
    1603735 3M 922576-34-I INTRA-CONNECTOR, NON-CORROSION ALLOY 770
    1603747 3M 922576-40-I INTRA-CONNECTOR, NON-CORROSION ALLOY 770
    1603759 3M 922576-50-I INTRA-CONNECTOR, NON-CORROSION ALLOY 770
    1603796 3M 922578-40-I Intra-switch
    1603802 3M 922578-50-I Intra-switch
    1603875 3M 929974-01-36 Connectors, PCB, Wire to Board, Female G
    1609099 3M 923351-I JUMPER WIRE KIT, 350 PER PACK, 22 AMERIC
    1609105 3M 923690-08_ Long wire test clip, 8 contact, DIP
    1609117 3M 923690-14_ Long wire test clip, 14 contact, DIP
    1609129 3M 923690-16. Long wire test clip, 16 contact, DIP
    1609142 3M 923690-18 Long wire test clip, 18 contact, DIP
    1609154 3M 923690-20. Long wire test clip, 20 contact, DIP
    1609166 3M 923690-24. Long wire test clip, 24 contact, DIP
    1609178 3M 923690-28. Connectors; Connector Type: DIP IC Test
    1609180 3M 923690-40. Connectors; Connector Type: DIP IC Test
    1613030 3M 1245 TAPE (1/2) EMBOSS COP FOIL 4 MIL ACRYL ADH ON LINER
    1625688 3M 3793-5002 Connectors; Connector Type: Four Wall Ej
    1625690 3M 3793-6002 Connectors, Headers & Receptacles, Four
    1625706 3M 3793-6302 Latch/ejector header, header, 10 circuit
    1625718 3M 3793-6303 Latch/ejector header, header, 10 circuit
    162644 3M 4620 WRISTBAND, BLUE 4MM
    162670 3M 4623 WRISTBAND, MAROON 4MM
    162681 3M 4624 WRISTBAND, LIME 4MM
    162693 3M 4640 WRISTBAND, BLUE 10MM
    162711 3M 4610 GROUND CORD 1.5M
    162735 3M 4650 WRISTBAND SET, BLUE 4MM
    162747 3M 4654 WRISTBAND SET, LIME 4MM
    162759 3M 4670 WRISTBAND SET, BLUE 10MM
    162760 3M 4674 WRISTBAND SET, LIME 10MM
    1648871 3M 1181(3/4X18) Tape
    1648913 3M 3357-6515. Metalized plastic EMI junction shell D-s
    1648925 3M 3357-6537. Metalized plastic EMI junction shell D-s
    1648937 3M 3385-6614. 14/SKT/CB/OP/SRC/30AVG
    1648949 3M 3659/16 (100') Cable; Cable/Wire Type: Round-To-Flat Ca
    1677056 3M 8810 Table Mat, Static Control, Rubber, 2 foo
    1677068 3M 8811 Table Mat, Static Control, Rubber, 2 foo
    1677093 3M 8840 Table Runner, Static Control, Rubber, 2
    1677100 3M 8841 Table Runner, Static Control, Rubber, 2
    1677135 3M 8870 Anti-static floor mat, color gray, rubbe
    1677147 3M 8871 Floor Mat, Static Control, Rubber, 4 foo
    1678711 3M O/B+ Insulated electrical spring connector, o
    1678723 3M R/Y+ Insulated electrical spring connector, r
    1678735 3M B/G+ Insulated electrical spring connector, b
    1690681 3M 3042 GROUND KIT-2 WRIST STRAPS, MOU
    1702634 3M 923253 MINI-BREADBOARD, 4.9 INCH LENGTH X 2.25
    1733242 3M 6100 Hot melt connector, ST connector, multim
    1735652 3M 3302/25 (100') Cable; Total Number of Conductors: 25; J
    1743089 3M 4634-6001. Plug, 34 contact, .1 in. pitch, 26 & 28
    1743090 3M 4650-6001. Plug, 50 contact, .1 in. pitch, 26 & 28
    1743107 3M 4620-6000. Plug, 20 contact, .1 in. pitch, 26 & 28
    1744902 3M 35 GREEN (1/2"X20') Electrical Tape for Color Coding, Type 3
    1745244 3M 27 TAPE (3/4") Scotch 27 Glass Cloth Electrical Tape,
    1745256 3M 48(1/4"X260') Scotch Thread Sealant Tape, 1/4 inch Wi
    1745268 3M 48 1/2" Scotch Thread Sealant Tape, 1/2 inch Wi
    1745270 3M 2210 (4"X10') Scotch 2210 Vinyl Mastic Pad, 4 inch Wi
    1745293 3M 2242 (3/4"X15') Scotch 2242 Splicing Compound Tape, 3/4
    1745335 3M 16720 Highland Vinyl Plastic Electrical Tape,
    1745347 3M SWD SCOTCHCODE WRITE-ON TAPE DISPENSER WITH
    1745359 3M SWD-R REFILL TRANSPARENT PRESSURE-SENSITIVE TA
    1745360 3M SLW SCOTCHCODE WRITE-ON LARGE TAPE DISPENSE
    1745372 3M SMP-B SCOTCHCODE MARKING PEN, PERMANENT BLACK
    1745402 3M 35.. Electrical Tape for Color Coding, Vinyl
    1745426 3M 35 ORANGE (3/4"X66') Electrical Tape for Color Coding, Type 3
    1745440 3M 35 BLUE (1/2"X20') Electrical Tape for Color Coding, Type 3
    1745451 3M 35... Electrical Tape for Color Coding, Type 3
    1756746 3M 3048 GROUND SYSTEM-2 WRIST STRAPS, 15' CORD,
    1757854 3M 3448-63. Plastic Flat Ribbon Cable Connector, Del
    1757866 3M 3357-9209. Metal Junction Shell for EMI and ESD Pro
    1757878 3M 3357-9215. Metal Junction Shell for EMI and ESD Pro
    1757880 3M 3357-9225. Metal Junction Shell for EMI and ESD Pro
    1757891 3M 3357-9237. Metal Junction Shell for EMI and ESD Pro
    1757908 3M 3357-9250. 50/STEEL JS/D-SUB/RND CAB/STR PORT/100 P
    1757910 3M 3448-8D09A. Flat Ribbon Cable Connector, D-Subminiat
    1757921 3M 3448-8D15A. Flat Ribbon Cable Connector, D-Subminiat
    1757933 3M 3448-8D25A. Strain Relief
    1757945 3M 3448-8D37A. Flat Ribbon Cable Connector, D-Subminiat
    1757957 3M 3448-8D50 FLAT RIBBON CABLE CONNECTOR, D-SUBMINIAT
    1757969 3M 3626-6000 Connectors, IDC, Open End, Receptacle, 2
    1757970 3M 3626-6600 Connectors, IDC, Open End, Receptacle, 2
    1757982 3M 3448-3024 SOCKET CONNECTOR, OPTIONAL CLIP ON STRAI
    1757994 3M 3627-5002 Connectors, Headers & Receptacles, Four
    1758007 3M 3627-6002 Connectors, Headers & Receptacles, Four
    1758019 3M 3385-6000 Connectors, IDC, Open End, Receptacle, 1
    1758020 3M 3419-6000 Connectors, IDC, Open End, Receptacle, 3
    1758032 3M 3334-6000 CONNECTORS, PCB CONNECTOR TYPE:WIRE TO B
    1758482 3M 4634-6000. Plug, 34 contact, .1 in. pitch, 26 & 28
    1758494 3M 4640-6000. Plug, 40 contact, .1 in. pitch, 26 & 28
    1758500 3M 4650-6000. Plug, 50 contact, .1 in. pitch, 26 & 28
    1758512 3M 4660-6001 Connectors, IDC, Open End, Plug, 60 Cont
    1758536 3M 3448-52 CARD EDGE CONNECTORS (0.100)" STRAIN REL
    1758550 3M 3448-54 Card Edge Connector, 0.100 inch, Strain
    1758561 3M 3448-55 Card Edge Connector, 0.100 inch, Strain
    1758597 3M 3448-58 Card Edge Connector, 0.100 inch, Strain
    1758627 3M 4610-6000 Connectors, IDC, Open End, Plug, 10 Cont
    1758639 3M 4614-6000. Plug, 14 contact, .1 in. pitch, 26 & 28
    1758640 3M 4616-6000. Plug, 16 contact, .1 in. pitch, 26 & 28
    1758652 3M 4624-6000. Plug, 24 contact, .1 in. pitch, 26 & 28
    1758664 3M 4626-6000. Plug, 26 contact, .1 in. pitch, 26 & 28
    1758676 3M 4630-6000. Plug, 30 contact, .1 in. pitch, 26 & 28
    1758690 3M 4660-6000. Plug, 60 contact, .1 in. pitch, 26 & 28
    1758706 3M 4664-6000. Plug, 64 contact, .1 in. pitch, 26 & 28
    1758718 3M 4610-6001 Connectors, IDC, Open End, Plug, 10 Cont
    1758720 3M 4614-6001. Plug, 14 contact, .1 in. pitch, 26 & 28
    1758731 3M 4616-6001. Plug, 16 contact, .1 in. pitch, 26 & 28
    1758755 3M 4626-6001. Plug, 26 contact, .1 in. pitch, 26 & 28
    1758780 3M 4664-6001. Plug, 64 contact, .1 in. pitch, 26 & 28
    1758809 3M 3448-4640. Plug, 40 contact, .1 in. pitch, 26 & 28
    1758810 3M 3448-4650. Plug, 50 contact, .1 in. pitch, 26 & 28
    1758822 3M 3448-4660. Plug, 60 contact, .1 in. pitch, 26 & 28
    1758834 3M 3448-4664. Plug, 64 contact, .1 in. pitch, 26 & 28
    1758846 3M 4620-6001. Plug, 20 contact, .1 in. pitch, 26 & 28
    1758858 3M 3448-4614. Plug, 14 contact, .1 in. pitch, 26 & 28
    1758860 3M 3448-4616. Plug, 16 contact, .1 in. pitch, 26 & 28
    1758871 3M 3448-4620. Plug, 20 contact, .1 in. pitch, 26 & 28
    1758895 3M 3448-4626. Plug, 26 contact, .1 in. pitch, 26 & 28
    1758913 3M 3448-4634. Plug, 34 contact, .1 in. pitch, 26 & 28
    1759061 3M 923345-08 Jumper wire, .8 in. length, gray, 150 pe
    1759073 3M 923345-09 Jumper wire, .9 in. length, white, 150 p
    1759085 3M 923345-10 Jumper wire, 1 in. length, brown, 100 pe
    1759097 3M 923345-20 Jumper wire, 2 in. length, red, 100 per
    1759103 3M 923345-30 Jumper wire, 3 in. length, orange, 75 pe
    1759115 3M 923345-40 Jumper wire, 4 in. length, yellow, 75 pe
    1759127 3M 923345-50 Jumper wire, 5 in. length, green, 75 per
    1759140 3M 923345-02 Jumper wire, .2 in. length, red, 200 per
    1759152 3M 923345-03 Jumper wire, .3 in. length, orange, 200
    1759164 3M 923345-04 Jumper wire, .4 in. length, yellow, 200
    1759176 3M 923345-05 Jumper wire, .5 in. length, green, 200 p
    1759188 3M 923345-06 Jumper wire, .6 in. length, blue, 150 pe
    1759190 3M 923345-07 Jumper wire, .7 in. length, violet, 150
    1759206 3M 923670-44. Test clip, 44 contact, PLCC
    1759243 3M 923717 Standard nail-head test clip, 28 contact
    1759255 3M 923719 Standard nail-head test clip, 32 contact
    1760282 3M 3750/10 (100') Cable; Number of Conductors: 10; Jacket
    1760300 3M 3750/26 (100') Cable; Number of Conductors: 26; Jacket
    1760361 3M 3476/40 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760373 3M 3476/50 Cable; Cable/Wire Type: Ribbon Cable; To
    1760397 3M 1700/40 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760403 3M 1700/50 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760415 3M 1700/60 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760427 3M 1700/64 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760464 3M 1700/10 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760476 3M 1700/14 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760488 3M 1700/16 (100') CABLE, TWIST AND FLAT RIBBON (FLAT) CABL
    1760490 3M 1700/20 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760506 3M 1700/26 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1760518 3M 1700/34 (100') Cable; Cable/Wire Type: Ribbon Cable; To
    1767410 3M 923690-32 Long wire test clip, 32 contact, DIP
    1767422 3M 923689-28 Long wire test clip, 28 contact, DIP
    1779710 3M 2209 Wrist Strap, 3 M Brand, Disposable
    1779734 3M 2204 Wrist Band, for Adjustable 3 M Brand Wri
    1779746 3M 2214 Wrist Brand Strap Set, 3 M, Adjustable,
    1779758 3M 2224 Wrist Brand Strap Set, 3 M, Adjustable,
    1779771 3M 2244 Wrist Brand Strap Set, 3 M, Adjustable,
    178253 3M 228-6023. IC SOCKET, ZIF 28 WAY
    178254 3M 232-1287. IC SOCKET, ZIF 32 WAY
    178255 3M 240-6182. IC SOCKET, ZIF 40 WAY
    178270 3M 923690-08 TEST CLIP, DIL 8 WAY
    178271 3M 923690-14 TEST CLIP, DIL 14 WAY
    178272 3M 923690-16 TEST CLIP, DIL 16 WAY
    178273 3M 923690-20 TEST CLIP, DIL 20 WAY
    178274 3M 923689-24 TEST CLIP, DIL 24 WAY
    178275 3M 923690-24_ TEST CLIP, DIL 24 WAY
    178276 3M 923690-28 TEST CLIP, DIL 28 WAY
    178277 3M 923690-40 TEST CLIP, DIL 40 WAY
    178278 3M 923650-08 TEST CLIP, SOIC 8 WAY
    178279 3M 923650-14 TEST CLIP, SOIC 14 WAY
    178280 3M 923650-16 TEST CLIP, SOIC 16 WAY
    178282 3M 923660-20 TEST CLIP, SOIC 20 WAY
    178283 3M 923660-24 TEST CLIP, SOIC 24 WAY
    1810042 3M 3421-7600 Connectors, IDC, Closed End, Receptacle,
    1810054 3M 3626-7000 Connectors, IDC, Closed End, Receptacle,
    1810066 3M 3626-7600 Connectors, IDC, Closed End, Receptacle,
    1810078 3M 3399-7600 Connectors, IDC, Closed End, Receptacle,
    1810091 3M 3419-7600 Connectors, IDC, Closed End, Receptacle,
    1810108 3M 3385-7000 Connectors, IDC, Closed End, Receptacle,
    1810110 3M 3385-7600 Connectors, IDC, Closed End, Receptacle,
    1810121 3M 3452-7000 Connectors, IDC, Closed End, Receptacle,
    1810133 3M 3452-7600 CONNECTORS, PCB CONNECTOR TYPE:IDC; NUMB
    1810145 3M 3421-7000 Connectors, IDC, Closed End, Receptacle,
    1810157 3M 3414-7000 Connectors, IDC, Closed End, Receptacle,
    1810169 3M 3414-7600 Connectors, IDC, Closed End, Receptacle,
    1810170 3M 3417-7000 CONNECTORS, PCB CONNECTOR TYPE:IDC; NUMB
    1810182 3M 3417-7600 Connectors, IDC, Closed End, Receptacle,
    1810194 3M 3425-7600 Connectors, IDC, Closed End, Receptacle,
    1810200 3M 3334-7000 Connectors, PCB, Wire to Board, Female G
    1810212 3M 3334-7600 Connectors, PCB, Wire to Board, Female G
    1810224 3M 3505-16. Short ejector latch
    1810248 3M 3940-0000T Connectors, PCB, Wire to Board, Male Gen
    1810273 3M 3473-7600 Connectors, IDC, Closed End, Receptacle,
    1810297 3M 3443-106N. Locator plate
    1810303 3M 3910-0000T Connectors, PCB, Wire to Board, Male Gen
    1810315 3M 3914-0000T Connectors, PCB, Wire to Board, Male Gen
    1810327 3M 3916-0000T Connectors, IDC, Open End, Receptacle, 1
    1810352 3M 3926-0000T Connectors, IDC, Open End, Receptacle, 2
    1810418 3M 925980-R IDC Assembly Hand Tool (Includes Anvil),
    1812853 3M MH14-14R/SX Connectors; Connector Type: Ring Tongue
    1812865 3M MH14-516R/SX Connectors; Connector Type: Ring Tongue
    1812877 3M MH14-38RX Connectors; Connector Type: Ring Tongue
    1812907 3M MH10-14RX Connectors; Connector Type: Ring Tongue
    1812919 3M MH10-38RX (BOX) Connectors; Connector Type: Ring Tongue
    1812920 3M MH18-6FLX Connectors; Connector Type: Ring Tongue
    1812932 3M MH18-10FLX Connectors; Connector Type: Ring Tongue
    1812944 3M MH14-6FLX Connectors; Connector Type: Ring Tongue
    1812956 3M MH14-10FLX Connectors; Connector Type: Ring Tongue
    1812970 3M MH10-8FLX Connectors; Connector Type: Ring Tongue
    1812981 3M MH10-10FLX Connectors; Connector Type: Ring Tongue
    1812993 3M MH10-14FLX Connectors; Connector Type: Ring Tongue
    1813006 3M MNHU18-250DFIX Connectors; Connector Type: Ring Tongue
    1813018 3M MNHU14-250DFIX Connectors; Connector Type: Ring Tongue
    1813020 3M MNHU14-250DMIX Connectors; Connector Type: Ring Tongue
    1813122 3M MNHU10-250DMIX Connectors; Connector Type: Ring Tongue
    1813134 3M 314 (BOXED) Self stripping connector, 22-14 AWG, blu
    1813225 3M 8213 Static-control table mat, vinyl material
    1813237 3M 8214 Static-control table mat, vinyl construc
    1826049 3M MNHU10-250DFIX Connectors; Connector Type: Ring Tongue
    1827224 3M 562 (BOXED) Self stripping IDC, 12/10 AWG, yellow
    1827236 3M 564 (BULK) Self stripping IDC, 18-14 AWG, white
    1827248 3M 567 (BOXED) Self stripping IDC, 18-14 TAP and 12-10
    1839457 3M 3425-6000 Connectors, IDC, Open End, Receptacle, 5
    1852796 3M 2272 Wrist Strap Set, 3 M, Adjustable, Highla
    1852814 3M 2271 Wrist Band, for Adjustable 3 M Wrist Str
    1852875 3M 8215 Anti-static table mat, vinyl material, 2
    1854422 3M 8307 CONNECTOR, SC CONNECTOR, HIGH REPEATABIL
    1854501 3M 6300 Hot melt connector, SC connector, high r
    1854549 3M 922306 PCB PCB Type: Solderless; Pitch Spacing:
    1854550 3M 922309 PCB PCB Type: Solderless; Pitch Spacing:
    1854562 3M 922318 PCB PCB Type: Solderless; Pitch Spacing:
    1854574 3M 922327 PCB PCB Type: Solderless; Pitch Spacing:
    1854586 3M 922336 PCB PCB Type: Solderless; Pitch Spacing:
    1854604 3M 922354 PCB PCB Type: Solderless; Pitch Spacing:
    1854628 3M 2340-5211TG Connectors, Headers & Receptacles, Pin H
    1854641 3M 2380-5121TG Connectors, Headers & Receptacles, Pin H
    1854653 3M 2380-5121TN Connectors, Headers & Receptacles, Pin H
    1854677 3M 2380-5221TG Connectors, Headers & Receptacles, Pin H
    1854689 3M 2340-6111TG Connectors, Headers & Receptacles, Pin H
    1854690 3M 2340-6111TN Connectors, Headers & Receptacles, Pin H
    1854707 3M 2340-6211TG Connectors, Headers & Receptacles, Pin H
    1854720 3M 2380-6121TG Connectors, Headers & Receptacles, Pin H
    1854732 3M 2380-6121TN Connectors, Headers & Receptacles, Pin H
    1854744 3M 2380-6221TG Connectors, Headers & Receptacles, Pin H
    1854756 3M 2380-6221TN Connectors, Headers & Receptacles, Pin H
    1854768 3M 2340-5111TG Connectors, Headers & Receptacles, Pin H
    1854770 3M 89110-0101. Preassembled wiremount socket, 10 contac
    1854781 3M 89114-0101. Preassembled wiremount socket, 14 contac
    1854793 3M 89116-0101. Preassembled wiremount socket, 16 contac
    1854800 3M 89120-0101. Preassembled wiremount socket, 20 contac
    1854811 3M 89126-0101. Preassembled wiremount socket, 26 contac
    1854823 3M 89134-0101. Preassembled wiremount socket, 34 contac
    1854835 3M 89140-0101. Preassembled wiremount socket, 40 contac
    1854847 3M 89150-0101. Preassembled wiremount socket, 50 contac
    1854859 3M 89160-0101 Connectors, IDC, Open End, Receptacle, 6
    1854884 3M 3448-89116. Plastic strain relief
    1854896 3M 3448-89120. STRAIN RELIEF/DUAL RECESS/89120 SKT CONN
    1854902 3M 3448-89126. Strain Relief for IDC Socket, 26 Pins
    1854914 3M 3448-89134. Strain Relief for IDC Socket, 34 Pins
    1854926 3M 3448-89140. Strain Relief for IDC Socket, 40 Pins
    1854938 3M 3448-89150. Strain Relief for IDC Socket, 50 Pins
    1854951 3M 3435-0 Keying plug
    1854975 3M 3490-89124 Pull tab, 24-36 contact, 891 series
    1854987 3M 3490-89140 Pull tab, 40-60 contact, 891 series
    1855025 3M 89837-8000 Connectors, D-Subminiature, Plug, 37 Pos
    1855049 3M 89915-8000 Connector, socket, 15 position, steel sh
    1855645 3M 3460-0000 DIP connector, pcb termination, gold ove
    1896544 3M 2529-K UNIVERSAL SPLICE KIT, FIBRLOK™ II,
    1909058 3M 3357-6509. Metalized plastic EMI junction shell D-s
    1909071 3M 3399-7626 CONNECTORS, IDC
    1909125 3M 3759/14 (100') Cable; Total Number of Conductors: 14; J
    1912562 3M 62C64-1100EF. Eurosocket, 26 and 28 AWG, socket, strai
    1924096 3M 2524-6002UB Connectors, Headers & Receptacles, Four
    1924102 3M 2516-6002UB Connectors; Connector Type: Four Wall Lo
    1935367 3M 2526-5002UB Connectors, Headers & Receptacles, Four
    1935379 3M 2520-5002UB. Low profile header, 20 contact, .1 in. p
    1935598 3M 6147 Scotch 06147 Electrical Moisture Sealan
    1935604 3M 6149 Scotch 06149 Electrical Moisture Sealan
    1941008 3M 2516-5002UB Connectors, Headers & Receptacles, Four
    1941010 3M 2524-5002UB Connectors, Headers & Receptacles, Four
    1941033 3M 2534-5002UB Connectors, Headers & Receptacles, Four
    1949755 3M R18-4C CONNECTORS, RING CRIMP CONNECTORS WIRE S
    1949767 3M R18-6C Connectors; Color: None; Stud/Tab Size:
    1949779 3M R18-8C Connectors; Color: None; Stud/Tab Size:
    1949780 3M R18-10C Connectors; Color: None; Stud/Tab Size:
    1949792 3M R14-4C Connectors; Color: None; Stud/Tab Size:
    1949809 3M R14-6C Connectors; Color: None; Stud/Tab Size:
    1949810 3M R14-8C Connectors; Color: None; Stud/Tab Size:
    1949822 3M R14-10C Connectors; Color: None; Stud/Tab Size:
    1949846 3M R10-8L Connectors; Color: None; Stud/Tab Size:
    1949858 3M R10-10L Connectors; Color: None; Stud/Tab Size:
    1949860 3M R10-14L Connectors; Color: None; Stud/Tab Size:
    1949871 3M RV18-6C Vinyl insulated butted seam ring tongue
    1949883 3M RV18-8C Vinyl insulated butted seam ring tongue
    1949895 3M RV18-10C Vinyl insulated butted seam ring tongue
    1949913 3M RV14-6C Connectors; Color: None; Stud/Tab Size:
    1949925 3M RV14-8C Vinyl insulated butted seam ring tongue
    1949937 3M RV14-10C Vinyl insulated butted seam ring tongue
    1949949 3M RV14-14C Vinyl insulated butted seam ring tongue
    1949950 3M RV14-516L Vinyl insulated butted seam ring tongue
    1949974 3M RV10-10L Connectors; Color: None; Stud/Tab Size:
    1949986 3M RV10-14L Connectors; Color: None; Stud/Tab Size:
    1949998 3M RV10-38L VINYL INSL RING TERMINAL, WIRE 12-10, ST
    1950009 3M RV10-516Q Connectors; Color: None; Stud/Tab Size:
    1950071 3M FV14-8C Vinyl insulated brazed seam standard for
    1950216 3M BFV18-6C Connectors; Color: Red; Stud/Tab Size: 6
    1950228 3M BFV18-8C Connectors; Color: Red; Stud/Tab Size: 8
    1950230 3M BFV18-10C Connectors; Color: Red; Stud/Tab Size: 1
    1950241 3M BFV14-6C Connectors; Color: Blue; Stud/Tab Size:
    1950253 3M BFV14-8C Connectors; Color: Blue; Stud/Tab Size:
    1950265 3M BFV14-10C Connectors; Color: Blue; Stud/Tab Size:
    1950277 3M BFV10-6L Connectors; Color: Yellow; Stud/Tab Size
    1950289 3M BFV10-8L Connectors; Color: Yellow; Stud/Tab Size
    1950290 3M BFV10-10L Connectors; Color: Yellow; Stud/Tab Size
    1950400 3M LFV18-4L Connectors; Color: Red; Stud/Tab Size: 4
    1950411 3M LFV18-6L Vinyl insulated butted seam locking fork
    1950423 3M LFV18-8L Vinyl insulated butted seam locking fork
    1950435 3M LFV14-6L Vinyl insulated butted seam locking fork
    1950447 3M LFV14-8L Vinyl insulated butted seam locking fork
    1950459 3M LFV14-10L Vinyl insulated butted seam locking fork
    1950496 3M BS18C Connectors; Color: None; Wire Size (AWG)
    1950502 3M BS14C Connectors; Color: None; Wire Size (AWG)
    1950514 3M BS10L Connectors; Color: None; Wire Size (AWG)
    1950526 3M BSV18C Butted seam butt connector, 22-18 Americ
    1950538 3M BSV14C Butted seam butt connector, 16-14 Americ
    1950540 3M BSV10L Butted seam butt connector, 12-10 Americ
    1950551 3M FD18-187C Connectors; Color: None; Stud/Tab Size:
    1950563 3M FD18-250C Connectors; Color: None; Stud/Tab Size:
    1950575 3M FD14-187C Connectors; Color: None; Stud/Tab Size:
    1950587 3M FD14-250C Connectors; Color: None; Stud/Tab Size:
    1950599 3M FD10-250L Connectors; Color: None; Stud/Tab Size:
    1950605 3M FDV18-187C Vinyl insulated butted seam female disco
    1950617 3M FDV18-250C Vinyl insulated butted seam female disco
    1950629 3M FDV14-187C Vinyl insulated butted seam female disco
    1950630 3M FDV14-250C Vinyl insulated butted seam female disco
    1950642 3M FDV10-250L Vinyl insulated butted seam female disco
    1950654 3M FDI18-187C Fully insulated butted seam female disco
    1950666 3M FDI18-250C Fully insulated butted seam female disco
    1950678 3M FDI14-187C Fully insulated butted seam female disco
    1950680 3M FDI14-250C Fully insulated butted seam female disco
    1950691 3M FDI10-250L Fully insulated butted seam female disco
    1950769 3M MTV18-250C Vinyl insulated butted seam male disconn
    1950800 3M MTI18-187C Nylon fully insulated butted seam male d
    1950824 3M MTI14-187C Nylon fully insulated butted seam male d
    1950836 3M MTI14-250C Nylon fully insulated butted seam male d
    1950848 3M MTI10-250L Nylon fully insulated butted seam male d
    1950850 3M SPV18-156L Connectors; Color: Red; Wire Size (AWG):
    1950861 3M SPV14-156L Connectors; Color: Blue; Wire Size (AWG)
    1950885 3M SRI14-156L Nylon insulated butted seam snap recepta
    1959724 3M 471 YELLOW 2" Type 471 Plastic Film Lane Marking Tape,
    1963478 3M MP-3401/02 WHITE Scotchmate™ Hook and Loop Fastenin
    1963480 3M MP-3401/02 BLACK Scotchmate™ Hook and Loop Fastenin
    1963491 3M MP-3526/27 WHITE Scotchmate™ Hook and Loop Fastenin
    1963508 3M MP-3526/27 BLACK Tape
    1963510 3M MP-3541/42 BLACK Dual Lock™ Reclosable Fastening Sy
    1963521 3M MP-3551/52 BLACK Dual Lock™ Reclosable Fastening Sy
    1963533 3M MP-3560 CLEAR Dual Lock™ Reclosable Fastening Sy
    1963557 3M 6969 2" SILVER Duct Tape, Cloth, 2 inch Width x 60 yard
    1963582 3M 5480 1" Type 5480 Skived PTFE Film Tape, 1 inch
    1963600 3M 5490 Type 5490 Extruded PTFE Film Tape, 1 inc
    1963624 3M 5413 1/2" Polymide Film Tape, 1/2 inch Width x 36
    1963636 3M 5413 3/4" Polymide Film Tape, 3/4 inch Width x 36
    1963648 3M 1280 2" Type 1280 Circuit Board Plating Tape, 2
    1963715 3M 425 2" Type 425 Aluminum Foil Tape, 2 inch Widt
    1989420 3M 3439-2 Keying plug
    1997634 3M 3341-1S. D/R JACK SKT KIT- SHORT- SINGLE KIT PKG
    1997658 3M 3425-6650. Wiremount socket, 50 contact, .05 in. pi
    1997671 3M 3429-6302 Latch/ejector header, header, 26 circuit
    1997683 3M 3431-6302 Latch/ejector header, header, 34 circuit
    1997701 3M 3433-6302 Latch/ejector header, header, 50 circuit
    1997713 3M 3433-6305 Latch/ejector header, header, 50 circuit
    1997749 3M 3485-2400F. Plastic junction shell D sub connector,
    1997762 3M 3759/50 (100') Cable; Total Number of Conductors: 50; J
    1997981 3M 3341-3 DR/J-SKT/IEEE-448/SINGLE KIT PKG/300
    1997993 3M 3414-7034 Wiremount socket, 34 contact, .05 in. pi
    1998006 3M 3417-6640. Wiremount socket, 40 contact, .05 in. pi
    1998055 3M 3473-7010 Wiremount socket, 10 contact, .05 in. pi
    1998067 3M 3801/50 (100') Cable; Total Number of Conductors: 50; J
    1998079 3M 7964-6500EC. Wiremount socket, 64 contact, .05 in. pi
    2004823 3M 3429-5302 CONNECTORS, PCB
    2004835 3M 3431-5302 Latch/ejector header, header, 34 circuit
    2004847 3M 3432-5302 Latch/ejector header, header, 40 circuit
    2004872 3M 3448-7964 64/SRC/SKT
    2004884 3M 3452-6616. Wiremount socket, 16 contact, .05 in. pi
    2004902 3M 4610-6051. Plug, 10 contact, .1 in. pitch, 26 & 28
    2004914 3M 8337-6003 Connectors, D-Subminiature, Socket, 37 P
    2006194 3M 3314-6302 Latch/ejector header, header, 14 circuit
    2006200 3M 3365/64 (100') Cable; Total Number of Conductors: 64; J
    2006212 3M 3399-6626. Wiremount socket, 26 contact, .05 in. pi
    2006224 3M 3408-5302 Latch/ejector header, header, 16 circuit
    2006236 3M 3414-6634. Wiremount socket, 34 contact, .05 in. pi
    2006248 3M 3417-7640 Wiremount socket, 40 contact, .05 in. pi
    2006250 3M 3421-6620. Wiremount socket, 20 contact, .05 in. pi
    2006261 3M 3421-7620 Wiremount socket, 20 contact, .05 in. pi
    2006273 3M 3425-7650 CONNECTORS, IDC
    2006327 3M 3433-5302 Latch/ejector header, header, 50 circuit
    2006339 3M 3473-6610. Wiremount socket, 10 contact, .05 in. pi
    2006340 3M 3473-7610 Wiremount socket, 10 contact, .05 in. pi
    2006352 3M 3759/37 (100') Cable; Total Number of Conductors: 37; J
    2006376 3M 4650-6300 Plug, 50 contact, .1 in. pitch, 26 & 28
    2006406 3M 7296-50C2TH Normal DIN header, 96 contact, 1000 Vrms
    2006492 3M 130C (3/4"X30') Scotch 130C Splicing Compound Tape, 3/4
    2006509 3M 23 (3/4"X30') 3/4" x 30', SELF-FUSING, 30 MI
    2024032 3M FOIL TAPE KIT Foil Tape Engineering Kit, 3/4 inch Widt
    2024044 3M 1183 (1X18YDS) Tape
    2024056 3M 8505 Grounding Kit, Portable, for Field Servi
    2024421 3M 82100-6006 CONNECTORS, PCB CONNECTOR TYPE:D SUBMINI
    2024445 3M 82020-6006 Connectors; Connector Type: Wire To Boar
    2024470 3M 82040-6006 Connectors; Connector Type: Wire To Boar
    2024482 3M 82050-6006 Connectors, PCB, Wire to Board, Female G
    2024500 3M 82068-6006 Connectors, PCB, Wire to Board, Female G
    2024512 3M 82080-6006 Connectors, PCB, Wire to Board, Female G
    2024524 3M 3749/20 (100') Cable; Total Number of Conductors: 20; J
    2024548 3M 3749/40 (100') Cable; Total Number of Conductors: 40; J
    2024550 3M 3749/50 (100') Cable; Total Number of Conductors: 50; J
    2024573 3M 3749/68 (100') Cable; Total Number of Conductors: 68; J
    2024585 3M 3749/80 (100') Cable; Total Number of Conductors: 80; J
    2052428 3M SWB-1 SCOTCHCODE WRITE-ON BOOK, 0.50 INCH WID
    2052430 3M SWB-2 SCOTCHCODE WRITE-ON BOOK, 0.75 INCH WID
    2052441 3M SWB-3 SCOTCHCODE WRITE-ON BOOK, 1.0 INCH WIDT
    2052465 3M SPB-01 PREPRINTED BOOK, 45 EACH 0-9; 15 EACH L1
    2052477 3M SPB-02 PREPRINTED BOOK, 10 EACH A-Z; 0-15, +, -
    2052489 3M SPB-03 PREPRINTED BOOK, 10 EACH 1-45, SCOTCHCOD
    2052829 3M STD Tape Dispenser, Wire Marker, SCOTCHCODE&
    2052830 3M 69 (1/2"X66') Insulating Tape
    2052842 3M 69 (3/4"X66') TAPE,INSULATING,INSULATING,SCOTCH 69 GLA
    2052866 3M 2228-2x10FT Scotch 2228 Rubber Mastic Roll, 2 inch
    2052878 3M 804 BOX Moisture resistant tap connector
    2059253 3M 3759/9 Cable; Cable/Wire Type: Round-To-Flat Ca
    2059289 3M 3759/25 (100') Cable; Cable/Wire Type: Round-To-Flat Ca
    2059290 3M 3759/26 (100') Cable; Cable/Wire Type: Round-To-Flat Ca
    2059319 3M 3759/40 (100') Cable; Cable/Wire Type: Round-To-Flat Ca
    2059320 3M 3759/60 (100') Cable; Cable/Wire Type: Round-To-Flat Ca
    2059368 3M 923689-24. Long wire test clip, 24 contact, DIP
    2060553 3M DEL-FP-301 1/4" CL 100' HEAT SHRINK TUBING-FLEXIBLE POLYOLEFIN T
    2073810 3M SDR-WH WIRE MARKER TAPE REFILL FOR STD DISPENSE
    2073821 3M SDR-YL WIRE MARKER TAPE REFILL FOR STD DISPENSE
    2073833 3M 3564-2000 D ribbon connector, plug, 50 position, g
    2073857 3M 8209-6003 Connectors, D-Subminiature, Plug, 9 Posi
    2073869 3M 8215-6003 Connectors, D-Subminiature, Plug, 15 Pos
    2073870 3M 8225-6003 Connectors, D-Subminiature, Plug, 25 Pos
    2073882 3M 8237-6003 Connectors, D-Subminiature, Plug, 37 Pos
    2073894 3M 8309-6003 Connectors, D-Subminiature, Socket, 9 Po
    2073900 3M 8315-6003 Connectors, D-Subminiature, Socket, 15 P
    2073936 3M 3426-0000T PCB connector, 50 contact, .1 in. pitch,
    2116959 3M SLW-R Tape, Refill Roll for Type SLW
    2151844 3M 1181 TAPE (1/4) Scotch 1181 EMI/RFI Foil Shielding Tape
    2151856 3M 1181 TAPE (1/2) Scotch 1181 EMI/RFI Foil Shielding Tape
    2151870 3M 1345 TAPE (1/2) Scotch 1345 EMI/RFI Foil Shielding Tape
    2161473 3M 929647-01-36 Pin strip header, male, 36 circuit, 36 c
    2161850 3M 3505-62. Latch bracket, stainless steel, nickel p
    2161862 3M 929952-10 Shunt, straight, gold over nickel finish
    2183493 3M 3429-6202 Latch/ejector header, header, 26 circuit
    2183845 3M 3759/20 (100') Cable; Cable/Wire Type: Round-To-Flat Ca
    2185003 3M 4016 1" Acrylic Adhesive Foam Tape, Urethane, 0.
    2185696 3M 3050 FEMALE FASTENER FOR 8200 MATS
    2186652 3M 4626-6300 Plug, 26 contact, .1 in. pitch, 26 & 28
    2187930 3M E-9BM HAND, CRIMP, TOOL
    2188466 3M E-9Y CRIMP TOOL, SPRING RETURN
    2188478 3M 8325-6003 Connectors, D-Subminiature, Socket, 25 P
    2188569 3M 2514-5002UB Connectors, Headers & Receptacles, Four
    2188582 3M 4640-6001. Plug, 40 contact, .1 in. pitch, 26 & 28
    2188612 3M 2520-6002UB Connectors, Headers & Receptacles, Four
    2189409 3M 3759/34 (100') Cable; Total Number of Conductors: 34; J
    2189422 3M 701 Test Kit for Static Control Surface
    2189689 3M 3749/100 (100') Cable; Total Number of Conductors: 100;
    2190552 3M 3695-0000. Europlug, 64 contact, .1 in. pitch, pcb
    2194636 3M 929665-09-36-I 72/PS/2R/SRT/.235 .145/ALL 10AVE CONNECT
    289553 3M 8500 MASK, NUISANCE DUST (PK50)
    289565 3M 8710E MASK, EN149FFP1 (PK20)
    289577 3M 8812 MASK, EN149FFP1 (PK10)
    289589 3M 8810 MASK, EN149FFP2 (PK20)
    289590 3M 8822 MASK, EN149FFP2S (PK10)
    289607 3M 8825 MASK, EN149FFP2SL (PK5)
    289619 3M 8835 MASK, EN149FFP3SL (PK5)
    289620 3M 9925 MASK, EN149FFP2S (PK10)
    289632 3M 4251 MASK EN405FFA1P1
    289668 3M 105 WIPES, MASK SEAL PK40
    291080 3M 232-1285. IC SOCKET, ZIF 32 WAY
    291092 3M 210-2599-00-0602. IC SOCKET, ZIF 10 WAY
    291109 3M 220-2600-00-0602. IC SOCKET, ZIF 20 WAY
    291110 3M 232-2601-00-0602. IC SOCKET, ZIF 32 WAY
    291122 3M 220-3342. IC SOCKET, ZIF 20 WAY
    296790 3M 3365-9 RIBBON CABLE, 9 WAY 30.5M
    296806 3M 3365-10 RIBBON CABLE, 10 WAY 30.5M
    296818 3M 3365-14 RIBBON CABLE, 14 WAY 30.5M
    296820 3M 3365-15 RIBBON CABLE, 15 WAY 30.5M
    296831 3M 3365-16 RIBBON CABLE, 16 WAY 30.5M
    296843 3M 3365-20 RIBBON CABLE, 20 WAY 30.5M
    296855 3M 3365-25 RIBBON CABLE, 25 WAY 30.5M
    296867 3M 3365-26 RIBBON CABLE, 26 WAY 30.5M
    296879 3M 3365-34 RIBBON CABLE, 34 WAY 30.5M
    296880 3M 3365-37 RIBBON CABLE, 37 WAY 30.5M
    296892 3M 3365-40 RIBBON CABLE, 40 WAY 30.5M
    296909 3M 3365-50 RIBBON CABLE, 50 WAY 30.5M
    296910 3M 3365-60 RIBBON CABLE, 60 WAY 30.5M
    296922 3M 3302-9 RIBBON CABLE, 9 WAY 30.5M
    296934 3M 3302-10 RIBBON CABLE, 10 WAY 30.5M
    296946 3M 3302-14 RIBBON CABLE, 14 WAY 30.5M
    296960 3M 3302-16 RIBBON CABLE, 16 WAY 30.5M
    296971 3M 3302-20 RIBBON CABLE, 20 WAY 30.5M
    296983 3M 3302-25 RIBBON CABLE, 25 WAY 30.5M
    296995 3M 3302-26 RIBBON CABLE, 26 WAY 30.5M
    297008 3M 3302-34 RIBBON CABLE, 34 WAY 30.5M
    297010 3M 3302-37 RIBBON CABLE, 37 WAY 30.5M
    297021 3M 3302-40 RIBBON CABLE, 40 WAY 30.5M
    297033 3M 3302-50 RIBBON CABLE, 50 WAY 30.5M
    297045 3M 3302-60 RIBBON CABLE, 60 WAY 30.5M
    297057 3M 3659-9 RIBBON CABLE, RND/FLAT 9 WAY 30.5M
    297069 3M 3659-10 RIBBON CABLE, RND/FLAT 10 WAY 30.5M
    297070 3M 3659-14 RIBBON CABLE, RND/FLAT 14 WAY 30.5M
    297082 3M 3659-15 RIBBON CABLE, RND/FLAT 15 WAY 30.5M
    297094 3M 3659-16 RIBBON CABLE, RND/FLAT 16 WAY 30.5M
    297100 3M 3659-20 RIBBON CABLE, RND/FLAT 20 WAY 30.5M
    297112 3M 3659-25 RIBBON CABLE, RND/FLAT 25 WAY 30.5M
    297124 3M 3659-26 RIBBON CABLE, RND/FLAT 26 WAY 30.5M
    297136 3M 3659-34 RIBBON CABLE, RND/FLAT 34 WAY 30.5M
    297148 3M 3659-37 RIBBON CABLE, RND/FLAT 37 WAY 30.5M
    297150 3M 3659-40 RIBBON CABLE, RND/FLAT 40 WAY 30.5M
    297161 3M 3659-50 RIBBON CABLE, RND/FLAT 50 WAY 30.5M
    297173 3M 3659-60 RIBBON CABLE, RND/FLAT 60 WAY 30.5M
    297185 3M 2010-10 RIBBON CABLE, 10 WAY 30.5M
    297215 3M 2010-20 RIBBON CABLE, 20 WAY 30.5M
    297227 3M 2010-26 RIBBON CABLE, 26 WAY 30.5M
    297239 3M 2010-34 RIBBON CABLE, 34 WAY 30.5M
    297252 3M 2010-50 RIBBON CABLE, 50 WAY 30.5M
    297276 3M 3365-9 RIBBON CABLE, 9 WAY PER M
    297288 3M 3365-10 RIBBON CABLE, 10 WAY PER M
    297290 3M 3365-14 RIBBON CABLE, 14 WAY PER M
    297306 3M 3365-15 RIBBON CABLE, 15 WAY PER M
    297318 3M 3365-16 RIBBON CABLE, 16 WAY PER M
    297320 3M 3365-20 RIBBON CABLE, 20 WAY PER M
    297331 3M 3365-25 RIBBON CABLE, 25 WAY PER M
    297343 3M 3365-26 RIBBON CABLE, 26 WAY PER M
    297355 3M 3365-34 RIBBON CABLE, 34 WAY PER M
    297367 3M 3365-37 RIBBON CABLE, 37 WAY PER M
    297379 3M 3365-40 RIBBON CABLE, 40 WAY PER M
    297380 3M 3365-50 RIBBON CABLE, 50 WAY PER M
    297392 3M 3365-60 RIBBON CABLE, 60 WAY PER M
    297409 3M 3302-9 RIBBON CABLE, 9 WAY PER M
    297410 3M 3302-10 RIBBON CABLE, 10 WAY PER M
    297422 3M 3302-14 RIBBON CABLE, 14 WAY PER M
    297446 3M 3302-16 RIBBON CABLE, 16 WAY PER M
    297458 3M 3302-20 RIBBON CABLE, 20 WAY PER M
    297460 3M 3302-25 RIBBON CABLE, 25 WAY PER M
    297471 3M 3302-26 RIBBON CABLE, 26 WAY PER M
    297483 3M 3302-34 RIBBON CABLE, 34 WAY PER M
    297495 3M 3302-37 RIBBON CABLE, 37 WAY PER M
    297501 3M 3302-40 RIBBON CABLE, 40 WAY PER M
    297513 3M 3302-50 RIBBON CABLE, 50 WAY PER M
    297525 3M 3302-60 RIBBON CABLE, 60 WAY PER M
    297537 3M 3659-9 RIBBON CABLE, RND/FLAT 9 WAY PER M
    297549 3M 3659-10 RIBBON CABLE, RND/FLAT 10 WAY PER M
    297550 3M 3659-14 RIBBON CABLE, RND/FLAT 14 WAY PER M
    297562 3M 3659-15 RIBBON CABLE, RND/FLAT 15 WAY PER M
    297574 3M 3659-16 RIBBON CABLE, RND/FLAT 16 WAY PER M
    297586 3M 3659-20 RIBBON CABLE, RND/FLAT 20 WAY PER M
    297598 3M 3659-25 RIBBON CABLE, RND/FLAT 25 WAY PER M
    297604 3M 3659-26 RIBBON CABLE, RND/FLAT 26 WAY PER M
    297616 3M 3659-34 RIBBON CABLE, RND/FLAT 34 WAY PER M
    297628 3M 3659-37 RIBBON CABLE, RND/FLAT 37 WAY PER M
    297630 3M 3659-40 RIBBON CABLE, RND/FLAT 40 WAY PER M
    297641 3M 3659-50 RIBBON CABLE, RND/FLAT 50 WAY PER M
    297653 3M 3659-60 RIBBON CABLE, RND/FLAT 60 WAY PER M
    297665 3M 2010-10 RIBBON CABLE, 10 WAY PER M
    297690 3M 2010-20 RIBBON CABLE, 20 WAY PER M
    297707 3M 2010-26 RIBBON CABLE, 26 WAY PER M
    297719 3M 2010-34 RIBBON CABLE, 34 WAY PER M
    297732 3M 2010-50 RIBBON CABLE, 50 WAY PER M
    3000114 3M 3357-6509 BACKSHELL, D SHIELDED 9WAY
    3000126 3M 3357-6515 BACKSHELL, D SHIELDED 15WAY
    3000138 3M 3357-6525 BACKSHELL, D SHIELDED 25WAY
    3000140 3M 3357-6537 BACKSHELL, D SHIELDED 37WAY
    3000564 3M 3443-15 LOCATOR PLATE
    3003577 3M 89110-0101HA SOCKET, IDC BUMP & CLIP 10WAY
    3003589 3M 89114-0101HA SOCKET, IDC BUMP & CLIP 14WAY
    3003590 3M 89116-0101HA SOCKET, IDC BUMP & CLIP 16WAY
    3003607 3M 89120-0101HA SOCKET, IDC BUMP & CLIP 20WAY
    3003619 3M 89126-0101HA SOCKET, IDC BUMP & CLIP 26WAY
    3003620 3M 89134-0101HA SOCKET, IDC BUMP & CLIP 34WAY
    3003632 3M 89140-0101HA SOCKET, IDC BUMP & CLIP 40WAY
    3003644 3M 89150-0101HA SOCKET, IDC BUMP & CLIP 50WAY
    3003656 3M 89160-0101HA SOCKET, IDC BUMP & CLIP 60WAY
    3003747 3M 3448-89110 STRAIN RELIEF CLIP, 10 WAY
    3003759 3M 3448-89114 STRAIN RELIEF CLIP, 14 WAY
    3003760 3M 3448-89116 STRAIN RELIEF CLIP, 16 WAY
    3003772 3M 3448-89120 STRAIN RELIEF CLIP, 20 WAY
    3003784 3M 3448-89126 STRAIN RELIEF CLIP, 26 WAY
    3003796 3M 3448-89134 STRAIN RELIEF CLIP, 34 WAY
    3003802 3M 3448-89140 STRAIN RELIEF CLIP, 40 WAY
    3003814 3M 3448-89150 STRAIN RELIEF CLIP, 50 WAY
    3003826 3M 3448-89160 STRAIN RELIEF CLIP, 60 WAY
    302521 3M 200-40 RIBBON CABLE, TWIST/FLAT 40 WAY PER M
    3037459 3M 101A0-6000EC Connectors, D-Subminiature, Plug, 100 Po
    3042765 3M 1190 TAPE, COPPER FABRIC 19.0MM
    3047489 3M 8510-4500JL SOCKET, PCB 10 WAY
    3047490 3M 8516-4500JL SOCKET, PCB 16 WAY
    3047507 3M 8520-4500JL SOCKET, PCB 20 WAY
    3047519 3M 8526-4500JL SOCKET, PCB 26 WAY
    3047520 3M 8534-4500JL SOCKET, PCB 34 WAY
    3047532 3M 8540-4500JL SOCKET, PCB 40 WAY
    3047544 3M 8550-4500JL SOCKET, PCB 50 WAY
    3047556 3M 8560-4500JL SOCKET, PCB 60 WAY
    3085181 3M 100-1-6PR-BULK 3M 100 1" X 6"  100C  (Bulk Pack)
    3085200 3M 100-3/8-6PR-BULK 3M 100 3/8" X 6"  100C (bulk pack)
    3085223 3M 100-3/8-8PR-BULK 3M 100 3/8" X 8"  75C  (bulk pack)
    3085235 3M 100-6ST-BLACK-BULK SCOTCH 100 BLACK 3/8" (bulk pack)
    3085259 3M 100-6ST-BLUE-BULK SCOTCH 100 BLUE  3/8" (bulk pack)
    3085260 3M 100-6ST-GREEN-BULK SCOTCH 100 GREEN 3/8" (bulk pack)
    3085533 3M 100-6ST-RED-BULK SCOTCH 100 RED 3/8" (bulk pack)
    3085557 3M 100-6ST-WHITE-BULK SCOTCH 100 WHITE 3/8" (bulk pack)
    3089678 3M 100-6ST-YELLOW-BULK SCOTCH 100 YELLOW 3/8" (bulk pack)
    3108533 3M 3443-94 LOCATOR PLATE
    3121641 3M 929715-10-36-I 72/PS/2R/STR.318-.175/ALL 10AVE CONNECTO
    3130484 3M 680-1 POST-IT INDEX  RED
    3130496 3M 680-2 POST-IT INDEX  BLUE
    3130502 3M 680-3 POST-IT INDEX  GREEN
    3130514 3M 680-5 POST-IT INDEX  YELLOW
    3130526 3M 680-8 POST-IT INDEX  PURPLE
    3262625 3M 3448-89124 STRAIN RELIEF CLIP, 24WAY
    3262637 3M 3448-89130 STRAIN RELIEF CLIP, 30WAY
    3262649 3M 89124-0101HA SOCKET, IDC BUMP & CLIP 24WAY
    3262650 3M 89130-0101HA SOCKET, IDC BUMP & CLIP 30WAY
    3262662 3M 5120-B7A2JL SOCKET, R/A PCB 20WAY
    3262674 3M 5126-B7A2JL SOCKET, R/A PCB 26WAY
    3262686 3M 5134-B7A2JL SOCKET, R/A PCB 34WAY
    3262698 3M 5140-B7A2JL SOCKET, R/A PCB 40WAY
    3262704 3M 5150-B7A2JL SOCKET, R/A PCB 50WAY
    3263058 3M 3314-5602 HEADER, R/A L/LATCH 14WAY
    3263060 3M 3408-5602 HEADER, R/A L/LATCH 16WAY
    3263071 3M 3627-5602 HEADER, R/A L/LATCH 24WAY ((NS))
    3263095 3M 3764-5602 HEADER, R/A L/LATCH 64WAY ((NW))
    3263101 3M 3627-6602 HEADER, STRT L/LATCH 24WAY
    3263113 3M 3440-6602 HEADER, STRT L/LATCH 30WAY
    3263125 3M 3764-6602 HEADER, STRT L/LATCH 64WAY
    3263277 3M 3793-5002UG HEADER, R/A 10WAY
    3263290 3M 3408-5002UG HEADER, R/A 16WAY
    3263307 3M 3428-5002UG HEADER, R/A 20WAY
    3263320 3M 3429-5002UG HEADER, R/A 26WAY
    3263356 3M 3432-5002UG HEADER, R/A 40WAY
    3263368 3M 3433-5002UG HEADER, R/A 50WAY
    3263393 3M 3793-6002UG HEADER, STRT 10WAY
    3263400 3M 3314-6002UG HEADER, STRT 14WAY
    3263435 3M 3627-6002UG HEADER, STRT 24WAY
    3263447 3M 3429-6002UG HEADER, STRT 26WAY
    3263459 3M 3440-6002UG HEADER, STRT 30WAY
    3263460 3M 3431-6002UG HEADER, STRT 34WAY
    3263472 3M 3432-6002UG HEADER, STRT 40WAY
    3267192 3M 2524-5002 HEADER, R/A 24WAY
    3267209 3M 2530-5002 HEADER, R/A 30WAY
    3267210 3M 2524-6002 HEADER, STRT 24WAY
    3267477 3M 10120-6000EC Connectors, D-Subminiature, Socket, 20 P
    3267489 3M 10320-3210-000 JUNCTION SHELL FOR 20-POSITION 0.050-INC
    3269917 3M 3505-8010 RETAINER 10WAY
    3269929 3M 3505-8014 RETAINER 14WAY
    3269930 3M 3505-8016 RETAINER 16WAY
    3269942 3M 3505-8020 RETAINER 20WAY
    3269966 3M 3505-8026 RETAINER 26WAY
    3269980 3M 3505-8034 RETAINER 34WAY
    3269991 3M 3505-8040 RETAINER 40WAY
    3270002 3M 3505-8050 RETAINER 50WAY
    3271330 3M 4624-6000 HEADER, IDC LUGGED 24WAY
    3271353 3M 3448-4610 STRAIN RELIEF CLIP, 10WAY
    3271365 3M 3448-4614 STRAIN RELIEF CLIP, 14WAY
    3271377 3M 3448-4616 STRAIN RELIEF CLIP, 16WAY
    3271389 3M 3448-4620 STRAIN RELIEF CLIP, 20WAY
    3271419 3M 3448-4634 STRAIN RELIEF CLIP, 34WAY
    3271420 3M 3448-4640 STRAIN RELIEF CLIP, 40WAY
    3271432 3M 3448-4650 STRAIN RELIEF CLIP, 50WAY
    3271500 3M 3960-2010T TRANSITION, IDC 60WAY
    3271511 3M 3964-2010T TRANSITION, IDC 64WAY
    3271778 3M 3448-3914 STRAIN RELIEF CLIP, 14WAY
    3271780 3M 3448-3916 STRAIN RELIEF CLIP, 16WAY
    3271810 3M 3448-3926 STRAIN RELIEF CLIP, 26WAY
    3271845 3M 3448-3940 STRAIN RELIEF CLIP, 40WAY
    3271870 3M 3448-3964 STRAIN RELIEF CLIP, 64WAY
    3271894 3M 3418-0005VZB TRANSITION, IDC 40WAY
    3271900 3M 3426-0005VZB TRANSITION, IDC 50WAY
    3271912 3M 3406-3000 PLUG, IDC DIL 14WAY
    3271924 3M 3416-3000 PLUG, IDC DIL 16WAY
    3271936 3M 3448-3406 STRAIN RELIEF CLIP, 14WAY
    3271948 3M 3448-3416 STRAIN RELIEF CLIP, 16WAY
    3273672 3M 3357-9209 BACKSHELL, D EMI METAL 9WAY
    3273684 3M 3357-9215 BACKSHELL, D EMI METAL15WAY
    3273696 3M 3357-9225 BACKSHELL, D EMI METAL 25WAY
    3273702 3M 3357-9237 BACKSHELL, D EMI METAL 37WAY
    3273714 3M 3357-9250 BACKSHELL, D EMI METAL 50WAY
    3273726 3M 3505-62 LATCH BRACKET FOR 50WAY
    3273738 3M 3485-2100F BACKSHELL, D PLASTIC 9WAY
    3273740 3M 3485-2200F BACKSHELL, D PLASTIC 15WAY
    3273751 3M 3485-2300F BACKSHELL, D PLASTIC 25WAY
    3273763 3M 3485-2400F BACKSHELL, D PLASTIC 37WAY
    3273830 3M 3548-1001 PLUG, IDC CENTRONIC 24WAY
    3273842 3M 3366-1001 PLUG, IDC CENTRONIC 36WAY
    3273866 3M 3564-1001 PLUG, IDC CENTRONIC 50WAY
    3273880 3M 3448-61 STRAIN RELIEF CLIP, 24WAY
    3273891 3M 3448-62 STRAIN RELIEF CLIP, 36WAY
    3286447 3M 218-3341. IC SOCKET, ZIF 18 WAY
    3286459 3M 224-1286. IC SOCKET, ZIF 24 WAY
    3286460 3M 248-4775. IC SOCKET, ZIF 48 WAY
    3286484 3M 242-1293. IC SOCKET, SHRINK ZIF 42 WAY
    3286496 3M 264-1300. IC SOCKET, SHRINK ZIF 64 WAY
    3286502 3M 208-7391-55-1902. IC SOCKET, SOIC ZIF 8 WAY
    3286514 3M 220-7201-55-1902. IC SOCKET, SOIC ZIF 20 WAY
    3286526 3M 224-7397-55-1902. IC SOCKET, SOIC ZIF 24 WAY
    3286538 3M 228-7396-55-1902. IC SOCKET, SOIC ZIF 28 WAY
    3310073 3M 17003 Hook, Fastener
    3329859 3M 37825P270A RIBBON CABLE, 10 LOOSE PAIRS
    3329860 3M 378220P270A RIBBON CABLE, 40 LOOSE PAIRS
    3329872 3M 378232P270A RIBBON CABLE, 64 LOOSE PAIRS
    3329884 3M 3319-10 RIBBON CABLE, HIGH FLEX 10 WAY 30.5M
    3329896 3M 3319-14 RIBBON CABLE, HIGH FLEX 14 WAY 30.5M
    3329902 3M 3319-16 RIBBON CABLE, HIGH FLEX 16 WAY 30.5M
    3329914 3M 3319-20 RIBBON CABLE, HIGH FLEX 20 WAY 30.5M
    3329926 3M 3319-26 RIBBON CABLE, HIGH FLEX 26 WAY 30.5M
    3329940 3M 3784-05P-540A RIBBON CABLE, TWIST/FLAT 5PR 76.2M
    3329951 3M 3784-07P-540A RIBBON CABLE, TWIST/FLAT 7PR 76.2M
    3329963 3M 3784-08P-540A RIBBON CABLE, TWIST/FLAT 8PR 76.2M
    3329975 3M 3784-17P-540A RIBBON CABLE, TWIST/FLAT 17PR 76.2M
    3329987 3M 3849-96 RIBBON CABLE, 96 WAY 30.5M
    3332020 3M 3319-10 RIBBON CABLE, HIGH FLEX 10 WAY PER M
    3332032 3M 3319-14 RIBBON CABLE, HIGH FLEX 14 WAY PER M
    3332044 3M 3319-16 RIBBON CABLE, HIGH FLEX 16 WAY PER M
    3332056 3M 3319-20 RIBBON CABLE, HIGH FLEX 20 WAY PER M
    3332068 3M 3319.26 RIBBON CABLE, HIGH FLEX 26 WAY PER M
    3332070 3M 3319-34 RIBBON CABLE, HIGH FLEX 34 WAY PER M
    3332081 3M 3784-05P-540A RIBBON CABLE, TWIST/FLAT 5PR PER M
    3332111 3M 3784-17P-540A RIBBON CABLE, TWIST/FLAT 17PR PER M
    3332123 3M 3849-96 RIBBON CABLE, 96 WAY PER M
    3346020 3M 2044 2044 BULK ECONOMY HEEL GROUNDING ASSEMBL
    3355391 3M SBKDG-1 SCHOOL BUS KIT School Bus Marking Kit
    3355408 3M SPB-08 ScotchCode SPB Pre-Printed Wire Marker B
    3356206 3M SPB-12 ScotchCode SPB Pre-Printed Wire Marker B
    3451963 3M 2229 1"X 10' 1" x 10' Scotch-Seal Mastic Tape
    3451975 3M 2229 3 3/4" X 10' 3 3/4" x 10' Scotch-Seal Mastic Tape
    3452128 3M 3939-1x60YD Tartan Duct Tape, Silver  1" x 60 yds
    3452130 3M 3939-3x60YD Tartan Duct Tape, Silver  3" x 60 yds
    3452141 3M 3939 4" Tartan Duct Tape, Silver  4" x 60 yds
    3452190 3M 425 1 1/2" Scotch 425 Aluminum Foil Tape 1 1/2" x 6
    3452207 3M 425 4" Foil Tape
    3452219 3M 471  1/2" BLACK 1/2" x yds Plastic Film Lane Marketing T
    3452220 3M 471  1/2" BLUE 1/2" x 36 yds Plastic Film Lane Marketin
    3452232 3M 471  1/2" GREEN 1/2" x 36 yds Plastic Film Lane Marketin
    3452244 3M 471  1/2" RED 1/2" x 36 yds Plastic Film Lane Marketin
    3452256 3M 471  1"  BLACK 1" x  36 yds Plastic Film Lane Marketing
    3452268 3M 471  1" GREEN 1" x  36 yds Plastic Film Lane Marketing
    3452347 3M 6969 2" BLACK Cloth Duct Tape 2" x 60 yds Black
    3452359 3M 6969 3" SILVER Cloth Duct Tape 3" x 60 yds Silver
    3452360 3M 94717 Connectors; Connector Type: Ring Tongue;
    3452372 3M 94719 Connectors; Connector Type: Ring Tongue;
    3452384 3M 94773 Connectors; Wire Size (AWG): 16-14; Powe
    3452396 3M 94783 Connectors; Wire Size (AWG): 12-10.; Pow
    3452402 3M 94800 Connectors; Connector Type: Female Disco
    3452414 3M 94804 Connectors; Connector Type: Female Disco
    3452426 3M 94808 Connectors; Connector Type: Male Disconn
    3452438 3M 94812 Connectors; Connector Type: Male Disconn
    3452440 3M 94817 Connectors; Connector Type: Female Disco
    3452463 3M 94829 Connectors; Connector Type: Male Disconn
    3452475 3M 94833 Connectors; Connector Type: Female Disco
    3452487 3M 94837 Connectors; Connector Type: Male Disconn
    3452505 3M 94842 FEMALE DISCONNECT SOLDERLESS TERMINAL CO
    3452517 3M 94869 Connectors; Color: Blue; Stud/Tab Size:
    3452529 3M 94873 Connectors; Color: Blue; Stud/Tab Size:
    3452530 3M 94875 Connectors; Color: Blue; Stud/Tab Size:
    3452542 3M 94879 Connectors; Stud/Tab Size: 1/4in; Wire S
    3452554 3M 94883 Connectors; Stud/Tab Size: 8; Wire Size
    3452566 3M 981-K3 TRAILER KIT FOR TRUCKS Kit for marking 45-48 ft Trailer
    3452578 3M 981-10ES White Scotchlite Diamond Grade White, 2" x 12"
    3452591 3M 981-32ES Red/White Scotchlite Diamond Grade 11" Red, 7" Whi
    3452610 3M 985-32 ES Scotchlite Diamonfd Grade 11" Red, 7" Wh
    3558137 3M 10140-6000EC IDC wiremount plug connector-shielded, 2
    3596618 3M MH18-8FLX Connectors; Connector Type: Ring Tongue
    3596620 3M SDTK-2 Scotchlok Terminal/IDC Assortment Kit
    3596631 3M STK-1 Scotchlok Terminal Assortment Kit
    3596643 3M 2120 Scotch Transparent Duct Tape, 1.88"x 20y
    3596679 3M MH10-10RX HEAT SHRINK INSULATED RING TONGUE. BRAZE
    3596680 3M MH10-8RX HEAT SHRINK INSULATED RING TONGUE. BRAZE
    3596692 3M MH10BCX HEAT SHRINK INSULATED BUTT CONNECTOR SEA
    3596709 3M MH14-10R/LX HEAT SHRINK INSULATED RING TONGUE BRAZED
    3596710 3M MH14-6R/LX HEAT SHRINK INSULATED RING TONGUE BRAZED
    3596722 3M MH14-8R/LX HEAT SHRINK INSULATED RING TONGUE BRAZED
    3596734 3M MH14BCX HEAT SHRINK INSULATED BUTT CONNECTOR SEA
    3596746 3M MH18-10R/LX HEAT SHRINK INSULATED RING TONGUE BRAZED
    3596758 3M MH18-6R/LX HEAT SHRINK INSULATED RING TONGUE BRAZED
    3596760 3M MH18-8R/LX HEAT SHRINK INSULATED RING TONGUE BRAZED
    3596783 3M MH18BCX HEAT SHRINK INSULATED BUTT CONNECTOR SEA
    3599991 3M 6112 Connectors; Connector Type: ST? Multimod
    3613215 3M 1700P TAPE (3/4 X 66) PRINTED TEMFLEX VINYL PLASTIC ELECTRICAL
    3703794 3M BG INSULATED CROCODILE CLIP
    3703800 3M AS-10 ADAPTOR SNAP
    3703812 3M SS-10 STACK SNAP
    3710415 3M MH14-14FLX Connectors Connector Type:Ring Tongue So
    3716922 3M 102A0-6212VC Connectors, PCB, Mini D Ribbon, Female G
    3882860 3M 152212-0100-GB Connectors, PCB, Wire to Board, Female G
    3936247 3M 10326-52F0-008 CONNECTORS ((NW))
    3956003 3M 8502 STATIC DISSIPATIVE TELECOMMUNICATIONS FI
    3972525 3M 101A0-900AJL Straddlemount plug-shielded, plug, 100 c
    3978266 3M 152250-0100-GB Connectors, PCB, Wire to Board, Female G
    3983444 3M PLCC-20-SMT-TT IC SOCKET, PLCC 20 WAY
    3983456 3M PLCC-28-SMT-TT IC SOCKET, PLCC 28 WAY
    3983468 3M PLCC-32-SMT-TT IC SOCKET, PLCC 32 WAY
    3983470 3M PLCC-44-SMT-TT IC SOCKET, PLCC 44 WAY
    3983481 3M PLCC-52-SMT-TT IC SOCKET, PLCC 52 WAY
    3983493 3M PLCC-68-SMT-TT IC SOCKET, PLCC 68 WAY
    3983500 3M PLCC-84-SMT-TT IC SOCKET, PLCC 84 WAY
    3983511 3M PLCC-P-28-PS-TT IC SOCKET, PLCC 28 WAY
    3983523 3M PLCC-P-32-PS-TT IC SOCKET, PLCC 32 WAY
    3983535 3M PLCC-P-44-PS-TT IC SOCKET, PLCC 44 WAY
    3983547 3M PLCC-P-52-PS-TT IC SOCKET, PLCC 52 WAY
    3983559 3M PLCC-P-68-PS-TT IC SOCKET, PLCC 68 WAY
    3983560 3M PLCC-P-84-PS-TT IC SOCKET, PLCC 84 WAY
    4078603 3M 1435 EAR MUFFS ((NW))
    4136500 3M 10314-52F0-008 Enclosures; Body Material: Polyester; Co
    4136512 3M 10114-3000VE Connectors, D-Subminiature, Plug, 14 Pos
    4138910 3M 3460-4000 PLUG, IDC DIL 24WAY
    4138922 3M 3508-4000 PLUG, IDC DIL 40WAY
    4138934 3M 3448-18 STRAIN RELIEF, 40 WAY
    4138946 3M 3448-25 STRAIN RELIEF, 24 WAY
    4138958 3M 3448-3563 STRAIN RELIEF 18 WAY
    4138960 3M 3443-12 LOCATOR PLATE DIP 14 WAY
    4138971 3M 3443-13 LOCATOR PLATE DIP 16 WAY
    4138983 3M 3442-14 PLATEN FOR 14 WAY DIP
    4138995 3M 3442-16 PLATEN FOR 16 WAY DIP
    4139008 3M 3443-10 LOCATOR PLATE 24 WAY DIP
    4139010 3M 3442-6 PLATEN FOR 24 WAY DIP
    4139021 3M 3443-47 LOCATOR PLATE FOR 40 WAY DIP
    4139033 3M 3442-8 PLATEN FOR 40 WAY DIP
    4139045 3M 4610-6051 HEADER, IDC NO LUGS 10WAY
    4139057 3M 4614-6001 HEADER, IDC NO LUGS 14WAY
    4139069 3M 4616-6001 HEADER, IDC NO LUGS 16WAY
    4139070 3M 4620-6001 HEADER, IDC NO LUGS 20WAY
    4139082 3M 4626-6001 HEADER, IDC NO LUGS 26WAY
    4139094 3M 4634-6001 HEADER, IDC NO LUGS 34WAY
    4139100 3M 4640-6001 HEADER, IDC NO LUGS 40WAY
    4139112 3M 4650-6001 HEADER, IDC NO LUGS 50WAY
    4139124 3M 4664-6001 HEADER, IDC NO LUGS 64WAY
    4139136 3M 3505-16 EJECTORS, SHORT
    4139148 3M 3505-17 EJECTORS, LONG
    4139150 3M 3448-4626 STRAIN RELIEF CLIP, 26 WAY
    4139161 3M 3505-30 EJECTORS, SHORT
    4139173 3M 3505-31 EJECTORS, LONG
    4139185 3M 8564-4500JL SOCKET, PCB 64 WAY
    4139240 3M 3549-1000 SOCKET, IDC 24WAY
    4139264 3M 3565-1000 SOCKET, IDC 50WAY
    4139355 3M 3436-1B SHUT HEIGHT GUAGE 3443-71
    4139367 3M 3436-1C SHUT HEIGHT GUAGE
    4139379 3M 3436-1D SHUT HEIGHT GUAGE
    4139380 3M 3436-1K SHUT HEIGHT GUAGE
    4139392 3M 3436-1N SHUT HEIGHT GUAGE
    4139409 3M 3443-112 LOCATOR PLATE  FOR 8250
    4139410 3M 3442-44 PLATEN 50W D CONNECTORS
    4139422 3M 3436-1F SHUT HEIGHT GUAGE 3443-112
    4139434 3M 3793-6502 HEADER, STRT S/LATCH 10WAY
    4139446 3M 3408-6502 HEADER, STRT S/LATCH 16WAY
    4139458 3M 3627-6502 HEADER, STRT S/LATCH 24WAY
    4139471 3M 3372-6502 HEADER, STRT S/LATCH 60WAY
    4139483 3M 3764-6502 HEADER, STRT S/LATCH 64WAY
    4139495 3M 3793-5502 HEADER, R/A S/LATCH 10WAY
    4139501 3M 3314-5502 HEADER, R/A S/LATCH 14WAY
    4139513 3M 3408-5502 HEADER, R/A S/LATCH 16WAY
    4139525 3M 3428-5502 HEADER, R/A S/LATCH 20WAY
    4139537 3M 3627-5502 HEADER, R/A S/LATCH 24WAY
    4139549 3M 3429-5502 HEADER, R/A S/LATCH 26WAY
    4139550 3M 3440-5502 HEADER, R/A S/LATCH 30WAY
    4139562 3M 3431-5502 HEADER, R/A S/LATCH 34WAY
    4139574 3M 3433-5502 HEADER, R/A S/LATCH 50WAY
    4139586 3M 3372-5502 HEADER, R/A S/LATCH 60WAY
    4139598 3M 3764-5502 HEADER, R/A S/LATCH 64WAY
    4140576 3M 3365-24 RIBBON CABLE, 24 WAY 30.5M
    4140588 3M 3365-64 RIBBON CABLE, 64 WAY 30.5M
    4140590 3M 3659-36 RIBBON CABLE, RND/FLAT 36 WAY 30.5M
    4140606 3M 3659-64 RIBBON CABLE, RND/FLAT 64 WAY 30.5M
    4140618 3M 3319-24 RIBBON CABLE, HIGH FLEX 24 WAY 30.5M
    4140620 3M 3319-40 RIBBON CABLE, HIGH FLEX 40 WAY 30.5M
    4140631 3M 2010-14 RIBBON CABLE, 14 WAY 30.5M
    4140643 3M 2010-16 RIBBON CABLE, 16 WAY 30.5M
    4140655 3M 2010-25 RIBBON CABLE, 25 WAY 30.5M
    4140667 3M 2010-37 RIBBON CABLE, 37 WAY 30.5M
    4140679 3M 2010-40 RIBBON CABLE, 40 WAY 30.5M
    4140680 3M 2010-60 RIBBON CABLE, 60 WAY 30.5M
    4140692 3M 2010-64 RIBBON CABLE, 64 WAY 30.5M
    4140709 3M 3539-10 RIBBON CABLE, MED FLEX 10 WAY 30.5M
    4140710 3M 3539-14 RIBBON CABLE, MED FLEX 14 WAY 30.5M
    4140722 3M 3539-16 RIBBON CABLE, MED FLEX 16 WAY 30.5M
    4140734 3M 3539-20 RIBBON CABLE, MED FLEX 20 WAY 30.5M
    4140746 3M 3539-26 RIBBON CABLE, MED FLEX 26 WAY 30.5M
    4140758 3M 3539-34 RIBBON CABLE, MED FLEX 34 WAY 30.5M
    4140760 3M 3539-40 RIBBON CABLE, MED FLEX 40 WAY 30.5M
    4140771 3M 3539-50 RIBBON CABLE, MED FLEX 50 WAY 30.5M
    4140783 3M 3539-64 RIBBON CABLE, MED FLEX 64 WAY 30.5M
    4141027 3M 3365-24 RIBBON CABLE, 24 WAY PER M
    4141039 3M 3365-64 RIBBON CABLE, 64 WAY PER M
    4141040 3M 3659-36 RIBBON CABLE, RND/FLAT 36 WAY PER M
    4141052 3M 3659-64 RIBBON CABLE, RND/FLAT 64 WAY PER M
    4141064 3M 3319-24 RIBBON CABLE, HIGH FLEX 24 WAY PER M
    4141076 3M 3319-40 RIBBON CABLE, HIGH FLEX 40 WAY PER M
    4141088 3M 2010-14 RIBBON CABLE, 14 WAY PER M
    4141090 3M 2010-16 RIBBON CABLE, 16 WAY PER M
    4141106 3M 2010-25 RIBBON CABLE, 25 WAY PER M
    4141118 3M 2010-37 RIBBON CABLE, 37 WAY PER M
    4141120 3M 2010-40 RIBBON CABLE, 40 WAY PER M
    4141131 3M 2010-60 RIBBON CABLE, 60 WAY PER M
    4141143 3M 2010-64 RIBBON CABLE, 64 WAY PER M
    4141155 3M 3539-10 RIBBON CABLE, MED FLEX 10 WAY PER M
    4141167 3M 3539-14 RIBBON CABLE, MED FLEX 14 WAY PER M
    4141179 3M 3539-16 RIBBON CABLE, MED FLEX 16 WAY PER M
    4141180 3M 3539-20 RIBBON CABLE, MED FLEX 20 WAY PER M
    4141192 3M 3539-26 RIBBON CABLE, MED FLEX 26 WAY PER M
    4141209 3M 3539-34 RIBBON CABLE, MED FLEX 34 WAY PER M
    4141210 3M 3539-40 RIBBON CABLE, MED FLEX 40 WAY PER M
    4141222 3M 3539-50 RIBBON CABLE, MED FLEX 50 WAY PER M
    4141234 3M 3539-64 RIBBON CABLE, MED FLEX 64 WAY PER M
    4145677 3M CHG2010J01010KEP Connectors, PCB, Wire to Board, Female G
    4145689 3M CHG2026J01010KEP Connectors, PCB, Wire to Board, Female G
    4145690 3M CHG2034J01010KEP Connectors, PCB, Wire to Board, Female G
    4176182 3M 150250-6002-TB Connectors, PCB, Wire to Board, Female G
    4193994 3M 10280-6212VC Boardmount thru hole vertical receptacle
    4233918 3M SJ-5744 BLACK Feet, Accessory, Enclosure, Color Black,
    4285505 3M 152210-0100-GB Connectors, PCB, Wire to Board, Female G
    430511 3M 200-6311-9UN-1900. IC SOCKET, ZIF 11X11
    430523 3M 200-6313-9UN-1900. IC SOCKET, ZIF 13X13
    430535 3M 200-6315-9UN-1900. IC SOCKET, ZIF 15X15
    430547 3M 200-6321-9UN-1900. IC SOCKET, ZIF 21X21
    4306636 3M 2360 Dual-Conductor Wrist Strap Ground Cord,
    4306648 3M 2370 Dual-Conductor Wrist Strap Ground Cord,
    4306650 3M 2371 Dual-Conductor Wrist Strap Ground Cord,
    4352129 3M 3586-12 Connectors; For Use With: Type CHG Assem
    4353602 3M 150240-6002-TB Connectors, PCB, Wire to Board, Female G
    4364661 3M 151220-7422-TB Connectors, Headers & Receptacles, Pin H
    4383060 3M 152226-0100-GB Wiremount socket, 28 American wire gauge
    439915 3M 3793-5602 HEADER, R/A L/LATCH 10WAY
    439927 3M 3428-5602 HEADER, R/A L/LATCH 20WAY
    439939 3M 3429-5602 HEADER, R/A L/LATCH 26WAY
    439940 3M 3431-5602 HEADER, R/A L/LATCH 34WAY
    439952 3M 3432-5602 HEADER, R/A L/LATCH 40WAY
    439964 3M 3433-5602 HEADER, R/A L/LATCH 50WAY
    439976 3M 3372-5602 HEADER, R/A L/LATCH 60WAY
    439988 3M 3793-6602 HEADER, STRT L/LATCH 10WAY
    439990 3M 3314-6602 HEADER, STRT L/LATCH 14WAY
    440000 3M 3408-6602 HEADER, STRT L/LATCH 16WAY
    440024 3M 3428-6602 HEADER, STRT L/LATCH 20WAY
    440036 3M 3429-6602 HEADER, STRT L/LATCH 26WAY
    440048 3M 3431-6602 HEADER, STRT L/LATCH 34WAY
    440050 3M 3432-6602 HEADER, STRT L/LATCH 40WAY
    440127 3M 3433-6602 HEADER, STRT L/LATCH 50WAY
    440139 3M 3372-6602 HEADER, STRT L/LATCH 60WAY
    440255 3M 3314-6502 HEADER, STRT S/LATCH 14WAY
    440292 3M 3428-6502 HEADER, STRT S/LATCH 20WAY
    440309 3M 3429-6502 HEADER, STRT S/LATCH 26WAY
    440334 3M 3431-6502 HEADER, STRT S/LATCH 34WAY
    4403782 3M SDR-0-9 Scotchcode Wire Marker Tape Refill  For
    440449 3M 3432-6502 HEADER, STRT S/LATCH 40WAY
    440486 3M 3433-6502 HEADER, STRT S/LATCH 50WAY
    440498 3M 3793-5602UG HEADER, R/A 10WAY
    440504 3M 3314-5602UG HEADER, R/A 14WAY
    440516 3M 3408-5602UG HEADER, R/A 16WAY
    440541 3M 3428-5602UG HEADER, R/A 20WAY
    440590 3M 3440-5602UG HEADER, R/A 30WAY
    440772 3M 3433-5602UG HEADER, R/A 50WAY
    440784 3M 3372-5602UG HEADER, R/A 60WAY
    440840 3M 3764-5602UG HEADER, R/A 64WAY
    441041 3M 3314-6602UG HEADER, STRT 14WAY
    4410440 3M 10220-55G3VC Connectors, PCB, Mini D Ribbon, Female G
    441363 3M 3429-6602UG HEADER, STRT 26WAY
    441387 3M 3431-6602UG HEADER, STRT 34WAY
    441466 3M 3432-6602UG HEADER, STRT 40WAY
    442720 3M 3372-6602UG HEADER, STRT 60WAY
    442744 3M 3793-5502UG HEADER, R/A 10WAY
    442756 3M 3314-5502UG HEADER, R/A 14WAY
    442768 3M 3408-5502UG HEADER, R/A 16WAY
    442770 3M 3428-5502UG HEADER, R/A 20WAY
    442781 3M 3429-5502UG HEADER, R/A 26WAY
    442793 3M 3440-5502UG HEADER, R/A 30WAY
    442835 3M 3764-5502UG HEADER, R/A 64WAY
    442847 3M 3793-6502UG HEADER, STRT 10WAY
    442859 3M 3314-6502UG HEADER, STRT 14WAY
    442860 3M 3408-6502UG HEADER, STRT 16WAY
    442938 3M 3429-6502UG HEADER, STRT 26WAY
    443141 3M 3432-6502UG HEADER, STRT 40WAY
    443311 3M 3433-6502UG HEADER, STRT 50WAY
    443359 3M 3764-6502UG HEADER, STRT 64WAY
    443396 3M 2510-5002UG HEADER, R/A 10WAY
    443440 3M 2516-5002UG HEADER, R/A 16WAY
    443451 3M 2520-5002UG HEADER, R/A 20WAY
    443463 3M 2526-5002UG HEADER, R/A 26WAY
    443610 3M 2534-5002UG HEADER, R/A 34WAY
    443621 3M 2540-5002UG HEADER, R/A 40WAY
    443633 3M 2550-5002UG HEADER, R/A 50WAY
    443657 3M 2510-6002UG HEADER, STRT 10WAY
    443694 3M 2514-6002UG HEADER, STRT 14WAY
    443700 3M 2516-6002UG HEADER, STRT 16WAY
    443712 3M 2520-6002UG HEADER, STRT 20WAY
    443785 3M 2526-6002UG HEADER, STRT 26WAY
    443803 3M 2530-6002UG HEADER, STRT 30WAY
    443815 3M 2534-6002UG HEADER, STRT 34WAY
    443827 3M 2540-6002UG HEADER, STRT 40WAY
    443839 3M 2550-6002UG HEADER, STRT 50WAY
    443852 3M 2564-6002UG HEADER, STRT 64WAY
    4473899 3M 471 BLUE 1/4" Tape, Color Blue, Width 1/4 Inches, Leng
    4474442 3M 4950  1" 1" X 36 YD WHITE VHB TAPE, .045" THICK
    4476992 3M 5400756390 RED, 2 OR 3 WIRE BUTT, 19-26 A
    4477832 3M 2056 Ground Cord, Static Protection, Max surf
    4487254 3M 8898 24MM Film strapping tape, blue tensilized pol
    4487266 3M 8898 48MM Film strapping tape, blue tensilized pol
    4487278 3M 3750-1PK  48MM CLEAR Box sealing tape, high-performance polyp
    4487280 3M 3750-1PK  48MM TAN Box sealing tape, high-performance polyp
    4487308 3M 2000 DUCT TAPE TAPE ROLL LENGTH:50YARD; COLOR:GRAY; FEA
    4488684 3M 8898 12MM X 55M Film strapping tape, blue tensilized pol
    4490162 3M 929836-09-36 Connectors, Headers & Receptacles, Pin H
    4490186 3M 929834-04-36 Pin strip header, 36 contact, .1 in. pit
    4490230 3M 929838-04-36 Pin strip header, 36 contact, .1 in. pit
    4490241 3M CHG2026J01010KCP CONNECTORS, PCB CONNECTOR TYPE:WIRE TO B
    4490253 3M CHG2050J01010KEP Connectors, PCB, Wire to Board, Female G
    4490277 3M 89124-0101 Connectors, IDC, Open End, Receptacle, 2
    4518846 3M 929450-01-36-I Connectors, Headers & Receptacles, Pin H
    4518858 3M 929647-02-36-I Connectors, Headers & Receptacles, Pin H
    4518860 3M 929647-09-36-I Connectors, Headers & Receptacles, Pin H
    4520518 3M 3334-7660 Socket, female, 26 & 28 American wire ga
    4531966 3M 10140-3000VE Connectors; Connector Type: D-Subminiatu
    4531978 3M 10226-R21TS Connectors, PCB, Mini D Ribbon, Female G
    4531980 3M 81068-520203 Latch/ejector header, 68 circuit, 68 con
    4532119 3M 150210-6002-TB Connectors, PCB, Wire to Board, Female G
    4532120 3M 150220-6002-TB Connectors, PCB, Wire to Board, Female G
    4532132 3M 150226-6002-TB Connectors, PCB, Wire to Board, Female G
    4532144 3M 150240-5002-TB Connectors, PCB, Wire to Board, Female G
    4532156 3M 150244-5002-TB Connector Number of Contacts:44; Pitch S
    4532168 3M 150244-6002-TB Connectors, PCB, Wire to Board, Female G
    4532170 3M 151210-7422-TB Connectors, Headers & Receptacles, Pin H
    4532181 3M 151210-8322-TB Connectors, Headers & Receptacles, Pin H
    4532193 3M 151220-8322-TB Connectors, Headers & Receptacles, Pin H
    4532200 3M 151226-8322-TB Connectors, Headers & Receptacles, Pin H
    4532211 3M 151240-8322-TB Connectors, Headers & Receptacles, Pin H
    4532223 3M 151250-8322-TB Connectors, Headers & Receptacles, Pin H
    4538961 3M UR2 (BOX) CONNECTORS, SPLICE IDC CONNECTOR TYPE:BU
    4548036 3M 929834-07-36 Pin strip header, 36 contact, .1 in. pit
    4548048 3M 929836-02-36 Pin strip header, 36 contact, .1 in. pit
    4550201 3M CHG2016J01010KEP Connectors, PCB, Wire to Board, Female G
    4550213 3M CHG2020J01010KEP Connectors, PCB, Wire to Board, Female G
    4550225 3M CHG2040J01010KEP Connectors, PCB, Wire to Board, Female G
    4554383 3M 929975-01-36 Connectors, PCB, Wire to Board, Female G
    4555624 3M 10320-52F0-008 Enclosures; Body Material: Polyester; Co
    4556057 3M SJ-5023 (BLACK) BLACK, .30 x .81" WIDE, PAD OF
    4568473 3M 6100-B Connector, ST connector, zirconia cerami
    4568485 3M 6100-R Connector hot melt, ST connector, zircon
    4568539 3M 4943F 3/4" VHB™+ Acrylic Foam Tape, 0.045 inc
    4568540 3M 4950  3/4" TAPE,FOAM,FOAM,VHB™ ACRYLIC FOAM T
    4568588 3M 4652 Wrist Strap Set, Band and Cord, 4600 Ser
    4568590 3M 9500 Anti-fatigue static-control mat, rubber
    4570029 3M 6113  COUPLING Connectors; Connector Type: ST? Multimod
    4575271 3M 3448-6201 Strain Relief
    4575829 3M 150250-5002-TB Connectors, PCB, Wire to Board, Female G
    4577139 3M 10120-3000VE Connectors, D-Subminiature, Plug, 20 Pos
    4577140 3M 10136-3000VE Connectors, D-Subminiature, Plug, 36 Pos
    4577991 3M 10336-52F0-008 2-piece junction backshell for 0.050" mi
    4579290 3M SV-SH32 32" HOSE, STRETCHES TO APPROX 10 FEET
    4579409 3M 10220-6212VC CONNECTORS, D-SUBMINIATURE
    4584375 3M 8506 Grounding Kit, Portable, for Field Servi
    4585800 3M 8100-YS Connector, ST connector, single fiber, c
    4587911 3M 151260-8322-TB Connectors, Headers & Receptacles, Pin H
    4587923 3M 151260-7422-TB Connectors, Headers & Receptacles, Pin H
    4587935 3M 10180-6000EC Connectors, D-Subminiature, Plug, 80 Pos
    4591689 3M 929957-08 Midgie, .1 in. pitch, copper alloy conta
    4602328 3M 62C64-1100EC Socket, female, 26 & 28 American wire ga
    4605020 3M SDR-MC SCOTCHCODE WIRE MARKER TAPE REFILLS FOR
    4605342 3M 2010/16  (100') Cable; Cable/Wire Type: Ribbon Cable; To
    4605354 3M 2010/26  (100') Cable; Cable/Wire Type: Ribbon Cable; To
    4605366 3M 2010/40  (100') Cable; Cable/Wire Type: Ribbon Cable; To
    4605378 3M 2010/50  (100') Cable; Cable/Wire Type: Ribbon Cable; To
    4605380 3M 2010/64  (100') Cable; Cable/Wire Type: Ribbon Cable; To
    4605391 3M 2100/10TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605408 3M 2100/14TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605410 3M 2100/16TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605421 3M 2100/20TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605433 3M 2100/26TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605445 3M 2100/34TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605457 3M 2100/40TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605469 3M 2100/50TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605470 3M 2100/60TP Cable; Cable/Wire Type: Ribbon Cable; To
    4605482 3M 2100/64TP Cable; Cable/Wire Type: Ribbon Cable; To
    4612644 3M 4720 Static Protection Wrist Grounder
    4613314 3M 963 BENCHTOP AIR IONIZER, AC 120V
    4615130 3M 152244-0100-GB Socket, 28 American wire gauge, female,
    4617964 3M 3624-42 Connectors, Crimp Tools, Standard hand t
    4619547 3M 732 Dual Remote Input Jack
    468010 3M 3473-6600 SOCKET, IDC 10WAY
    468022 3M 3452-6600 SOCKET, IDC 16WAY
    468034 3M 3421-6600 SOCKET, IDC 20WAY
    468046 3M 3399-6600 SOCKET, IDC 26WAY
    468058 3M 3414-6600 SOCKET, IDC 34WAY
    468060 3M 3417-6600 SOCKET, IDC 40WAY
    468071 3M 3425-6600 SOCKET, IDC 50WAY
    468423 3M 3518 POLARISING CLIP, PK 20
    468885 3M 2510-6002 HEADER, STRT 10WAY
    468897 3M 2514-6002 HEADER, STRT 14WAY
    468903 3M 2516-6002 HEADER, STRT 16WAY
    468915 3M 2520-6002 HEADER, STRT 20WAY
    468927 3M 2526-6002 HEADER, STRT 26WAY
    468939 3M 2534-6002 HEADER, STRT 34WAY
    468940 3M 2540-6002 HEADER, STRT 40WAY
    468952 3M 2550-6002 HEADER, STRT 50WAY
    468964 3M 2560-6002 HEADER, STRT 60WAY
    469166 3M 4620-6000 HEADER, IDC LUGGED 20WAY
    469178 3M 4626-6000 HEADER, IDC LUGGED 26WAY
    469180 3M 4634-6000 HEADER, IDC LUGGED 34WAY
    469191 3M 4640-6000 HEADER, IDC LUGGED 40WAY
    469208 3M 4650-6000 HEADER, IDC LUGGED 50WAY
    469210 3M 3910-2010T TRANSITION, IDC 10WAY
    469221 3M 3914-2010T TRANSITION, IDC 14WAY
    469233 3M 3916-2010T TRANSITION, IDC 16WAY
    469245 3M 3920-2010T TRANSITION, IDC 20WAY
    469257 3M 3926-2010T TRANSITION, IDC 26WAY
    469269 3M 5113828408 TRANSITION, IDC 34WAY ((NW))
    469270 3M 3940-2010T TRANSITION, IDC 40WAY
    469282 3M 3950-2010T TRANSITION, IDC 50WAY
    469300 3M 3474-0005VZB TRANSITION, IDC 10WAY
    469324 3M 3422-0005VZB TRANSITION, IDC 20WAY
    469336 3M 3434-0005VZB TRANSITION, IDC 26WAY
    469348 3M 3402-0005VZB TRANSITION, IDC 34WAY
    469373 3M 8209-8009 PLUG, D IDC 9WAY
    469385 3M 8215-8009 PLUG, D IDC 15WAY
    469397 3M 8225-8009 PLUG, D IDC 25WAY
    469403 3M 8237-8009 PLUG, D IDC 37WAY
    469415 3M 8309-8009 SOCKET, D IDC 9WAY
    469427 3M 8315-8009 SOCKET, D IDC 15WAY
    469439 3M 8325-8009 SOCKET, D IDC 25WAY
    469440 3M 8337-8009 SOCKET, D IDC 37WAY
    469531 3M 3640 PRESS TOOL INC'3442-1A PLATEN
    469567 3M 3443-16 LOCATOR PLATE
    469579 3M 3443-71 LOCATOR PLATE, 39XX TRANSITION
    469592 3M 3443-106N LOCATOR PLATE, D
    469610 3M 3442-9 PLATEN, DIN41612
    4720787 3M IDH-50LP-PS-TR Connectors, Headers & Receptacles, Pin H
    473509 3M 3385-6600 SOCKET, IDC 14WAY
    473510 3M 3334-6600 SOCKET, IDC 60WAY
    4791071 3M IDH-10LP-PS-TR Connectors, Headers & Receptacles, Pin H
    4791095 3M IDH-14LP-PS-TR Connectors, Headers & Receptacles, Pin H
    4791101 3M IDH-16LP-PS-TR Connectors, Headers & Receptacles, Pin H
    4791113 3M IDH-16PK-PS-TG30 Connectors, Headers & Receptacles, Pin H
    4791125 3M IDH-20LP-PS-TR Connectors, Headers & Receptacles, Pin H
    4791150 3M IDH-34PK-PS-TG30 Connectors, Headers & Receptacles, Pin H
    4791186 3M IDH-50PK-PS-TG30 Connectors, Headers & Receptacles, Pin H
    4791198 3M IDH-60LP-PS-TR Connectors, Headers & Receptacles, Pin H
    4791370 3M 10214-R21TS Boardmount compliant pin vertical recept
    4791381 3M 10250-R21TS Connectors, PCB, Mini D Ribbon, Female G
    4791873 3M 150210-5002-TB Connectors, PCB, Wire to Board, Female G
    4791885 3M 150220-5002-TB CONNECTORS, PCB CONNECTOR TYPE:WIRE TO B
    4791897 3M 150230-5002-TB Connectors, PCB, Wire to Board, Female G
    4791903 3M 150230-6002-TB Connectors, PCB, Wire to Board, Female G
    4791915 3M 151212-7422-TB Connectors, Headers & Receptacles, Pin H
    4791927 3M 151212-8322-TB Connectors, Headers & Receptacles, Pin H
    4791939 3M 151226-7422-TB Connectors, Headers & Receptacles, Pin H
    4791940 3M 151230-7422-TB Connectors, Headers & Receptacles, Pin H
    4791952 3M 151230-8322-TB Connectors, Headers & Receptacles, Pin H
    4791964 3M 151240-7422-TB Connectors, Headers & Receptacles, Pin H
    4791976 3M 151244-7422-TB Connectors, Headers & Receptacles, Pin H
    4791988 3M 151244-8322-TB Connectors, Headers & Receptacles, Pin H
    4791990 3M 151250-7422-TB Connectors, Headers & Receptacles, Pin H
    4796627 3M CP2-HA110-GE1-TG30 Connectors, Headers & Receptacles, Pin H
    4796640 3M MP2-HP08-41P1-TG30 Connectors, Headers & Receptacles, Compa
    4796652 3M MP2-HP10-51P1-TG30 Connectors, Headers & Receptacles, Compa
    4796664 3M MP2-H024-41P1-S-TG30 Connectors, Headers & Receptacles, Compa
    4796676 3M MP2-H030-51P1-S-TG30 Connectors, Headers & Receptacles, Compa
    4796688 3M MP2-S024-41M1-C-TG30 2MM HARD METRIC STANDARD SOCKET BACKPLAN
    4796690 3M MP2-S030-51M1-C-TG30 2MM HARD METRIC STANDARD SOCKET BACKPLAN
    4798727 3M MP2-SP08-41M1-TG30 2MM HARD METRIC POWER SOCKET BACKPLANE C
    4798739 3M MP2-SP10-51M1-TG30 2MM HARD METRIC POWER SOCKET BACKPLANE C
    4814952 3M AAMAM-AT0001 SINGLE MODE CABLE ASSEMBLY, ST-ST SIMPLE
    4814964 3M AAMAM-AT0002 CABLE ASSEMBLY, ST-ST SIMPLEX CONNECTOR,
    4814976 3M AAMAM-AT0003 CABLE ASSEMBLY, ST-ST SIMPLEX CONNECTOR,
    4814988 3M AAMAM-AT0005 CABLE ASSEMBLY, ST-ST SIMPLEX CONNECTOR,
    4814990 3M AAMAM-AT0010 CABLE ASSEMBLY, ST-ST SIMPLEX CONNECTOR,
    4815002 3M AAMAM-AT0015 CABLE ASSEMBLY, ST-ST SIMPLEX CONNECTOR,
    4815014 3M AAMAM-AT0020 CABLE ASSEMBLY, ST-ST SIMPLEX CONNECTOR,
    4815026 3M ADADA-AT0001 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815038 3M ADADA-AT0002 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815040 3M ADADA-AT0003 CABLE ASSEMBLY, SIMPLEX CONNECTOR, 3 MET
    4815051 3M ADADA-AT0005 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815063 3M ADADA-AT0010 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815075 3M ADADA-AT0015 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815087 3M ADADA-AT0020 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815099 3M ADADA-BW0001 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815105 3M ADADA-BW0002 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815117 3M ADADA-BW0003 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815129 3M ADADA-BW0005 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815130 3M ADADA-BW0010 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815142 3M ADADA-BW0015 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815154 3M ADADA-BW0020 CABLE ASSEMBLY, SC-SC DUPLEX CONNECTOR,
    4815166 3M AEPEP-AT0001 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815178 3M AEPEP-AT0002 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815180 3M AEPEP-AT0003 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815191 3M AEPEP-AT0005 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815208 3M AEPEP-AT0010 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4815210 3M AEPEP-AT0020 CABLE ASSEMBLY, SC-SC SIMPLEX CONNECTOR,
    4831974 3M 35 3/4" X 66' GREEN Vinyl Electrical Tape 3/4" x 66' Roll, G
    4831986 3M 425 1" Scotch 425 Aluminum Foil Tape 1" x 60 yd
    4832528 3M UB2A CONNECTOR IDC BRIDGE
    4832966 3M 72M-187-20-P Connectors; Connector Type: Male Disconn
    4833727 3M 3793-1502UG 3793-1502UG         10/HDR/3W/RA/SNAPIN
    484374 3M 232-7162-71-3857 IC SOCKET, PLCC 32 WAY
    4863859 3M MVU18-187DFK (BULK) VINYL INSL FEMALE DISC SOLDERLESS TERMIN
    4899611 3M 100-6ST-BLACK BODY MATERIAL:POLYPROPYLENE HOOK/NYLON L
    4903390 3M 35 3/4" X 66' VIOLET Vinyl Electrical Tape 3/4" x 66' Roll, V
    4903407 3M 425 1/2" Scotch 425 Aluminum Foil Tape 1/2" x 60
    4903419 3M 972  (BOXED) 18-16 Auto Fuse Holder Insulation Displa
    4958743 3M DDM-37-000-1-BSK1 Enclosures; Connector Type: Wire IDC D-S
    4958755 3M DDM-37P-137G-TG30 Connectors, D-Subminiature, Male, 37 Pos
    4965905 3M 100-6ST-BLUE BODY MATERIAL:POLYPROPYLENE HOOK/NYLON L
    4965917 3M 100-6ST-GREEN BODY MATERIAL:POLYPROPYLENE HOOK/NYLON L
    4965929 3M 100-6ST-YELLOW BODY MATERIAL:POLYPROPYLENE HOOK/NYLON L
    4972314 3M 929834-05-36 36/PS/1R/STR.235-.610/TIN/90:10 CONNECTO
    4973422 3M 151210-8422-TB 2MM X 2MM PIN STRIP HEADERS DUAL ROW STR
    4973434 3M 151230-8422-TB 2MM X 2MM PIN STRIP HEADERS DUAL ROW STR
    4986696 3M SDR-B ScotchCode SDR Wire Marker Tape Refill "
    4986702 3M SPB-14 ScotchCode SPB Pre-Printed Wire Marker B
    4987070 3M 2228-1x10FT 1" x 10' Scotch Rubber Mastic Tape
    4987123 3M 3939-2x60YD Tartan Duct Tape, Silver  2" x 60 yds
    4987159 3M 560 (BOXED) 18-16 AWG Flame Retardant IDC
    4987172 3M 94785 Connectors; Wire Size (AWG): 22-18; Powe
    4987184 3M 94799 Connectors; Connector Type: Female Disco
    4989363 3M 929550-01-36-I Connector Number of Contacts:36; Number
    1007646 3M ROBINSON NUGENT ICA-083-S-TG30 DIP SOCKET - SCREW MACHINE
    1007658 3M ROBINSON NUGENT ICA-083-WB-TG30 8/SKT/TG30
    1010621 3M ROBINSON NUGENT P25E-040S-TG P25E series board mount 50-mil IDC socke
    1010633 3M ROBINSON NUGENT P25E-050-S-TG RN PAK-50 P25E SERIES 50 MIL IDC SOCKET
    1010657 3M ROBINSON NUGENT P25E-080-S-TG P25E series board mount 50-mil IDC socke
    1010669 3M ROBINSON NUGENT P25E-100-S-TG P25E series board mount 50-mil IDC socke
    1010736 3M ROBINSON NUGENT P50E-040P1-S1-TG Connectors, IDC, Latch, Plug, 40 Contact
    1010750 3M ROBINSON NUGENT ICE-143-S-TG Open body screw machine socket, circuit
    1010761 3M ROBINSON NUGENT ICE-163-S-TG Open body screw machine socket, circuit
    1010773 3M ROBINSON NUGENT ICE-183-S-TG Open body screw machine socket, circuit
    1010785 3M ROBINSON NUGENT ICE-203-S-TG Open body screw machine socket, circuit
    1010797 3M ROBINSON NUGENT ICE-243-S-TG Open body screw machine socket, circuit
    1010803 3M ROBINSON NUGENT ICE-246-S-TG Open body screw machine socket, circuit
    1010815 3M ROBINSON NUGENT ICE-286-S-TG Open body screw machine socket, circuit
    1010839 3M ROBINSON NUGENT ICE-406-S-TG Open body screw machine socket, circuit
    1010840 3M ROBINSON NUGENT PLCCE-084-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1010852 3M ROBINSON NUGENT PLCC-20-SMTL-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1010864 3M ROBINSON NUGENT PLCC-28-SMTL-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1010876 3M ROBINSON NUGENT PLCC-32-SMTL-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1010888 3M ROBINSON NUGENT PLCC-44-SMTL-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1010906 3M ROBINSON NUGENT PLCC-68-SMTL-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1010918 3M ROBINSON NUGENT PLCC-84-SMTL-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1010955 3M ROBINSON NUGENT P50E-050P1-S1-TG RN PAK-50 IDC Plug, 50 MIL, P50E Series
    1010980 3M ROBINSON NUGENT P50E-080P1-SR1-TG RN PAK-50 IDC PLUG, 50 MIL, P50E SERIES
    1010992 3M ROBINSON NUGENT P50E-100P1-SR1-TG RN PAK-50 IDC PLUG, 50 MIL, P50E SERIES
    1011017 3M ROBINSON NUGENT P50E-080P1-S1-TG Connectors, IDC, Latch, Plug, 80 Contact
    1011029 3M ROBINSON NUGENT P50E-100P1-S1-TG Connectors, IDC, Latch, Plug, 100 Contac
    1011030 3M ROBINSON NUGENT ICE-083-S-TG Open body screw machine socket, circuit
    1103891 3M ROBINSON NUGENT PLCCE-020-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1103908 3M ROBINSON NUGENT PLCCE-028-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1103910 3M ROBINSON NUGENT PLCCE-032-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1103921 3M ROBINSON NUGENT PLCCE-044-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1103933 3M ROBINSON NUGENT PLCCE-052-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1103945 3M ROBINSON NUGENT PLCCE-068-S1-TT CHIP CARRIER SOCKET, PLCCE SERIES, PLAST
    1103969 3M ROBINSON NUGENT ICO-083-S8A-T DIL, IC, Connector, Contact Count 8
    1103982 3M ROBINSON NUGENT ICO-163-S8A-T DIP SOCKET - STAMPED DUAL WIPE
    1103994 3M ROBINSON NUGENT ICO-183-S8A-T DIL, IC, Connector, Contact Count 18
    1104007 3M ROBINSON NUGENT ICO-203-S8A-T DIP SOCKET - STAMPED DUAL WIPE
    1104020 3M ROBINSON NUGENT ICO-243-S8A-T DIP SOCKET - STAMPED DUAL WIPE
    1104032 3M ROBINSON NUGENT ICO-246-S8A-T DIL, IC, Connector, Contact Count 24
    1104068 3M ROBINSON NUGENT ICO-326-S8A-T DIL, IC, Connector, Contact Count 32
    1104070 3M ROBINSON NUGENT ICO-406-S8A-T DIP SOCKET - STAMPED DUAL WIPE
    1104111 3M ROBINSON NUGENT ICE-063-S-TG Open body screw machine socket, circuit
    1104123 3M ROBINSON NUGENT ICE-063-S-TG30 6/SKT/TG30
    1104135 3M ROBINSON NUGENT ICE-083-S-TG30 8/SKT/TG30
    1104147 3M ROBINSON NUGENT ICE-163-S-TT Machine Dip Socket, ICE Series, Screw Ma
    1104160 3M ROBINSON NUGENT ICE-183-S-TT Machine Dip Socket, ICE Series, Screw Ma
    1104172 3M ROBINSON NUGENT ICE-183-S-TG30 18/SKT/TG30
    1104184 3M ROBINSON NUGENT ICE-203-S-TG30 20/SKT/TG30
    1104196 3M ROBINSON NUGENT ICE-243-S-TG30 DIP Socket Number of Contacts:24; Pitch
    1104238 3M ROBINSON NUGENT ICE-246-S-TG30 24/SKT/TG30
    1104240 3M ROBINSON NUGENT ICE-283-S-TT Machine Dip Socket, ICE Series, Screw Ma
    1104251 3M ROBINSON NUGENT ICE-283-S-TG30 28/SKT/TG30
    1104287 3M ROBINSON NUGENT ICE-326-S-TG30 32/SKT/TG30
    1104299 3M ROBINSON NUGENT ICE-406-S-TG30 40/SKT/TG30
    1104342 3M ROBINSON NUGENT ICE-143-S-TT CONNECTORS, DIP SOCKET IC CONNECTOR TYPE
    1104354 3M ROBINSON NUGENT ICE-143-S-TG30 DIP SOCKET; NUMBER OF CONTACTS:14; PITCH
    1396602 3M ROBINSON NUGENT PLCC-28-SMT-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1396614 3M ROBINSON NUGENT PLCC-32SMT-TT Socket, PLCC-SMT Series, Surface Mount,
    1396626 3M ROBINSON NUGENT PLCC-44SMT-TT Socket, PLCC-SMT Series, Surface Mount,
    1396638 3M ROBINSON NUGENT PLCC-52-SMT-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1396640 3M ROBINSON NUGENT PLCC-68-SMT-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1396651 3M ROBINSON NUGENT PLCC-84-SMT-TT SOCKET, PLCC-SMT SERIES, SURFACE MOUNT,
    1677536 3M ROBINSON NUGENT ICO-083-S8-T DIL, IC, Connector, Contact Count 8
    1677548 3M ROBINSON NUGENT ICO-143-S8-T DIL, IC, Connector, Contact Count 14
    1677550 3M ROBINSON NUGENT ICO-163-S8-T DIL, IC, Connector, Contact Count 16
    1677561 3M ROBINSON NUGENT ICO-183-S8-T DIL, IC, Connector, Contact Count 18
    1677597 3M ROBINSON NUGENT ICO-243-S8-T DIP SOCKET - STAMPED DUAL WIPE
    1677603 3M ROBINSON NUGENT ICO-246-S8-T DIL, IC, Connector, Contact Count 24
    1677627 3M ROBINSON NUGENT ICO-286-S8-T DIL, IC, Connector, Contact Count 28
    1677639 3M ROBINSON NUGENT ICO-326-S8-T DIL, IC, Connector, Contact Count 32
    1677640 3M ROBINSON NUGENT ICO-406-S8-T DIL, IC, Connector, Contact Count 40
    1827534 3M ROBINSON NUGENT DIN-64CSB-S1L-TR Socket, female, 64 contact, C type body
    1827546 3M ROBINSON NUGENT DIN-96CPC-SR1-TR Header, 96 contact, C type body
    1827560 3M ROBINSON NUGENT DIN-96CSC-S1L-TR Socket, female, 96 contact, C type body
    1827625 3M ROBINSON NUGENT ICA-143-S-TG DIP SOCKET - SCREW MACHINE
    1827637 3M ROBINSON NUGENT ICA-143-S-TG30 DIP SOCKET - SCREW MACHINE
    1827662 3M ROBINSON NUGENT ICA-163-S-TG30 DIP SOCKET - SCREW MACHINE
    1827674 3M ROBINSON NUGENT ICA-163-WB-TG30 Screw machine socket, circuit size 16, w
    1827686 3M ROBINSON NUGENT ICA-203-S-TG30 DIP SOCKET - SCREW MACHINE
    1827698 3M ROBINSON NUGENT ICA-203-WB-TG30 20/SKT/TG30
    1827704 3M ROBINSON NUGENT ICA-243-S-TG DIP SOCKET - SCREW MACHINE
    1827716 3M ROBINSON NUGENT ICA-243-S-TG30 DIP SOCKET - SCREW MACHINE
    1827730 3M ROBINSON NUGENT ICA-246-S-TG30 DIP SOCKET - SCREW MACHINE
    1827753 3M ROBINSON NUGENT ICA-286-S-TG30 DIP SOCKET - SCREW MACHINE
    1827790 3M ROBINSON NUGENT ICA-406-S-TG30 DIP SOCKET - SCREW MACHINE
    1827807 3M ROBINSON NUGENT ICE-283-S-TG Open body screw machine socket, circuit
    1828058 3M ROBINSON NUGENT ICT-083-S-TG DIP SOCKET - SCREW MACHINE
    1828060 3M ROBINSON NUGENT ICT-143-S-TG DIP SOCKET - SCREW MACHINE
    1828071 3M ROBINSON NUGENT ICT-163-S-TG DIP SOCKET - SCREW MACHINE
    1828083 3M ROBINSON NUGENT ICT-183-S-TG DIP SOCKET - SCREW MACHINE
    1828101 3M ROBINSON NUGENT ICT-243-S-TG DIP SOCKET - SCREW MACHINE
    1828113 3M ROBINSON NUGENT ICT-246-S-TG DIP SOCKET - SCREW MACHINE
    1828137 3M ROBINSON NUGENT ICT-286-S-TG ICT-286-S-TG DIP SOCKET - SCREW MACHINE
    1828149 3M ROBINSON NUGENT ICT-326-S-TG DIP SOCKET - SCREW MACHINE
    1828150 3M ROBINSON NUGENT ICT-406-S-TG 40 POSITION MACHINE SCREW SOCKET WITH A
    1829397 3M ROBINSON NUGENT P50E-100S-TG IDC socket, circuit size 100, .05 in. pi
    1829403 3M ROBINSON NUGENT PGA-068CH3-S-TG Pin Grid Array Socket, PGA Series, 68 Pi
    1829452 3M ROBINSON NUGENT SBE-640-S-TG Screw Machine Socket Strip, SBE Series,
    1854860 3M ROBINSON NUGENT 3448-89110 STRAIN RELIEF/DUAL RECESS/89110 SKT CONN
    2521432 3M ROBINSON NUGENT ICE-083-S-TT Machine Dip Socket, ICE Series, Screw Ma
    3597155 3M ROBINSON NUGENT CP2-HA110-GA1TG30 PCB, CONNECTOR, STYLE A, NUMBER OF PINS
    4670814 3M ROBINSON NUGENT P08-080SL-A-G PAK8 CONNECTOR
    4681009 3M ROBINSON NUGENT CP2-SA110-G1-TG30 Connectors, PCB, Compact PCI Hard Metric
    4681010 3M ROBINSON NUGENT CP2-SB110-G1-TG30 Connectors, PCB, Compact PCI Hard Metric
    4681022 3M ROBINSON NUGENT MP2-HP08-41S1-TR30 Connectors, Headers & Receptacles, Compa
    4681034 3M ROBINSON NUGENT MP2-HP10-51S1-TR30 Connectors, Headers & Receptacles, Compa
    4681046 3M ROBINSON NUGENT MP2-H024-41S1-TR30 Connectors, Headers & Receptacles, Compa
    4681058 3M ROBINSON NUGENT MP2-SP08-41M1-TR30 Connectors, PCB, Hard Metric interconnec
    4681060 3M ROBINSON NUGENT MP2-SP10-51M1-TR30 Connectors, PCB, Hard Metric interconnec
    4681071 3M ROBINSON NUGENT MP2-S024-41M1-TR30 Connectors, PCB, Hard Metric interconnec
    3768880 3M TEXTOOL 268-5401-00-0000 Connectors Body Material:Aluminum; For U
    4665405 3M TEXTOOL 228-1277-00-0602J SOCKET, CIRCUIT SIZE 28, 0.1 INCH PIN SP
    4665417 3M TEXTOOL 268-5401-001102JH LCC SOCKET, CIRCUIT SIZE 68, GOLD FLASH
    4665430 3M TEXTOOL 216-3340-00-0602J SOCKET, CIRCUIT SIZE 16, 0.1 INCH PIN SP
    4665442 3M TEXTOOL 218-3341-00-0602J SOCKET, CIRCUIT SIZE 18, 0.1 INCH PIN SP
    4665454 3M TEXTOOL 224-1275-00-0602J SOCKET, CIRCUIT SIZE 24, 0.1 INCH PIN SP
    4665466 3M TEXTOOL 240-1280-00-0602J SOCKET, CIRCUIT SIZE 40, 0.1 INCH PIN SP
    4665478 3M TEXTOOL 264-4493-00-0602J SOCKET, CIRCUIT SIZE 64, 0.1 INCH PIN SP
    4666290 3M TEXTOOL 214-3339-00-0602J CONNECTORS, DIP SOCKET IC CONNECTOR TYPE
    4677365 3M TEXTOOL 220-3342-00-0602J Socket, female, 1 A, >1 x 109 Ohm, 1000
北京欧时创通公司是英国FARNELL公司中国指定代理商。 公司网罗了全世界1500多家著名厂商的58大类共20多万种产品,包括电子元器件、仪器仪表、连接器件、机械工具,电子、电气及机械零件、保健及安全用品、各类仪表工具和五金化工产品等。其中…  更多>>
英国Farnell公司中国代理
联系人:张光宇
地址:北京市海淀区志新路27号龙德商务会馆200号
邮编:100083
电话:010-62313773,020-85636617
传真:010-62317747,020-85636805
公司网址:www.bjosct.com
  • LYRA YANG 在2026/7/22 11:01:00留言
  • 详细留言:我是公司采购,想跟贵公司建立合作, 请联系我或者加我微信
  • Jessica Yuan 在2026/5/9 13:36:00留言
  • 详细留言:需要采购,18550322837请通过电话加我微信
  • 彭工 在2016/4/23 10:24:00留言
  • 详细留言:我想问一下,MAX03N Aavid Thermalloy与max03NG Aavid Thermalloy的外形尺寸是一样的么?这两个有什么区别么
  • 王力 在2014/12/15 17:52:00留言
  • 沙磊 在2009/9/15 12:05:00留言
  • 详细留言:116-9606 20pcs 116-9607 20pcs pl-259 40pcs 139-0049 400m 都是farnell的东西, 尽快
