深圳市锦冠辰贸易有限公司
  • 进口德国 KLAUS FISCHER 压力表,压差表,控制阀
  • 发布时间:2007/12/2 10:14:41   修改时间:2007/12/2 10:13:11 浏览次数:2357
  • 专业代理进口德国 KLAUS FISCHER 压力表,压差表,控制阀
    1)压力表,压力变送器,压力开关。
    MA04 Precision pressure gauge, for neutral media
    MA07 Pressure gauge, capsule element type, for neutral media
    MA11 Pressure gauge, bourdon tube, for neutral media, general purpose
    MA12 Pressure gauge, diaphragm, heavy duty, PN25
    MA13 Pressure gauge, bourdon tube, chemical applications
    MA15 Pressure gauge, diaphragm, stainless steel
    MA16 Pressure gauge, diaphragm, neutral media
    MA32 Pressure gauge, bourdon tube with transmitter, stainless steel
    MD03 Chemical seal, milk coupling, for food and beverage
    MD26 Chemical seal, G 1/2" male thread
    MD28 Chemical seal, flange
    MD36 Chemical seal, G 1/2" male thread
    MD38 Chemical seal, flange
    ME01 Pressure gauge, electronic type, digital indicator
    ME02 Pressure gauge, electronic type, digital indicators on front and back side
    ME49 Pressure transmitter, stainless steel connector, explosion proof
    ME56 Pressure transmitter, programmable, local and / or PC
    ME61 Pressure transmitter, stainless steel, industry standard
    ME69 Pressure transmitter, for aggressive media
    ME71 Pressure transmitter, stainless steel, high precision, analogue + HART
    ME75 Pressure transmitter, with Datalogger
    MS10 Pressure gauge and switch, for vacuum applications
    MS11 Pressure gauge and switch, general purpose, PN25
    2)压差表,压差开关
    DA01 Differential pressure gauge, stainless steel, PN250
    DA03 Differential pressure gauge, stainless steel, ... PN100
    DA04 Differential pressure gauge, stainless steel, PN25
    DA08 Differential pressure gauge, neutral gases
    DA09 Differential pressure gauge, stainless steel, ... PN25
    DA12 Differential pressure gauge, general purpose, PN25
    DE03 Differential pressure transmitter, stainless steel, PN100
    DE13 Differential pressure transmitter, stainless steel, PN100
    DE16 Differential pressure transmitter, general purpose, PN25
    DE25 Differential pressure transmitter, neutral gases
    DE28 Differential pressure transmitter, neutral gases and fluids
    DE38 Differential pressure transmitter, digital, neutral gases and fluids
    DE44 Differential pressure transmitter, digital, dual channel, neutral gases
    DE45 Differential pressure transmitter, digital, neutral gases
    DE46 Differential pressure transmitter, digital, very low pressure, neutral gases
    DE50 Differential pressure transmitter, neutral gases
    DE51 Differential pressure transmitter, neutral gases
    DE61 Differential pressure transmitter, neutral gases
    DE70 Differential pressure transmitter, stainless steel, PN140
    DS11 Differential pressure switch and indicator, general purpose, PN25
    DS13 Differential pressure switch, general purpose, PN25
    DS21 / 21D Differential pressure switch and indicator / German-Lloyd approved
    DS31 Differential pressure switch, neutral media
    DS35 Differential pressure switch, neutral gases
    DZ13/14 Valve manifolds for DE16, DS11, DS13, DS21
    DZ35 Valve manifold for DA03, DE03, DE13, DE70, wall mountable
    DZ36 Valve manifold for DA03, DE03, DE13, DE70, flanged
    DZ43/44 Valve manifolds for DA04
    DZ55 Valve manifold for DA03, DE03, DE13, DE70, wall mountable
    DZ56 Valve manifold for DA03, DE03, DE13, DE70, flanged
    DZ93/94 Valve manifolds for DA09
    3)温度计,热电偶
    TA Thermometer, expansion type
    TE01 Thermometer, digital type, analogue output
    TE41 Temperature transmitter, PC programmable, for thermocouple and Pt100
    TE42 Temperature transmitter, PC-programmable, for Pt100
    TK Thermometer, capillary type
    TS01 Temperature switch, adjustable
    TS61 Temperature switch, compact type
    TT30 Thermocouple, screw-in type
    TT31 Thermocouple, screw-in type,
    TT32 Thermocouple, screw-in type
    TT35 Thermocouple, screw-in type
    TT36 Thermocouple, screw-in type
    TT40 Thermocouple, weld-in type
    TT45 Thermocouple, weld-in type
    TT46 Thermocouple, weld-in type
    TT50 Thermocouple, flange type
    TT55 Thermocouple, flange type
    TT56 Thermocouple, flange type
    TW27 Resistance thermometer, sliding clamp
    TW30 Resistance thermometer, screw-in type
    TW31 Resistance thermometer, screw-in type
    TW32 Resistance thermometer, screw-in type
    TW35 Resistance thermometer, screw-in type
    TW36 Resistance thermometer, screw-in type
    TW40 Resistance thermometer, weld-in type
    TW45 Resistance thermometer, weld-in type
    TW46 Resistance thermometer, weld-in type
    TW50 Resistance thermometer, flange type
    TW55 Resistance thermometer, flange type
    TW56 Resistance thermometer, flange type
    TW70 Resistance thermometer, outdoor use
    TW71 Resistance thermometer, contact type
    TW72 Resistance thermometer, room sensor
    TW73 Resistance thermometer, room sensor
    4)控制阀
    BR206306GM Control valve w/ electric actuator PN6, max. 130 °C
    BR206306GMC Control valve w/ electric actuator PN6, max. 130 °C
    BR216316GM Control valve w/ electric actuator PN16, max. 130 °C
    BR216316GMC Control valve w/ electric actuator PN16, max. 130 °C
    BR216316M Control valve w/ electric actuator PN16, max. 200 °C
    BR216316MC Control valve w/ electric actuator PN16, max. 200 °C
    BR216316MMC Control valve w/ electric actuator PN16, max. 120 °C
    BR216316PA Control valve w/ pneumatic actuator PN16, max. 200 °C
    BR216316RMC Control valve w/ electric actuator PN16, max. 130 °C
    BR216316Z Control valve w/ electric actuator
    BR225325M Control valve w/ electric actuator PN25, max. 350 °C
    BR225325MC Control valve w/ electric actuator PN25, 350 °C
    BR225325PA Control valve w/ pneumatic actuator PN25, max. 350 °C
    BR225RGAMC Control valve w/ electric actuator PN25, max. 130 °C
    BR240340EM Control valve w/ electric actuator PN16-40, max. 350 °C
    BR240340EMC Control valve w/ electric actuator PN16-40, max. 350 °C
    BR240340EPA Control valve w/ pneumatic actuator PN16-40, max. 350 °C
    BR240340SM Control valve w/ electric actuator PN40, max. 350 °C
    BR240340SMC Control valve w/ electric actuator PN40, max. 350 °C
    BR240340SPA Control valve w/ pneumatic actuator PN40, max. 350 °C
    BR240GM Control valve w/ electric actuator PN40, max. 350 °C
    BR240GMC Control valve w/ electric actuator PN40, max. 350 °C
    BR240GPA Control valve w/ pneumatic actuator PN40, max. 350 °C
    BRDF16M Flange butterfly PN16
    BRDF6M Flange butterfly PN6
    BRDR16EVSA Control shut-off butterfly DN50-400, PN6-16
    BRDR16EVSM Control shut-off butterfly DN 25-200, PN6-16
    BRDR6/16M Butterfly valve PN6-16
    BRFH210EH Control valve w/ electric actuator PN16, bis 200 °C
    BRFH210EH2 Control valve w/ electric actuator PN25, bis 200 °C
    BRFH210EHE Control valve w/ electric actuator, max. 200 °C
    BRFH210EHG Control valve w/ electric actuator, max. 200 °C
    BRFH210EHS Control valve w/ electric actuator, max. 350 °C
    5)数字指示器,电源,信号变换器。
    DPM Digital indicator, programmable limit switches
    EA10 Digital indicator, LED 3 1/2 digit
    EA11 Digital indicator, LED 3 1/2 digit, loop powered
    EK75 Limiter with digital indicator
    EN10 Power supply
    ES11 Programmable temperatur measuring system
    ES15 TempLogger
    ES50 Signal converter and limiter
    ET50 Signal conditioner
    EU41 Signal converter, PC programmable
    EU50 Signal converter
    EW50 Limiter
    6)压差指示器,压力指示器,可编程的控制器
    EA14D Differential pressure indicator, with dp transmitter output and contacts
    EA14F Level indicator, with transmitter output and contacts
    EA14M Pressure indicator, with transmitter output and contacts
    EK76 Programmable controller, dual channel
    7)水平指示器,水平传感器,水平开关,湿度传感器,压力测试仪,压差测试仪
    ER76 / GT76 Control relay for level sensors, GL certified
    ES 10 Tank content metering system, programmable
    NB 10 Well probe
    NC56 Level sensor, capacitive
    NK02 Leakage detector, conductive
    NK06 Level sensor, conductive, GL certified
    NK10 Level switch, GL certified
    NR01 Level sensor with float and external signal converter
    NS01 Level switch, electronic, programmable
    FF10 Humidity sensor
    FT10 Humidity and temperature sensor
    MA25 Handheld Differential Pressure Tester
    MA26 Handheld Pressure Tester
    MA27 Handheld Pressure Tester for Otto and Diesel engines
    KE Contact banks for pressure and differential pressure gauges
    KE07 Rheostatic transmitter, resistance or current output, for temperature and pressure gauges
    KE09 Azimuth transmitter, capacitive EEx ib II C T5/T6, for temperature and pressure gauges
    8)液面指示器,水平传感器,电平开关
    NB 10 Well probe
    进口商:深圳市锦冠辰贸易有限公司
    我司为进口工业器材、零配件的专业进口销售公司。
    公司特点如下;
    1)直接进口,经销产品直接由国外工厂进货,价格有竞争力。
    2)鉴别配件经验丰富,找寻配件专家。
    3)提供17%增值税发票。
我司是一家专业代理经销各种原装进口工业器材以及备品备件的公司。产品范围函盖所有工业领域;包括工业低压电器,自动化元件、仪器仪表、电子器材、气动元件、传动部件、传感器、皮带、轴承、泵、马达、阀门等。传感器(SENSOR)继电器(REL…  更多>>
深圳市锦冠辰贸易有限公司
联系人:伍小姐
地址:深圳市深南中路3037号南光捷佳大厦2917室
邮编:518033
电话:0755-82513763
传真:0755-82513769
公司网址:www.jinguanchen.com
  • 王力 在2015/3/17 11:44:00留言
  • Cady Lin 在2014/7/29 16:49:00留言
  • 详细留言:您好,请问贵公司可有提供一下品牌型号产品: 品牌:EItra传感器 型号:S25GH10R5PUA6 数量: 1个 如果有的话,可否提供报价,及税费,运费,货期情况,不胜感谢!!
  • 邹先生 在2014/1/23 10:30:00留言
  • 详细留言:需要询价一台VALHALLA SCIENTIFIC 2701C PROGRAMMABLE PRECISION DC VOLTAGE/CURRENT STANDARD,请帮忙在今天给我报一个大概的价格。谢谢!
  • 姜荃 在2013/10/10 9:14:00留言
  • 详细留言:需求 减速机备件\箱体总成\4RV1200-S\D3334-100 一套, 品牌是DRAVO WELLMAN。 麻烦速回复
  • 杨先生 在2013/9/24 23:12:00留言
  • 详细留言:想问下贵公司能提供COMTEC 电机吗?
