厦门兴锐达自动化设备有限公司
  • GE Fanuc
  • 发布时间:2009/10/19 16:49:05   修改时间:2009/10/19 16:49:05 浏览次数:1626
  • GE Fanuc
    相关型号
    Specification Descripton product group
    411AP ROTARY SWITCH FOR OP PANEL U.SCH411AP consumable parts
    44A717186-042 LAMP, 28V 40MA INCAN-T-1 3/4M consumable parts
    A02B-0072-K893 BURNDY CONNECTOR (3P, BROWN) consumable parts
    A02B-0120-K323 CONNECTOR, AMP, 3 PINS, FEMALE BLACK consumable parts
    A02B-0120-K324 CONNECTOR, AMP, 3 PINS, FEMALE BLACK, X TYPE consumable parts
    A02B-0124-K001 ACCESSORIES CABLE CLAMP,8 PIECES consumable parts
    A02B-0207-J561/613K PC CARD PCB
    A02B-0213-K211 COMPACT FLASH CARD, 256 MB consumable parts
    A02B-0213-K212 COMPACT FLASH CARD, 1GB consumable parts
    A02B-0236-C203 SEPARATE DETECTOR I/F UNIT 1 BASIC 4 AXES consumable parts
    A02B-0236-C205 SEPARATE DETECTOR I/F UNIT consumable parts
    A02B-0236-C230 OPERATOR PANEL (MAIN PANEL A) consumable parts
    A02B-0236-C931/16 PC CARD MAINTENANCE KIT consumable parts
    A02B-0236-C932/16 PC CARD MAINTENANCE KIT consumable parts
    A02B-0236-C932/211 PC CARD MAINTENANCE KIT consumable parts
    A02B-0236-K150 COMPACT FLASH CARD ADAPTER consumable parts
    A02B-0236-K170 SET OF 55 TRANSPARENT KEY TOPS consumable parts
    A02B-0236-K312 CONNECTOR, CM67 consumable parts
    A02B-0236-K313 CONNECTOR, CM68, CM69 consumable parts
    A02B-0259-C221/A HANDY OPERATOR PANEL 20 KEYS, MPG, 2 LINES LCD consumable parts
    A02B-0261-C162/MCR SEPARATE TYPE MDI 61 FULL KEY HORIZONTAL, ENGLISH consumable parts
    A02B-0281-C125/TBE SEPARATE TYPE MDI, TURNING HORIZONTAL, ENGLISH & SYMBOL consumable parts
    A02B-0281-K601 COMPACT FLASH CARD, 128 MB consumable parts
    A02B-0303-C231 MACHINE OPERATOR PANEL MAIN PANEL consumable parts
    A02B-0303-C245 MACHINE OPERATOR PANEL+ MDI QWERTY MDI consumable parts
    A02B-0303-K150 COMPACT FLASH CARD ADAPTER consumable parts
    A03B-0801-C141 DO MODULE OD64A I/O Units
    A03B-0815-C001 I/O MODULE FOR CONNECTOR PANEL BASIC MODULE I/O Units
    A03B-0815-C003 I/O MODULE FOR CONNECTOR PANEL EX MODULE B I/O Units
    A03B-0815-C005 I/O MODULE FOR CONNECTOR PANEL EX MODULE D, ANALOG INPUT 4 CH I/O Units
    A03B-0815-C021 TERMINAL MODULE A I/O Units
    A03B-0819-C002 BASE UNIT ABU5A HORIZONTAL TYPE, 5 SLOTS I/O Units
    A03B-0819-C011 INTERFACE MODULE AIF01A I/O Units
    A03B-0819-C051 ANALOG INPUT MODULE AAD04A 4 CHANNELS ANALOG INPUT I/O Units
    A03B-0819-C052 ANALOG OUTPUT MODULE ADA02A 2 CHANNELS ANALOG INPUT 12-BIT I/O Units
    A03B-0819-C104 DIGITAL INPUT MODULE AID16D 16PT, 24VDC, 20MS I/O Units
    A03B-0819-C105 DIGITAL INPUT MODULE AID32E1 32PT, 24VDC, 20MS I/O Units
    A03B-0819-C109 DIGITAL INPUT MODULE AID32F2 32PT, 24VDC, 2MS I/O Units
    A03B-0819-C114 DIGITAL INPUT MODULE AID16L 16PT, 24VDC, 2MS I/O Units
    A03B-0819-C152 DIGITAL OUTPUT MODULE AOD08D 8PT, 12-24VDC, 2A, NEG I/O Units
    A03B-0819-C154 DIGITAL OUTPUT MODULE AOD16D 16PT, 12-24VDC, 0.5A, POS I/O Units
    A03B-0819-C156 DIGITAL OUTPUT MODULE AOD32D 32PT, 12-24VDC, 0.3A, POS I/O Units
    A03B-0819-C160 DIGITAL OUTPUT MODULE AOR08G 8PT, 250VAC-30VDC, 4A I/O Units
    A03B-0819-C161 DIGITAL OUTPUT MODULE AOR16G 16PT, 250VAC-30VDC, 2A I/O Units
    A03B-0819-C167 DIGITAL OUTPUT MODULE AOD32D 32PT, 12-24VDC, 0.3A I/O Units
    A03B-0819-C182 DIGITAL OUTPUT MODULE AOD16D 16PT, 12-24VDC, 0.3A I/O Units
    A03B-0823-C001 BASIC I/O MODULE WITH TERMINAL I/O Units
    A03B-0823-C003 EXTENSION I/O MODULE B W/ MPG TERMINAL I/O Units
    A04B-0800-C009*LR TURBO BLOWER Laser Parts
    A04B-0800-C011*LR TURBO BLOWER Laser Parts
    A04B-0800-C015*LR TURBO BLOWER Laser Parts
    A04B-0800-K328/1 TURBO BLOWER OIL (1x200ml) Laser Parts
    A04B-0800-K367 LASER GAS FILTER 0.5 MICRON Laser Parts
    A04B-0817-D201 REAR MIRROR Laser Parts
    A04B-0817-D202 FOLDING MIRROR Laser Parts
    A04B-0817-D203 FOLDING MIRROR Laser Parts
    A04B-0818-D201 REAR MIRROR Laser Parts
    A04B-0819-D200 OUTPUT COUPLER Laser Parts
    A06B-0031-B077/7008 SERVO MOTOR BETA 1/3000 STRAIGHT SHAFT, I32, KEY Beta Motor
    A06B-0032-B075/7000 SERVO MOTOR BETA 2/3000 STRAIGHT SHAFT, A32 Beta Motor
    A06B-0032-B075/7008 SV MOTOR BETA 2/3000 STRAIGHT SHAFT, A32, KEY Beta Motor
    A06B-0032-B077/7008 SERVO MOTOR BETA 2/3000 STRAIGHT SHAFT, I32, KEY Beta Motor
    A06B-0034-B075/7000 SERVO MOTOR BETA 6/2000 STRAIGHT SHAFT, A32 Beta Motor
    A06B-0034-B075/7008 SERVO MOTOR BETA 6/2000 STRAIGHT, A32, KEY Beta Motor
    A06B-0061-B403 SV MOTOR BETA iS 2/4000 BRAKE Beta Motor
    A06B-0075-B003 SV MOTOR BETA iS 8/3000 TAPER SHAFT Beta Motor
    A06B-0112-B103 SV MOTOR BETA iS 0.3/5000 Beta Motor
    A06B-0113-B075/7008 SERVO MOTOR BETA 0.5/3000 STRAIGHT SHAFT, A32, KEY Beta Motor
    A06B-0113-B077/7000 SERVO MOTOR BETA 0.5/3000 STRAIGHT, I32 Beta Motor
    A06B-0115-B103 SV MOTOR BETA iS 0.5/6000 IP67 Beta Motor
    A06B-0115-B103/0100 SV MOTOR BETA iS 0.5/6000 IP67 Beta Motor
    A06B-0115-B403/0100 SV MOTOR BETA iS 0.5/6000 BRAKE Beta Motor
    A06B-0116-B103 SV MOTOR BETA iS 1/6000 Beta Motor
    A06B-0116-B103/0100 SV MOTOR BETA iS 1/6000 IP67 Beta Motor
    A06B-0116-B203 SV MOTOR BETA iS 1/5000 KEY Beta Motor
    A06B-0123-B075/7000 SERVO MOTOR ALPHA 3/3000 TAPER SHAFT, A64 Alpha Motor
    A06B-0123-B077/7000 SERVO MOTOR ALPHA 3/3000 TAPER SHAFT, I64 Alpha Motor
    A06B-0123-B577/7008 SERVO MOTOR ALPHA 3/3000 STRAIGHT, I64, KEY Alpha Motor
    A06B-0127-B077/7000 SERVO MOTOR ALPHA 6/2000 TAPER SHAFT, I64 Alpha Motor
    A06B-0128-B577/7000 SERVO MOTOR ALPHA 6/3000 STRAIGHT SHAFT, I64 Alpha Motor
    A06B-0142-B077/7000 SERVO MOTOR ALPHA 12/2000 STRAIGHT SHAFT, I64 Alpha Motor
    A06B-0147-B077/7000 SERVO MOTOR ALPHA 22/2000 STRAIGHT SHAFT, I64 Alpha Motor
    A06B-0172-B575/7000 SERVO MOTOR ALPHA 6/3000HV STRAIGHT SHAFT, A64 Alpha Motor
    A06B-0202-B101 SV MOTOR ALPHA iF 1/5000 Alpha i Motor
    A06B-0205-B000 SV MOTOR ALPHA iF 2/5000 TAPER SHAFT Alpha i Motor
    A06B-0212-B200 SV MOTOR ALPHA iS 2/5000 KEY Alpha i Motor
    A06B-0212-B700/0100 SV MOTOR ALPHA iS 2/5000 STRAIGHT, BRAKE 90V, A1K, IP67 Alpha i Motor
    A06B-0213-B100/0100 SV MOTOR ALPHA iS 2/5000HV IP67 Alpha i Motor
    A06B-0213-B200 SV MOTOR ALPHA iS 2/5000HV KEY Alpha i Motor
    A06B-0213-B400/0100 SV MOTOR ALPHA iS 2/5000HV BRAKE, IP67 Alpha i Motor
    A06B-0215-B100/0100 SV MOTOR ALPHA iS 4/5000 IP67 Alpha i Motor
    A06B-0215-B700/0100 SV MOTOR ALPHA iS 4/5000 STRAIGHT SHAFT, BRAKE 90VDC, I Alpha i Motor
    A06B-0216-B100 SV MOTOR ALPHA iS 4/5000HV Alpha i Motor
    A06B-0216-B100/0100 SV MOTOR ALPHA iS 4/5000HV IP67 Alpha i Motor
    A06B-0216-B400/0100 SV MOTOR ALPHA iS 4/5000HV BRAKE, IP67 Alpha i Motor
    A06B-0216-B500 SV MOTOR ALPHA iS 4/5000HV KEY, BRAKE Alpha i Motor
    A06B-0223-B000 SV MOTOR ALPHA iF 4/4000 TAPER SHAFT Alpha i Motor
    A06B-0223-B001 SV MOTOR ALPHA iF 4/4000 TAPER SHAFT Alpha i Motor
    A06B-0227-B400 SV MOTOR ALPHA iF 8/3000 BRAKE Alpha i Motor
    A06B-0236-B100 SV MOTOR ALPHA iS 8/4000HV Alpha i Motor
    A06B-0239-B100 SV MOTOR ALPHA iS 12/4000HV Alpha i Motor
    A06B-0239-B400 SV MOTOR ALPHA iS 12/4000HV BRAKE Alpha i Motor
    A06B-0266-B400 SV MOTOR ALPHA iS 22/4000HV BRAKE Alpha i Motor
    A06B-0269-B400 SV MOTOR ALPHA iS 30/4000HV BRAKE Alpha i Motor
    A06B-0273-B420 SV MOTOR ALPHA iS 40/4000HV STRAIGHT SHAFT, BRAKE 70 NM Alpha i Motor
    A06B-0314-B005/7000 AC SERVO MOTOR 5S Alpha Motor
    A06B-0314-B572/7000 AC MOTOR 5S Alpha Motor
    A06B-0371-B577/7000 SERVO MOTOR ALPHA 1/3000 STRAIGHT SHAFT, I64 Alpha Motor
    A06B-0372-B077/7000 SERVO MOTOR ALPHA 2/2000 TAPER, I64 Alpha Motor
    A06B-0373-B075/7000 SERVO MOTOR ALPHA 2/3000 TAPER SHAFT, A64 Alpha Motor
    A06B-0373-B077/7000 SERVO MOTOR ALPHA 2/3000 TAPER SHAFT, I64 Alpha Motor
    A06B-0373-B175/7000 SERVO MOTOR ALPHA 2/3000 TAPER SHAFT, BRAKE, A64 Alpha Motor
    A06B-0373-B577/7008 SERVO MOTOR ALPHA 2/3000 STRAIGHT, I64, KEY Alpha Motor
    A06B-0373-B588/7076 SERVO MOTOR ALPHA 2/3000 STRAIGHT SHAFT, A1000, IP67, K Alpha Motor
    A06B-0374-B569/7000 SERVO MOTOR 0-OSP A 100ABS Alpha Motor
    A06B-0374-B575/7000 SERVO MOTOR ALPHA 2.5/3000 STRAIGHT, A64 Alpha Motor
    A06B-0374-B577/7000 SERVO MOTOR ALPHA 2.5/3000 STRAIGHT, I64 Alpha Motor
    A06B-0374-B588/7075 SERVO MOTOR ALPHA 2.5/3000 STRAIGHT SHAFT, A1000, IP67 Alpha Motor
    A06B-0374-B677/7000 SERVO MOTOR ALPHA 2.5/3000 STRAIGHT, BRAKE, I64 Alpha Motor
    A06B-0376-B575/7075 SERVO MOTOR ALPHA M2/3000 STRAIGHT SHAFT, A64, IP67 Alpha Motor
    A06B-0377-B575/7075 SERVO MOTOR ALPHA M2.5/3000 STRAIGHT SHAFT, A64, IP67 Alpha Motor
    A06B-0377-B675/7075 SERVO MOTOR ALPHA M2.5/3000 STRAIGHT SHAFT, BRAKE, A64, IP Alpha Motor
    A06B-0377-B677/7000 SERVO MOTOR ALPHA M2.5/3000 STRAIGHT, BRAKE, I64 Alpha Motor
    A06B-0850-B391/3000 SPINDLE MOTOR ALPHA 1/8000 EXHAUST FRONT Alpha Motor
    A06B-0850-B395/3000 SPINDLE MOTOR ALPHA 1/15000 EXHAUST FRONT Alpha Motor
    A06B-0851-B190/3000 SPINDLE MOTOR ALPHA 1.5/8000 KEY Alpha Motor
    A06B-0851-B391/3000 SPINDLE MOTOR ALPHA 1.5/8000 EXHAUST FRONT Alpha Motor
    A06B-0853-B130/3000 SPINDLE MOTOR ALPHA 3/8000 KEY, HR Alpha Motor
    A06B-0866-B300/3000 SPINDLE MOTOR ALPHA 0.5/3000 PG Alpha Motor
    A06B-0866-B380/3000 SPINDLE MOTOR ALPHA 0.5/3000 Alpha Motor
    A06B-1501-B102 SP MOTOR ALPHA iI 0.5/10000HV FLANGE, iM, NO FAN Alpha i Motor
    A06B-1501-B105 SP MOTOR ALPHA iI 0.5/10000HV FLANGE, iMZ, NO FAN Alpha i Motor
    A06B-1503-B101 SP MOTOR ALPHA iI 1.5/10000HV FLANGE, iM, EXHAUST FRONT Alpha i Motor
    A06B-1503-B103 SP MOTOR ALPHA iI 1.5/10000HV FLANGE, iMZ, EXHAUST REAR Alpha i Motor
    A06B-6050-K115 CONNECTOR (SIGNAL LINE) STRAIGHT TYPE, WATERPROOF consumable parts
    A06B-6050-K120 CONNECTOR (SIGNAL LINE) BETA 0.5 consumable parts
    A06B-6058-H005 AC SERVO UNIT 10,20M Servo Units
    A06B-6058-H006 AC SERVO UNIT 20,30S Servo Units
    A06B-6058-H224 AC SERVO UNIT Servo Units
    A06B-6066-H006 AC SERVO AMP C Servo Units
    A06B-6066-H233 2-AXIS SERVO Servo Units
    A06B-6066-H244 C SERIES DGT SERVO Servo Units
    A06B-6070-H005 E SERIES SERVO AMPLIFIER Servo Units
    A06B-6071-K203 CONNECTOR AMP FOR PSM (PS, ESP, MCC) consumable parts
    A06B-6077-H106 POWER SUPPLY PSM 5.5 Servo Units
    A06B-6077-H111 POWER SUPPLY PSM 11 Servo Units
    A06B-6078-C001 FAN ADAPTOR PSM-11 SPM-11 CE consumable parts
    A06B-6078-H202/H500 SPINDLE AMPLIFIER SPM 2.2 TYPE I Servo Units
    A06B-6078-H206/H500 SPINDLE AMPLIFIER SPM 5.5 TYPE I Servo Units
    A06B-6078-H211/H500 SPINDLE AMPLIFIER SPM 11 TYPE I Servo Units
    A06B-6079-H103 SERVO AMPLIFIER SVM 1-40S PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H105 SERVO AMPLIFIER SVM 1-80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H106 SERVO AMPLIFIER SVM 1-130 PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H201 SERVO AMPLIFIER SVM 2-12/12 PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H206 SERVO AMPLIFIER SVM 2-40/40 PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H207 SERVO AMPLIFIER SVM 2-40/80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H208 SERVO AMPLIFIER SVM 2-80/80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6079-H301 SERVO AMPLIFIER SVM 3-12/12/12 PWM INTERFACE TYPE A Servo Units
    A06B-6079-K815 CONNECTOR (POWER LINE), GROUP ELBOW SHELL, CABLE CLAMP consumable parts
    A06B-6082-H202/H512 SPINDLE AMPLIFIER SPMC 2.2 TYPE I Servo Units
    A06B-6082-H211/H512 SPINDLE AMPLIFIER SPMC-11 TYPE I Servo Units
    A06B-6087-H115 POWER SUPPLY PSM 15 Servo Units
    A06B-6087-H126 POWER SUPPLY PSM 26 Servo Units
    A06B-6087-H130 POWER SUPPLY PSM 30 Servo Units
    A06B-6087-H155 POWER SUPPLY PSM 55 Servo Units
    A06B-6088-H226/H500 SPINDLE AMPLIFIER SPM 26 TYPE I Servo Units
    A06B-6088-H230/H500 SPINDLE AMPLIFIER SPM 30 TYPE I Servo Units
    A06B-6089-H101 SERVO AMPLIFIER SVU 1-12 PWM INTERFACE TYPE A/B Servo Units
    A06B-6089-H105 SERVO AMPLIFIER SVU 1-80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6089-H106 SERVO AMPLIFIER SVU 1-130 PWM INTERFACE TYPE A/B Servo Units
    A06B-6089-H206 SERVO AMPLIFIER SVU 2-40/40 PWM INTERFACE TYPE A/B Servo Units
    A06B-6089-H208 SERVO AMPLIFIER SVU 2-80/80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6090-H003 SERVO AMPLIFIER SVUC 1-12 PWM INTERFACE TYPE A/B Servo Units
    A06B-6090-H004 SERVO AMPLIFIER SVUC 1-40 PWM INTERFACE TYPE A/B Servo Units
    A06B-6090-H006 SERVO AMPLIFIER SVUC 1-80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6090-H006/R0011 SERVO AMPLIFIER SVUC 1-80 PWM INTERFACE TYPE A/B Servo Units
    A06B-6090-H233 SERVO AMPLIFIER SVUC 2-12/12 PWM INTERFACE TYPE A/B Servo Units
    A06B-6090-H244 SERVO AMPLIFIER SVUC 2-40/40 PWM INTERFACE TYPE A/B Servo Units
    A06B-6091-H130 POWER SUPPLY PSM 30 HV Servo Units
    A06B-6091-H145 POWER SUPPLY PSM 45 HV Servo Units
    A06B-6091-H175 POWER SUPPLY PSM 75 HV Servo Units
    A06B-6093-H101 SERVO AMPLIFIER SVU 1-12 PWM INTERFACE TYPE B Servo Units
    A06B-6093-H102 SERVO AMPLIFIER SVU 1-20 BETA, PWM INTERFACE TYPE B Servo Units
    A06B-6093-H111 SERVO AMPLIFIER SVU 1-12 BETA, FSSB INTERFACE Servo Units
    A06B-6093-H112 SERVO AMPLIFIER SVU 1-20 BETA, FSSB INTERFACE Servo Units
    A06B-6093-H151 SERVO AMPLIFIER SVU 1-12 BETA, I/O-LINK INTERFACE Servo Units
    A06B-6093-H152 SERVO AMPLIFIER SVU 1-20 BETA, I/O-LINK INTERFACE Servo Units
    A06B-6093-H401 REGENERATION RESISTOR SEPARATE TYPE, 30 OHM/ 20W Servo Units
    A06B-6093-K303 CONNECTOR KIT BATTERY LINK (CX5X, CX5Y) consumable parts
    A06B-6093-K305 CONNECTOR KIT BETA SVU 1-12/20 W/O DISCHARGE RESISTOR consumable parts
    A06B-6093-K306 CONNECTOR KIT BETA SVU 1-12/20 W/ DISCHARGE RESISTOR consumable parts
    A06B-6093-K313 CONNECTOR KIT BETA SVU 1-40/80 FOR CX22 WIRE>3,5MM2 consumable parts
    A06B-6096-H101 SERVO AMPLIFIER SVM 1-12 FSSB INTERFACE Servo Units
    A06B-6096-H102 SERVO AMPLIFIER SVM 1-20 FSSB INTERFACE Servo Units
    A06B-6096-H103 SERVO AMPLIFIER SVM 1-40S FSSB INTERFACE Servo Units
    A06B-6096-H104 SERVO AMPLIFIER SVM 1-40L FSSB INTERFACE Servo Units
    A06B-6096-H105 SERVO AMPLIFIER SVM 1-80 FSSB INTERFACE Servo Units
    A06B-6096-H106 SERVO AMPLIFIER SVM 1-130 FSSB INTERFACE Servo Units
    A06B-6096-H116 SERVO AMPLIFIER SVM 1-130S FSSB INTERFACE Servo Units
    A06B-6096-H201 SERVO AMPLIFIER SVM 2-12/12 FSSB INTERFACE Servo Units
    A06B-6096-H203 SERVO AMPLIFIER SVM 2-20/20 FSSB INTERFACE Servo Units
    A06B-6096-H204 SERVO AMPLIFIER SVM 2-12/40 FSSB INTERFACE Servo Units
    A06B-6096-H206 SERVO AMPLIFIER SVM 2-40/40 FSSB INTERFACE Servo Units
    A06B-6096-H207 SERVO AMPLIFIER SVM 2-40/80 FSSB INTERFACE Servo Units
    A06B-6096-H208 SERVO AMPLIFIER SVM 2-80/80 FSSB INTERFACE Servo Units
    A06B-6096-H301 SERVO AMPLIFIER SVM 3-12/12/12 FSSB INTERFACE Servo Units
    A06B-6096-H304 SERVO AMPLIFIER SVM 3-20/20/20 FSSB INTERFACE Servo Units
    A06B-6096-H305 SERVO AMPLIFIER SVM 3-12/12/40 FSSB INTERFACE Servo Units
    A06B-6097-H204 SERVO AMPLIFIER SVM 2-40/40 HV FSSB INTERFACE Servo Units
    A06B-6097-H206 SERVO AMPLIFIER SVM 2-60/60 HV FSSB INTERFACE Servo Units
    A06B-6102-H202/H520 SPINDLE MODULE SPM 2.2 TYPE 1 Servo Units
    A06B-6102-H206/H520 SPINDLE MODULE SPM 5.5 TYPE 1 Servo Units
    A06B-6102-H211/H520 SPINDLE MODULE SPM 11 TYPE 1 Servo Units
    A06B-6102-H222/H520 SPINDLE MODULE SPM 22 TYPE 1 Servo Units
    A06B-6102-H226/H520 SPINDLE MODULE SPM 26 TYPE 1 Servo Units
    A06B-6102-H230/H520 SPINDLE MODULE SPM 30 TYPE 1 Servo Units
    A06B-6104-H245/H520 SPINDLE MODULE SPM 45 HV TYPE1 Servo Units
    A06B-6110-C601 FAN UNIT consumable parts
    A06B-6110-C602 FAN UNIT consumable parts
    A06B-6110-C603 FAN UNIT consumable parts
    A06B-6110-H011 POWER SUPPLY ALPHA iPS 11 Servo Units
    A06B-6110-H015 POWER SUPPLY ALPHA iPS 15 Servo Units
    A06B-6110-K200/XXM CONNECTOR POWER, AMP, XX CODED SIZE M, ALPHAi PSM, SVM, SPM consumable parts
    A06B-6110-K200/XXS CONNECTOR POWER, AMP, XX CODED SIZE S, ALPHAi PSM, SVM, SPM consumable parts
    A06B-6110-K201/XYM CONNECTOR POWER, AMP, XY CODED SIZE M, ALPHAi SVM-2, SVM-3M consumable parts
    A06B-6110-K201/XYS CONNECTOR POWER, AMP, XY CODED SIZE S, ALPHAi SVM-2, SVM-3M consumable parts
    A06B-6110-K201/XYSS CONNECTOR POWER, AMP, XY CODED SIZE SS, ALPHAi SVM-2, SVM-3M consumable parts
    A06B-6110-K202/YYM CONNECTOR POWER, AMP, YY CODED SIZE M, ALPHAi SVM-3 consumable parts
    A06B-6110-K202/YYS CONNECTOR POWER, AMP, YY CODED SIZE S, ALPHAi SVM-3 consumable parts
    A06B-6110-K203/ZZL CONNECTOR POWER, AMP UNIVERSAL SIZE L, ALPHAi PSM, SVM, SPM consumable parts
    A06B-6110-K203/ZZM CONNECTOR POWER, AMP UNIVERSAL SIZE M, ALPHAi PSM, SVM, SPM consumable parts
    A06B-6110-K203/ZZS CONNECTOR POWER, AMP UNIVERSAL SIZE S, ALPHAi PSM, SVM, SPM consumable parts
    A06B-6110-K210 CONNECTOR FOR ALPHA-i AMPLIFIE FOR CX2A TO CX2B consumable parts
    A06B-6111-H403 SSM-100 SUB MODULE SM FOR SYNCHRONOUS BUILT-IN SP.MOTOR Servo Units
    A06B-6114-H103 AMP. ALPHA iSV 1-20 FSSB Servo Units
    A06B-6114-H104 AMP. ALPHA iSV 1-40 FSSB Servo Units
    A06B-6114-H205 AMP. ALPHA iSV 2-20/20 FSSB Servo Units
    A06B-6114-H208 AMP. ALPHA iSV 2-40/80 FSSB Servo Units
    A06B-6114-H209 AMP. ALPHA iSV 2-80/80 FSSB Servo Units
    A06B-6114-H303 AMP. ALPHA iSV 3-20/20/20 FSSB Servo Units
    A06B-6114-K204/S CONNECTOR, MOTOR FEEDBACK FOR BETA M /ALPHAi, STRAIGHT consumable parts
    A06B-6114-K230/E CONNECTOR, MOTOR POWER FOR BETA M MOTOR consumable parts
    A06B-6114-K232/E CONNECTOR, MOTOR BRAKE FOR BETA M MOTOR consumable parts
    A06B-6120-H011 POWER SUPPLY ALPHA iPS 11HV 400V Servo Units
    A06B-6120-H018 POWER SUPPLY ALPHA iPS 18HV 400V Servo Units
    A06B-6120-H030 POWER SUPPLY ALPHA iPS 30HV 400V Servo Units
    A06B-6120-H045 POWER SUPPLY ALPHA iPS 45HV 400V Servo Units
    A06B-6120-H075 POWER SUPPLY ALPHA iPS 75HV 400V Servo Units
    A06B-6120-H100 POWER SUPPLY iPS 100HV 400V Servo Units
    A06B-6121-H006/H550 AMP. ALPHA iSP 5.5HV TYPE A Servo Units
    A06B-6121-H011/H550 AMP. ALPHA iSP 11HV TYPE A Servo Units
    A06B-6121-H030/H550 AMP. ALPHA iSP 30HV TYPE A Servo Units
    A06B-6122-H030/H550 AMP. ALPHA iSP 30HV TYPE B Servo Units
    A06B-6122-H045/H553 AMP. ALPHA iSP 45HV TYPE B, SYNCHRON Servo Units
    A06B-6124-H102 AMP. ALPHA iSV 1-10HV 400V, FSSB Servo Units
    A06B-6124-H104 AMP. ALPHA iSV 1-40HV 400V, FSSB Servo Units
    A06B-6124-H106 AMP. ALPHA iSV 1-180HV 400V, FSSB Servo Units
    A06B-6124-H202 AMP. ALPHA iSV 2-10/10HV 400V, FSSB Servo Units
    A06B-6124-H205 AMP. ALPHA iSV 2-20/20HV 400V, FSSB Servo Units
    A06B-6124-H207 AMP. ALPHA iSV 2-40/40HV 400V, FSSB Servo Units
    A06B-6124-H208 AMP. ALPHA iSV 2-40/80HV 400V, FSSB Servo Units
    A06B-6124-H209 AMP. ALPHA iSV 2-80/80HV 400V, FSSB Servo Units
    A06B-6127-H202 AMP. ALPHA iSV 2-10/10HV 400V, FSSB, 30i Servo Units
    A06B-6127-H207 AMP. ALPHA iSV 2-40/40HV 400V, FSSB, 30i Servo Units
    A06B-6127-H208 AMP. ALPHA iSV 2-40/80HV 400V, FSSB, 30i Servo Units
    A06B-6130-H001 SERVO AMPLIFIER BETA i SVM1-4i, WITH FSSB INTERFACE Servo Units
    A06B-6130-H002 SERVO AMPLIFIER BETA i SVM1-20i, WITH FSSB INTERFACE Servo Units
    A06B-6130-H003 SERVO AMPLIFIER BETA i SVM1-40i, WITH FSSB INTERFACE Servo Units
    A06B-6130-H401 SEP.REGENERATIVE RESISTOR FOR 4A 20A TYPE AMPLIFIER 20W Servo Units
    A06B-6130-K200 CONNECTOR KIT FOR CZ7 FOR BETAi consumable parts
    A06B-6130-K201 CONNECTOR KIT FOR CX19B/CX19A FOR BETAi consumable parts
    A06B-6130-K202 CONNECTOR KIT FOR CA20 FOR BETA i consumable parts
    A06B-6130-K203 CONNECTOR KIT FOR CX29 FOR BETAi consumable parts
    A06B-6130-K204 CONNECTOR KIT FOR CX30 FOR BETAi consumable parts
    A06B-6132-H002 SERVO AMPLIFIER BETA i SVM1-20i, WITH I/O LINK OPTION Servo Units
    A06B-6150-H030 POWER SUPPLY ALPHA iPS 30HV 400 VAC INPUT Servo Units
    A13B-0154-B001 OPTICAL I/O LINK ADAPTOR consumable parts
    A13L-0197-0001/F0083 VARIABLE RESISTANCE consumable parts
    A14B-0061-B002 POWER SUPPLY UNIT consumable parts
    A14B-0067-B002 POWER SUPPLY UNIT consumable parts
    A14B-0076-B001 INPUT UNIT L consumable parts
    A14B-0082-B211 POWER SUPPLY UNIT FOR LASER consumable parts
    A15L-0001-0060/A CONNECTOR UNIT FOR 2 SLOTS consumable parts
    A15L-0001-0077/K1 CABLE consumable parts
    A16B-1010-0285 PCB - MASTER FS-0B 3/4 AXIS PCB
    A16B-1100-0200 PCB - AC SPINDLE CONTROL DIG PCB
    A16B-1200-0670 PCB - AC SERVO CONTROL DIGITAL PCB
    A16B-1200-0800 PCB - AC SERVO CONTROL DIGITAL PCB
    A16B-1210-0560 PCB - POWER SUPPLY PCB
    A16B-1211-0850 PCB - POWER SUPPLY PCB
    A16B-1211-0970 PCB - I/O E3 104/72 PCB
    A16B-1212-0100 PCB - POWER SUPPLY PCB
    A16B-1212-0110 PCB - POWER SUPPLY B2 PCB
    A16B-1212-0210 PCB - MEMORY PCB
    A16B-1212-0871 PCB - POWER SUPPLY B1 PCB
    A16B-1212-0901 PCB - POWER SUPPLY A1 PCB
    A16B-1212-0950 PCB - POWER SUPPLY CE MARK PCB
    A16B-1213-0070 PCB - POWER SUPPLY PCB
    A16B-1213-0160 PCB - POWER SUPPLY PCB
    A16B-1213-0161 PCB - POWER SUPPLY PCB
    A16B-1310-0010 PCB - POWER SUPPLY PCB
    A16B-1310-0380 PCB - OPERATORS PANEL PCB
    A16B-2200-0120 PCB - BASE 0 512 KB PCB
    A16B-2200-0121 PCB - BASE 0 512 KB PCB
    A16B-2200-0131 PCB - BASE 1 WITH DRAM 512 KB PCB
    A16B-2200-0360 PCB - 3/4 AXIS CONTROL PCB
    A16B-2200-0390 PCB - 4 AXIS CONTROL SERIAL PCB
    A16B-2201-0101 PCB - MEMORY WITH SERIAL SPINDLE PCB
    A16B-2201-0103 PCB - MEMORY PCB
    A16B-2201-0110 PCB - OP.PANEL CONTROL PCB
    A16B-2202-0421 PCB - ALPHA PSU CONTROL PSM 15 PCB
    A16B-2202-0710 PCB - MAIN POWER MATE E PCB
    A16B-2202-0831 PCB - SERVO POWER PM-E PCB
    A16B-2203-0110 PCB - I/O C7 104/72 PCB
    A16B-2203-0332 PCB - ALPHA SPINDLE CONTROL PCB
    A16B-3200-0260 PCB - MAIN CPU PCB
    A16B-3200-0425 PCB - MASTER 21/210iS-B PCB
    A16B-3200-0495 PCB - MASTER PCB
    A17B-3300-0201 PCB - AXIS CARD i - SERIES PCB
    A20B-0009-0320 PCB - DC SERVO CONTROL PCB
    A20B-1000-0560 PCB - AC-SERVO CONTROL PCB
    A20B-1001-0120 PCB - AC SPINDLE DIG CONTROL PCB
    A20B-1001-0160 PCB - PSU 9" CRT/MDI MONO PCB
    A20B-1001-0720 PCB - SOFT KEY PCB
    A20B-1003-0010 PCB - AC SPINDLE CONTROL PCB
    A20B-1003-0020 PCB - POWER (WIRING) PCB
    A20B-1003-0080 PCB - SERVO WIRING DIGITAL PCB
    A20B-1003-0081 PCB - SERVO WIRING DIGITAL PCB
    A20B-1003-0090 PCB - AC SERVO CONTROL DIGITAL PCB
    A20B-1003-0230 PCB - BACKPLANE 13 SLOT PCB
    A20B-1006-0271 PCB - SOFT KEY FS-21B PCB
    A20B-2000-0170 PCB - MASTER A FS-0C 32 BIT PCB
    A20B-2000-0175 PCB - MASTER A FS-0C 32 BIT PCB
    A20B-2002-0470 PCB - I/O CARD PCB
    A20B-2002-0520 PCB - I/O CARD WITH MPG PCB
    A20B-2002-0521 PCB - I/O CARD WITHOUT MPG PCB
    A20B-2003-0150 PCB - BACK PLANE 2 SLOTS PCB
    A20B-2100-0540 PCB - ALPHA SERVO CONTROL FSSB PCB
    A20B-2100-0541 PCB - ALPHA SERVO CONTROL FSSB PCB
    A20B-2100-0543 PCB - ALPHA SERVO CONTROL FSSB PCB
    A20B-2100-0762 PCB - CONTROL BOARD ALPHA I PCB
    A20B-2100-0920 PCB - POWER SUPPLY PCB
    A20B-2101-0041 PCB - CONTROL BOARD FOR ALPHA i SERVO PCB
    A20B-2101-0050 PCB - BETA i AMPLIFIER CONTROL PCB
    A20B-2101-0392 PCB - CONTROL BOARD FOR ALPHA i SPM PCB
    A20B-2900-0380 PCB - SERVO INTERFACE MODULE PCB
    A20B-2900-0620 PCB - DRIVER MODULE C-SERIES PCB
    A20B-2901-0360 PCB - SERVO MODULE PCB
    A20B-2902-0070 PCB - SERVO MODULE RAM 32KB PCB
    A20B-2902-0390 PCB - DRIVER MODULE PCB
    A20B-2902-0420 PCB - DIGITAL SERVO MODULE PCB
    A20B-3300-0032 PCB - SERVO CONTROL CARD 4 AXIS PCB
    A20B-3300-0120 PCB - SERVO CONTROL CARD PCB
    A20B-3300-0260 PCB - CPU CARD PENTIUM NEW PCB
    A20B-3300-0310 PCB - CPU CARD, DRAM 16MB PCB
    A20B-3300-0311 PCB - CPU CARD, DRAM 32MB PCB
    A20B-3300-0390 PCB - SERVO CARD UP TO 24 AXIS i-B SERIES PCB
    A20B-3300-0391 PCB - SERVO CONTROL WITH 6 AXIS SERVO CONTROL PCB
    A20B-3300-0392 PCB - SERVO CARD UP TO 16-AXIS i-B SERIES PCB
    A20B-3300-0472 PCB - CPU CARD A6 PCB
    A20B-3300-0479 PCB - CPU CARD D3 PCB
    A20B-3900-0020 PCB - SRAM MODULE 3MB PCB
    A20B-3900-0042 PCB - DRAM MODULE 4MB 4M PCB
    A20B-3900-0052 PCB - SRAM MODULE 512KB 512KB PCB
    A20B-3900-0060 PCB - SRAM MODULE 2MB 2M PCB
    A20B-3900-0061 PCB - SRAM MODULE 1MB PCB
    A20B-3900-0073 PCB - F ROM MODULE 6MB PCB
    A20B-3900-0131 PCB - DRAM MODULE 8MB 8M PCB
    A20B-3900-0132 PCB - DRAM MODULE 4MB PCB
    A20B-3900-0163 PCB - FROM 32MB / SRAM 1MB PCB
    A20B-3900-0170 PCB - ANALOG SPINDLE MODULE PCB
    A20B-3900-0222 PCB - FROM 16MB / SRAM 3MB PCB
    A20B-8001-0291 PCB - HSSB INTERFACE CONTROL 180 THIN SLOT PCB
    A20B-8001-0621 PCB - TOUCH PANEL CONTROL PCB
    A20B-8001-0630 PCB - SUB CPU PCB
    A20B-8001-0730 PCB - HSSB INTERFACE PCB
    A20B-8001-0920 PCB - INVERTER i - SERIES FOR 10.4" LCD PCB
    A20B-8001-0961 PCB - PC SIDE HSSB I/F BOARD 1 CHANNEL, TYPE 2 PCB
    A20B-8002-0020 PCB - CONTROL I/O OP.PANEL PCB
    A20B-8002-0251 PCB - BACKPANEL FOR PENTIUM M PANEL i PCB
    A20B-8100-0135 PCB - MASTER FS-18 i PCB
    A20B-8100-0663 PCB - MASTER FS-21i-B PMC-SB7 PCB
    A20B-8100-0665 PCB - MASTER FS-21i-B PMC-SB7 PCB
    A20B-8100-0670 PCB - FAST EHTERNET BOARD FOR STAND-ALONE TYPE PCB
    A20B-8101-0030 PCB - FAST DATA SERVER PCB
    A20B-8101-0360 PCB - PENTIUM M MAINBOARD PANEL i PCB
    A20B-8101-0368 PCB - MAINBOARD FOR PANEL i PCB
    A20B-8101-0500 PCB - MASTER BOARD DISPLAY UNIT WITH PC FUNCTION PANAL i PCB
    A210-0114-X032 FIXING RAIL consumable parts
    A230-0480-T001 FRAME FOR SPINDLE AMP. consumable parts
    A230-0533-X003 BATTERY CASE FOR BETA ABSOLUT PULSE CODER BATTERY consumable parts
    A230-0577-X002 COVER FOR I/O MODULE A03B-0815-C00X consumable parts
    A230-0602-T104 COVER consumable parts
    A230-0602-T109 BATTERY CASE FOR ALPHA SERIE (60mm/90mm MODEL) consumable parts
    A230-0604-T109 BATTERY CASE FOR ALPHA i SERIE (MODEL SVM1-360i, 360HVi) consumable parts
    A230-0604-X003 FAN COVER consumable parts
    A250-0620-T001 FRAME FOR CRT/MDI 9" SMALL consumable parts
    A250-0689-X006 FILTER consumable parts
    A250-0854-T003 COVER FOR 10.4" LCD i SERIES TOUCH PANEL W/O SOFTKEY consumable parts
    A250-0854-X020/C CASE 2 OPTION SLOTS W/O PC i SERIES consumable parts
    A250-0854-X021 DOOR FOR CASE W/ 2 OPTION SLOT i SERIES consumable parts
    A250-8002-Z350/064 SHORT BAR DC-LINK 64 MM ALPHA SERIES consumable parts
    A250-8002-Z350/085 SHORT BAR consumable parts
    A250-8002-Z350/090 SHORT BAR DC-LINK 90 MM ALPHA SERIES consumable parts
    A250-8002-Z350/154 SHORT BAR consumable parts
    A290-0121-X035 MOTOR COVER Motor parts
    A290-0141-X035 MOTOR COVER Motor parts
    A290-0371-X503 SMALL TYPE OLDHUMS COUPLING Motor parts
    A290-0501-V535 OLDHUM ASSY Motor parts
    A290-0501-X531 OLDHUMS COUPLING Motor parts
    A290-0561-V501 PULSE CODER PLATE:A860 Motor parts
    A290-0561-V502 PULSE CODER Motor parts
    A290-0561-V503 PULSE CODER LPLATE:A860 INCREMENTAL ENCODER 3000 PULSE Motor parts
    A290-0601-V001 BRUSH, AXIS Motor parts
    A290-0601-X713 BRUSH FOR TACHOGENERATOR Motor parts
    A290-0632-V001 BRUSH OOM Motor parts
    A290-0641-V001 BRUSH, AXIS Motor parts
    A290-0651-V001 BRUSH Motor parts
    A290-0651-V511 PULSE COD 2000P<7R LPLATE:A860 Motor parts
    A290-0651-X004 BRUSH CAP M10,20,30 Motor parts
    A290-0731-V410 COVER ASSEMBLY Motor parts
    A290-0731-X437 PLUG Motor parts
    A290-0817-V001 MOTOR BRUSH Motor parts
    A290-0820-V001 BRUSH Motor parts
    A290-0850-T500 FAN ASSEMBLY Motor parts
    A290-0850-T511 FAN ASSEMBLY Motor parts
    A290-0853-V350 SENSOR ASS'Y Motor parts
    A290-0854-V320 PULSE GENERATOR Motor parts
    A290-0854-V330 PULSE GENERATOR Motor parts
    A290-0854-V350 PULSE GENERATOR Motor parts
    A290-0856-X501 FAN COVER Motor parts
    A290-1003-T500 FAN MOTOR ASSY Motor parts
    A290-1003-X003 GEAR Motor parts
    A290-1012-T500 FAN MOTOR ASSY Motor parts
    A290-1406-T500 FAN UNIT ASSEMBLY Motor parts
    A290-1406-V410 COVER FOR TERMINAL BOX Motor parts
    A290-1502-T501 FAN ASSY Motor parts
    A290-1619-T231 ROTOR FOR BUILT IN SPINDLE MOTOR ALPHA 50LL/12500i Motor parts
    A290-4513-X252 CAP Laser Parts
    A290-4516-T020 DISCHARGE TUBE Laser Parts
    A290-4533-T001 DISCHARGE TUBE Laser Parts
    A290-4540-V170 OIL MIST CLEANER C4000-E Laser Parts
    A290-4541-T001 DISCHARGE TUBE Laser Parts
    A300-0001-0022/L10 STUD BOLT consumable parts
    A300-0001-X133 SCREW i SERIES FOR NEW PLASTIC CASE consumable parts
    A300-0009-X352 GASKET FOR C SERIES SERVO AMP. consumable parts
    A30L-0010-0075/3X6 SCREW M3X6 consumable parts
    A370-3083-0039 WARNING LABEL FOR ALPHI i PSM, SVM, SPM IN FRENCH consumable parts
    A370-3083-0040 WARNING LABEL FOR BATTERYCOVER FOR ALPHA i SVM IN FRENCH consumable parts
    A45L-0001-0329 CHOKE COIL consumable parts
    A50L-0001-0091 TRANSISTOR MODULE FUJI EVK31-050 consumable parts
    A50L-0001-0096/AM TRANSISTOR MODULE FUJI EVK 71-060D consumable parts
    A50L-0001-0109/M TRANSISTOR MODULE FUJI EVL32-060D consumable parts
    A50L-0001-0118/A TRANSISTOR MODULE FUJI 2DI75S-050A consumable parts
    A50L-0001-0125/A TRANSISTOR MODULE FUJI 6DI50A-060 consumable parts
    A50L-0001-0175/M TRANSISTOR MODULE FUJI 6DI120D-060 consumable parts
    A50L-0001-0178 TRANSISTOR MODULE FUJI 6DI85A-060 consumable parts
    A50L-0001-0179/30A TRANSISTOR REGENERATIVE FUJI 1DI30A-060 consumable parts
    A50L-0001-0209 TRANSISTOR MODULE FUJI 6DI150A-060 consumable parts
    A50L-0001-0221 TRANSISTOR MODULE FUJI 6MBPI150FA-060 consumable parts
    A50L-0001-0295/NS TRANSISTOR MODULE FUJI 1MBI600NN-060-03 consumable parts
    A50L-0001-0327 TRANSISTOR MODULE consumable parts
    A50L-0001-0329 TRANSISTOR MODULE FUJI 6MBP80RTA060-01 consumable parts
    A50L-0001-0331 TRANSISTOR MODULE FUJI 6MBP100RTA060-01 consumable parts
    A50L-0001-0337 TRANSISTOR MODULE FUJI 2MBI200TA-060-01 consumable parts
    A50L-0001-0338 TRANSISTOR MODULE FUJI 2MBI300TA-060-01 consumable parts
    A50L-0001-0340 TRANSISTOR MODULE FUJI 2MBI400TB-060-01 consumable parts
    A50L-0001-0342 TRANSISTOR MODULE FUJI 2MBI200TC-060-01 consumable parts
    A50L-0001-0384 TRANSISTOR MODULE FUJI 6MBP50RTF060-01 consumable parts
    A50L-2001-0257/R DIODE FOR LASER consumable parts
    A50L-2001-0439 DIODE MODULE USR120PP6A 32A ONLY FOR LASER consumable parts
    A50L-5000-0029/50 THYRISTOR MODULE PDT508 consumable parts
    A50L-8101-0033/100H THERMISTOR consumable parts
    A55L-0001-0041/904O SCREEN consumable parts
    A55L-0001-0241/02R ESP SWITCH consumable parts
    A55L-0001-0267/3BM1C1LZ SWITCH consumable parts
    A55L-0001-0267/3K2C1A KEY SWITCH FOR OPERATORS PANEL A02B-0236-C232 / C233 consumable parts
    A56L-0001-0109/PG0020DA ROTARY SWITCH consumable parts
    A56L-0001-0109/PG0020FA ROTARY SWITCH OPERATORS PANEL 21 POLE consumable parts
    A56L-0001-0109/PG0022FA ROTARY SWITCH OPERATORS PANEL consumable parts
    A56L-0001-0109/PR0020DA ROTARY SWITCH OPERATORS PANEL A02B-0080-C141 / C142 consumable parts
    A56L-0001-0134/2A2B ESP SWITCH consumable parts
    A57L-0001-0037 MAGNETIC SENSOR WITH HEAD FSH-137B consumable parts
    A57L-0001-0037/B SENSOR HEAD consumable parts
    A57L-0001-0037/N MAGNETIC SENSOR N, 12000 RPM WITH HEAD FSH-137B consumable parts
    A58L-0001-0337 MAGNETIC CONTACTOR consumable parts
    A60L-0001-0031/5A FUSE 5 A, GLASS TYPE 31X6.3MM consumable parts
    A60L-0001-0036/PC1-30 FUSE PC1-30, 30 A 50 x 15 mm consumable parts
    A60L-0001-0039/M-5 FUSE M-5, 5 A GLASS TUBE 32 x 6 mm consumable parts
    A60L-0001-0046/0.32 FUSE MP032, 0.32 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/0.5 FUSE MP05, 0.5 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/1.0 FUSE MP10, 1.0 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/1.6 FUSE MP16, 1.6 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/2.0 FUSE MP20, 2.0 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/3.2 FUSE MP32, 3.2 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/5.0 FUSE MP50, 5.0 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/5.0R FUSE MP50, 5.0 A REVERSE LABEL WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/6.3 FUSE MP63, 6.3 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/7.5 FUSE MP75, 7.5 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0046/7.5R FUSE MP75, 7.5 A REVERSE LABEL WITH ALARM INDICATOR consumable parts
    A60L-0001-0075/1.6 FUSE SMP16, 1.6 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0075/2.0 FUSE SMP20, 2.0 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0075/3.2 FUSE SMP32, 3.2 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0075/5.0 FUSE SMP50, 5.0 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0101/P405H FUSE P405H, 0.5 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P4100H FUSE P4100H, 10 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P413H FUSE P413H, 1.3 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P420H FUSE P420H, 2 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P430H FUSE P430H, 3.0 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P435H FUSE P435H, 3.5 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P450H FUSE P450H, 5.0 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0101/P475H FUSE P475H, 7.5 A ALARM FUSE BLACK, 250V AC consumable parts
    A60L-0001-0118 FUSE PL4150S, 15 A ALARM FUSE BROWN consumable parts
    A60L-0001-0127/25FH75 FUSE 25FH75, 75 A SCREW M4/42MM consumable parts
    A60L-0001-0145 FUSE 25SH100, 100 A SCREW M6/59MM consumable parts
    A60L-0001-0147 FUSE 25FH50, 50 A SCREW M4/42MM consumable parts
    A60L-0001-0149 FUSE 25SH140, 140 A SCREW M6/59MM consumable parts
    A60L-0001-0163 FUSE 25SH150, 150 A SCREW M6/59MM consumable parts
    A60L-0001-0172/DM03 FUSE DM03, 0.3 A GRID 2.5 MM 1/10 INCH consumable parts
    A60L-0001-0172/DM10 FUSE DM10, 1.0 A GRID 2.5 MM 1/10 INCH consumable parts
    A60L-0001-0172/DM20 FUSE DM20, 2.0 A GRID 2.5 MM 1/10 INCH consumable parts
    A60L-0001-0172/DM32 FUSE DM32, 3.2 A GRID 2.5 MM 1/10 INCH consumable parts
    A60L-0001-0175/0.3A FUSE HM03, 0.3 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0175/0.5A FUSE HM05, 0.5 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0175/1.0A FUSE HM10, 1.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0175/2.0A FUSE HM20, 2.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0175/3.2A FUSE HM32, 3.2 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0175/5.0A FUSE HM50, 5.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0183/100AS FUSE RAPID 100 A QFS25U-100 SCREW M4/42MM consumable parts
    A60L-0001-0183/200A FUSE CR2L-200, 200 A consumable parts
    A60L-0001-0194/3.2 FUSE HP32, 3.2 A consumable parts
    A60L-0001-0194/5.0 FUSE HP50, 5 A CNC POWER SUPPLY consumable parts
    A60L-0001-0197/PC2F-50 FUSE PC2F-50, 50A 50 x 15 mm consumable parts
    A60L-0001-0208/150A FUSE SHB150, 150 A SCREW M8/82MM consumable parts
    A60L-0001-0245/GP100 FUSE GP100, 10 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0245/GP20 FUSE GP20, 2 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0245/GP32 FUSE GP32, 3.2 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0245/GP50 FUSE GP50 5 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0245/GP75 FUSE GP75 7.5 A WITH ALARM INDICATOR consumable parts
    A60L-0001-0276/3.15 FUSE 218/3.15 A consumable parts
    A60L-0001-0290/LM03 FUSE LM03, 0.3 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0290/LM10 FUSE LM10, 1.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0290/LM20 FUSE LM20, 2.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0290/LM20C FUSE LM20C, 2.0 A consumable parts
    A60L-0001-0290/LM32 FUSE LM32, 3.2 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0290/LM32C FUSE LM32C, 3.2 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0290/LM50 FUSE LM50, 5.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0290/LM50C FUSE LM50C, 5.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0359 FUSE MINI FOR AMPLIFIER 5.0 A GRID 5 MM 1/5 INCH consumable parts
    A60L-0001-0396/8.0A FUSE consumable parts
    A61L-0001-0074 CRT COLOR 14" FS-10/11 consumable parts
    A61L-0001-0092 CRT MONOCHROME 9" YELLOW FS-0 consumable parts
    A61L-0001-0093 CRT MONOCHROME 9" FS-0, FS-16 consumable parts
    A61L-0001-0094 CRT COLOR 14" FS-15A consumable parts
    A61L-0001-0094/A CRT 14" COLOR FS-15A consumable parts
    A61L-0001-0096 CRT COLOR 14" FS-16B/18B consumable parts
    A61L-0001-0142 LCD MONOCHROME 7.2" i SERIES consumable parts
    A61L-0001-0142/BLS BACKLIGHT FOR 7,2 " LCD (SHARP consumable parts
    A61L-0001-0154 LCD MONOCHROME 9.5" i SERIES consumable parts
    A61L-0001-0168 LCD COLOR 10.4" i SERIES consumable parts
    A61L-0001-0168/BL BACKLIGHT FOR LCD 10.4" (SHARP LQ1DD367, LQ1DD368) consumable parts
    A61L-0001-0168/BLN BACKLIGHT FOR LCD 10.4" (NEC NL6448BC33-49) consumable parts
    A61L-0001-0168/BLS BACKLIGHT FOR LCD 10.4" (SHARP LQ1DD368A/SA) consumable parts
    A620-0002-T083 KNOB FOR ROTARY SWITCH FS-16 OPERATORS PANEL consumable parts
    A63L-0001-0133/23A CONNECTOR HONDA MR-20RMH consumable parts
    A63L-0001-0133/24A CONNECTOR HONDA MR-20RFH consumable parts
    A63L-0001-0134/01 CONNECTOR HONDA 50 PIN FEMALE consumable parts
    A63L-0001-0134/02 CONNECTOR HONDA 20 PIN FEMALE MR-20LFH consumable parts
    A63L-0001-0134/101 CONNECTOR,50PINS FEM./SOLDER consumable parts
    A63L-0001-0134/11 CONNECTOR 50 PIN MALE consumable parts
    A63L-0001-0134/12 CONNECTOR HONDA 20 PIN MALE STANDARD CASE consumable parts
    A63L-0001-0135/F112 CONTACT DOUBLE PIN GOLD PLATED consumable parts
    A63L-0001-0219/12-C00 PLUG HOUSING consumable parts
    A63L-0001-0220/UN689-6 PIN consumable parts
    A63L-0001-0220/UN690-1 PIN consumable parts
    A63L-0001-0226 PIN FOR CONNECTOR (SILVER) FOR A63L-0001-0202/XXX consumable parts
    A63L-0001-0399/20FA-CA HONDA CONNECTOR + CASE 20 PIN FOR PRESSING PCR-E20FA-V20LA consumable parts
    A63L-0001-0399/20FH-CD HIROSE CONNECTOR + CASE, 20 PI SOLDERING FI40B-20S-FI-20-CV5 consumable parts
    A63L-0001-0399/20FP HONDA CONNECTOR 15 PIN FOR SOLDERING consumable parts
    A63L-0001-0399/20FP-CB HONDA CONNECTOR + CASE 15 PIN SOLDERING FI40B-2015S-FI-20-CV consumable parts
    A63L-0001-0399/20FS-CA HONDA CONNECTOR + HOUSING 20 PIN SOLDER PCR-E20FS-V20LA consumable parts
    A63L-0001-0399/20FS-SA CONNECTOR, SOLDER, CABLE SIDE NC-SPM(C), SPM-SPM, LOAD/SPEED consumable parts
    A63L-0001-0406/SY TERMINAL BLOCK FOR I/O MODULE A03B-0807-CXXX consumable parts
    A63L-0001-0428/CT CONNECTOR FOR MAIN POWER SERVO MOTOR 2-0S consumable parts
    A63L-0001-0456/AS CONTACT GOLD PLATED FOR WIRE UP TO 0.2MM consumable parts
    A63L-0001-0456/ASL CONTACT GOLD PLATED FOR WIRE UP TO 1.42MM consumable parts
    A63L-0001-0456/ASM-H CONTACT consumable parts
    A63L-0001-0456/ASMT CONTACT GOLD PLATED consumable parts
    A63L-0001-0456/BSL CONTACT TIN PLATED FOR WIRE UP TO 1.42MM consumable parts
    A63L-0001-0460/025KD CONNECTOR HOUSING 2 PIN BETA AMPLIFIER consumable parts
    A63L-0001-0460/3HKX CONNECTOR FOR POWER SUPPLY 3 PIN 220V AC X CODE consumable parts
    A63L-0001-0472/S20 CONNECTOR consumable parts
    A63L-0001-0508/201S CONNECTOR consumable parts
    A63L-0001-0616/B1810SK PLUG CONNECTOR POWER LINE consumable parts
    A63L-0001-0648/21810PH PLUG CONNECTOR ALPHA SER. consumable parts
    A63L-0001-0829/P1 CONNECTOR consumable parts
    A63L-0001-0848/CB CONNECTOR consumable parts
    A63L-0001-0875/EC CONNECTOR consumable parts
    A63L-0001-0875/SC CONNECTOR consumable parts
    A63L-0001-0923/CA CONNECTOR STRAIGHT FEEDBACK BETA M /ALPHAi consumable parts
    A63L-0001-0923/CB CONNECTOR ELBOW FOR FEEDBACK BETA M /ALPHAi consumable parts
    A63L-0001-0931/K2 SET OF 10 GASKETS, RUBBER CAP COVER, SCREWS, TERMINAL consumable parts
    A65L-0001-0630/SD SHORT BAR consumable parts
    A660-2003-T221/L14R03 CABLE consumable parts
    A660-2004-T189/L240R0 CABLE consumable parts
    A660-2004-T259/L7R003 CABLE consumable parts
    A660-2004-T411/L12R03A CABLE consumable parts
    A660-2005-T626/L200R0A CABLE consumable parts
    A660-2040-T045/34B0020 CABLE consumable parts
    A660-2040-T189/0100 EXTENSION CABLE A FOR I/O MODULE consumable parts
    A660-8011-T605/L5R003 BATTERY CABLE consumable parts
    A66L-2003-0497/L2R003 SIGNAL CABLE FOR DPL/MDI, 2M consumable parts
    A66L-2050-0010/A CABLE FOR MEMORY CARD i SERIES consumable parts
    A66L-2050-0010/B CABLE FOR MEMORY CARD consumable parts
    A66L-2050-0025/A FLAT CABLE FOR PCMCIA SLOT consumable parts
    A66L-2050-0025/B FLAT CABLE FOR PCMCIA SLOT consumable parts
    A66L-6001-0023/L150R0 OPTICAL FIBER CABLE 0.15M, INSIDE CABINET consumable parts
    A66L-6001-0023/L1R003 OPTICAL FIBER CABLE 1M, INSIDE CABINET consumable parts
    A66L-6001-0023/L2R003 OPTICAL FIBER CABLE 2M, INSIDE CABINET consumable parts
    A66L-6001-0023/L300R0 OPTICAL FIBER CABLE 0.3M, INSIDE CABINET consumable parts
    A66L-6001-0023/L3R003 OPTICAL FIBER CABLE 3M, INSIDE CABINET consumable parts
    A66L-6001-0023/L500R0 OPTICAL FIBER CABLE 0.5M, INSIDE CABINET consumable parts
    A66L-6001-0026/L10R03 OPTICAL FIBER CABLE 10M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L15R03 OPTICAL FIBER CABLE 15M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L1R003 OPTICAL FIBER CABLE 1M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L20R03 OPTICAL FIBER CABLE 20M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L2R003 OPTICAL FIBER CABLE 2M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L30R03 OPTICAL FIBER CABLE 30M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L3R003 OPTICAL FIBER CABLE 3M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L5R003 OPTICAL FIBER CABLE 5M, HSSB/FSSB, REINFORCED consumable parts
    A66L-6001-0026/L7R003 OPTICAL FIBER CABLE 7M, HSSB/FSSB, REINFORCED consumable parts
    A6-N1-8S NUT M8 consumable parts
    A6-SSA-4X8S SCREW consumable parts
    A6-SW2NA-3X6S SCREW M3X6 consumable parts
    A6-SW2NA-3X8S SCREW M3X8 consumable parts
    A6-SW2NA-5X16S SCREW consumable parts
    A6-WM-8S WASHER FOR M8 SCREW consumable parts
    A860-0106-X015 KEY TOP RED consumable parts
    A860-0106-X016 KEY TOP GREEN consumable parts
    A860-0203-T001 MANUAL PULSE GENERATOR consumable parts
    A860-0203-T014 MANUAL PULSE GENERATOR G PENDANT TYPE consumable parts
    A860-0301-T002 INCREMENTAL PULSE CODER UNIT 2500 PPR, 2400 RPM consumable parts
    A860-0309-T302 ALPHA POSITION CODER 1024 PPR, 10000 RPM consumable parts
    A860-0309-T352 ALPHA POSITION CODER S 10.000 RPM, SPM TYPE B consumable parts
    A860-0315-T102 PULSE CODER 2500P consumable parts
    A860-0319-T002 HIGH-RESOLUTION POSITION CODER 360000/1024 PPR, 8000RPM consumable parts
    A860-0333-T801 HI-RESOLUTION SERIAL OUTPUT CI CIRCUIT C consumable parts
    A860-0346-T041 SENSOR W/COVER consumable parts
    A860-0346-T141 PULSE CODER ABS consumable parts
    A860-0360-T001 PULSE CODER ALPHA consumable parts
    A860-0360-T021 PULSE CODER consumable parts
    A860-0360-T211 PULSE CODER consumable parts
    A860-0360-V501 PULSE CODER ALPHA consumable parts
    A860-0360-V511 PULSE CODER consumable parts
    A860-0360-V906 CABLE ASSEMBLY consumable parts
    A860-0365-T001 PULSE CODER consumable parts
    A860-0365-T101 PULSE CODER consumable parts
    A860-0365-V501 ALPHA PULSE CODER consumable parts
    A860-0372-T001 PULSE CODER ALPHA A1000S 1000000 PPR, 4000RPM consumable parts
    A860-0390-X001 SENSOR GEAR consumable parts
    A860-0390-X011 Z PHASE RING consumable parts
    A860-0392-T011 BZ SENSOR 256 TEETH 128 TEETH, MAX. 15000 RPM consumable parts
    A860-0392-V160 BUILT-IN SENSOR consumable parts
    A860-0392-V166 BUILT-IN SENSOR consumable parts
    A860-2000-T301 a1000i ABSOLUTE PULSE CODER WITH OLDHAM COUPLING, IP65 consumable parts
    A860-2000-T321 PULSE CODER consumable parts
    A860-2001-T301 A16000I PULSE CODER WITH OLDHAM COUPLING, IP65 consumable parts
    A860-2001-T321 A16000I PULSE CODER consumable parts
    A860-2002-T321 A1000i ABSOLUTE PULSE CODER WITH OLDHAM COUPLING, IP67 consumable parts
    A860-2005-T301 I1000I PULSE CODER consumable parts
    A860-2020-T301 PULSECODER consumable parts
    A860-2100-V001 Mi SENSOR consumable parts
    A860-2110-V001 MZi SENSOR consumable parts
    A860-2120-T401 iBZ SENSOR 256 TEETH STANDARD SPEED,(MAX15.000) RPM consumable parts
    A860-2120-T511 iBZ SENSOR 384 TEETH STANDARD SPEED,(MAX15.000) RPM consumable parts
    A860-2120-V003 SENSOR ASSEMBLY consumable parts
    A860-2150-V001 BZi SENSOR 512 TEETH consumable parts
    A86L-0001-0125 KEY BOARD FOR CRT/MDI FANUC SYSTEM 0 consumable parts
    A86L-0001-0126 KEY BOARD FOR OPERATORS PANEL FANUC SYSTEM 0 consumable parts
    A86L-0001-0127 KEYBOARD FOR 0T/0P consumable parts
    A86L-0001-0237 54 KEYS KEYBOARD OT/OM, PCB consumable parts
    A86L-0001-0252/TBS MDI (STANDARD)SYMBOLIC KEY consumable parts
    A86L-0001-0261 SOFT KEYS 10.4" LCD i - SERIES consumable parts
    A86L-0001-0287 SOFTKEY consumable parts
    A86L-0001-0290/A KEYBOARD SOFTKEY consumable parts
    A86L-0001-0298 KEYBOARD consumable parts
    A86L-0001-0301 SOFTKEY consumable parts
    A87L-0001-0180 FLASH MEMORY CARD 4MB consumable parts
    A87L-0001-0186/40GA HDD 40 GB consumable parts
    A90L-0001-0049/V FAN MOTOR consumable parts
    A90L-0001-0219/A FAN MOTOR consumable parts
    A90L-0001-0219/A-L FAN MOTOR consumable parts
    A90L-0001-0316/R FAN MOTOR consumable parts
    A90L-0001-0317/R FAN MOTOR consumable parts
    A90L-0001-0335/B FAN MOTOR FOR ALPHA UNIT 150MM 220V AC EXTERNAL consumable parts
    A90L-0001-0335/B-L FAN MOTOR FOR ALPHA UNIT 150MM 220V AC EXTERNAL consumable parts
    A90L-0001-0378 FAN MOTOR 2.4W consumable parts
    A90L-0001-0385/A FAN MOTOR FOR ALPHA UNIT 40MM 24V DC INTERNAL consumable parts
    A90L-0001-0385/B FAN MOTOR FOR ALPHA UNIT 60MM 24V DC INTERNAL consumable parts
    A90L-0001-0385/C FAN MOTOR consumable parts
    A90L-0001-0385/T FAN consumable parts
    A90L-0001-0396/T COOLING FAN FOR MATCHING BOX consumable parts
    A90L-0001-0396/TPC COOLING FAN consumable parts
    A90L-0001-0396-L FAN MOTOR consumable parts
    A90L-0001-0422 FAN MOTOR FOR ALPHA UNIT 80MM 24V DC INTERNAL consumable parts
    A90L-0001-0423/105 FAN MOTOR FOR ALPHA UNIT + CNC 60 x 60 mm, 24V DC INTERNAL consumable parts
    A90L-0001-0423/105S FAN MOTOR FOR ALPHA UNIT 60 x 60 mm, 24V DC INTERNAL consumable parts
    A90L-0001-0423/300 FAN MOTOR consumable parts
    A90L-0001-0425*LR VACUUM PUMP consumable parts
    A90L-0001-0441 FAN MOTOR FOR i SERIES 24V DC consumable parts
    A90L-0001-0441/100 FAN MOTOR consumable parts
    A90L-0001-0441/39 FAN MOTOR consumable parts
    A90L-0001-0441/400 FAN MOTOR consumable parts
    A90L-0001-0441/650 FAN MOTOR consumable parts
    A90L-0001-0442/R FAN MOTOR consumable parts
    A90L-0001-0443/R FAN KIT FOR EXHAUST FAN CABLE LENGHT 174 MM consumable parts
    A90L-0001-0443/RL FAN KIT FOR EXHAUST FAN CABLE LENGHT 510 MM consumable parts
    A90L-0001-0444/R FAN MOTOR consumable parts
    A90L-0001-0444/RS FAN KIT FOR EXHAUST FAN consumable parts
    A90L-0001-0455 FAN FOR SHUTTER consumable parts
    A90L-0001-0487 FAN consumable parts
    A90L-0001-0488 FAN MOTOR consumable parts
    A90L-0001-0491/F FAN MOTOR consumable parts
    A90L-0001-0506/105 FAN MOTOR consumable parts
    A90L-0001-0506/135 FAN MOTOR consumable parts
    A90L-0001-0506/280 FAN FOR REAR COVER (BIG) consumable parts
    A90L-0001-0507/A FAN consumable parts
    A90L-0001-0507/B FAN consumable parts
    A90L-0001-0508 FAN consumable parts
    A90L-0001-0509 FAN consumable parts
    A90L-0001-0510 FAN consumable parts
    A90L-0001-0511 FAN consumable parts
    A90L-0001-0515/R FAN consumable parts
    A90L-0001-0519/R FAN consumable parts
    A90L-0001-0519/RL FAN consumable parts
    A90L-0001-0528/70 FAN consumable parts
    A90L-0001-0538/R FAN consumable parts
    A90L-0001-0539/F FAN consumable parts
    A90L-0001-0541/F FAN MOTOR consumable parts
    A90L-0001-0541/R FAN MOTOR consumable parts
    A90L-0001-0548/R FAN consumable parts
    A90L-0001-0551/A FAN FOR BASIC UNIT, 40 mm consumable parts
    A90L-0001-0552/A FAN FOR BASIC UNIT, 60 mm consumable parts
    A91L-0001-0219 HOUR METER consumable parts
    A97L-0200-0649/2-2-S FILTER (QTY1) consumable parts
    A97L-0200-0666/8-75-S BOLT consumable parts
    A97L-0201-0211 CARTRIDGE FILTER (QTY1) consumable parts
    A980-0005-0283 PACKING (SPONGE) consumable parts
    A98L-0001-0481/M KEY SHEET FOR CRT/MDI 9" FS-12M consumable parts
    A98L-0001-0482/M KEY SHEET consumable parts
    A98L-0001-0482/T KEY SHEET consumable parts
    A98L-0001-0518/M02 KEY SHEET FOR CRT/MDI 9" FS-0 consumable parts
    A98L-0001-0518/MB KEY SHEET FOR SMALL-T ENGLISH FS-0T SMALL KEY SYMBOL consumable parts
    A98L-0001-0518/MR KEY SHEET FOR 9" SMALL M ENG. consumable parts
    A98L-0001-0518/T KEY SHEET FOR CRT/MDI 9" FS-0 consumable parts
    A98L-0001-0518/TB KEY SHEET FOR CRT/MDI 9" FS-0T SMALL KEY SYMBOL consumable parts
    A98L-0001-0518/TR KEY SHEET FOR SMALL-T ENGLISH FS-0T SMALL KEY consumable parts
    A98L-0001-0519 KEY SHEET FOR SOFTKEY 9" FS-0 consumable parts
    A98L-0001-0524/A KEY SHEET FOR OPERATORS PANEL A02B-0084-C141, A02B-0092-C141 consumable parts
    A98L-0001-0524/B KEY SHEET FOR OPERATORS PANEL A02B-0083-C141, A02B-0083-C160 consumable parts
    A98L-0001-0524/BI KEY SHEET FOR OPERATORS PANEL A02B-0091-C144 consumable parts
    A98L-0001-0524/BK KEY SHEET FOR OPERATORS PANEL A02B-0098-C150 consumable parts
    A98L-0001-0524/BL KEY SHEET FOR OPERATORS PANEL A02B-0098-C151, 0098-C170/BL consumable parts
    A98L-0001-0524/DP KEYSHEET TORNOS consumable parts
    A98L-0001-0524/F KEY SHEET FOR OPERATORS PANEL A02B-0083-C145 consumable parts
    A98L-0001-0524/J KEY SHEET FOR OPERATORS PANEL A02B-0084-C147 consumable parts
    A98L-0001-0524/K KEY SHEET FOR OPERATORS PANEL A02B-0083-C147 consumable parts
    A98L-0001-0524/M KEY SHEET consumable parts
    A98L-0001-0524/MB KEY SHEET FOR OPERATORS PANEL A02B-0099-C150/MB consumable parts
    A98L-0001-0524/MBR KEY SHEET consumable parts
    A98L-0001-0524/TB KEY SHEET FOR OPERATORS PANEL A02B-0098-C170//TB consumable parts
    A98L-0001-0524/TBR KEY SHEET consumable parts
    A98L-0001-0567/P02 MDI KEY SHEET consumable parts
    A98L-0001-0568/M02 KEY SHEET FOR CRT/MDI 9 FS-0M FULL KEY consumable parts
    A98L-0001-0568/MR KEY SHEET consumable parts
    A98L-0001-0568/T KEY SHEET FOR OT FULL KEY FS-0T consumable parts
    A98L-0001-0568/TB KEY SHEET FOR FULL T SYMBOL consumable parts
    A98L-0001-0568/TR KEY SHEET FOR FULL T ENG consumable parts
    A98L-0001-0615/B FOLDING MIRROR consumable parts
    A98L-0001-0616/C ZERO-DEGREE SHIFT MIRROR consumable parts
    A98L-0001-0617/C CIRCULAR POLARIZATION MIRROR consumable parts
    A98L-0001-0619/1025 O-RING consumable parts
    A98L-0001-0619/2030 O-RING consumable parts
    A98L-0001-0628/A KEY SHEET FOR CRT/MDI 14" FS-10/11/12 consumable parts
    A98L-0001-0628/E SURFACE SHEET(HORZ.10TF) consumable parts
    A98L-0001-0629 KEY SHEET OT/M SOFT KEY consumable parts
    A98L-0001-0630 KEY SHEET FOR SOFTKEY 14" FS-15 consumable parts
    A98L-0001-0633/M KEY SHEET FOR OPERATORS PANEL A02B-0092-C161 consumable parts
    A98L-0001-0633/MB KEY SHEET FULL OP.PANEL 0-M CE consumable parts
    A98L-0001-0633/T KEY SHEET FOR OPERATORS PANEL A02B-0092-C181, A02B-0092-C183 consumable parts
    A98L-0001-0633/TB KEY SHEET FULL OP.PANEL 0-T consumable parts
    A98L-0001-0633/TBR KEY SHEET consumable parts
    A98L-0001-0634/B KEY SHEET FOR FS-0M consumable parts
    A98L-0001-0646/A KEYSHEET FOR CRT/MDI 14" FS-15 consumable parts
    A98L-0001-0646/B KEYSHEET FOR CRT/MDI 14" FS-15 consumable parts
    A98L-0001-0646/C KEYSHEET FOR CRT/MDI 14" FS-15 consumable parts
    A98L-0001-0647/M KEYSHEET FOR CRT/MDI 9" FS-15 consumable parts
    A98L-0001-0756 OUTPUT MIRROR consumable parts
    A98L-0001-0757/B REAR MIRROR consumable parts
    A98L-0001-0866/B FOLDING MIRROR consumable parts
    A98L-0003-0004/P22.4S O-RING consumable parts
    A98L-0003-0004/P26S O-RING consumable parts
    A98L-0003-0004/P30.6S O-RING DISCHARGE TUBE consumable parts
    A98L-0003-0004/P58 O-RING consumable parts
    A98L-0003-0015/D OUTPUT MIRROR consumable parts
    A98L-0003-0016/C REAR MIRROR consumable parts
    A98L-0003-0027 OUTPUT COUPLER consumable parts
    A98L-0003-0036 OUTPUT COUPLER consumable parts
    A98L-0003-0037 REAR MIRROR consumable parts
    A98L-0004-0096 BATTERY CASE-F3 consumable parts
    A98L-0004-0149 BATTERY CASE consumable parts
    A98L-0004-0249/HTCY0024 OIL SEAL consumable parts
    A98L-0004-0249/HTCY0035 OIL SEAL consumable parts
    A98L-0004-0348/2-N NYLON GAS FERRULE, 1/4 INCH consumable parts
    A98L-0004-0348/3-N NYLON GAS FERRULE, 3/4 INCH consumable parts
    A98L-0004-0348/4-N NYLON GAS FERRULE, 1/2 INCH consumable parts
    A98L-0004-0652/GS KNOB FOR ROTARY SWITCH A02B-0236-C232 / C233 consumable parts
    A98L-0004-0737/P22.4 O-RING consumable parts
    A98L-0004-0799/A RUBBER VR. ISOLATOR consumable parts
    A98L-0004-0799/B RUBBER VR. ISOLATOR consumable parts
    A98L-0004-0801/4-15 BOLT FOR TRIGGER ELECTRODE consumable parts
    A98L-0005-0032/B KEY SHEET consumable parts
    A98L-0005-0032/D COVER SHEET FOR CTRL OT-F consumable parts
    A98L-0005-0032/F KEY SHEET consumable parts
    A98L-0005-0032/Q KEY SHEET consumable parts
    A98L-0005-0181 BLANK KEY TOP (QTY 1) consumable parts
    A98L-0005-0187 TRIGGER ELECTRODE ASSEMBLY consumable parts
    A98L-0005-0252 SOFT KEYSHEET consumable parts
    A98L-0005-0255 KEYSHEET consumable parts
    A98L-0031-0005 BATTERY MONOBLOCK QTY 1 58X33MM consumable parts
    A98L-0031-0006 BATTERY LITHIUM 3V-POWER MATE PANASONIC CR17335SE-R 34X18MM consumable parts
    A98L-0031-0011 BATTERY LITHIUM 6V FOR PM ABSOLUT PULSCODER 50X28X14MM consumable parts
    A98L-0031-0011/L BATTERY LITHIUM 6V FOR BETA ABSOLUT PULSCODER 50X28X14MM consumable parts
    A98L-0031-0012 BATTERY LITHIUM 3V CNC CONTROL SANYO CR17450 SE-R 45X18MM consumable parts
    A98L-0031-0017 BATTERY FOR INTELL. TERMINAL consumable parts
    A98L-0031-0025 BATTERY FOR ABSOLUTE PULSE CODER SERVO AMPLIFIER consumable parts
    A98L-0031-0026 LITHIUM BATTERY FOR CONTROL UNIT FOR MEMORY BACKUP consumable parts
    A990-0163-0023 PROTECTION SHEET FOR 10.4" LCD UNIT consumable parts
    A990-0163-0026 PROTECTION SHEET FOR 7.2" LCD UNIT consumable parts
    A990-0165-0002 SHEET FOR TOUCH PANEL 12,1" consumable parts
    A990-0165-0004 PROTECTION SHEET FOR TOUCH PANEL 15,0" consumable parts
    A990-0165-0005 PROTECTION SHEET FOR TOUCH PANEL 7,2" consumable parts
    A990-0165-0011 PROTECTION SHEET consumable parts
    A99L-0035-0001 CABLE CLAMP METAL 14MM FOR G RAIL consumable parts
    A99L-0128-0002/14 LABEL consumable parts
    A99L-0164-0001 PEN FOR TOUCH PANEL LCD i SERIES consumable parts
    B-62760IT PARAMETER MANUAL 16/18-C ITALIAN Manuals
    B-63007EN HANDBOOK ENGLISH 16i/160i, 18i/180i-MODEL A Manuals
    B-63524CZ OPERATOR'S MANUAL CZECH 16i/18i/160i/180i-TB Manuals
    B-63524IT OPERATOR'S MANUAL ITALIAN 16i/18i/160i/180i-TB Manuals
    B-63524PL OPERATOR'S MANUAL POLISH 16i/18i/160i/180i-TB Manuals
    B-63524RU OPERATOR'S MANUAL RUSSIAN 16i/18i/160i/180i-TB Manuals
    B-63524SW OPERATOR'S MANUAL SWEDISH 16i/18i/160i/180i-TB Manuals
    B-63525CZ MAINTENANCE MANUAL CZECH i AND is SERIES - MODEL B Manuals
    B-63525EN MAINTENANCE MANUAL ENGLISH i AND is SERIES - MODEL B Manuals
    B-63525FR MAINTENANCE MANUAL FRENCH i AND is SERIES - MODEL B Manuals
    B-63525GE MAINTENANCE MANUAL GERMAN i AND is SERIES - MODEL B Manuals
    B-63525IT MAINTENANCE MANUAL ITALIAN i AND is SERIES - MODEL B Manuals
    B-63525RU MAINTENANCE MANUAL RUSSIAN i AND is SERIES - MODEL B Manuals
    B-63527EN OPERATION & MAINTENANCE HANDBOOK,i & is SERIES-MODEL B Manuals
    B-63530IT PARAMETER MANUAL ITALIAN 16i/160i/is/18i/180i/is-B Manuals
    B-63534CZ OPERATOR'S MANUAL CZECH 16i/16is-MB,18i/18is-MB + MB5 Manuals
    B-63534GE OPERATOR'S MANUAL GERMAN 16i/16is-MB,18i/18is-MB + MB5 Manuals
    B-63534PL OPERATOR'S MANUAL POLISH 16i/16is-MB,18i/18is-MB + MB5 Manuals
    B-63534SW OPERATOR'S MANUAL SWEDISH 16i/16is-MB,18i/18is-MB + MB5 Manuals
    B-63604CZ OPERATOR'S MANUAL CZECH 21i/210i-TB Manuals
    B-63604SW OPERATOR'S MANUAL SWEDISH 21i/210i-TB Manuals
    B-63614CZ OPERATOR'S MANUAL CZECH 21i/210i-MB Manuals
    B-63834CZ OPERATOR'S MANUAL, CZECH 0i-MODEL TB Manuals
    B-63874CZ OPERATOR'S MANUAL, CZECH MANUAL GUIDE i Manuals
    B-63874DU OPERATOR'S MANUAL, DUTCH MANUAL GUIDE i Manuals
    B-63874FI OPERATOR'S MANUAL, FINNISH MANUAL GUIDE i Manuals
    B-63874GE OPERATOR'S MANUAL, GERMAN MANUAL GUIDE i Manuals
    B-63874SW OPERATOR'S MANUAL, SWEDISH MANUAL GUIDE i Manuals
    B-63944CZ 30i/300i/300is CNC, CZECH USERS MANUAL TURNING/MILLING Manuals
    B-63944EN 30i/300i/300is CNC, ENGLISH USERS MANUAL TURNING/MILLING Manuals
    B-63944EN-1 USERS MANUAL (TURNING) ENGLISH, 30i/300i/300is CNC Manuals
    B-63944FR USERS MANUAL (TURNING/MILLING) FRENCH, 30i/300i/300is CNC Manuals
    B-63944GE-1 USERS MANUAL (TURNING) GERMAN, 30i/300i/300is CNC Manuals
    B-63944GE-2 USERS MANUAL (MILLING) GERMAN, 30i/300i/300is CNC Manuals
    B-63944SW-1 USERS MANUAL (TURNING) SWEDISH, 30i/300i/300is CNC Manuals
    B-63945EN SERIES 30i/300i/300is CNC MAINTENANCE MANUAL, ENGLISH Manuals
    B-63945FR MAINTENANCE MANUAL, FRENCH SERIES 30i/300i/300is CNC Manuals
    B-63945GE MAINTENANCE MANUAL, GERMAN SERIES 30i/300i/300is CNC Manuals
    B-63947EN SERIES 30i/300i/300is CNC OPER. & MAINT. MANUAL, ENGLISH Manuals
    B-64114CZ OPERATOR MANUAL, 0i-TC Czech Manuals
    B-64114PL OPERATOR MANUAL, 0i-TC POLISH Manuals
    B-64114SW 0i-TC, SWEDISH OPERATOR MANUAL Manuals
    B-64115CZ MAINTENANCE MANUAL, CZECH 0i / 0i MATE-C Manuals
    B-64115IT MAINTENANCE MANUAL, Italian 0i / 0i MATE-C Manuals
    B-64115PL MAINTENANCE MANUAL, POLISH 0i / 0i MATE-C Manuals
    B-64124CZ OPERATOR MANUAL, CZECH 0i-MC Manuals
    B-64124IT OPERATOR MANUAL, ITALIAN 0i-MC Manuals
    GFME-0004-ML quaeroCNC FOR ENDUSER Manuals
    GFTE-589-CZ TRAINING BOOK MANUAL GUIDE i PACK OF 1, CZECH Manuals
    GFTE-589-EN TRAINING BOOK MANUAL GUIDE i PACK OF 1, ENGLISH Manuals
    GFTE-589-FR TRAINING BOOK MANUAL GUIDE i PACK OF 1, FRENCH Manuals
    GFTE-589-GE TRAINING BOOK MANUAL GUIDE i PACK OF 1, GERMAN Manuals
    GFTE-598-CZ TRAINING BOOK MGi, MILLING PACK OF 1, CZECH Manuals
    GFTE-598-EN TRAINING BOOK MGi, MILLING PACK OF 1, ENGLISH Manuals
    GFTE-598-FR TRAINING BOOK MGi, MILLING PACK OF 1, FRENCH Manuals
    GFTE-598-GE TRAINING BOOK MGi, MILLING PACK OF 1, GERMAN Manuals
    JB-OR4D-G45 O-RING Laser Parts
    JB-OR4D-G55 O-RING Laser Parts
    JB-OR4D-P10 O-RING TRIGGER ELECTRODE Laser Parts
    JB-OR4D-P24 O-RING Laser Parts
    JB-OR4D-P28 O-RING Laser Parts
    JB-OR4D-P31 O-RING Laser Parts
    JB-OR4D-P34 O-RING Laser Parts
    JB-OR4D-P38 O-RING Laser Parts
    JB-OR4D-P41 O-RING Laser Parts
    LX02B-0100-K004/A SIGNAL CONNECTOR consumable parts
    LX02B-0100-K846 LED FOR OPERATOR PANEL LED MG T 13/4 YELLOW consumable parts
    LX02B-0121-K800 LIGHT BULB FOR OPERATOR PANEL consumable parts
    LX02B-0124-K002 VACUUM GREASE APIEZON L 50 G Laser Parts
    LX02B-0124-K003 LENS CLEANING TIS. WHAT2105841 10X15CM, 1 SET OF 625 SHEETS Laser Parts
    LX02B-0124-K006 ACRYLIC BLOCK 250X50X30 MM Laser Parts
    LX02B-0126-K001 MEMORY CARD ADAPTOR consumable parts
    LX63L-0001-0203/2029W CONNECTOR, SOLDER TYPE SIZE 2029SW, ELBOW cable
    LX63L-0001-0207/1810 CONNECTOR, SOLDER TYPE SIZE 18-10S, ELBOW cable
    LX660-2007-T010/L10R03 I/O LINK SIGNAL CABLE PVC CABLE JACKET cable
    LX660-2007-T010/L1R003 I/O LINK SIGNAL CABLE PVC CABLE JACKET cable
    LX660-2007-T012/L500R0 I/O LINK SIGNAL CABLE cable
    LX660-2077-T220/L200R0 SERVO SIGNAL CABLE ALPHA i SERIES AMPLIFIER cable
    LX660-2077-T220/L300R0 SERVO SIGNAL CABLE ALPHA i SERIES AMPLIFIER cable
    LX660-2077-T220/L500R0 SERVO SIGNAL CABLE ALPHA i SERIES AMPLIFIER cable
    LX660-2077-T222/L300R0 SIGNAL CABLE SERVO AMPLIFIER BETA i SERIES cable
    LX660-4024-T012/L5R003 SIGNAL CABLE RS232C cable
    LX660-4024-T023/L2R003 SIGNAL CABLE HANDY MACHINE OPERATOR'S PANEL cable
    LX660-4077-T201/L12R03 SERVO SIGNAL CABLE cable
    LX660-4077-T201/L8R003 SERVO SIGNAL CABLE cable
    LX660-4077-T215/L8R003 SPINDLE MOTOR THERMOSTAT CABLE FOR ALPHA SPMC AMPLIFIER cable
    LX660-4077-T216/L8R003 SPINDLE MOTOR THERMOSTAT CABLE cable
    LX660-4077-T218/L7R003 SPINDLE SIGNAL CABLE STRAIGHT cable
    LX660-4077-T260/L5R003 SERVO SIGNAL CABLE STRAIGHT cable
    LX660-4077-T260/L7R003 SERVO SIGNAL CABLE STRAIGHT cable
    LX660-4077-T292/L6R003 SERVO SIGNAL CABLE STRAIGHT CONNECTOR cable
    LX660-4077-T293/L5R003 SERVO SIGNAL CABLE ELBOW CONNECTOR cable
    LX660-4077-T293/L6R003 SERVO SIGNAL CABLE ELBOW CONNECTOR cable
    LX660-4077-T293/L7R003 SERVO SIGNAL CABLE ELBOW CONNECTOR cable
    LX660-4077-T296/L10R03 SERVO SIGNAL CABLE STRAIGHT CONNECTOR cable
    LX660-4077-T296/L14R03 SERVO SIGNAL CABLE STRAIGHT CONNECTOR cable
    LX660-4077-T296/L16R03 SERVO SIGNAL CABLE STRAIGHT CONNECTOR cable
    LX660-4077-T297/L10R03 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L12R03 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L14R03 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L4R003 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L5R003 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L6R003 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L7R003 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T297/L8R003 SERVO SIGNAL CABLE ALPHA I SERIES ELBOW cable
    LX660-4077-T310/L8R003 SPINDLE SIGNAL CABLE ALPHA I /BETA i SERIES MOTOR cable
    LX660-8000-T004/L7R003 SERVO FEEDBACK CABLE cable
    LX660-8007-T012/L1R003 I/O CONNECTION CABLE cable
    LX660-8015-T001/L7R003/B SERVO MOTOR FEED BACK CABLE cable
    LX660-8024-T013/L1R003 SIGNAL CABLE MOP-CNC cable
    LX660-8050-T008/L6R003 POWER CABLE SERVO MOTOR cable
    LX660-8077-T201/L7R003/B SERVO POWER CABLE cable
    LX660-8077-T213/L6R003 SERVO POWER CABLE STRAIGHT cable
    LX660-8077-T213/L7R003 SERVO POWER CABLE STRAIGHT cable
    LX660-8077-T214/L7R003 SPINDLE/SERVO POWER CABLE cable
    LX660-8077-T260/L5R003 SERVO POWER CABLE ALPHA I SERIES STRAIGHT cable
    LX660-8077-T260/L6R003 SERVO POWER CABLE ALPHA I SERIES STRAIGHT cable
    LX660-8077-T260/L7R003 SERVO POWER CABLE ALPHA I SERIES STRAIGHT cable
    LX660-8077-T260/L8R003 SERVO POWER CABLE ALPHA I SERIES STRAIGHT cable
    LX660-8077-T267/L6R003 SERVO POWER CABLE ALPHA I SERIES ELBOW cable
    LX660-8077-T271/L12R03 SERVO POWER CABLE ALPHA I SERIES ELBOW cable
    LX660-8077-T308/L5R003 SERVO/SPINDLE MOT POWER CABLE STRAIGHT CONNECTOR 6 X 1 MM2 cable
    LX660-8077-T318/L5R003 SERVO POWER CABLE ALPHA i SERIES MOTOR cable
    LX660-8077-T318/L7R003 SERVO POWER CABLE ALPHA i SERIES MOTOR cable
    LX660-8077-T320/L7R003 SERVO POWER CABLE ALPHA i SERIES MOTOR cable
    LX98L-0001-0911 VACUUM PUMP EXH. FILT (QTY1) Laser Parts
    LX98L-0040-0093/1.0L1 EXHAUST PUMP OIL SERIES I 1000 ml Laser Parts
    MS3057-10A CLAMP consumable parts
    MS3057-12A CLAMP consumable parts
    MS3057-4A CLAMP consumable parts
    MS3102A10SL-3P BRAKE CONNECTO, R 3 PINS consumable parts
    MS3102A18-10P CONNECTOR consumable parts
    MS3102A20-29PW CONNECTOR MOTOR 5M F consumable parts
    MS3102A22-22P CONNECTOR consumable parts
    MS3108B10SL-3S CONNECTOR consumable parts
    MS3108B18-10S CONNECTOR consumable parts
    MS3108B20-29S CONNECTOR L consumable parts
    MS3108B20-29SW FEEDBACK CONNECTOR consumable parts
    MS3108B22-14S CONNECTOR consumable parts
    MS3108B22-22S CONNECTOR consumable parts
    MS3108B24-10S CONNECTOR consumable parts
    P413/SFAB250/402A FUSE P413, 1.3 A ALARM FUSE BLACK 250V AC consumable parts
    P430/SFAB250/402A FUSE P430, 3.0 A ALARM FUSE BLACK 250V AC consumable parts
    P450/SFAB250/402A FUSE P450, 5.0 A ALARM FUSE BLACK 250V AC consumable parts
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
