杭州微浪科技有限公司(MOXA一级代理, MOXA总代理)
  • 宁夏MOXA双射频无线AP AWK-5232-M12-RCC-EU代理
  • 发布时间:2015/11/26 22:17:07   修改时间:2015/11/26 22:17:07 浏览次数:892
  • MOXA AWK-5232-M12-RCC-EU
    标温(-25 ~ 60 ℃),2个10/100/1000BaseT(X) M12接口,QMA无线接口
    规格WLAN标准:IEEE 802.11a/b/g/n for Wireless LANIEEE 802.11i for Wireless SecurityIEEE 802.3 for 10BaseTIEEE 802.3u for 100BaseTXIEEE 802.3ab for 1000BaseTIEEE 802.3at for Power-over-Ethernet PlusIEEE 802.1D for Spanning Tree ProtocolIEEE 802.1w for Rapid STPIEEE 802.1Q for VLAN扩频调制与速率(典型):? DSSS with DBPSK,DQPSK,CCK? OFDM with BPSK,QPSK,16QAM,64QAM? 802.11b: CCK @ 11/5.5 Mbps,DQPSK @ 2 Mbps,DBPSK @ 11 Mbps? 802.11a/g: 64QAM @ 54/48 Mbps,16QAM @ 36/24Mbps,QPSK @ 18/12 Mbps,BPSK @ 9/6 Mbps? 802.11n: 64QAM @ 300 Mbps to BPSK @ 6.5 Mbps(multiple rates supported)工作频道(中心频率):US:2.412 ~ 2.462 GHz (11 channels)5.18 ~ 5.24 GHz (4 channels)EU:2.412 ~ 2.472 GHz (13 channels)5.18 ~ 5.24 GHz (4 channels)安全:? SSID broadcast enable/disable? Firewall for MAC/IP/Protocol/Port-based filtering? 64-bit and 128-bit WEP encryption,WPA /WPA2-Personal and Enterprise (IEEE 802.1X/RADIUS,TKIPand AES)传输速率:802.11b: 1,2,5.5,11 Mbps802.11a/g: 6,9,12,18,24,36,48,54 Mbps802.11n: 6.5 to 300 Mbps (multiple rates supported)TX发射功率:802.11b:1 to 11 Mbps: Typ. 18 dBm (± 1.5 dBm)802.11g:6 to 24 Mbps: Typ. 18 dBm (± 1.5 dBm)36 to 48 Mbps: Typ. 17 dBm (± 1.5 dBm)54 Mbps: Typ. 15 dBm (± 1.5 dBm)802.11a: 6 to 24 Mbps: Typ. 17 dBm (± 1.5 dBm) 36 to 48 Mbps: Typ. 16 dBm (± 1.5 dBm) 54 Mbps: Typ. 14 dBm (± 1.5 dBm) TX发射功率MIMO:802.11a/n (20/40 MHz):MCS15 20 MHz: Typ. 13 dBm (± 1.5 dBm)MCS15 40 MHz: Typ. 12 dBm (± 1.5 dBm)802.11g/n (20 MHz): MCS15 20 MHz: Typ. 14 dBm (± 1.5 dBm)RX灵敏度:802.11b:-92 dBm @ 1 Mbps,-90 dBm @ 2 Mbps,-88 dBm @ 5.5Mbps,-84 dBm @ 11 Mbps802.11g:-87 dBm @ 6 Mbps,-86 dBm @ 9 Mbps,-85 dBm @ 12Mbps,-82 dBm @ 18 Mbps,-80 dBm @ 24 Mbps,-76dBm @ 36 Mbps,-72 dBm @ 48 Mbps,-70 dBm @ 54Mbps802.11a:-87 dBm @ 6 Mbps,-86 dBm @ 9 Mbps,-85 dBm @ 12Mbps,-82 dBm @ 18 Mbps,-80 dBm @ 24 Mbps,-76 dBm @ 36 Mbps,-72 dBm @48 Mbps,-70 dBm @ 54 MbpsRX灵敏度MIMO:802.11a/n:-68 dBm @ MCS15 40 MHz,-69 dBm @ MCS15 20 MHz,-70 dBm @ MCS7 40 MHz,-71 dBm @ MCS7 20 MHz802.11g/n:-69 dBm @ MCS15 20 MHz,-71 dBm @ MCS7 20 MHz协议一般协议支持:Proxy ARP,DNS,HTTP,HTTPS,IP,ICMP,SNTP,TCP,UDP,RADIUS,SNMP,PPPoE,DHCP仅AP协议:ARP,BOOTP,DHCP,STP/RSTP (IEEE802.1D/w)接口外接天线接口:AWK-5232-M12-RCC: QMA (female)M12接口:2个,自适应10/100/1000BaseT(X),F/H duplexmode,and auto MDI/MDI-X connectionConsole口:RS-232 (RJ45-type)LED指示灯:PWR1,PWR2,PoE+,FAULT,STATE,WLAN1,WLAN2,LAN1,LAN2报警触头(数字输出):1个继电器输出,负载能力1A @ 24数字输入:2个共地隔离输入? +13 to +30 V for state “1”? +3 to -30 V for state “0”? Max. input current: 8 mA机械特性外壳:金属,IP30防护等级重量:1.2 Kg尺寸:74.55 x 135 x 105 mm (2.94 x 5.31 x 4.13 in)安装方式:导轨(标准),壁挂(可选)工作环境工作温度:标准型号:-25 ~ 60 °C (-13 ~ 140 °F)宽温型号:-40 ~ 75 °C (-40 ~ 167 °F)存储温度:-40 ~ 85 °C (-40 ~ 185 °F)相对湿度:5% ~ 95% (non-condensing)电源需求输入电压:12 ~ 48 VDC,冗余双直流电源输入或48 VDCPoE+ (IEEE 802.3at compliant)*符合EN 50155标准中的24 VDC连接头:10-pin可移除接线端子电源功耗:最高24.5W @ 12 ~ 48 VDC,1.5 A (max.)电源反接保护:有安规认证Safety:UL 60950-1,EN 60950-1EMC:EN 301 489-1/17,FCC Part 15 Subpart B,EN55022/55024,IEC 61000-6-2/4Radio:EN 300 328,EN 301 893Rail Traffic:EN 50155*,EN 50121-1/4* 符合EN 50155标准基本部分,如有需要,可直接联络Moxa。注意:请登陆Moxa官网查询最新的认证信息。可靠性MTBF (平均无故障时间):350,643小时保修保修期:5年
“成功会带来更多的成功。”这句话不仅是Moxa的公司哲学,同时也适用于Moxa的产品应用上。许多的客户已将Moxa产品成功地使用在许多串口通讯应用上,而好好地借重他们的成功经验也可让您在这个领域里一马当先。提供您数则大公司或中小企业如何应…  更多>>
联系人:施陈奕
地址:杭州文三路499
邮编:314400
电话:18006836682
传真:0571-87399697
公司网址:
  • 在2020/6/14 17:03:00留言
  • 详细留言:光电转换器\TCF-142-S MOXA
  • 李宝强 在2014/2/17 15:34:00留言
  • 详细留言:MOXA EDS-408A-MM-SC交换机fault灯在不停地闪烁,交换机的地址也读取不到,请问一下可以修补,还有没有修的价值
