上海秋腾贸易有限公司
  • COAX
  • 发布时间:2013/5/16 16:23:52   修改时间:2013/5/16 16:23:52 浏览次数:363
  • COAX阀
    德国Coax阀有着45年的研发历史,适用于各种对产品质量要求非常高而环境非常恶劣的工业场合。Coax阀具有20000多不同型号的阀,能函盖所有的工业应用场合,是企业控制、调节、监控工业介质的坚实伙伴。
    德国COAX以生产同轴阀著称,凭借丰富的经验,可靠而经过严格测试的材质,过硬的质量管理,已代表了工程、制造专业以及创新工艺方案的最高技术。CO-AX已将同轴阀发展成为用于控制真空气态、液态、凝胶状、有颗粒、高污染和强腐蚀性介质的可靠产品。COAX同轴阀的设计与普通阀门相比,具有在高流量工况下控制高压的特点。并能提供二位二通或二位三通的形式,有螺纹或法兰连接方式。阀门可通过直动电磁阀或外部驱动。COAX阀门用于控制、调节和止回,适合各种介质,包括从低到高粘性的,从润滑到有颗粒的,从化学性能中性到强腐蚀的,COAX阀门都能应对自如,而且保证质量不变,标准最高。COAX核心产品有XX COAX电磁阀、XXCOAX电动调节阀、XX-COAX气动调节阀、XX COAX自力式调节阀、XXCOAX温度调节阀、COAX压力调节阀、COAX电动球阀、COAX气动球阀、COAX电动蝶阀、COAX气动蝶阀及真空泵、COAX、CO-AX、COAX电磁阀、coax电动调节阀、coax同轴阀、coax真空发生器、coax阀、coax气动蝶阀、coax阀门
    2/2 way coaxial direct acting
    3/2 way coaxial direct acting
    2/2 way coaxial externally controlled
    3/2 way coaxial externally controlled
    certificated valves
    cartridge valves
    lateral valves
    high pressure valves coaxial
    high pressure valves lateral
    modules and manifolds
    pressure control valves
    flow control valves
    special valves
    function NC - normally closed, NO - normally open
    body materials aluminium, brass, galvanized steel, nickel plated brass, nickel plated steel, without non-ferrous metals, stainless steel
    seal materials NBR, PTFE, FPM, CR, EPDM, special seal materials
    media gaseous, liquid, gelatinous, highly viscous, pasty, contaminated, aggressive
    actuation DC direct current coil
    AC direct current coil with integrated / separated rectifier
    nominal voltage DC 24 V / AC 110 V / AC 230 V
    electrical connection plug acc. DIN EN 175301-803, form A, LED
    insulation rating H 180°C
    enclosure protection IP 65
    energized duty rating ED 100%   (16 bar max.)
    vacuum leak rate 10-6 mbar
    options special threads, special flanges, function NO, damping, limit switches, manual override, approvals, mounting, special voltage, plug M 12 x 1, terminal box
    COAX现货、COAX价格、COAX厂家、COAX代理、COAX经销、COAX型号
    COAX COAX COAX spot, price, manufacturer, COAX COAX agent, distribution, COAX model
    COAX pressure regulator, COAX electric ball valves, pneumatic ball valves, COAX COAX COAX electric butterfly valve, pneumatic butterfly valve
上海秋腾贸易有限公司是一家集设备、备品备件采购、国内物流、市场咨询和调研于一体的技术型贸易公司。经过多年的发展,现已成为一家工业产品经销商,销售的品牌超过900多个,备有大量库存。上海秋腾贸易有限公司成立于2003年,公司长期服务于…  更多>>
上海秋腾贸易有限公司
联系人:沙夕梅
地址:上海市景泰路170号康建商务广场8号楼202室
邮编:200333
电话:021-51695276
传真:021-51691570
公司网址:http://www.qiuten.com
  • 詹文冲 在2024/11/15 9:53:00留言
  • 详细留言:SCHLEICHER_SNV4063KL 价格
  • 王东会 在2016/5/7 15:31:00留言
  • 详细留言:想了解 GEMü 800 GEMü 850的具体价格以及其它相关问题!
  • 河南洛阳 在2016/2/17 17:14:00留言
  • 详细留言:抱闸控制板 印刷电路板(已装妥组件) 厂牌:SIME-Stromag 型号:AC 64-50 数量1个,请报个含税(17%)含运价格,货期,谢谢!请尽快联系我
  • 王欣 在2015/6/18 15:58:00留言
  • 详细留言:LFS931113000
  • 王力 在2015/3/17 11:11:00留言
