我公司所有的产品直接从境外进货,能够提供不同国别、厂商的设备配件,
解决您多处寻找的麻烦和对产品质量的担心等,在价格上我们有很大的优势,
欢迎来电咨询,我们将会给您最优质的服务!
产品详细信息,欢迎来电查询!
只要是您想要的,我都能帮您找到!价格从优!
你急需的产品,请联系我们!
你询不到的产品,请联系我们!
你买不到的产品,请联系我们!
厦门兴锐达自动化设备有限公司
地址:厦门市嘉禾路488号(怡鹭大厦)之三号806室
黄文(销售工程师)
电话:0592-5580703
邮箱:muin33442@sina.com
手机:15260210205
QQ:763119904
主营产品,优势供应,充足库存:
HHCTS 1
5D32046G02 Drive Assy VME Disk Assy 1.3GB Disk Assy (w/ Fugitsu drive) 4
5D32046G08 Drive Assy VME Disk Assy 1.3GB Disk Assy (w/ Quantum 1225S drive) 3
5D32046G09 Drive Assy
VME Disk Assy 5.2GB Disk Assy (w/ 4ea Quantum 1225S
drives) 1
5D32052G01 VME Card Cage VME Card Frame (on inside, side of chassis) 4
5D32052G05 VME Card Cage VME Card Frame (on inside, side of chassis) 3
5D32114G01 Chassis Dual card racks of 386 WEStation DPU 18
5D32115G01 Cabinet I/O Quad Cabinet - 486 WEStation DPU 4
5D32122G02 Chassis
Top bar w/ cables on 386 WEStation DPU (on 5D32114G01
Chassis) 22
5D32123G01 Panel AC/DC Power Distribution Panel 3
5D32123G02 Panel AC/DC Power Distribution Panel 10
5D32123G03 Panel AC/DC Power Distribution Panel 1
5D32149G01 Chassis 486 WEStation DPU card cage 34
5D32161G01 Chassis 486 WEStation DPU chassis assy 28
5D32161G02 Chassis 486 WEStation DPU chassis assy 20
5D32191G01 Power Supply
MultiBus P/S MPS512-PFC for 486 WS DPU w/ 3A99116G01
MDPS 115VAC 85
5D32191G02 Power Supply
MDPS 230VAC 74
5D92481G06 Power Supply HC Power Inc HS1244-C1353 0
5D92830G01 Relay Panel Form C, KUEP, 16 fuses (for H/S assembly) 8
5D92848G01 Transceiver
Ethernet 10Mbit/sec Transceiver unit (MAU) - Ethernet Tap
Bracket Assy 20
5X00006H12 Cartridge Travan 20GB Tape Cartridge 3
5X00058G01 Analog Module Ovation Hart Analog Output Module 1
5X00059G01 Analog Module Ovation Hart Analog Input Module 1
5X00062G01 Analog Module Ovation Hart Analog Output Module 1
5X00063G01 Analog Module Ovation Hart Analog Output Module 1
5X00082H12 Cartridge Sony 1/2 Data Cartridge 4
5X00105G01 Board Ovation Control Board 2
5X00117H02 Keyboard SUN UNIX (US) Type 6 Keyboard and Mouse 5
5X00117H03 Keyboard SUN USB Type 6 Keyboard and Mouse 5
5X00117H04 Memory 256MB DRAM Expansion For Sun Blade 100 5
5X00117H06 Drive Hard Disk 20GB EIDE for Sun Blade 100 5
5X00128G01 Monitor 22/20" NEC CRT (20.1" LCD replacement solution) 5
5X00134G01 Sun Workstation
SUN Microsystems Blade 100 (configured to customer spec w/
or w/o PGI) 5
5X00134G02 Sun Workstation
SUN Microsystems Blade 150 (configured to customer spec w/
or w/o PGI) 5
5X00178G01 Monitor 20.1" LCD Monitor 5
5X00230G01
1P00049G01 2QOL QOL G01 card 2
5X00286H13 Mouse 2-button Optical corded USB mouse 1
5X00290G01 Monitor 21/20" NEC CRT (20.1" LCD replacement solution) 5
7379A06G02
7379A06G82 2QCI13 QCI G02 Contact Closure Input card 1
7379A06G02 3QCI1 QCI G02 Contact Closure Input card 1
7379A06G02 3QCI3 QCI G02 Contact Closure Input card 1
7379A06G02 4QCI2 QCI G02 Contact Closure Input card 42
7379A06G02 4QCI3 QCI G02 Contact Closure Input card 2
7379A06G02 4QCI4 QCI G02 Contact Closure Input card 15
7379A06G02
3A99160G02 6QCI1 QCI G02 Contact Closure Input card 114
7379A13G01 QPA QPA G01 Pulse Accumulator card 0
7379A13G04 6QPA8 QPA G04 Pulse Accumulator card 48V sub Y 4
7379A21G01 5QAV4 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 1
7379A21G01 5QAV9 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 1
7379A21G01 5QAV14 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 9
7379A21G01 5QAV19 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 10
7379A21G01 6QAV16 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 7
7379A21G01
3A99164G01 8QAV1 QAV G01 Analog Input Point card - -5 to +20mVDC, 500ohm 7
7379A21G02 5QAV20 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 4
7379A21G02 6QAV12 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 18
7379A21G02 6QAV17 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 33
7379A21G02
3A99164G02 8QAV2 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 75
7379A21G02
3A99164G02
3A99164G50 8QAV4 QAV G02 Analog Input Point card - -12.5 to +50mVDC, 500ohm 9
7379A21G03 5QAV21 QAV G03 Analog Input Point card - -25 to +100mVDC, 1Kohm 1
7379A21G03
3A99164G03
3A99164G50 8QAV4 QAV G03 Analog Input Point card - -25 to +100mVDC, 1Kohm 0
7379A28G02 4QAM6
QAM G02 Auto/Manual Stn Ctrlr card - 0 to +20mA, 0 to +5VDC
(output) 2
7379A28G02 4QAM7
(output) 2
7379A29G01 3QDT1 QDT Diagnostic Test card 7
7379A29G01 3QDT1 QDT Diagnostic Test card w/ 4256A36G01 1QDTD1 daughter 3
7379A31G01 3QAW5 QAW G01 Analog High-Level Input Point card - 0 to +1VDC 3
7379A31G01 5QAW7 QAW G01 Analog High-Level Input Point card - 0 to +1VDC 1
7379A31G01
/ 6QAW13 QAW G01 Analog High-Level Input Point card - 0 to +1VDC 0
7379A31G81
7379A31G02 7QAW2 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 1
7379A31G02 7QAW9 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 11
7379A31G02 7QAW15 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 3
7379A31G02
3A99165G02 9QAW18 / 22 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 4
7379A31G02
3A99165G50 9QAW26 / 30 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 3
7379A31G02
3A99165G50 9QAW30 QAW G02 Analog High-Level Input Point card - 0 to +5VDC 2
7379A31G03 5QAW15 QAW G03 Analog High-Level Input Point card - 0 to +10VDC 2
7379A31G03 7QAW3 QAW G03 Analog High-Level Input Point card - 0 to +10VDC 1
7379A31G03
3A99165G03
3A99165G50 9QAW19 / 22
QAW G03 Analog High-Level IP card - 0 to +10VDC w/ 6ea
4QAXD6 G06 2
7379A31G03
3A99165G03
3A99165G50 9QAW27 / 30
4QAXD6 G06 2
7379A31G04 3QAW8 QAW G04 Analog High-Level Input Point card - 0 to +20mA 3
7379A31G04 5QAW10 QAW G04 Analog High-Level Input Point card - 0 to +20mA 1
7379A31G04 7QAW11 QAW G04 Analog High-Level Input Point card - 0 to +20mA 9
7379A31G04 7QAW17 QAW G04 Analog High-Level Input Point card - 0 to +20mA 3
7379A31G04
3A99165G04
/ G52 9QAW20 / 24
QAW G04 Analog High-Level IP card - 0 to +20mA w/ 6ea
4QAXD5 G05s 6
7379A31G04
3A99165G04
/ G52 9QAW32
4QAXD5 G05s 1
7379A31G05
3A99165G51 9QAW29
QAW G05 Analog High-Level Input Point card - 0 to +20mA
(self-powered) 1
7379A31G05
3A99165G51 9QAW33 / 34
(self-powered) 4
7379A31G06 5QAW18 QAW G06 Analog High-Level Input Point card - 0 to +50mA 1
7379A31G06 7QAW19 QAW G06 Analog High-Level Input Point card - 0 to +50mA 1
7379A34G01 QMR QMR G01 card 0
7379A36G01 4QAH25 QAH G01 High-Speed Analog Input Point card - (+/-) 10VDC 1
7379A36G01 4QAH37
Sub Q 1
7379A36G01 4QAH49 QAH G01 High-Speed Analog Input Point card - (+/-) 10VDC 1
7379A36G02 4QAH34 QAH G02 High-Speed Analog Input Point card - (+/-) 5VDC 1
7379A36G03 4QAH39 QAH G03 High-Speed Analog Input Point card - 0 to 10VDC 9
7379A36G04 QAH QAH G04 High-Speed Analog Input Point card - 0 to 5VDC 0
7379A39G03 QAE QAE G03 card 0
7379A47G04 QMA QMA G04 card 0
7379A62G01 2QRT9 QRT G01 RTD Input Amp card - 10mV 1
7379A62G01 2QRT9
QRT G01 RTD Input Amp card - 10mV w/ 4ea 2FILM
7379A90G06 RTD 1
7379A62G01 4QRT1 QRT G01 RTD Input Amp card - 10mV 1
7379A62G01 4QRT1
QRT G01 RTD Input Amp card - 10mV w/ 4ea 1DRE
7380A92G06 RTD 3
7379A62G01 4QRT1
QRT G01 RTD Input Amp card - 10mV w/ 3ea 1DRE
7380A92G06 RTD 1
7379A62G01 4QRT1
7379A90G06 RTD 1
7379A62G01 4QRT2 QRT G01 RTD Input Amp card - 10mV 1
7379A62G01 4QRT2
QRT G01 RTD Input Amp card - 10mV w/ 1DRE 7380A92G06
daughters 1
7379A62G02 2QRT1 QRT G02 RTD Input Amp card - 33mV 1
7379A62G02 4QRT2 QRT G02 RTD Input Amp card - 33mV 1
7379A62G02 4QRT2
QRT G02 RTD Input Amp card - 33mV w/ 4ea 3DRE2
7380A92G02 1
7379A62G02 4QRT2
QRT G02 RTD Input Amp card - 33mV w/ 4ea 3DRE3
7380A92G03 4
7379A62G02 4QRT2
QRT G02 RTD Input Amp card - 33mV w/ 2ea 3DRE3
7380A92G03 1
7379A62G02 4QRT2
QRT G02 RTD w/ 2ea 3DRE3 G03 & 2ea 3DRE G03 /
9690A38G34 1
7379A62G02 4QRT2
QRT G02 RTD Input Amp card - 33mV w/ 3ea 3DRE2 G02 & 1ea
3DRE4 G04 2
7379A62G02 4QRT2
QRT G02 RTD Input Amp card - 33mV w/ 4ea 1DRE10
7380A92G04 9
7379A62G02 4QRT2
QRT G02 RTD Input Amp card - 33mV w/ 4ea 3DRE3 G01 /
9690A38G34 4
7379A62G02 4QRT4
9690A38G34 9
7379A62G02 4QRT4 QRT G02 RTD Input Amp card - 33mV 3
7379A66G01 QMB QMB G01 card 0
7379A70G02 2QMT5 QMT G02 M-Bus Terminator card - 13VDC monitor Sub 3 3
7379A70G03 2QMT3 QMT G03 M-Bus Terminator card - 13VDC monitor Sub 5 9
7379A78G01 QIA QIA G01 card 0
7379A82G01 QSI QSI G01 card 0
7379A84G01 3QBE5 QBE G01 Bus Extender card - DIOB discharging Sub 1 3
7379A84G01 3QBE7 QBE G01 Bus Extender card - DIOB discharging Sub 2 10
7379A84G01 4QBE1 QBE G01 Bus Extender card - DIOB discharging Sub 3 58
7379A84G01 4QBE3 QBE G01 Bus Extender card - DIOB discharging Sub 4 6
7379A84G01 4QBE5 QBE G01 Bus Extender card - DIOB discharging Sub 5 2
7379A89G01 4MBU7 MBU Board 1
7379A89G01 4MBU8 MBU Board 1
7379A89G01 5MBU3 MBU Board 7
7379A89G01 5MBU5 MBU Board 2
7379A89G01
772B222G01 5MBU3 MBU Board 3
7379A89G01
772B222G01 5MBU5 MBU Board 2
7379A89G01
772B222G02 5MBU3 MBU Board 1
7379A90G06 2FILM7 FILM G06 daughter card (RTD on QRT) 4
7379A91G02 2QAA3 QAA G02 Actuator Auto/Manual card card - Beck Dr. 13
7379A92G02 3MBC6 MBC Board 1
7379A92G02 4MBC8 MBC Board 13
7379A92G03 7MBC2 MBC Board 82
7379A93G01 2MBD14 MBD Board 4
7379A93G01 3MBD11 MBD Board 3
7379A93G01 3MBD17 MBD Board 2
7379A93G01 3MBD18 MBD Board 33
7379A94G06 2MBS14 MBS Board 3
7380A17G01 3FILM FILM Board 1
7380A18G01 3MBK1 MBK bd in fixed cord optr keybds 5
7380A27H01
772B379G01 Intel PBA 143472-004 1
7380A29G03 Intel Intel daugter card on MSP 14
7380A31G01 3MSC9
MMI P/S Controller card in 4D33613G01 and/or 1661D89G05
MMIs 5
7380A36G01 3QSE2 QSE Sequence of Events Recorder card - 7 to 21mA 1
7380A36G01 5QSE4 QSE Sequence of Events Recorder card - 7 to 21mA Sub J 2
7380A36G01 5QSE6 QSE Sequence of Events Recorder card - 7 to 21mA 1
7380A36G01 7QSE1 QSE Sequence of Events Recorder card - 7 to 21mA 3
7380A36G01 7QSE5 QSE Sequence of Events Recorder card - 7 to 21mA Sub X 7
7380A37G01 3DCS17 DPU P/S Controller card in 1D54582G01 and/or G05 10
7380A37G03 3DCS23 DPU P/S Controller card in 1D54582G03 3
7380A43G01 4MVP7 PC Bd 1
7380A43G02 MVP PC Bd 0
7380A51G01 MPP 1
7380A67G01 2DBK2 WDPF DBK daughter card (on QAA) 5
7380A70G02 4MBT6 MBT Board 39
7380A72G01 1SBA2 SBA daugter card on MSP 14
7380A78G01 3DPU1 DPU back plane (9 slot) 25
7380A84H01 Extender Multibus Card Extender PBA 1000280-03 4
7380A92G01 3DRE1 DRE G01 daughter card for QRT card (Copper) 108
7380A92G02 1DRE8 DRE G02 daughter card for QRT card (Platinum) 6
7380A92G03 1DRE9 DRE G03 daughter card for QRT card (120 Ohm Nickle) 13
7380A92G03 3DRE3 DRE G03 daughter card for QRT card (120 Ohm Nickle) 3
7380A92G04 1DRE10 DRE G04 daughter card for QRT card (100 Ohm Platinum) 22
7380A92G06 1DRE DRE G06 daughter card for QRT card (100 Ohm Copper) 8
7381A01G01
772B388G01 3MSP32 Multibus Shared Processor Board 1
7381A01G01
772B388G01 5MSP13 Multibus Shared Processor Board 1
7381A01G01
772B388G02 3MSP32 Multibus Shared Processor Board 2
7381A01G01
772B388G02 6MSP25 Multibus Shared Processor Board 1
7381A01G01
772B388G10 3MSP3 Multibus Shared Processor Board 1
7381A01G01
772B388G10 3MSP32 MSP Board w/ 7380A71G01 2SBG1 daughter 1
7381A01G01
772B388G25 8MSP1 Multibus Shared Processor Board 5
7381A01G01
772B388G25 8MSP11 Multibus Shared Processor Board 3
7381A01G01
772B388G25 8MSP13 Multibus Shared Processor Board 1
7381A01G01
772B388G26 8MSP1 Multibus Shared Processor Board 3
7381A01G01
772B388G26 8MSP9 Multibus Shared Processor Board 1
7381A01G01
772B388G26 8MSP11 Multibus Shared Processor Board 3
7381A01G01
772B388G26 8MSP13 Multibus Shared Processor Board 1
7381A01G01
772B388G26 8MSP11 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
7381A01G02
/ 8MSP2 Multibus Shared Processor Board 1
772B388G24
7381A01G02
773B388G21 3MSP33 Multibus Shared Processor Board 2
7381A01G03 8MSP21 Multibus Shared Processor Board 1
7381A01G03
772B388G29 6MSP21 Multibus Shared Processor Board 1
7381A01G03
772B388G29 6MSP27 Multibus Shared Processor Board 1
7381A01G03
772B388G29 8MSP3 Multibus Shared Processor Board 2
7381A01G03
772B388G29 8MSP7 Multibus Shared Processor Board 13
7381A01G03
772B388G29 8MSP12 Multibus Shared Processor Board 7
7381A01G03
772B388G29 8MSP15 Multibus Shared Processor Board 3
7381A01G03
772B388G29 8MSP21 Multibus Shared Processor Board 2
7381A01G03
772B388G29 8MSP7 MSP Board + 2ea 1SBA2 daughters 7380A72G01 1
7381A01G03
772B388G30 8MSP7 Multibus Shared Processor Board 1
7381A01G03
772B388G30 8MSP15 Multibus Shared Processor Board 1
7381A01G03
772B388G38 8MSP10 Multibus Shared Processor Board 1
7381A01G03
772B388G38 8MSP7 Multibus Shared Processor Board 1
7381A01G03
772B388G38 8MSP7 MSP Board w/ Intel PBA 146040-001 daughter 1
7381A01G03
772B388G38 8MSP12 Multibus Shared Processor Board 1
7381A01G03
772B388G38 8MSP6 MSP Board w/ Intel PBA 146040-001 daughter 1
7381A01G03
772B388G48 8MSP3 MSP Board w/ 249-06-01 Matrox MSBX-900 daughter 1
7381A01G03
772B388G48 8MSP7 MSP Board w/ 249-06-02 Matrox MSBX-900 daughter 2
7381A01G03
772B388G48 8MSP7 MSP Board w/ 249-06-04 Matrox MSBX-900 daughter 1
7381A01G03
772B388G53 8MSP3 Multibus Shared Processor Board 1
7381A01G03
772B388G53 8MSP7 Multibus Shared Processor Board 2
7381A01G03
772B388G53 8MSP3 MSP Board w/ 249-06-01 Matrox MSBX-900 daughter 2
7381A01G03
772B388G53 8MSP3 MSP Board w/ 249-06-02 Matrox MSBX-900 daughter 1
7381A01G03
