深圳鸿瑞源二手仪器回收有限公司
  • MT8820A/MT8820A现货/安立MT8820A
  • 发布时间:2012/8/4 10:31:49   修改时间:2012/8/4 10:31:49 浏览次数:593
    Anritsu MT8820A技术参数:
    General:
    频率范围:30至2700 MHz
    ·最大输入电平:+35 dBm的主要1)
    ·1主要输入/输出接口
    ·阻抗:50Ω
    ·驻波比:≤1.2(<1.6千兆赫),≤1.25(1.6至2.2 GHz),≤1.3(2.2千兆赫)
    ·连接器:N型
    AUX1输出连接器
    ·阻抗:50Ω
    ·驻波比:≤1.3(SG输出电平:≤-10 dBm时)
    ·连接器:SMA型
    参考振荡器
    ·频率:10 MHz
    ·平:TTL
    ·启动特性:≤±5×10-8(在10分钟启动后参考频率24小时后明星
    ·老化率:≤±2 x10-8/day,≤±1×10-7/year(参考启动后,频率为24小时)
    ·温度特性:≤±5×10-8
    ·连接器:BNC型
    外部参考输入
    ·频率:在10 MHz或13 MHz(±1 PPM)
    ·等级:≥0 dBm的
    ·阻抗:50Ω
    ·连接器:BNC型
    MT8820A Anritsu MT8820A
    ____________________________________________
    小提示:如果您找不到联系方式,请Baidu“仪器回收 鸿瑞源”,谢谢
    ______________________________________________________
    MT8820A的硬件平台,涵盖了30兆赫的频率范围至2.7 GHz。当安装了专用测量软件和硬件(选项),这个单一平台上支持所有主要的传输/接收W-CDMA/HSDPA,GSM/ GPRS / EGPRS的cdma2000R1X(IS-2000),CDMA2000的测试项目的评价套1xEV-DO,PDC和PHS/高级小灵通终端。MT8820A/MT8820A二手/安立MT8820A
    Frequency range: 30 to 2700 MHz
    Max. input level: +35 dBm Main 1)
    Main 1 input/output connector
    Impedance: 50 Ω
    VSWR: ≤ 1.2 (< 1.6 GHz), ≤ 1.25 (1.6 to 2.2 GHz), ≤ 1.3 (> 2.2 GHz)
    Connector: N type
    AUX 1 output connector
    Impedance: 50 Ω
    VSWR: ≤ 1.3 (at SG Output level: ≤ –10 dBm)
    Connector: SMA type
    General
    Reference oscillator
    Frequency: 10 MHz
    Level: TTL
    Startup characteristics: ≤ ±5 x 10–8 (at 10 min after startup referenced to frequency 24 h after startup)
    Aging rate: ≤ ±2 x 10–8/day, ≤ ±1 x 10–7/year (referenced to frequency 24 h after startup)
    Temperature characteristics: ≤ ±5 x 10–8
    Connector: BNC type
    External reference input
    Frequency: 10 MHz or 13 MHz (±1 ppm)
    Level: ≥ 0 dBm
    Impedance: 50 Ω
    Connector: BNC type
    Frequency
    Frequency range: 30 to 2700 MHz (setting range: 0.4 to 2700 MHz)
    Setting resolution: 1 Hz
    Accuracy: Due to reference oscillator accuracy
    Output level
    Level range: –140 to –10 dBm (Main 1), –130 to 0 dBm (AUX 1)
    Resolution: 0.1 dB
    RF signal generator
    Accuracy: ±1.0 dB (–120 to –10 dBm, Main 1, after calibration), ±1.0 dB (–110 to 0 dBm, AUX 1, after calibration)
    Signal purity
    Non-harmonic spurious:
    ≤ –50 dBc (at offset frequency: ≥ 100 kHz, except Uplink frequency – Downlink frequency + 4.1825 GHz),
    ≤ –40 dBc [spurious of (4.8 GHz – Downlink frequency GHz) GHz at ≥ 2.1 GHz]
    Harmonics: ≤ –25 dBc
    Uninterrupted level variation
    Variable range: 0 to –30 dB
    Setting resolution: 1 dB
    Display
    Color 8.4" TFT LCD, 640 x 480 dots
    External control
    Others
    GPIB: Control from external host with main unit as device (excluding some functions such as power-on),
    no external device control
    Interface functions: SH1, AH1, T6, L4, SR1, RL1, PP0, DC1, DT1, C0, E2
    Power supply 100 to 120/200 to 240 Vac (–15/+15%, 250 V max.), 47.5 to 63 Hz, ≤300 VA (with Option 01), ≤650 VA (with all Options)
    Dimensions and mass 426 (W) x 221.5 (H) x 498 (D) mm (excluding projections), ≤ 27 kg (with Option 01), ≤ 34 kg (with all Options)
    Operating temperature and humidity: 0 to +50?C, ≤ 95% (no condensation)
    Storage temperature and humidity: –20 to +60?C, ≤ 95% (no condensation)
    EMC Environmental conditions
    EN61326: 1997/A2: 2001 (Class A), EN61000-3-2: 2000 (Class A), EN61326: 1997/A2: 2001 (Annex A)
    LVD
    EN61010-1: 2001 (Pollution Degree 2)
    ·MT8820A (Mainframe)
自2002年成立以来,深圳市鸿瑞源二手仪器回收有限公司经销批发的数字示波器、综合测试仪、网络分析仪、频谱分析仪、信号发生器畅销消费者市场,在消费者当中享有较高的地位,公司与多家零售商和代理商建立了长期稳定的合作关系。公司经销的数字…  更多>>
深圳鸿瑞源二手仪器回收有限公司
联系人:刘子微
地址:深圳市宝安区龙华民治大道牛栏前大厦主楼C802
邮编:518000
电话:0755-23048669
公司网址:http://www.hrk17.com
