杭州微浪科技有限公司(MOXA一级代理, MOXA总代理)
  • 唐山MOXA单射频无线AP AWK-1131A-EU代理
  • 发布时间:2016/4/5 10:19:01   修改时间:2016/4/5 10:19:01 浏览次数:834
  • MOXA AWK-1131A-EU
    802.11a/b/g/n 工业级无线AP,RJ45/RP-SMA,EU band,0 ~ 60 ℃操作温度
    无线局域网接口标准:IEEE 802.11a/b/g/n适用于Wireless LANIEEE 802.11i适用于Wireless SecurityIEEE 802.3适用于10BaseTIEEE 802.3u适用于100BaseT(X)IEEE 802.3ab适用于1000BaseT扩频调制与速率(典型产品):? DSSS with DBPSK,DQPSK,CCK? OFDM with BPSK,QPSK,16QAM,64QAM? 802.11b: CCK @ 11/5.5 Mbps,DQPSK @ 2 Mbps,DBPSK @ 11 Mbps? 802.11a/g: 64QAM @ 54/48 Mbps,16QAM @ 36/24Mbps,QPSK @ 18/12 Mbps,BPSK @ 9/6 Mbps? 802.11n: 64QAM @ 300 Mbps to BPSK @ 6.5 Mbps(multiple rates supported)工作频道(central frequency):US:2.412 ~ 2.462 GHz (11频段)5.180 ~ 5.240 (4频段)5.260 ~ 5.320 (4频段)*5.500 ~ 5.700 GHz (8频段 - 不包括5.600 ~ 5.640 GHz)*5.745 ~ 5.825 GHz (5频段)EU:2.412 ~ 2.472 GHz (13频段)5.180 ~ 5.240 (4频段)5.260 ~ 5.320 (4频段)*5.500 ~ 5.700 GHz (11频段)*JP:2.412 ~ 2.484 GHz (14频段,DSSS)5.180 ~ 5.240 (4频段)5.260 ~ 5.320 (4频段)*5.500 ~ 5.700 GHz (11频段)*请注意:因DFS认证暂未通过,AWK-1131A暂不支持这些频段。请登录Moxa网站以了解最新DFS认证状态。安全:? SSID广播开闭功能? 基于MAC/IP / 协议 / 端口过滤的防火墙技术? 64-bit and 128-bit WEP encryption,WPA / WPA2-Personal and Enterprise (IEEE 802.1X/RADIUS,TKIPand AES)数据速率:802.11b: 1,2,5.5,11 Mbps802.11a/g: 6,9,12,18,24,36,48,54 Mbps802.11n: 6.5 ~ 300 Mbps (multiple rates supported)TX发射功率(每一天线端口):2.4 GHz802.11b:Typ. 23±1.5 dBm @ 1 MbpsTyp. 20±1.5 dBm @ 5 MbpsTyp. 19±1.5 dBm @ 11 Mbps802.11g:Typ. 20±1.5 dBm @ 6 to 24 MbpsTyp. 19±1.5 dBm @ 36 MbpsTyp. 18±1.5 dBm @ 48 MbpsTyp. 17±1.5 dBm @ 54 Mbps802.11n (20 MHz):MCS0,8@20 MHz: Typ. 20 dBm (± 1.5 dBm)MCS7,15@20 MHz: Typ. 16 dBm (± 1.5 dBm)MCS0,8@40 MHz: Typ. 20 dBm (± 1.5 dBm)MCS7,15@40 MHz: Typ. 16 dBm (± 1.5 dBm) 5 GHz802.11a:Typ. 20±1.5 dBm @ 6 to 24 MbpsTyp. 19±1.5 dBm @ 36 MbpsTyp. 16±1.5 dBm @ 48 MbpsTyp. 15±1.5 dBm @ 54 Mbps802.11n (20/40 MHz):MCS0,8@20 MHz: Typ. 19 dBm (± 1.5 dBm)MCS7,15@20 MHz: Typ. 14 dBm (± 1.5 dBm)MCS0,8@40 MHz: Typ. 18 dBm (± 1.5 dBm)MCS7,15@40 MHz: TyAWK-1131A-EU.jpg
    p. 14 dBm (± 1.5 dBm)RX灵敏度:2.4 GHz802.11b:-92 dBm @ 1 Mbps,-90 dBm @ 2 Mbps,-88 dBm @ 5.5 Mbps,-84 dBm @ 11 Mbps802.11g:-87 dBm @ 6 Mbps,-86 dBm @ 9 Mbps,-85 dBm @ 12 Mbps,-82 dBm @ 18 Mbps,-80 dBm @ 24 Mbps,-76 dBm @ 36 Mbps,-74 dBm @ 48 Mbps,-72 dBm @ 54 Mbps802.11n:-69 dBm @ MCS15 20MHz-71 dBm @ MCS7 20MHz5 GHz802.11a:-87 dBm @ 6 Mbps,-86 dBm @ 9 Mbps,-85 dBm @ 12 Mbps,-82 dBm @ 18 Mbps,-80 dBm @ 24 Mbps,-76 dBm @ 36 Mbps,-74 dBm @ 48 Mbps,-72 dBm @ 54 Mbps802.11n:-68 dBm @ MCS15 40MHz-69 dBm @ MCS15 20MHz-70 dBm @ MCS7 40MHz-71 dBm @ MCS7 20MHz协议支持一般协议支持:Proxy ARP,DNS,HTTP,HTTPS,IP,ICMP,SNTP,TCP,UDP,RADIUS,SNMP,PPPoE,DHCP,LLDPAP协议支持:ARP,BOOTP,DHCP接口默认天线:2个双射频全向天线,2 dBi,RP-SMA (male)扩展天线连接:RP-SMA (female)RJ45口:1,10/100/1000BaseT(X) auto negotiation speed,F/H duplex mode,and auto MDI/MDI-X connectionConsole口:RS-232 (RJ45-type)Reset:有LED指示灯:PWR,FAULT,STATE,SIGNAL,WLAN,10/100/1000 (RJ45 port)机械特性外壳:IP30防护等级,金属外壳尺寸:58 x 115 x 70 mm (2.28 x 4.53 x 2.76 in)安装方式:导轨安装(标准),壁挂安装(选配)工作环境工作温度:标准型号:0 ~ 60 ℃ (32 ~ 140 °F)存储温度:-40 ~ 85 ℃ (-40 ~ 185 °F)相对湿度:5% ~ 95% (non-condensing)电源需求输入电压:12 ~ 48 VDC,冗余双直流电源输入连接类型:4-pin removable terminal block电源功耗:12 ~ 48 VDC电源反接保护:有安规认证Safety:UL 60950-1,EN 60950-1EMC:EN 301 489-1/17,FCC Part 15 Subpart B Class B,EN 55022/55024Radio:EN 300 328,EN 301 893,TELEC注意:请登陆Moxa网站了解最新的产品认证信息。可靠性MTBF(平均无故障时间):810022小时保修保修期:5年
“成功会带来更多的成功。”这句话不仅是Moxa的公司哲学,同时也适用于Moxa的产品应用上。许多的客户已将Moxa产品成功地使用在许多串口通讯应用上,而好好地借重他们的成功经验也可让您在这个领域里一马当先。提供您数则大公司或中小企业如何应…  更多>>
联系人:施陈奕
地址:杭州文三路499
邮编:314400
电话:18006836682
传真:0571-87399697
公司网址:
  • 在2020/6/14 17:03:00留言
  • 详细留言:光电转换器\TCF-142-S MOXA
  • 李宝强 在2014/2/17 15:34:00留言
  • 详细留言:MOXA EDS-408A-MM-SC交换机fault灯在不停地闪烁,交换机的地址也读取不到,请问一下可以修补,还有没有修的价值
