electric Stainless Steel flexible Conduit for instrument cable protection
Flexible stainless steel conduit for electrical wirings protections
Strip wound small ID flexible metallic conduit,hose for electrical wirings armoring
braided Small BORE Flexible stainless steel conduit,for automobile & industry wiring harness
Optical Fiber and sensors wirings protecting Flexible metal conduit
Small bore Flexible metal conduit,for protection of instrument wirings
Small id Flexible Stainless Steel Conduit ( AT )
Small bore instrumentation tubing flexible conduit flexible stainless steel conduit for electric wirings
*Stainless steel strip (square locked or interlocked), very flexible *Corrosion Resistant
*EMI Shielding *Most suitable for instrument wiring protections.
MADE FROM STAINLESS STEEL STRIPS:
*ALL Stainless steel construction for corrosion resistant.
*Durable and long life.
*Designed for tight-spot installation and where continuous flexing is required
Applications:
Suitable for use in Industrial environments. Protection for stainless tubes, sensor cords or electric cords. It is designed to protect sensitive electronic circuits in applications such as sensors, electronic instruments and industrial control wirings.
Flexible Stainless Steel Conduit: Type AT is an ultra-flexible, stainless steel conduit designed primarily for OEM applications. A typical application would be armouring in specialty sensing devices, or medical equipment, including fiber-optics.
SMALL BORE HOSE
Delikon manufactures unique tubing that is relied on in numerous industries. The tubing is produced by helical coiling of a cold-rolled metal strip onto a spindle, with the helical coils being linked with each other by means of a special type of strip profile. Basic materials for the strip are stainless steel or galvanized steel strip. However, other metals are also available.
Applications:
Instrumentation tubing is used by manufacturers of various industries, such as Process & Control Instrumentation, Measuring & Controlling Devices, Analytical Instruments, Medical Instruments and many others with specific applications including temperature measuring, wiring conduit or armor cable and protective casing.
Instrumentation tubing is made in two configurations, or constructions, commonly called SquareLok and InterLok, and is often abbreviated as SL and FI.
http://www.delikon.com
http://users4.nofeehost.com/delikon
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/at4.jpg" alt="Flexible stainless steel conduits">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/atnew1.jpg" alt="small bore tubing">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/atC.gif" alt="small bore Instrumentation tubing">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/fibre2.jpg" alt="prtecting your inspection equipment wirings">
Stainless Flexible Protection conduits with PVC Sheathing Or Metal Wire Braiding
For Large Quantity Order, it is possible to Vacuum-Jacket or Extrude a PVC covering onto the
above AT-SL (SquareLok Type) conduits for water proof applications.
TYPE: AT-SL-JACKETED
The PVC covering is applied onto the metal surface with a Vacuum process. The finished surface will have a spiral corrugated pattern. It is most suitable for tight-spot installation and where a certain water tightness is required
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/jacketp.jpg" alt="Flexible stainless steel conduits with pvc jacket">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/jacket.gif" alt="Flexible stainless steel conduits with pvc jacket">
TYPE: AT-SL-EXTRUDED
The PVC covering is extruded onto the metal surface,
thus producing a smoother finished surface. when used with liquid-tight fittings it offers a higher degree of liquid tightness than the vacuum jacketed type.
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/extrudep.jpg" alt="Flexible stainless steel conduits with extruded plastic covering">
TYPE: AT-SL-SLEEVED
A short length of the AT-SL tubing is directly inserted into a thermoplastic sleeve. A very smooth outer surface and a very uniform thickness of sleeving is ensured. For cut to length OEM orders.
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/insert1.jpg" alt="Cut to length Flexible stainless steel conduits inserted into plastic sleeve">
<p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/insert2.gif" alt="Cut to length Flexible stainless steel conduits inserted into plastic sleeve">
TYPE: AT-SL-BRAIDED
High tensile strength metal wires are tightly braided onto the AT-SL small bore flexible metal tubing for optimum protection. It provides increased abrasion resistant, improved EMI screening, and resists hot metal splashes.
<p align="center"><a href="http://www.delikon.com/at.html"><img border="0" src="http://www.delikon.com/images/atbraid1.gif" alt="small bore Instrumentation tubing with metal braiding">
<p align="center"><a href="http://www.delikon.com/at.html"><img border="0" src="http://www.delikon.com/images/atbraid2.gif" alt="small bore Instrumentation tubing with metal braiding">
