杭州微浪科技有限公司(MOXA一级代理, MOXA总代理)
  • 长春MOXA AWK-3131-M12-EU价格
  • 发布时间:2015/5/27 21:35:58   修改时间:2015/5/27 21:35:58 浏览次数:922
  • MOXA AWK-3131-EU
    支持-25~60℃标温操作,组合型RJ45&SFP接口,QMA
    以太网标准:IEEE 802.11a/b/g/n 适用于Wireless LANIEEE 802.11i适用于Wireless SecurityIEEE 802.3适用于10BaseTIEEE 802.3u适用于100BaseT(X)IEEE 802.3ab适用于1000BaseTIEEE 802.3af适用于Power-over-EthernetIEEE 802.1D 适用于Spanning Tree ProtocolIEEE 802.1w 适用于 Rapid STPIEEE 802.1Q适用于 VLAN扩频调制与速率 (典型产品):? DSSS with DBPSK, DQPSK, CCK? OFDM with BPSK, QPSK, 16QAM, 64QAM? 802.11b: CCK @ 11/5.5 Mbps, DQPSK @ 2 Mbps,DBPSK @ 11 Mbps? 802.11a/g: 64QAM @ 54/48 Mbps, 16QAM @ 36/24 Mbps,QPSK @ 18/12 Mbps, BPSK @ 9/6 Mbps? 802.11n: 64QAM @ 300 Mbps to BPSK @ 6.5 Mbps (multiplerates supported)工作频道 (central frequency):US:2.412 ~ 2.462 GHz (11频段)5.18 ~ 5.24 GHz (4频段)EU:2.412 ~ 2.472 GHz (13频段)5.18 ~ 5.24 GHz (4频段)JP:2.412 ~ 2.472 GHz (13频段, OFDM)2.412 ~ 2.484 GHz (14频段, DSSS)5.18 ~ 5.24 GHz (对于W52 , 4频段)安全:? SSID广播开闭功能? 基于MAC/IP/ 协议/ 端口过滤的防火墙技术? 64-bit and 128-bit WEP encryption, WPA /WPA2-Personal andEnterprise (IEEE 802.1X/RADIUS, TKIP and AES)数据速率:802.11b: 1, 2, 5.5, 11 Mbps802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps802.11n: 6.5 to 300 Mbps (multiple rates supported)TX发射功率:802.11b:1 to 11 Mbps: Typ. 18 dBm (± 1.5 dBm)802.11g:6 to 24 Mbps: Typ. 18 dBm (± 1.5 dBm)36 to 48 Mbps: Typ. 17 dBm (± 1.5 dBm)54 Mbps: Typ. 15 dBm (± 1.5 dBm)802.11a:6 to 24 Mbps: Typ. 17 dBm (± 1.5 dBm)36 to 48 Mbps: Typ. 16 dBm (± 1.5 dBm)54 Mbps: Typ. 14 dBm (± 1.5 dBm)TX 发射功率 MIMO:802.11a/n (20/40 MHz):MCS15 20 MHz: Typ. 13 dBm (± 1.5 dBm)802.11g/n (20 MHz):MCS15 20 MHz: Typ. 14 dBm (± 1.5 dBm)RX 灵敏度:802.11b: -92 dBm @ 1 Mbps, -90 dBm @ 2 Mbps, -88 dBm @5.5 Mbps, -84 dBm @ 11 Mbps802.11g: -87 dBm @ 6 Mbps, -86 dBm @ 9 Mbps, -85 dBm @12 Mbps, -82 dBm @ 18 Mbps, -80 dBm @ 24 Mbps, -76 dBm@ 36 Mbps, -72 dBm @ 48 Mbps, -70 dBm @ 54 Mbps802.11a: -87 dBm @ 6 Mbps, -86 dBm @ 9 Mbps, -85 dBm @12 Mbps, -82 dBm @ 18 Mbps,-80 dBm @ 24 Mbps, -76 dBm @ 36 Mbps, -72 dBm @ 48Mbps, -70 dBm @ 54 MbpsRX 灵敏度MIMO:802.11a/n:-68 dBm @ MCS15 40 MHz,-69 dBm @ MCS15 20 MHz,-70 dBm @ MCS7 40 MHz,-71 dBm @ MCS7 20 MHz802.11g/n:-69 dBm @ MCS15 20 MHz,-71 dBm @ MCS7 20 MHz协议一般协议支持: Proxy ARP, DNS, HTTP, HTTPS, IP, ICMP,SNTP, TCP, UDP, RADIUS, SNMP, PPPoE, DHCPAP协议支持:ARP, BOOTP, DHCP, STP/RSTP (IEEE 802.1D/w)接口默认天线:2个双频全向天线,2 dBi, RP-SMA (male)*仅适用于AWK-3131扩展天线连接:AWK-3131: RP-SMA (female)AWK-3131-M12: QMA (female)RJ45端口: 1, 10/100/1000BaseT(X) auto negotiation speed, F/Hduplex mode, and auto MDI/MDI-X connection (AWK-3131 only)Fiber端口: 1, 1000BaseSFP slot (AWK-3131 only)M12端口: 1, 10/100/1000BaseT(X) auto negotiation speed, F/H duplexmode, and auto MDI/MDI-X connection (AWK-3131-M12 only)控制端口:RS-232 (RJ45防水接口)LED指示灯:PWR1, PWR2, PoE, FAULT, STATE, signalstrength, WLAN, LAN报警触头(数字输出方式,M12连接器):1个继电器输出,负载能力1A @ 24 VDC数字输入: 2个共地隔离输入? 状态“1”:+13 ~ +30 V? 最大输入电流:8 mA机械特性外壳:IP68防护等级,金属材料重量: 970 g尺寸:53.6 x 135 x 105 mm (2.11 x 5.31 x 4.13 in)安装方式:壁挂安装(标准)、DIN导轨安装 (可选)、工作环境工作温度:标准模式: -25 ~ 60℃(-13 ~ 140°F)宽湿模式: -40 ~ 75℃ (-40 ~ 167°F)存储温度:-40 ~ 85℃ (-40 ~ 185°F)工作湿度:5% ~ 100% (无凝露)电源需求输入电压:12 ~ 48 VDC,冗余双直流电源输入或者48 VDC以太网供电 ( 兼容IEEE 802.3af)*24 VDC兼容EN 50155标准连接方式:10-pin removable terminal block电源功耗:12 ~ 48 VDC, 700 mA电源反接保护:有安规认证Safety: UL 60950-1, EN 60950-1EMC: EN 301 489-1/17, FCC Part 15 Subpart B, EN55022/55024Radio: EN 300 328, EN 301 893, DSPR (Japan)Rail Traffic: EN 50155, EN 50121-1/4注意: 请登录 Moxa 网站,获取最新认证信息。可靠性MTBF (平均无故障时间):AWK-3131: 388,581小时保修保修期:5 年
“成功会带来更多的成功。”这句话不仅是Moxa的公司哲学,同时也适用于Moxa的产品应用上。许多的客户已将Moxa产品成功地使用在许多串口通讯应用上,而好好地借重他们的成功经验也可让您在这个领域里一马当先。提供您数则大公司或中小企业如何应…  更多>>
联系人:施陈奕
地址:杭州文三路499
邮编:314400
电话:18006836682
传真:0571-87399697
公司网址:
  • 在2020/6/14 17:03:00留言
  • 详细留言:光电转换器\TCF-142-S MOXA
  • 李宝强 在2014/2/17 15:34:00留言
  • 详细留言:MOXA EDS-408A-MM-SC交换机fault灯在不停地闪烁,交换机的地址也读取不到,请问一下可以修补,还有没有修的价值
