上海御林信息科技有限公司
  • VE4005S2B2
  • 发布时间:2018/8/8 10:20:37   修改时间:2014/3/13 10:24:26 浏览次数:1381
  • DELTAV   DC9430X1-CA2, 44B2733X022       ALARM INTERFACE UNIT
    DELTAV   KJ1501X1-BB1, 12P0678X022       SYSTEM PASSTHROUGH POWER SUPPLY 12/12VDC (DC/DC)
    DELTAV   KJ1501X1-BC1, VE5008, 12P2186X012       System Dual DC Power Supply (DC/DC)
    DELTAV   KJ1700X1-BA1, VE6006, 12P1710X012       Media Converter
    DELTAV   KJ2002X1-CA1, 12P1509X042       M5 Controller
    DELTAV   KJ2002X1-CA1, VE3004, 12P1509X092       M5+ Controller
    DELTAV   KJ3001X1-BA1, VE4001S2T1, 12P0549X112   DI, 8-Channel, 24 VDC, Isolated Card
    DELTAV   KJ3001X1-BB1, VE4001S2T2, 12P0550X142   DI, 8-Channel, 24 VDC, Dry Contact Card
    DELTAV   KJ3001X1-BC1, 12P0551X132, VE4001S3T1B1         DI 120VAC ISOLATED
    DELTAV   KJ3001X1-BG1, VE4002S1T1, 12P0557X152   DO, 8-Channel, 24 VDC, Isolated Card
    DELTAV   KJ3001X1-BJ1, VE4002S1T2B2, 12P0555X122         DO, 8-Ch, 24 VDC, High Side Card, 6AMP/CARD 1.5AMP/CH
     d
    DELTAV   KJ3002X1-BB1, 12P0683X072       ANALOG OUTPUT, 4-20mA
    DELTAV   KJ3002X1-BA1, VE4003S2, 12P0680X122     Analog Input, 8 Channel, 4-20mA, HART Card
    DELTAV   KJ3002X1-BC1, VE4003S1B2, 12P0681X092   Analog Input Module Final Assy, 4-20mA, Card
    DELTAV   KJ3002X1-BE1, 12P0682X052, VE4005S2B2   Analog Output, 8-Channel, 4-20mA, HART Card
    DELTAV   KJ3002X1-BF1, VE4003S6B1, 12P1732X012   RTD Card
    DELTAV   KJ3002X1-BG2, VE4003S5B1, 12P1731X032   Thermocouple, mV Card
    DELTAV   KJ3003X1-BA1, 12P0914X062, VE4009       Serial Interface Card
    DELTAV   KJ3222X1-BA1, 12P2532X072, VE4003S2B1   ANALOG INPUT, 8 Ch, 4-20mA, HART, SERIES 2
    DELTAV   KJ4001X1-BA2,  VE3051CO, 12P1562X032    Power Controller 2 Wide Carrier
    DELTAV   KJ4001X1-BE1, VE4050S2K1C1, 12P0818X052         8 Wide I/O Carrier with Shield Bar
    DELTAV   KJ4001X1-CA1, 12P0823X052       I/O TERMINAL BLOCK
    DELTAV   KJ4001X1-CB1, 12P0625X052       Fused I/O Terminal Block
    DELTAV   KJ4001X1-CB1, 12P0625X062       Fused I/O Terminal Block
    DELTAV   KJ4001X1-CC1, 12P0733X032       4 Wire TX Terminal Block
    D
    DELTAV   KJ4001X1-CH1, 12P1811X012       RTD Terminal Block
    DELTAV   KJ4001X1-HA1, 12P0949X022       Local Bus Extender Cable
    DELTAV   KJ4002X1-BB1, 12P1728X042, VE4055S2C0   Right 8 Wide Vertical Carrier
    DELTAV   KJ4002X1-BA1, 12P1727X042, VE4055S1C0   Left 8 Wide Vertical Carrier
    DELTAV   KJ4010X1-BF1, 12P0831X042       Local Bus Left Extension
    DELTAV   KJ4010X1-BG1, 12P0830X042       Local Bus Right Extension
    DELTAV KJ4010X1-BG1, 12P0830X072 LOCAL BUS RIGHT EXTENDER
    DELTAV KJ4010X1-BF1, 12P0831X062 LOCAL BUS LEFT EXTENDER
    DELTAV KJ4010X1-BE1, 12P0631X012 CABLE
    DELTAV 12P0631X012 DELTAV PARALLEL CORD
    DELTAV KJ4001X1-HA1, 12P0949X022 LOCAL BUS EXTENDER CABLE
    DELTAV KJ4002X1-BF2, 12P3866X012 DELTAV BOTTOM EXTENDER CABLE
    DELTAV KJ4002X1-BE1, 12P4048X012 DELTAV TOP EXTENDER CABLE
    DELTAV KJ4001X1-GB1, 12P0831X022 LOCAL BUS LEFT EXTENDER
    DELTAV KJ4001X1-CA1, 12P0623X022 I/O TERMINAL BLOCK
    DELTAV KJ3003X1-EA1, 12P0921X012 SER. INT. TERMINAL BLOCK
    DELTAV 8605-FT-TC, VER: MT02 FIELD TERM. THERMOCOUPLE
    DELTAV KJ4001X1-BB1, 12P0619X012 8 WIDE I/O CARRIER
    DELTAV KJ4001X1-BA1, 12P0679X012 2 SLOT CARRIER
    DELTAV KJ4001X1-BA2, 12P1562X012 2 WIDE CARRIER W/ RED
    DELTAV 8105-TI-TC, VER:MT01 4-CHANNEL THC/MV INPUT
    DELTAV KJ3002X1-BA1, 12P0680X122 AI MODULE FINAL ASSY
    DELTAV KJ3001X1-BB1, 12P0550X112 DI 24VDC DRY CONTACT
    DELTAV KJ3001X1-BC1, 12P0550X112 DI 24VDC DRY CONTACT
    DELTAV KJ3001X1-BG1, 12P0557X032 DO 24VDC ISOLATED
    DELTAV KJ3001X1-BH1, 12P0558X102 DO 120-230 VAC ISOLATED
    DELTAV KJ3002X1-BG2, 12P1731X062 THERMOCOUPLE mV
    DELTAV KJ2003X1-BA2, 12P2093X112 CONTROLLER MD
    DELTAV KJ1501X1-BB1, 12P0678X012 SYSTEM POWER SUPPLY (DC/DC)
    DELTAV 8910-PS-DC SYSTEM POWER SUPPLY, 24VDC
    DELTAV KJ2003X1-BA2, 12P2093X072 CONTROLLER MD
    DELTAV KJ3001X1-BH1, 12P0558X112 DO MODULE VAC ISOLATED
    DELTAV KJ4001XBA2 2 WIDE CARRIER
    Rosemount System 3 Equipment
    ALL KINDS OF CIRCUIT BOARDS AND ACCESSORIES, FROM FUJITSU PRINTERS, FUSES, TO CIRCUIT BOARDS, EVERYTHING FOR THE RS3, $Call for price
    RS3      01984-0023-0001         CONTROL FILE CARD CAGE
    RS3      01984-0303-0001         AC DISTRIBUTION PANEL
    RS3      01984-0303-0002         AC DISTRIBUTION PANEL
    RS3      01984-0488-0001         PEERWAY TAP A
    RS3      01984-0489-0001         PEERWAY TAP B
    RS3      01984-0605-0001         HIGH VOLTAGE POWER SUPPLY
    RS3      01984-0607-0004         MUX REED, 4-20mA
    RS3      01984-0607-0007         MUX REED, HI VOLTAGE, THERMOCOUPLE
    RS3      01984-0607-0009         MUX REED, RTD
    RS3      01984-0607-0009         TWO OPTIONS KEYBOARD
    RS3      01984-0620-0001         MULTIPLEXTER FLEX TERM CAGE
    RS3      01984-0628-0001         MUX COMMUNICATION CARD
    RS3      01984-0660-0001         CONSOLE OI CARD CAGE
    RS3      01984-0744-0007         ALARM OUTPUT BOARD
    RS3      01984-1011-0003         MINICONSOLE PRINTER INTERFACE
    RS3      01984-1045-0003         MC PEERWAY
    RS3      01984-1046-0003         MC PEERWAY
    RS3      01984-1064-0001         OI COLOR VIDEO
    RS3      01984-1137-0001         OI POWER SUPPLY
    RS3      01984-1140-0001         OI SCSI HOST ADAPTER
    RS3      01984-1144-0001         DC POWER DISTRIBUTION BUS
    RS3      01984-1147-0001         OI BUBBLE MEMORY
    RS3      01984-1149-0001         23 MAT 06
    RS3      01984-1175-0001         MULTI STRATEGY MOTHERBOARD FLEX
    RS3      01984-1252-0001         ANALOG FIELD TERMINATION  BOARD
    RS3      01984-1362-0001         NON ISO AND ISO ANALOG OUTPUT/INPUT  CARD EXTENDER
    RS3      01984-1432-0001         POWER REGULATOR
    RS3      01984-1432-0001         CONTROL FILE POWER REGULATOR
    RS3      01984-1439-0005         MULTI LOOP PROCESSOR
    RS3      01984-1445-0005         CONTACT PROCESSOR
    RS3      01984-1448-0002         COORDINATOR PROCESSOR
    RS3      01984-1460-0003         CONTACT I/O
    RS3      01984-1463-0001         ANALOG INPUT FIC NON-ISOLATED
    RS3      01984-1483-0003         NV BUBBLE MEMORY
    RS3      01984-1490-0003         ANALOG OUTPUT FIC NON ISOLATED
    RS3      01984-1494-0005         MULTI LOOP PROCESSOR
    RS3      01984-1502-0001         PEERWAY BUFFER
    RS3      01984-1540-0009         OI PROCESSOR
    RS3      01984-1547-0001         OI NV RAM
    RS3      01984-1594-0002         COORDINATOR PROCESSOR II
    RS3      01984-1598-0001         4 MEG NV BUBBLE MEM
    RS3      01984-1632-1000         OPTIONS KEYBOARD
    RS3      01984-1632-2000         TWO OPTIONS KEYBOARD
    RS3      01984-1975-0001         TRACKBALL KEYBOARD
    RS3      01984-1984-0001         POWER SUPPLY
    RS3      01984-1984-0003         POWER SUPPLY
    RS3      01984-2137-0008         OI PROCESSOR 1 MEG
    RS3      01984-2298-0001         POWER SUPPLY
    RS3      01984-2347-0021         NV MEMORY
    RS3      01984-2386-0005         KEYBOARD
    RS3      01984-2402-0001         INTERFACE R5422-R5232
    RS3      01984-2445-0001         MULTI STRATEGY MOTHERBOARD FLEX
    RS3      01984-2500-0005         CONTROLLER SERIAL 1/O
    RS3      01984-2503-0001         OI GRAPHICS VIDEO GEN
    RS3      01984-2512-0003         ANALOG MARSHALLING PANEL
    RS3      01984-2518-0002         FIC 4-20 mA  2In/1Out
    RS3      01984-2526-0002         SIO RACK MINT CD CAGE
    RS3      01984-2543-0001         COMMUNICATIONS CONNECT III
    RS3      01984-2543-0001         COMUNICATIONS CONECT II
    RS3      01984-2546-0002         PULSE I/O
    RS3      01984-2551-0001         OUTPUT BYPASS CARD
    RS3      01984-2597-0001         ANALOG I/O CAGE MOTHERBOARD
    RS3      01984-2731-0001         FIC RTD/TC
    RS3      01984-2759-0008         OI PROCESSOR III
    RS3      01984-2837-0001         FLOOPY DRIVE
    RS3      01984-2871-0004         MAIN KEYBOARD
    RS3      01984-3100-0001R        QUANTUM HARD DRIVE
    RS3      01984-3202-0010         OI PROSSESOR V
    RS3      01984-3222-0004         KEYBOARD INT.VIDEO ISOLATOR
    RS3      01984-3505-0001         POWER REGULATOR II 5 VOLT ONLY
    RS3      01984-353-0001
    RS3      01984-4068-0006         MULTI-PURPOSE CONTROLLER II
    RS3      01984-4068-0006         MULTI PURPOSE CONTROLLER II
    RS3      01984-4080-0001         DISCRETE FIELD INTERFACE MODULE 32 POINTS
    RS3      01984-4121-0001         ISOLATED DISCRETE TERMINATION PANEL A
    RS3      01984-4121-0001         ISOLATED DISCRETE TERMINATION PANEL B
    RS3      01984-4121-0002         ISOLATED DISCRETE TERMINATION PANEL A
    RS3      01984-4124-0001         ISOLATED DISCRETE TERMINATION PANEL B
    RS3      01984-4124-0001         ISOLATED DISCRETE TERMINATION PANEL A
    RS3      01984-4164-0004         COORDINATOR PROCESSOR IV+
    RS3      01984-4205-0001         COMM TERM PANEL II
    RS3      01984-4383-0001         MAIO TERMINATION PANEL
    RS3      01984-4398-0001         LOOP POWER MODULE
    RS3      01984-4414-1001         16 POINT ANALOG INPUT FIELD INTERFACE MODULE 4-20 mA
    RS3      01984-4418-0001         16 POINT ANALOG OUTPUT FIELD INTERFACE MODULE 4-20 mA
    RS3      105S    QUANTUM HARD DRIVE
    RS3      10P50400006     MULTI-PURPOSE CONTROLLER II
    RS3      10P50400006     MULTI PURPOSE CONTROLLER II
    RS3      10P50870004     COORDINATOR PROCESSOR IV+
    RS3      10P52760001     PEERWAY TAP A
    RS3      10P53520006     DISCRETE FIELD INTERFACE MODULE LOW SIDE SWITCH
    RS3      10P54040004     16 POINT ANALOG INPUT FIELD INTERFACE MODULE
    RS3      10P54770001     ISOLATED DISCRETE TERMINATION PANEL
    RS3      10P55270010     OI PROSSESOR  V
    RS3      10P56500001     CONTROLLER CARD FILE
    RS3      10P56620002     AC POWER DISTRIBUTION 115 VAC
    RS3      2060S   ARCHIVE TAP DRIVE 60MB
    RS3      2150S   ARCHIVE TAP DRIVE 150MB
    RS3      21F8568         TANDBERG TAPE DRIVE 150MB
    RS3      232XSS  EXPANDABLE SMART SWITCH
    RS3      5945 S-1        ARCHIVE TAP DRIVE 45MB
    RS3      70-IAC5         OPTO22
    RS3      70-ODC5R        OPTO22
    RS3      80S     QUANTUM HARD DISK
    RS3      DC 300XLP       45 MB TAPE
    RS3      DC 6150         150 MB TAPE
    RS3      IAC5    OPTO22
    RS3      M3345A  FUJITSU LIMITED PRINTER
    RS3      DX2400  FUJITSU LIMITED PRINTER
    RS3      OAC5    OPTO22
    RS3      OAC5A   OPTO22
    RS3      OAC5A   OPTO22
    RS3      ST34520N        SEAGATE HARD DRIVE
    RS3      WD400BB-00DEA0  WESTERN DIGITAL HARD DRIVE
    RS3              MTCC ENHANCED KEYBOARD
    RS3              KEYBOARD WITH TRACKBALL AND OPTIONS KEYBOARD
    Honeywell TDC3000 Equipment
    TDC3000  30671513-001    TERMINAL PANEL MODEL C-TCB30
    TDC3000  30731808-001    REGULATOR
    TDC3000  30731811-001    PWA, OUTPUT
    TDC3000  30731823-001    A/D MUX PWB
    TDC3000  30731832-001    PWA, PROCESSOR
    TDC3000  30735863-001    SWITCHING PWB
    TDC3000  30735863-002    C-CDS00 ANALOG SWITCHCARD
    TDC3000  30735866-001    DECODER PWB
    TDC3000  4DP7APXAD211    A/D CONVERTER R3
    TDC3000  4DP7APXDH11     CABLE I/F
    TDC3000  4DP7APXDH111    PWA, Highway I/F
    TDC3000  4DP7APXDH233    PWA, DATA HIGHWAY I/F
    TDC3000  4DP7APXIA322    ANALOG IN
    TDC3000  4DP7APXID211    1 MEC 24V DIG IN
    TDC3000  4DP7APXIO211    PWA I/O
    TDC3000  4DP7APXOA311    ANALOG OUT
    TDC3000  4DP7APXOD411    7100 DIGITAL OUT P-XOD41
    TDC3000  4DP7APXPM155    PWA, DATA HIGHWAY I/F
    TDC3000  4DP7APXPR211    1 POINT FILE CON
    TDC3000  4DP7APXPR311    2 POINT FILE CON
    TDC3000  51303903-100    TERMINAL PANEL MODEL P-TCB60
    TDC3000  82407381-001    PWB, CONTROL
    TDC3000  82407387-001    PWB, IBC R15/20/30 J-CBC00
    TDC3000  82407390-001    IBI       **MOUNTED TO 82408215-001
    TDC3000  82407390-001    PWB, IBI R30
    TDC3000  82407444-001    PANEL, TERM J-TPF40
    TDC3000  82407465-001    REG-A
    TDC3000  82407468-001    REG-B
    TDC3000  82407468-002    REG-B
    TDC3000  82408215-001    PWB, IBI A/D R15  **MOUNTED TO 82407390-001
    TDC3000  82408217-001    PWB, MOS CPU R15
    TDC3000  82408330-001    PWA, HIWAY #2
    TDC3000  82408363-001    J-TPF20
    TDC3000  82408440-001    PWB, UAC I/F R30
    TDC3000  82408449-001    PWB, IBCD R30
    TDC3000  82408452-001    RBCD CONTROLL R300
    TDC3000  82408456-002    J-CBM55
    TDC3000  82408458-002    BM-A CARD
    TDC3000  82408461-001    BM-B CARD
    TDC3000  82408464-100    SO SWITCH
    TDC3000  82408467-001    PWB, I/O BUS SW
    TDC3000  82408470-001    PWB, I/O BUS SW
    TDC3000  82408485-001    PWB, SBLA III
    TDC3000  82408667-001    PWA, ROM/RAM 535
    TDC3000  82408667-003    PWB, ROM/RAM 505
    TDC3000  CHASSIS J-CB535         W/SBC MAIN BACKPLANE 82407411
    TDC3000  CHASSIS J-CD506         W/RBCD BACKPLANE 82408512
    TDC3000  CHASSIS J-CDD50         W/RBCD I/O BUS SWITCH BACKPLANE 82408517
    TDC3000  CHASSIS J-CDM50         W/BACKUP MEMORY BACKPLANE 82408522
    TDC3000  CHASSIS J-PF200         W/SBC I/O BACKPLANE 82407364-001
    TDC3000  51400700-100    PWA, Data Highway I/F
    TDC3000  51400667-100    PWA, Enhanced LCN
    TDC3000  51401288-100    PWA, HPK2-2MW
    TDC3000  51108088-100    PWA, DHI I/O
    TDC3000  51107403-100    I/O CARD, LCN
    TDC3000  51109919-100    PWA, PCSR
    TDC3000  80360206-100    PWA, CLI
    TDC3000  51400910-100    PWA, EMEM 1MW
    TDC3000  51400901-100    PWA, EMPU
    TDC3000  80360230-001    PWA, CLI I/O
    TDC3000  51400668-100    WDC
    TDC3000  51108676-100    PWB, I/O WREN II
    TDC3000 51198947100F D/C 0610
    TDC3000 80363969-150 HW ANALOG INPUT,16
    TDC3000 80363972-150 HW DIGI-INPUT, 24 VDC
    TDC3000 51304754-150,HDW HIGH LEVEL ANALOG-INPUT
    TDC3000 51403422-150,HDW HIGH PERFORMANCE COM/CONTROL
    TDC3000 51309276-150, HIGH PERFOMANCE I/O LINK
    TDC3000 51304362-150 LOW ANALOG LEVEL MUX
    T
上海御林信息科技有限公司 公司主要从事PLC&DCS,仪器仪表,传动电气设备,机电产品的销售以及工业自动化产品系统集成方案。公司与国内外众多知名品牌供应商建立有极其良好的合作关系,在欧美,东南亚,中东,非洲,大洋洲等地形成了稳定、高效的…  更多>>
上海御林信息科技有限公司
联系人:魏洋涛
地址:上海市浦东周康路26号万达E座1505
邮编:201318
电话:021-33891086
传真:021-33891530
公司网址:
  • 陈慧 在2023/12/15 10:50:00留言
  • 详细留言:ACS141-2K7-1询价
  • 李勇 在2023/8/9 15:09:00留言
  • 详细留言:60SR3B05 数量100
  • Mohammed 在2020/12/3 17:14:00留言
  • 详细留言:Hi 1- TSGASH-1624 Fail-safe Gas/Flame detector input FTA with HART interface. 2- SAI-1620M 3- SPD(SD32T3) 3 WIRE AI ANALOGE SIGNAL. 4- TERMINAL BLOCKA
  • amr saeed 在2019/1/8 19:28:00留言
  • 详细留言:greetings this is amr saeed from power egypt corporation specialized at manufacturing ac units we require the following: johnson control a36aha-8c 10-90f , 4 stage thermostat please quote us technically and prices
  • 神华机电 在2016/10/12 11:10:00留言
  • 详细留言:询价
