上海纽沃柯电子科技有限公司
  • Quantum-QT110-D 触控感测器芯片
  • 发布时间:2007/6/29 15:47:14   修改时间:2007/6/29 15:47:14 浏览次数:3991
  • 公司简介
    特价产品
    畅销产品
    产品查询
    设计之窗
    新品精选
    在线目录
    厂商在线
    首页 > 畅销产品 > 集成电路 > 特殊功能IC
    触控感测器芯片
    Quantum Research Group
    电荷转移(QT)电容触控元件厂商Quantum Research Group于十一月二日发表 QT60160(16键)与QT60240(24键)触控感测器芯片。新款元件能透过任何绝缘材料的面板感测手指的触控动作,在使用扫瞄式X-Y被动矩阵时,面板的厚度可达到50mm。新款感测器让研发业者能开发强固、密封、且安全的操控面板,以支持包含家电、交互式多媒体信息站、门禁保全面板、以及可携式仪器等产品。此外,能于1.8VDC电压下运作的特性,更使新款感测器芯片适用于手机、MP3随身听、以及其他掌上型装置。另外,其按键尺寸、形状、以及位置都可自行调整,并可透过I2C界面单独调整灵敏度、反应时间、以及其他参数,以上优点,都能使美学设计有更大的弹性及发挥空间。
    产品描述 型号 订货号
    Charge Transfer touch Sensor, auto calibration, piezo sounder feedback, pulse or toggle O/P, 2.5V to 5.0V operation @ 20A QT110-D 362-5825
    SMD version of the QT110, -40 to +85° C QT110-IS 428-0192
    Charge Transfer touch Sensor with longer recalibration period than QT110, used for continuous touch applications, piezo sounder feedback, pulse or toggle O/P QT111-D 362-5837
    SMD version of the QT111, -40 to +85° C QT111-IS 428-0209
    Charge Transfer touch Sensor with variable gain and a faster response time, the much higher sensitivity allows detection through thicker panels QT113-D 362-5849
    SMD version of the QT113 QT113-S 362-5930
    SMD version of the QT113, -40 to +85° C QT113-IS 428-0210
    Charge Transfer Level sensor with two trip points and "slosh" filter to suppress liquid motion QT114-D 362-5850
    SMD version of the QT114, -40 to +85° C QT114-IS 362-5941
    Evaluation board for the QT114 E114 362-6015
    Charge Transfer touch Sensor, variable gain and "daisy-chain" facility which enables multiple devices to be synchronised together, fast response time and high sensitivity QT115-D 362-5862
    SMD version of the QT115 QT115-S 362-5953
    SMD version of the QT115, -40 to +85° C QT115-IS 428-0222
    Charge Transfer touch Sensor, variable gain with piezo beeper drive, toggle & pulse output mode. QT118H-D 508-9761
    SMD version of the QT118, -40 to +85° C QT118H-IS 508-9773
    Evaluation board for the E110/E111/E113 Touch Sensor ICs E11X 428-0180
    Charge Transfer touch Sensor, Four channels, 4v to 5v operation QT140-D 426-9743
    SMD Charge Transfer touch Sensor, Four channels, 4v to 5v operation, -40 to +85° C QT140-AS 426-9755
    Charge Transfer touch Sensor, Five channels, 4v to 5v operation QT150-D 426-9767
    SMD Charge Transfer touch Sensor, Five channels, 4v to 5v operation, -40 to +85° C QT150-AS 426-9779
    Charge Transfer touch Sensor, Six channels, 4v to 5v operation QT160-D 426-9780
    QProx Charge Transfer touch sensor with 6 channels of sensing, high sensitivity, permits backlighting. Includes AKSAdjacent Key Suppression, toggle mode, various timeouts QT160-AS 426-9792
    Evaluation board for the QT140/150/160 sensor IC with 6 backlighted keys E160 426-9858
    4 Channel Touch Sensor Eval Kit E240 815-9378
    Charge Transfer touch Sensor with SPI serial port for continuous signal measurement QT300-D 362-5874
    SMD version of the QT300 QT300-IS 428-0234
    Charge Transfer touch Sensor with 8-bit PWM output and full end-point calibration QT301-D 508-9748
    SMD version of the QT301, -40to +85° C QT301-IS 508-9750
    The E3A evaluation board is designed for evaluating the QT300 device. The QT300 can be evaluated using the E3A in combination with the QTM300CA cloning adapter. E3A 426-9834
    1-channel QProx sensor with user-definable setups loadable from a PC via QTM300CA cloning adapter. Suitable for both fluid point level sensing and touch applications. 1.8 to 5.25V operation @ 60-300uA QT310-D 426-9706
    SMD version of the QT310 QT310-IS 426-9718
    2-channel QProx charge transfer touch sensor with user-definable setups loadable from a PC via QTM300CA. Does everything the QT113 and QT115 can do but in 2 independent channels. 1.8 to 5.25V operation @ 60-300uA QT320-D 426-9720
    SMD version of the QT320 QT320-IS 426-9731
    Evaluation board for the QT310 and QT320 E3B 426-9846
    Cloning adapter for loading setups from a PC to the QT310 and QT320 sensor ICs. Supplied cable allows it to plug directly into E3B evaluation board. Also works in stand-alone mode (without a PC). 8-15V DC QTM300CA 428-0179
    Linear Touch Sensor Eval Kit E401 815-9386
    Charge Transfer touch Sensor, 4 key Through-glass matrix detection, digital autocal on each key, signal filtering, allows up to two keys to be touched at a time QT60040-D 362-5886
    SMD version of the QT60040 QT60040-S 362-5977
    Evaluation board for the QT60040 E604 362-6040
    QMatrixTM touch sensor to create 16 keys through any dielectric, SPI, UART and Parallel interface, AKS Adjacent key supression, individual sensitivity setting of each key, panel thicknesses of upto 5cm QT60161B-AS 426-9809
    Evaluation board for the QT60161 IC with serial PC interface, includes sample 4x4 matrix panel, cables, QmBtn software for windows 95/98/NT E616 426-9860
    48 Channel Touch Sensor Eval Kit E6486 815-9394
    24-pin DIP module employing the feature-rich QT9701B2 ICs; uses the E297S board to load setups from a PC; includes analog and switched outputs, SPI and UART serial ports. 5V DC operation QTM2000 426-9822
     欢迎点击查询订购更多Quantum Research Group产品!
上海纽沃柯电子科技有限公司
联系人:魏先生
地址:万源路788弄32号202室
邮编:201103
电话:QQ:1003000751 13501905617
传真:021-34228879
公司网址:http://www.vanking.cn
  • 黎浩 在2023/12/22 8:33:00留言
  • 详细留言:帮客户询价
  • 在2023/7/27 11:11:00留言
  • 详细留言:MHP1400R010F*18PCS
  • 在2023/3/2 17:44:00留言
  • 杨女士 在2022/11/8 16:08:00留言
  • 伍余华 在2022/2/11 22:05:00留言
  • 详细留言:TYCO FLHTCO311-14-2
