南通正泰科技有限公司
  • 原装进口西门子产品
  • 发布时间:2010/8/16 10:48:41   修改时间:2010/8/16 10:48:41 浏览次数:2621
  • 原装进口西门子产品
    南通正泰科技有限公司
    电话:0513-85752553   0513-87111800
    传真: 0513-87111804
    联系人:周一能(销售部)
    手机:13773662679
    E-mail: my_ckc@yahoo.com
    公司网址:http://www.jszjgzt.cn/aboutme.asp
    _3WL1216-2CB36-4BJ2-Z  FIXED-MOUNTED CIRCUIT BREAKER  3-POLE, SIZE II, IEC IN="1600A"  TO 690V, AC50/60HZ ICU="100KA"  AT 500V FRNT.CONN. TOP/BOT.  DUAL-HOLE Z="A05"+K07
    3AH2115-2HK88-8KC0  VACUUM CIRCUIT-BREAKER 12KV, 2  POSITION SWITCHES, 2 SHUNT  TRIPS AND 2 UNDERVOLTAGE  RELEASES
    3DA1036-4CZ  Second function of  =BJ11+BJ01-Q01
    3DA1036-4C-Z  second function of  =BJ13+BJ01-Q01
    3DA1036-4C-Z%A36+E26  CIRCUIT BREAKER 3POLE, 12KV  L.2 1600A 31,5KA/1S 80KA  Z=A36, E26
    3DC1012-2L-Z  CIRCUIT BREAKER 3POLE, 12KV  L.2 630A 31,5KA/1S 80KA Z="A16",  E06
    3DC1012-2L-Z%A16+E06  DISCONNECT SWITCH 12KV Z="A16",  E06
    3DC1032-2L  second function of  =BL11+BL01-Q01
    3DC1032-2L-Z  second function of  =BI12+BI01-Q01
    3DC1032-2L-Z%A36+E26  CIRCUIT BREAKER 3POLE, 12KV  L.2 630A Z= A36, E26
    3DC1032-2L-Z%A36+E26  CIRCUIT BREAKER 3POLE, 12KV  L.2 630A 31,5KA/1S 80KA Z="A36",  E26
    3DC1032-3N-Z  Second function of =BK11 +BK01  "-Q01,
    3DC1032-3N-Z%A36+E26  CIRCUIT BREAKER 3POLE, 12KV  L.2 1250A Z= A36, E26
    3EF1036-0A  "SURGE SUPPRESSOR
    RATED VOLTAGE " UP TO 3,6KV
    3EF1072-0A  "SURGE SUPPRESSOR
    RATED VOLTAGE " UP TO 7,2KV
    3EF1120-0A  "SURGE SUPPRESSOR
    RATED VOLTAGE " UP TO 12KV
    3NA3220  LV HRC FUSE LINK GL/GG WITH  NON-INSULATED GRIP LUGS WITH  FRONT INDICATOR SIZE 2, 50A,  AC 500V/DC 440V
    3NA3236  LV HRC FUSE LINK GL/GG WITH  NON-INSULATED GRIP LUGS WITH  FRONT INDICATOR SIZE 2, 160A,  AC 500V/DC 440V
    3NA3244  LV HRC FUSE LINK GL/GG WITH  NON-INSULATED GRIP LUGS WITH  FRONT INDICATOR SIZE 2, 250A,  AC 500V/DC 440V
    3NA3260  LV HRC FUSE LINK GL/GG WITH  NON-INSULATED GRIP LUGS WITH  FRONT INDICATOR SIZE 2, 250A,  AC 500V/DC 440V
    3NJ4133-3BF01  IN-LINE FUSE SWITCH  DISCONNECTOR 3-POLE  SWITCHABLE, SIZE 2, I="400A" ,  U=690V, SCREW TERMINAL M 12  NEW DESIGN
    3RH1122-1AP00  CONTACTOR RELAY, 2NO+2NC, AC  230V, 50Hz, SCREW CONNECTION,  SIZE S00
    3RH1122-1BB40  CONTACTOR RELAY, 2NO+2NC, DC  24 V, SCREW CONNECTION, SIZE  S00
    3RH1122-1BB40_  CONTACTOR RELAY, 2NO+2NC, DC   24 V, SCREW CONNECTION, SIZE   S00
    3RH1140-1BB40  CONTACTOR RELAY, 4NO, DC 24 V,  SCREW CONNECTION, SIZE S00
    3RH1140-1BB40_  CONTACTOR RELAY, 2NO+2NC, DC   24 V, SCREW CONNECTION, SIZE   S00
    3RH1244-1BB40  CONTACTOR RELAY, 4NO+4NC, W.  PERMANENT. JOINTED AUXILIARY  SWITCH BLOCK 24V DC, SIZE S00,  SCREW CONNECTION, SIZE S00
    3RH1262-1AP00  CONTACTOR RELAY, 4NO+4NC, W.   PERMANENT. JOINTED AUXILIARY   SWITCH BLOCK 24V DC, SIZE S00,   SCREW CONNECTION, SIZE S00
    3RH1262-1BB40  CONTACTOR RELAY, 6NO+2NC, W.  PERMANENT. JOINTED AUXILIARY  SWITCH BLOCK 24V DC, SIZE S00,  SCREW CONNECTION, SIZE S00
    3RH1911-1FC22  AUXILIARY SWITCH BLOCK, , 22,  2NO+2NC 2U, DIN EN50005, SCREW  CONNECTION, F. CONTACTOR  RELAYS A. CONTACT. FOR  SWITCHING MOTORS, SIZE S00
    3RH1911-1GA22  AUXILIARY SWITCH BLOCK, 62E,  2NO+2NC, DIN EN50011, SCREW  CONNECTION, FOR CONTACTOR  RELAYS, 4-POLE
    3RH1921-1FA22  MOUNTING BLOCK DIN EN 50005,  4-POLE,2NO+2NC
    3RH1921-2DE11  ELECTRONIC AUXILIARY SWITCH  DIN EN 50012 LATERAL, CAGE  CLAMP CONN. 1NO+1NC, SEALED,  SIZE S0...S3
    3RP1531-1AP30  TIME RELAY, OFF-DELAY W.  AUXIL. SW.,1 C, 0.5 S...10 S  AC 24,200...240 V AND DC 24 V,  WITH LED
    3RT1015-1BB41  CONTACTOR, AC-3 3 KW/400 V, 1  NO, DC 24 V, 3-POLE, SIZE S00,  SCREW CONNECTION
    3RT1025-1BB44-3MA0_  CONTACTOR, AC-3: 7.5 KW/400 V  2 NO + 2 NC, PERMANENT.  JOINTED
    3RT1025-1BB44-3MA0__  CONTACTOR, AC-3: 7.5 KW/400 V  2 NO + 2 NC, PERMANENT.  JOINTED
    3RT1026-1AP04  CONTACTOR, AC-3 11 KW/400 V,  AC 230 V, 50 HZ, 3-POLE, 2 NO  + 2 NC, SIZE S0, SCREW  CONNECTION
    3RT1034-1AP04  CONTACTOR, AC-3 15 KW/400 V,  AC 230 V, 50 HZ, 2 NO + 2 NC  3-POLE, SIZE S2, SCREW  CONNECTION
    3RT1034-1BB44  CONTACTOR, AC-3 15 KW/400 V,  DC 24 V, 3-POLE, 2 NO + 2 NC,  SIZE S2, SCREW CONNECTION
    3RT1036-1AP00  CONTACTOR, AC-3 22 KW/400 V,  AC 230 V, 50 HZ, 3-POLE, SIZE  S2, SCREW CONNECTION
    3RT1044-1BB44  CONTACTOR, AC-3 30 KW/400 V,  DC 24 V, 2 NO + 2 NC 3-POLE,  SIZE S3, SCREW CONNECTION
    3RT1055-6AP36  CONTACTOR, 75KW/400V/AC-3,  AC(40...60HZ)/DC OPERATION UC  220...240V AUXIL. CONTACTS  2NO+2NC 3-POLE, SIZE S6 BAR  CONNECTIONS CONVENTIONAL  OPERATING MECHAN. SCREW  TERMINAL
    3RT1916-1BD00  CONTACTOR, AC-3: 7.5 KW/400 V   2 NO + 2 NC, PERMANENT.   JOINTED
    3RT1916-1DG00  SUPPRESSION DIODE, DC 12...250  V, SURGE SUPPRESSOR, FOR  MOUNTING ONTO CONTACTORS  SIZES00
    3RT1926-1BB00  VARISTOR, AC 24...48V, DC  24...70V, SURGE SUPPRESSOR,  FOR MOUNTING ONTO CONTACTORS  SZ. S0, S2, S3
    3RT1926-1BD00  VARISTOR, AC 127...240V, DC  150...250V, SURGE SUPPRESSOR,  FOR MOUNTING ONTO CONTACTORS  SZ. S0...S3
    3RV1011-0HA15  CIRCUIT-BREAKER, SIZE S00, FOR  MOTOR PROTECTION, CLASS 10, A  REL.0.55...0.8A, N REL. 10A,  SCREW CONNECTION, STANDARD  BREAKING CAPACITY W. TRANSV.  AUX. SWITCH 1NO/1NC
    3RV1011-1BA15  CIRCUIT-BREAKER, SIZE S00, FOR  MOTOR PROTECTION, CLASS 10, A  REL. 1.4...2A, N REL. 26A,  SCREW CONNECTION, STANDARD  BREAKING CAPACITY W. TRANSV.  AUX. SWITCH 1NO/1NC
    3RV1021-1EA15_  CIRCUIT-BREAKER, SIZE S0, FOR  MOTOR PROTECTION, CLASS 10, A  REL.2.8A...4.0A, N REL.52A,  SCREW CONNECTION, STANDARD  BREAKING CAPACITY W. TRANSV.  AUX. SWITCH 1NO/1NC
    3RV1021-1HA15_  CIRCUIT-BREAKER, SIZE S0, FOR  MOTOR PROTECTION, CLASS 10, A  REL.5.5...8 A, N REL.104 A,  SCREW CONNECTION, STANDARD  BREAKING CAPACITY, W. TRANSV.  AUX. SWITCH 1NO/1NC
    3RV1021-4CA15_  CIRCUIT-BREAKER, SIZE S0, FOR  MOTOR PROTECTION, CLASS 10, A  REL.17...22 A, N REL.286 A,  SCREW CONNECTION, STANDARD  BREAKING CAPACITY
    3RV1031-4EA10  CIRCUIT-BREAKER SIZE S2. FOR  MOTOR PROTECTION, CLASS 10,  A-REL. 22...32A, N-REL. 416A,  SCREW TERMINAL, STANDARD  SWITCHING CAPACITY
    3RV1031-4GA10  CIRCUIT-BREAKER 36...45 A,  N-RELEASE 585 A, SIZE S2,  MOTOR PROTECTION CLASS 10  SCREW CONNECTION STANDARD  BREAKING CAPACITY
    3RV1611-1AG14  CIRCUIT-BREAKER, SIZE S00, FOR   MOTOR PROTECTION, CLASS 10, A   REL. 1.4...2A, N REL. 26A,   SCREW CONNECTION, STANDARD   BREAKING CAPACITY W. TRANSV.   AUX. SWITCH 1NO/1NC
    3RV1901-1E  AUXIL. SWITCH, TRANSVERSE 1NO  + 1NC, F. CIRCUIT-BREAKER,  SIZE S00,S0,S2,S3
    3SB3000-0AA11  SAFETY POS. SWITCH W. SEPARATE  ACTUATOR,PLASTIC ENCLOSURE,  31MM; 1X(M20X1.5) SLOW-ACTION  CONTACTS 1NO+2NC, 5 DIRECTIONS  OF APPROACH, THE MATCHING  SEPARATE ACTUATOR  3SE5000-0AV0. IS TO BE ORDERED  SEPARATELY
    3SB3000-0AA51  22MM PLASTIC ROUND ACTUATOR:  PUSHBUTTON WITH FLAT BUTTON  WITH HOLDER BLUE
    3SB3000-4LD01  22MM PLASTIC ROUND ACTUATOR:  CES KEY-OPER.SWITCH WITH 2  KEYS 2 SWITCH POSITIONS O-I  LATCHING LOCK NO SSG 10,  REMOVAL POS. O WITH HOLDER
    3SB3000-4MF11  22MM PLASTIC ROUND ACTUATOR:  CES KEY-OPER.SWITCH WITH 2  KEYS 2 SWITCH POSITIONS O-I  MOMENTARY CONTACT TYPE LOCK NO  LSG 1, REMOVAL POS. O WITH  HOLDER
    3SB3100-8CC21  22MM PLASTIC ROUND ACTUATOR:  TWIN PUSHBUTTON WITH FLAT +  RAISED BUTTON NON-ILLUMINATED  WITH HOLDER GREEN-RED  INSCRIPTION GREEN: I; RED: O
    3SB3201-0AA11  22MM PLASTIC ROUND COMPLETE  UNIT COMBINATION: PUSHBUTTON  WITH FLAT BUTTON SCREW  TERMINAL, 1NO+1NC WITH HOLDER  BLACK
    3SB3201-2KA11  22MM PLASTIC ROUND COMPLETE  UNIT COMBINATION: SELECTOR  SWITCH LATCHING 2 SWITCH  POSITIONS O-I NON-ILLUMINATED  SCREW TERMINAL, 1NO+1NC WITH  HOLDER BLACK
    3SB3244-6AA60  22MM PLASTIC ROUND COMPLETE  UNIT COMBINATION: INDICATOR  LIGHT WITH SMOOTH LENSE  ILLUMINATED WITH INTEGRATED  LED 24V AC/DC SCREW TERMINAL  WITH HOLDER WHITE
    3SB3245-0AA71  22MM PLASTIC ROUND COMPLETE  UNIT COMBINATION: ILLUMINATED  PUSHBUTTON MOMENTARY CONTACT  TYPE WITH FLAT BUTTON  ILLUMINATED WITH INTEGRATED  LED 24V AC/DC SCREW TERMINAL,  1NO WITH HOLDER CLEAR
    3SB3400-0A  ACTUATOR-/INDICATOR COMPONENT  CONTACT BLOCK WITH 2 CONTACTS  SCREW TERMINAL, 1NO+1NC
    3SB3400-0B  ACTUATOR-/INDICATOR COMPONENT  CONTACT BLOCK WITH 1 CONTACT  ELEMENT SCREW TERMINAL, 1NO
    3SB3400-0C  ACTUATOR-/INDICATOR COMPONENT  CONTACT BLOCK WITH 1 CONTACT  ELEMENT SCREW TERMINAL, 1NC
    3SB3902-1XZ  BACKING PLATE LABEL SIZE 12.5  X 27 MM WITH CUSTOM MADE  INSCRIPTION  Auxiliary Voltage  on
    3SB3902-1XZ  BACKING PLATE LABEL SIZE 12.5  X 27 MM  WITH CUSTOM MADE  INSCRIPTION Disconnect-                       Switch on/off
    3SB3902-1XZ  BACKING PLATE LABEL SIZE 12.5  X 27 MM  WITH CUSTOM MADE  INSCRIPTION Grounding-                       Switch on/off
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Grounding-
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Key switch
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Current
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Current Lower
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Lamp Test
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Voltage
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Voltage Lower
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Main
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  High voltage
    3SB3902-1XZ.K0Y  INSCRIPTION ACTUATOR/INDICATOR  ON LABEL HOLDER INSCRIPTION  LABEL FOR STICKING = BACKING  PLATE LABEL SIZE 12.5 X 27 MM  WITH CUSTOM MADE INSCRIPTION  ACC.TO ORDER FORM SUPPLEMENT  BLACK WITH WHITE PRINT  UPPER/LOWER CASE  Disconnect-
    3SB3922-0AV  INSCRIPTION ACTUATOR/INDICATOR  FLAT LABEL HOLDER FOR  INSCRIPTION LABEL FOR STICKING  LABEL SIZE 12.5 X 27 MM BLACK
    3SB3922-0AY  INSCRIPTION ACTUATOR/INDICATOR  TWIN PUSHBUTTON FOR FLAT LABEL  HOLDER FOR INSCRIPTION LABEL  FOR STICKING LABEL SIZE 12.5 X  27 MM BLACK
    3SE5000-0AV01  SEPARATE STANDARD ACTUATOR FOR  POS. W. TUMBLER  3SE5312../3SE5322.. AND ASI  3SF13... AND POS. WITH  SEPARATE ACTUATOR  3SE51../3SE52.. AND ASI  3SF11../3SF21..
    3SE5232-0QV40  SAFETY POS. SWITCH W. SEPARATE  ACTUATOR,PLASTIC ENCLOSURE,  31MM; 1X(M20X1.5) SLOW-ACTION  CONTACTS 1NO+2NC, 5 DIRECTIONS  OF APPROACH, THE MATCHING  SEPARATE ACTUATOR  3SE5000-0AV0. IS TO BE ORDERED  SEPARATELY
    3TH2022-0AP0  CONTACTOR RELAY 22E EN 50 011  2NO+2NC, SCREW TERMINALS AC  OPERATION AC 230/220V 50HZ,  276/264V 60HZ
    3TK2828-1BB40  SIRIUS SAFETY RELAY WITH RELAY  RELEASE CIRCUITS (FK), 24V DC,  45.0MM, SCREW TERMINAL, FK  INSTANT.: 2S, FK DELAYED: 2S  0.5...30S, MK: 1OE, AUTOSTART,  BASIC UNIT, MAX. CATEGORY: 4
    3TK2830-1CB30  SIRIUS SAFETY RELAY WITH RELAY  RELEASE CIRCUITS (FK), 24V  AC/DC, 22.5MM, SCREW TERMINAL,  FK INSTANT.: 4S, FK DELAYED:  0, MK: 0, EXPANSION UNIT, MAX.  CATEGORY: AS G
    3TL6515-1AL2-Z  VACUUMCONTACTOR 400A 12KV  4S+3O AC 50/60HZ 230V
    3UG4512-1AR20  ANALOG MONITORING RELAY PHASE  FAILURE AND -SEQUENCE 3X 160  TO 690V AC 50 TO 60 HZ 1  CHANGEOVER CONTACT SCREW  TERMINAL
    3VF3211-5ES71-0AA0  CIRCUIT-BREAKER, 3-POLE FOR  MOTOR PROTECTION IR="100-160A",  ICU=40KA/415V WITH OVERCURRENT  RELEASE AN N-REL. 15 X IN,  FIXED-MOUNTED TRIP CLASS  ADJUSTABLE WITH PHASE-FAILURE  SENSITIVITY W/O AUXIL.  CONTACT/ALARM SWITCH W/O
    3WL1106-3CB34-4BJ2-Z  FIXED-MOUNTED CIRCUIT BREAKER  3-POLE, SIZE I, IEC IN="630A" TO  690V, AC50/60HZ ICU="66KA" AT  500V FRNT.CONN. TOP/BOT.  DUAL-HOLE  Z="K07"
    3WL1106-3CB36-4BJ4  WITHDRAWABLE CIRCUIT BREAKER  WITH GUIDE FRAME 3-POLE, SIZE  I, IEC IN="630A" TO 690V,  AC50/60HZ ICU="66KA" AT 500V  REAR CONNECTION HORIZONTAL
    3WL1106-3CB36-4BJ4  FIXED-MOUNTED CIRCUIT BREAKER  3-POLE, SIZE I, IEC IN="630A" TO  690V, AC50/60HZ ICU="66KA" AT  500V FRNT.CONN. TOP/BOT.  DUAL-HOLE  Z="K07", B04
    3WL1208-4CB32-4BJ4-Z  FIXED-MOUNTED CIRCUIT BREAKER  3-POLE, SIZE II, IEC IN="800A"  TO 690V, AC50/60HZ ICU="100KA"  AT 500V FRNT.CONN. TOP/BOT.  DUAL-HOLE, Z="A05" + KL07 + B06
    3WL1210-4CB36-4BJ4-Z  WITHDRAWABLE CIRCUIT BREAKER  WITH GUIDE FRAME 3-POLE, SIZE  II, IEC IN="1000A" TO 690V,  AC50/60HZ ICU="100KA" AT 500V  REAR CONNECTION HORIZONTAL  Z=A05
    4EP3700-2US00  MAINS CHOKE F.FU; PHASES:3;  UN1(V):480; ITHMAX 1(A) /  F1(HZ):35,5 /60; I LN  (A):31,95; UK(%):2;  LN(MH):0,397; TA/ISOKL:40 /B;  IP00; TYPE OF TERMINALS:SCREW  CONNECTION; EN 61558-2-20  >UL/CSA-RECOGNIZED< >CHOKE<
    4MA72_XD  CURRENT TRANSFORMER 400/1A,  RITZ
    4UA3632-5AF10-2AA0  SIRIUS SAFETY RELAY WITH RELAY   RELEASE CIRCUITS (FK), 24V   AC/DC, 22.5MM, SCREW TERMINAL,   FK INSTANT.: 4S, FK DELAYED:   0, MK: 0, EXPANSION UNIT, MAX.   CATEGORY: AS G
    4UB4342-2AM20-2DA0  PERFORMANCE TRANSFORMATOR 3~  400V v/ 690 V 20KVA
    5SE2310  NEOZED FUSE LINK 400V GL, SIZE  D01, 10A IN FOLDING BOX
    5SE2316  NEOZED FUSE LINK 400V GL, SIZE  D01, 16A IN FOLDING BOX
    5SE2325  NEOZED FUSE LINK 400V GL, SIZE  D02, 25A IN FOLDING BOX
    5SE2350  NEOZED FUSE LINK 400V GL, SIZE  D02, 50A IN FOLDING BOX
    5SE2363  NEOZED FUSE LINK 400V GL, SIZE  D02, 63A IN FOLDING BOX
    5SG7133  N-TYPE MINIZED FUSE SWITCH FOR  NEOZED FUSE LINKS D02, 3-POLE,  D=70 MM DRAW-OUT ASSEMBLY
    5ST3010  HILFSSTROMSCHALTER  1S + 1?         FUER LS-SCHALTER
    5ST3733  PIN BUSBAR SHOCKPROOF, 10 SQMM  1-PHASE+HS, 1016 MM LONG  WITHOUT END CAPS
    5ST3748  END CAP FOR PIN BUSBARS  1-PHASE
    5SU1356-6KK06  FI/LS-PROTECTOR TYPE A  (PSE/SSF), D="70MM" IFN  30MA,6KA, 1+N-POLEE B 6A
    5SY4102-7  CIRCUIT BREAKER 230/400V 10KA,  1-POLE, C, 2A, D="70MM"
    5SY4104-7  CIRCUIT BREAKER 230/400V 10KA,  1-POLE, C, 4A, D="70MM"
    5SY4106-7  CIRCUIT BREAKER 230/400V 10KA,  1-POLE, C, 6A, D="70MM"
    5SY4110-7  CIRCUIT BREAKER 230/400V 10KA,  1-POLE, C, 10A, D="70MM"
    5SY4116-7  CIRCUIT BREAKER 230/400V 10KA,  1-POLE, C, 16A, D="70MM"
    5SY4202-7  CIRCUIT BREAKER 400V 10KA,  2-POLE, C, 2A, D="70MM"
    5TT3421  PHASE MONITOR, N-TYPE AC230V  4A
    6ES7153-1AA03-0XB0  SIMATIC DP, INTERFACE IM  153-1, FOR ET 200M, FOR MAX. 8  S7-300 MODULES
    6ES7307-1EA00-0AA0  SIMATIC S7-300,LOAD POWER  SUPP. PS 307, 120/230 V AC, 24  V DC, 5 A
    6ES7315-2EH13-0AB0  SIMATIC S7-300 CPU 315-2  PN/DP, CENTRAL PROCESSING UNIT  WITH 256 KBYTE WORKING MEMORY,  1. INTERFACE MPI/DP 12MBIT/S,  2. INTERFACE ETHERNET  PROFINET, MICRO MEMORY CARD  NECESSARY
    6ES7321-1BL00-0AA0  SIMATIC S7-300, DIGITAL INPUT  SM 321, OPTICALLY ISOLATED  32DI, 24 V DC, 40 PIN
    6ES7322-1BL00-0AA0  SIMATIC S7-300, DIGITAL OUTPUT  SM 322, OPTICALLY ISOLATED, 32  DO, 24V DC, 0.5A, 40 PIN, SUM  OF OUTPUT CURRENTS 4A/GROUP  (16A/MODULE)
    6ES7331-7KF02-0AB0  SIMATIC S7-300, ANALOG INPUT  SM 331, OPTICALLY ISOLATED,  U/I/THERMOCOUPLE/RESISTANCE  INTERRUPT, DIAGNOSTICS;  RESOLUTION 9/12/14 BITS, 8AI,  REMOVE/INSERT W. BACKPLANE  BUS, 20 PIN
    6ES7331-7PF01-0AB0  SIMATIC S7-300, ANALOG INPUT  SM 331, OPT. ISOL.,2/3/4 WIRE,  8AI, RESISTANCE,  PT100/200/1000  NI100/120/200/500/1000, CU10,  PLUS CHARACTERISTICS ACCORDING  TO GOST STANDARD 16 (INTERN  24) BIT, 50MS,40 PIN
    6ES7390-1AE80-0AA0  SIMATIC S7-300, RAIL L="480MM"
    6ES7390-1AF30-0AA0  SIMATIC S7-300, RAIL L="530MM"
    6ES7392-1AJ00-0AA0  SIMATIC S7-300, FRONT  CONNECTOR FOR SIGNAL MODULES  WITH SCREW CONTACTS, 20-PIN
    6ES7392-1AM00-0AA0  SIMATIC S7-300,FRONT CONNECTOR  392 WITH SCREW CONTACTS,  40-PIN
    6ES7953-8LG11-0AA0  SIMATIC S7, MICRO MEMORY CARD  F. S7-300/C7/ET 200S IM151  CPU, 3.3 V NFLASH, 128 KBYTES
    6ES7972-0BB41-0XA0  SIMATIC DP, BUS CONNECTOR FOR  PROFIBUS UP TO 12 MBIT/S WITH  TILTED OUTGOING CABLE, 15,8 X  54 X 39,5 MM (WXHXD),  TERMINAT. RESIST. WITH ISOLAT.  FUNCTION, WITH PG SOCKET
    6ES7972-0BB50-0AA0  SIMATIC DP,BUS CONNECTOR FOR  PROFIBUS UP TO 12 MBIT/S 90  DEGREE ANGLE OUTGOING  "CABLE,
    15,8 X 72,2 X 36,4 MM " "(BXHXT),
    TECHOLOGY FAST " CONNECT, WITH PG SOCKET
    6ES7972-0BB50-0XA0  SIMATIC DP, BUS CONNECTOR FOR  PROFIBUS UP TO 12 MBIT/S 90  DEGREE ANGLE OUTGOING CABLE,  15,8 X 72,2 X 36,4 MM (WXHXD),  IPCD TECHOLOGY FAST CONNECT,  WITH PG SOCKET
    6GK1500-3AA00  SIMATIC NET, PROFIBUS OBT OPT.  BUS TERMINAL FOR CONNECT. OF A  PROFIBUS STATION W/O INTEGR.  OPT. INTERFACE TO THE OPT.  PROFIBUS DP, W/O SIMPLEX  CONNECTORS
    6RA7028-6DV62-0  SIMOREG DC MASTER CONVERTER  WITH MICROPROCESSOR FOR  FOUR-QUADRANT DRIVES  CONNECTION (B6) A (B6) C  INPUT: 3-PHASE AC 400V, 75A  CONTROLLABLE  FIELD RECTIFIER  D420/90 MREQ-GEG6V62 OUTPUT:  DC 420V,     90A OUTPUT
    6SE7023-4EC61  SIMOVERT MASTERDRIVES VECTOR  CONTROL CONVERTER COMPACT  UNIT, IP20 3 380-480V AC,  50/60HZ, 34 A NOM. POWER  RATINGS: 15KW DOCUMENTATION ON  CD
    6SE7023-4ES87-0FB1  SIMOVERT MASTERDRIVES VECTOR  CONTROL/MOTION CONTROL RADIO  INTERF. SUPPR. FILTER B1 3-PH.  380-460 V, 50/60 HZ, 36 A
    6SE7023-4ES87-1FE0  SIMOVERT MASTERDRIVES OUTPUT  REACTOR FMAX = 300HZ, FP =  3KHZ 3 380-460V AC 34A
    7KG6106-2EN27-0B  "SIMEAS-TRANSDUCER (G)MUU
    FOR " ALTERNATING CURRENT, INPUT  VOLTAGE AC 100V, OUTPUT SIGNAL  "DC 4 TILL 20MA
    RATED FREQUENZY " "50HZ
    AC 45 - 65HZ, 230V "
    7KG6113-2AN27-0B  "SIMEAS-TRANSDUCER (G)MUI
    FOR " ALTERNATING CURRENT, INPUT  CURRENT 1A, OUTPUT SIGNAL DC 4  "TILL 20MA
    7KG7755-0AA00-0AA0  SIMATIC NET, PROFIBUS OBT OPT.   BUS TERMINAL FOR CONNECT. OF  A  PROFIBUS STATION W/O  INTEGR.  OPT. INTERFACE TO THE  OPT.  PROFIBUS DP, W/O SIMPLEX   CONNECTORS
    8WA1011-6EG44  ZENER DIODE TERMINAL, 6,5MM,  SIZE 4
    8WD4308-0DA  SIGNAL COLUMNS, DIAMETER 70MM  ACCESSORIES BASE WITH TUBE  (100MM)
    8WD4408-0AB  SIGNALLING COLUMN CONNECT.  ELEMENT FOR WITH BASE  MOUNT./ANGLE MOUNT. COVER LID  AND SEAL FOR SCREW CONNECTION
    8WD4420-5AC  SIGNALLING COLUMN STEADY LIGHT  LED GREEN, 24V AC/DC
    8WD4420-5DB  SIGNALLING COLUMN  ROTATING-BEACON RED, 24V AC/DC
    BBBBBB  SWITCH CABINET LIGHTING
    DG_T_275FM  DEHNguard  OVERVOLTAGE  PROTECTION DEVICE
    E.M.OFF  Emergency OFF pushbutton
    E.M.-OFF  Emergency OFF pushbutton
    GOSS:M01281-B9100  CHANGE OVER TELLTALE 24V DC,  32/36MM FABR. GOSSEN
    GSE_20  VOLTAGE TRANSFORMER, RITZ
    GSES_12_D  VOLTAGE TRANSFORMER GSES 12 D     3000V/100V, RITZ
    GSES_24_D  VOLTAGE TRANSFORMER GSES 24 D     12000V/100V, RITZ
    GSWS_12_D_GR._2  CURRENT TRANSFORMER, RITZ
    GSWS_12G_GR1  CURRENT TRANSFORMER SWITCHABLE
    KALTLEITERGER腡  ZIEHL TYPE:MS220C NR. T221804  AC 230-240V 50-60HZ P<2VA
    KALTLEITER-RELAIS  ZIEHL TYPE:MSF220K NR.:T221716  AC220-240V P>2VA
    KLEMME_L  THROUGH-TYPE TERMINAL L  ADAPT  SIZE TO CONDUCTOR  DIAMETER
    KLEMME_N  THROUGH-TYPE TERMINAL N ADAPT  SIZE TO CONDUCTOR  DIAMETER
    KLEMME_PE  THROUGH-TYPE TERMINAL PE   ADAPT SIZE TO CONDUCTOR   DIAMETER
    LZS:PT5A5L24  PLUG-IN RELAY COMPLETE UNIT DC  24V, 4 CO CONTACT LED MODULE  RED STANDARD PLUG-IN SOCKET  SCREW TERMINAL 3.5 MM PINNING
    LZS:PT5A5L24_  PLUG-IN RELAY COMPLETE UNIT DC  24V, 4 CO CONTACT LED MODULE  RED STANDARD PLUG-IN SOCKET  SCREW TERMINAL 3.5 MM PINNING
    LZS:RT4A4L24  PLUG-IN RELAY COMPACT UNIT DC  24V, 2 CO CONTACT LED MODULE  RED STANDARD PLUG-IN SOCKET  SCREW TERMINAL
    MENNEKES_1463  ELECTRICAL SOCKET 20?MENNEKES  230V 16A3-POLE IP44
    MENNEKES_1500  ELECTRICAL SOCKET 20?MENNEKES  400V 32A 5_POLE 6H IP44
    MENNEKES_2764A  ELECTRICAL SOCKET20?MENNEKES  690V 32A 5-POLE5H IP44
    RITZ_PTT10  VOLTAGE TRANSFORMER RITZ PTT10
    RT18-32  FUSE HOLDER from Yueqing Smico  Electrical Co. , Ltd.., 690V,  50 Hz AC, 32 A
    RT18-63  FUSE HOLDER from Yueqing Smico  Electrical Co. , Ltd.., 690V,  50 Hz AC, 63 A
    SU60664AA00  STATIC USV MASTERGUARD E  "100
    CLASS VFI-SS-111 (IEC " "62040-3)
    WITH BUILT-IN " "BATTERY
    INPUT
    1-PHASE 230V " (176V-276V) 1ACN  "(TN)
    OPTIONALLY " "(AUTOSELECTION)
    3-PHASE 400V " (304V-478V) 3ACN (TN)
    SU64134PN00  "BATTERYPACK
    FOR USV " MASTERGUARD E 60 OR E  "100
    BATTERY
    CLOSED, " "UNATTENDET
    VRLA LEAD BATTERY "
    TABB10B500+ATADIN03  IME-TRANSFORMER 50/1A WITH  RAIL MOUNTING
    TAIC10C400  IME BUS BAR PRIMARY  SINGLE-PHASE CURRENT  TRANSFORMER 30 x 10MM
    TAIG10C600  IME BUS BAR PRIMARY  SINGLE-PHASE CURRENT  TRANSFORMER 600 / 1A FOR RAIL   40 x 10MM
    TERMINAL_L  THROUGH-TYPE TERMINAL L BLACK   ADAPT SIZE TO CONDUCTOR  DIAMETER
    TERMINAL_M  THROUGH-TYPE TERMINAL L BLACK    ADAPT SIZE TO CONDUCTOR   DIAMETER
    TERMINAL_N  THROUGH-TYPE TERMINAL N BLUE,  ADAPT SIZE TO CONDUCTOR   DIAMETER
    TERMINAL_PE  THROUGH-TYPE TERMINAL PE  GREEN-YELLOW,  ADAPT SIZE TO  CONDUCTOR DIAMETER
    TRANSFORMER_TERMINAL  MEASURING TRANSFORMER TERMINAL  4QMM
    VIBREX  VARISTOR, AC 127...240V, DC  150...250V, SURGE SUPPRESSOR,  FOR MOUNTING ONTO CONTACTORS  SZ. S0...S3
南通正泰科技有限公司
联系人:周一能
地址:南通正泰科技有限公司
邮编:226006
电话:0513-87111800
传真:0513-87111804
公司网址:
  • 蒋杰 在2023/7/20 15:48:00留言
  • 详细留言:询价西门子1PH8911-7BA55-0AAO 编码器套件
  • 王力 在2015/3/17 11:40:00留言
  • 王小进 在2012/12/21 11:44:00留言
  • 详细留言:我公司目前使用多台三菱的Q系列PLC及相关的输入输出模块,三菱的GOT,另外还有欧姆龙的PLC,望能提供贵司能够提供的相关备品配件的清单,谢谢
  • 潘建帮 在2012/7/27 10:13:00留言
  • 详细留言:安全栅 资料
  • 张玉洲 在2012/5/4 22:47:00留言
  • 详细留言:输入380V隔爆兼本质安全型电器控制箱,输出交流380V,36V,直流24V需要配置的安全栅资料
