Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • braided flexible metallic conduit
  • 发布时间:2007/12/25 3:06:42   修改时间:2007/12/24 20:51:35 浏览次数:534
    Overbraided Flexible Steel Conduit For High Temperature Wiring
    Inherently low fire hazard (ILFH),  Braided Flexible Metal Conduit is widely used to counter mechanical stress and is highly flexible, and it is resistant against tensile stresses and transverse pressure. This conduit also offers excellent protection to cables against hot metal particles, and immunity from electromagnetic interference. Most suitable for use in Hazardous Locations, industrial environments and high temperatures.
    Braided Electric Flexible steel Conduit resists abrasion and hot metal splashes
    Flexible steel conduit for heavy mechanical stress,braided flexible steel conduit
    It is used to counter mechanical stress and is highly flexible, and it is resistant against tensile stresses and transverse pressure.
    Over braiding Flexible metal conduit for hot metal splashes shielding
    A galvanised steel conduit with stainless steel overbraid, making it
    particularly suitable for chemical and heavy industrial applications.
    The system affords high compression and crush strength as well as
    impact resistance. As part of the Braided system range it has inherent
    fire protection, high pull off strength and offers EMI screening.
    Electrical Flexible metal Conduit,steel Wire Braided,EMI shielding
    Type SM-70001
    Over braided flexible conduit is particularly used in (mechanical) critical situations, such as machine-building, steel works but also in transport systems and security. The SM-70001 is excellent in protecting cables against metal particles and against vandalism or rodents.
    Wire Over-Braided Flexible Conduit ( SM70001 )
    typically used for machineries electric cables and wirings protection
    *Galvanized steel helically wound with wire over-braid.
    *3/8"~2" trade size
    *Resists high temperature and hot metal splashes
    *Wire over-braiding provide more abrasion resistant and EMI screening.
    *Explosion proof.
    *Durable and long life.
    *Inner core made from  galvanized steel strip.
    *Low fire hazard
    *Resists hot metal splashes
    Applications:
    Most suitable for use in Hazardous Locations, industrial environments and high temperatures, such as welding machines and metal casting machines; Also  for industrial environments where higher abrasion resistance or screening are required.
    http://www.delikon.com
    http://users4.nofeehost.com/delikon
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/sm70001.gif" alt="Electric flexible conduits">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/cbraidst.jpg" alt="braided flexible steel conduits">
    <p align="center"><a href="http://www.delikon.com"><img border="0" src="http://www.delikon.com/images/sm71p1.jpg" alt="braided flexible steel conduits">
    <p align="center"><a href="http://www.delikon.com/braids.htm"><img border="0" src="http://www.delikon.com/images/ship1.jpg" alt="For Ship building">
    <p align="center"><a href="http://www.delikon.com/sm.htm"><img border="0" src="http://www.delikon.com/images/smsteel.jpg" alt="Overbraided Flexible Steel Conduit For High Temperature Wiring">
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
