上海秋腾贸易有限公司
  • HF SCIENTIFIC
  • 发布时间:2013/5/16 16:49:42   修改时间:2013/5/16 16:49:42 浏览次数:516
  • HF SCIENTIFIC浊度监测器
    HF Scientific,MicroTOL,自来水在线浊度仪,进口在线浊度仪表MicroTOL应用于自来水厂、污水厂、水池、渠道及水利设施、贮液罐、防洪监测;采用一体式模块化设计,符合美国EPA180.1或ISO7027标准;独特设计的水汽消除系统,干燥剂可更换;清洗校正非常容易。
    上海秋腾代理销售美国 HF SCIENTIFIC浊度监测器、HF SCIENTIFIC实验室手提型浊度计、HF SCIENTIFIC流导电流计和HF SCIENTIFIC UV穿透度监测器等全系列产品。
    HF scientific produces instrumentation, test kits and chemical reagents used to monitor water quality in a variety of applications. Its primary markets are in industrial and municipal water treatment. However, HF scientific products are also used in applications as varied as industrial process control systems and phamaceutical and environmental applications.
    HF scientific offers a comprehensive line of on-line, continuous monitoring instruments as well as instrumentation for laboratory and field use, including instruments for: chlorine testing; turbidity testing; online continuous monitoring for turbidity; UV% transmission; and residual chlorine. HF scientific also offers test kits, reagents, and buffers.
    Through better design, HF scientific has found ways to reduce user maintenance costs, decrease the operator's learning curve, incorporate innovative technology and deliver comprehensive service to its customers. In the processing plant, laboratory or field, HF scientific products perform with accuracy, durability and longevity.
    HF SCIENTIFIC浊度计 MicroTOL参数:测量范围:0~1000 NTU,测量原理:散射比浊法测量(90o方向),测量精度:2%读数或±0.02 NTU(<40 NTU);5%读数(>40 NTU),分辨率:0.0001,其他分辨率可选,响应时间:5~500秒(0~1000 NTU测量范围内),输入压力:1~200psi(内置压力调节器),标准输出:4~20mA信号隔离输出或RS-485输出,光源:白光光源(7年使用寿命),报警方式:浊度值“高/低"报警,报警器触点容量:C形连接,250VAC 2A,显示:带背景光的多行对话框LCD显示,内置系统自诊装置,储存温度:-20~60℃,运行温度:0~50℃,与水接触部分的材质:采用防水材料:不锈钢,外壳:符合Nema 4X、IP 66防护标准。
    HF SCIENTIFIC现货、HF SCIENTIFIC价格、HF SCIENTIFIC厂家、HF SCIENTIFICHF SCIENTIFIC代理、HF SCIENTIFIC经销、HF SCIENTIFIC型号
    HF SCIENTIFIC spot, HF SCIENTIFIC price, HF SCIENTIFIC manufacturers, HF SCIENTIFICHF SCIENTIFIC agent, HF SCIENTIFIC distribution, HF SCIENTIFIC model
    HF SCIENTIFIC turbidity monitor, HF SCIENTIFIC laboratory portable type turbidity meter, HF SCIENTIFIC flow guide galvanometer and HF SCIENTIFIC UV penetration degree monitor
上海秋腾贸易有限公司是一家集设备、备品备件采购、国内物流、市场咨询和调研于一体的技术型贸易公司。经过多年的发展,现已成为一家工业产品经销商,销售的品牌超过900多个,备有大量库存。上海秋腾贸易有限公司成立于2003年,公司长期服务于…  更多>>
上海秋腾贸易有限公司
联系人:沙夕梅
地址:上海市景泰路170号康建商务广场8号楼202室
邮编:200333
电话:021-51695276
传真:021-51691570
公司网址:http://www.qiuten.com
  • 詹文冲 在2024/11/15 9:53:00留言
  • 详细留言:SCHLEICHER_SNV4063KL 价格
  • 王东会 在2016/5/7 15:31:00留言
  • 详细留言:想了解 GEMü 800 GEMü 850的具体价格以及其它相关问题!
  • 河南洛阳 在2016/2/17 17:14:00留言
  • 详细留言:抱闸控制板 印刷电路板(已装妥组件) 厂牌:SIME-Stromag 型号:AC 64-50 数量1个,请报个含税(17%)含运价格,货期,谢谢!请尽快联系我
  • 王欣 在2015/6/18 15:58:00留言
  • 详细留言:LFS931113000
  • 王力 在2015/3/17 11:11:00留言
