厦门兴锐达自动化设备有限公司
  • GE FAUNC 停厂备件
  • 发布时间:2009/10/19 16:50:50   修改时间:2009/10/19 16:50:50 浏览次数:601
  • GE FAUNC 停厂备件
    相关型号
    GE FANUC A16B
    A16B-2200-0842 MAIN CPU PCB W/ 6 DAUGHTERBDS
    A20B-2000-0220/05B AC Spindle Servo Unit
    A20B-2002-0380 PCB S MONITOR
    A16B-2200-0842/04C PROCESSOR BOARD FOR RJ
    A03B-0808-C001 I/O BASE UNIT NEW
    A20B-2000-0360/03B RJ TEACH PENDANT CONTROL
    A20B-2901-0891/01A SMD CARD NEW
    A16B-2200-0842/O4C PROCESSOR BOARD RJ2
    12 SLOT RACK WITH POWER SUPPLY APPEARS NEW
    A16B-2201-0890/03A BOAR
    A16B-2200-0252/05C BOARD
    A16B-1211-0060/12C BOARD
    A16B-1211-0060/11C BOARD
    A16B-1210-0020/09E BOARD
    A16B-1210-0020/08E BOARD
    A16B-1210-0020/07E BOARD
    A03B-0807-C159 MODULE
    A03B-0807-C107 MODULE
    A20B-2900-0281/01A DAUGHTER BOARD
    IC600 BOARD NEW
    A20B-2001-0670/02A BACK PLANE W/ SLOTS
    A20B-1000-0770 POWER UNIT
    A20B-1000-0560 /R00 PLC BOARD
    A16B-1211-0040/07A CPU BOARD
    A16B-2200-0252 PCB 2 AXES CONTROL DSPII
    A16B-2200-0200/03A MAIN CPU BOARD
    A16B-1210-0200/02B ROBOT PCB
    A16B-2200-0200/03A ROBOT PCB
    A20B-2900-0630/04C DAUGHTER BOARD
    A20B-1003-0041 PCB OPERATOR PANEL
    A16B-1210-0280/02A RAM BOARD
    A16B-2200-0250/05C PCB 4 AXES CONTROL (R-H)
    A16B-1211-0860/05A PCB
    A20B-0008-0871 BOARD
    A20B-2900-0610/02B DAUGHTER BOARD
    A16B-1210-0950/02B MAIN PCB FOR RF (MODIFIED)
    A16B-1210-0270/02A RAM BOARD
    531X111PSHAPG2 MFC POWER SUPPLY BOARD
    A16B-1211-0030/03A CPU BOARD
    A20B-1000-0770-01 POWER UNIT
    A16B-1211-0091 BUBBLE MEMORY UNIT
    A16B-2203-0291/02A ETHERNET REMOTE PCB ER1T
    A16B-2201-0890/03A EHTERNET REMOTE PCB
    A20B-0007-0007/08B BOARD
    A16B-1211-0170/11E i/o board
    A16B-1210-0060/08E BOARD
    IC600CB52K ARITH CONTROL
    IC600CB503L I/O CONTROL MODULE
    IC600CB515N EXPII LOGIC CONTROL APPEARS NEW
    A16B-1210-0220/08B PCB
    A16B-1210-0220/03B PCB
    A20B-1006-030/03B PCB EMERGENCY STOP
    A20B-1006-030/05C NSSP PLC
    A20B-2900-0500/04D DAUGHTERBOARD NEW
    A16B-1211-0091/05C BUBBLE MEMORY PCB (1.5MB)
    A16B-1211-0041/06A MainCPU Board, RH, 1MB
    A16B-2200-020/04A MAIN CPU BOARD
    A16B-1211-0030/02A RH Path CPU Board
    A16B-1211-0170/16G I/O ARC MATE RG2 BOARD
    A16B-1211-0170/07G I/O BOARD
    A16B-1210-0210/03B RF MainBUFFER, PC Board
    IC600BF902K 24V SINK OUTPUT REPAIRED
    IC600BF831K HIGH DENSITY INPUT MODULE
    IC600BF830L ADV I/O RECIEVER APPEARS NEW
    IC600BF802K PROGRAMMABLE CONTROLLER
    A16B-1200-0210/02A SENSOR INTERFACE APPEARS
    I/O Electric Module - 32 Point 0 pcs
    Cat # A16B-1210-0430 /04B Axis Board
    Cat # A20B-1000-0913 /04A PCB
    A16B-2200-0842/O6E PROCESSOR BOARD RJ2  3pcs
    A16B-2200-0842/08F PROCESSOR BOARD FOR RJ
    A16B-2200-0840/05D PROCESSOR BOARD FOR RJ2
    A16B-2200-0842/07F PROCESSOR BOARD FOR RJ
    RJ2 A16B-2200-0842/08F PROCESSOR BOARD
    RJ2 A16B-2200-0842/06F PROCESSOR BOARD
    Cat # A06B-6058-H005 Servo Amplifier with top board Cat # A20B-1003-0090 /05A
    Cat # A16B-1310-0530 /20E PC Board 1 pcs
    CONTROL BOARDS A20B-0009-0150 NEW 3 pcs
    VMI VME MODEL 3230 T/C CONDITIONER
    A16B-2200-0173 REMOTE BUFFER SERIAL PORT BOARD
    A03B-0801-C104 IF01D INTERFACE MODULE
    IC660 BUSS CONTROL CARD
    A16B-2200-025 AXIS CONTROL BOARD
    IC600 LX612K 12 MEM. ASM. BOARD
    A16B 2200 0120 04B CARD,NEW
    A16B-1211-0300/04A I/O-C3 CARD TAKEOUT
    A05B-2051-C143 TEACH PENDANT
    A16B-1211-0062/10B BOARD
    A16B-1200-0150/02A ROM CARD
    A16B-2200-0430/03A I/O BOARD  6pcs
    I/O BASE UNIT WITH MODULES - A03B-0801-C004
    A03B-0801-C118 - OA08E (1 UNIT)
    A03B-0801-C141 - OD64A (3 UNITS)
    A03B-0801-C123 - ID64C (4 UNITS)
    A03B-0801-C102 - IF01B (1 UNIT)
    POWER UNIT A16B-1310-0010 -01 (1 UNIT)
    I/O BASE UNIT WITH MODULES-A03B-0801-C004 - A03B-0801-B002-9 MODULES INCLUDED - BRAND NEW
    A03B-0801-C055 - DA03A (1 UNIT)
    A03B-0801-C054 - CT01A (1 UNIT)
    A03B-0801-C103 - IF04C (1 UNIT)
    A03B-0801-C023 - SD03A (1 UNIT)
    A03B-0801-C024 - OL04A (1 UNIT)
    A03B-0801-C102 - IFO1B (2 UNITS)
    A03B-0801-C030 - MEM5A (1 UNIT)
    A03B-0801-C021 - CPU-A (1 UNIT)
    I/O BASE UNIT WITH MODULES - A03B-0801-C009-12 MODULES INCLUDED - BRAND NEW
    A03B-0801-C131 - ID16A (5 UNITS)
    A03B-0801-C111 - 0D16B  (4 UNITS)
    A03B-0801-C113 - 0D64B (1 UNIT)
    A03B-0801-C101 - IF01A (1 UNIT)
    I/O BASE UNIT WITH MODULES-A03B-0801-C009 10 MODULES INCLUDED - BRAND NEW
    A03B-0801-C115 - OD16C ( 6 UNITS)
    A03B-0801-C118 - OA08E ( 1 UNIT)
    A03B-0801-C119 - OA16E ( 2 UNITS)
    A03B-0801-C101 / IF01A  - ( 1 UNIT)
    A03B-0801-C129 - IA16E (1 UNIT)
    A03B-0801-C119 - OA16E (2 UNITS)
    A03B-0801-C111 - OD16B (1 UNIT)
    A03B-0801-C112 - OD32B (1 UNIT)
    A03B-0801-C113 - OD64B (2 UNITS)
    A03B-0801-C131 - ID16A (2 UNITS)
    A03B-0801-C135 - ID16B (1 UNIT)
    90-30 10-Slot PLC Complete System Rack CPU 331
    ?  (1) IC693CHS391H  EMI Enhanced 10-slot Rack
    ?  (1) IC693PWR321S  Std Power Supply
    ?  (1) IC693CPU331R  Central Processor Unit
    ?  (1) IC693PCM301G  Programmable Co-Processor 192k RAM Module
    ?  (4) IC693MDL645D  Input 16PT Pos / Neg Logic Modules
    ?  (4) IC693MDL740E  Output 12 / 24 VDC .5 Amp 16PT Pos Modules
    ?  (1) IC693CHS391K  EMI Enhanced 10-slot Rack
    ?  (1) IC693PWR321T  Std Power Supply
    ?  (1) IC693CPU331X  Central Processor Unit
    ?  (1) IC693PCM301M  Programmable Co-Processor 192k RAM Module
    ?  (1) IC693CMM311N  Communications Control Module
    ?  (1) IC693ALG220D 4PT Analog Input Module
    ?  (2) IC693MDL645D  Input 16PT Pos / Neg Logic Modules
    ?  (1) IC693MDL655F  Input 32PT Pos / Neg Fast Module
    ?  (1) IC693MDL753D  Output 12 / 24 VDC .5 Amp 32PT Pos Module
    ?  (2) IC693MDL740E  Output 12 / 24 VDC .5 Amp 16PT Pos Modules
    This system consists of the following:
    ?  (1) IC693PWR321-AA  Std Power Supply
    ?  (1) IC693CPU331-AA  Central Processor Unit
    ?  (1) IC693PCM301L  Programmable Co-Processor 192k RAM Module
    ?  (1) IC693MDL655E  Input 32PT Pos / Neg Fast Module
    ?  (1) IC693MDL753F  Output 12 / 24 VDC .5 Amp 32PT Pos Module
    90-30 IC693MDL740 E Output 12/24VDC 5AMP 16PT  12pcs
    A20B-2000-0411/05A  1pcs
    A20B-1005-0111/04A  1pcs
     POWER SUPPLY BOARD A16B-1212-0531 NEW  1pcs
    A03B-0801-C021 CPU MODULE  Q"ty:2
    A03B-0801-C051 Positioning Module PT01A  Q"ty:3
    A03B-0801-C117 OUTPUT MODULE OA16D  Q"ty:3
    A03B-0801-C129 INPUT MODULE IA16E  Q"ty:1
    A03B-0801-C141 OUTPUT MODULE OD64A  Q"ty:1
     A16B-1310-0530/16D  Q"ty:1
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
